2 Setup Components
Setup components are the prerequisite data that you configure before creating product offerings. For example, before creating product offerings, you must configure the ratable usage metrics (RUMs) that define how to measure events.
You can create the following setup components in the Oracle Communications Pricing Design Center (PDC) UI:
                     Service-event maps. See "Creating Service-Event Maps".
                     RUMs. See "Creating a RUM Configuration".
                     Impact categories. See "Creating Impact Categories for Zones".
                     Balance elements. See "Creating Balance Elements".
                     (Optional) Zone models. See "Creating Zone Models".
                     Policy specifications. See "Configuring Policy Specifications".
                     Item type selectors. See "Configuring Item Type Selectors".
                     (Optional) Special day calendars. See "Creating Special Day Calendars".
                     (Optional) Custom analyzer rules. See "Creating Custom Analyzer Rules".
                     Tax codes. See "Creating Tax Codes".
                     Tax exemption codes. See "Creating Tax Exemption Codes".
You need to configure the optional setup components only if you plan to use the related feature or perform certain business functions. For example, you configure a zone model only if you use zoning to determine a price in your charge offer.
See the discussion about configuring setup components in PDC Creating Product Offerings for more information about other setup components that are required for creating product offerings in PDC and how to configure them by using the SyncPDC and ImportExportPricing utilities.
A service-event map defines which events can be used for a service and which ratable usage metrics (RUMs) can be used for each service-event combination. These maps determine which events are available when you define charge and discount offers.
To create service-event maps:
                        In the Setup section of the navigation pane, under Pricing Elements, click Service-Event Map. The Service-Event Map page appears.
                        In the Service-Event Map section, select Service-Event Map and then click the Add icon. The Add Service or Account dialog box appears.
                        From the Service list, select a service or select Account and click OK. The selected service or Account is added under Service-Event Map.
                        Select a service or select Account and then click the Add icon. The Add Events dialog box appears.
                        Select the events to map to the service or select Account and click OK. You must map at least one event to the service you added or to Account. The selected events appear under the selected service or Account.
                        Select an event and then click the Add icon. The Map RUMs dialog box appears.
                        In the RUM column, select the RUMs to map to the event. Optionally, you can click New RUM to create a RUM configuration. See "Creating a RUM Configuration". You must map at least one RUM to each event that is added.
                        For each selected RUM, in the Expression field, enter the expression that indicates the quantity of the event. Optionally, you can click the Edit icon next to the Expression field and use the RUM Expression Builder to build the RUM expression. Note: You must ensure that the RUM expression that you enter is valid for the rating system in which the RUM is used.
                        Click OK. The selected RUMs appear under the selected event.
                        Click Submit.
Service-Event Map Page
Use the Service-Event Map page to map events to services or to Account and map RUMs to events. These mappings are used to define charge and discount offers.
Expand the service node to display the events mapped to that service.
Expand the event node to display the RUMs mapped to that event.
Related Tasks
Map RUMs Dialog Box
Use the Map RUMs dialog box to map RUMs to an event and configure the RUM expression for measuring the event.
| Field | Description |
| RUM | Displays the available RUMs for the selected event. Select the RUMs to map to the event. |
| Expression | Enter the expression that indicates the quantity of the event. For example, to calculate the duration quantity, you might reference the start and end fields in the event with the expression End Time - Start Time. Optionally, you can click the Edit icon and use the RUM Expression Builder to build the expression. |
| New RUM | Click this button to create a RUM configuration. |
Related Tasks
RUM Expression Builder Dialog Box
Use the RUM Expression Builder dialog box to build the expression for measuring the event for the selected RUM.
| Mathematical Elements Toolbar | Click any of the mathematical elements to add them to the Expression field. |
| Field | Select a field to add it to the Expression field. |
| Expression | Displays the RUM expression that indicates the quantity of the event. Note: You must ensure that the RUM expression is a valid expression for the rating system in which the RUM is used. |
Related Tasks
New RUM Dialog Box
Use the New RUM dialog box to create a RUM configuration.
| Name | Enter a unique name for the RUM. |
| Code | Enter a unique reference code for the RUM. |
| Units | Select the units of measurement to use for measuring the event. For RUMs of type Conditional, this field is not applicable. |
| Rounding | (Optional) Select the rounding method to use for the event usage. |
| Type | Select one of the following RUM types:
 You can change the RUM type only when the RUM is not used in any other components. |
To create a RUM configuration, you must first map the services to the events, and then map the RUMs to the events. See "Creating Service-Event Maps".
To create a RUM configuration:
                        In the Service-Event Map section of the Service-Event Map page, select an event and then click the Add icon. The Map RUMs dialog box appears.
                        Click New RUM. The New RUM dialog box appears.
                        In the Name field, enter a unique name for the RUM.
                        In the Code field, enter a unique reference code for the RUM.
                        From the Units list, select the unit of measurement to use for measuring the event. This step does not apply for RUMs of type Conditional.
                        (Optional) From the Rounding list, select the rounding method to use for the event usage.
                        From the Type list, select the RUM type.
                        Click OK.
Related Topics
You use impact categories to determine a price in a charge offer. An impact category represents a combination of event, service, or account attributes.
To create impact categories for zones:
                        In the Setup section of the navigation pane, under Pricing Elements, click Impact Categories. The Impact Categories page appears.
                        In the Impact Categories for Zones section, click the Add icon in the table toolbar. An editable row is added.
                        In the Name column, enter a unique name for the impact category.
                        In the Description column, enter a description for the impact category.
                        (Optional) To use the impact category as a result in a Usage Scenario (USC) selector and an Access Point Name (APN) selector, select the Derived Only check box. See "About Impact Categories for Zones" for information about different uses of impact categories for zones.
                        Click Submit. The impact category is added to the table in the Impact Categories for Zones section.
Related Topics
Impact categories for zones are used as follows:
                           Base zone impact categories are used as results in zone models. You can also use them as results in USC and APN selectors.
                           Derived Zone impact categories are used as results in USC and APN selectors. They are considered derived because the rules in USC and APN selectors take base zone impact categories and remap them, resulting in new impact categories. For example, a USC selector rule might specify that if the base zone impact category is China and the usage type is Friends & Family, the selector returns the Friends & Family derived zone impact category.
Impact Categories Page Reference
Use the Impact Categories page to create impact categories for zones.
For a description of the fields, see:
Impact Categories for Zones Section
Use the Impact Categories for Zones section to create impact categories for zones.
Click the Add icon in the table toolbar to add an impact category.
| Column | Description |
| Name | Enter a unique name for the impact category |
| Description | Enter a description for the impact category. |
| Derived Only | (Optional) Select the check box to use this impact category only in the USC and APN selectors. |
Related Tasks
A balance element represents a currency or noncurrency asset of economic value, such as U.S. dollars or included minutes. When you configure pricing in a charge, you specify the balance elements that are debited or credited when the charge offer is used to rate an event. For example, a charge of one dollar per minute for a phone call affects the US Dollars balance element.
To create a balance element, see:
Creating Currency Balance Elements
To create currency balance elements:
                           In the Setup section of the navigation pane, under Pricing Elements, click Balance Elements. The Balance Elements page appears. See "Balance Elements Section" for details.
                           In the Balance Elements section, click the Add Currency Balance Element icon in the table toolbar: A new row is added to the balance elements table. See "Balance Elements Table" for details.
                           In the Name column, select a currency name. The default reference code, numeric code, and symbol for the currency are automatically displayed. The Temporary and Counter columns are not applicable.
                           To use the balance element in a fold charge, select the check box in the Can Be Folded column.
                           To trigger notifications to customers when the balance element is about to expire, select the check box in the Notify Before Expiration column.
                           To trigger notifications to customers a set amount of time after the balance element has expired, select the check box in the Notify After Expiration column.
                           In the Consumption Rule column, select a consumption rule.
                           Click Save. The currency balance element is saved in the balance elements table, and the default rounding rules for the currency balance element are saved in the rounding rules table. You cannot delete the default rounding rules.
                           To add rounding rules for specific events, see "Adding Rounding Rules for Specific Events".
Related Topics
Creating Noncurrency Balance Elements
To create noncurrency balance elements:
                           In the Balance Elements section, click the Add Noncurrency Balance Element icon in the table toolbar: A new row is added to the balance elements table. See "Balance Elements Table" for details.
                           In the Name column, enter a unique name.
                           In the Code column, enter a unique reference code.
                           If you want to change the default numeric code, enter a unique reference code in the Numeric Code column. You can change the numeric code only before publishing the balance element.
                           In the Symbol column, enter a symbol.
                           To use the balance element for tracking balances temporarily while applying discounts to events, select the check box in the Temporary column. If you select this check box, rounding rules are not applicable.
                           To use the balance element as a counter, select the check box in the Counter column.
                           To use the balance element in a fold charge, select the check box in the Can Be Folded column. This column is disabled if the check box in the Temporary column is selected.
                           To trigger notifications to customers after the balance element has expired, select the check box in the Notify After Expiration column.
                           Click Save. The noncurrency balance element is saved in the balance elements table. If you have not selected the check box in the Temporary column, the default rounding rules for the noncurrency balance element are saved in the rounding rules table. You cannot delete the default rounding rules.
Related Topics
The Rounding Rules section displays the rounding rules for the balance element selected in the balance elements table. (See "Rounding Rules Section" for details.) You cannot delete the default rounding rules, but you can add new rounding rules for specific events.
To add rounding rules for specific events:
                           In the Rounding Rules section, click the Add icon in the table toolbar. The Processing Stage and Event Selection dialog box appears. See "Processing Stage and Event Selection Dialog Box" for details.
                           From the Processing Stage list, select a processing stage for the rounding rule.
                           From the Event Category list, select an event category.
                           From the Event(s) list, select the events.
                           Click OK. For each selected event, a rounding rule is added to the rounding rules table.
                           (Optional) If the selected events have child events, in the Rounding Rules section, select the check box in the Apply To Child Events column to use the balance element for both parent and child events.
                           (Optional) In the Rounding Method column, select a rounding method to use for the selected balance element.
                           (Optional) In the Precision column, enter the precision for rounding the balance element.
                           (Optional) In the Tolerance Parameters columns, enter the minimum and maximum tolerance values and the tolerance percentage that determines how the rounding rule will be applied to the balance element.
                           Click Save. The rounding rules are saved.
Related Topics
Balance Elements Page Reference
Use the Balance Elements page to create, modify, or delete currency or noncurrency balance elements and to add or delete rounding rules.
Use the Balance Elements section to create, modify, or delete currency or noncurrency balance elements.
See "Balance Elements Table" for information about the balance elements table.
| Add Currency Balance Element  | Use to add a currency balance element. |
| Add Noncurrency Balance Element  | Use to add a noncurrency balance element. |
| Delete  | Use to delete a balance element. |
| Balance Element table | Use to configure balance elements. |
Related Topics
Use the balance elements table in the Balance Elements section to configure balance elements. Each row in the table represents a balance element.
Tip:
| Name | For a currency balance element, select a currency from the list. For a noncurrency balance element, enter a unique name. |
| Code | For a currency balance element, this column displays the default reference code: it is read-only. For a noncurrency balance element, enter a unique reference code for the balance element. |
| Numeric Code | Displays the numeric code for the currency or noncurrency balance element. You can change the default numeric code for a noncurrency balance element only. |
| Symbol | (Optional) For a currency balance element, this column displays the default currency symbol: it is read-only. For a noncurrency balance element, enter a symbol. You can enter any character string for this balance element. |
| Temporary | (Optional) For a noncurrency balance element, select the check box to use the balance element for tracking balances temporarily while applying discounts to events. See "About Using Temporary Balances in Discounts" in PDC Creating Product Offerings. If you select this check box, rounding rules are not applicable. If you do not select this check box, the default rounding rules for each processing stage are automatically added to the rounding rules table. |
| Counter | (Optional) For a noncurrency balance element, select the check box to use the balance element as a counter. |
| Can Be Folded | (Optional) Select this check box to use the balance element in a fold charge. |
| Notify Before Expiration | (Optional) Select this check box to send notifications to your customers when their balance (of this balance element) is about to expire. |
| Notify After Expiration | (Optional) Select this check box to send notifications to your customers several days, weeks, or months after their balance (of this balance element) has expired. |
| Consumption Rule | (Optional) Select a consumption rule for the balance element. |
Use the Rounding Rules section to add or delete rounding rules.
When you add a balance element, the default rounding rules for each processing stage are added to the rounding rules table. You cannot delete these rounding rules.
Select a balance element in the balance elements table and click Add or Delete icon in the rounding rules table toolbar to add or delete rounding rules.
| Processing Stage | Displays the processing stage to which the rounding rule applies. For default rounding rules, this column is read-only. |
| Event Name | Displays the event to which the rounding rule applies. For default rounding rules, this column displays an asterisk (*), which indicates that the rounding rules will be applied to all the events. |
| Apply To Child Events | (Optional) If the selected event has child events, select this check box to use the balance element for both parent and child events. For default rounding rules, this column is read-only. |
| Rounding Method | (Optional) Select one of the following rounding methods to use for the balance element:
| Precision | (Optional) Enter the precision for rounding the balance element. For example, if the precision is 2, 1.1201 rounds to 1.12. Note: The precision must be between 0 and 15. |
| Tolerance Min | (Optional) Enter the minimum error tolerance for rounding the currency balance element. |
| Tolerance Max | (Optional) Enter the maximum error tolerance for rounding the currency balance element. For example, for Swiss Francs, if the minimum error tolerance is 2 and the maximum error tolerance is 3:
 Note: The maximum tolerance value must be greater than the minimum tolerance value. |
| Tolerance % | (Optional) Enter the error tolerance percentage for rounding the currency balance element. For example, if the tolerance percentage for Swiss Francs is 98%:
 If you set both a tolerance percentage and a tolerance amount, the tolerance percentage overrides the tolerance amount. For example, if the tolerance percentage is 1% and the minimum error tolerance is 5. If the customer pays in euros for a 1000 CHF charge, and the euro amount converts to 992, the percentage tolerance is met, so the payment is accepted, even though the minimum error tolerance has not been met. Note: The tolerance percentage must be between 0 and 100. |
Related Tasks
Use the Processing Stage and Event Selection dialog box to select a processing stage and the events for adding the rounding rules.
| Processing Stage | Select the processing stage. |
| Event Category | Select an event category. This category determines which events are displayed in the Event(s) list. See "About Charge Categories" for descriptions of the categories. |
| Event(s) | Select the events for adding the rounding rules. Note: The Event(s) list displays only the events that are not associated with any processing stage. |
Related Tasks
Related Topics
You can configure the following types of zone models:
                        Standard Zone Model: Associates the origin and destination area codes of a call to an impact category. See "Creating Standard Zone Models".
                        Geographical Zone Model: Associates the distance between the origin and destination area codes of a call to an impact category. See "Creating Geographical Zone Models".
To create standard zone models:
                           In the Setup section of the navigation pane, under Pricing Elements, click Zone Models. The Zone Models page appears.
                           In the Zone Models section, click the Add icon in the table toolbar. An editable row is added.
                           In the Details section, enter a name and a description.
                           Under Type, select Standard.
                           Under the Zone Rules subtab, click the Add icon in the table toolbar. An editable row is added.
                           In the Service Type column, do one of the following: -
                                 Select the service type to which this zone rule applies.
                                 Select the asterisk (*), which applies this zone rule to all the services.
                           In the Origin column, enter the call origin area code to associate with this zone rule. Note: The area code must include the international code.
                           In the Destination column, enter the call destination area code to associate with this zone rule. Note: The area code must include the international code.
                           In the Results column, under Zone Impact Category, select a zone impact category to associate with the call origin and call destination area codes. The impact category name is also the name of the zone. Note: The Zone Impact Category list shows only the base zone impact categories. This list is empty if no zone impact category is available. You must create the base zone impact category to proceed further. See "Creating Impact Categories for Zones".
                           (Optional) In the Results column, under Alternate Zone Model, select an alternative zone model that can be used to determine the price of a call. Note: The alternative zone model that you select must have at least one zone rule with the service type that matches with the service type selected for this zone model.
                           In the Validity column, enter the period for which this zone rule is valid. See "Setting Validity Periods" for information about setting the validity period.
                           (Optional) Add more zone rules to the standard zone model.
                           Click Submit. A standard zone model is added to the table in the Zone Models section.
To create geographical zone models:
                           Under Type, select Geographical.
                           In the Distance column, enter the distance between call origin and call destination.
                           In the Results column, under Zone Impact Category, select an impact category that is assigned to the specified distance. The impact category name is also the name of the zone. Note: The Zone Impact Category list shows only the base zone impact categories. This list is empty if no zone impact category is available. You must create the base zone impact category to proceed further. See "Creating Impact Categories for Zones".
                           (Optional) Add more zone rules to the geographical zone model.
                           Click the Area Codes subtab.
                           Click the Add icon in the table toolbar. An editable row is added.
                           In the Prefix Area Code column, enter the area code prefix.
                           In the Latitude column, enter the latitude for the specified area code.
                           In the Longitude column, enter the longitude for the specified area code.
                           In the Validity column, enter the period for which this mapping is valid. See "Setting Validity Periods" for information about setting the validity period.
                           (Optional) Add more area code combinations for this geographical zone model.
                           Click Submit. A geographical zone model is added to the table in the Zone Models section.
Zone Models Page Reference
Use the Zone Models page to add and create zone models.
Zone Models Section
Use the Zone Models section to add zone models.
Click the Add icon in the table toolbar to add a zone model.
| Name, Description | Displays the name and the description of the zone model added in the Details section. |
| Type | Displays the type of the zone model added in the Details section. |
Details Section
Use the Details section to provide general information for the zone model.
The Details section also contains the Zone Rules subtab and, for geographical zone models, the Area Codes subtab.
| Name, Description | Enter a unique name and a unique description for the zone model |
| Type | Select the zone model type:
Zone Rules Subtab for Standard Zone Model
Use the Zone Rules subtab to add rules that associate origin and destination area codes to impact categories.
| Service Type | Select the service type to which this zone rule applies. Select the asterisk (*) to apply this zone rule to all the services. |
| Origin | Enter the call origin area code to associate with this zone rule. Include the international code. |
| Destination | Enter the call destination area code to associate with this zone rule. Include the international code. |
| Results | Select the base zone impact category to associate with the call origin and call destination area codes. The impact category name is also the name of the zone. (Optional) Select the alternative zone model that can be used to determine the price of a call. You specify an alternative zone model when you create zone hierarchies. |
| Validity | Specify the period for which this zone rule is valid. Enter the start and end dates for this zone rule. |
Related Tasks
Zone Rules Subtab for Geographical Zone Model
Use the Zone Rules subtab to add rules that associate distances between origin and destination area codes to impact categories.
| Distance | Enter the distance between call origin and call destination. |
| Results | Select the base zone impact category, which is also the name of the zone, that is assigned to the specified distance. (Optional) Select the alternative zone model that can be used to determine the price of a call. You specify an alternative zone model when you create zone hierarchies. See PDC Creating Product Offerings for more information on alternative zone models. |
Related Tasks
Area Codes Subtab
Use the Area Codes subtab to add a set of mappings that associate area codes to their respective latitude and longitude coordinates for geographical zone models.
| Prefix Area Code | Enter the area code prefix. You can create multiple geographical zones within a single area code by mapping different combinations of longitude and latitude coordinates to that area code. |
| Latitude | Enter the latitude for the specified area code. The range for valid latitude values is -90 through 90. |
| Longitude | Enter the longitude for the specified area code. The range for valid longitude values is -180 through 180. |
| Validity | Specify the period for which this mapping is valid. Enter the start and end dates for this mapping. |
Related Tasks
Related Topics
A policy specification is made up of one or more counter policies each of which defines a gradation in the QoS based on the subscriber's service usage. For example, you can have a policy specification called Platinum for a data service and a balance element for it as Megabytes Used. You can define a counter policy labeled Fair Usage, which has three levels, Low QoS, Medium QoS, and High QoS, with each level containing a usage range valid for that quality of service, such as 100-150, 150-200, and 200-No Maximum megabytes.
See the discussion about policy specifications in PDC User's Guide for more information.
To configure policy specifications by using the PDC user interface:
                        In the Setup section of the navigation pane, under Pricing Elements, click Policy Specifications. The Policy Specifications page appears.
                        Specifying general information for a policy specification. See "Specifying General Information for a Policy Specification" for more information.
                        Create policy labels. See "Creating Policy Labels" for more information.
                        Create counter policies. See "Creating Counter Policies" for more information.
Related Topics
To specify general information for a policy specification:
                           In the Policy Specifications section, click the Add icon in the table toolbar. A new row is added.
                           In the Name column, enter a unique name for the policy specification.
                           In the Description column, enter a description for the policy specification.
To create a policy label:
                           In the Counter Policies section, click the Add icon in the table toolbar. The Create Counter Policy dialog box appears.
                           From the Policy Label list, select Create…. The Create Policy Label dialog box appears.
                           In the Name field, enter a unique name for the policy label.
                           In the Sub-Labels section, click the Add icon in the table toolbar. A new row is added.
                           In the Label column, enter a unique name for the sublabel. You can add additional sub labels by repeating steps 4 and 5.
                           Click OK.
Related Topics
To create a counter policy:
                           In the Counter Policies section, click the Add icon in the table toolbar. The Create Counter Policies dialog box appears.
                           From the Policy Label list, select a policy label or create a new policy label. See "Creating Policy Labels" for more information.
                           From the Unit list, select the unit to be used for measurement.
                           From the Balance Element list, select a balance element to which the counter policy must be applied. Note: The Balance Element list displays only the noncurrency balance elements. You can add only one counter policy for a balance element in a policy specification.
                           Click OK.
                           Click Save.
Related Topics
Adding Counter Ranges
To vary QoS based on the level of usage, add counter ranges to a counter policy and use different policy labels for each range.
To add a counter range to a counter policy:
                           In the Counting Ranges section, click the Add icon in the table toolbar. The Add Counter Range dialog box appears.
                           In the Starting At field, enter the starting value for the range, or select No Minimum. PDC automatically generates an end value for the range based on the existing counter ranges. For example, if you specify 5, PDC creates the following range: -
                                 5 – No maximum
 If you then create another quantity range with a start value of 2.5, PDC creates the following ranges: -
                                 2.5 – 5
                                 5 – No maximum
                           Add counter ranges.
                           From the Label list, select the corresponding label for each counter range. Tip: You can select the same label for multiple counter ranges as appropriate.
                           Click OK. A table for the counter range is added.
Modifying Policy Specifications
To modify a policy specification:
                           In the Policy Specifications section, click the policy specification that you want to modify.
                           Edit the name and description as required.
                           Modify the counter policies as required. See "Modifying Counter Policies" for more information.
                           Click Save.
Modifying Policy Labels
To modify a policy label:
                           In the Counter Policies section, click the counter policy that you want to modify. The Edit Counter Policy dialog box appears.
                           From the Policy Label list, select the policy label that you want to modify. The Edit Policy Label dialog box appears.
                           Modify the policy label and sub labels as required. To edit a sublabel, click a label in the Sub-labels section. To delete a sublabel, select a label in the Sub-labels section and then click the Delete icon in the table toolbar.
                           Click OK.
Related Topics
To modify a counter policy:
                           In the Counter Policies section, click the counter policy that you want to modify. The Edit Counter Policies dialog box appears.
                           Modify the policy label, counter ranges, and the range labels as required. For modifying policy labels, see "Modifying Policy Labels". For modifying counter ranges, see "Modifying Counter Ranges".
                           Click OK.
Related Topics
To modify the counter range in a counter policy:
                           Go to the Counter Ranges section.
                           In the Counter Ranges table, click the link in the Counter Ranges column for which you want to change the range. The Edit Counter Range dialog box appears.
                           Modify the Start value. You can specify a minimum start value or select No Minimum. You cannot enter a value that includes the entire following counter range. Instead, to extend a range beyond the following range, first delete the following range. See "Deleting Counter Ranges" for more information. PDC adjusts the start and end values of the preceding and following counter ranges accordingly.
                           Click OK.
Deleting Policy Specifications
To delete a policy specification:
                           In the Policy Specifications section, click the policy specification that you want to delete.
                           Click the Delete icon in the table toolbar. A confirmation message appears.
                           Click OK. The policy specification and the associated counter policies are removed.
                           Click Save.
Deleting Counter Policies
To delete a counter policy:
                           In the Counter Policies section, select the counter policy that you want to delete.
                           Click OK. The counter policy is removed from the table.
                           Click Save.
To delete a counter range:
                           In the Counter Ranges table, select the range in the Counter Ranges column.
                           Click OK. The counter range and the corresponding policy label are removed from the table. If you deleted a middle range, PDC automatically adjusts the end value of the previous counter range.
Policy Specifications Page Reference
Use the Policy Specifications page to create, modify, or delete policy specifications, counter policies, and policy labels.
| Add  | Use to add a policy specification, policy label, and counter policy. |
| Delete  | Use to remove a policy specification, policy label, and counter policy. |
Tip:
Policy Specifications Section
Use the Policy Specifications section to add the policy specifications. Click the Add icon in the table toolbar to add a policy specification.
| Name, Description | Enter the name and the description of the policy specification that you have added. |
Related Topics
Create Policy Label Dialog Box
Use the Create Policy Label dialog box to create policy labels.
| Name | Enter a unique name for the policy label. |
| Sub Labels | In the sub labels section, click Add icon to enter a unique name for the sub label. |
Create Counter Policies Dialog Box
Use the Create Counter Policies dialog box to counter policies.
| Policy Label | Select a policy label from the drop down list. You can also create and edit a policy label. |
| Units | Select the units to be used for measurement. |
| Balance Element | Select a balance element to which the counter policy must be applied. |
| Add Counter Range | Add counter ranges to a counter policy and use different policy labels for each range. |
An item type selector contains rules and item specifications for assigning balance impacts to bill items. These rules and specifications enable you to assign different bill items for balance impacts within the same event or event type. For example, you can define separate bill items for international and national calls and apply a different tax to each bill item at billing time.
See the discussion about item type selectors in PDC User's Guide for more information.
To configure item type selectors by using the PDC user interface:
                        In the Setup section of the navigation pane, under Pricing Elements, click Item Type Selectors. The Item Type Selectors page appears.
                        Specifying general information for an item type selector. See "Specifying General Information for an Item Type Selector".
                        Select the attributes that you want to use in the rules for the item type selector. See "Selecting Rule Attributes".
                        Create the rules for the item type selector. See "Creating Item Type Selector Rules".
Related Topics
You can add only one item type selector for a combination of service, event, and item group.
To specify general information for an item type selector:
                           In the Item Type Selector section, click the Add icon in the table toolbar. A new row is added.
                           In the Name column, enter a unique name for the item type selector.
                           In the Description column, enter a description for the item type selector.
                           In the Applicable To column, select the service name or account.
                           To apply the item type selector to all the child services of the selected service or account, select the check box in the Select Applicable to all Child Services column.
                           In the Event column, select the name of an event.
                           To apply the item type selector to all the child events of the selected event, select the check box in the Select Applicable to all Child Events column.
                           In the Item Group column, enter the name of the item group to be used for aggregating the balance impacts.
                           To apply the item type selector to all the balance impacts, select the check box in the Applicable to all Balance Impacts column.
                           In the Default Item Spec column, select a default item specification from the list or create a default item specification. To create the default item specification, see "Creating Item Specifications".
                           Click Save.
To select the rule attributes:
                           In the Rules section, click Manage Rule Attributes. The Manage Rule Attributes dialog box appears.
                           Choose the attribute for assigning balance impacts and click the check box in the Use column.
                           Select an operator to be used in the rule for the selected attributes from the Operator list.
                           Click OK. The selected attributes are displayed in the Rules section.
To create rules for an item type selector:
                           In the Item Type Selectors section, select an item type selector.
                           Click the Add icon in the table toolbar of the Rules section. A new row is added. By default, in the Priority column, the priority of the rules is displayed in the order of creation.
                           In the Rule Name column, enter a name for the rule.
                           In the attribute columns, enter values for each of the rule attributes that you selected in the Manage Rule Attributes dialog box.
                           In the Item Spec column, select an item specification from the list or create an item specification. To create an item specification, see "Creating Item Specifications".
                           Click Save.
Related Topics
Changing Priority of the Rules
To change the priority of the rules, in the Rules section select a rule and then click the up and down arrow keys in the table toolbar.
                              In the Rules section, you cannot sort the columns in the ascending or descending order because the columns are dynamically generated. You can only change the priority of the rules.
                              After creating the rules, changing the event or service in the item type selector removes all the rules configured for that event or service.
Related Topics
To create an item specification:
                           In the item specifications column, navigate till the end of the list of values and then click Manage Item Spec. The Item Specifications dialog box appears.
                           Click the Add icon in the table toolbar. A new row is added.
                           In the Name column, enter a unique name for the item specification.
                           In the Category column, enter a charge category for the item specification.
                           In the Type column, enter an item type for assigning balance impacts. Note: -
                                    Item type should always start with /item/.
                                    You can add only one item specification for a combination of category, item type, and aggregation type.
                           In the Aggregation Type column, select an aggregation type to track the balance impacts.
                           Click OK.
Related Topics
Modifying Item Type Selectors
To modify an item type selector:
                           In the Item Type Selectors section, click the item type selector that you want to modify.
                           Do the following as appropriate: -
                                 To modify an item specification, in the item specifications column navigate till the end of the list of values, and then click Manage Item Spec. In the Item Specifications dialog box, click the item specification that you want to modify.
                                 To modify a rule, in the Rules section click the rule that you want to modify.
                           Make the necessary changes as required.
                           Click Save.
Related Topics
Deleting Item Type Selectors
To delete an item type selector:
                           In the Item Type Selectors section, click the item type selector that you want to delete.
                                 To delete an item specification, in the item specifications column navigate till the end of the list of values, and then click Manage Item Spec. In the Item Specifications dialog box, click the item specification that you want to delete. Note: You cannot delete an item specification that is in use.
                                 To delete a rule, in the Rules section, click the rule that you want to delete.
                           Click OK. The selected item is removed.
                           Click Save.
Item Type Selectors Page Reference
Use the Item Type Selectors page to create, modify, or delete item type selectors, item specifications, and their rules.
| Add  | Use to add an item type selector, item specification, and a rule. |
| Delete  | Use to remove an item type selector, item specification, and a rule. |
Item Type Selectors Section
Use the Item Type Selectors section to add the item type selectors.
| Name, Description | Enter a unique name and a description for the item type selector. |
| Applicable To | Select the service name or account. |
| Applicable to all Child Services | (Optional) Select the check box to apply the item type selector to all the child services of the selected service or account. |
| Event | Select the name of an event. |
| Applicable to all Child Events | (Optional) Select the check box to apply the item type selector to all the child events of the selected event. |
| Item Group | Enter the name of the item group to be used for aggregating the balance impacts. |
| Applicable to all Balance Impacts | (Optional) Select the check box to apply the item type selector to all the balance impacts. |
| Default Item Spec | Select a default item specification. |
Item Specifications Dialog Box
Use the Item Specifications dialog box to create item specifications.
| Name | Enter a unique name for the item specification. |
| Category | Enter a charge category. This category determines the balance impacts to be tracked. See "About Charge Categories" for descriptions of the categories. |
| Type | Enter the type of the bill item for assigning balance impacts. This must match the item type created in BRM. Note: Item type should always start with /item/. You can add only one item specification for a combination of category, type, and aggregation type. |
| Aggregation Type | Select the aggregation type for tracking balance impacts:
Related Topics
Manage Rule Attributes Dialog Box
Use the Manage Rule Attributes dialog box to select the attributes that you want to use in the item type selector rules.
| Use | Select this check box against the attributes that you want to use in the rules. |
| Attribute Name | Displays the attributes that you can use in the rules. |
| Operator | Select an operator and enter a value. Displays the relationship between the rule's default field value and the value in the subscriber, event, service, or charging field. You can select one of the following operators:
Related Topics
Rules Section
Use the Rules section to add the item type selector rules.
| Priority | Displays the priority of the rules. By default, the priority of the rules is displayed in the order of creation. |
| Rule Name | Enter a name for the rule. |
| Field Name | Enter values for each of the rule attributes that you selected. The same fields are used for all the rules in the item type selector. You can set specific values in the rule to limit the fields that you want used in a rule. |
| Item Spec | Select or add an item specification. |
Use a special day calendar to define a set of dates, such as holidays, for which you want to configure special prices for your services. Each date can either be a specific date valid only in one year or a recurring date valid each year. These dates are used in a time model to define a time period. A time period can be used in a charge offer to determine a price.
To create special day calendars:
                        In the Setup section of the navigation pane, under Pricing Elements, click Special Day Calendars. The Special Day Calendars page appears.
                        In the Special Day Calendars section, click the Add icon in the table toolbar. An editable row is added.
                        In the Special Day Calendars column, enter a name.
                        In the Special Day Definitions for Selected Calendar section, click the Add icon in the table toolbar. An editable row is added.
                        In the Type column, select one of the following types of special days: -
                              Fixed to specify a specific date valid in only one year.
                              Recurring to specify a date that is valid every year.
                        In the Special Days column, enter the date.
                        In the Description column, enter a brief description for the special day.
                        Enter additional special day definitions for the calendar as needed.
                        Click Submit. The special day definitions for the selected calendar are added to the table.
Related Topics
Special Day Calendars Page Reference
Use the Special Day Calendars page to create, edit, or delete a set of dates, such as holidays, for which you want to configure special prices for your services. These dates are used in a time model to define a time period. A time period can be used in a charge offer to determine a price.
Special Day Calendars Section
Use the Special Day Calendars section to define names for the calendars.
Click the Add icon in the table toolbar to add a special day calendar.
| Special Day Calendars | Enter a name for the special day calendar. |
Related Tasks
Special Day Definitions for Selected Calendar Section
Use the Special Day Definitions for Selected Calendar section to specify the dates to include in the calendar.
Click the Add icon in the table toolbar to add special days to the calendar.
| Type | Select the special day type:
| Special Days | Click the date selector to select a date for the special day type in the following formats:
| Description | Enter a brief description. |
Related Tasks
A custom analyzer rule (custom rule) is a named expression that is used in selector rules to guide to a price. You can use these rules when configuring a charge based on a subscriber's Friends & Family, Special Day, or Closed User Group profile. For example, you can create custom rules for calls to friends and family on a subscriber's birthday, or to configure supplementary services, such as call forwarding and call blocking.
To create custom analyzer rules:
                        In the Setup section of the navigation pane, under Pricing Elements, click Custom Analyzer Rules. The Custom Analyzer Rules page appears.
                        In the Custom Analyzer Rules section, click the Add icon in the table toolbar. A new row is added.
                        In the Name column, enter the rule name.
                        (Optional) Enter the rule description.
                        In the Details section, select the following for which you want to create the rule: -
                              Profile Attribute Specification. Select the profile attribute specifications that you want to use for configuring the rule.
                              Service Specification. Select the service attributes that you want to use for configuring the rule.
                              Event Specification. Select the event attributes that you want to use for configuring the rule.
                        Under Condition, click the condition link. The Condition Builder dialog box appears.
                        In the Condition Builder dialog box, enter the conditions for the custom rule. For example, you can define the conditions for identifying if the originating and terminating subscribers belong to a common closed user group to apply special rates for the calls between the members of the closed user group.
                        Click OK.
                        Click Save.
Related Topic
Custom Analyzer Rules Page Reference
Use the Custom Analyzer Rules page to create custom rules.
See "Details Section" for configuring custom rules.
| Name, Description | Enter a unique name and a description for the custom rule. |
You can copy the existing rules. When you click the Duplicate icon, a copy of the selected rule is added below the selected rule.
The rule's fields contain the same values as the fields in the original rule.
Related Topic
Details Section
Use the Details section to configure custom rules.
| Rating Profile | Select the profile attribute specifications that you want to use for configuring the rule. Note: If you do not select any profile attribute specification value, Not Used is selected by default. |
| Service | Select the service attributes that you want to use for configuring the rule. Note: If you do not select any service specification value, Not Used is selected by default. |
| Event | Select the event attributes that you want to use for configuring the rule. Note: If you do not select any event specification value, Any is selected by default. |
| Condition | Click to enter the expression and then select conditions for the custom rule. See "Condition Builder Dialog Box" for more information. |
Related Topic
Use the Condition Builder dialog box to configure conditions by using condition elements.
| Condition Type/Left Hand Side Condition Type Create Right Hand Side of Condition Type | Select one of the following condition types for the condition type, left hand side condition type, and the right hand side condition type (as applicable):
| Originating | Select the originating values for configuring the closed user groups.
| Operator (for Dynamic Fields) | Displays the INTERSECT operator. |
| Terminating | Select the terminating values for configuring the closed user groups.
| Compare Field | Select a field that you want to compare. Note: The list of fields appears based on the configuration. |
| Operator (for Condition Type ) | Select an operator to compare the fields, fields and values, or the left hand side and right hand side conditions. |
| Compare to Field | Select a field that you want to compare with. Note: The list of fields appears based on the configuration. |
| Values | Enter the values for which you want to compare with the field. |
Creating Tax Codes
Tax codes are used to assign taxes to the products and services that you sell to your customers. For example, you use tax codes to apply taxes differently to usage charges versus charges for physical goods. A tax code indicates which tax to apply based on a charge offer. For example, a telephone handset uses a different tax code than an online service subscription. When a customer is charged, the tax code identifies the tax to apply.
Creating Tax Codes for a Flat Tax or Custom Implementation
You use Tax Codes page to implement simple flat taxes. You configure tax code and then assign it to one or more tax rates, which are differentiated by criteria such as validity date and jurisdiction.
To create a tax code for a flat tax or custom implementation:
                           In the Setup section of the navigation pane, under Pricing Elements, click Tax Codes. The Tax Codes page appears.
                           In the Tax Codes section, click the Add icon in the table toolbar. A new row is added.
                           In the Tax Name column, enter the tax name.
                           (Optional) Enter the tax description.
- In the GLID column, enter the general ledger ID to associate with the tax code.
                           In the Tax Code column, enter a unique tax code.
                           In the Type column, select the tax package type that you want to use. For flat taxes and custom implementations, select CUSTOM.
                           In the Details section, configure the following: - In the Description column, enter the tax rate description.
- In the Rate (%) column, enter the tax rate in percent.
- In the Jurisdiction column, select the Jurisdiction level for which this rate is applicable.
- In the Nexus column, click the link to configure nexus for the corresponding jurisdiction level.
- In the Tax Calculation Rule column, select the tax rule type that determines how taxes will be calculated. For more information about tax calculation rule, see "Details Section (For Flat Taxes and Custom Implementations)".
                                 Select Manage... from the drop-down list to configure the validity period. The Manage Validity Period dialog box appears. You can add, edit, and delete the validity period from the Manage Validity Period dialog box. By default, validity period is set to Immediately - Never Ends.
- Click Save.
Creating Tax Codes for Vertex
You specify to calculate taxes using Vertex by mapping tax codes to Vertex product codes. The Vertex product codes are used to apply the tax rate. The two types of Vertex tax codes are VERTEX_QUANTUM and VERTEX_COMMTAX_21.
                                    If you have selected tax package type as VERTEX_QUANTUM, configure Transaction Type, Transaction Subtype, and Sale Type.
                                    If you have selected tax package type as VERTEX_COMMTAX_21, configure Category Code, Service Code, and Sale Type.
- Click Save.
Tax Codes Page Reference
Use the Tax Code page to create, modify, and delete tax codes.
Tax Codes Section
Use the Tax Codes section to add tax codes.
| Tax Name, Description | Name and a brief description of the tax code. |
| GLID | The general ledger ID associated to the tax code. |
| Tax Code | A unique alphanumeric value that defines categories with different tax treatments. |
| Type | The tax package type. Values are:
Use the Details section to configure tax rates for flat taxes and custom implementations.
| Description | Description of tax rate. |
| Rate (%) | The tax rate in percent. For example, 4.25 means 4.25%. For prepaid purchase events that grant negative currency balances, the corresponding tax associated with it should also be negative. For example, -4.25. |
| Jurisdiction | Jurisdiction level for which this rate is applicable. Values are FEDERAL, STATE, COUNTY, CITY, LOCATION. |
| Nexus | The jurisdiction where the rate applies. If the Jurisdiction field value is STATE, the Nexus values must be state-level jurisdictions. |
| Tax Calculation Rule | Determines how taxes will be computed. Values are:
Details Section (For Vertex)
Use the Details section to map tax codes for Vertex.
| Category Code | (Applicable for VERTEX_QUANTUM tax package type.) Refer to the Communications Tax Q Series documentation for more information about its category codes. |
| Service Code | (Applicable for VERTEX_QUANTUM tax package type.) Refer to the Communications Tax Q Series documentation for more information on service codes. |
| Transaction Type | (Applicable for VERTEX_COMMTAX_21 tax package type.) Refer to the Sales Tax Q Series documentation for more information on transaction types. |
| Transaction Subtype | (Applicable for VERTEX_COMMTAX_21 tax package type.) Refer to the Sales Tax Q Series documentation for more information on transaction subtypes. |
| Sale Type | Indicates if the charge offer is for sale (SALE) or resale (RESALE). The default value is SALE. |
Manage Validity Period Dialog Box
Use the Manage Validity Period dialog box to add, modify, and delete the validity period for the tax rate. You can use multiple validity periods to create different rates for a single tax code, but the validity periods must not overlap.
Click the Add icon in the table toolbar to add a new validity period.
| Start | Start date for the tax rate validity period. By default, start date is set to Immediately. To set a specific start date, deselect Immediately, then enter a date or use the date selector to select a date. |
| End | End date for the tax rate validity period. By default, end date is set to Never Ends. To set a specific end date, deselect Never Ends, then enter a date or use the date selector to select a date. |
You use tax exemption codes to remove tax liability (either entirely or partially) from a charge. For example, you could create a tax exemption code to exempt a customer account from all tax liability.
To create a tax exemption code:
                        In the Setup section of the navigation pane, under Pricing Elements, click Tax Exemption Codes. The Tax Exemption Codes page appears.
                        In the Tax Exemption Codes section, click the Add icon in the table toolbar. A new row is added.
                        In the Name column, enter the tax exemption name.
                        (Optional) Enter the tax exemption description.
                        In the Tax Exemption Code column, enter a unique tax exemption code.
                        In the Jurisdictions column, select one or more jurisdiction levels for which this rate is applicable.
                        In the Jurisdictions and Rates section, do the following for each jurisdiction: -
                              In the Rate (%) column, enter a rate between 0 and 1 that represents a percentage. For example, enter 0.25 for a 25% exemption.
                              In the Validity column, select the Immediately - Never Ends link and then enter the new start and end dates for the validity period.
                        Click Save.
Related Topics
Tax Exemption Codes Page Reference
Use the Tax Exemption Code page to create, modify, and delete tax exemption codes.
Tax Exemption Codes Section
Use the Tax Exemption Codes section to define your tax exemption codes.
Click the Add icon in the table toolbar to add a tax exemption code.
| Name | Enter a unique name for the tax exemption code. |
| Description | (Optional) Enter a brief description for the tax exemption code. |
| Tax Exemption Code | Enter a unique alphanumeric value that defines categories with different tax exemptions. |
| Jurisdictions | Enter the jurisdiction level for which this exemption is applicable: All, City, County, District, Federal, Location, State, and Territory. |
Jurisdictions and Rates Section
Use the Jurisdictions and Rates section to configure the exemption rate for each jurisdiction level.
| Jurisdiction | Displays the jurisdiction levels you selected. |
| Rate (%) | Enter the tax exemption rate. Enter a value between 0 and 1. For example, enter .15 for 15%. |
| Validity | Displays the validity period for the tax exemption code. By default, it displays Immediately – Never Ends. To modify the validity period, click the link for the validity period. See "Manage Validity Period Dialog Box". |
Use the Manage Validity Period dialog box to set the validity period for the jurisdiction's tax exemption rate.
| Start | Displays the start date for the validity period. By default, the start date is set to Immediately. To set a specific start date, deselect Immediately and then enter or select a date. |
| End | Displays the end date for the validity period. By default, the end date is set to Never Ends. To set a specific end date, deselect Never End and then enter or select a date. |
Configuring Price Tags
Price tags let you apply special prices to charge offers or discounts according to your specified rules. You configure price tag setup components to specify the balance elements, resources, and services a price tag applies to and set the list of possible values.
To configure price tags:
- In the Setup section of the navigation pane, under Pricing
                    Elements, click Price Tags.
                        The Price Tags page appears.
- Create, modify, or delete price tag setup components and the price tags within them. See:
Related Topics
Creating Price Tags
To create price tags:
- In Price Tags table, click the Add icon.
                           A new row appears.
- In the Price Tag Name column, enter a unique name for the price tag setup component.
- Optionally, in the Description column, enter a description.
- In the new row in the Price Tag details table, configure tags. See "Price Tag Details Table."
- Click Save.
You can add more rows in the Price Tags table to create more setup components with their own sets of price tags. For each row in the Price Tags table, you can add more rows in the Price Tag details table to define more price tags within the same setup component.
Within the same setup component, you cannot create duplicate price tags. This means:
- You cannot create multiple Price Tag details rows that specify all of the same values for Resource Id, Resource Unit Type, and Permitted. For example, Tag1 and Tag 2 could not both specify Resource Id: 840, Resource Unit Type: BYTE and Permitted: IP.
- You cannot create multiple Price Tag details rows that specify a subset of the same values for Resource Id, Resource Unit Type, and Permitted. For example, because using Resource Id: 0 means the tag applies to any balance element, if one row specifies Resource Id: 0, Resource Unit Type: BYTE and Permitted: IP, another row could not specify Resource Id: 840, Resource Unit Type: BYTE and Permitted: IP.
If needed, you can create duplicate tags in separate setup components. For example, you could create:
- A row in the Price Tags table for TagGroup1 that includes a row in the Price Tag details table specifying Resource Id: 0, Resource Unit Type: BYTE and Permitted: IP
- A second row in the Price Tags table for TagGroup2 that includes a row in the Price Tag details table specifying the same values for Resource ID, Resource Unit Type, and Permitted.
Modifying Price Tags
To modify price tags:
- In the Price Tags table, click the price tag you want to modify.
- Modify fields as required:
                           - For price tags that are not referenced by other pricing components, you can modify all fields.
- For price tags that are referenced by other pricing components,
                        you can modify the following fields:
                                 - Description
- Rule Type
- Values
 Note: Be sure that you understand the impact that modifying the rules and values will have on the pricing components that reference the price tag.
- Click Save.
Related Topics
Deleting Price Tags
You can delete a price tag only if it is not referenced by any other pricing components.
To delete a price tag:
- In the Price Tags table, click the row for the price tag you want to delete.
- Do one of the following:
                           - To delete the entire setup component, click the Delete icon in the Price Tags table toolbar.
- To delete a tag within the setup component, in the Price Tag details table, click the row for the tag you want to delete, and then click the Delete icon in the Price Tag details table toolbar.
- Click OK.
                           The selected tag or setup component is removed.
- Click Save.
Price Tags Page Reference
Use the Price Tags page to create, modify, and delete price tags.
Price Tags Table
Use the Price Tags table to configure price tag setup components. Each row in the table represents a price tag setup component, which can contain multiple price tags.
Use the Add and Delete icons in the table toolbar to add or delete a price tag setup component.
See "Price Tag Details Table" for more information about the price tags details table.
| Price Tag Name | Displays the name of the price tag setup component. |
| Description | Displays the description of the price tag setup component. |
Related Topics
Use the Price Tag details table to configure price tags. Each row in the table represents a price tag with the price tag setup component selected in the Price Tags table.
| Resource Id | The balance element associated with the price tag. The default value of 0 lets you use the price tag with any balance element. |
| Resource Unit Type | The unit for the balance element. The default of ANY lets you use the price tag with any unit. |
| Permitted | The services to associate the price tag with. You can select
							multiple services and their children. The default of ANY lets you use the price tag with any service. See "Permitted Services Dialog Box" for more information. |
| Rule Type | The type of values that can be configured. The default of ANY lets you use any values at purchase time. |
| Values | The possible values that can be used. Values can be positive
							or negative integers or decimals.
Use the Permitted Services dialog box to select the services that a price tag can be used with.
| Permitted | Select a service name from the drop down list. The default of ANY lets you use the price tag with any service. |
| Child Services | (Optional) Select the check box to allow the price tag to be used with all child services of the selected service. |
