13 Using Logging for ECE Composable Services
You can review log files to troubleshoot errors and monitor system activity in the Oracle Communications Elastic Charging Engine (ECE) composable services.
Topics in this document:
About Logging
The ECE composable services use the Apache Log4j2 Java logging utility to log information and errors about the following:
  • Startup and shutdown activity
  • Interaction with external applications at integration points, including interactions with the ingress controller and 5G Network Functions (NFs)
  • Charging Manager (CHF) and Charging Gateway Function (CGF) composable services
For general information about:
When you deploy the ECE composable services, logging is automatically set up and running in your system with default settings.
Accessing the ECE Composable Service Logs
You access the logs by using the kubectl command in the ECE composable services namespace.
To access the logs:
  1. Retrieve the names of the ECE composable service pods by entering this command:
    kubectl -n EceCompServicesNameSpace get pods
    where EceCompServicesNameSpace is the namespace in which Kubernetes objects for the Helm chart reside.
    The following is an example of the command's output, with the pod names in bold:
    NAME                                       READY  STATUS     RESTARTS    AGE
    cgf-0                                      1/1    Running    0           7h23m
    cgf-coordinator-69f7d75d75-rml48           1/1    Running    0           7h23m
    nchf-converged-charging-65cfd79c6c-nvqb8   1/1    Running    0           7h23m
    nchf-nrf-7598464577-k8w25                  1/1    Running    0           7h23m
  2. Access the logs for a pod by entering this command:
    kubectl -n EceCompServicesNameSpace logs PodName
    For example, to access the cgf-0 logs, enter:
    kubectl -n EceCompServicesNameSpace logs cgf-0
The following is an example of the logs for the cgf-0 pod:
2026-05-19T17:58:20,591+00:00 | INFO | | main | r.hikari.HikariDataSource | oracle - Starting...
2026-05-19T17:58:20,993+00:00 | INFO | | main | er.hikari.pool.HikariPool | oracle - Added connection com.mysql.cj.jdbc.ConnectionImpl@620c8641
2026-05-19T17:58:21,687+00:00 | INFO | | main | r.hikari.HikariDataSource | oracle - Start completed.
2026-05-19T17:58:21,797+00:00 | INFO | | main | oracle.cagbu.ccs.cgf.Main | Configured Kafka subscriber lifecycle for 2 messaging service(s).
2026-05-19T17:58:22,102+00:00 | INFO | | main | gging.log4j.Log4jProvider | Logging initialization.
This task shows how to access logs for a single pod at a time. To tail logs from multiple pods, Oracle recommends using the Kubernetes Stern tool.
Changing the Log Levels
You can change the logging level for each pod at the root level and package level to one of the following:
  • TRACE: This log level provides verbose information, including each row loaded into the database.
  • DEBUG: This log level provides information about the steps for each loading function.
  • WARN: This log level provides non-critical warnings.
  • INFO: This log level provides a one-line summary of each file processed.
  • ERROR: This log level provides only error information.
To change the log levels for a pod:
  1. Create an override-values.yaml file for your ECE composable services Helm chart.
  2. To set a pod's root-level logging, set the logging.rootLevel key to the desired logging level.
  3. To set a pod's package-level logging, set the following keys:
    • logging.packageLogging.name: The name of the logging package, such as io.helidon or org.jboss.
    • logging.packageLogging.level: The logging level, such as TRACE, DEBUG, WARN, INFO, or ERROR.
  4. Save and close your override-values.yaml file.
  5. Update your Helm release:
    helm upgrade EceCompServicesReleaseName oc-ccs-version --values override-values.yaml -n EceCompServicesNameSpace
The following shows sample logging settings for the charging-gateway pod.
cgf:
   chargingGateway:
      logging:
         format:
            type: TEXT
            pattern: *loggingPattern
         rootLevel: DEBUG
         packageLogging:
            - name: com.oracle.cagbu
              level: INFO
            - name: io.helidon
              level: INFO
