64 Business Logic pin.conf Reference
Learn how to use the business logic pin.conf settings to configure Oracle Communications Billing and Revenue Management (BRM).
Topics in this document:
See also "business_params Reference" and "System Administration pin.conf Reference".
Account Creation pin.conf Entries
Table 64-1 lists the account creation pin.conf entries.
Table 64-1 Account Creation pin.conf Entries
| Name | Program | Description | pin.conf File | Implementation |
allow_active_service_with_inactive_account |
fm_cust |
Specifies whether services can be activated (during a SET_STATUS operation) if the account or bill unit is inactive. |
CM |
Cached by the CM. Restart the CM after changing this entry. |
cc_checksum |
fm_cust_pol |
Specifies whether to run checksum validation on the customer's credit card during account creation. |
CM |
The new value becomes effective immediately and applies to the next account created. The CM does not need to be restarted. |
config_dir |
fm_cust_pol |
Specifies the location of the ISP configuration data, which is stored in the default.config file. Used by the PCM_OP_CUST_POL_GET_CONFIG policy opcode. |
CM |
country |
fm_cust_pol |
Specifies the default country for new accounts (default is USA). |
CM |
currency |
fm_cust_pol |
Specifies the default currency for new accounts. |
CM |
domain |
fm_cust_pol |
Specifies the email domain assigned to customers during account creation. |
CM |
new_account_welcome_msg |
fm_cust_pol |
Specifies whether the system should send the default welcome message on account creation. |
CM |
welcome_dir |
fm_cust_pol |
Specifies the location of the welcome message sent to customers after account creation. |
CM |
Accounts Receivable pin.conf Entries
Table 64-2 lists the Accounts Receivable pin.conf entries.
Table 64-2 Accounts Receivable pin.conf Entries
calc_cycle_from_cycle_start_t |
fm_bill |
Specifies whether to calculate charge offer fees based on the charge offer's purchase date (PIN_FLD_CYCLE_START_T). See "Calculating Cycle Fees for Backdating" in BRM Configuring and Running Billing. |
CM |
This value is read by the utility when it runs. You do not need to restart the CM. |
cycle_tax_interval |
fm_bill |
Determines whether deferred taxes are calculated separately for a paying parent bill unit and its nonpaying child bill units or are consolidated into a single tax item for both the parent and child bill units. |
CM |
item_search_batch |
fm_bill |
Specifies the number of items returned by a step search. |
CM |
overdue_tolerance |
fm_bill |
Specifies how BRM treats amounts applied to the item when they are less than the amount due as a result of euro and Economic and Monetary Union (EMU) conversions. See "Rounding Errors for Overpayments and Underpayments" in BRM Managing Customers. |
CM |
underdue_tolerance |
fm_bill |
Specifies how BRM treats amounts applied to the item when they are more than the amount due as a result of euro and EMU conversions. See "Rounding Errors for Overpayments and Underpayments" in BRM Managing Customers. |
CM |
Billing pin.conf Entries
Table 64-3 lists the Billing pin.conf entries.
Table 64-3 Billing pin.conf Entries
advance_bill_cycle |
fm_bill |
Sets the first billing date to be the day after account creation. See "Setting the First Billing Cycle to the Day after Account Creation" in BRM Configuring and Running Billing. |
CM |
attach_item_to_event |
fm_act |
Specifies how BRM assigns event and service combinations to bill items. See "About Using Event and Service Combinations to Assign Bill Items" in BRM Configuring and Running Billing. |
CM |
bill_when |
fm_cust_pol |
Specifies the default billing-cycle length. See "Setting the Default Billing-Cycle Length" in BRM Configuring and Running Billing. |
CM |
The new value becomes effective immediately. You do not have to restart the CM. |
billing_segment_config_refresh_delay |
fm_cust |
Specifies how often data in the cached /config/billing_segment object is automatically refreshed from the database. See "Updating Billing Segments" in BRM Configuring and Running Billing. |
CM |
config_billing_cycle |
fm_bill |
Specifies how long after the billing cycle ends that new events are considered for the previous month's bill. |
CM Billing utilities |
config_billing_delay |
fm_bill |
Specifies the billing delay interval during which both old events (for the previous cycle) and new events (for the current cycle) can be processed. When specified, the system creates the next bill object (for the next billing cycle). Bill total calculation occurs only outside of this delay interval. See "Setting Up Delayed Billing" in BRM Configuring and Running Billing. |
custom_bill_no |
fm_bill |
Specifies the accounting cycle (first or last) in which to assign a bill number to a bill in a multi-month billing cycle. See "Specifying When to Apply Custom Bill Numbers" in BRM Configuring and Running Billing. |
cycle_delay_align |
fm_bill |
Specifies whether to align the charge offer purchase, cycle, and usage start and end times with the accounting cycle. See "Aligning Account and Cycle Start and End Times" in BRM Configuring and Running Billing. |
CM |
cycle_delay_use_special_days |
fm_bill |
Sets the delayed cycle start date to the 1st of the following month for all bundles purchased on the 29th, 30th, or 31st. See "Setting Delayed Cycle Start Dates to the 29th, 30th, or 31st" in BRM Configuring and Running Billing. |
deadlock_retry_count |
fm_bill_accts |
Specifies the number of retries to attempt when a deadlock occurs during a billing run. See "Specifying the Number of Retries in Case of a Deadlock". |
pin_billd |
This entry is read by the utility when it runs. You do not need to restart the CM. |
delay_cycle_fees |
fm_bill |
In systems set up for delayed billing, specifies when to apply cycle forward fees and cycle rollovers (during partial billing or final billing). See "Specifying When to Apply Cycle Forward Fees and Cycle Rollovers" in BRM Configuring and Running Billing. |
CM |
delta_step |
pin_billd |
Reduces contention at the database level during billing. |
pin_billd |
enable_30_day_proration |
fm_bill |
Allows you to base monthly proration on 30-day months rather than the actual number of days in a billing cycle. This is often needed when working in parallel with older legacy billing systems. See "About 30-Day-Based Proration" in BRM Configuring and Running Billing. |
CM |
enforce_billing |
pin_bill_accts |
Enforces partial billing from the billing application inside the billing delay interval. See "Enforcing Partial Billing in the Billing Delay Interval" in BRM Configuring and Running Billing. |
pin_billd |
group_by_account |
pin_deferred_act |
Specifies to use one thread to process scheduled actions for one account. |
pin_billd |
keep_cancelled_products_or__discounts |
fm_subscription_pol |
Specifies whether to keep canceled charge offers and discount offers. See "Providing Discounts to Closed Accounts" in BRM Configuring and Running Billing. |
CM |
The new value becomes effective immediately. You do not need to restart the CM. |
num_billing_cycles |
fm_subs |
Specifies the maximum number of billing cycles allowed between the current time and the backdated event time of a backdated operation. |
CM |
open_item_actg_include_prev_total |
fm_bill |
Includes previous bill totals in the pending receivable value calculated during billing for accounts that use open item accounting. See "Including Previous Balances in the Current Amount Due in Open Item Accounting" in BRM Configuring and Running Billing. |
CM |
Cached by the CM. Restart the CM after changing this entry |
purchase_fees_backcharge |
fm_bill |
Specifies which cycle (current or next) to apply the deferred purchase fees to during billing when the deferred time coincides with the billing time. See "Specifying Which Billing Cycle to Assign to Deferred Purchase Fees" in BRM Configuring and Running Billing. |
CM |
rating_longcycle_roundup_flag |
fm_rate |
Enables rounding up for the long cycle. |
CM |
stop_bill_closed_accounts |
fm_bill |
Stops billing of closed bill units (/billinfo objects) when all items have zero due. See "Suspending Billing of Closed Accounts" in BRM Configuring and Running Billing. |
CM |
timestamp_rounding |
fm_bill |
Rounds timestamp to midnight. See "About Time-Stamp Rounding" in BRM Configuring and Running Billing. See also "About Sub-Balances" in BRM Creating Product Offerings. |
CM |
unset_error_status |
pin_bill_accts |
Sets billing status in a bill unit when billing errors occur. See "Setting the Bill Unit Status When Billing Errors Occur" in BRM Configuring and Running Billing. |
pin_billd |
use_number_of_days_in_month |
fm_bill |
Specifies how to calculate proration when a cycle charge offer is purchased or canceled. See "Calculating Prorated Cycle Fees" in BRM Configuring and Running Billing. |
CM |
Collections pin.conf Entries
Table 64-4 lists the Collections pin.conf entries.
Table 64-4 Collections pin.conf Entries
account_search_batch |
fm_collections |
Specifies the number of bill units to retrieve in collections step searches. See "Setting the Number of Bill Units Retrieved during Step Searches" in BRM Collections Manager. |
CM |
collections_action_dependency |
fm_collect |
Creates dependencies between collections actions in a collections scenario. See "Creating Dependencies between Collections Actions in a Scenario" in BRM Collections Manager. |
CM |
email_body |
pin_collections_send_dunning pin_inv_send |
Specifies the path to a text file containing a customized message. See "Specifying a File for the Email Body" in BRM Collections Manager. |
pin_collections pin_inv |
The new value is effective immediately. You do not need to restart the CM. |
execute_all_actions |
fm_collections |
Specifies whether to run all actions, including actions due before the date on which pin_collections_process is run for the first time, or only to run actions due after the date on which pin_collections_process is run for the first time. See "Performing Scheduled Collections Actions after Reinstalling Collections Manager" in BRM Collections Manager. |
CM |
minimum_due |
pin_collections_process |
Specifies the minimum overdue balance that a bill unit must have to qualify for collections. See "Setting the Minimum Overdue Balance to Process" in BRM Collections Manager. |
pin_collections |
Customer Management pin.conf Entries
Table 64-5 lists the Customer Management pin.conf entries.
Table 64-5 Customer Management pin.conf Entries
apply_rollover |
fm_bill |
If you do not use rollovers, you can disable rollover calculation by using this entry. This entry is on by default, that is, rollovers are applied, but you can turn it off to increase performance. |
CM |
cycle_arrear_proration |
fm_rate |
Specifies when to prorate cycle arrears fees, at purchase or at cancellation. See "Proration for Special Cases" in BRM Configuring and Running Billing. |
CM |
em_db |
fm_delivery |
Specifies the Email Data Manager database number. See "Configuring the Email Data Manager" in BRM Managing Customers. |
CM |
intro_dir |
fm_cust_pol |
Specifies the location of the introductory message that allows a customer to confirm account creation. |
CM |
Discounting pin.conf Entries
Table 64-6 lists the Discounting pin.conf entries.
Table 64-6 Discounting pin.conf Entries
propagate_discount |
fm_subscription |
Enables immediate propagation of shared discount when a new discount is added to/deleted from the group or a member subscribes to/unsubscribes from the group. See "Configuring the Start and End Times for Discount Sharing" in BRM Managing Customers. |
CM |
rollover_zeroout_discounts |
fm_rate |
Zeroes-out the positive bucket. See "Configuring the Start and End Times for Discount Sharing" in BRM Managing Customers. |
CM |
General Ledger pin.conf Entries
Table 64-7 lists the General Ledger pin.conf entries.
Table 64-7 General Ledger pin.conf Entries
gl_segment |
fm_cust_pol |
Specifies the default G/L segment for an account during account creation. See "Changing the Default G/L Segment" in BRM Collecting General Ledger Data. |
CM |
transaction_grouping |
pin_ledger_report |
Specifies how many A/R accounts to group in a single transaction for ledger_report to run. See "Setting the Number of A/R Accounts per G/L Report" in BRM Collecting General Ledger Data. |
pin_billd |
Invoicing pin.conf Entries
Table 64-8 lists the Invoicing pin.conf entries.
Table 64-8 Invoicing pin.conf Entries
database |
pin_inv_accts pin_inv_export pin_inv_send pin_inv_upgrade |
Specifies the database schema to which the following utilities should connect:
See "Configuring the Invoice pin.conf for Multiple Database Schemas" in BRM Designing and Generating Invoices. |
pin_inv |
export_dir |
pin_inv_export |
Specifies the path to the invoice directory. See "Exporting Invoices" in BRM Designing and Generating Invoices. |
pin_inv |
from |
pin_inv_send |
Specifies the e-mail address of the sender. See "About Invoices" and "pin_inv_send" in BRM Designing and Generating Invoices. |
pin_inv |
html_template |
pin_inv_pol |
Specifies the HTML template file to use to generate invoices. |
CM |
invoice_db |
pin_inv_export pin_inv_send |
Specifies the database number for the schema. See "Configuring BRM to Use a Separate Invoice Database Schema" in BRM Designing and Generating Invoices. |
pin_inv |
invoice_dir |
fm_bill |
Specifies the directory where invoices are stored. See "Exporting Invoices" in BRM Designing and Generating Invoices. |
CM |
invoice_fmt |
Specifies the invoice format. See "Exporting Invoices" in BRM Designing and Generating Invoices. |
pin_inv |
inv_perf_features |
fm_inv |
Improves performance by removing unnecessary details from your invoices. |
CM |
sender |
fm_cust_pol pin_inv_send |
Specifies the name of the e-mail sender. |
CM pin_inv |
service_centric_invoice |
fm_inv_pol |
Enables service-centric invoicing. |
CM |
show_rerate_details |
fm_inv_pol |
Specifies whether to display shadow adjustment details on invoices. See "Including Shadow Event Adjustment Details in Invoices" in BRM Designing and Generating Invoices. |
CM |
subject |
pin_inv_send |
Specifies the subject of the e-mail. See "About Invoices" and "pin_inv_send" in BRM Designing and Generating Invoices. |
pin_inv |
Payments pin.conf Entries
Table 64-9 lists the Payments pin.conf entries.
Table 64-9 Payments pin.conf Entries
cc_revalidation_interval |
fm_pymt_pol |
Specifies the credit card revalidation interval. |
CM |
cc_validate |
fm_pymt_pol |
Specifies whether to validate a customer's credit card information during account creation. See "Validating Credit Cards at Account Creation" in BRM Managing Customers. |
CM |
config_payment |
fm_pymt |
Specifies the database and POID of the /config/payment object. Change this value if you create a custom /config/payment object. |
CM |
cvv2_required |
fm_pymt_pol |
Specifies whether to use Visa CVV2 fraud protection for Paymentech transactions. See "Requiring Additional Protection against Credit Card Fraud" in BRM Configuring and Collecting Payments. |
CM |
dd_collect |
fm_pymt_pol |
Specifies whether to perform real-time authorization of the fixed charges information with the customer's debit card during account creation. |
CM |
dd_revalidation_interval |
fm_pymt_pol |
Specifies the debit card revalidation interval. |
CM |
dd_validate |
fm_pymt_pol |
Specifies whether to validate a customer's direct debit (debit card) information during account creation. |
CM |
merchant |
fm_cust_pol |
Specifies the merchant to receive money collected during credit-card processing. See "Specifying Merchant IDs and Merchant Numbers" in BRM Configuring and Collecting Payments. |
CM |
minimum |
pin_billd |
Specifies the minimum balance for retrieving accounts for collection. Use this entry to set a minimum threshold for the amount due on an account when searching for accounts for collection. See "Specifying the Minimum Payment to Collect" in BRM Configuring and Running Billing. |
pin_billd |
minimum_payment |
fm_pymt_pol |
Specifies the minimum amount to charge. The amount charged is greater than or equal to the minimum amount. See "Specifying the Minimum Amount to Charge" in BRM Configuring and Running Billing. |
CM |
minimum_refund |
fm_pymt_pol |
Specifies the minimum refund amount that the system allows. The amount refunded is greater than or equal to the minimum amount. See "Specifying the Minimum Amount to Refund" in BRM Managing Accounts Receivable. |
CM |
validate_acct |
fm_pymt_pol |
Allows use of the customer's credit card on an account different from the root account. See "Specifying the Account That Records Credit Card Validations" in BRM Managing Customers. |
CM |
Pricing and Rating pin.conf Entries
Table 64-10 lists the Pricing and Rating pin.conf entries.
Table 64-10 Pricing and Rating pin.conf Entries
backdate_trigger_auto_rerate |
fm_subs |
Specifies whether to create auto-rerate job objects used by pin_rerate. |
CM |
backdate_window |
fm_subs |
Specifies the minimum time difference needed between the current time and the backdated event time for triggering automatic rerating. |
CM |
cancel_tolerance |
fm_bill |
Specifies the cancellation tolerance of account charge offers in minutes. See "Canceling Charge Offers without Charging a Cancel Fee" in BRM Managing Customers. |
CM |
delay |
pin_rerate |
Specifies the delay for rerating jobs. |
pin_rerate |
fm_offer_profile_cache |
cm_cache |
Specifies the attributes of the CM cache for offer profiles. Note: This entry is mandatory for policy-driven charging. See BRM Creating Product Offerings. |
CM |
fm_price_cache_beid |
cm_cache |
Specifies attributes of the CM cache for the size of balance element IDs (BEID). See "Improving Performance for Loading Large Product Offerings". |
CM |
fm_price_prod_provisioning_cache |
cm_cache |
Specifies the attributes of the CM cache for the size of charge offer provisioning tags. See "Improving Performance for Loading Large Product Offerings". |
CM |
log_refresh_product |
fm_rate |
Specifies whether to log product offering changes. You can use the log entries to generate notifications about such changes. See "Logging Changes to Product Offerings" in BRM Creating Product Offerings. |
CM |
rate_change |
fm_subscription |
Enables the enhanced pricing change management feature. See "Rerating Cycle Forward and Cycle Forward Arrears Charges" in BRM Rerating Events. |
CM |
rating_max_scale |
fm_rate |
Specifies the precision level of decimal values. See "Changing the Precision of Rounded and Calculated Values". |
CM |
rating_quantity_rounding_scale |
fm_rate |
Specifies the precision of rounded values. See "Changing the Precision of Rounded and Calculated Values". |
CM |
rating_timezone |
fm_rate |
Specifies the server time zone. |
CM |
refresh_product_interval |
fm_rate |
Specifies the interval in which product offerings are refreshed in cache memory. See "Setting the Interval for Checking for Product Offering Changes". |
CM |
timezone_file |
fm_rate |
Specifies the location of the timezones.txt file. |
CM |
update_interval |
fm_zonemap_pol |
Specifies an interval for revising the value map. See "Setting the Interval for Checking for Product Offering Changes". |
CM |
validate_deal_dependencies |
fm_utils |
Specifies whether to validate the bundle prerequisites and mutually exclusive relations. See "Configuring Bundle Dependencies" in BRM Managing Customers. |
CM |
Revenue Assurance pin.conf Entries
Table 64-11 lists the Revenue Assurance pin.conf entries.
Table 64-11 Revenue Assurance pin.conf Entries
writeoff_control_point_id |
fm_process_audit |
Changes the control point ID. See BRM Collecting Revenue Assurance Data. |
CM |
Service Lifecycle Management pin.conf Entries
Table 64-12 lists the Service Lifecycle Management pin.conf entries.
Table 64-12 Service Lifecycle Management pin.conf Entries
fm_bill_template_cache |
cm_cache |
Specifies attributes of the template cache. This cache is used by the Service Lifecycle Management feature. See "Managing Service Life Cycles" in BRM Managing Customers. |
CM |
fm_bill_utils_business_profile_cache |
cm_cache |
Specifies attributes of the business_profile cache. This cache is used by the Service Lifecycle Management feature. See "Managing Service Life Cycles" in BRM Managing Customers. |
CM |
fm_cust_lifecycle_config_cache |
cm_cache |
Specifies attributes of the lifecycle cache. This cache is used by the Service Lifecycle Management feature. See "Managing Service Life Cycles" in BRM Managing Customers. |
CM |
fm_cust_statemap_config_cache |
cm_cache |
Specifies attributes of the statemap cache. This cache is used by the Service Lifecycle Management feature. See "Managing Service Life Cycles" in BRM Managing Customers. |
CM |
Services Framework pin.conf Entries
Table 64-13 lists the Services Framework pin.conf entries.
Table 64-13 Service Framework pin.conf Entries.
agent_return |
fm_tcf |
Specifies the provisioning status when provisioning is simulated. |
CM |
commit_at_prep |
dm_provision |
Specifies whether to send the payload to the agent at PREP_COMMIT time and not to send anything at COMMIT time. See "Configuring the Provisioning Data Manager" in BRM Telco Integration. |
dm_prov_telco |
connect_retries |
dm_provision |
Specifies the number of times dm_provision attempts to connect to the Infranet agent on connection failure. See "Provisioning Data Manager Configuration File Entries" in BRM Telco Integration. |
dm_prov_telco |
connect_retry_interval |
dm_provision |
Specifies how many seconds to wait before retrying to connect to the Infranet agent on connection failure. See "Provisioning Data Manager Configuration File Entries" in BRM Telco Integration. |
dm_prov_telco |
prov_db |
fm_tcf |
Specifies the number of the database to which provisioning connects to send the service order. See "Connecting the Connection Manager to the Provisioning Data Manager" in BRM Telco Integration. |
CM |
prov_ptr |
dm_provision |
Specifies where to find the Provisioning Data Manager. See "Configuring the Provisioning Data Manager" in BRM Telco Integration. |
CM |
prov_timeout |
dm_provision |
Specifies the length of time to wait to receive a complete response from the provisioning agent. See the instructions in the pin.conf file. |
dm_prov_telco |
provisioning_enabled |
fm_tcf |
Enables charge offer provisioning. |
CM |
simulate_agent |
fm_tcf |
Creates a response and updates the service order. |
CM |
Tax Calculation pin.conf Entries
Table 64-14 lists the Tax Calculation pin.conf entries.
Table 64-14 Tax Calculation pin.conf Entries
commtax_series |
dm_vertex |
Specifies the Vertex tax package that BRM uses to calculate telecom taxes. See "Configuring the Vertex DM for Communications Tax Q Series" in BRM Calculating Taxes. |
dm_vertex |
Restart the DM after changing this entry. |
commtax_config_path |
dm_vertex |
Specifies the location of Communications Tax Q Series configuration file (ctqcfg.xml). See "Configuring the Vertex DM for Communications Tax Q Series" in BRM Calculating Taxes. |
dm_vertex |
Valid only when commtax_series is set to 6. Restart the DM after changing this entry. |
commtax_config_name |
dm_vertex |
Specifies the Communications Tax Q Series configuration name. See "Configuring the Vertex DM for Communications Tax Q Series" in BRM Calculating Taxes. |
dm_vertex |
include_zero_tax |
fm_rate |
Specifies whether to include zero tax amounts in the tax jurisdictions for the event's balance impacts. See "Reporting Zero Tax Amounts" in BRM Calculating Taxes. |
CM |
provider_loc |
fm_rate_pol |
Specifies the city, state, ZIP code, and country where services are provided for taxation. |
CM |
The new value becomes effective immediately and all subsequent tax calculations use the new address. You do not need to restart the CM. |
quantum_logfile |
dm_vertex |
Specifies the QSUT API to log debug information (into the specified file name) about the current transaction to be processed for tax calculation. See "Setting Up Tax Calculation for Vertex" in BRM Calculating Taxes. |
dm_vertex |
quantumdb_passwd |
dm_vertex |
Specifies the Oracle user password. See "Configuring Vertex Manager" in BRM Calculating Taxes. |
dm_vertex |
quantumdb_register |
dm_vertex |
Specifies whether to log an audit trail of invoices in the Quantum Register database. See "Setting Up Tax Calculation for Vertex" in BRM Calculating Taxes. |
dm_vertex |
quantumdb_server |
dm_vertex |
Specifies the name of the database server than contains the Quantum tables. See "Configuring Vertex Manager" in BRM Calculating Taxes. |
dm_vertex |
quantumdb_source |
dm_vertex |
Specifies the schema where the STQ tables reside. For Indexed Sequential Access Method (ISAM) databases, specifies the ISAM data file directory. See "Configuring Vertex Manager" in BRM Calculating Taxes. |
dm_vertex |
quantumdb_user |
dm_vertex |
Specifies the name of the Oracle user. See "Configuring Vertex Manager" in BRM Calculating Taxes. |
dm_vertex |
tax_now |
fm_ar |
Specifies when tax is calculated for account-level adjustments (at the end of billing or at the time of adjustment). |
CM |
tax_return_juris |
fm_rate |
Specifies whether to summarize taxes by jurisdiction or to itemize taxes. |
CM |
tax_return_loglevel |
fm_rate |
Specifies how to log messages returned from the taxation DM. |
CM |
tax_reversal_with_tax |
fm_ar |
Specifies whether to apply a tax reversal for an adjustment, dispute, or settlement |
CM |
tax_supplier_map |
fm_rate |
Specifies the location of the tax_supplier_map file. |
tax_valid |
fm_cust_pol |
Specifies how to validate the state and zip code of the billing address during account creation. |
CM |
taxation_switch |
fm_bill |
Enables taxation. See "Enabling and Disabling Taxation Globally" in BRM Calculating Taxes. |
CM |
taxcodes_map |
fm_rate |
Specifies the location of the taxcodes_map file. |
vertex_db |
fm_rate |
Specifies the database number of the Vertex database. See "Specifying Connection Entries" in BRM Calculating Taxes. |
CM |
