27 Customizing Billing Care Labels
Learn how to use the SDK to customize Oracle Communications Billing Care labels.
Topics in this document:
About the Billing Care Resource Bundle
Billing Care uses an XML Localization Interchange File Format (XLF) file resource bundle for customization of Billing Care labels and localization. The default English language XLF file (BillingCareResources_en.xlf) is available in the SDK_home/references folder, where SDK_home is the directory where you installed the SDK. This file contains Billing Care key-value mappings for Billing Care labels, organized into functional group elements.
Customizing the Resource Bundle
Customize the Billing Care labels by creating a custom XLF file containing your label values. After creating your XLF file, use the orai18n-js.jar, included in the Billing Care SDK, to generate the required JavaScript files for the customizations shared library deployed in the Billing Care domain.
The following XLF customizations are supported:
Creating a Custom XLF File
Label customizations are configured in a custom XLF file.
To create a custom XLF file:
Create the customized_en.xlf file in your myproject/web/resources/translation/ directory, where myproject is your NetBeans IDE project containing your Billing Care customizations.
Open the customized_en.xlf file in an editor and add the following text:
<?xml version="1.0" encoding="utf-8" ?> <xliff version="1.0"> <file original="test_en.js" source-language="EN-US" target-language="EN-US" datatype="JavaScript"> <header/> <body> </body> </file> </xliff>
Modifying Existing Labels
Modify an existing label by adding a group element in your custom XLF file containing <trans-unit>
elements for the labels you are changing. <trans-unit>
elements specify the source and target of a label to modify. For more information on the <trans-unit>
element, see:
http://docs.oasis-open.org/xliff/v1.2/os/xliff-core.html#trans-unit
Example 27-1 shows a sample <trans-unit>
element.
Example 27-1 Sample trans-unit Element for Modifying an Existing Label
<group id="common" restype="common"> <trans-unit id="INVALID_VALUE" translate="yes"> <source>Invalid MODIFIED</source> <target>Invalid MODIFIED</target> </trans-unit> </group>
To modify existing labels:
In the body section of the customized_en.xlf file, add a group element with the same name as the label you want to update (for example,
common
Add a <
trans-unit>
element using the same label name as the default label you are modifying. -
Add the new custom label (for example,
Invalid MODIFIED
Save your customized_en.xlf file.
Adding New Labels
Add new labels by adding a custom_extensions
group containing your new labels in your customized_en.xlf file.
Example 27-2 shows a sample new <group>
element.
Example 27-2 Sample group Element for Adding New Label
<group> <group id="custom_extensions" restype="sdk"> <trans-unit id="TEST_CUSTOM" translate="yes"> <source>Custom New Value</source> <target>Custom New Value</target> </trans-unit> </group>
To add a new label:
Add a new
<group>
element with a custom_extensions<group id>
value in your customized_en.xlf file inside the<body>
element. See the BillingCareResources_en.xlf file for group element examples.Note:
The
<group id>
must be custom_extensions. -
Add the new labels inside your
<group>
element. -
Creating Required JavaScript Files for Deployment
After completing your label customizations, generate the required JavaScript files to add to your customizations shared library deployed to the Billing Care domain.
To generate the required JavaScript files:
Add the customized_en.xlf and default BillingCareResources_en.xlf files to the myproject/web/resources/translation folder, where myproject is the NetBeans IDE project folder containing your Billing Care customizations.
Open a shell or command window, and change directory to the myproject/web/resources/translation folder.
Enter the following command using an absolute path to orai18n-js.jar.
java –jar full_path/orai18n-js.jar –from XLF –to JS -file BillingCareResources_en.xlf Customized_en.xlf
where full_path is the directory where orail8n-js.jar is stored. This JAR is included in the SDK_home/libs directory.
Two JavaScript files are created. One file contains the default resources of Billing Care, and the other file contains your customizations.
Delete the BillingCareResources_en.xlf file.
Package and deploy your resource bundle customizations to your Billing Care domain.
For more information, see "Packaging and Deploying Customizations".
Verify your changes in Billing Care.
Localizing Billing Care into Other Languages
You can customize Billing Care to use alternative language labels by translating the BillingCareResources_en.xlf file into another language. For example, create a file named BillingCareResources_is.xlf to localize Billing Care in Icelandic.
To configure Billing Care with an alternative language localization:
Translate the BillingCareResources_en.xlf file into a version specific to the language you are enabling. For example, create a file named BillingCareResources_XX.xlf, where XX is the two-character language code you are enabling.
Copy the BillingCareResources_XX.xlf file to the myproject/web/resources/translation directory, where myproject is your NetBeans IDE project directory containing your Billing Care customizations.
Run the conversion utility using orail8n-js.jar to create the JavaScript for the language you are enabling:
java -jar full_path/orai18n-js.jar -from XLF -to JS -file BillingCareResources_XX.xlf
