18 Tax Selectors
A tax selector consists of rules that associate account, service, profile, and event attributes with tax codes.
For information on using tax selectors, see:
For overview information, see "About Selectors" in PDC Creating Product Offerings.
Creating a Tax Selector
To create a tax selector:
In the Pricing section of the navigation pane, under Models & Selectors, click Create Tax Selector.
Specify general information for the tax selector. See "Specifying Tax Selector General Information".
Select the attributes to use in the tax selector rules. See "Selecting Attributes for Tax Selector Rules".
Create rules for the tax selector. See "Creating Tax Selector Rules".
Related Topics
To specify general information for a tax selector:
In the Pricing section of the navigation pane, under Models and Selectors, click Create Tax Selector.
The Create Tax Selector page appears.
In the General Information section, enter a unique name and a description for the tax selector.
From the Service list, select a service to associate with the tax selector.
From the Event list, select an event to associate with the tax selector.
From the Rating Profiles list, select one or more rating profiles to associate with the tax selector.
From the Pricing Profile list, select a pricing profile to associate with the tax selector.
Click Next.
The Rule Attributes tab appears.
Related Topics
To create rules for a tax selector, you must first specify the customer, service, event, and profile attributes to use in the rules.
To specify attributes for tax selector rules:
Go to the Rule Attributes tab of the Create Tax Selector page.
In the Select Fields for Rules section, click the Add icon in the table toolbar.
The Add Field dialog box appears.
Select at least one field to use in the rules.
To select multiple fields at the same time, press and hold the CTRL key during selection.
The selected fields are included in every rule defined for the tax selector, but in each rule, you can override a field's default value.
Click OK.
The selected fields are added to the table, with one field per row.
Click the Value Type cell, and select a value type from the list.
The Operator cell is automatically set to Equals (for a value type of Single Value) or Contained in (for a value type of List of Values).
In the Default cell, do one of the following:
If you selected Single Value, click the cell and enter a value.
If you selected List of Values, click the cell and do the following:
In the Enter Value dialog box, click the List of Values cell and enter a value.
For each additional value, click the Add icon and enter a value in the new cell.
Click OK.
The values, separated by semicolons, are added to the cell.
Click Next.
The Rules tab appears.
Related Topics
Tax selectors use rules to determine which tax code to apply to an event.
The selector evaluates rules in the order they appear in the table. You can change the order by moving a row up or down, or by entering a different priority number.
To create a tax selector rule:
Go to the Rules tab of the Create Tax Selector page.
(Optional) From the Effective Period list, click Manage to add or change the effective period.
The effective period indicates when the rules are valid. The default effective period starts immediately and never ends.
If the selector contains multiple effective periods, select one.
In the table, click the Add icon in the table toolbar.
A row is added to the table.
Tip:
You can also add a row by clicking the Actions menu and then selecting Insert Rule Above or Insert Rule Below.
Click the Priority cell, and enter the priority number.
Click the Rule Name cell, and enter a unique name for the rule.
Click the cell for each attribute, and enter a value.
In the Tax Code cell, select a tax code.
Click Finish.
You can edit or validate the tax selector.
Create Tax Selector Page Reference
Use the Create Tax Selector page to create rules that associate subscriber, service, profile, and event attributes with tax codes.
For a description of the fields, see the following:
General Information Section
Use the General Information section to provide a name and description for the tax selector and to associate it with a service, event type, rating profile, and pricing profile.
Field | Description |
Name, Description |
Enter a unique name and a description. The name must be unique across tax selectors. |
Service |
Select the service type to which the tax selector applies. |
Event |
Select the event type to which the tax selector applies. |
Rating Profiles |
Select the rating profile for the tax selector. |
Pricing Profile |
Select the pricing profile for the tax selector. |
Rule Attributes Section
Use the Rule Attributes section to select the subscriber, service, profile, and event attribute fields to use in the tax selector rules.
Select Fields for Rules Table
The table lists the attribute fields to include in the rules. In the table, you can add or delete fields, add or remove columns, or reorder the columns. See "Working with Tables" for more information.
Click the Add icon to add fields using the Select Field dialog box. See "Select Field Dialog Box".
Column Name | Description |
Field |
Displays the name of the customer, service, event, or profile attribute field you specified in the "Select Field Dialog Box". |
Value Type |
Select one of the following:
Operator |
Displays the operator type, which is dependent on the Value Type entry.
Default |
Specify a default value for the field. If the operator is Equals, enter a value. If the operator is Contained in List, clicking on the cell opens the Select Field dialog box. In the Select Field dialog box, enter a value in each row. Note: The default value of asterisk (*) specifies the field can contain any value. |
Use the Select Field dialog box to specify the attribute fields to evaluate. The dialog box includes one or more of the following categories: Customer, Service, Event, and Profile.
Expand a category to view the attribute fields you can add to a rule. Select a field name to add it to your rule. To select multiple fields at the same time, press and hold the CTRL key during selection.
Related Tasks
Rules Section
Use the Rules section to define tax selector rules.
Click the Add icon in the table to add rules.
The table in this section lists the rules in the order that they are evaluated. The tax selector returns the tax code of the first rule that matches the values in the event.
You can select a rule and move it up or down if you wish to reorder the rules.
Column | Description |
Effective Period |
(Optional) Set the start and end dates to specify the period when the rules in the selector are valid. The default effective period starts immediately and never ends. From the Effective Period list, click Manage to add or change an effective period. See "Manage Effective Periods Dialog Box". |
Priority |
Enter the rule's priority. This table displays rules in numerical order, starting with priority 1. The rules are evaluated in order of priority. When a rule includes multiple attributes (fields), BRM processes the attributes from left to right. Reorder a rule in either of the following ways:
The priority numbers of all rules affected by the move are changed. |
Rule Name |
Enter a unique name for the rule. |
Field Name |
Enter a value. To apply the rule to an event, the subscriber, service, profile, or event value must match the corresponding value. Note: An asterisk (*) matches all values in the corresponding field. |
Tax Code |
Select the name of the tax code to associate with the rule. |
Related Tasks
Use the Manage Effective Periods dialog box to add or change effective periods.
To add a new effective period, click the Add icon. In the Add New Effective Period dialog box, enter a start date or click the date selector to select a date.
To change the effective period that starts immediately, deselect Immediately and enter a new start date or click the date selector to select a date.
Related Tasks
