19 Tax Exemption Selectors
A tax exemption selector consists of rules that associate account, service, profile, and event attributes with tax exemption codes. You use a tax exemption selector in a charge offer to apply tax exemptions based on the rule results.
You must create all tax exemption codes before creating your tax exemption selectors. See "Creating Tax Exemption Codes".
For information on using tax exemption selectors, see:
For overview information, see "About Selectors" in PDC Creating Product Offerings.
Creating a Tax Exemption Selector
To create a tax exemption selector:
If you haven't done so already, create your tax exemption codes. See "Creating Tax Exemption Codes".
In the Pricing section of the navigation pane, under Models & Selectors, click Create Tax Exemption Selector.
Specify general information for the tax exemption selector. See "Specifying Tax Exemption Selector General Information".
Select the attributes to use in the tax exemption selector rules. See "Selecting Attributes for Tax Exemption Selector Rules".
Create rules for the tax exemption selector. See "Creating Tax Exemption Selector Rules".
Related Topics
To specify general information for a tax exemption selector:
In the Pricing section of the navigation pane, under Models and Selectors, click Create Tax Exemption Selector.
The Create Tax Exemption Selector page appears.
In the General Information section, enter a unique name and a description for the tax exemption selector.
From the Service list, select a service to associate with the tax exemption selector.
From the Events list, select one or more events to associate with the tax exemption selector.
From the Rating Profiles list, select one or more rating profiles to associate with the tax exemption selector.
From the Pricing Profile list, select a pricing profile to associate with the tax exemption selector.
Click Next.
The Rule Attributes tab appears.
Related Topics
To create rules for a tax exemption selector, you must first specify the customer, service, event, and profile attributes to use in the rules. The attributes available depend on the service, event, rating profile, and pricing profile you selected.
To specify attributes for tax exemption selector rules:
Go to the Rule Attributes tab of the Create Tax Exemption Selector page.
In the Select Fields for Rules section, click the Add icon in the table toolbar.
The Select Field dialog box appears.
Select at least one field to use in the rules.
To select multiple fields at the same time, press and hold the CTRL key during selection.
The selected fields are included in every rule defined for the tax exemption selector, but in each rule, you can override a field's default value.
Click OK.
The selected fields are added to the table, with one attribute field per row.
Click the Value Type cell, and select a value type from the list.
Click the Operator cell, and select an operator from the list.
In the Default column, do one of the following:
If you selected Single Value, enter a value directly in the table cell.
If you selected List of Values:
Click the cell.
The Enter Value dialog box appears.
Click the List of Values cell, and enter a value in the table cell.
To add other values to the list, click the Add icon and enter values.
Click OK.
The values, separated by semicolons, are added to the cell.
Click Next.
The Rules tab appears.
Related Topics
Tax exemption selectors use rules to determine which tax exemption code to apply to an event.
The selector evaluates rules in the order they appear in the table. You can change the order by moving a row up or down, or by entering a different priority number.
To create a tax exemption selector rule:
Go to the Rules tab of the Create Tax Exemption Selector page.
(Optional) From the Effective Period list, click Manage to add or change the effective period.
The effective period indicates when the rules are valid. The default effective period starts immediately and never ends.
If the selector contains multiple effective periods, select one.
In the table, click the Add Rule icon in the table toolbar.
A row is added to the table.
Tip:
You can also add a row by clicking the Actions menu and then selecting Insert Rule Above or Insert Rule Below.
Click the Priority cell, and enter the priority number.
Click the Rule Name cell, and enter a unique name for the rule.
Click the cell for each attribute, and enter a value.
In the Tax Exemption Code cell, select a tax exemption code.
Click Finish.
Related Topics
Create Tax Exemption Selector Page Reference
Use the Create Tax Exemption Selector page to create rules that associate subscriber, service, profile, and event attributes with tax exemption codes.
For a description of the fields, see the following:
General Information Section
Use the General Information section to provide a name and description for the tax exemption selector and to associate it with a service, event type, rating profile, and pricing profile.
| Field | Description |
Name, Description |
Enter a unique name and a description. The name must be unique across tax exemption selectors. |
Service |
Select the service type to which the tax exemption selector applies. |
Events |
Select one or more event types to which the tax exemption selector applies. |
Rating Profiles |
Select one or more rating profiles for the tax exemption selector. |
Pricing Profile |
Select the pricing profile for the tax exemption selector. |
Rule Attributes Section
Use the Rule Attributes section to specify the account, service, event, and profile attributes to include in your tax exemption selector rules.
For a description of the subsections in the Rule Attributes section, see:
Select Fields for Rules Table
The table lists the attribute fields to include in the rules. In the table, you can add or delete fields, add or remove columns, or reorder the columns. See "Working with Tables" for more information.
Click the Add icon to add fields using the Select Field dialog box. See "Select Field Dialog Box".
| Column Name | Description |
Field |
Displays the name of the customer, service, event, or profile attribute field you specified in the "Select Field Dialog Box". |
Value Type |
Select one of the following:
Operator |
Displays the operator type, which is dependent on the Value Type entry.
Default |
Specify a default value for the field. If the operator is Equals, enter a value. If the operator is Contained in List, clicking on the cell opens the Select Field dialog box. In the Select Field dialog box, enter a value in each row. Note: The default value of asterisk (*) specifies the field can contain any value. |
Use the Select Field dialog box to specify the attribute fields to evaluate. The dialog box includes one or more of the following categories: Customer, Service, Event, and Profile.
Expand a category to view the attribute fields you can add to a rule. Select a field name to add it your rule. To select multiple fields at the same time, press and hold the CTRL key during selection.
Rules Section
Use the Rules section to associate each rule to a tax exemption code.
Click the Add icon in the table to add rules.
The table in this section lists the rules in the order that the selector evaluates them. The selector returns the tax exemption code of the first rule that matches the values in the event.
You can select a rule and move it up or down if you wish to reorder the rules.
| Column | Description |
Effective Period |
(Optional) Set the start and end dates to specify the period when the rules in the selector are valid. The default effective period starts immediately and never ends. From the Effective Period list, click Manage to add or change an effective period. See "Manage Effective Periods Dialog Box". |
Priority |
Enter the rule's priority. This table displays rules in numerical order, starting with priority 1. The rules are evaluated in order of priority. When a rule includes multiple attributes (fields), BRM processes the attributes from left to right. Reorder a rule in either of the following ways:
The priority numbers of all rules affected by the move are changed. |
Rule Name |
Enter a unique name for the rule. |
Field Name |
Enter a value. To apply the rule to an event, the subscriber, service, profile, or event value must match the corresponding value. Note: An asterisk (*) matches all values in the corresponding field. |
Tax exemption code |
Select the name of the tax exemption code to associate with the rule. |
Use the Manage Effective Periods dialog box to add or change effective periods.
To add a new effective period, click the Add icon. In the Add New Effective Period dialog box, enter a start date or click the date selector to select a date.
To change the effective period that starts immediately, deselect Immediately and enter a new start date or click the date selector to select a date.
Related Tasks
