21 Connecting ECE to a 5G Client
You can set up 5G network integration for online and offline charging by using the Oracle Communications Elastic Charging Engine (ECE) HTTP Gateway.
Topics in this document:
Caution:
Deploying charging for 5G with HTTP Gateway (5G CHF) requires a cloud native deployment of ECE and BRM components. The HTTP Gateway can be used only on an ECE cloud native system.
About the HTTP Gateway
You integrate 5G clients with ECE by using the HTTP Gateway. The HTTP Gateway sends usage requests to ECE for online and offline charging and then sends responses to the 5G network.
The HTTP Gateway supports the 5G service-based architecture and does the following:
  • Receives ECE REST API requests from 5G clients and then translates them into batch request server (BRS) requests.
  • Publishes details about inbound ECE REST API requests that failed to the ECE failure Kafka topic.
  • Determines whether a usage request requires online or offline charging. See "About Determining the Charging Type" for details.
  • Submits BRS requests to the ECE server.
  • Receives responses from the ECE server and then translates them into REST API responses.
  • Responds to the 5G clients.
  • Consumes notifications from the ECE notification topic and then notifies the 5G clients by making a REST call to the URL stored in the system.
  • Publishes details about failed notifications to the corresponding Kafka dead-letter queue. For example: Ece.ChfNetwork.RarNotificationEvent.ChfNet001.Dlq.
When configured to do so, the HTTP Gateway can also send ECE REST API requests from 5G clients to the CDR Gateway for generating CDRs. For more information, see "Generating CDRs for External Systems".
ECE can perform online charging and offline charging. When HTTP Gateway receives a usage request, it determines whether to route the request to online or offline charging as follows:
  • For INITIATE requests, based on the multipleUnitUsage block. If the block is present, the request needs online charging. If the block is missing, the request needs offline charging.
  • For UPDATE requests, based on the value of the quotaManagementIndicator field in the request. If the value is set to ONLINE_CHARGING, the request needs online charging. If the field is missing or the value is set to OFFLINE_CHARGING, the request needs offline charging.
  • For TERMINATE requests, based on the value of the quotaManagementIndicator field in the request. If the value is set to ONLINE_CHARGING, the request needs online charging. If the field is missing or the value is set to OFFLINE_CHARGING, the request needs offline charging.
For more information about these properties, see the Nchf Converged Charging endpoints and Nchf Offline-Only Charging endpoints in REST API for Elastic Charging Engine.
About Sending Notifications to HTTP Gateway
You can configure ECE to send the following notifications to the ECE notification topics, where they are retrieved by the HTTP Gateway:
  • Spending Limit Notification (SNR): Specifies that a subscriber has reached a spending threshold or limit.
  • Reauthorization Request (RAR): Specifies that a reauthorization request is needed.
Configure HTTP Gateway to consume SNR and RAR notifications from the ECE notification topics. When configured to do so, HTTP Gateway listens on the ECE notification topics and filters notifications based on the notification type in the header. Depending on the notification type, HTTP Gateway does the following:
  • Retrieves SNR notifications from the Kafka topic and makes a REST API call to notifUri to post the notification.
  • Retrieves RAR notifications from the Kafka topic and makes a REST API call to post the notification to notifUri in the usage request.
Integrating HTTP Gateway with 5G Networks
For information about conformance with industry standards, see ECE 5G CHF Protocol Implementation Conformance Statement.
To integrate HTTP Gateway with your 5G network:
  1. Create Apache Kafka topics and connect them to ECE. See "Creating Kafka Topics for ECE Integration".
  2. Configure the NRF registration details for each HTTP Gateway instance in your system. See "Configuring Registration Details for the HTTP Gateway Server".
  3. Configure one or more NF services. See "Configuring NF Services".
  4. Configure the HTTP Gateway to send usage requests to ECE Server for convergent charging. See "Configuring HTTP Gateway for Convergent Charging".
  5. Define any custom service-event mappings in Pricing Design Center. See "Enabling Charging for Custom Events" in PDC Creating Product Offerings.
  6. Edit your mediation specification file and load it into ECE. The mediation specification enables the HTTP Gateway to associate each HTTP request with its respective usage-request builder. See "Editing the HTTP Gateway Mediation Specification File".
  7. Configure HTTP Gateway to terminate requests that have timed out at the client. See "Checking for Client-Side Timeouts in HTTP Gateway".
  8. Configure ECE to send notifications to HTTP Gateway through the ECE notification topics. See "Configuring ECE to Publish Notifications to HTTP Gateway".
  9. Enable OAuth 2.0 authentication in HTTP Gateway. See "Enabling OAuth 2.0 Authentication in HTTP Gateway" in BRM Security Guide.
  10. (Optional) Enable SSL-based communications between the CHF and the NRF, PCF, and SMF. See "Securing Communication Between HTTP Gateway and the NRF, PCF, and SMF".
    Skip this step if you enabled SSL-based communication between the CHF and the NRF, PCF, and SMF during the ECE installation process. See "Installing an ECE Integrated System" in ECE Installation Guide.
  11. (Optional) Configure your charging function (CHF) operations to route communication through a Services Communication Proxy (SCP). See "Configuring Communication Through SCP".
  12. Start your HTTP Gateway. See "Starting the HTTP Gateway".
After the HTTP Gateway is set up, your 5G clients can start:
  • Submitting ECE REST API requests to HTTP Gateway for online or offline charging by ECE. See "Using the ECE REST API".
  • Sending unrated 5G usage events to HTTP Gateway so they can be converted into CDRs and sent to roaming partners, data warehousing system, and legacy billing systems. See "Generating CDRs for External Systems".
You can register:
  • One or more HTTP Gateway server instances with an NRF registration server.
  • One HTTP Gateway server instance with multiple NRF registration servers.
  • One HTTP Gateway server instance with both primary and secondary NRF registration servers. In this case, when a primary NRF server goes down, the HTTP Gateway server registers with the secondary NRF server. See "Configuring Multiple Primary and Secondary NRF Registration Servers" for more information.
You do so by configuring the registration details in JConsole and then starting the HTTP Gateway instance.
To build an NRF registration request for an HTTP Gateway server instance:
  1. Access the ECE configuration MBeans in a JMX editor, such as JConsole. See "Accessing ECE Configuration MBeans".
  2. Expand the ECE Configuration node.
  3. Expand charging.nfProfileConfigurations.
  4. Expand Attributes.
  5. Specify the registration values for the fields in Table 21-1.
    Table 21-1 Fields for Configuring NRF Registration
    Attribute Name Mandatory Description
    name
    Yes
    The name of the HTTP Gateway instance.
    clusterName
    Yes
    The name of the cluster that the HTTP Gateway belongs to.
    allowedNfDomains No
    The network function (NF) domains that are allowed to access the HTTP Gateway server. Enter a regular expression for the domains according to the ECMA-262 dialect [8].
    If not provided, any NF domain is allowed to access the HTTP Gateway server.
    allowedNfTypes No
    The type of NFs that are allowed to access the HTTP Gateway server, such as AMF or SMF.
    If not provided, any NF type is allowed to access the HTTP Gateway server.
    allowedNssaisSd No
    The S-NSSAI Slice Differentiator (SD) ID of the network slices that are allowed to access the HTTP Gateway server.
    If not provided, any slice is allowed to access the HTTP Gateway server.
    allowedNssaisSst
    No
    The S-NSSAI Slice/Service Type (SST) ID of the network slices that are allowed to access the HTTP Gateway server.
    allowedPlmnsMcc No
    The Mobile Country Code (MCC) of the PLMNs that are allowed to access the HTTP Gateway server.
    If not provided, any PLMN is allowed to access the HTTP Gateway server.
    allowedPlmnsMnc
    No
    The Mobile Network Code (MNC) of the PLMNs that are allowed to access the HTTP Gateway server.
    capacity No
    The static capacity information in the range of 0-65535, expressed as a weight relative to other NF instances of the same type. The default is 0.
    If the capacity is also present in the nfServiceList parameters, those will have precedence over this value.
    customInfo No
    The specific data for custom NFs.
    defaultNotificationSubscriptionsCallbackUri No
    The callback URI for the default notification type.
    defaultNotificationSubscriptionsN1MessageClass
    No
    The information element (IE) that is used to identify the class of the N1 message type.
    defaultNotificationSubscriptionsN2InformationClass
    No
    The information element (IE) that is used to identify the class of the N2 message type.
    defaultNotificationSubscriptionsNotificationType
    No
    The type of notification for the corresponding callback URI.
    fqdn Yes
    The FQDN of the HTTP Gateway server.
    For AMF, the FQDN registered with the NRF is the AMF name. For example: chf-demo.novalocal.
    gpsiRangeListEnd No
    The ending range for the list of GPSIs that can be served by the CHF instance. The default is 100008.
    If not provided, the CHF can serve any GPSI.
    gpsiRangeListPattern No
    The pattern for the list of GPSI ranges that can be served by the CHF instance. The default is ^extid-.+@oracle1.com$.
    gpsiRangeListStart No
    The starting range for the list of GPSIs that can be served by the CHF instance. The default is 10000.
    heartBeatTimer No
    The time, in seconds, between two consecutive heartbeat messages from an NF Instance to the NRF.
    httpGatewayName
    Yes
    The name of the HTTP Gateway that this property configuration belongs to.
    interPlmnFqdn No
    The FQDN that is used for inter-PLMN routing as specified in 3GPP 23.003 [12]. This is required if the HTTP Gateway needs to be discoverable by other NFs in a different PLMN.
    ipv4Addresses No
    The IPv4 addresses of the HTTP Gateway.
    ipv6Addresses No
    The IPv6 addresses of the HTTP Gateway.
    load No
    The current load percentage of the HTTP Gateway, ranging from 0 to 100.
    locality No
    Operator-defined information about the location of the HTTP Gateway instance, such as the geographic location.
    nfProfileChangesInd No
    Whether the IE is absent in the request to the NRF and may be included by the NRF in the NFRegister or NFUpdate response:
    • true: The NF Profile contains changes.
    • false: The complete NF Profile. This is the default.
    nfProfileChangesSupportInd No
    Whether the IE may be present in the NFRegister or NFUpdate request and will be absent in the response:
    • true: The NF Service Consumer supports receiving NF Profile Changes in the response.
    • false: The NF Service Consumer does not support receiving NF Profile Changes in the response. This is the default.
    nfServicePersistence No
    If present, and set to true, it indicates that the different instances of an NF Service in this NF instance, supporting the same API version, can persist their resource state in shared storage. Thus, these resources are available after a new NF service instance supporting the same API version is selected by a NF Service Consumer (see 3GPP 23.527 [27]).
    Otherwise, it indicates that the NF Service Instances of the same NF Service cannot share a resource state inside the NF Instance.
    Possible values are true or false.
    nfSetId
    No
    A globally unique identifier of a set of equivalent and interchangeable NFs from an SNPN or PLMN network that provide distribution, redundancy, and scalability. This attribute is required if your system uses an SCP. See "Configuring Communication Through SCP".
    The default is empty.
    Note: You can include multiple instances of CHF under one NFSet ID. If one of the CHF instances is not available, SCP sends the request to another instance belonging to the same NFSet ID.
    nfStatus Yes
    The status of the HTTP Gateway server:
    • REGISTERED
    • SUSPENDED
    • UNDISCOVERABLE
    The default is REGISTERED.
    nfType Yes
    The type of NF. Set this to CHF.
    Note: ECE supports only CHF.
    nrfHttp2Enable
    No
    Whether the endpoint URL of the NRF registration server (nrfRestEndPointUrl) uses the HTTP/2 protocol:
    • true: The HTTP/2 protocol is used. This is the default.
    • false: The HTTP/1 protocol is used.
    nrfRestEndPointUrl Yes
    The endpoint URL of the NRF registration server. To register this HTTP Gateway instance with multiple NRF registration servers, list the endpoint URLs separated by a comma. For example: http://localhost:8080,http://localhost:8081.
    If this field is missing, NRF URL registration will not occur.
    nrfSecondarySiteRestEndPointUrls
    No
    The endpoint URL of one or more secondary NRF servers. The list can include NRF servers on the same site and on different sites.
    nsiList No
    The list of Network Slice Instances (NSIs) of the HTTP Gateway.
    If not provided, the HTTP Gateway can serve any NSI.
    perPlmnSnssaiListPlmnIdMcc
    No
    The Mobile Country Code (MCC) value for plmnSnssai.
    perPlmnSnssaiListPlmnIdMnc
    No
    The Mobile Network Code (MNC) value for plmnSnssai.
    perPlmnSnssaiListSd
    No
    The Slice Differentiator (SD) value for plmnSnssai.
    perPlmnSnssaiListSst
    No
    The Slice/Service Type (SST) value for plmnSnssai.
    plmnListMcc
    No
    The MCC value for plmnList.
    plmnListMnc
    No
    The MNC value for plmnList.
    plmnRangeListEnd
    No
    The ending range for the list of PLMNs (including the PLMN IDs of the CHF instance) that can be served by the CHF instance. The default is 333333.
    If not provided, the CHF can serve any PLMN.
    plmnRangeListPattern
    No
    The pattern for the list of PLMNs (including the PLMN IDs of the CHF instance) that can be served by the CHF instance.
    plmnRangeListStart
    No
    The starting range for the list of PLMNs that can be served by the CHF instance. The default is 100000.
    priority
    No
    The priority of this NF service relative to other services of the same type, where lower values indicate higher priority. The value must be in the range of 0-65535. The default is 1.
    Note: The NRF may overwrite the received priority value when exposing an NFProfile.
    recoveryTime
    No
    The timestamp for when the NF was started or restarted, in DateTime format.
    snssaisSdl
    No
    The S-NSSAIs of the NF. When present, this IE represents the list of S-NSSAIs supported in all the PLMNs listed in the plmnList IE.
    If not provided, the NF can serve any S-NSSAI.
    snssaisSst No
    If not provided, the CHF can serve any S-NSSAI.
    supiRangeListEnd No
    The end of a list of GPSI ranges that can be served by the CHF instance, such as 1009. The default is 10008.
    supiRangeListPattern No
    The pattern for a list of GPSI ranges that can be served by the CHF instance. The default is ^nai-450081.+@.+org$.
    supiRangeListStart No
    The start of a list of GPSI ranges that can be served by the CHF instance. The default is 10000.
You can configure an HTTP Gateway server instance to register with multiple primary and secondary NRF registration servers. In this case, when the heartbeat to a primary NRF server fails, HTTP Gateway retries the heartbeat for a configurable number of times. If all retries fail, HTTP Gateway initiates a registration request on the secondary NRF server. If all retries fail on the secondary NRF server, HTTP Gateway initiates a registration request on the next secondary NRF server.
If, later on, the primary NRF server comes back online, HTTP Gateway re-registers with the primary NRF server, starts the heartbeat in the primary NRF server, and then deregisters from the secondary NRF server.
To configure an HTTP Gateway instance to register with both primary and secondary NRF registration servers:
  5. Specify the value for the following attributes:
    • nrfRestEndPointUrl: Set this to the endpoint URL of the primary NRF server.
      To configure multiple primary NRF servers, list the endpoint URLs separated by a comma (,).
    • nrfSecondarySiteRestEndPointUrls: Set this to the endpoint URL of the secondary NRF server.
      • To configure multiple secondary NRF servers for one primary NRF server, list the endpoint URLs, in order, separated by a semicolon (;). HTTP Gateway uses the secondary NRF servers in the order listed.
      • If you have multiple primary NRF servers and want to map each to a different secondary NRF server, separate the secondary endpoint URLs by a comma (,).
      • If a secondary NRF server is not available for one of the primary NRF servers, enter NA or None.
Example: Configure One Primary with No Secondaries
This example specifies to configure a primary NRF server (primaryNRF_1) with no secondary NRF servers.
nrfRestEndPointUrl="www.primaryNRF_1.com"
secondaryNrfEndpointUrl=""
Example: Configure One Primary with Two Secondaries
This example specifies to configure a primary NRF server (primaryNRF_1) with two secondary NRF servers (secondaryNRF_A and secondaryNRF_B).
secondaryNrfEndpointUrl="www.secondaryNRF_A.com;www.secondaryNRF_B.com"
Example: Configure One Primary with Two Secondaries, and Another Primary with One Secondary
This example specifies to configure:
  • A primary NRF server (primaryNRF_1) with two secondary NRF servers (secondaryNRF_A and secondaryNRF_B)
  • A primary NRF Server (primaryNRF_2) with one secondary NRF server (secondaryNRF_C)
nrfRestEndPointUrl="www.primaryNRF_1.com,www.primaryNRF_2.com"
secondaryNrfEndpointUrl="www.secondaryNRF_A.com;www.secondaryNRF_B.com,www.secondaryNRF_C.com"
Example: Configure Three Primaries, Two with a Secondary and One with No Secondary
  • A primary NRF server (primaryNRF_1) with one secondary NRF server (secondaryNRF_A)
  • A primary NRF server (primaryNRF_2) with no secondary NRF server (None)
  • A primary NRF Server (primaryNRF_3) with one secondary NRF server (secondaryNRF_B)
nrfRestEndPointUrl="www.primaryNRF_1.com,www.primaryNRF_2.com,www.primaryNRF_3.com"
secondaryNrfEndpointUrl="www.secondaryNRF_A.com,None,www.secondaryNRF_B.com"
You must configure at least one NF service for HTTP Gateway. By default, HTTP Gateway includes one, but you can add more.
To add or remove an NF service configuration, do this:
  3. Expand charging.nfServiceConfigurations.
  4. Expand Operations.
  5. Do one of the following:
    • To add an NF service configuration, enter its name and then click addNfServiceConfiguration.
    • To remove an NF service configuration, enter its name and then click removeNfServiceConfiguration.
To configure an NF service, do this:
  1. Access the ECE configuration MBeans.
  3. Expand charging.nfServiceConfigurations.Instance_Name.
  5. Specify the NF service configuration values for the attributes in Table 21-2.
    Table 21-2 NF Service Configuration Attributes
    allowedNfDomains No
    The network function (NF) domains that are allowed to access the service instance. Enter a regular expression for the domains according to the ECMA-262 dialect.
    If not provided, any NF domain is allowed to access the service instance.
    allowedNfTypes No
    The type of NFs that are allowed to access the service instance.
    If not provided, any NF type can access the service instance.
    allowedNssaisSd No
    The S-NSSAI Slice Differentiator (SD) ID of the network slices that are allowed to access the service instance.
    If not provided, any slice can access the service instance.
    allowedNssaisSst No
    The S-NSSAI Slice/Service Type (SST) ID of the network slices that are allowed to access the service instance.
    allowedPlmnsMcc No
    The Mobile Country Code (MCC) of the PLMNs that are allowed to access the service instance.
    If not provided, any PLMN can access the service instance.
    When included, the allowedPlmns attribute does not need to include the PLMN IDs registered in the plmnList attribute of the NF Profile.
    allowedPlmnsMnc No The Mobile Network Code (MNC) of the PLMNs that are allowed to access the service instance.
    apiFullVersion Yes The full version number of the API as specified in 3GPP 29.501.
    apiPrefix No The optional path segments used to construct the {apiRoot} variable of the different API URIs.
    apiVersionInUri Yes The version of the service instance to be used in the URI for accessing the API.
    capacity No
    The static capacity information in the range of 0-65535, expressed as a weight relative to other services of the same type. The default is 50.
    The capacity and priority parameters, if present, are used for NF selection and load balancing.
    defaultNotificationSubscriptionsCallbackUri No The callback URI for the default notification type.
    defaultNotificationSubscriptionsN1MessageClass No The information element (IE) that is used to identify the class of the N1 message type.
    defaultNotificationSubscriptionsN2InformationClass No The information element (IE) that is used to identify the class of the N2 message type.
    defaultNotificationSubscriptionsNotificationType No The type of notification for the corresponding callback URI.
    expiry No The expiration date and time of the NF service. The default is 2020-12-01T18:55:08.871Z.
    fqdn No The FQDN of the NF service instance.
    interPlmnFqdn No The FQDN that is used for inter-PLMN routing as specified in 3GPP 23.003. This is required if the service instance needs to be discoverable by other NFs in a different PLMN.
    ipv4Address No
    The IPv4 address.
    ipv6Address No
    The IPv6 address.
    load No
    The current load percentage of the NF service, ranging from 1 through 100. The default is 5.
    name Yes
    The name of the NF service.
    nfServiceStatus Yes
    The status of the NF service instance:
    • REGISTERED
    • SUSPENDED
    • UNDISCOVERABLE
    port No The port number. The default is 0.
    primaryChfServiceInstance
    No
    The specific data for a CHF service instance.
    Include this IE if the CHF service instance serves as a secondary CHF instance of another primary CHF. When present, set it to the serviceInstanceId of the primary CHF service instance.
    priority No
    The priority used for service selection (relative to other services of the same type), ranging from 0 through 65535. Lower values indicate a higher priority. The default is 1.
    The NRF may overwrite the received priority value when exposing an NFProfile with the Nnrf_NFDiscovery service.
    recoveryTime No The timestamp when the NF service was started or restarted. For example, 2019-08-03T18:55:08.871Z.
    The format should be of type DateTime.
    scheme Yes The URI scheme, such as http or https. The default is http.
    secondaryChfServiceInstance
    No
    Include this IE if the CHF service instance serves as a primary CHF instance of another secondary CHF.
    When present, set it to the serviceInstanceId of the secondary CHF service instance.
    Do not set this IE when primaryChfServiceInstance is present.
    serviceInstanceId Yes The unique ID of the service instance within a given NF instance. The default is chf1.
    serviceName Yes
    The name of the service instance:
    • nnrf-nfm
    • nnrf-disc
    • nudm-sdm
    • nudm-uecm
    • nudm-ueau
    • nudm-ee
    • nudm-pp
    • namf-comm
    • namf-evts
    • namf-mt
    • namf-loc
    • nsmf-pdusession
    • nsmf-event-exposure
    • nausf-auth
    • nausf-sorprotection
    • nausf-upuprotection
    • nnef-pfdmanagement
    • npcf-am-policy-control
    • npcf-smpolicycontrol
    • npcf-policyauthorization
    • npcf-bdtpolicycontrol
    • npcf-eventexposure
    • npcf-ue-policy-control
    • nsmsf-sms
    • nnssf-nsselection
    • nnssf-nssaiavailability
    • nudr-dr
    • nlmf-loc
    • n5g-eir-eic
    • nbsf-management
    • nchf-spendinglimitcontrol
    • nchf-convergedcharging
    • nnwdaf-eventssubscription
    • nnwdaf-analyticsinfo
    The default is nchf-convergedcharging.
    supportedFeatures No The supported features of the NF Service instance.
    transport No The transport protocol. The default is TCP.
    httpGatewayName
    Yes
    clusterName
    Yes
Configure the HTTP Gateway to send usage requests to ECE Server for convergent charging, and to consume SNR and RAR notifications from the ECE notification topics.
To configure the HTTP Gateway for convergent charging:
  1. To allow secure communication between the CHF and the PCF, NRF, SMF, generate a self-signed SSL certificate for the CHF.
  2. Access the ECE configuration MBeans in a JMX editor, such as JConsole.
  3. Expand the ECE Configuration node.
  4. Expand charging.httpGatewayConfigurations.
  5. Expand Attributes.
  6. Specify values for the fields in Table 21-3.
    Table 21-3 Fields for Converged Charging
    Name Default Description
    serverSslKeyStore
    "httpGatewayServer.jks"
    The name of the KeyStore file for ECE server.
    serverSslKeyStoreType
    "@ECE_HTTPGATEWAY_KEYSTORE_TYPE@"
    The SSL KeyStore type for ECE server, such as JKS or PKCS12.
    serverSslKeyStoreAlias
    "@ECE_HTTPGATEWAY_KEYSTORE_ALIAS@"
    The alias name for the ECE server SSL KeyStore.
    walletLocation
    "@ECE_WALLET_LOCATION@"
    The path to the ECE wallet.
    snrHttp2Enable
    "true"
    Whether HTTP Gateway uses the HTTP/2 protocol:
    retryIntervalInMillis
    "5000"
    The amount of time, in milliseconds, between reconnection attempts to ECE server.
    notificationListenerConnectionPoolSize
    "10"
    The number of threads used by the HTTP Gateway instance for retrieving notifications from the ECE notification topics.
    httpIdentityKeystore
    "@HTTP_IDENTITY_KEYSTORE@"
    The path to the Identity KeyStore certificate file. The default is httpIdentityKeystore.p12.
    httpIdentityKeystoreType
    "@HTTP_IDENTITY_KEYSTORE_TYPE@"
    The type of Identity KeyStore: SSO or PKCS12. The default is PKCS12.
    httpTruststore
    "@HTTP_TRUSTSTORE@"
    The path to the TrustStore file. The default is httpTruststore.p12.
    httpTruststoreType
    "@HTTP_TRUSTSTORE_TYPE@"
    The type of TrustStore: SSO or PKCS12. The default is PKCS12.
  7. Expand charging.HttpGatewayConfigurations.name, where name is the name of the HTTP Gateway instance.
  8. Expand Attributes.
  9. Specify values for the fields in Table 21-4.
    Table 21-4 Fields for an HTTP Gateway Instance
    name
    "@HTTPGATEWAY_NAME@"
    clusterName
    "@CLUSTER_NAME@"
    serverHttp2Enabled
    "@HTTPGATEWAY_HTTP2_ENABLED@"
    Whether ECE Server uses the HTTP/2 protocol:
    serverPort
    "@HTTPGATEWAY_SERVER_PORT@"
    The HTTPS port number of the server on which HTTP Gateway resides.
    serverHttpPort
    "@HTTPGATEWAY_SERVER_HTTP_PORT@"
    The HTTP port number of the server on which HTTP Gateway resides.
    nrfHeartBeatRetryCount
    "4"
    The number of times the heartbeat retries if it fails during registration.
    serverSslEnabled
    "@HTTPGATEWAY_SERVER_SSL_ENABLED@"
    Whether SSL communication is enabled between your HTTP client and the HTTP Server (true) or not (false).
    processingThreadPoolSize
    "200"
    The number of threads used by the HTTP Gateway instance to process a set of incoming usage requests.
    processingQueueSize
    "32768"
    The number of incoming usage requests that can be processed simultaneously by the HTTP Gateway.
    kafkaBatchSize
    "10"
    The size of the Kafka batch.
    externalTrafficInfo
    The location of the header URL information.
    nrfRetryIntervalInSecond
    "60"
    The amount of time to wait before retrying a connection to an NRF instance.
    nrfRetryCount
    "3"
    The number of retry attempts for each NRF instance before attempting to register on a new NRF site.
    kafkaPartition
    “5,6,7,8,9”
    When kafkaCustomPartitionAssignorEnabled is set to false, this is the ID of the Kafka partition that the notification listener should consume messages from.
    Note: This attribute is ignored for ECE systems with a topic-based Kafka architecture. (That is, when the kafkaCustomPartitionAssignorEnabledattribute is set to true.)
    pcfSslEnabled
    "@PCF_SSL_ENABLED@"
    Whether SSL communication is enabled between the CHF and the PCF (true) or not (false). The default is false.
    nrfSslEnabled
    "@NRF_SSL_ENABLED@"
    Whether SSL communication is enabled between the CHF and the NRF (true) or not (false). The default is false.
    smfSslEnabled
    "@SMF_SSL_ENABLED@"
    Whether SSL communication is enabled between the CHF and the SMF (true) or not (false). The default is false.
    httpSSLType
    "@HTTP_SSL_TYPE@"
    The type of SSL connection between the CHF and PCF, NRF, or SMF:
    • oneway: The client must authenticate the server's identity. This is the default.
    • twoway: The client and server must authenticate each others identity.
    oauth2Enabled
    "@OAUTH2_ENABLED@"
    Whether incoming ECE API requests must have the access token attached to the header (true) or not (false).
    For information about setting up OAuth 2.0, see "ECE REST API Security" in BRM Security Guide.
    ingressRequestTimeoutMs
    "3000"
    Specifies how long the 5G client waits for a response, in milliseconds, before timing out. After this amount of time, the HTTP Gateway terminates the request. The default is 3000.
    Note: Set this to a slightly lower value than the client's timeout to account for the time spent traversing the network.
    enableNetworkExpiration
    "true"
    Whether to calculate the ingress request timeout using the time stamp contained in the payload (true) or using the time the message arrived (false).
    chfNetworkId
    The CHF Network ID for the HTTP Gateway.
    Note: This is used by Kafka topic-based routing when creating topic names.
    ccnNotificationAgeLimitInSec
    "300"
    (Requires ECE Interim Patch 15.1.0.0.1 (37951934))
    The time limit, in seconds, after which any Converged Charging Notify (CCN) notification consumed by the HTTP Gateway is considered expired and delivery attempts for the N40 notification to the N40 client are halted.
    slcnNotificationAgeLimitInSec
    "300"
    The time limit, in seconds, after which any Spending Limit Control Notify (SLCN) notification consumed by HTTP Gateway is considered expired and delivery attempts for the N28 notification to the N28 client are halted.
The mediation specification file enables HTTP Gateway to associate each ECE REST API request with its respective usage-request builder. HTTP Gateway uses the mediation specification to determine which service and event combination applies to an incoming ECE REST API request, enabling it to select the event definition that applies to the event to be rated.
You configure HTTP Gateway to base its selection of event definitions on any combination of the following in the request:
  • Service-Context-Id
  • Service-Identifier
  • Rating-Group
  • Event-Timestamp
From the preceding values, HTTP Gateway derives the following fields, which uniquely identify the event definition to use for building the BRS request for ECE:
  • ProductType (service)
  • EventType
  • Version
To edit the mediation specification:
  1. Create a mediation specification file or edit an existing one.
    A sample mediation specification file is available at ECE_home/sample_data/config_data/specifications/ece_end2end/http_mediation.spec.
    It is recommended to create only one mediation specification file. You can have only one mediation specification loaded in the ECE cluster and the last one loaded takes precedence.
  2. In the mediation specification file, add a row (in the table) for each event to be rated that specifies the following information:
    • Service-Identifier: The Service-Identifier is a placeholder.
    • Rating-Group: The Rating-Group value sent in the ECE REST API request.
    • ProductType: The service you have defined for the event.
    • EventType: The event definition you have defined for the event.
    • Version: The version number of the event definition object that you want to apply to the event.
    Define this information for each event definition object defined in the mediation table.
    For each received request, HTTP Gateway correlates the Rating-Group, and Event-Timestamp values (that you defined in the mediation specification) to the usage-request builder that applies to the event to be rated (for the applicable version, service, and event).
  3. (Optional) In the ValidFrom field of the table, set a future date and time when you want HTTP Gateway to recognize a newly deployed event definition object.
    For example, to have requests processed according to a new specification on December 16, 2020, you would enter:
    |   ValidFrom
     | "2020-12-16T12:01:01"
    You can also specify a time zone. For example,
    |   ValidFrom
     | "2020-12-16T12:01:01 PST"
    If a time zone is not sent, the ValidFrom field is set to UTC.
  4. Save the http_mediation.spec file in the directory where you save your configuration data.
  5. Verify that the directory specified in the ECE_home/config/management/migration-configuration.xml file is the directory where you save your configuration data.
  6. Run the configLoader utility:
    start configLoader
    The utility deploys your mediation specification to the ECE cluster. Any earlier mediation specification that was in the ECE cluster is overwritten.
    Any time you deploy a new version of a mediation specification into the repository, HTTP Gateway re-creates its in-memory usage-request builder map and begins using the mapping definitions (to send requests that adhere to the specifications) provided that the validFrom date is reached.
  7. Restart the HTTP Gateway.
  8. Load the mediation specification file into the ECE server by using the configLoader utility.
5G clients can contain their own request timeouts that activate when ECE takes too long to respond. When this occurs, the 5G client abandons the request, but ECE may continue to process the request and send a response, which the client discards. This extra processing is unnecessary and can be detrimental to ECE production systems approaching overload conditions. To improve performance, you can configure the HTTP Gateway to terminate requests that have timed out on the client side.
To configure the HTTP Gateway to check for client-side timeouts:
  3. Expand charging.HttpGatewayConfigurations.name, where name is the name of the HTTP Gateway instance.
  5. Specify timeout values for the HTTP Gateway instance:
    • ingressRequestTimeoutMs: Specifies how long the 5G client waits for a response, in milliseconds, before timing out. After this amount of time, the HTTP Gateway terminates the request. The default is 3000.
    • enableNetworkExpiration: Specifies whether to calculate the ingress request timeout using the time stamp contained in the request payload (true) or the time the message arrived at the HTTP Gateway (false). The default is true.
  6. Expand charging.brsConfigurations.name, where name is the name of the BRS instance.
  7. Expand Attributes.
  8. Specify timeout values for the BRS instance:
    • requestMaxRetry: Specifies the maximum number of times the BRS retries sending the ingress request to ECS. Use a value between 1 and 5. The default is 3.
    • requestRetryWaitTimeMs: Specifies the amount of time, in milliseconds, between each retry attempt. The default is 5.
When a request is terminated, the HTTP Gateway logs an error and sets the ResponseConsumerFailureCode field to Expired in the response to the client.
You can configure ECE to publish Nchf_SpendingLimitControl_Notify and Nchf_ConvergedCharging_Notify notifications to the ECE notification topics, where they will be retrieved by the HTTP Gateway. To do so:
  3. Expand charging.server.
  5. Set the kafkaEnabledForNotifications property to true.
  6. Expand charging.notification.
  8. Set the rarNotificationMode and spendingLimitNotificationMode properties to one of the following:
    • NONE: ECE does not send this notification type.
    • ASYNCHRONOUS: ECE sends asynchronous notifications to the ECE notification topics.
      If configured to do so, the HTTP Gateway will consume notifications from the ECE notification topics and dispatch them through a REST API call.
You can enable secure communication between the HTTP Gateway (CHF) and the NRF, PCF, and SMF during the ECE installation process. See "Installing an ECE Integrated System" in ECE Installation Guide for more information.
If you did not enable it during the ECE installation process, you can secure communication during a maintenance window.
To secure communication between HTTP Gateway and the NRF, PCF, and SMF:
  1. Generate your SSL TrustStore and Identity KeyStore certificates for the NRF, PCF, and SMF.
  2. Access the ECE configuration MBeans in a JMX editor, such as JConsole. See "Accessing ECE Configuration MBeans".
  6. Specify values for the following fields:
    • httpIdentityKeystore: Specify the path to the Identity KeyStore certificate files.
    • httpIdentityKeystoreType: Specify the type of SSL Identity KeyStore: PKCS12 or SSO.
    • httpTruststore: Specify the path to the SSL TrustStore files.
    • httpTruststoreType: Specify the type of SSL TrustStore file: PKCS12 or SSO.
  7. Expand charging.httpGatewayConfigurations.name, where name is the name of the HTTP Gateway instance.
  9. Specify values for the following fields:
    • pcfSSLEnabled: Set this to true to enable SSL-based communication between the CHF and PCF.
    • nrfSSLEnabled: Set this to true to enable SSL-based communication between the CHF and NRF.
    • smfSSLEnabled: Set this to true to enable SSL-based communication between the CHF and SMF.
    • httpSSLType: Specify the type of SSL communication: oneway or twoway.
    • scpAuthorities: Enter the URL of the primary and secondary SCP authority, delimited by commas. For example: scpAuthorities="scp1.example.com,scp2.example.com".
  10. If your system routes communication between the CHF and other network functions through an Oracle Services Communications Proxy (SCP), also set this attribute:
HTTP Gateway supports the communication models shown in Figure 21-1 for the charging function (CHF) operations.
Figure 21-1 Supported Communication Models for CHF Operations
Configuring your system to route communication between the CHF and other NFs through an Oracle Services Communications Proxy (SCPs) involves the following high-level tasks:
  1. Deploy two or more interchangeable CHF instances within the same PLMN or SNPN network and assign them the same NFSet ID.
  2. Include the NFSet ID in the HTTP Gateway's registration request to the NRF registration server.
  3. Provide the SCP KeyStore credentials to HTTP Gateway.
  4. Supply the SCP connection details to each instance of the HTTP Gateway.
NFSet IDs enable the SCP to reroute charging requests to another CHF instance within the same NFSet if one of the CHF instances becomes unavailable.
To configure HTTP Gateway to communicate through an SCP:
  5. Set nfSetId to a unique identifier for a set of equivalent and interchangeable NFs in a PLMN or SNPN network:
    • For PLMN networks, use this format:
      setsetID.chfset.5gc.mncthreeDigitMnc.mccthreeDigitMcc
      For example: set12.chfset.5gc.mnc007.mcc427.
    • For SNPN networks, use this format:
      setsetID.chfset.5gc.nidthreeDigitNid.mncthreeDigitMnc.mccthreeDigitMcc
      For example: set10.chfset.5gc.nid283.mnc012.mcc345.
    where:
    • setID consists of alphabetic characters, digits (0-9), and, optionally, a hyphen (-). The characters are not case specific.
    • threeDigitNid is a three-digit code for a Network Interface Device (NID). The NID code is assigned by an SNPNs during deployment.
    • threeDigitMnc is a three-digit code for a Mobile Network Code (MNC). If there are only two significant digits, start the code with a zero.
    • threeDigitMcc is a three-digit code for a Mobile Country Code (MCC).
  6. Expand the ECE Configuration node.
  9. Configure the following attributes:
    • Select httpIdentityKeystore and enter the name and path to the SCP-related KeyStore certificate file.
    • Select httpTruststore and enter the name and path to the SCP SSL TrustStore file.
  10. Expand the ECE Configuration node.
  11. Expand charging.HttpGatewayConfigurations.name, where name is the name of the HTTP Gateway instance.
  12. Expand Attributes.
  13. Configure the following attributes:
    • Select scpAuthorities and enter the URL of the primary and secondary SCP authority, delimited by commas. For example: scpAuthorities="scp1.example.com,scp2.example.com".
    • Select nrfHeartBeatRetryCount and enter the maximum number of tries for a heartbeat call. If all retries have been exhausted, HTTP Gateway starts registering with a new NRF. The default is 4.
    • Select nrfRetryCount and enter the number of retries for NRF registration. The default is 3.
When the HTTP Gateway starts, it automatically joins the Coherence cluster and gains access to ECE caches and invocation services that it uses to send requests to ECS. At startup, HTTP Gateway checks for notifications in the ECE notification topics.
To start the HTTP Gateway:
  1. Ensure that the HTTP Gateway server and other components are started.
  2. Start ECC:
    ./ecc
  3. Start the HTTP Gateway:
    ecc:000> start httpGateway
After you set up the HTTP Gateway on your system, your 5G clients can submit requests to the ECE REST API. For more information about the ECE REST API operation types, see REST API for Elastic Charging Engine.
You make calls to the ECE REST API through Swagger at this URL:
https://hostname:serverhttpsPort/openapi-ui/index.html
where hostname is the host name of the machine on which HTTP Gateway is running, and serverhttpsPort is the port number on the HTTP Gateway server.
If your system's communication model includes an SCP:
  • You must include the Authority header in all HTTP requests to the CHF operations. Set the Authority header to the host name and port number of the SCP Authority Server. For example:
    Authority: example.com:1534
  • CHF responses include a 3gpp-Sbi-Binding header to indicate binding preferences to SCP and NF consumers. The header appears in the following format:
    3gpp-Sbi-Binding: bl=nf-set; nfset=NFSet_ID; recoverytime=timestamp
