64 Business Logic pin.conf Reference
Learn how to use the business logic pin.conf settings to configure Oracle Communications Billing and Revenue Management (BRM).
Topics in this document:
See also "business_params Reference" and "System Administration pin.conf Reference".
Account Creation pin.conf Entries
Table 64-1 lists the account creation pin.conf entries.
Table 64-1 Account Creation pin.conf Entries
Name Program Description pin.conf File Implementation
allow_active_service_with_inactive_account
fm_cust
Specifies whether services can be activated (during a SET_STATUS operation) if the account or bill unit is inactive.
CM
Cached by the CM. Restart the CM after changing this entry.
cc_checksum
fm_cust_pol
Specifies whether to run checksum validation on the customer's credit card during account creation.
CM
The new value becomes effective immediately and applies to the next account created. The CM does not need to be restarted.
config_dir
fm_cust_pol
Specifies the location of the ISP configuration data, which is stored in the default.config file. Used by the PCM_OP_CUST_POL_GET_CONFIG policy opcode.
CM
country
fm_cust_pol
Specifies the default country for new accounts (default is USA).
CM
currency
fm_cust_pol
Specifies the default currency for new accounts.
CM
domain
fm_cust_pol
Specifies the email domain assigned to customers during account creation.
CM
new_account_welcome_msg
fm_cust_pol
Specifies whether the system should send the default welcome message on account creation.
CM
welcome_dir
fm_cust_pol
Specifies the location of the welcome message sent to customers after account creation.
CM
Accounts Receivable pin.conf Entries
Table 64-2 lists the Accounts Receivable pin.conf entries.
Table 64-2 Accounts Receivable pin.conf Entries
calc_cycle_from_cycle_start_t
fm_bill
Specifies whether to calculate charge offer fees based on the charge offer's purchase date (PIN_FLD_CYCLE_START_T).
See "Calculating Cycle Fees for Backdating" in BRM Configuring and Running Billing.
CM
This value is read by the utility when it runs. You do not need to restart the CM.
cycle_tax_interval
fm_bill
Determines whether deferred taxes are calculated separately for a paying parent bill unit and its nonpaying child bill units or are consolidated into a single tax item for both the parent and child bill units.
CM
item_search_batch
fm_bill
Specifies the number of items returned by a step search.
CM
overdue_tolerance
fm_bill
Specifies how BRM treats amounts applied to the item when they are less than the amount due as a result of euro and Economic and Monetary Union (EMU) conversions.
See "Rounding Errors for Overpayments and Underpayments" in BRM Managing Customers.
CM
underdue_tolerance
fm_bill
Specifies how BRM treats amounts applied to the item when they are more than the amount due as a result of euro and EMU conversions.
CM
Billing pin.conf Entries
Table 64-3 lists the Billing pin.conf entries.
Table 64-3 Billing pin.conf Entries
advance_bill_cycle
fm_bill
Sets the first billing date to be the day after account creation.
See "Setting the First Billing Cycle to the Day after Account Creation" in BRM Configuring and Running Billing.
CM
attach_item_to_event
fm_act
Specifies how BRM assigns event and service combinations to bill items.
See "About Using Event and Service Combinations to Assign Bill Items" in BRM Configuring and Running Billing.
CM
bill_when
fm_cust_pol
Specifies the default billing-cycle length.
See "Setting the Default Billing-Cycle Length" in BRM Configuring and Running Billing.
CM
The new value becomes effective immediately. You do not have to restart the CM.
billing_segment_config_refresh_delay
fm_cust
Specifies how often data in the cached /config/billing_segment object is automatically refreshed from the database.
See "Updating Billing Segments" in BRM Configuring and Running Billing.
CM
config_billing_cycle
fm_bill
Specifies how long after the billing cycle ends that new events are considered for the previous month's bill.
CM
Billing utilities
custom_bill_no
fm_bill
Specifies the accounting cycle (first or last) in which to assign a bill number to a bill in a multi-month billing cycle.
See "Specifying When to Apply Custom Bill Numbers" in BRM Configuring and Running Billing.
CM
Billing utilities
cycle_delay_align
fm_bill
Specifies whether to align the charge offer purchase, cycle, and usage start and end times with the accounting cycle.
See "Aligning Account and Cycle Start and End Times" in BRM Configuring and Running Billing.
CM
cycle_delay_use_special_days
fm_bill
Sets the delayed cycle start date to the 1st of the following month for all bundles purchased on the 29th, 30th, or 31st.
See "Setting Delayed Cycle Start Dates to the 29th, 30th, or 31st" in BRM Configuring and Running Billing.
CM
Billing utilities
deadlock_retry_count
fm_bill_accts
Specifies the number of retries to attempt when a deadlock occurs during a billing run.
See "Specifying the Number of Retries in Case of a Deadlock".
pin_billd
This entry is read by the utility when it runs. You do not need to restart the CM.
delay_cycle_fees
fm_bill
In systems set up for delayed billing, specifies when to apply cycle forward fees and cycle rollovers (during partial billing or final billing).
See "Specifying When to Apply Cycle Forward Fees and Cycle Rollovers" in BRM Configuring and Running Billing.
CM
delta_step
pin_billd
Reduces contention at the database level during billing.
See "Rearranging Accounts to Improve Billing Performance".
pin_billd
enable_30_day_proration
fm_bill
Allows you to base monthly proration on 30-day months rather than the actual number of days in a billing cycle. This is often needed when working in parallel with older legacy billing systems.
See "About 30-Day-Based Proration" in BRM Configuring and Running Billing.
CM
enforce_billing
pin_bill_accts
Enforces partial billing from the billing application inside the billing delay interval.
See "Enforcing Partial Billing in the Billing Delay Interval" in BRM Configuring and Running Billing.
pin_billd
group_by_account
pin_deferred_act
Specifies to use one thread to process scheduled actions for one account.
See "Ensuring the Sequence of Scheduled Actions".
pin_billd
keep_cancelled_products_or__discounts
fm_subscription_pol
Specifies whether to keep canceled charge offers and discount offers.
See "Providing Discounts to Closed Accounts" in BRM Configuring and Running Billing.
CM
The new value becomes effective immediately. You do not need to restart the CM.
num_billing_cycles
fm_subs
Specifies the maximum number of billing cycles allowed between the current time and the backdated event time of a backdated operation.
CM
open_item_actg_include_prev_total
fm_bill
Includes previous bill totals in the pending receivable value calculated during billing for accounts that use open item accounting.
See "Including Previous Balances in the Current Amount Due in Open Item Accounting" in BRM Configuring and Running Billing.
CM
purchase_fees_backcharge
fm_bill
Specifies which cycle (current or next) to apply the deferred purchase fees to during billing when the deferred time coincides with the billing time.
See "Specifying Which Billing Cycle to Assign to Deferred Purchase Fees" in BRM Configuring and Running Billing.
CM
rating_longcycle_roundup_flag
fm_rate
Enables rounding up for the long cycle.
CM
stop_bill_closed_accounts
fm_bill
Stops billing of closed bill units (/billinfo objects) when all items have zero due.
See "Suspending Billing of Closed Accounts" in BRM Configuring and Running Billing.
CM
timestamp_rounding
fm_bill
Rounds timestamp to midnight.
See "About Time-Stamp Rounding" in BRM Configuring and Running Billing.
See also "About Sub-Balances" in BRM Creating Product Offerings.
CM
unset_error_status
pin_bill_accts
Sets billing status in a bill unit when billing errors occur.
See "Setting the Bill Unit Status When Billing Errors Occur" in BRM Configuring and Running Billing.
pin_billd
use_number_of_days_in_month
fm_bill
Specifies how to calculate proration when a cycle charge offer is purchased or canceled.
See "Calculating Prorated Cycle Fees" in BRM Configuring and Running Billing.
CM
Collections pin.conf Entries
Table 64-4 lists the Collections pin.conf entries.
Table 64-4 Collections pin.conf Entries
account_search_batch
fm_collections
Specifies the number of bill units to retrieve in collections step searches.
See "Setting the Number of Bill Units Retrieved during Step Searches" in BRM Collections Manager.
CM
collections_action_dependency
fm_collect
Creates dependencies between collections actions in a collections scenario.
See "Creating Dependencies between Collections Actions in a Scenario" in BRM Collections Manager.
CM
email_body
pin_collections_send_dunning
pin_inv_send
Specifies the path to a text file containing a customized message.
See "Specifying a File for the Email Body" in BRM Collections Manager.
pin_collections
pin_inv
The new value is effective immediately. You do not need to restart the CM.
execute_all_actions
fm_collections
Specifies whether to run all actions, including actions due before the date on which pin_collections_process is run for the first time, or only to run actions due after the date on which pin_collections_process is run for the first time.
See "Performing Scheduled Collections Actions after Reinstalling Collections Manager" in BRM Collections Manager.
CM
minimum_due
Specifies the minimum overdue balance that a bill unit must have to qualify for collections.
See "Setting the Minimum Overdue Balance to Process" in BRM Collections Manager.
pin_collections
Customer Management pin.conf Entries
Table 64-5 lists the Customer Management pin.conf entries.
Table 64-5 Customer Management pin.conf Entries
apply_rollover
fm_bill
If you do not use rollovers, you can disable rollover calculation by using this entry. This entry is on by default, that is, rollovers are applied, but you can turn it off to increase performance.
CM
cycle_arrear_proration
fm_rate
Specifies when to prorate cycle arrears fees, at purchase or at cancellation.
See "Proration for Special Cases" in BRM Configuring and Running Billing.
CM
em_db
fm_delivery
Specifies the Email Data Manager database number.
See "Configuring the Email Data Manager" in BRM Managing Customers.
CM
intro_dir
fm_cust_pol
Specifies the location of the introductory message that allows a customer to confirm account creation.
CM
Discounting pin.conf Entries
Table 64-6 lists the Discounting pin.conf entries.
Table 64-6 Discounting pin.conf Entries
propagate_discount
fm_subscription
Enables immediate propagation of shared discount when a new discount is added to/deleted from the group or a member subscribes to/unsubscribes from the group.
See "Configuring the Start and End Times for Discount Sharing" in BRM Managing Customers.
CM
rollover_zeroout_discounts
fm_rate
Zeroes-out the positive bucket.
CM
General Ledger pin.conf Entries
Table 64-7 lists the General Ledger pin.conf entries.
Table 64-7 General Ledger pin.conf Entries
gl_segment
fm_cust_pol
Specifies the default G/L segment for an account during account creation.
See "Changing the Default G/L Segment" in BRM Collecting General Ledger Data.
CM
transaction_grouping
pin_ledger_report
Specifies how many A/R accounts to group in a single transaction for ledger_report to run.
See "Setting the Number of A/R Accounts per G/L Report" in BRM Collecting General Ledger Data.
pin_billd
Invoicing pin.conf Entries
Table 64-8 lists the Invoicing pin.conf entries.
Table 64-8 Invoicing pin.conf Entries
database
pin_inv_accts
pin_inv_export
pin_inv_send
pin_inv_upgrade
Specifies the database schema to which the following utilities should connect:
  • pin_inv_accts
  • pin_inv_export
  • pin_inv_send
  • pin_inv_upgrade
See "Configuring the Invoice pin.conf for Multiple Database Schemas" in BRM Designing and Generating Invoices.
pin_inv
export_dir
pin_inv_export
Specifies the path to the invoice directory.
See "Exporting Invoices" in BRM Designing and Generating Invoices.
pin_inv
from
pin_inv_send
Specifies the e-mail address of the sender.
See "About Invoices" and "pin_inv_send" in BRM Designing and Generating Invoices.
pin_inv
html_template
pin_inv_pol
Specifies the HTML template file to use to generate invoices.
CM
invoice_db
pin_inv_export
pin_inv_send
Specifies the database number for the schema.
See "Configuring BRM to Use a Separate Invoice Database Schema" in BRM Designing and Generating Invoices.
pin_inv
invoice_dir
fm_bill
Specifies the directory where invoices are stored.
CM
invoice_fmt
pin_inv_export
pin_inv_send
Specifies the invoice format.
pin_inv
inv_perf_features
fm_inv
Improves performance by removing unnecessary details from your invoices.
CM
sender
fm_cust_pol
pin_inv_send
Specifies the name of the e-mail sender.
CM
pin_inv
service_centric_invoice
fm_inv_pol
Enables service-centric invoicing.
CM
show_rerate_details
fm_inv_pol
Specifies whether to display shadow adjustment details on invoices.
See "Including Shadow Event Adjustment Details in Invoices" in BRM Designing and Generating Invoices.
CM
subject
pin_inv_send
Specifies the subject of the e-mail.
pin_inv
Payments pin.conf Entries
Table 64-9 lists the Payments pin.conf entries.
Table 64-9 Payments pin.conf Entries
cc_revalidation_interval
fm_pymt_pol
Specifies the credit card revalidation interval.
CM
cc_validate
fm_pymt_pol
Specifies whether to validate a customer's credit card information during account creation.
See "Validating Credit Cards at Account Creation" in BRM Managing Customers.
CM
config_payment
fm_pymt
Specifies the database and POID of the /config/payment object. Change this value if you create a custom /config/payment object.
CM
cvv2_required
fm_pymt_pol
Specifies whether to use Visa CVV2 fraud protection for Paymentech transactions.
See "Requiring Additional Protection against Credit Card Fraud" in BRM Configuring and Collecting Payments.
CM
dd_collect
fm_pymt_pol
Specifies whether to perform real-time authorization of the fixed charges information with the customer's debit card during account creation.
CM
dd_revalidation_interval
fm_pymt_pol
Specifies the debit card revalidation interval.
CM
dd_validate
fm_pymt_pol
Specifies whether to validate a customer's direct debit (debit card) information during account creation.
CM
merchant
fm_cust_pol
Specifies the merchant to receive money collected during credit-card processing.
See "Specifying Merchant IDs and Merchant Numbers" in BRM Configuring and Collecting Payments.
CM
minimum
pin_billd
Specifies the minimum balance for retrieving accounts for collection.
Use this entry to set a minimum threshold for the amount due on an account when searching for accounts for collection.
See "Specifying the Minimum Payment to Collect" in BRM Configuring and Running Billing.
pin_billd
minimum_payment
fm_pymt_pol
Specifies the minimum amount to charge. The amount charged is greater than or equal to the minimum amount.
See "Specifying the Minimum Amount to Charge" in BRM Configuring and Running Billing.
CM
minimum_refund
fm_pymt_pol
Specifies the minimum refund amount that the system allows. The amount refunded is greater than or equal to the minimum amount.
See "Specifying the Minimum Amount to Refund" in BRM Managing Accounts Receivable.
CM
validate_acct
fm_pymt_pol
Allows use of the customer's credit card on an account different from the root account.
See "Specifying the Account That Records Credit Card Validations" in BRM Managing Customers.
CM
Pricing and Rating pin.conf Entries
Table 64-10 lists the Pricing and Rating pin.conf entries.
Table 64-10 Pricing and Rating pin.conf Entries
backdate_trigger_auto_rerate
fm_subs
Specifies whether to create auto-rerate job objects used by pin_rerate.
CM
backdate_window
fm_subs
Specifies the minimum time difference needed between the current time and the backdated event time for triggering automatic rerating.
CM
cancel_tolerance
fm_bill
Specifies the cancellation tolerance of account charge offers in minutes.
See "Canceling Charge Offers without Charging a Cancel Fee" in BRM Managing Customers.
CM
delay
pin_rerate
Specifies the delay for rerating jobs.
pin_rerate
fm_offer_profile_cache
cm_cache
Specifies the attributes of the CM cache for offer profiles.
Note: This entry is mandatory for policy-driven charging.
See BRM Creating Product Offerings.
CM
fm_price_cache_beid
cm_cache
Specifies attributes of the CM cache for the size of balance element IDs (BEID).
See "Improving Performance for Loading Large Product Offerings".
CM
fm_price_prod_provisioning_cache
cm_cache
Specifies the attributes of the CM cache for the size of charge offer provisioning tags.
CM
log_refresh_product
fm_rate
Specifies whether to log product offering changes. You can use the log entries to generate notifications about such changes.
See "Logging Changes to Product Offerings" in BRM Creating Product Offerings.
CM
rate_change
fm_subscription
Enables the enhanced pricing change management feature.
See "Rerating Cycle Forward and Cycle Forward Arrears Charges" in BRM Rerating Events.
CM
rating_max_scale
fm_rate
Specifies the precision level of decimal values.
See "Changing the Precision of Rounded and Calculated Values".
CM
rating_quantity_rounding_scale
fm_rate
Specifies the precision of rounded values.
CM
rating_timezone
fm_rate
Specifies the server time zone.
CM
refresh_product_interval
fm_rate
Specifies the interval in which product offerings are refreshed in cache memory.
See "Setting the Interval for Checking for Product Offering Changes".
CM
timezone_file
fm_rate
Specifies the location of the timezones.txt file.
CM
update_interval
fm_zonemap_pol
Specifies an interval for revising the value map.
CM
validate_deal_dependencies
fm_utils
Specifies whether to validate the bundle prerequisites and mutually exclusive relations.
See "Configuring Bundle Dependencies" in BRM Managing Customers.
CM
Revenue Assurance pin.conf Entries
Table 64-11 lists the Revenue Assurance pin.conf entries.
Table 64-11 Revenue Assurance pin.conf Entries
writeoff_control_point_id
fm_process_audit
Changes the control point ID.
See BRM Collecting Revenue Assurance Data.
CM
Service Lifecycle Management pin.conf Entries
Table 64-12 lists the Service Lifecycle Management pin.conf entries.
Table 64-12 Service Lifecycle Management pin.conf Entries
fm_bill_template_cache
cm_cache
Specifies attributes of the template cache. This cache is used by the Service Lifecycle Management feature.
See "Managing Service Life Cycles" in BRM Managing Customers.
CM
fm_bill_utils_business_profile_cache
cm_cache
Specifies attributes of the business_profile cache. This cache is used by the Service Lifecycle Management feature.
CM
fm_cust_lifecycle_config_cache
cm_cache
Specifies attributes of the lifecycle cache. This cache is used by the Service Lifecycle Management feature.
CM
fm_cust_statemap_config_cache
cm_cache
Specifies attributes of the statemap cache. This cache is used by the Service Lifecycle Management feature.
CM
Services Framework pin.conf Entries
Table 64-13 lists the Services Framework pin.conf entries.
Table 64-13 Service Framework pin.conf Entries.
agent_return
fm_tcf
Specifies the provisioning status when provisioning is simulated.
CM
commit_at_prep
dm_provision
Specifies whether to send the payload to the agent at PREP_COMMIT time and not to send anything at COMMIT time.
See "Configuring the Provisioning Data Manager" in BRM Telco Integration.
dm_prov_telco
connect_retries
dm_provision
Specifies the number of times dm_provision attempts to connect to the Infranet agent on connection failure.
See "Provisioning Data Manager Configuration File Entries" in BRM Telco Integration.
dm_prov_telco
connect_retry_interval
dm_provision
Specifies how many seconds to wait before retrying to connect to the Infranet agent on connection failure.
dm_prov_telco
prov_db
fm_tcf
Specifies the number of the database to which provisioning connects to send the service order.
See "Connecting the Connection Manager to the Provisioning Data Manager" in BRM Telco Integration.
CM
prov_ptr
dm_provision
Specifies where to find the Provisioning Data Manager.
CM
prov_timeout
dm_provision
Specifies the length of time to wait to receive a complete response from the provisioning agent.
See the instructions in the pin.conf file.
dm_prov_telco
provisioning_enabled
fm_tcf
Enables charge offer provisioning.
CM
simulate_agent
fm_tcf
Creates a response and updates the service order.
CM
Tax Calculation pin.conf Entries
Table 64-14 lists the Tax Calculation pin.conf entries.
Table 64-14 Tax Calculation pin.conf Entries
commtax_series
dm_vertex
Specifies the Vertex tax package that BRM uses to calculate telecom taxes.
See "Configuring the Vertex DM for Communications Tax Q Series" in BRM Calculating Taxes.
dm_vertex
Restart the DM after changing this entry.
commtax_config_path
dm_vertex
Specifies the location of Communications Tax Q Series configuration file (ctqcfg.xml).
dm_vertex
Valid only when commtax_series is set to 6. Restart the DM after changing this entry.
commtax_config_name
dm_vertex
Specifies the Communications Tax Q Series configuration name.
dm_vertex
include_zero_tax
fm_rate
Specifies whether to include zero tax amounts in the tax jurisdictions for the event's balance impacts.
See "Reporting Zero Tax Amounts" in BRM Calculating Taxes.
CM
provider_loc
fm_rate_pol
Specifies the city, state, ZIP code, and country where services are provided for taxation.
CM
The new value becomes effective immediately and all subsequent tax calculations use the new address. You do not need to restart the CM.
quantum_logfile
dm_vertex
Specifies the QSUT API to log debug information (into the specified file name) about the current transaction to be processed for tax calculation.
See "Setting Up Tax Calculation for Vertex" in BRM Calculating Taxes.
dm_vertex
quantumdb_passwd
dm_vertex
Specifies the Oracle user password.
See "Configuring Vertex Manager" in BRM Calculating Taxes.
dm_vertex
quantumdb_register
dm_vertex
Specifies whether to log an audit trail of invoices in the Quantum Register database.
dm_vertex
quantumdb_server
dm_vertex
Specifies the name of the database server than contains the Quantum tables.
dm_vertex
quantumdb_source
dm_vertex
Specifies the schema where the STQ tables reside. For Indexed Sequential Access Method (ISAM) databases, specifies the ISAM data file directory.
dm_vertex
quantumdb_user
dm_vertex
Specifies the name of the Oracle user.
dm_vertex
tax_now
fm_ar
Specifies when tax is calculated for account-level adjustments (at the end of billing or at the time of adjustment).
CM
tax_return_juris
fm_rate
Specifies whether to summarize taxes by jurisdiction or to itemize taxes.
CM
tax_return_loglevel
fm_rate
Specifies how to log messages returned from the taxation DM.
CM
tax_reversal_with_tax
fm_ar
Specifies whether to apply a tax reversal for an adjustment, dispute, or settlement
CM
tax_supplier_map
fm_rate
Specifies the location of the tax_supplier_map file.
CM
Billing utilities
tax_valid
fm_cust_pol
Specifies how to validate the state and zip code of the billing address during account creation.
CM
taxation_switch
fm_bill
Enables taxation.
See "Enabling and Disabling Taxation Globally" in BRM Calculating Taxes.
CM
taxcodes_map
fm_rate
Specifies the location of the taxcodes_map file.
CM
Billing utilities
vertex_db
fm_rate
Specifies the database number of the Vertex database.
See "Specifying Connection Entries" in BRM Calculating Taxes.
CM
