39 Diagnosing Some Common Problems with BRM
Learn about some common problems that you might find when troubleshooting Oracle Communications Billing and Revenue Management (BRM).
Topics in this document:
Problems Starting BRM Components
Problem: Bad Bind, Error 13
One of the log files (log or pinlog) for the DM or CM has a reference to “bad bind" and “errno 13".
Cause
The port number specified in the configuration file (dm_port or cm_ptr entry) is incorrect.
Another possibility is that the port number is below 1023, and the CM, CMMP, or DM was not started as root. System processes that use port numbers below 1023 must be started as root. If you use a port number greater than 1024, you do not have to start the process as root.
Solution
Edit the configuration file for the component to specify an unassigned port number above 1023, such as 1950.
Problem: Bad Bind, Error 125
The log file for the DM or CM has a reference to “bad bind" and “errno 125".
Cause
Duplicate port number. Some other process is already using the port.
Solution
Problem: Cannot Connect to Oracle Database
When you look at the processes running, you see the Oracle DM master and front ends running but no back end running.
Causes
  • The database name configuration entry (sm_database) for the DM points to the wrong database name. (The error message shows which database name the DM is trying to connect to.)
  • The Oracle password configuration entry (sm_pw) is missing.
  • The Oracle tnsnames file is missing or incorrect.
  • The oracle_sid or oracle_home environment variable is set incorrectly.
  • The Oracle DM is spawning too many back-end processes simultaneously for the IPC or BEQ protocol to handle.
Solutions
  • Enter the correct database name and Oracle user name and password for the BRM database in the configuration file for the Oracle DM and restart the DM.
  • Create a valid Oracle tnsnames file and check the environment variables.
  • If you are using the IPC or BEQ protocol, configure the Oracle DM to wait a specified amount of time before spawning or respawning a new back-end process. To do this, add the following entry to the Oracle DM configuration file (BRM_home/sys/dm_oracle/pin.conf), where BRM_home is the directory in which BRM is installed:
    - dm dm_restart_delay DelayTime
    Adding a delay increases the Oracle DM startup time.
    where DelayTime is the amount of time, in microseconds, the Oracle DM should wait before spawning a new back-end process. Set DelayTime to the smallest possible time that fixes your connection problems. As a guideline, start with 1000000 microseconds (1 second) and then decrease the time until you find the optimal setting for your system.
Problem: Lost TCP Connections
Cause
BRM recognizes when an application closes a TCP connection. If the computer running the client application fails, however, the application might not close the TCP socket.
Solutions
In the pin.conf files for the CM and the Connection Manager Master Process (CMMP), the keepalive entry specifies whether to monitor the TCP connection. See "Enabling Java PCM Clients to Use Operating System TCP/IP Keepalive Parameters".
This entry should be set to avoid sockets not being closed properly due to network problems or hardware crashes.
The CM monitors the TCP connections by using the standard TCP keepalive feature. This lets you detect lost connections and clean up the CM and DM.
With the keepalive feature turned on, BRM uses the system's keepalive APIs to detect a lost connection and to try to reconnect, before closing the socket.
For more information on TCP keepalive options, see the TCP and keepalive documentation for your operating system.
Problem: Hung and or Looping Processes
A hung process does not respond in a normal fashion.
A looping process uses CPU cycles without doing any useful work.
Cause
If the CM does not respond to a login attempt, one of the processes in the system might be hung.
If the CPU time for a process is increasing and is out of proportion to the rest of the processes, this might be a looping process.
Solutions
Check the status of the CM. See "Monitoring Connection Manager Activity". The CM should show a new connection. If the CM report shows that the CM is “waiting on DM," the DM might be hung. You can check the database by verifying that it responds to manual SQL commands.
To check the CPU time used by a process, enter the following command twice, separated by a 10- to 30-second interval (or as much as several minutes on a lightly loaded system):
ps -ef | grep process
Stopping a Hung or Looping Process
Before you stop a hung or looping DM or CM process, check its status at least twice at 30-second intervals (or up to several minutes on a lightly loaded system). For more information, see "Monitoring Data Manager Activity" or "Monitoring Connection Manager Activity".
Enter the following command to stop a hung or looping process:
kill -ABRT process_id
BRM stops the process and writes a core image file of the process. If you contact Oracle Technical Support about this problem, send the core file along with the relevant log files. (See "Contacting Technical Support".)
Problem: ORA-01502: Index 'PINPAP.I_EVENT_ITEM_OBJ__ID' or Partition of Such Index Is in Unusable State
While loading the CDRs using the direct path load option, an error stating that the index is in an unusable state occurs.
Cause
While IREL processes the CDRs using the direct path loading option, it updates the indexes. However, as the index is being updated, another application, for example, pin_monitor_balance would also access the same index partition.
Solution
Configure the dm_sql_retry entry in the pin.conf file. This is specified as an integer value that indicates the number of times an SQL statement is to be retried if this error occurs.
This is not a mandatory parameter to be set in the pin.conf file. The default behavior is to not try running the SQL statement if the error occurs.
Problems Stopping BRM Components
Problem: No Permission to Stop the Component
You run the stop script, but the script fails. You find a reference to “permission denied" in the log file for the component.
Cause
You do not have permission to stop the BRM system.
Solution
Log in as root or as the user who started the BRM system.
Problem: No pid File
You run the stop script, but the script fails. You find a reference to “no pid file" in the log file for the component.
Cause
BRM cannot find the .pid file.
Solution
Identify the process ID for the component you want to stop, and then stop the process manually. See "Starting and Stopping the BRM System".
Problems Connecting to BRM
Problem: Cannot Connect to the Database
When you try to start a client application, you get an error message advising you of “problems connecting to the database."
Cause
The CM might not be set to handle the number of current client sessions.
Solution
Set the cm_max_connects entry in the configuration file for the CM to a number larger than the number of client sessions you anticipate. Then restart the CM.
Problem: AMM Takes Longer Time to Connect to the Database
When you try to enable the Account Migration Manager (AMM) jobs by running the pin_amt utility, the Authentication lapse error is logged in the pin_amt.log file.
Cause
When enabling the migration jobs, AMM takes much longer time than expected to connect to the Oracle database.
Solution
Do the following:
  1. Open the BRM_home/bin/pin_amt file in a text editor.
  2. Search for the following entries in the file:
    $JAVA -DPIN_HOME=$PIN_DIR
    -DJAVA_OPTS="-Xmx2048m -Xms256m" com.portal.amt.AmtUI $*
  3. Replace the entries with the following:
    $JAVA -Djava.security.egd=file:/dev/./urandom
    -Dsecurerandom.source=file:/dev/./urandom
    -DPIN_HOME=$PIN_DIR -DJAVA_OPTS="-Xmx2048m -Xms256m" com.portal.amt.AmtUI $*
  4. Save and close the file.
Problem: Cannot Connect to the CM
An application cannot connect to BRM, and the log file for the application (which might be default.pinlog in the current directory) shows the error “PIN_ERR_NAP_CONNECT_FAILED(27)."
Causes
  • The configuration file (pin.conf) for the application might be pointing to the wrong CM.
  • The CM is not running.
  • The CM is not set to handle this many connections.
  • No TCP sockets are available on the client or CM machine, perhaps because you used many sockets recently and the sockets have not been released from their two-minute wait period after the connections were closed.
Solutions
  • Open the configuration file for the application and check the entries that specify the CM.
  • Check for CM processes. See "Checking the Number and ID of a BRM Process".
  • Set the cm_max_connects entry in the configuration file for the CM to a number larger than the number of application sessions you anticipate. Then restart the CM.
  • Wait a few minutes to see if the sockets are freed up.
    On Linux: To see how many sockets are available:
    netstat -n -A inet -t | wc -l
    If the resulting number is close to 65535, there are too many socket connections for a single IP address on this machine.
Problem: CM Cannot Connect to a DM
You might find a message similar to the following:
DMfe #3: dropped connect from 111.122.123.1:45826, too full
W Thu Aug 06 13:58:05 2001 portalhost dm:17446 dm_front.c(1.47):1498
Cause
There are not enough connections allowed for the DM.
Solution
  • Use the dm_max_per_fe parameter in the DM configuration file to increase the number of CM connections allowed.
  • Install and configure an additional DM.
Problem: Rated Event Loader Cannot Connect to the CM
If SSL is enabled in BRM, sometimes Rated Event Loader fails to connect to the CM with the following error message:
An error occurred while attempting to connect to the Infranet CM.
Please validate the infranet.connection property value and ensure the CM is
running.
Cause
There might be a heavy load on Rated Event Loader.
Solution
Do the following:
  1. Create a copy of the BRM_home/wallet/client directory by running the following command:
    cp -r BRM_home/wallet/client BRM_home/wallet/client_ssl
  2. Open the BRM_home/apps/pin_rel/Infranet.properties file in a text editor.
  3. Modify the infranet.pcp.ssl.wallet.location entry to point to the absolute path of the directory that you created in step 1:
    infranet.pcp.ssl.wallet.location = BRM_home/wallet/client_ssl
Problems with Deadlocking
Problem: BRM “Stops Responding" or Oracle Deadlocks
Your BRM system stops responding, or Oracle reports deadlocking messages.
Cause
The DM might have too few back ends for the type of BRM activity.
Solution
Configure the DM with more back ends. For example, provide at least two DM back ends for each customer service representative. For more guidelines on setting the number of back ends, see "Improving Data Manager and Queue Manager Performance".
Problem: dm_oracle Cannot Connect to the Oracle Database
The Oracle DM (dm_oracle) waits indefinitely for a response from the Oracle database.
Cause
If there is a problem with the Oracle database, dm_oracle might stop responding when it attempts to connect to the database.
Solution
Set the database_request_timeout_duration parameter in the dm_oracle configuration file (BRM_home/sys/dm_oracle/pin.conf):
- dm database_request_timeout_duration milliseconds
where milliseconds is the number of milliseconds the DM waits for a response. For example:
- dm database_request_timeout_duration 10000
If the database does not respond during the wait period and you are using Oracle RAC, the DM times out and then makes one attempt to connect to another Oracle database instance.
If this pin.conf parameter is not specified or is set to 0, the connection attempt does not time out.
  • If you are using a single database or a multischema system without Oracle RAC, the DM attempts to connect to the same database schema again. In this case, the timeout setting is useful only if you are experiencing temporary network problems.
  • If you are using Oracle RAC, the tnsnames.ora file must be configured correctly for the reconnection to work.
Problems with Memory Management
Problem: Out of Memory
The DM will not start, and the error log file for the DM refers to “bad shmget" or “bad shmat" and “errno 12." Or, when the system is running, the CM or an application shows the error “PIN_ERR_NO_MEM" in its log file.
Causes
The DM or another queuing-based daemon did not have enough shared memory to complete the operation. This is caused by one or more of the following conditions:
  • Other processes are using all of the shared memory.
  • There are too many CM processes.
  • There are memory leaks in the CM or its FMs.
Solutions
To check for memory leaks, use ps with the vsz flag at two or more intervals to see changes in shared memory.
On Linux:
ps -eo pid,vsz,f,s,sz,pmem,comm | egrep 'cmldml [application]'
For a CM, vsz should grow only until an operation has passed through the CM and then stay constant. For example, if vsz is growing during billing, there is a memory leak.
To check for and clean up unused memory on Linux:
  1. Stop all DM processes. See "Starting and Stopping the BRM System".
  2. Confirm that there are no DM processes running. See "Checking the Number and ID of a BRM Process".
  3. Run df -k to check swap space usage. Confirm that the available space is very low.
  4. Run ipcs -ma to show the shared memory segments that have been allocated but not used recently.
  5. Run ipcs -mac to show the shared memory segments that have been allocated along with the corresponding user information.
  6. Run ipcs -mat to show the shared memory segments that have been allocated detach timing information.
    In steps 4, 5, and 6, a shared memory segment is probably abandoned when you see the following conditions:
    • Number of attaches (NATTCH) is 0
    • KEY is 0 (and not using a special dm_shmkey)
    • Creator process ID (CPID) is gone
    • Last detach time (DTIME) has a value
  7. Run ipcrm -m segment_id on each of the unused segments to free up the space.
  8. Run df -k again to confirm that the available swap space has been cleared.
  9. Stop and restart the DM processes.
To increase the system shared memory on Linux, open the /etc/sysctl.conf file and set the shminfo_shmmax configuration parameter to a value greater than the value of dm_shmsize in the DM configuration file (pin.conf). Stop and restart the computer.
Problem: Java Out of Memory Error
When using GUI applications such as Developer Center or batch applications such as Invoice formatter, you might sometimes receive “java.lang.OutOfMemoryError: Java heap space" error messages.
Cause
The Java application does not have enough memory to complete the operation.
Solution
Increase the maximum heap size used by the Java Virtual Machine (JVM). The exact amount varies greatly with your needs and system resources.
The heap size is controlled by the -Xmx size entry in the Java application startup script. By default, the -Xmx size entry is not present in the startup line. To increase the maximum heap size, add this entry and a number (in megabytes) to the application startup line. The following example adds a 1024 MB maximum heap size to the class:
java -Xmx1024m class
Increasing the heap size may degrade the performance of other processes if insufficient resources are available. You must adjust the heap size based on your application needs and within your system's limits.
Problem: Memory Problems with the Oracle DM
The error log file for the DM for your Oracle database refers to “No memory for...", such as “No memory for list in pini_flist_grow." You suspect memory problems, but your system has sufficient memory for the environment.
Cause
The DM is not configured to use sufficient shared memory.
Solution
  1. Open the DM configuration file (BRM_home/sys/dm_oracle/pin.conf).
  2. Increase the size of the dm_bigsize and dm_shmsize parameters. Follow the guidelines in the configuration file for editing these entries.
  3. Save the configuration file.
  4. Stop and restart the DM.
Problems Running Billing
Problem: Column Size Exceeded for EVENT_POID_LIST
When BRM has events, like payments or adjustments, that transfer items, you may receive an error indicating that the maximum size of the EVENT_POID_LIST column has been exceeded in the ITEM_T, BILLINFO_T, or AU_BILLINFO_T table. For example, you may see this error when running PCM_OP_PAYMENT_COLLECT.
Cause
The standard length of the EVENT_POID_LIST column in the ITEM_T, BILLINFO_T, and AU_BILLINFO_T tables is 4000 characters. Some pricing configurations create values that exceed this limit. The most likely table to generate this error is ITEM_T.
Solution
You can solve this problem by increasing the size of the column in the relevant table or tables.
You must run the following SQL commands before you run any of the table-specific commands below. You only need to run this set of commands once per schema. These commands must be run as a database user with sysdba privileges.
SHUTDOWN IMMEDIATE;
STARTUP UPGRADE;
ALTER SYSTEM SET max_string_size=extended;
@?/rdbms/admin/utl32k.sql
SHUTDOWN IMMEDIATE;
STARTUP;
In addition to the commands above, you must run the following commands once per schema. These commands should be run as the schema user, for example pin01:
update dd_objects_fields_t set length=32000 where FIELD_NAME='PIN_FLD_EVENT_POID_LIST';
commit;
update search_t set flags=0 where POID_ID0=701;
commit;
Run the following sets of commands depending on the table or tables that are causing the error. All of the commands below should be run as the schema user, for example pin01:
For errors from ITEM_T:
alter table item_t add epl_copy varchar2(32000);
update item_t set epl_copy = EVENT_POID_LIST;
update item_t set EVENT_POID_LIST = null;
commit;
alter table item_t modify EVENT_POID_LIST long;
alter table item_t modify EVENT_POID_LIST clob;
update item_t set EVENT_POID_LIST = epl_copy;
alter table item_t drop column epl_copy;
commit;
For errors from BILLINFO_T:
alter table billinfo_t add epl_copy varchar2(32000);
update billinfo_t set epl_copy = EVENT_POID_LIST;
update billinfo_t set EVENT_POID_LIST = null;
commit;
alter table billinfo_t modify EVENT_POID_LIST long;
alter table billinfo_t modify EVENT_POID_LIST clob;
update billinfo_t set EVENT_POID_LIST = epl_copy;
alter table billinfo_t drop column epl_copy;
commit;
For errors from AU_BILLINFO_T:
alter table au_billinfo_t add epl_copy varchar2(32000);
update au_billinfo_t set epl_copy = EVENT_POID_LIST;
update au_billinfo_t set EVENT_POID_LIST = null;
commit;
alter table au_billinfo_t modify EVENT_POID_LIST long;
alter table au_billinfo_t modify EVENT_POID_LIST clob;
update au_billinfo_t set EVENT_POID_LIST = epl_copy;
alter table au_billinfo_t drop column epl_copy;
commit;
Problem: Billing Daemons Are Running, but Nothing Happens
Even though the billing processes are running, BRM is not producing billing data.
Cause
There are too few back ends for the DM. Because billing daemons run in parallel, you must have at least one DM back end for each billing program thread, plus one back end for the main thread searches.
Solution
Edit the dm_n_be entry in the DM configuration file (pin.conf) to add more back ends to the DM, and then stop and restart the DM. See "Configuring DM Front Ends and Back Ends".
Problem: High CPU Usage for the Number of Accounts Processed
Running the billing scripts puts an inordinately heavy load on the computer, and processing the accounts takes a long time.
Cause
An index is missing or unbalanced; or in Oracle, an index is in the CHOOSE Optimizer mode and statistics are out of date.
Solution
Rebuild the BRM indexes before you run the billing scripts. See "Rebuilding Indexes" in BRM Installation Guide.
Problems Creating Accounts
Problem: fm_delivery_mail_sendmsgs Error Reported in the CM Log File
Cause
BRM is trying to send a welcome email message, but the Email DM (dm_email) is not running.
Solution
Start the Email DM, or disable the welcome email message.
Problem: Opcode Timeout Error When Creating an Account Using Web Services Manager
In BRM 15.x, when you try to create an account using Web Services Manager from any SOAP client, you may encounter the following error in the cm.pinlog file:
opcode timeout occurred before calling: PCM_OP_TRANS_OPEN
Cause
The <CORRELATION_ID> element in the input payload contains colon characters (:). In BRM 15.x, there is a feature related to opcode timeout that parses the CORRELATION_ID based on colon characters. Therefore, it should not already exist in the input payload.
Solution
To resolve this error, ensure that you do not use a colon character in the <CORRELATION_ID> element for the input payload. You can replace this with a hyphen character (-).
For example, change
<CORRELATION_ID>e3d32cfc-a087-446b-809b-aa92547731d5-2024-09-02T08:44:45.988Z</CORRELATION_ID>
to
<CORRELATION_ID>e3d32cfc-a087-446b-809b-aa92547731d5-2024-09-02T08-44-45.988Z</CORRELATION_ID>
Problems Loading Configuration Objects
Problem: Failed to create XML context in isXsltExists, error [266]
Cause
The load_config utility tried to load the contents of XML configuration files into configuration (/config/*) objects in the BRM database, but the contents are not loaded.
Solution
Set the ORACLE_HOME environment variable to the BRM database client library path; for example, /tools/CGBU/contrib/Linux/x86_64/packages/oracle/db/12.2.0.1.0.
Problems During BRM Upgrade
Problem: The BRM root passwords stored in the wallet and /service/pcm object are not matching
A validation error appears due to incorrect BRM root password during the BRM installation for upgrade.
Cause
You have provided an incorrect BRM root password during the BRM installation for upgrade.
Solution
Change the incorrect BRM root password in the BRM client wallet by using the pin_config_editor utility. See "Changing Incorrect BRM Root Password" for more information.
You can also change the BRM root password in the BRM client wallet by using the PCM_OP_CUST_UPDATE_SERVICES opcode. For more information on the opcode, see BRM Opcode Guide.
To change the incorrect BRM root password:
  1. Go to the BRM_home/bin directory.
  2. Run the following command:
    pin_config_editor -setconf -wallet clientWalletLocation -parameter -.login_pw –pwd
    where clientWalletLocation is the path to the BRM client wallet.
  3. At the command prompt, enter the existing BRM root password.
    Ensure that you provide only the existing BRM root password. You can retrieve the existing BRM root password by using pin_crypt_app utility. See "Retrieving Configuration Entries from Client Wallet for Java PCM Applications" for more information.
  4. Enter the wallet password.
  5. Run the following command:
    pin_config_editor -setconf -wallet clientWalletLocation -parameter infranet.connection
  6. At the command prompt, enter values listed in Table 39-1.
    Table 39-1 BRM Connection Information
    Field Description
    User Name
    The user name for connecting to BRM.
    Password
    The BRM user's password.
    Host Name
    The IP address or the host name of the machine on which the primary BRM Connection Manager (CM) or CM Master Process (CMMP) are running.
    Port Number
    The TCP port number of the CM or CMMP on the host computer. The default value is 11960.
    Service Type
    The BRM service type. The default value is /service/admin_client.
    Service POID Id
    The POID of the BRM service. The default value is 1.
    Wallet Password
    The password for the BRM wallet.
Accessing Additional Debugging Information
If Oracle requests more logs to diagnose an issue, you may need to use the CMAP_DEBUG and CM_DEBUG flags.
These flags are typically used for troubleshooting and should not be enabled for extended periods, especially in a production environment, due to the significant increase in log data volume.
You set the CM_DEBUG and CMAP_DEBUG flags in the pin.conf file of the CM. Any setting changes for these values requires a restart of CM service.
Enabling the CM_DEBUG flag provides additional logging information about the main CM process. To enable this flag, assign the value 0x0001 to the CM_DEBUG environment variable.
Table 39-2 details the flags associated with the CMAP_DEBUG variable. Enabling the CMAP_DEBUG flag provides additional logging information. To enable this flag, assign one of the values from the table below to the CMAP_DEBUG environment variable.
Table 39-2 CMAP_DEBUG Flag Values
Flag Name Value Description
CMAP_DEBUG_TRACE 0x0001 Traces the flow of execution within CM.
CMAP_DEBUG_TRACE_FM 0x0004 Traces calls made to the FM module, excluding file listings.
CMAP_DEBUG_TIME_COUNTER 0x0008 Measures and logs the execution time of multi-node search operations.
CMAP_DEBUG_TRANS_IN_PR 0x0020 Logs information about received opcodes during transactions.
CMAP_DEBUG_PRINT_OUT_OP 0x0040 Logs the details of the flist sent as output by CM.
CMAP_DEBUG_PRINT_IN_OP 0x0080 Logs the details of the flist received as input by CM.
CMAP_DEBUG_ERROR 0x0100 Logs details regarding FATAL errors encountered by CMAP.
CMAP_DEBUG_TXN_CACHE 0x0200 Enables debugging messages related to the transaction cache.
CMAP_DEBUG_PRINT_TO_DM 0x1000 Logs the opcode and input flist sent to the Data Manager (DM).
CMAP_DEBUG_PRINT_FROM_DM 0x2000 Logs the opcode and output flist received from the Data Manager.
CMAP_DEBUG_RFLDS_CACHE 0x4000 Tracks hits and fills (successful retrievals and new data additions) within the Recently Fetched Fields Cache (part of the transaction cache).
CMAP_DEBUG_RFLDS_CACHE_DETAILS 0x8000 Provides detailed debugging information about the Recently Fetched Fields Cache.
All the definitions of flags are available at BRM_home/PortalDevKit/include/cm_debug.h.
Problem: Error Logging in to Customer Center Using Migrated BRM 7.5 Records After Upgrade to BRM 15
You are unable to log in to Customer Center after upgrading from BRM 7.5 to BRM 15. The CM logs an error like the following:
E Wed Nov 27 13:03:04 2024 cm4bill:1023009 cm_utils.c(159):5974 3::CustomerCenter:0:AWT-EventQueue-0:3:1732723384754001:5:::::-1
CM FM->DM input flist: opcode=PCM_OP_READ_OBJ, flags=0x0, errno=PIN_ERR_NOT_FOUND:3
# number of field entries allocated 20, used 1
0 PIN_FLD_POID POID [0] 0.0.0.1 /service/admin_client 1561800603 10479
And the DM logs an error like the following:
E Wed Nov 27 13:03:04 2024 dm:1022420 dm_subr.c(192):7412 3::CustomerCenter:0:AWT-EventQueue-0:3:1732723384754001:5:::::-1
dm_read_subrow_multi_select: no data on SUBTYPE, tbl admsvc_config_role_t
Cause
BRM 15 requires an association between the admin client or PCM client services and a /config/role object. This association is missing for records migrated from BRM 7.5, which prevents successful login.
Solution
To log in to Customer Center as a new user:
  1. Run the following command in SQL*Plus to insert the record into the ADMSVC_CONFIG_ROLE_T table:
    INSERT INTO ADMSVC_CONFIG_ROLE_T VALUES (1561800603,0,0,'',0);
    commit;
  2. Add this entry to the pin.conf file in the BRM_home/sys/test directory:
    - nap login_name super_user.0.0.0.1
  3. Run the PCM_OP_CUST_ASSOCIATE_ROLE opcode with the following input flist:
    0 PIN_FLD_CONFIG_ROLE         SUBSTRUCT [0] allocated 3, used 1
    1    PIN_FLD_CONFIG_PROFILE_OBJ    POID [0] 0.0.0.1 /config/role 417 0
    For more information about PCM_OP_CUST_ASSOCIATE_ROLE opcode, see "Associating a pcm_client or admin_client Service with a Role" in BRM Opcode Guide.
  4. Read the /service/admin_client object to confirm that the role association was created successfully.
  5. Log in as super_user.0.0.0.1.
To log in to Customer Center as an existing user:
  1. Run the following command in SQL*Plus to insert a record into the ADMSVC_CONFIG_ROLE_T table:
    commit;
  2. Run the PCM_OP_CUST_ASSOCIATE_ROLE opcode with the following input flist:
Problems Running BRM Applications and Utilities
Problem: PIN_ERR_BAD_UTF8 Error
BRM is reporting a PIN_ERR_BAD_UTF8 error when you run a utility or application that accesses the BRM database.
Cause
A field in a BRM table requires UTF8 characters. However, the utility or application validates whether any database fields contain erroneous UTF8 characters as part of its normal process.
Solution
Disable the UTF8 validation process in BRM by doing the following:
  1. In the Connection Manager (CM) configuration file (BRM_home/sys/cm/pin.conf), add the following entry:
    - cm pcp_validate_string_fields_as_utf8 0
  2. In the Data Manager (DM) configuration file (BRM_home/sys/dm_oracle/pin.conf), add the following entry:
    - dm pcp_validate_string_fields_as_utf8 0
  3. In the testnap configuration file (BRM_home/sys/test/pin.conf), add the following entry:
    - - pcp_validate_string_fields_as_utf8 0
