40 Reference Guide to BRM Error Codes
Learn how to use the Oracle Communications Billing and Revenue Management (BRM) error locations, classes, and codes to help troubleshoot problems in your system.
Topics in this document:
For information about troubleshooting BRM, including examples of error messages that use these error codes, see "Resolving Problems in Your BRM System".
Interpreting BRM Error Codes
When a BRM process has a problem, its log file displays an error message that often includes:
  • Error location; for example:
    location=<PIN_ERRLOC_FM:5>
  • Error class; for example:
    class=<PIN_ERRCLASS_APPLICATION:4>
  • Error code; for example:
    errno=<PIN_ERR_BAD_VALUE:46>
The tables below list the error locations, classes, and codes and give the meaning of each. Use this information to help find what caused the problem and what you can do to solve it.
BRM Error Locations
Table 40-1 lists the BRM error locations.
Table 40-1 BRM Error Locations
Error Location No. Source of the Error
PIN_ERRLOC_PCM
1
General problem connecting to BRM. Common causes include illegal parameters.
PIN_ERRLOC_PCP
2
Internal error. The Portal Communications Protocol (PCP) library provides communication support between the modules of BRM. Common causes include network connection failures. This value indicates a system problem that requires immediate attention.
PIN_ERRLOC_CM
3
Connection Manager. Common causes include an unknown opcode or an input flist missing the required Portal object ID (POID) field.
PIN_ERRLOC_DM
4
Data Manager. Common causes include an input flist that does not meet the required specification or a problem communicating with the underlying data storage system.
PIN_ERRLOC_FM
5
Facilities Module. Common causes include an input flist that does not conform to the required specification.
PIN_ERRLOC_FLIST
6
An flist manipulation routine local to the application. Common causes include an illegal parameter and low system memory.
PIN_ERRLOC_POID
7
POID manipulation routine local to the application. Common causes include an illegal parameter and low system memory.
PIN_ERRLOC_APP
8
An error occurred within an application.
PIN_ERRLOC_QM
9
An error occurred within the Queue Manager (qmflist).
PIN_ERRLOC_PCMCPP
10
An error occurred within the PCM C++ wrapper.
PIN_ERRLOC_LDAP
11
An error occurred within the LDAP library.
PIN_ERRLOC_UTILS
14
An error occurred within a BRM utility.
PIN_ERRLOC_JS
15
An error occurred within the Java Server Framework.
PIN_ERRLOC_JSAPP
16
An error occurred within the Java Server Application or opcode handler.
PIN_ERRLOC_PDO
17
An error occurred within the BRM data objects.
BRM Error Classes
Table 40-2 lists the BRM error classes.
Table 40-2 BRM Error Classes
Error Class No. Meaning
PIN_ERRCLASS_SYSTEM_DETERMINATE
1
The error was caused by a system failure during the operation. Retrying the operation is unlikely to succeed, and the system failure should be investigated immediately. The error was detected before any data was committed to the database; no data has changed. After the error is fixed, retry the operation.
PIN_ERRCLASS_SYSTEM_INDETERMINATE
2
The error was caused by a system failure during the “commit" phase of an operation. The error might not be repeatable, and the system might not save specific information about the error. There is a small window during the commit where a network failure can leave the system unsure of whether the commit occurred. This means it is up to the application to determine whether system data has been changed. This class of error is extremely rare, but you must deal with it carefully to avoid corrupting the data in the database. The transactional model of BRM guarantees that either all the changes within the indeterminate transaction are committed, or none of them are committed and the system data is left unchanged. If you find that no changes were made, resolve the system failure and retry the operation.
PIN_ERRCLASS_SYSTEM_RETRYABLE
3
The error was probably caused by a transient condition. Try the operation again. Common causes include a temporary shortage of system resources (perhaps caused by too many connections to the CM) or a failure of a network connection that you can route around. The error was detected before any data was committed to the database; no data has changed.
4
The error was caused by a custom application passing invalid data to BRM or by a system failure within the client application. The error was detected before the requested operation was performed, so no data in the database has been changed. After you fix the error, retry the operation.
BRM Error Codes
Table 40-3 lists the BRM error codes.
Table 40-3 BRM Error Codes
Error Code No. Description
PIN_ERR_NONE
0
No error.
This error code indicates a general condition, not a specific error. Some BRM routines use this error code to indicate that the routine was successful.
PIN_ERR_NO_MEM
1
There was insufficient memory to complete the attempted operation.
Check system memory. Also check the shmsize and bigsize values in the Data Manager configuration file (pin.conf). If you see this error code with a custom application, check for memory leaks.
PIN_ERR_NO_MATCH
2
BRM couldn't find the value it was looking for.
From the Data Manager, this error indicates a bad search template from the qm_flist.
From the SDK FM, this error means that the FM cannot find the object it was told to modify.
PIN_ERR_NOT_FOUND
3
BRM couldn't find a value.
This error code doesn't always indicate an error. For example, some opcodes look for a value in the configuration file, but if the value is not there, a default value can be used.
PIN_ERR_BAD_ARG
4
A required field in an flist is incorrect.
This is always a serious error because the system will not work until the argument is fixed. The problem is usually a programming or data entry error.
PIN_ERR_BAD_XDR
5
The application unexpectedly lost the connection to the BRM database.
Usually, this error means that the connection to the network was lost. If the network is working correctly, the BRM server might have stopped working. Look for errors in the CM log file. Also check for CM or DM core files.
PIN_ERR_BAD_FIRST_READ
6
No longer used.
PIN_ERR_BAD_READ
7
BRM couldn't read from the network or some other IO device, probably because the connection was cut off unexpectedly.
PIN_ERR_NO_SOCKET
8
BRM couldn't create a socket.
The machine or process might be overloaded and have reached a limit on socket/file descriptors. The networking part of the operating system might have failed.
Try restarting the machine. If that doesn't work, report the problem to the OS vendor.
PIN_ERR_BAD_TYPE
9
BRM encountered an erroneous field or object type.
This error usually results from programming errors in custom applications and FMs, but the error might also result from a mismatch between a field and its corresponding field type.
If seen when pcpxdr_fld_list is called, it means a down-level version of the libraries saw incompatible wire protocols or a new field type.
PIN_ERR_DUPLICATE
10
BRM could not create an object because the requested ID is already used by another object.
PIN_COMPARE_EQUAL
11
This code doesn't indicate an error. The billing FM uses this code for internal operations.
PIN_COMPARE_NOT_EQUAL
12
PIN_ERR_MISSING_ARG
13
A required argument is missing.
If the log file doesn't indicate the field, see the specification for the opcode.
PIN_ERR_BAD_POID_TYPE
14
BRM encountered an erroneous object type.
This is similar to error 9, but is more specific to object type. For example, BRM was expecting an account object but encountered an event object.
PIN_ERR_BAD_CRYPT
15
Packet header failed encryption/decryption. Possible corruption of data.
PIN_ERR_BAD_WRITE
16
Error while attempting to send data on the IP socket.
PIN_ERR_DUP_SUBSTRUCT
17
Information not available.
PIN_ERR_BAD_SEARCH_ARG
18
A required field in a search template or flist is incorrect.
PIN_ERR_BAD_SEARCH_ARG_RECID
19
Invalid automatic number identification (ANI) in the search operation.
PIN_ERR_DUP_SEARCH_ARG
20
There are duplicate entries in the search argument list.
PIN_ERR_NONEXISTANT_POID
21
BRM cannot find the object in the database.
PIN_ERR_POID_DB_IS_ZERO
22
The database number is specified as zero.
Make sure the routine is passing a valid database number that matches the number in the configuration file.
PIN_ERR_UNKNOWN_POID
23
The POID does not contain valid information, or the format is incorrect.
PIN_ERR_NO_SOCKETS
24
PIN_ERR_DM_ADDRESS_LOOKUP
_FAILED
25
The Connection Manager couldn't find the Data Manager.
The Bind (or DNS) service is pointing to the wrong TCP/IP address, or the network is having problems.
Try pinging the DM to verify the network connection. Check the DM pointer specified in the configuration file for the CM.
PIN_ERR_DM_CONNECT_FAILED
26
BRM couldn't connect to the Data Manager.
The configuration file for the CM might be pointing to the wrong DM, or the DM might not be running.
PIN_ERR_NAP_CONNECT_FAILED
27
An application couldn't connect to the Connection Manager.
The configuration file for the application might be pointing to the wrong CM. The CM might not be running, or there might not be any more available connections. Also check for network errors between the application and the CM. For example, no more TCP sockets might be available on the client or CM machine.
PIN_ERR_INVALID_RECORD_ID
28
The ID of the specified element in the array is not valid.
The specified ID might be greater than the maximum record ID.
PIN_ERR_STALE_CONF
29
BRM found outdated values in pin.conf entries.
PIN_ERR_INVALID_CONF
30
Configuration data is missing or in an invalid format in the pin.conf files.
PIN_ERR_WRONG_DATABASE
31
The database number in the POID is not valid.
PIN_ERR_DUP_ARG
32
The flist has duplicate fields or elements.
PIN_ERR_BAD_SET
33
BRM couldn't assign an object ID.
PIN_ERR_BAD_CREATE
34
A routine couldn't create an object.
PIN_ERR_BAD_FIELD_NAME
35
Mapping error from field home to type.
PIN_ERR_BAD_OPCODE
36
Undefined opcode used.
PIN_ERR_TRANS_ALREADY_OPEN
37
An application attempted to open a transaction when one was already open on the same object.
This error usually results from a programming error in a custom application or FM. The error sometimes appears in a series of cascading errors; look for a predecessor error.
PIN_ERR_TRANS_NOT_OPEN
38
An application attempted to commit or cancel a transaction, but none had been opened.
This error usually results from a programming error in a custom application or FM. The error sometimes shows up in a series of cascading errors; look for a predecessor error.
PIN_ERR_NULL_PTR
39
A routine couldn't get a value because it was set to “null".
PIN_ERR_BAD_FREE
40
A routine tried, but failed, to free memory that was no longer needed.
This error usually results from a programming error in a custom application or FM. This problem might cause memory leaks.
PIN_ERR_FILE_IO
41
Error while attempting to do an IO operation on a file.
PIN_ERR_NONEXISTANT_ELEMENT
42
The array in the specified object doesn't have the specified element.
PIN_ERR_STORAGE
43
The database returned an error.
Check the Data Manager log file for database-specific error messages. Also check the database server error logs.
PIN_ERR_TRANS_TOO_MANY_POIDS
44
BRM attempted transactions to too many Data Managers.
PIN_ERR_TRANS_LOST
45
The transaction was lost. The Data Manager failed during a transaction.
PIN_ERR_BAD_VALUE
46
BRM couldn't interpret data from the database.
The data isn't valid in the current context, and BRM cannot resolve the conflict.
PIN_ERR_PARTIAL
47
When sending a batch of transactions to the credit card Data Managers, some of the credit cards were processed, but others were not.
PIN_ERR_NOT_YET_DONE
48
BRM has not yet completed an operation (such as an opcode or transaction).
This is typically an internal debugging error code that isn't displayed.
PIN_ERR_STREAM_IO
49
The application encountered an error while sending data to or from the BRM database.
Usually, this error means that the connection to the network was lost. If the network is working correctly, the server might have stopped working. Look for errors in the CM log file. Also check for CM or DM core files.
PIN_ERR_STREAM_EOF
50
PIN_ERR_OP_NOT_OUTSTANDING
51
No operation is in progress under this context.
PIN_ERR_OP_ALREADY_BUSY
52
There is an operation already in progress within this context.
PIN_ERR_OP_ALREADY_DONE
53
Certain operations can be done only once. This error indicates that an operation of this type is being attempted a second time.
PIN_ERR_NO_DATA_FIELDS
54
The Data Manager received an flist with no data fields.
Check the input flist.
PIN_ERR_PROHIBITED_ARG
55
BRM couldn't create an object because one or more values were invalid or fields do not allow updating.
PIN_ERR_BAD_LOGIN_RESULT
56
The application couldn't connect to the CM.
Check the login name and password.
PIN_ERR_CM_ADDRESS_LOOKUP
_FAILED
57
The application couldn't find the computer running the CM. The Bind (or DNS) service is pointing to the wrong TCP/IP address, or the network is having problems.
Try pinging the CM to verify the network connection. Check the CM host name specified in the configuration file for the application.
PIN_ERR_BAD_LOGIN_REDIRECT_INFO
58
The re direction information received from the CMMP is incorrect.
PIN_ERR_TOO_MANY_LOGIN
_REDIRECTS
59
Too many connect login redirects from the CMMP.
This error might have resulted from a loop in the configuration. Check the configuration files for the application, CM, and DM.
PIN_ERR_STEP_SEARCH
60
The step search operation didn't find an expected STEP_NEXT/STEP_END.
PIN_ERR_STORAGE_DISCONNECT
61
BRM lost the connection with the database during the middle of a transaction and couldn't re-establish the connection.
See "Configuring Oracle Databases" in BRM Installation Guide.
PIN_ERR_NOT_GROUP_ROOT
62
Not the root of a group.
PIN_ERR_BAD_LOCKING
63
Error while attempting to lock/unlock a heap storage.
PIN_ERR_AUTHORIZATION_FAIL
64
No information available.
PIN_ERR_NOT_WRITABLE
65
Tried to write a field that cannot be modified.
PIN_ERR_UNKNOWN_EXCEPTION
66
Unknown C++ exception.
PIN_ERR_START_FAILED
67
BRM couldn't start the process.
PIN_ERR_STOP_FAILED
68
BRM couldn't stop the process.
PIN_ERR_INVALID_QUEUE
69
PIN_ERR_TOO_BIG
70
PIN_ERR_BAD_LOCALE
71
BRM doesn't understand the locale. Check the locale of the computer running the client application.
PIN_ERR_CONV_MULTIBYTE
72
A client application had a problem converting data from UTF8 format, as it is stored in the BRM database, to multibyte format. Either the client has the wrong locale or the data is corrupted.
PIN_ERR_CONV_UNICODE
73
A client application had a problem converting data from UTF8 format, as it is stored in the BRM database, into Unicode format. Either the client has the wrong locale or the data are corrupted.
PIN_ERR_BAD_MBCS
74
The input flist includes a string that is not in valid multibyte format.
PIN_ERR_BAD_UTF8
75
The input flist includes a string that is not in valid Unicode format.
PIN_ERR_CANON_CONV
76
PIN_ERR_UNSUPPORTED_LOCALE
77
BRM doesn't support canonicalization for the locale of the client application.
PIN_ERR_CURRENCY_MISMATCH
78
A nonpaying bill unit (/billinfo object) or account has a different account currency than the parent account.
PIN_ERR_DEADLOCK
79
Two or more database sessions attempted to access the same database resource. Each session waits for another session to release locks on the resource. The database detects the deadlock and cancels one of the session's operations. If you receive this error, retry the transaction or operation.
PIN_ERR_BACKDATE_NOT_ALLOWED
80
BRM cannot backdate the adjustment, write-off, or other transaction because the G/L report has already been posted.
PIN_ERR_CREDIT_LIMIT_EXCEEDED
81
PIN_ERR_IS_NULL
82
The value is null (not set).
PIN_ERR_DETAILED_ERR
83
A detailed error message uses an enhanced buffer (errbuf).
PIN_ERR_AR_ACTION_EXISTS
84
Outstanding A/R actions present which must be closed before proceeding.
PIN_ERR_BACKDATE_BEFORE_ACCOUNT_EFFECTIVE_DATE
85
Backdated date is prior to the effective date of the account.
PIN_ERR_BACKDATE_BEFORE_GL_POSTING_DATE
86
Backdated date is prior to the G/L posting date.
PIN_ERR_BACKDATE_BEFORE_SERVICE_EFFECTIVE_DATE
87
Backdated date is prior to the effective date of the service.
PIN_ERR_BACKDATE_BEFORE_OFFERING_EFFECTIVE_DATE
88
Backdated date is prior to the effective date of the offer.
PIN_ERR_BACKDATE_FEES_ALREADY_APPLIED
89
Fees have already been applied for backdated date.
PIN_ERR_BACKDATE_BEFORE_STATUS_CHANGE
90
Backdated date is prior to the date of the last status change.
PIN_ERR_BACKDATE_BEFORE_PURCHASE_START
91
Backdated date is prior to purchase start date.
PIN_ERR_STMT_CACHE
92
There is a problem with the statement cache.
PIN_ERR_CACHE_SIZE_ZERO
93
Tried to initialize cm_cache with zero size.
PIN_ERR_DEF_BG_MOVEMENT
94
Cannot repoint the default balance group of a billinfo.
PIN_ERR_ACCT_BG_MOVEMENT
95
Cannot repoint the account level balance group.
PIN_ERR_VALIDATE_PROFILE
96
Profile validation failed.
PIN_ERR_CORR_INV_DISABLED
97
Corrective Invoicing feature is disabled.
PIN_ERR_BILL_IS_SUBORD
98
Corrective bill cannot be produced for subordinate bill.
PIN_ERR_BILL_IS_NOT_FINALIZED
99
Bill has to be finalized in order to produce a corrective bill.
PIN_ERR_REASON_AND_DOMAIN_NOT_PRESENTED
100
Both the fields, REASON_ID and REASON_DOMAIN_ID, must be presented in the input.
PIN_ERR_TYPE_NOT_REPLACEMENT
101
In the absence of A/R charges, the invoice type should be set to 'Replacement'.
PIN_ERR_NO_AR_CHARGES
102
There are no A/R charges.
PIN_ERR_BILL_IS_NOT_LAST
103
The bill is not the last one for the 'balance_forward' accounting type.
PIN_ERR_BILL_IS_FULLY_PAID
104
Bill is fully paid.
PIN_ERR_BILL_IS_PAID
105
Bill is already paid.
PIN_ERR_AR_CHARGES_ARE_TOO_LOW
106
A/R charges are less than the threshold value.
PIN_ERR_NOT_PRIMARY
107
Not the primary instance.
PIN_ERR_REASON_OR_DOMAIN_ARE_NOT_CORRECT
108
Either reason or domain are not correct.
PIN_ERR_NO_INVOICE_FOR_BILL
109
The invoice for the bill has to be created before producing the corrective bill.
PIN_ERR_PAYMENTS_EXIST
110
There are no A/R charges except payments.
PIN_ERR_INVALID_STATE
111
The state is invalid.
PIN_ERR_NO_SECONDARY
112
No secondary instance exists.
PIN_ERR_ACCT_CLOSED
113
The account is in the Closed state.
PIN_ERR_EM_CONNECT_FAILED
114
The connection between the CM and EM failed.
PIN_ERR_FAST_FAIL
115
A fast fail occurred in dual timeout.
PIN_ERR_BAD_ENC_SCHEME
116
The MD5 encryption scheme is configured; however, the AES encryption library is being used.
PIN_ERR_MAX_BILL_WHEN
117
The value in the bill_when field exceeds the maximum number of months allowed in billing cycles.
PIN_ERR_PERF_LIMIT_REACHED
118
The performance limit has been reached.
PIN_ERR_ACTIVE_NOT_READY
119
The TIMOS passive instance is switching over to active, but it is not active yet.
PIN_ERR_POID_ALREADY_LOCKED
120
The POID is already locked.
PIN_ERR_SERVICE_LOCKED
121
This error code is used by SOX.
PIN_ERR_VALIDATE_PASSWORD
122
Password validation failed.
PIN_ERR_DISC_AMT_AND_PERCENT
123
Only one among discount amount and percent is allowed in input.
PIN_ERR_COLLECTIONS_MANDATORY_ACTION_STATUS_ERROR
124
Mandatory Action cannot be cancelled.
PIN_ERR_COLLECTIONS_ACTION_INSERT_ERROR
125
Actions cannot be inserted before or between complete actions.
PIN_ERR_COLLECTIONS_ALREADY_PART_OF_COLLECTIONS_GROUP
126
Billinfo is already part of another group.
PIN_ERR_COLLECTIONS_ALREADY_UNDER_PROMISE_TO_PAY_OBLIGATION
127
This billinfo is already associated with a Promise-to-Pay obligation. Another invocation cannot be initiated.
PIN_ERR_COLLECTIONS_PROMISE_TO_PAY_INVOKE_IN_PAST
128
A Promise-to-Pay cannot be invoked for a date in the past or on the same date as the system date.
PIN_ERR_COLLECTIONS_ADD_ACTION_IN_PROMISE_TO_PAY_PERIOD
129
This action cannot be inserted during the Promise-to-Pay period.
PIN_ERR_COLLECTIONS_NOT_UNDER_PROMISE_TO_PAY_OBLIGATION
130
The customer or the billinfo is not under Promise-to-Pay obligation.
PIN_ERR_COLLECTIONS_ADD_PROMISE_ACTION_OUTSIDE_PROMISE_TO_PAY_PERIOD
131
Cannot add promise action outside of a Promise-to-Pay period.
PIN_ERR_COLLECTIONS_UPDATE_PROMISE_ACTION_ERROR
132
Cannot update Promise-to-Pay information.
PIN_ERR_COLLECTIONS_MILESTONE_AMOUNT_NOT_FOUND
133
Both milestone amount and number of milestones are not found. Either one of them should be specified
PIN_ERR_COLLECTIONS_INVALID_MILESTONE_AMOUNT
134
Milestone amount should be less than or equal to overdue amount.
PIN_ERR_COLLECTIONS_MILESTONE_INTERVAL_NOT_FOUND
135
Both milestone interval and total number of days are not found. Either one of them should be specified.
PIN_ERR_COLLECTIONS_PARAMETER_IS_ZERO
136
Milestone interval should be greater than zero.
PIN_ERR_COLLECTIONS_INVALID_PROMISE_AMOUNT
137
Promise amount should be greater than exit amount.
PIN_ERR_COLLECTIONS_MEMBER_BILLINFO_CANNNOT_BE_EXEMPTED
138
Cannot exempt: Billinfo is a member of /group/collections_targets.
PIN_ERR_COLLECTIONS_BILLINFO_HAS_CYCLE_RELATION
139
The billinfo has cycle relation.
PIN_ERR_COLLECTIONS_GROUP_NAME_ALREADY_EXISTS
140
The name is either already in use or is empty. Please provide a unique name.
PIN_ERR_COLLECTIONS_BILLINFO_IS_SUBORD
141
Billinfo is a subordinate.
PIN_ERR_COLLECTIONS_BILLINFO_IS_ALREADY_EXEMPTED
142
Billinfo is already exempted from collections.
PIN_ERR_COLLECTIONS_BILLINFO_IS_ALREADY_MEMBER
143
Billinfo is already a member of collections group.
PIN_ERR_COLLECTIONS_BILLINFO_IS_ALREADY_PARENT
144
Billinfo is already parent of collections group.
PIN_ERR_COLLECTIONS_BILLINFO_IS_IN_COLLECTIONS
145
Member's billinfo is already present in collections.
PIN_ERR_CUST_SEPA_CURRENCY_NOT_EURO
146
Customer SEPA currency is not in Euro.
PIN_ERR_CUST_INVALID_IBAN_LENGTH
147
Length of IBAN is not according to ISO 13616:2007 standard.
PIN_ERR_CUST_INVALID_IBAN_FORMAT
148
PIN_ERR_CUST_NON_MOD97_IBAN
149
IBAN is not mod97 compliant.
PIN_ERR_CUST_INVALID_BIC_LENGTH
150
The length of the BIC is not in accordance with standards. It should be either 8 or 11 characters.
PIN_ERR_CUST_INVALID_BIC_FORMAT
151
Invalid format of customer's Business Identifier Code (BIC).
PIN_ERR_CUST_UMR_ALREADY_EXISTS
152
Customer unique mandate reference (UMR) number already exists.
PIN_ERR_CUST_INVALID_MANDATE_SIGNED_T
153
Invalid mandate signed date.
PIN_ERR_CUST_INVALID_CREDITOR_INFO
154
Invalid creditor information of customer.
PIN_ERR_CUST_NON_EXISTANT_CREDITOR_ID
155
Non-existent creditor ID of customer.
PIN_ERR_CUST_NON_EXISTANT_CREDITOR_INFO
156
Non-existent creditor info of customer.
PIN_ERR_CUST_PENDING_SEPA_REQUEST
157
The Payinfo has a /sepa object in a pending status; hence, deletion is not possible.
PIN_ERR_XAER_PROTO
158
An XA transaction protocol error has occurred; a routine was started in an improper context.
PIN_ERR_XAER_OUTSIDE
159
The resource manager (JCA Resource Adapter) is doing work outside the XA transaction.
PIN_ERR_XAER_NOTA
160
The global transaction ID (XID) for the XA transaction is invalid.
PIN_ERR_XAER_INVAL
161
An invalid argument was passed during the XA transaction.
PIN_ERR_XAER_DUPID
162
The global transaction ID (XID) for the XA transaction already exists.
PIN_ERR_XAER_ASYNC
163
An asynchronous operation is outstanding.
PIN_ERR_XA_RDONLY
164
The XA transaction branch was read-only and has been committed.
PIN_ERR_XA_RETRY
165
The routine returned without having any effect. It can be reissued.
PIN_ERR_XA_HEURHAZ
166
The XA transaction branch might have been manually committed to the BRM database. Some parts of the transaction are known to have been manually committed or rolled back, but the outcome of the entire transaction is unknown.
PIN_ERR_XA_HEURCOM
167
The XA transaction branch has been manually committed to the BRM database.
BRM returns this error code to JCA Resource Adapter during the recovery process of a failed two-phase commit transaction.
PIN_ERR_XA_HEURRB
168
The XA transaction branch has been manually rolled back.
PIN_ERR_XA_HEURMIX
169
Part of the XA transaction branch has been manually committed to the BRM database, and part has been manually rolled back.
PIN_ERR_XA_RBCOMMFAIL
170
The XA transaction was rolled back because of a communications failure.
PIN_ERR_XA_RBDEADLOCK
171
The XA transaction was rolled back because a deadlock was detected.
PIN_ERR_XA_RBINTEGRITY
172
The XA transaction was rolled back because a condition that violates the integrity of the resource was detected.
PIN_ERR_XA_RBOTHER
173
The XA transaction was rolled back for a reason not specified by an error code in this table.
PIN_ERR_XA_RBPROTO
174
The XA transaction was rolled back because of a protocol error in the resource manager.
PIN_ERR_XA_RBROLLBACK
175
The XA transaction was rolled back for an unspecified reason.
PIN_ERR_XA_RBTIMEOUT
176
The XA transaction was rolled back because it timed out.
PIN_ERR_XA_RBTRANSIENT
177
The XA transaction was rolled back because of a brief malfunction. The transaction branch can be retried.
PIN_ERR_XAER_RMFAIL
178
The extended architecture (XA) transaction resource manager (JCA Resource Adapter) is unavailable.
PIN_ERR_XAER_RMERR
179
An XA transaction resource manager (JCA Resource Adapter) error occurred in the transaction branch.
PIN_ERR_PURCHASE_FUTURE_DEAL
180
Future dated purchase deal has wrong purchase cycle and usage start dates.
PIN_ERR_PURCHASE_EXPIRED_DEAL
181
Cannot purchase the expired deal.
PIN_ERR_PERMISSION_DENIED
182
The attempted operation is not allowed; data is not viewable.
PIN_ERR_PDO_INTERNAL
183
An internal error occurred in the BRM data objects.
PIN_ERR_IPT_DNIS
184
The Dialed Number Identification Service (DNIS) is not authorized.
PIN_ERR_DB_MISMATCH
185
The database numbers do not match.
PIN_ERR_NO_CREDIT_BALANCE
186
No credit balance is available.
PIN_ERR_NOTHING_TO_BILL
187
There are no new items to bill.
PIN_ERR_MASTER_DOWN
188
The main BRM system is down.
PIN_ERR_OPCODE_HNDLR_INIT_FAIL
189
The opcode handler initialization at JS failed.
PIN_ERR_INVALID_OBJECT
190
The POID is invalid.
This error occurs when an object is accessed whose database_number field of the POID is NULL.
PIN_ERR_VALIDATE_ADJUSTMENT
191
The validate adjustment policy opcode fails.
PIN_ERR_SYSTEM_ERROR
192
A generic system error occurred while the application was running.
PIN_ERR_BILLING_ERROR
193
An error occurred during the billing run.
PIN_ERR_AUDIT_COMMIT_FAILED
194
Commit for the audit tables failed.
PIN_ERR_NOT_SUPPORTED
195
The operation is not supported.
PIN_ERR_INVALID_SER_FORMAT
196
The serialized format received from the database is incorrect.
PIN_ERR_READ_ONLY_TXN
197
Cannot insert or update in a read-only transaction.
PIN_ERR_VALIDATION_FAILED
198
Deals or plans validation failed.
PIN_ERR_PROC_BIND
199
The binding for the Procedure arguments failed.
PIN_ERR_PROC_EXEC
200
The procedure returned an application-specific error.
PIN_ERR_STORAGE_FAILOVER
201
An Oracle RAC failover message.
PIN_ERR_RETRYABLE
202
A failover error occurred and is retryable if needed.
PIN_ERR_TIMEOUT
203
Request timeout.
PIN_ERR_CONNECTION_LOST
204
The connection has been lost.
PIN_ERR_FEATURE_DISABLED
205
The feature is disabled.
PIN_ERR_CONV_NOT_ALLOWED_IN_DELAY_PERIOD
206
Conversion not allowed in delay period.
PIN_ERR_AR_CREATE_ITEM_DISUTE_WITH_ZERO_DUE
207
Item dispute accounts receivable action created with zero amount due.
PIN_ERR_AR_TAX_INFORMATION_NOT_FOUND
208
Tax information not found.
PIN_ERR_AR_ACCOUNT_WRITEOFF_FAILED
209
Account write-off failed.
PIN_ERR_PYMT_NOT_RECORDED_FOR_CORRECT_ACCT
210
Payment not recorded for correct account.
PIN_ERR_COLLECTIONS_INVALID_CONFIG_COLLECTIONS_PROMISE_TO_PAY_SPEC
211
Invalid configuration in collections Promise-to-Pay specification.
PIN_ERR_COLLECTIONS_INVALID_MILESTONE_PERCENTAGE
212
Milestone percentage is less than Promise-to-Pay specification percentage.
PIN_ERR_COLLECTIONS_INVALID_TOTAL_MILESTONE_AMOUNT
213
PIN_ERR_COLLECTIONS_INVALID_TOTAL_MILESTONE_PERCENTAGE
214
Invalid total milestone percentage.
PIN_ERR_COLLECTIONS_MILESTONE_INTERVAL_EXCEEDED
215
Milestone interval exceeded.
PIN_ERR_COLLECTIONS_NUM_OF_MILESTONE_EXCEEDED
216
Number of milestone exceeded.
PIN_ERR_INSTL_PERCENTAGE_NOT_VALID
217
Installment percentage not valid.
PIN_ERR_INSTL_CRITERIA_NOT_VALID
218
Installment criteria not valid.
PIN_ERR_INSTL_OPERATOR_NOT_VALID
219
Operator not valid.
PIN_ERR_INSTL_BAD_INPUT
220
Invalid input field.
PIN_ERR_INSTL_INVALID_STATE_TRANSITION
221
Invalid state transition in installment.
PIN_ERR_INSTL_UPDATE_STATUS_FAILED
222
Installment status update failed.
PIN_ERR_INSTL_BUFFER_NOT_FOUND
223
Installment buffer not found.
PIN_ERR_INSTL_NON_ZERO_ITEM_DUE
224
Non zero item due in installment.
PIN_ERR_INSTL_UPDATE_FAILED
225
Installment update failed.
PIN_ERR_INSTL_OBJECT_BAD_RESULTS
226
Installment object not found.
PIN_ERR_INSTL_TOTAL_AMT_INVALID
227
Invalid installment total amount.
PIN_ERR_INSTL_NOT_FOUND
228
Installment not found.
PIN_ERR_INSTL_ERROR_MANDATORY_FIELD_MISSING
229
Mandatory field is missing in the input for installment opcodes.
PIN_ERR_INSTL_BAD_STATUS
230
Invalid status of installment.
PIN_ERR_INSTL_ALREADY_CREATED
231
Installment already created.
PIN_ERR_INSTL_INVALID_PERIOD
232
Invalid installment period.
PIN_ERR_NOTIF_SPEC_DUPLICATE
250
Notification specifcation already exists.
PIN_ERR_NOTIF_SPEC_CRITERIA_NOT_VALID
251
Notification specification criteria not valid.
PIN_ERR_NOTIF_SPEC_MANDATORY_FIELD_MISSING
252
Notification specification mandatory field missing.
PIN_ERR_NOTIF_OPERATOR_NOT_VALID
253
Notification operator not valid.
PIN_ERR_NOTIF_TYPE_NOT_VALID
254
Notification type not valid.
PIN_ERR_NOTIF_INVALID_DELIVERY_METHOD
255
Delivery method in input is invalid.
PIN_ERR_NOTIFICATION_SPEC_NOT_FOUND
256
Notification specification not found.
PIN_ERR_INSTL_NO_OPEN_ITEMS
257
No open items available to select for installment.
PIN_ERR_RETRY_SET_TRANS_ERROR
261
Rollback and retry the failed transaction according to the user's configuration.
PIN_ERR_SKIP_FLD_MISMATCH_ERROR
262
Indicates that the mismatch error between portal_op_flds.dat and the database will be ignored.
PIN_ERR_DEPOSIT_SPEC_PROFILE_DUPLICATE
331
Deposit specification profile already exists.
PIN_ERR_DEPOSIT_SPEC_PROFILE_NOT_FOUND
332
Deposit specification profile not found.
PIN_ERR_DEPOSIT_SPEC_NOT_FOUND
333
Deposit specification not found.
PIN_ERR_DEPOSIT_BAD_INPUT
334
Invalid input.
PIN_ERR_DEPOSIT_PURCHASED_DEPOSIT_NOT_FOUND
335
Purchased deposit not found.
PIN_ERR_DEPOSIT_REFUND_REQUEST_NOT_FOUND
336
Refund request not found.
PIN_ERR_DEPOSIT_INVALID_AMOUNT
337
Invalid amount.
PIN_ERR_DEPOSIT_INVALID_CHARGE_OFFER
338
Invalid charge offer.
PIN_ERR_DEPOSIT_BUFFER_NOT_FOUND
339
Buffer not found.
PIN_ERR_DEPOSIT_SPEC_STATUS_DRAFT
340
Incorrect draft flag in input flist.
PIN_ERR_DEPOSIT_INVALID_SERVICE
341
Invalid service.
PIN_ERR_DEPOSIT_INVALID_ACTION
342
Invalid action.
PIN_ERR_DATA_OVERFLOW
343
To indicate error when size limit exceeds during conversion.
