9 TAP and EDR Field Mappings
This chapter describes the mapping of fields from TAP file to the EDR container that Oracle Communications Billing and Revenue Management (BRM) uses when processing TAP input files and the mapping of fields from EDR container to TAP file used for generating TAP output files.
TAP-to-EDR Mapping
When processing incoming TAP files, BRM copies input data from TAP fields into EDR container fields. The table below lists the TAP fields and the corresponding EDR field(s) where the data from the TAP field is stored.
Some of the fields in the TAP file can map to multiple fields in the EDR container description file. For example, both the ACTUAL_DELIVERY_TIMESTAMP and ACT_DELIVERY_UTC_TIME_OFFSET fields in the Associated Content Extension Record of the EDR container description file store the data from the Actual Delivery Timestamp field in the TAP file.
For some other TAP fields, placement of the field within the TAP file determines where to copy the field's data in the EDR container description file. For example, depending on the context within the TAP file, Location Identifier can be mapped to the LOCATION_LIST.IDENTIFIER field in either Associated Location Extension Record or Associated Content Extension Record of the EDR container description file as shown in Table 9-1.
Table 9-1 TAP-to-EDR Mapping
TAP Field EDR Field Comments
Access Point Name NI
GPRS Destination Camel Group:
  • DETAIL.ASS_CAMEL_EXT.DEST_GPRS_APN_ADDRESS
GPRS Destination, other cases:
  • DETAIL.ASS_GPRS_EXT.APN_ADDRESS
Access Point Name NI and Access Point Name OI are mapped to a single EDR field as concatenated and comma-separated items.
Action Code
DETAIL.ASS_GSMW_EXT.SS_PACKET.ACTION_CODE
No comment.
DETAIL.ASS_CONT_EXT.ACTUAL_DELIVERY_TIMESTAMP
and
DETAIL.ASS_CONT_EXT.ACT_DELIVERY_UTC_TIME_OFFSET
The timestamp part of this item is mapped to DETAIL.ASS_CONT_EXT.ACTUAL_DELIVERY_TIMESTAMP and the UTC offset part is mapped to DETAIL.ASS_CONT_EXT.ACT_DELIVERY_UTC_TIME_OFFSET.
Advised Charge
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.ADVISED_CHARGE
No comment.
Advised Charge Currency
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.ADVISED_CHARGE_CURRENCY
No comment.
Age Of Location
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.AGE_OF_LOCATION
No comment.
Air Interface User Rate Requested
DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST.AIUR
and
DETAIL.ASS_GSMW_EXT.BS_PACKET.AIUR_REQUESTED
No comment.
Basic HSCSD Parameters
This is a block.
Basic Service Used
This is a block.
Bearer Service Code
DETAIL.BASIC_SERVICE
No comment.
Call Event Details Count
TRAILER.TAP_TOTAL_NUMBER_OF_RECORDS
No comment.
Call Event Start Timestamp
DETAIL.CHARGING_START_TIMESTAMP
and
DETAIL.UTC_TIME_OFFSET
The timestamp part of this item is mapped to DETAIL.CHARGING_
START_TIMESTAMP and the UTC offset part is mapped to DETAIL.UTC_
TIME_OFFSET.
Call Reference
DETAIL.ASS_LOCN_EXT.CALL_REFERENCE
For Location Services group, Call Reference is saved in the EDR field.
Call Type Level 1
DETAIL.CONNECT_TYPE
Call Type Level 1 and Call Type Level 2 are mapped to the EDR field as concatenated comma-separated items.
Call Type Level 2
DETAIL.CONNECT_TYPE
Call Type Level 3
DETAIL.CONNECT_SUB_TYPE
No comment.
Called Country Code
DETAIL.CALLED_COUNTRY_CODE
No comment.
Called Number
DETAIL.B_NUMBER & DETAIL.INTERN_B_NUMBER_ZONE & DETAIL.ASS_GSMW_EXT.DIALED_DIGITS
The called number is the representation of the number dialled by the subscriber.
Called Place
DETAIL.DESCRIPTION
Destination Group.
The TAP fields Called Place and Called Region are mapped to the EDR field as concatenated comma-separated items.
Called Region
DETAIL.DESCRIPTION
Destination Group.
Camel Call Reference
DETAIL.ASS_CAMEL_EXT.CAMEL_REFERENCE_NUMBER
No comment.
CAMEL Destination Number
DETAIL.ASS_CAMEL_EXT.DEST_GSMW_NUMBER_ORIGINAL
No comment.
Camel Invocation Fee
DETAIL.ASS_CAMEL_EXT.SERVER_TYPE_OF_NUMBER
The charge for the CAMEL invocation after discounts have been deducted.
Camel Initiated CF Indicator
DETAIL.ASS_CAMEL_EXT.CAMEL_INITIATED_CF_INDICATOR
No comment.
Camel Modification
DETAIL.ASS_CAMEL_EXT.CAMEL_MODIFICATION_LIST
All Camel Modification fields present in Camel Modification List are mapped to the EDR field as concatenated comma-separated items.
Camel Server Address
DETAIL.ASS_CAMEL_EXT.SERVER_ADDRESS
No comment.
CAMEL Service Key
DETAIL.ASS_CAMEL_EXT.SERVICE_KEY
No comment.
CAMEL Service Level
DETAIL.ASS_CAMEL_EXT.SERVICE_LEVEL
No comment.
CAMEL Service Used
This is a block.
Cause For Termination
DETAIL.CALL_COMPLETION_INDICATOR
If the TAP field value is less than 10, it is prefixed with 0.
Cell Identity
GPRS Network Location:
  • DETAIL.ASS_GPRS_EXT.CELL_ID
Network Location:
  • DETAIL.ASS_GSMW_EXT.CELL_ID
Present within groups:
  • GPRS Network Location
  • Network Location
Channel Coding Acceptable
DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.CHANNEL_CODING_OK_LIST
All channel coding fields present in Channel Coding Acceptable List are mapped to the EDR field as concatenated comma-separated items.
Channel Coding Used
HSCSD Parameter Modification:
  • DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST.CHANNEL_CODING_USED
Basic HSCSD Parameters:
  • DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.CHANNEL_CODING_USED
Channel Coding Acceptable List:
  • DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.CHANNEL_CODING_OK_LIST
No comment.
Charge
DETAIL.ASS_CBD.CP.CHARGED_AMOUNT_VALUE
No comment.
Charge Refund Indicator
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.CHARGE_REFUND_INDICATOR
No comment.
Charge Type
Taxation:
  • DETAIL.ASS_CBD.TP.CHARGE_TYPE
Charge Detail:
  • TRAILER.TOTAL_CHARGE_VALUE_LIST.CHARGE_TYPE
  • DETAIL.ASS_CBD.CP.IMPACT_CATEGORY
  • Taxation, when the associated Tax Rate Code references a tax applied to a specific Charge Type.
  • Charge Detail
Chargeable Units
DETAIL.ASS_CBD.CP.CHARGEABLE_QUANTITY_VALUE
No comment.
Charged Party Equipment
DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.EQUIPMENT
This is a block.
Charged Party Home Identification
DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.HOMEID_LIST
This is a block.
Charged Party ID Type
DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.ID_LIST.TYPE
No comment.
Charged Party Identification
This is a block.
Charged Party Identifier
DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.ID_LIST.IDENTIFIER
No comment.
Charged Party Information
This is a block.
Charged Party Location
DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.LOCATION_LIST
This is a block.
Charged Party Status
DETAIL.USAGE_DIRECTION
No comment.
Charged Units
DETAIL.ASS_CBD.CP.ROUNDED_QUANTITY_VALUE
No comment.
Charging Characteristics
DETAIL.USAGE_CLASS
No comment.
Charging ID
DETAIL.ASS_GPRS_EXT.CHARGING_ID
No comment.
Charging Timestamp
Supplementary Service Used:
  • DETAIL.ASS_GSMW_EXT.SS_PACKET.CHARGING_START_TIMESTAMP
    and
  • DETAIL.ASS_GSMW_EXT.SS_PACKET.UTC_TIME_OFFSET
Location Service Usage
  • DETAIL.ASS_GPRS_EXT.SERVICE_USED_CHARGING_START_TIMESTAMP
    and
  • DETAIL.ASS_GPRS_EXT.SERVICE_USED_UTC_TIME_OFFSET
  • DETAIL.ASS_GPRS_EXT.GS_PACKET.CHARGING_START_TIMESTAMP
    and
  • DETAIL.ASS_GPRS_EXT.GS_PACKET.UTC_TIME_OFFSET
Basic Service Used:
  • DETAIL.ASS_GSMW_EXT.BS_PACKET.CHARGING_START_TIMESTAMP
    and
  • DETAIL.ASS_GSMW_EXT.BS_PACKET.UTC_TIME_OFFSET
GPRS Call (Record type MSS, SCU, and VAS):
  • DETAIL.CHARGING_START_TIMESTAMP
    and
  • DETAIL.UTC_TIME_OFFSET
GPRS Service Usage Block:
GPRS Service Used Block:
  • Supplementary Service Used. The timestamp is mandatory and occurs within Supplementary Service Event.
  • Location Service Usage. The timestamp is only present where it is not the same as the associated LCS Request Timestamp.
  • Basic Service Used. The timestamp is only present where it is not the same as an associated Call Event Start Timestamp.
CLIR Status Indicator
Call Originator and SCU Basic Information:
  • DETAIL.USAGE_CLASS
  • DETAIL.ASS_ROAMING_EXT.CLIR_INDICATOR
Third Party Information:
  • DETAIL.ASS_GSMW_EXT.SS_PACKET.CLIR_INDICATOR
  • Call Originator where available.
  • SCU Basic Information where available and the Charged Party Status indicates a terminating short message.
  • Third Party Information where available.
Commission
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.COMMISSION
No comment.
Completion Timestamp
DETAIL.CHARGING_END_TIMESTAMP
No comment.
Content Charging Point
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.CONTENT_CHARGING_POINT
No comment.
Content Provider
DETAIL.ASS_CONT_EXT.SERVING_PARTIES_INFO.PROVIDER_LIST
This is a block.
Content Provider ID Type
LCS SP Identification:
  • DETAIL.ASS_LOCN_EXT.LCSSP_INFO.ID_LIST.TYPE
Content Provider:
  • DETAIL.ASS_CONT_EXT.SERVING_PARTIES_INFO.PROVIDER_LIST.TYPE
Mandatory within groups:
  • LCS SP Identification
  • Content Provider
Content Provider Identifier
  • DETAIL.ASS_LOCN_EXT.LCSSP_INFO.ID_LIST.IDENTIFIER
Content Provider:
  • DETAIL.ASS_CONT_EXT.SERVING_PARTIES_INFO.PROVIDER_LIST.IDENTIFIER
  • Content Provider
Content Provider Name
DETAIL.ASS_CONT_EXT.SERVING_PARTIES_INFO.PROVIDER_NAME
No comment.
Content Service Used
This is a block.
Content Transaction Code
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.CONTENT_TRANSACTION_CODE
No comment.
Content Transaction Type
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.CONTENT_TRANSACTION_TYPE
No comment.
CSE Information
DETAIL.ASS_CAMEL_EXT.CSE_INFORMATION
No comment.
Customer ID Type
Tracking Customer Identification:
  • DETAIL.ASS_LOCN_EXT.TRACKING_CUST_INFO.ID_LIST.TYPE
Tracked Customer Identification:
  • DETAIL.ASS_LOCN_EXT.TRACKED_CUST_INFO.ID_LIST.TYPE
  • Tracking Customer Identification
  • Tracked Customer Identification
Customer Identifier
  • DETAIL.ASS_LOCN_EXT.TRACKING_CUST_INFO.ID_LIST.IDENTIFIER
  • DETAIL.ASS_LOCN_EXT.TRACKED_CUST_INFO.ID_LIST.IDENTIFIER
Data Volume Incoming
GPRS Service Used:
  • DETAIL.ASS_GPRS_EXT.GS_PACKET.VOLUME_RECEIVED
  • DETAIL.VOLUME_RECEIVED
Content Service Used:
  • DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.DATA_VOLUME_INCOMING
  • GPRS Service Used. Mandatory.
  • Content Service Used when available.
Data Volume Outgoing
GPRS Service Used:
  • DETAIL.ASS_GPRS_EXT.GS_PACKET.VOLUME_SENT
  • DETAIL.VOLUME_SENT
  • DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.DATA_VOLUME_OUTGOING
Day Category
DETAIL.ASS_CBD.CP.DAY_CODE
No comment.
Default Call Handling Indicator
DETAIL.ASS_CAMEL_EXT.DEFAULT_CALL_HANDLING_INDICATOR
No comment.
Deposit Timestamp
The timestamp part of this item is mapped to DETAIL.CHARGING_START_TIMESTAMP and the UTC offset part is mapped to DETAIL.UTC_TIME_OFFSET.
Destination Network
DETAIL.DESTINATION_NETWORK
No comment.
Dialled Digits
  • DETAIL.ASS_GSMW_EXT.DIALED_DIGITS
  • DETAIL.C_NUMBER
No comment.
Discountable Amount
DETAIL.ASS_ROAMING_EXT.DISCOUNTABLE_AMOUNT
The actual part of the Charge/Tax/CAMEL Invocation Fee to which the Discount Value and Discount Rate (Code) relate.
Discount Code
DETAIL.ASS_CBD.CP.GRANTED_DISCOUNT_AMOUNT_VALUE
No comment.
Discount Value
No comment.
Distance Charge Band Code
DETAIL.ZONE_DESCRIPTION
No comment.
Dual Bearer Service Code
DETAIL.ASS_GSMW_EXT.BASIC_DUAL_SERVICE
The TAP field is prefixed with 1 and stored in the EDR field.
Dual Teleservice Code
The TAP field is prefixed with 0 and stored in the EDR field.
Earliest Call Timestamp
TRAILER.FIRST_START_TIMESTAMP
TRAILER.FIRST_CHARGING_UTC_TIME_OFFSET
The timestamp part of this item is mapped to TRAILER.FIRST_START_TIMESTAMP and the UTC offset part is mapped to TRAILER.FIRST_CHARGING_UTC_TIME_OFFSET.
Equipment ID
Charged Party Equipment:
  • DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.EQUIPMENT.IDENTIFIER
Tracking Customer Equipment:
  • DETAIL.ASS_LOCN_EXT.TRACKING_CUST_INFO.EQUIPMENT.IDENTIFIER
Tracked Customer Equipment:
  • DETAIL.ASS_LOCN_EXT.TRACKED_CUST_INFO.EQUIPMENT.IDENTIFIER
  • Charged Party Equipment
  • Tracking Customer Equipment
  • Tracked Customer Equipment
Equipment ID Type
  • DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.EQUIPMENT.TYPE
  • DETAIL.ASS_LOCN_EXT.TRACKING_CUST_INFO.EQUIPMENT.TYPE
  • DETAIL.ASS_LOCN_EXT.TRACKED_CUST_INFO.EQUIPMENT.TYPE
ESN
DETAIL.ASS_GSMW_EXT.DEVICE_NUMBER
No comment.
Exchange Rate Code
DETAIL.ASS_CBD.CP.EXCHANGE_RATE
No comment.
File Available Timestamp
HEADER.TRANSMISSION_DATE
No comment.
File Creation Timestamp
HEADER.CREATION_TIMESTAMP
HEADER.UTC_TIME_OFFSET
The timestamp part of this item is mapped to HEADER.CREATION_TIMESTAMP and the UTC offset part is mapped to HEADER.UTC_TIME_OFFSET.
File Sequence Number
HEADER.SEQUENCE_NUMBER
HEADER.ORIGIN_SEQUENCE_NUMBER
No comment.
File Type Indicator
HEADER.DATA_TYPE_INDICATOR
No comment.
Fixed Network User Rate
DETAIL.ASS_GSMW_EXT.BS_PACKET.FNUR
No comment.
Fnur
No comment.
Fraud Monitor Indicator
DETAIL.FRAUD_MONITOR_INDICATOR
No comment.
Geographical Location
DETAIL.GEOGRAPHICAL_LOCATION
The EDR field contains comma-separated tag-value pairs that indicate the geographical location of the serving network, serving BID, serving location description, longitude, and latitude.
The tag values of the corresponding fields are as follows:
  • ServingNetwork: 1
  • ServingBID: 2
  • ServingLocationDescription: 3
  • Longitude: 4
  • Latitude: 5
Example 1: If the TAP field values are as follows:
  • ServingNetwork: AIRTEL
  • ServingBID: AIRBID
  • ServingLocationDescription: Bangalore
  • Longitude: 111
  • Latitude: 103
The value of DETAIL.GEOGRAPHICAL
_LOCATION would be: 1,AIRTEL, 2,AIRBID, 3,Bangalore, 4,111,5,103
Example 2: If the TAP field values are as follows:
  • Latitude: 103
_LOCATION would be: 1,AIRTEL, 2,AIRBID, 5,103
Guaranteed Bit Rate
DETAIL.ASS_ROAMING_EXT.GUARANTEED_BIT_RATE
Describes the bitrate the UMTS bearer service must guarantee to the user or application for circuit switched UMTS.
GPRS Destination
GPRS Basic Call Information:
  • DETAIL.ASS_GPRS_EXT.PDP_REMOTE_ADDRESS
CAMEL Service Used:
  • DETAIL.ASS_CAMEL_EXT.DEST_GPRS_PDP_REMOTE_ADDRESS
  • GPRS Basic Call Information. Mandatory.
  • CAMEL Service Used where GPRS Destination has been modified by the CAMEL server.
Home Bid
DETAIL.ASS_ROAMING_EXT.HOME_BID
The Home BID (Billing Identifier) is a code identifying the home market area of the Chargeable Subscriber.
Home ID Type
Charged Party Home Identification:
  • DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.HOMEID_LIST.TYPE
Tracking Customer Home ID:
  • DETAIL.ASS_LOCN_EXT.TRACKING_CUST_INFO.HOME_ID_LIST.TYPE
Tracked Customer Home ID:
  • DETAIL.ASS_LOCN_EXT.TRACKED_CUST_INFO.HOME_ID_LIST.TYPE
  • Charged Party Home Identification
  • Tracking Customer Home ID
  • Tracked Customer Home ID
Home Identifier
  • DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.HOMEID_LIST.IDENTIFIER
  • DETAIL.ASS_LOCN_EXT.TRACKED_CUST_INFO.HOME_ID_LIST.IDENTIFIER
  • DETAIL.ASS_LOCN_EXT.TRACKING_CUST_INFO.HOME_ID_LIST.IDENTIFIER
Home Location Description
DETAIL.ASS_ROAMING_EXT.HOMELOCATION_DESCRIPTION
A text description giving the home market area of the Chargeable Subscriber.
Horizontal Accuracy Delivered
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.H_ACCURACY_DELIVERED
No comment.
Horizontal Accuracy Requested
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.H_ACCURACY_REQUESTED
No comment.
HSCSD Indicator
DETAIL.ASS_ROAMING_EXT.HSCSD_INDICATOR
This indicator, set by the VPMN and passed to the Recipient, indicates that HSCSD has been used.
This is a block.
IMEI
  • DETAIL.ASS_GSMW_EXT.DEVICE_NUMBER
GPRS:
  • DETAIL.ASS_GPRS_EXT.DEVICE_NUMBER
Present within the group:
  • Equipment Identifier where available. Is not present when the terminal equipment is not involved in the call.
IMSI
  • DETAIL.ASS_GSMW_EXT.PORT_NUMBER
GPRS:
  • DETAIL.ASS_GPRS_EXT.PORT_NUMBER
  • Chargeable Subscriber when MIN is not present. Mandatory.
  • GSM Chargeable Subscriber when available.
  • Must be present for WLAN usage when IMSI is used for identifying the chargeable user.
Initiating Party
DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST.INITIATING_PARTY
No comment.
Internet Service Provider
DETAIL.ASS_CONT_EXT.SERVING_PARTIES_INFO.ISP_LIST
This is a block.
ISP ID Type
LCS SP Information:
  • DETAIL.ASS_LOCN_EXT.LCSSP_INFO.ISP_LIST.TYPE
Serving Parties Information:
  • DETAIL.ASS_CONT_EXT.SERVING_PARTIES_INFO.ISP_LIST.TYPE
No comment.
ISP Identifier
LCS SP Information:
  • DETAIL.ASS_LOCN_EXT.LCSSP_INFO.ISP_LIST.IDENTIFIER
  • DETAIL.ASS_CONT_EXT.SERVING_PARTIES_INFO.ISP_LIST.IDENTIFIER
No comment.
Latest Call Timestamp
TRAILER.LAST_START_TIMESTAMP
TRAILER.LAST_CHARGING_UTC_TIME_OFFSET
The timestamp part of this item is mapped to TRAILER.LAST_START_TIMESTAMP and the UTC offset part is mapped to TRAILER.LAST_CHARGING_UTC_TIME_OFFSET.
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.LCS_REQUEST_TIMESTAMP
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.LCS_REQ_UTC_OFFSET
The timestamp part of this item is mapped to DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.LCS_REQUEST_TIMESTAMP and the UTC offset part is mapped to DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.LCS_REQ_UTC_OFFSET.
This is a block.
LCS SP Information
This is a block.
LCS Transaction Status
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.LCS_TRANS_STATUS
No comment.
Local Currency
DETAIL.WHOLESALE_CHARGED_AMOUNT_CURRENCY
No comment.
Location Area Code
  • DETAIL.ASS_GPRS_EXT.LOCATION_AREA_INDICATOR
Network Location:
  • DETAIL.ASS_GSMW_EXT.LOCATION_AREA_INDICATOR
  • Network Location
except where not supported by the network or the call does not terminate at the equipment.
Location ID Type
Charged Party Location:
  • DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.LOCATION_LIST.TYPE
Tracked Customer Location:
  • DETAIL.ASS_LOCN_EXT.TRACKED_CUST_INFO.LOCATION_LIST.TYPE
Tracking Customer Location:
  • DETAIL.ASS_LOCN_EXT.TRACKING_CUST_INFO.LOCATION_LIST.TYPE
  • Charged Party Location
  • Tracked Customer Location
  • Tracking Customer Location
Location Identifier
  • DETAIL.ASS_CONT_EXT.CHARGED_PARTY_INFO.LOCATION_LIST.IDENTIFIER
  • DETAIL.ASS_LOCN_EXT.TRACKED_CUST_INFO.LOCATION_LIST.IDENTIFIER
  • DETAIL.ASS_LOCN_EXT.TRACKING_CUST_INFO.LOCATION_LIST.IDENTIFIER
This is a block.
Maximum Bit Rate
DETAIL.ASS_ROAMING_EXT.MAXIMUM_BIT_RATE
The maximum bit rate available for circuit switched UMTS.
Mdn
DETAIL.ASS_ROAMING_EXT.MOBILE_DIR_NUMBER
Mobile Directory Number.
Message Description Code
Message Description Code is not mapped to any EDR field. The DETAIL.DESCRIPTION field in the SCU Charge Type group contains description text with Message Description Code.
Message Status
Message Type
DETAIL.QOS_USED
No comment.
Min
DETAIL.ASS_ROAMING_EXT.MOBILE_ID_NUMBER
Mobile Identification Number is an item which uniquely identifies the subscriber who has used the network.
Modification Timestamp
DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST.MODIFICATION_TIMESTAMP
and
DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST.UTC_TIME_OFFSET
The timestamp part of this item is mapped to DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST.MODIFICATION_TIMESTAMP and the UTC offset part is mapped to DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST.UTC_TIME_OFFSET.
MSISDN
The TAP field is mapped to the following fields:
  • DETAIL.A_NUMBER
  • DETAIL.INTERN_A_NUMBER_ZONE
  • DETAIL.ASS_GSMW_EXT.A_NUMBER_USER
GPRS:
  • DETAIL.ASS_GPRS_EXT.A_NUMBER_USER
SCU:
MTC:
The EDR field is always prefixed with International Access Code.
  • Chargeable Subscriber or GPRS Chargeable Subscriber when IMSI is present. Should be associated with IMSI.
  • Present when expected in accordance with roaming agreement.
  • Present for WLAN network usage where the full IMSI or Network Access Identifier are not available.
DETAIL.ASS_ROAMING_EXT.NETWORKACCESS_IDENTIFIER
The Network Access Identifier (NAI) is a username identifying a unique customer when generating WLAN CDRs.
Network ID Type
  • PARTIES_INFO.NETWORK_LIST.TYPE
LCS SP Information:
  • DETAIL.ASS_LOCN_EXT.LCSSP_INFO.NETWORK_LIST.TYPE
No comment.
Network Identifier
  • PARTIES_INFO.NETWORK_LIST.IDENTIFIER
LCS SP Information:
  • DETAIL.ASS_LOCN_EXT.LCSSP_INFO.NETWORK_LIST.IDENTIFIER
No comment.
Network Init. PDP Context
DETAIL.ASS_GPRS_EXT.NETWORK_INITIATED_PDP
No comment.
Network Type
DETAIL.SOURCE_NETWORK_TYPE
No comment.
Number Of Channels
  • DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.NUMBER_OF_CHANNELS
  • DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST.MAX_NUMBER_OF_CHANNELS
No comment.
Number Of Channels Used
  • DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.NUMBER_OF_CHANNELS_USED
  • DETAIL.NUMBER_OF_UNITS
  • DETAIL.ASS_GSMW_EXT.BS_PACKET.HSCSD_INFO_PACKET.PM_LIST.NUMBER_OF_CHANNELS_USED
No comment.
Object Type
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.OBJECT_TYPE
No comment.
Operator Spec Information
DETAIL.OPERATOR_SPECIFIC_INFO [if Record type is record_GPRS]
HEADER.OPERATOR_SPECIFIC_INFO [record_Header]
TRAILER.OPERATOR_SPECIFIC_INFO [record_Trailer]
This is an optional repeating field which contains operator specific information.
Order Placed Timestamp
DETAIL.ASS_CONT_EXT.ORDER_PLACED_TIMESTAMP
DETAIL.ASS_CONT_EXT.ORDER_PLACED_UTC_TIME_OFFSET
The timestamp part of this item is mapped to DETAIL.ASS_CONT_EXT.ORDER_PLACED_TIMESTAMP and the UTC offset part is mapped to DETAIL.ASS_CONT_EXT.ORDER_PLACED_UTC_TIME_OFFSET.
Originating Network
No comment.
Paid Indicator
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.PAID_INDICATOR
A flag which shows that the Charged Party has paid for the service.
Partial Type Indicator
DETAIL.LONG_DURATION_INDICATOR
No comment.
Payment Method
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.PAYMENT_METHOD
No comment.
PDP Address
DETAIL.ASS_GPRS_EXT.PDP_ADDRESS
No comment.
PDP Context Start Timestamp
DETAIL.ASS_GPRS_EXT.PDP_CONTEXT_START_TIMESTAMP
DETAIL.ASS_GPRS_EXT.PDP_UTC_TIME_OFFSET
The timestamp part of this item is mapped to DETAIL.ASS_GPRS_EXT.PDP_CONTEXT_START_TIMESTAMP and the UTC offset part is mapped to DETAIL.ASS_GPRS_EXT.PDP_UTC_TIME_OFFSET.
Positioning Method
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.POSITIONING_METHOD
No comment.
Priority Code
DETAIL.QOS_REQUESTED
No comment.
QoS Delay
QoS Requested:
  • DETAIL.ASS_GPRS_EXT.QOS_REQUESTED_DELAY
  • DETAIL.ASS_GPRS_EXT.GS_PACKET.QOS_REQUESTED_DELAY
QoS Used:
  • DETAIL.ASS_GPRS_EXT.QOS_USED_DELAY
  • DETAIL.ASS_GPRS_EXT.GS_PACKET.QOS_USED_DELAY
No comment.
QoS Mean Throughput
QoS Requested:
  • DETAIL.ASS_GPRS_EXT.QOS_REQUESTED_MEAN_THROUGHPUT
  • DETAIL.ASS_GPRS_EXT.GS_PACKET.QOS_REQUESTED_MEAN_THROUGHPUT
QoS Used:
  • DETAIL.ASS_GPRS_EXT.QOS_USED_MEAN_THROUGHPUT
  • DETAIL.ASS_GPRS_EXT.GS_PACKET.QOS_USED_MEAN_THROUGHPUT
No comment.
QoS Peak Throughput
QoS Requested:
  • DETAIL.ASS_GPRS_EXT.QOS_REQUESTED_PEAK_THROUGHPUT
  • DETAIL.ASS_GPRS_EXT.GS_PACKET.QOS_REQUESTED_PEAK_THROUGHPUT
QoS Used:
  • DETAIL.ASS_GPRS_EXT.QOS_USED_PEAK_THROUGHPUT
  • DETAIL.ASS_GPRS_EXT.GS_PACKET.QOS_USED_PEAK_THROUGHPUT
No comment.
QoS Precedence
QoS Requested:
  • DETAIL.ASS_GPRS_EXT.QOS_REQUESTED_PRECEDENCE
  • DETAIL.ASS_GPRS_EXT.GS_PACKET.QOS_REQUESTED_PRECEDENCE
QoS Used:
  • DETAIL.ASS_GPRS_EXT.QOS_USED_PRECEDENCE
  • DETAIL.ASS_GPRS_EXT.GS_PACKET.QOS_USED_PRECEDENCE
No comment.
QoS Reliability
QoS Requested:
  • DETAIL.ASS_GPRS_EXT.QOS_REQUESTED_RELIABILITY
  • DETAIL.ASS_GPRS_EXT.GS_PACKET.QOS_REQUESTED_RELIABILITY
QoS Used:
  • DETAIL.ASS_GPRS_EXT.QOS_USED_RELIABILITY
  • DETAIL.ASS_GPRS_EXT.GS_PACKET.QOS_USED_RELIABILITY
No comment.
Radio Channel Requested
  • DETAIL.QOS_REQUESTED
  • DETAIL.ASS_GSMW_EXT.BS_PACKET.QOS_REQUESTED
No comment.
Radio Channel Used
  • DETAIL.QOS_USED
  • DETAIL.ASS_GSMW_EXT.BS_PACKET.QOS_USED
No comment.
RAP File Sequence Number
Call Event Details:
  • DETAIL.RAP_FILE_SEQ_NO
Batch Control Information and Notification:
  • HEADER.RAP_FILE_SEQ_NO
Must be present within groups:
  • Notification
  • Batch Control Information
Recipient
HEADER.RECIPIENT
No comment.
Recording Entity Code
Service Center Usage:
  • DETAIL.ASS_GSMW_EXT.ORIGINATING_SWITCH_IDENTIFICATION
Location Service:
  • DETAIL.ASS_LOCN_EXT.REC_ENTITY_CODE
  • Recording Entity Information
  • Location Service
  • Network Location
  • Service Center Usage where it must be of type 'Service Center'
In the case of GPRS network usage, two or more occurrences must be present within GPRS Network Location. One occurrence must be of type 'GGSN' (see Recording Entity Type) and all other occurrences must be of type 'SGSN'.
In the case of WLAN network usage, one occurrence must be present identifying the WLAN billing information recording entity.
Network Location:
Recording Entity Code is used to get corresponding Recording Entity ID. Recording Entity Code is not stored in any EDR field.
Rec Entity Code Information:
Release Version Number
HEADER.RELEASE_VERSION
No comment.
Requested Delivery Timestamp
DETAIL.ASS_CONT_EXT.REQUESTED_DELIVERY_TIMESTAMP
DETAIL.ASS_CONT_EXT.REQ_DELIVERY_UTC_TIME_OFFSET
The timestamp part of this item is mapped to DETAIL.ASS_CONT_EXT.REQUESTED_DELIVERY_TIMESTAMP, and the UTC offset part is mapped to DETAIL.ASS_CONT_EXT.REQ_DELIVERY_UTC_TIME_OFFSET.
Requested Destination
Requested Number:
  • DETAIL.ASS_LTE_EXT.REQUESTEDNUMBER
Requested Public User ID:
  • DETAIL.ASS_LTE_EXT.REQUESTEDPUBLICUSERID
The original destination to which the customer requested to be connected.
Response Time
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.RESPONSE_TIME
No comment.
Response Time Category
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.RESPONSE_TIME_CATEGORY
No comment.
Sender
HEADER.SENDER
No comment.
Serving Bid
The Serving BID (Billing Identifier) is a code associated with a geographical area.
Serving Location Description
A text description giving the geographical location of the terminal equipment.
Serving Network
Serving Network:
  • DETAIL.ASS_GSMW_EXT.SERVING_
  • NETWORK
Geographical Location:
  • DETAIL.GEOGRAPHICAL_LOCATION
Serving Network is stored in DETAIL.GEOGRAPHICAL_LOCATION along with other concatenated comma-separated tag-value pairs from Geographical Location.
This is a block.
SIM Toolkit Indicator
DETAIL.DISCOUNT_KEY
No comment.
SMS Destination Number
DETAIL.ASS_ROAMING_EXT.SMS_DESTINATION_NUMBER
The SMS Destination Number item contains the actual destination (intended recipient) of the SMS text message.
SMS Originator
DETAIL.ASS_ROAMING_EXT.SMS_ORIGINATOR
The SMS Originator holds the identification of the actual sender of the SMS
Specification Version Number
HEADER.SPECIFICATION_VERSION_NUMBER
No comment.
Speech Version Requested
DETAIL.ASS_GSMW_EXT.BS_PACKET.SPEECH_VERSION_REQUESTED
No comment.
Speech Version Used
DETAIL.ASS_GSMW_EXT.BS_PACKET.SPEECH_VERSION_USED
No comment.
Supplementary Service Code
DETAIL.ASS_GSMW_EXT.SS_PACKET.SS_EVENT
No comment.
Supplementary Service Parameters
DETAIL.ASS_GSMW_EXT.SS_PACKET.SS_PARAMETERS
No comment.
This is a block.
TAP Decimal Places
HEADER.TAP_DECIMAL_PLACES
No comment.
Tax Information
DETAIL.ASS_CBD.TP
This is a block.
Tax Rate Code
DETAIL.ASS_CBD.TP.TAX_CODE
  • Taxation
  • Tax Information
Tax Value
DETAIL.WHOLESALE_CHARGED_TAX_VALUE
DETAIL.ASS_CBD.TP.TAX_VALUE
No comment.
Taxable Amount
DETAIL.ASS_CBD.TP.TAXABLE_AMOUNT
No comment.
TeleService Code
DETAIL.ASS_GSMW_EXT.BS_PACKET.BASIC_SERVICE
The EDR fields are prefixed with 0.
Third Party Number
DETAIL.C_NUMBER
DETAIL.ASS_GSMW_EXT.SS_PACKET.THIRD_PARTY_NUMBER
Present within the Third Party Information group where available.
Time Band
DETAIL.ASS_CBD.CP.TIME_INTERVAL_CODE
No comment.
Total Advised Charge
TRAILER.ASS_ROAMING_EXT.TOTAL_ADVISEDCHARGE
The sum of all the advised charges associated with the corresponding currency excluding those representing a refund.
Total Advised Charge Refund
TRAILER.ASS_ROAMING_EXT.TOTAL_ADVISEDCHARGE_REFUND
The sum of all the advised charges associated with the corresponding currency representing a refund.
Total Commission
TRAILER.ASS_ROAMING_EXT.TOTAL_COMMISSION
The sum of all the commissions associated with the corresponding currency excluding those representing a refund.
Total Commission Refund
TRAILER.ASS_ROAMING_EXT.TOTAL_COMMISSION_REFUND
The sum of all the commissions associated with the corresponding currency representing a refund.
Total Discount Refund
TRAILER.ASS_ROAMING_EXT.TOTAL_DISCOUNT_REFUND
The sum of the Discount Values plus each application of a Fixed Discount Value contained in the batch representing a refund.
Total Tax Refund
TRAILER.ASS_ROAMING_EXT.TOTAL_TAX_REFUND
The sum of the Tax Values contained in the batch representing a refund.
Total Transaction Duration
Total Transaction Duration:
  • DETAIL.ASS_CONT_EXT.TOTAL_TRANSACTION_DURATION
Total Call Event Duration:
  • DETAIL.TOTAL_CALL_EVENT_DURATION
No comment.
No comment.
Total Charge
This is a block.
Total Charge Refund
TRAILER.TOTAL_CHARGE_VALUE_LIST.TOTAL_CHARGE_REFUND
No comment.
Total Data Volume
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.TOTAL_DATA_VOLUME
No comment.
Total Discount Value
TRAILER.TAP_TOTAL_DISCOUNT_VALUE
No comment.
Total Tax Value
TRAILER.TAP_TOTAL_TAX_VALUE
No comment.
This is a block.
Tracked Customer Home Id
This is a block.
This is a block.
Tracked Customer Information
This is a block.
This is a block.
This is a block.
Tracking Customer Home Id
This is a block.
This is a block.
Tracking Customer Information
This is a block.
This is a block.
Tracking Frequency
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.REQ_TRACKING_FREQUENCY
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.DEL_TRACKING_FREQUENCY
No comment.
Tracking Period
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.TRACKING_PERIOD
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.DEL_TRACKING_PERIOD
No comment.
Transaction Authorization Code
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.TRANSACTION_AUTH_CODE
No comment.
Transaction Description Suppression
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.TRANSACTION_DESCRIPTION_SUPP
No comment.
Transaction Detail Description
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.TRANSACTION_DETAIL_DESCRIPTION
No comment.
Transaction Identifier
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.TRANSACTION_IDENTIFIER
No comment.
Transaction Short Description
DETAIL.ASS_CONT_EXT.SERVICE_USED_LIST.TRANSACTION_SHORT_DESCRIPTION
No comment.
Transaction Status
DETAIL.ASS_CONT_EXT.TRANSACTION_STATUS
No comment.
Transfer Cut Off Timestamp
HEADER.TRANSFER_CUTOFF_TIMESTAMP
No comment.
Transparency Indicator
DETAIL.ASS_GSMW_EXT.BS_PACKET.TRANSPARENCY_INDICATOR
No comment.
UMTS Quality Of Service Requested
DETAIL.ASS_GPRS_EXT.GS_PACKET.UMTS_QOS_REQUESTED
The EDR field contains comma-separated tag-value pairs mapped from UMTS Quality Of Service Requested.
  • QosTrafficClassKey: 1
  • QosMaxBitRateUpLnKey: 2
  • QosMaxBitRateDownLnKey: 3
  • QosGuaranteedBitRateDownLnKey: 4
  • QosGuaranteedBitRateUpLnKey: 5
  • QosAllocRetenPriorityKey: 6
UMTS Quality Of Service Used
DETAIL.ASS_GPRS_EXT.GS_PACKET.UMTS_QOS_USED
The EDR field contains comma-separated tag-value pairs mapped from UMTS Quality Of Service Used.
User Protocol Indicator
DETAIL.ASS_GSMW_EXT.BS_PACKET.USER_PROTOCOL_INDICATOR
No comment.
UTC Time Offset
File Creation Timestamp:
  • HEADER.UTC_TIME_OFFSET
Earliest Call Timestamp:
  • TRAILER.FIRST_CHARGING_UTC_TIME_OFFSET
  • TRAILER.LAST_CHARGING_UTC_TIME_OFFSET
Mandatory within items:
  • File Creation Timestamp
  • Earliest Call Timestamp
  • Latest Call Timestamp
Mandatory within UTC Time Offset Information.
UTC Time Offset Code
Actual Delivery Timestamp:
  • DETAIL.ASS_CONT_EXT.ACT_DELIVERY_UTC_TIME_OFFSET
Order Placed Timestamp:
  • DETAIL.ASS_CONT_EXT.ORDER_PLACED_UTC_TIME_OFFSET
Requested Delivery Time Stamp:
  • DETAIL.ASS_CONT_EXT.REQ_DELIVERY_UTC_TIME_OFFSET
LCS Request Timestamp:
  • DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.LCS_REQ_UTC_OFFSET
  • Call Event Start Timestamp
  • Charging Timestamp
  • Charge Detail Timestamp
  • Deposit Timestamp
  • Completion Timestamp
  • Order Placed Timestamp
  • Requested Delivery Timestamp
  • Actual Delivery Timestamp
  • LCS Request Timestamp
  • PDP Context Start Timestamp
In Date Time group, UTC Time Offset Code is only used to get corresponding UTC Time Offset, but is not mapped to any EDR field.
Value Added Service Used
DETAIL.ASS_VAS_EXT
This is a block.
VAS Code
DETAIL.ASS_VAS_EXT.VAS_CODE
DETAIL.ASS_GSMW_EXT.VAS_PRODUCT_CODE
No comment.
Vertical Accuracy Delivered
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.V_ACCURACY_DELIVERED
No comment.
Vertical Accuracy Requested
DETAIL.ASS_LOCN_EXT.SERVICE_USAGE.V_ACCURACY_REQUESTED
No comment.
EDR-to-TAP Mapping
When generating output TAP files, BRM maps EDR container fields to the fields in TAP output files. Table 9-2 lists the EDR and TAP field mappings that BRM uses when producing the output files.
Some of the fields in the EDR container file, such as DETAIL.UTC_TIME_OFFSET, can provide data to different fields in the output TAP file.
Table 9-2 EDR-to-TAP Mapping
EDR Field TAP Field Comments
DETAIL.A_NUMBER
MSISDN
No comment.
CAMEL Service Used
This is a block.
No comment.
Camel Modification
Comma-separated list.
No comment.
CSE Information
No comment.
DETAIL.ASS_CAMELEXT.DEFAULT_CALL_HANDLING_INDICATOR
No comment.
GPRS Destination
The EDR field contains concatenated and comma-separated values of Access Point Name NI and Access Point Name OI.
Remote Pdp Address List
Camel Destination Number
International Access Code prefixes the EDR field.
DETAIL.ASS_CAMEL_EXT.RECORD_NUMBER
Tax Information List
No comment.
No comment.
No comment.
DETAIL.ASS_CAMEL_EXT.MSC_ADDRESS
Camel Msc Address
No comment.
CAMEL Service Key
No comment.
CAMEL Service Level
No comment.
Chargeable Units
No comment.
Charge
No comment.
DETAIL.ASS_CBD.CP.CHARGING_START_TIMESTAMP
Charging Timestamp
No comment.
Day Category
No comment.
Exchange Rate Code
No comment.
  • Discount Value
  • Discount Code
No comment.
Charge Type
No comment.
DETAIL.ASS_CBD.CP.PRODUCTCODE_USED
VAS:
  • VasShortDesc for the corresponding VAS Code
Camel:
  • Hard coded to CAMEL
In Charge Detail Group, values that are mapped to the EDR field depend on the service type: VAS or Camel.
Charged Units
No comment.
Time Band
No comment.
DETAIL.ASS_CBD.TP
Tax Information
This is a block.
Charge Type
No comment.
Tax Rate Code
No comment.
Tax Value
No comment.
Taxable Amount
No comment.
No comment.
This is a block.
This is a block.
  • Equipment Id
No comment.
  • Equipment ID Type
No comment.
This is a block.
  • Home Identifier
No comment.
  • Home ID Type
No comment.
This is a block.
No comment.
No comment.
This is a block.
  • Location Identifier
No comment.
  • Location ID Type
No comment.
No comment.
DETAIL.ASS_CONT_EXT.RECORD_NUMBER
Keeps the number of records of content Transaction.
No comment.
No comment.
This is a block.
Advised Charge
No comment.
No comment.
No comment.
Commission
No comment.
No comment.
No comment.
No comment.
No comment.
No comment.
Object Type
No comment.
Paid Indicator
No comment.
Payment Method
No comment.
Total Data Volume
No comment.
No comment.
No comment.
No comment.
No comment.
No comment.
This is a block.
This is a block.
ISP Identifier
No comment.
ISP ID Type
No comment.
DETAIL.ASS_CONT_EXT.SERVING_PARTIES_INFO.NETWORK_LIST
Network
This is a block.
DETAIL.ASS_CONT_EXT.SERVING_PARTIES_INFO.NETWORK_LIST.IDENTIFIER
Serving Parties Info Block:
  • Network Identifier
No comment.
DETAIL.ASS_CONT_EXT.SERVING_PARTIES_INFO.NETWORK_LIST.TYPE
  • Network ID Type
No comment.
Content Provider
This is a block.
Content Provider Block:
  • Content Provider Identifier
No comment.
  • Content Provider Id Type
No comment.
No comment.
No comment.
Transaction Status
No comment.
MSISDN
No comment.
GPRS Destination Group:
  • Access Point Name NI, if Camel option is not set.
  • Access Point Name OI, if Camel option is not set.
Cell Identity
No comment.
Charging ID
No comment.
IMEI
No comment.
DETAIL.ASS_GPRS_EXT.GGSN_ADDRESS
Recording Entity ID
Rec Entity Code Element Group.
Recording Entity Code is used to get corresponding Recording Entity ID. The obtained Recording Entity ID is stored in the EDR field.
GPRS Service Used
This is a block.
Charging Timestamp
No comment.
QoS Requested:
  • QoS Delay
No comment.
QoS Requested:
  • QoS Mean Throughput
No comment.
QoS Requested:
  • QoS Peak Throughput
No comment.
QoS Requested:
  • QoS Precedence
No comment.
QoS Requested:
  • QoS Reliability
No comment.
QoS Used:
  • QoS Delay
No comment.
QoS Used:
No comment.
QoS Used:
No comment.
QoS Used:
  • QoS Precedence
No comment.
QoS Used:
  • QoS Reliability
No comment.
The EDR field is mapped into concatenated and comma-separated tag-value pairs in UMTS Quality Of Service Requested.
The EDR field is mapped into concatenated and comma-separated tag-value pairs in UMTS Quality Of Service Used.
Charging Timestamp
No comment.
No comment.
No comment.
Location Area Code
No comment.
Network Initiated PDP Context
No comment.
DETAIL.ASS_GPRS_EXT.ORIGINATING_SWITCH_IDENTIFICATION
Recording Entity ID
Rec Entity Code Element.
Recording Entity Code is used to get corresponding Recording Entity ID. The Recording Entity ID is stored in the EDR field.
PDP Address
No comment.
No comment.
IMSI
No comment.
GGPRS Service Used Block:
No comment.
DETAIL.ASS_GPRS_EXT.SGSN_ADDRESS
Recording Entity ID
Recording Entity Code is used to get corresponding Recording Entity ID. Recording Entity ID is stored in the EDR field.
DETAIL.ASS_GPRS_EXT.SGSN_INFO_LIST.SGSN_ADDRESS
DETAIL.ASS_GPRS_EXT.WLAN_ADDRESS
Recording Entity ID
The Recording Entity code is used to get corresponding Recording Entity ID. The Recording Entity ID is stored in the EDR field.
  • MSISDN
  • Third Party Number
No comment.
  • Dual Teleservice Code
  • Dual Bearer Service Code
  • The EDR field is prefixed with 0.
  • The EDR field is prefixed with 1.
  • Basic Service
This is a block.
No comment.
Charging Timestamp
No comment.
No comment.
The EDR field is mapped as a comma-separated list of channel coding.
Channel Coding Used
Number Of Channels
No comment.
No comment.
No comment.
This is a block.
No comment.
Channel Coding Used
No comment.
Initiating Party
No comment.
Number Of Channels
No comment.
No comment.
No comment.
No comment.
Radio Channel Used
No comment.
No comment.
Speech Version Used
No comment.
No comment.
No comment.
Cell Identity
No comment.
IMEI or ESN
No comment.
  • Dialled Digits
  • MSISDN, in MTC and SCU groups
No comment.
DETAIL.ASS_GSMWEXT.LOCATION_AREA_INDICATOR
Location Area Code
No comment.
DETAIL.ASS_GSMW_EXT.MS_CLASS_MARK
Mobile Station Classmark
No comment.
DETAIL.ASS_GSMW_EXT.NUMBER_OF_SS_PACKETS
  • Number of Supplementary Service Used blocks
  • Number of Supplementary Service Used Event blocks
No comment.
  • Location Information
  • Recording Entity ID
No comment.
IMSI
No comment.
DETAIL.ASS_GSMW_EXT.SERVING_NETWORK
Serving Network
No comment.
This is a block.
Supplementary Service Action Code
No comment.
DETAIL.ASS_GSMW_EXT.SS_PACKET.BASIC_SERVICE_CODE_LIST
Basic Service Code SS
No comment.
No comment.
No comment.
No comment.
Third Party Number
No comment.
UTC Time Offset
No comment.
Call Reference
No comment.
LCS SP Information
This is a block.
This is a block.
No comment.
  • Content Provider ID Type
No comment.
This is a block.
LCS SP Information:
  • ISP Identifier
No comment.
LCS SP Information:
  • ISP ID Type
No comment.
LCS SP Information:
No comment.
LCS SP Information:
  • Network ID Type
No comment.
Location Service:
  • Recording Entity Code
No comment.
This is a block.
Age Of Location
No comment.
Tracking Frequency
No comment.
Tracking Period
No comment.
No comment.
No comment.
No comment.
No comment.
Positioning Method
No comment.
Tracking Frequency
No comment.
Response Time
No comment.
No comment.
Tracking Period
No comment.
No comment.
No comment.
This is a block.
This is a block.
  • Equipment Id
No comment.
  • Equipment ID Type
No comment.
This is a block.
Tracked Customer Home Id:
  • Home Identifier
No comment.
  • HomeIDType
No comment.
This is a block.
  • Customer Identifier
No comment.
  • Customer ID Type
No comment.
This is a block.
  • Location ID Type
This is a block.
This is a block.
  • Equipment ID
No comment.
  • Equipment ID Type
No comment.
This is a block.
  • Home Identifier
No comment.
  • Home ID Type
No comment.
This is a block.
No comment.
  • Customer ID Type
No comment.
This is a block.
No comment.
  • Location ID Type
No comment.
Requested Destination:
  • Requested Number
The EDR value is populated only for the Mobile Session (MO Voice Over LTE) events.
  • Requested Public User ID
CLIR Indicator
No comment.
Guaranteed Bit Rate
No comment.
HSCSD Indicator
No comment.
Maximum Bit Rate
No comment.
No comment.
Mobile ID Number
No comment.
No comment.
DETAIL.ASS_ROAMING_EXT.RAP_FILE_SEQ_NO
No comment.
No comment.
SMS Originator
No comment.
Home Bid
No comment.
No comment.
DETAIL.ASS_ROAMING_EXT.ISM_SIGNALLING_CONTEXT
ISM Signalling Context
No comment.
DETAIL.ASS_VAS_EXT
This is a block.
DETAIL.ASS_VAS_EXT.UTC_TIME_OFFSET
UTC Time Offset
No comment.
VAS Code
No comment.
DETAIL.ASS_VAS_EXT.VAS_DESC
VAS Description
No comment.
DETAIL.ASS_VAS_EXT.VAS_SHORT_DESC
VAS Short Description
No comment.
DETAIL.B_NUMBER
  • Called Number
  • Calling Number
  • Non Charged Number
  • TeleService Code
  • Bearer Service Code
No comment.
DETAIL.C_NUMBER
  • Dialled Digits
No comment.
  • Cause For Termination
  • Message Status
The EDR field is mapped to different TAP fields:
  • Service Center Usage Group. The EDR field is mapped to Message Status. If the value is less than 10, it is prefixed with 0.
  • GPRS/Mobile Originated/ Mobile Terminated Group. The EDR field is mapped to Cause for Termination. If the value is less than 10, it is prefixed with 0.
Called Country Code
No comment.
  • Call Event Start Time Stamp
  • Charging Time Stamp (MSS, SCU, and VAS)
When the EDR is mapped to Completion Timestamp, the DETAIL.UTC_TIME_OFFSET part is not stored.
  • Deposit Timestamp
No comment.
Call Type Level 3
No comment.
DETAIL.CONNECT_TYPE
  • Call Type Level 1
  • Call Type Level 2
Contents of the EDR field are mapped as concatenated items to Call Type Level 1 and Call Type Level 2.
DETAIL.DESCRIPTION
  • Called Place
  • Called Region
  • Message Description Code
Destination:
  • Contents of the EDR field are mapped as concatenated comma-separated values into Called Place and Called Region.
SCU Charge Type:
  • The EDR field mapped to Message Description corresponds to the Message Description Code present in SCU Charge Type.
Destination Network
No comment.
DETAIL.DISCOUNT_KEY
No comment.
DETAIL.DURATION
No comment.
No comment.
Contents of the EDR field are mapped as comma-separated tag-value pairs.
  • ServingNetwork: 1
  • ServingBID: 2
  • Longitude: 4
  • Latitude: 5
MSISDN
No comment.
No comment.
Operator Specific Information
No comment.
  • Priority Code
  • Radio Channel Requested
No comment.
DETAIL.QOS_USED
  • Message Type
  • Radio Channel Used
No comment.
No comment.
Originating Network
No comment.
Network Type
No comment.
DETAIL.USAGE_CLASS
GPRS Chargeable Subscriber:
  • Charging Characteristics
SCU Basic Information, Call Originator:
  • CLIR Status Indicator
No comment.
No comment.
  • Deposit Timestamp
No comment.
No comment.
DETAIL.VOLUME_SENT
No comment.
DETAIL.WHOLESALE_CHARGED_TAX_RATE
Tax Rate Code
No comment.
Tax Value
No comment.
No comment.
No comment.
File Type Indicator
No comment.
No comment.
No comment.
HEADER.RECIPIENT
Recipient
No comment.
HEADER.SENDER
Sender
No comment.
No comment.
No comment.
TAP Decimal Places
No comment.
No comment.
No comment.
No comment.
No comment.
No comment.
No comment.
Total Tax Value
No comment.
Charge Type
No comment.
Total Charge Refund
No comment.
