69 Starting and Stopping Pipeline Manager
This chapter describes how to start and stop Oracle Communications Billing and Revenue Management (BRM) Pipeline Manager framework components and pipelines.
Customizing the pin_ctl Utility Environment Variables for Pipeline Manager
Some BRM components need environment variables set before starting. You can edit the pin_ctl.conf file to change the environment variables if yours are different from the default settings.
Open the pin_ctl.conf file in BRM_home/bin.
To define environment variables for pipeline registry files, find the following lines:
# registry details for pipeline services aaa env_platform:common env_variable:AAA_REGISTRY env_val:$IFW_HOME/conf/diameter_charge.reg rtp env_platform:common env_variable:RTP_REGISTRY env_val:$IFW_HOME/conf/wirelessRealtime.reg bre env_platform:common env_variable:BRE_REGISTRY env_val:$IFW_HOME/conf/wireless.reg
Add the following line for each pipeline component that uses a registry file:
component env_platform:common env_variable:registry_variable env_val:$IFW_HOME/registry_file
where:
component is the pipeline component name.
registry_variable is the environment variable to set before starting component. The syntax for pipeline registry environment variables is *_REGISTRY.
registry_file is the path and file name for the pipeline registry file.
For example:
Save and close the file.
Starting Pipeline Manager Components by Using pin_ctl
To add a custom Pipeline Manager component to the components list, use the :pipeline parameter. For example:
4 bre_custom:pipeline
To start a BRM component by using the pin_ctl utility:
Edit the BRM_home/bin/pin_ctl.conf configuration file.
Copy the pipeline_home/bin/ifw binary file to pipeline_home/bin/component, where component is the pipeline component name.
Go to the BRM_home/bin directory.
Run the pin_ctl utility with the start action:
pin_ctl start component
where component is the component you want to start.
Starting and Stopping Pipeline Manager Manually
You can stop and start Pipeline Manager by using the command line instead of by using the pin_ctl utility.
If you start Pipeline Manager manually, you cannot use the pin_ctl utility to control Pipeline Manager (for example, to stop it or to get the status).
You start an instance of Pipeline Manager by using the following command from the pipeline_home directory:
bin/ifw -r RegistryFile
where RegistryFile is the name of the registry file.
If Pipeline Manager cannot establish a connection with the Pipeline Manager database (most likely because the database is down), you receive an error message and the Pipeline Manager startup is canceled.
The general syntax for the ifw command and parameters is:
ifw -r RegistryFile | -h | -v [-r RegistryFile]
where:
-r RegistryFile
Starts Pipeline Manager with the specified registry file.
-h
Displays the syntax and parameters.
Displays the version of Pipeline Manager. If you use the -r parameter, it also displays the version and name of data and function modules. For example:
ifw -v -r conf/wireless.reg
Module ifw.DataPool.Listener.Module Name: DAT_Listener, Version: 10010
Pipeline Manager displays Ready for processing when startup procedures are completed.
You stop Pipeline Manager by using the following semaphore entry:
ifw.Active = FALSE
Starting and Stopping Individual Pipelines
When you start Pipeline Manager, the Controller starts all pipelines. However, you can stop or restart individual pipelines by using semaphores.
When a pipeline cannot establish a connection with the Pipeline Manager database (most likely because the database is down), you receive an error message and the pipeline startup is canceled.
To start an individual pipeline, use the following semaphore entry:
ifw.Pipelines.PipelineName.Active = True
where PipelineName is the name of the pipeline.
To stop an individual pipeline, use the following semaphore entry:
ifw.Pipelines.PipelineName.Active = False
If files are added to the input directory after a pipeline is stopped and before it is restarted, the files are processed in order based on their last modified timestamp.
Pipeline Manager includes a set of Perl scripts, and associated semaphore files, that you can use to start and stop various types of pipelines and perform other system administration tasks. See "Using Perl Scripts to Start and Stop Pipeline Manager".
Restarting Pipeline Manager after an Abnormal Shutdown
Some modules track data in data files. If an abnormal shutdown occurs, you must delete the data files that were in progress when the shut-down occurred.
Table 69-1 describes the files and scripts used for starting and stopping pipelines:
Table 69-1 Scripts for Starting and Stopping Pipelines
| Semaphore and Perl script file names | Description |
start_all_pipeline.reg start_all_pipeline.pl |
Starts all pipelines configured in the start_all_pipeline.reg semaphore file. By default, this list includes these pipelines:
If you add custom pipelines, add their names to the semaphore file according to the default examples. Important:
start_all_rate.reg start_all_rate.pl |
Starts the ALL_RATE pipeline. |
start_DiscountPipeline.reg start_DiscountPipeline.pl |
Starts the discount pipeline (DiscountPipeline). |
start_main_stop_rerating.reg start_main_stop_rerating.pl |
Starts these pipelines:
Stops these pipelines:
start_pre_process.reg start_pre_process.pl |
Starts the preprocessing pipeline (PRE_PROCESS). |
start_pre_recycle.reg start_pre_recycle.pl |
Starts the pre-recycle pipeline (PRE_RECYCLE). |
start_RealtimePipelineGPRS.reg start_RealtimePipelineGPRS.pl |
Starts the real-time GPRS pipeline (RealtimePipelineGPRS). |
start_RealtimePipelineGSM.reg start_RealtimePipelineGSM.pl |
Starts the real-time GSM pipeline (RealtimePipelineGSM). |
start_RealtimePipelineZone.reg start_RealtimePipelineZone.pl |
Starts the real-time zoning pipeline (RealtimePipelineZone). |
start_recycle.reg start_recycle.pl |
Starts recycling rejected CDRs. |
start_rerating_stop_main.reg start_rerating_stop_main.pl |
stop_all_pipeline.reg stop_all_pipeline.pl |
Stops all the pipelines configured in the stop_all_pipeline.reg semaphore file. By default, this list includes these pipelines:
If you add custom pipelines, add their names to the semaphore file according to the default examples. |
stop_all_rate.reg stop_all_rate.pl |
Stops the ALL_RATE pipeline. |
stop_DiscountPipeline.reg stop_DiscountPipeline.pl |
Stops the discount pipeline (DiscountPipeline). |
stop_pre_process.reg stop_pre_process.pl |
Stops the preprocessing pipeline (PRE_PROCESS). |
stop_pre_recycle.reg stop_pre_recycle.pl |
Stops the pre-recycle pipeline (PRE_RECYCLE). |
stop_RealtimePipelineGPRS.reg stop_RealtimePipelineGPRS.pl |
Stops the real-time pipeline for GPRS (RealtimePipelineGPRS). |
stop_RealtimePipelineGSM.reg stop_RealtimePipelineGSM.pl |
Stops the real-time pipeline for GSM (RealtimePipelineGSM). |
stop_RealtimePipelineZone.reg stop_RealtimePipelineZone.pl |
Stops the real-time pipeline for zoning (RealtimePipelineZone). |
