12 General Ledger Opcode Workflows
Learn about the Oracle Communications Billing and Revenue Management (BRM) general ledger opcode workflows.
Topics in this document:
Opcodes Described in This Chapter
Table 12-1 lists the opcodes described in this chapter.
Caution:
  • Always use the BRM API to manipulate data. Changing data in the database without using the API can corrupt the data.
  • Do not use SQL commands to change data in the database. Always use the API.
Table 12-1 Opcodes Described in This Chapter
Opcode Topic
PCM_OP_ACT_POL_SPEC_GLID
Assigning G/L IDs to Prerated Events
PCM_OP_GL_LEDGER_REPORT
How BRM Exports G/L Reports
How BRM Stores General Ledger Reports
PCM_OP_GL_POL_EXPORT_GL
Customizing G/L Reports for Export
Customizing G/L Export Report Contents
PCM_OP_GL_POL_PRE_UPDATE_JOURNAL
Customizing G/L Data Stored in /journal Objects
How G/L IDs Affect Storage and Reporting of G/L Data
The G/L ID assigned to a balance impact determines whether the balance impact is stored in a /journal object and whether it is included in a G/L report as shown in Table 12-2:
Table 12-2 G/L IDs
G/L ID Description Stored in Journal Object? Included in G/L Report?
0
Default G/L ID.
If you forget to assign a G/L ID to a balance impact type, BRM automatically assigns G/L ID 0 to it. You should reassign such balance impact types to an appropriate G/L ID.
Yes
No
1 through 99
Assigned to balance impact types that are not included in G/L reports.
No
No
100 and above
Assigned to balance impact types that are included in G/L reports.
Yes
Yes
How BRM Records the Difference between Rounded and Unrounded Items
The difference between rounded and unrounded item totals is typically a very small amount referred to as the delta. This delta is recorded and included in G/L reports so that they can be accurately reconciled. The delta rounding difference is recorded in the following ways:
  • When billing is run and pending items are rounded, the delta rounding difference is recorded in the /item object.
  • A corresponding /journal entry object is created for each pending item. The delta rounding difference is stored as a credit or debit in the /journal object to balance the G/L:
    • If the rounding difference is negative, the balance needs to be credited, so the amount is stored in the PIN_FLD_CR_AR_NET_AMT field.
    • If the rounding difference is positive, the balance needs to be debited, so the amount is stored in the PIN_FLD_DB_AR_NET_AMT field.
  • When a G/L report is generated, the journal entry containing the delta rounding difference is included in the report.
The delta rounding difference is calculated as the difference between a rounded pending item total and the sum of the rounded journal entries associated with the pending item:
    round(unrounded pending items)
 -  sum(round(journal entries)
 =  rounding difference
For example, if a rounded pending item total is 11.72 and the sum of rounded journal entries is 11.73, the delta rounding difference is 11.72 - 11.73, or -.01.
During event processing, BRM retrieves balance impacts from each event and adds it to the revenue summary in the appropriate /journal object.
You can customize the data before it is written into /journal objects by using PCM_OP_GL_POL_PRE_UPDATE_JOURNAL.
PCM_OP_GL_POL_PRE_UPDATE_JOURNAL receives in the input flist the entries that are recorded in the /journal object. By default, the opcode does not perform any processing and returns only the entries passed in the input flist.
You can customize the opcode to add, modify, or remove one or more of the entries that will be recorded in the /journal object.
The opcode returns the following in the output flist:
  • PIN_FLD_POID field set to the /event object POID.
  • (Optional) PIN_FLD_JOURNAL_INFO array containing the entries that are recorded in the /journal object.
If the PIN_FLD_JOURNAL_INFO array is passed in the output flist, its PIN_FLD_POID field must be set either to -1 (when creating a new /journal object) or to a valid /journal POID (when updating an existing /journal object).
By default, BRM does not call PCM_OP_GL_POL_PRE_UPDATE_JOURNAL before writing data into /journal objects. You configure BRM to call the opcode by modifying the billing instance of the /config/business_params object with the pin_bus_params utility.
To enable this feature, run the pin_bus_params utility to change the CustomJournalUpdate business parameter. For information about this utility, see BRM Developer's Guide.
To enable custom updates to G/L data:
  1. Go to BRM_home/sys/data/config.
  2. Create an XML file from the /config/business_params object:
    pin_bus_params -r BusParamsBilling bus_params_billing.xml
  3. In the file, change disabled to enabled:
    <CustomJournalUpdate>enabled</CustomJournalUpdate>
  4. Save the file as bus_params_billing.xml.
  5. Load the XML file into the BRM database:
    pin_bus_params bus_params_billing.xml
  6. Stop and restart the CM.
You can customize the data in your exported G/L reports by configuring PCM_OP_GL_POL_EXPORT_GL. The pin_ledger_report utility calls this opcode in -export mode after it generates a G/L report but before it exports the G/L report data to an XML file.
For example, you can map the G/L revenue account name in the BRM system to a different account name based on your company's criteria. To do this, you customize PCM_OP_GL_POL_EXPORT_GL to do the mapping and return the modified PIN_FLD_GL_ACCTS array from the input flist.
When the pin_ledger_report utility runs in -export mode, it creates a new ledger report object with the custom data in the PIN_FLD_GL_ACCTS array. This customized G/L report is used for further processing and is exported to the G/L report XML files.
The PIN_FLD_RESULT value in the output flist determines whether to create a customized report from the original report used for export:
  • 0: Use the original G/L data to generate the export report. This is the default.
  • 1: Use the G/L data in the output flist to generate a custom export report.
The values returned by PCM_OP_GL_POL_EXPORT_GL must be in summary format even when the input flist data is in detailed format.
Use PCM_OP_GL_POL_EXPORT_GL to customize the contents of your exported G/L reports. For example, the BRM G/L account names could be mapped to the third-party account names or the BRM balance element IDs could be mapped to the third-party balance element IDs.
Mapping BRM G/L Account Names to Third-Party Account Names
Use PCM_OP_GL_POL_EXPORT_GL to convert BRM G/L account names to the G/L account names in your external G/L system before XML reports are exported. This makes importing them into the external system easier. The following is an example of the code used to map BRM G/L account names to the third-party account names after PCM_OP_GL_POL_EXPORT_GL has been called.
#Section to customize report
PCM_OP(ctxp, PCM_OP_READ_OBJ, 0, in_flistp, &r_flistp, ebufp);
PIN_ERR_LOG_FLIST(PIN_ERR_LEVEL_DEBUG,"Flistp after read obj in Custom report", r_flistp);
while ((tmp_flistp = PIN_FLIST_ELEM_TAKE_NEXT(r_flistp, PIN_FLD_GL_ACCTS,&rec_id, 1, &cookie, ebufp)) != (pin_flist_t *)NULL)
         char *segment = NULL;
         PIN_ERR_LOG_FLIST(PIN_ERR_LEVEL_DEBUG, "GL accts from input flist", tmp_flistp);
         tmp1_flistp = PIN_FLIST_ELEM_ADD(out_flistp, PIN_FLD_GL_ACCTS, ctr, ebufp);
         PIN_FLIST_CONCAT(tmp1_flistp, tmp_flistp, ebufp);
         ctr++;
         vp = PIN_FLIST_FLD_GET(r_flistp, PIN_FLD_GL_SEGMENT, 0, ebufp);
         if (vp)
            segment = (char *)vp;
         modify_acct_name(tmp1_flistp, PIN_FLD_AR_GROSS_GL_ACCT, segment, ebufp);
         modify_acct_name(tmp1_flistp, PIN_FLD_OFF_GROSS_GL_ACCT, segment, ebufp);
         modify_acct_name(tmp1_flistp, PIN_FLD_AR_NET_GL_ACCT, segment, ebufp);
         modify_acct_name(tmp1_flistp, PIN_FLD_OFF_NET_GL_ACCT, segment, ebufp);
         modify_acct_name(tmp1_flistp, PIN_FLD_AR_DISC_GL_ACCT, segment, ebufp);
         modify_acct_name(tmp1_flistp, PIN_FLD_OFF_DISC_GL_ACCT, segment, ebufp);
         modify_acct_name(tmp1_flistp, PIN_FLD_AR_TAX_GL_ACCT, segment, ebufp);
         modify_acct_name(tmp1_flistp, PIN_FLD_OFF_TAX_GL_ACCT, segment, ebufp);
         PIN_ERR_LOG_FLIST(PIN_ERR_LEVEL_DEBUG, "GL accts from output flist ", tmp1_flistp);
         PIN_ERR_LOG_FLIST(PIN_ERR_LEVEL_DEBUG, "Intermediate output flist ", out_flistp);
#Set PIN_FLD_RESULT to indicate customization
result = 1;
PIN_FLIST_FLD_SET(out_flistp, PIN_FLD_RESULT, (void *)&result, ebufp);
Mapping BRM Balance Element IDs to Third-Party Balance Element IDs
If the mapping capabilities provided with the BRM pin_glid mapping file are not sufficient, you can use PCM_OP_GL_POL_EXPORT_GL to convert BRM balance element IDs to the balance element IDs in your external G/L system before XML reports are exported. This makes importing them into the external system easier. The following is an example of the code used to map BRM balance element IDs to the third-party balance element IDs after PCM_OP_GL_POL_EXPORT_GL has been called.
PIN_ERR_LOG_FLIST(PIN_ERR_LEVEL_DEBUG, "Flistp after read obj in Custom report", r_flistp);
while ((tmp_flistp =PIN_FLIST_ELEM_TAKE_NEXT(r_flistp, PIN_FLD_GL_ACCTS,&rec_id, 1, &cookie, ebufp)) != (pin_flist_t *)NULL)
       PIN_ERR_LOG_FLIST(PIN_ERR_LEVEL_DEBUG, "GL accts from input flist ", tmp_flistp);
       ctr++;
       vp = PIN_FLIST_FLD_GET(r_flistp, PIN_FLD_RESOURCE_ID, 0, ebufp);
       if (vp)
          resource_id = (int32 *)vp;
          if (resource_id == 840)
              new_resource_id = 1840;
PIN_FLIST_FLD_SET(out_flistp, PIN_FLD_RESOURCE_ID, (void *)&new_resource_id, ebufp);
result = 1;
Customizing the G/L Report XML File Names
To customize the XML file names for your G/L reports, use the FileNamePrefix tag in the pin_config_export_gl.xml configuration file. For example, if your company tracks G/L data separately for multiple divisions of the same company, you can prefix the G/L data for each division with a unique identifier.
Use PCM_OP_ACT_POL_SPEC_GLID to assign G/L IDs to prerated events or partially rated events. By default, this opcode retrieves an event's G/L ID from the /config/map_glid object. You can customize it to perform searches on other objects and look at other fields.
For example, you can categorize adjustments by customizing the opcode to assign G/L IDs based on the adjustment type.
All customization is done using pin_glid and COA files.
The pin_ledger_report utility performs the following tasks when it runs:
  1. Retrieves G/L report configuration information from the /config/export_gl object to determine which reports to generate and which G/L segments to report.
  2. Creates a new /process_audit/export_gl object for this run and sets the status of the /process_audit/export_gl object to IN_PROGRESS.
  3. Reads the previous /process_audit/export_gl object and the ReportInitialStartDate value in the /config/export_gl object to determine if any G/L reports for previous periods have not been created. If so, creates them.
  4. Calls PCM_OP_GL_LEDGER_REPORT to create the /ledger_report object for the current period.
  5. Using the POID of the generated /ledger_report object, calls PCM_OP_GL_POL_EXPORT_GL and then does one of the following, based on the PIN_FLD_RESULT value:
    • 0: No customization; generates and exports the original report.
    • 1: Customization. If the G/L data was updated, creates a new /ledger_report object in database and exports the new report.
    If the report contains cumulative revenue, generates an incremental report by using the G/L report for the previous period, if one exists, and updates the /ledger_report object.
  6. If specified in the export configuration file, filters noncurrency balance elements from the generated /ledger_report object to be included in or excluded from the XML output file.
  7. Generates the XML output file.
  8. Updates the /process_audit/export_gl object with information about this run.
  9. Posts reports in the database.
  10. Sets the status of the /process_audit/export_gl object to RUN_COMPLETED.
    If the pin_ledger_report utility encounters errors during processing, it exits without completing the report processing. (One or more prior reports and one or more G/L export reports may have been successfully generated.)
The pin_ledger_report utility uses PCM_OP_GL_LEDGER_REPORT to store general ledger reports in the BRM database. This opcode calls PCM_OP_CREATE_OBJ to create a /ledger_report object.
When the PCM_OPFLG_READ_RESULT flag is set, the opcode returns the entire contents of the /ledger_report object.
How BRM Calculates G/L Revenue Using a Fixed Number of Days
When an event with a balance impact occurs, BRM stores the revenue data along with its associated G/L ID information in a /journal object in the BRM database. When you configure BRM to calculate G/L revenue based on a fixed number of days per month, BRM splits each /journal object based on the G/L cycle Day of Month (DOM) and billing DOM. See "Configuring Fixed-Day G/L Revenue Recognition" in BRM Collecting General Ledger Data for more information.
BRM creates /journal objects during cycle event processing through the PCM_OP_BILL_UPDATE_JOURNAL opcode. This opcode is called as part of the PCM_OP_ACT_USAGE flow.
When G/L revenue is calculated using a fixed number of days per month, the PCM_OP_BILL_UPDATE_JOURNAL opcode does the following:
  • Retrieves the account’s billing DOM from the account’s /balance_group object.
  • Retrieves the segment’s G/L cycle DOM from the /config/export_gl object.
  • Retrieves the fixed day value from the SmoothedGLReportingBasedOnFixedDays business parameter in the Billing instance of the /config/business_params object.
  • Calculates the amount recognized before the G/L cycle DOM using this formula:
    [(Fixed days value – days in period) ÷ fixed days] x Charge per month
  • Calculates the amount recognized after the G/L cycle DOM using this formula:
    Charge per month – Amount recognized before G/L cycle
  • Optionally, calls the PCM_OP_GL_POL_PRE_UPDATE_JOURNAL policy opcode to perform custom logic before creating the /journal objects. See "Customizing G/L Data Stored in /journal Objects".
  • Creates the following /journal objects:
    • One object for the amount recognized before the G/L cycle DOM
    • One object for each full billing cycle (applies only for multi-month cycles)
    • One object for the amount recognized after the G/L cycle DOM
The fixed-day calculation depends on the G/L DOM value defined in the /config/export_gl object. Make sure that the PIN_FLD_CALENDAR_DOM field is configured correctly for each G/L segment where fixed-day revenue recognition is required.
