5 Installing Elastic Charging Engine
Learn about the tasks required to install Oracle Communications Billing and Revenue Management (BRM) Elastic Charging Engine (ECE).
Topics in this document:
ECE supports complete installation only. To upgrade ECE, you install the new version of ECE using the Complete option and reconfigure the configuration and mediation files to match your existing release.
Downloading the ECE Software
For ECE 16.26.0.0 or any 16.26.0.x maintenance release: From the Oracle software delivery website (https://edelivery.oracle.com)
For any 16.26.0.x.y patch set release: From the Oracle support website (https://support.oracle.com)
Search for and download the Oracle Communications Elastic Charging Engine 16.26.0.x.y.0 software, where x refers to the maintenance release and y refers to the patch set release of ECE that you are installing.
The Zip archive includes the installer: OCECE-16.26.0.x.y.0_generic.jar.
Installing ECE by Using the GUI Installation
The steps for installing ECE by using the GUI installation depend on the ECE software components you choose to install:
To install an ECE integrated system, select the Complete option.
See "Installing an ECE Integrated System" for more information.
To install an ECE standalone system, select the Standalone option.
This option installs a self-contained, nonproduction version of ECE that is not integrated with Oracle Communications Billing and Revenue Management (BRM) or Pricing Design Center (PDC). Use the standalone system for evaluation, demonstration, and functional testing.
To install an ECE integrated system, select the Complete installation option. This option installs ECE Server, ECE Diameter Gateway, ECE HTTP Gateway, and all ECE integration packs.
If you are upgrading an existing ECE installation, select the same options and provide the same values that you provided during the previous installation.
To install an ECE integrated system:
On the server where you plan to install ECE, create a temporary directory (temp_dir).
Download the ECE software. See "Downloading the ECE Software" for instructions.
Go to the temp_dir directory, and run one of the following commands:
To start the GUI installer:
Java_home/bin/java -jar jarfile
where:
Java_home is the directory in which you installed the latest supported Java version.
jarfile is the ECE installer file, for example ocece-16.26.0.0.0_generic.jar.
To start the GUI installer and create a silent installer response file during the installation:
Java_home/bin/java -jar jarfile -record -destinationFile path
where path is the response file location and name.
The Welcome window appears.
In the Welcome window, click Next.
The installer creates an Inventory directory if it does not detect any installed Oracle products on the system. The Inventory directory stores information about Oracle products installed on your system.
In the Installation Inventory window, if you do not want to accept the defaults, enter the following settings and then click Next:
The full path of the inventory directory
The name of the operating system group that has write permission to the inventory directory
In the Installation Location window, enter the full path or browse to the directory in which you want to install ECE and then click Next.
If you have an existing ECE installation, ensure that you do not enter the path to the same directory in which the existing ECE release is installed. You can install ECE in a different directory on the same machine.
In the Languages Selection window, select the languages you want ECE to use and then click Next.
In the Installation Type window, select Complete and then click Next.
In the Select ECE Security Options window, select one of the ECE security options listed in Table 5-1 and then click Next.
Table 5-1 ECE Security Options
Option Description Security enabled with SSL
Enables the following security configurations:
SSL encryption
(SSL encryption affects overall system performance.)
JMX security
Authorized hosts list
Coherence node authentication
BRM SSL security authentication
PDC SSL security authentication
EM Gateway SSL security authentication
Security enabled without SSL
JMX security
Security disabled
Does not enable any security configuration. Available only for single-server installations.
In the Enable Persistence window, do one of the following and then click Next.
To persist all of the ECE data in the database, select Persistence enabled and proceed to step 12.
To persist only rated events in the Oracle NoSQL database, select Persistence disabled and proceed to the next step.
In the Oracle NoSQL Database Details window, specify the NoSQL database connection information in Table 5-2, click Next, and then proceed to step 17.
This window appears only if you selected Persistence disabled.
Table 5-2 Oracle NoSQL Database Details
Field Description Host Name
The host name or IP address of the machine on which the Oracle NoSQL database is installed.
Port Number
The port number assigned to the Oracle NoSQL database.
NoSQL Datastore Name (database name)
The name of the Oracle NoSQL data store in which you want to persist ECE rated events.
Rated Event Publisher writes rated events generated by the ECE server to this data store.
In the ECE Persistence Schema Creation window, select one of the following options and then click Next.
To have the installer create the schema user and tables for the ECE persistence schema, select Create schema user and tables and proceed to the next step.
To have the installer create only the tables for the ECE persistence schema, select Create tables only and proceed to step 16.
To use an existing schema user and tables, select Use existing schema user and tables and proceed to step 17.
In the ECE Persistence Database Details window, specify the information in Table 5-3 and then click Next.
Table 5-3 ECE Persistence Database Details
The host name or IP address of the machine on which the ECE persistence database is installed.
Port Number
The non-SSL port number assigned to the ECE persistence database service.
User Name
The user name for the ECE persistence database.
Password
The ECE persistence database user password.
Service Name
The name of the ECE persistence database service.
The ECE server persists all ECE data in this database.
SSL Enabled
Whether to enable SSL communication between ECE and the Oracle database.
The SSL Enabled option must be selected for production systems.
If SSL Enabled is not selected, the subsequent fields are disabled.
TLS Version
The version of TLS to use when connecting to the database. Select 1.2.
ORA Files Location
The location of the tnsnames.ora and sqlnet.ora files.
SSL Type
The SSL type: One Way or Two Way.
SSL Server Cert DN
The distinguished name of the SSL server certificate.
Wallet Location
The full path to the directory from which ECE accesses the SSL database wallets.
Wallet Type
The type of wallet: SSO or PKCS12.
Wallet Password
If you selected PKCS12, enter the password for the SSL database PKCS12 wallet.
If you selected SSO, this field is unavailable.
Ensure that the Oracle Database server is running. The installer connects to the server to verify that the information you entered is valid.
In the ECE Persistence Schema Details window, specify the information in Table 5-4, which is required to create the ECE schema in the ECE persistence database, and then click Next.
Table 5-4 ECE Persistence Schema Details
Field Description User Name
The ECE persistence schema user name.
Password
The password for the ECE persistence schema user.
Confirm Password
Enter the password for the ECE persistence schema user again.
ECE Tablespace
The name of the tablespace for the ECE schema.
Temp Tablespace
The name of the temporary tablespace for the ECE schema.
In the Configure Rated Event Partitions window, specify the information in Table 5-5, click Next, and then proceed to step 17.
Table 5-5 Configure Rated Event Partitions
Field Description Storage INITIAL
The RatedEvent table Storage INITIAL field data.
Storage NEXT
The RatedEvent table Storage NEXT field data.
Storage SUBPARTITIONS
The RatedEvent table Storage SUBPARTITIONS field data.
In the Persistence Database Details window, specify the information in Table 5-6 and then click Next.
This window appears only if you selected Create Tables Only for the ECE persistence schema.
Table 5-6 Persistence Database Details
Password
JDBC URL
The JDBC URL, in this format:
Driver:@HostName:Port:ServiceName
where:
Driver is the driver used to connect to Oracle Database.
HostName is the IP address or the host name of the computer on which the ECE persistence database is configured.
Port is the non-SSL port number assigned to the ECE persistence database service.
ServiceName is the name of the ECE persistence database service.
For example:
jdbc:oracle:thin:@localhost:1521:orclSSL Enabled
Select the SSL Enabled option for production systems.
When disabled, the subsequent fields are disabled.
SSL Type
Select the SSL type: One Way or Two Way.
SSL Server Cert DN
Wallet Location
The location of SSL database wallet.
Wallet Type
The type of SSL database wallet: SSO or PKCS12.
Wallet Password
The password of the SSL database wallet.
In the Config Data Details window, enter the path or browse to the directory in which ECE retrieves the XML files that contain your configuration data (mediation specifications). Click Next.
After installation, when you load data into ECE, the loading utility reads and loads configuration data from this directory.
In the Pricing Data Details window, enter the path or browse to the directory in which ECE retrieves the XML files that contain your pricing data. Click Next.
After installation, when you load data into ECE, the loading utility reads and loads pricing data from this directory.
In the Customer Data Details window, enter the path or browse to the directory in which ECE retrieves the XML files that contain your customer data. Click Next.
After installation, when you load data into ECE, the loading utility reads and loads customer data from this directory.
In the CrossRef Data Details window, enter the path or browse to the directory in which ECE retrieves the XML files that contain your cross-reference data. Click Next.
After installation, when you load data into ECE, the loading utility reads and loads cross-reference data from this directory.
In the PayLoad Config file Details window, enter the path or browse to the directory in which ECE retrieves the XML files that contain your payloadconfig data. Click Next.
After installation, when you load data into ECE, the loading utility reads and loads payloadconfig data from this directory.
In the Rated Event Manager Config File Details window, enter one of the following in the REF MODE field and then click Next.
CDR to only generate CDRs.
DIRECT to load data directly into BRM.
CDR_DIRECT to load data directly into BRM, and generate CDRs for audit purposes.
In the Persistence Data Details window, enter the path or browse to the directory into which the ECE BrmCdrPluginDirect Plug-in will write call detail record (CDR) files of rated events. Click Next.
This is the directory where the plug-in stores completed CDR files that are ready to be processed by BRM.
In the ECE Cluster Details window, enter the information in Table 5-7 and then click Next.
Table 5-7 ECE Cluster Details
Field Description User Name for Host Machines
The user name you specified when you created the ECE user account prior to installation. All machines in the cluster must have the same user name.
This is used by ECE to identify the remote machines on which to deploy ECE.
Java Heap Settings
The memory to allocate to each node in the ECE cluster.
The memory applies to each node for the driver machine and all server machines.
Cluster Name
The cluster name used by applications to identify ECE in the cluster. For example, Oracle Enterprise Manager Cloud Control uses the cluster name to locate ECE nodes for monitoring.
The cluster name must contain fewer than 32 characters.
Non Active-active multi site deployment
Select this if you do not plan to set up an active-active disaster recovery system.
Note: If you select this option, skip to step 26.
Active-Active multi site deployment
Select this if you plan to set up an active-active disaster recovery system. This is selected by default.
In the ECE Active Active Clusters window, enter the names of all clusters in your active-active sites, separated by commas. Ensure that you enter the current cluster's name. Click Next.
This window appears only if you selected Active-Active multi site deployment.
In the Coherence Grid Security window, specify the machines allowed to be part of the Coherence cluster and the credentials required for accessing the cluster, and then click Next.
If you selected the Security disabled option, this window does not appear. Go to step 27.
To specify the machines, do one or both of the following:
In the Host Details in comma separated format field, list the host names or IP addresses of all machines on which ECE nodes will reside. Separate each value with a comma.
Include your computer name in this field. Do not enter localhost or a loopback address.
Include all server machines across which the Coherence grid is deployed and any other machine that is to be part of the grid.
Specify a range of allowed addresses for hosts in the same subnet as follows:
In the Host Details Range from IP Address field, enter the valid IP address that starts the range.
In the Host Details Range to IP Address field, enter the valid IP address that ends the range.
To specify the credentials required to access the cluster:
In the Alias Name for Coherence grid security field, enter the account alias that defines the administrator for securing the Coherence cluster.
In the Password for the alias field, enter the password used to access the cluster security key in the Coherence keystore (the ECE_home/oceceserver/config/server.jks file).
This is the password for Coherence cluster security.
You use this password when enabling secure socket layer (SSL).
For more information, see "Setting Up Cluster Security" in BRM System Administrator's Guide.
In the KeyStore Credentials window, specify the keystore credential information in Table 5-8 and then click Next.
Table 5-8 KeyStore Credentials
Field Description Key Password for boundary system alias
The password ECE uses to access the server JKS file.
Certificate store password
The password used to access the server JKS file.
DName
The credentials that define what users are authorized to do regarding cluster security.
Examples:
CN=Administrator,OU=Rating,O=CompanyB
Or:
CN=Developer,OU=ECE
where:
CN is the common name for the user.
OU is the organizational unit of the user.
O is the organization of the user.
The combined DName values are similar to a group in Linux.
Tip: The value set here (in creating the certificate) is used for authentication in the cluster and must be the same as the value used in the ECE_home/oceceserver/config/permissions.xml file, which is created after installation and used for authorization in the cluster.
You use the DName value when enabling SSL.
The DName value is used as a command line parameter for creating the server.jks keystore.
In the Oracle Wallet Details window, specify the ECE wallet details in Table 5-9 and then click Next.
Table 5-9 Oracle Wallet Details
Field Description Wallet Location
The full path or browse to the directory in which you want to store the Oracle wallet for ECE.
Wallet Password
The password for the ECE wallet.
Confirm Wallet Password
The password for the ECE wallet again.
In the Kafka or WebLogic JMS window, specify whether to use Apache Kafka topics or WebLogic JMS queues for ECE and then click Next.
If you selected Kafka, proceed to the next step.
If you selected WebLogic JMS, proceed to step 31.
In the Kafka Configuration Details window, enter the information in Table 5-10, click Next, and then proceed to step 33.
Table 5-10 Kafka Configuration Details
Field Description Enable SSL connection for Kafka
Whether to enable an SSL connection for Kafka.
Enable OAuth 2.0 Connection for Kafka
Whether to enable OAuth 2.0 authentication between ECE and the Kafka brokers.
OAuth2.0 Token Endpoint Uses HTTPS
Whether the OAuth 2.0 token endpoint uses HTTPS (selected) or HTTP (unselected).
Host Name and Port
The host name and port number of the machine on which Apache Kafka is installed.
Kafka TrustStore Location
(If you have selected to use SSL with Kafka) The full path to the truststore JKS file.
Kafka TrustStore Password
(If you have selected to use SSL with Kafka) The password for the truststore.
OAuth2.0 Token Endpoint URL
(If you have selected OAuth 2.0 connection for Kafka) The specific network address (API endpoint) of your identity provider where the client exchanges credentials for a token.
OAuth2.0 Client ID
(If you have selected OAuth 2.0 connection for Kafka) The client ID registered with your identity provider that identifies the ECE application.
OAuth2.0 Client Scope
(If you have selected OAuth 2.0 connection for Kafka) The OAuth scope a Kafka client requests from the identity provider to generate an access token containing the broker's specific audience claim.
OAuth2.0 Client Secret
(If you have selected OAuth 2.0 connection for Kafka) The confidential secret used to authenticate the ECE application to the identity provider.
Topic Name
The name of the Kafka topic in which ECE will publish notifications.
Suspense Topic Name
The name of the Kafka topic in which BRM will publish failed notifications.
Failure Topic Persistence Enabled
Whether to save information about failed usage requests to the persistence database.
Failure Topic Name
(If failure topic persistence is enabled) The name of the Kafka topic in which ECE publishes failed ECE usage requests.
Overage Topic Name
The name of the Kafka topic in which ECE publishes overage records, which contain details about usage overage amounts for prepaid customers.
Partitions
The number of partitions to create in the ECE notification topic for Kafka partition-based routing. Configure enough partitions for all gateway notification consumers that use dedicated partitions, plus the partition configured by kafkaPartitionForInternalExternal.
If you assign consecutive partition IDs starting with 0, use this formula to calculate the minimum number of partitions:
[(Max Diameter Gateway instances) + (Max HTTP Gateway replicas) + (Max BRM Gateway instances) + (1 for kafkaPartitionForInternalExternal)]
For example, if you have 4 Diameter Gateway instances, 3 HTTP Gateway replicas, and 1 BRM Gateway instance, create at least [(4 + 3 + 1 + 1) = 9] partitions.
This example assumes that the configured partition IDs are 0 through 8. Regardless of the formula, the value of partitions must be greater than the highest partition ID configured in kafkaPartition or kafkaPartitionForInternalExternal. For example, if the highest configured partition ID is 9, configure at least 10 partitions.
You can set this value higher than the calculated minimum to allow future gateway partition IDs without changing the Kafka broker.
Failure Partitions
(If failure topic persistence is enabled) The number of partitions to create in your failure topic.
Replication Factor
The number of replications to create.
RGW Topic Name
The name of the Kafka topic in which ECE publishes RADIUS Gateway notifications.
In the ECE Notification Queue Details window, enter the Java Message Service (JMS) credentials in Table 5-11 and then click Next.
ECE publishes notifications into this JMS queue, which external systems can use to obtain data for their own processing.
After you enter the JMS credentials, the installer checks the connection to your WebLogic Server through TCP Port 7. Ensure that TCP Port 7 is open in your WebLogic server's firewall.
After you install ECE, you run a postinstallation script that creates the JMS queue on the server.
Table 5-11 ECE Notification Queue Details
The host name of the server on which the JMS queue (JMS topic) resides.
Port Number
The port number of the server on which the JMS queue (JMS topic) resides.
User Name
The user name for logging in to the server on which the JMS queue (JMS topic) resides.
Password
The password for logging in to the server on which the JMS queue (JMS topic) resides.
Connection Factory Name
The connection factory name used to create connections to the JMS queue (JMS topic) queue.
After installing ECE, you run an ECE postinstallation script that creates the JMS queue (JMS topic) on the server. The connection factory name entered here is used by the script to create connections to the JMS queue.
Topic Name
The name of the JMS queue on the server, to which ECE publishes notification events.
After installing ECE, you run a postinstallation script that creates the JMS queue (JMS topic) on the server. The topic name entered here is the name the ECE postinstallation script uses to create the JMS queue.
Suspense Queue Name
The name for the suspense queue to which ECE pushes the failed notifications.
In the ECE Notification Queue SSL Details window, enter the information in Table 5-12, which is required to connect to the Java Message Service queue to which ECE publishes notification events. Click Next.
Table 5-12 ECE Notification Queue SSL Details
Field Description Disable SSL
If you do not want to use SSL to encrypt communication between ECE and the JMS queue, select the Disable SSL option.
If you select this option, do not enter values in the following fields.
Keystore password
The password used to access the SSL keystore file.
Keystore location
The full path to the SSL keystore file.
In the Diameter Gateway Details window, enter the information in Table 5-13 and then click Next.
The Diameter Gateway details you enter in this window apply to one Diameter Gateway node instance that listens to all network interfaces for Diameter messages, which is suitable for basic testing directly after installation.
For a distributed environment, you must add Diameter Gateway node instances to your topology and configure a unique network interface for each instance after installation.
Table 5-13 Diameter Gateway Details
Field Description Skip
If you do not want Diameter Gateway to start when ECE starts, select the Skip option.
Origin Host
The value for the Origin-Host attribute-value pair (AVP) to be sent in the Diameter request.
This is a unique identifier that you assign your Diameter Gateway server on its host. It can be any string value.
The value set here is used by the Diameter client to identify your Diameter Gateway server as the connecting Diameter peer that is the source of the Diameter message.
For more information about how the Origin-Host AVP can be specified, refer to Internet Engineering Task Force (IETF) Network Working Group RFC 3588 (Diameter Base Protocol).
Origin Realm
The value for the Origin-Realm AVP to be sent by the Diameter Gateway in outgoing Diameter requests.
This is the signaling realm (domain) that you assign your Diameter Gateway server.
The value set here is used by Diameter clients to identify your Diameter Gateway server as the source of the Diameter message.
For more information about how the Origin-Realm AVP can be specified, refer to Internet Engineering Task Force (IETF) Network Working Group RFC 3588 (Diameter Base Protocol).
In the RADIUS Gateway Details window, enter the information in Table 5-14 and then click Next.
The RADIUS Gateway details you enter in this window apply to a single RADIUS Gateway instance (node) that listens to all network interfaces for RADIUS messages, which is suitable for basic testing directly after installation.
For a distributed environment, you must add RADIUS Gateway instances (nodes) to your topology and configure a unique network interface for each instance after installation.
Table 5-14 RADIUS Gateway Details
If you do not want RADIUS Gateway to start when ECE starts, select the Skip option.
Name
The name of the RADIUS Gateway instance.
Port
The port number assigned to RADIUS Gateway.
Shared Secret
The common password shared between the RADIUS Gateway server and Network Access Server (NAS). It is used by the RADIUS protocol for security.
Disconnect Port
The port used to send RADIUS Disconnect-Request messages to the NAS to terminate active subscriber sessions.
In the HTTP Gateway Details window, enter the information in Table 5-15 and then click Next.
Table 5-15 HTTP Gateway Details
Field Description Name
The name of the HTTP Gateway.
Enable HTTP2
If your HTTP Gateway server will communicate using the HTTP/2 protocol, select the Enable HTTP2 option. Otherwise, the HTTP 1.1 protocol will be used.
Server Port
The HTTPS port number of the computer on which the HTTP Gateway resides.
Enter a value only if SSL is enabled.
Server HTTP Port
Enter a value only if SSL is disabled.
Enable Server SSL
If you will use SSL to encrypt communication between the HTTP client and HTTP server, select the Enable Server SSL option.
When selected, the Server Port is used for communication.
Enable NRF Registration
If you want this HTTP Gateway server to use NRF registration charging setting parameters for NRF registration, select the Enable NRF Registration option.
Only one HTTP server can register to NRF. If more than one HTTP server has NRF registration enabled, the HTTP Gateway will throw an error and not start up.
If NRF registration is disabled on all HTTP servers, NRF registration will not happen.
In the HTTP Gateway Server SSL Keystore Password Details window, specify the information in Table 5-16 and then click Next.
Table 5-16 HTTP Gateway Server SSL Keystore Password Details
Field Description Keystore Alias
The unique alias for the keystore and trusted certificate entries. The default is oracle.
Keystore Type
The type of keystore, such as JCEKS, JKS, and PKCS12. The default is PKCS12.
Keystore Algorithm
The name of the algorithm used to generate the key such as RSA or DSA. The default is RSA.
Keystore DName
Examples:
Or:
CN=Developer,OU=ECE
where:
Keystore Size
The size of the keystore. The default is 1024.
Keystore Password
Confirm Keystore Password
Enter the keystore password again.
In the NRF, PCF and SMF SSL Configuration Details window, specify the information in Table 5-17 and then click Next.
Table 5-17 NRF, PCF and SMF SSL Configuration Details
Field Description Enable twoway SSL (mTLS)
If you will use two-way SSL between HTTP Gateway and the PCF, NRF, and SMF, select the Enable twoway SSL (mTLS) option.
Enable PCF SSL
If you will use SSL to encrypt communication between the HTTP Gateway and the PCF, select the Enable PCF SSL option.
Enable NRF SSL
If you will use SSL to encrypt communication between the HTTP Gateway and the NRF, select the Enable NRF SSL option.
Enable SMF SSL
If you will use SSL to encrypt communication between the HTTP Gateway and the SMF, select the Enable SMF SSL option.
Truststore location
The directory in which the truststore file is located.
Truststore type
The type of truststore: SSO or PKCS12. The default is PKCS12.
Truststore password
Identity keystore location
The directory in which the Identity keystore certificate file is located.
This field is required only when the Enable twoway SSL (mTLS) option is selected.
Identity keystore type
The type of keystore: SSO or PKCS12. The default is PKCS12.
Identity keystore password
The password for the identity keystore.
In the Enter Details for enabling OAuth2 window, specify the information in Table 5-18 and then click Next if you want to enable OAuth 2.0 for 5G services in an on-premises environment.
If OAuth2enabled is set to true, you must at least enter the JWT Algorithm used and NRF Public Key Location or Symmetric key.Table 5-18 Enabling OAuth2
Field Description Enable OAuth2
If you want OAuth 2.0 security protocol to authenticate a 5G client’s identity and authorize it to access the ECE REST API, select Enable OAuth2.
The path to the public key of the Network Repository Function.
You use this when asymmetric cryptography is used to create the access token.
JWT Algorithm used
The algorithm used by the Network Repository Function to create the JSON Web Token (JWT).
Symmetric Key
The details of the symmetric key.
It is used when you use symmetric cryptography to create the access token by the NRF.
The symmetric key is stored in the ECE wallet as
oauth2.symmetric.key.Note:
When you make access tokens by asymmetric cryptography, the following JWT Algorithms are supported:-
RSA
ECDSA
In the BRM Database Connection Details window, specify the information in Table 5-19 and then click Next.
Table 5-19 BRM Database Connection Details
Field Description JDBC URL
The following colon-separated values:
where:
Driver is the driver used to connect to the BRM database.
HostName is the IP address or the host name of the computer on which the BRM database is configured.
Port is the port number assigned to the BRM database service.
ServiceName is the name of the BRM database service.
For example:
jdbc:oracle:thin:@localhost:1521:PINDBUser Name
The BRM database schema user name.
Password
The password for the BRM database user.
Queue Name
The name of the Oracle Advanced Queuing (AQ) database queue that the Account Synchronization DM uses to publish business events for ECE to consume.
ECE listens on this queue for loading update requests from BRM.
Suspense Queue Name
The name of the Oracle AQ database queue to which ECE moves events for failed update requests for later reprocessing.
After installing ECE, you can use an ECE postinstallation script to create this queue. When prompted by the script, enter the queue name you entered here.
Acknowledgment Queue Name
The name of the Oracle AQ database queue to which ECE publishes acknowledgments for BRM.
For example, ECE uses this queue to send acknowledgment events to BRM during the rerating process, indicating that the process can start or finish.
AMT Queue Name
The name of the Oracle AQ database queue to which ECE publishes notifications for BRM.
SSL Enabled
Whether to enable SSL communication.
If disabled, the subsequent fields are disabled.
TLS Version
ORA Files Location
SSL Type
SSL Server Cert DN
Wallet Location
The location of the SSL database wallet.
Wallet Type
Wallet Password
In the BRM Gateway Details window, enter the information in Table 5-20 and then click Next.
Table 5-20 BRM Gateway Details
The IP address or the host name of the computer on which BRM is configured.
CM Port
The port number assigned to the CM.
User Name
The BRM user name.
Password
The password for logging in to BRM.
Disable SSL
If you will not use SSL to encrypt communication between ECE and BRM through BRM Gateway, select the Disable SSL option.
If you select this option, do not change the value in the following field.
Wallet File Absolute Path
The path to the Oracle wallet file that contains the SSL trusted certificates for BRM Gateway.
If SSL is enabled for BRM Gateway but the Oracle wallet file containing the SSL trusted certificates for BRM Gateway is not in the default location (/opt/wallet/client/cwallet.sso), replace the default path in the Wallet File Absolute Path field with the full path to the actual location.
In the External Manager (EM) Gateway Details window, specify the information in Table 5-21 and then click Next.
Table 5-21 External Manager (EM) Gateway Details
Field Description Number EM Gateways
The number of EM Gateway instances you want ECE to run automatically when you start EM Gateway.
Starting Port Number
The port number assigned to EM Gateway.
If you have more than one EM Gateway instance, this is the starting port number. Subsequent port numbers increase by one for each additional EM Gateway instance. For example, if the starting port number is 15502 and you specify three EM Gateway instances, ports 15502, 15503, and 15504 are used by EM Gateway processes.
Ensure that no other processes on the machine use port numbers assigned to EM Gateway instances.
Disable SSL
If you do not want to use SSL to encrypt communication between BRM and ECE through EM Gateway, select the Disable SSL option.
If you select this option, do not enter or change values in the following fields.
Client Authentication Disabled
If you do not want authentication to be performed to check whether EM Gateway is allowed to communicate with ECE, select the Client Authentication Disabled option.
If you select this option, do not change the values in the following fields.
Client wallet
If SSL is enabled for EM Gateway but the Oracle wallet file containing the SSL trusted certificates for EM Gateway is not in the default location (/opt/wallet/server/cwallet.sso), replace the default path in the Client wallet field with the full path to the actual location.
In the PDC Pricing Components Queue Details window, enter the system connection information in Table 5-22 for the server on which the JMS queue for PDC pricing component data resides. Click Next.
Table 5-22 PDC Pricing Components Queue Details
The IP address or host name of the computer that hosts the JMS queue for PDC pricing component data.
Port Number
The port number of the computer on which the PDC JMS queue resides.
User Name
The user name for logging in to the server on which the PDC JMS queue resides.
Password
The password for logging in to the server on which the PDC JMS queue resides.
Disable SSL
If you will not use SSL to encrypt communication between ECE and PDC, select the Disable SSL option.
PDC KeyStore password
KeyStore Path
PDC publishes pricing component data into this queue. ECE listens on this JMS queue to consume the pricing component data.
In the Third Party Component Details window, enter the path or browse to the directory that contains the third-party components required by ECE and then click Next.
In the Java Home Location window, enter the path or browse to the directory in which a supported version of Java is installed and then click Next.
In the Installation Summary window, review the selections you have made in the preceding windows and then click Install.
The Installation Progress window appears.
After the installation begins, clicking Stop installation stops the installation process, but the files that are already copied are not removed.
When the installation is done, click Next.
In the Installation Complete window, click Finish to exit the installer.
The installer verifies that all required software is available and displays errors for missing or unavailable components or connectivity issues.
For information about verifying the installation of ECE, see "Verifying the ECE Installation".
For information about ECE installer logs, see "Troubleshooting the ECE Installation".
Installing a Standalone ECE System
To install a standalone ECE system, select the Standalone installation option. A standalone ECE system is a self-contained, nonproduction version of ECE that is not integrated with BRM or Pricing Design Center (PDC). Use the standalone system for evaluation, demonstration, and functional testing.
To install a standalone ECE system:
where:
jarfile is the ECE installer file, for example ocece-16.26.0.1.0.0_generic.jar.
In the Installation Inventory window, specify the following information before clicking Next.
Full path of the inventory directory
Name of the operating system group that has write permission to the inventory directory
In the Installation Type window, select Standalone and then click Next.
In the ECE Security Options window, select one of the ECE security options listed in Table 5-23 and then click Next.
Table 5-23 ECE Security Options
Option Description Security disabled
(Single server installation only)
JMX security
SSL encryption
(SSL encryption can affect overall system performance.)
JMX security
To persist all ECE data in the database, select Persistence enabled and proceed to step 12.
To persist only the rated events in the Oracle NoSQL database, select Persistence disabled and proceed to the next step.
In the Oracle NoSQL Database Details window, specify the information in Table 5-24, click Next, and then proceed to step 16.
Table 5-24 Oracle NoSQL Database Details
Port Number
In the ECE Persistence Schema Creation window, do one of the following and then click Next.
To create a user and tables for the ECE persistence schema, select Create schema user and tables and proceed to the next step.
To create only the tables for the ECE persistence schema, select Create tables Only and proceed to step 13.
To use an existing schema user and tables, select Use existing schema user and tables and proceed to step 16.
In the ECE Persistence Database Details window, specify the information in Table 5-25 and then click Next.
Table 5-25 ECE Persistence Database Details
Port Number
User Name
The SYSDBA or system user name for the ECE persistence database.
Password
Service Name
This is where all ECE data is persisted by the ECE server.
SSL Enabled
TLS Version
ORA Files Location
SSL Type
SSL Server Cert DN
The distinguished name of the SSL server certificate. Wallet Location
Wallet Type
Wallet Password
If you selected PKCS12, enter the password for the SSL DB PKCS12 wallet.
If you selected SSO, this field is grayed out.
In the ECE Persistence Schema Details window, specify the information in Table 5-26, click Next, and then proceed to step 16.
Table 5-26 ECE Persistence Schema Details
Password
Confirm Password
ECE Tablespace
Temp Tablespace
In the Persistence Database Details window, specify the information in Table 5-27 and then click Next.
Table 5-27 Persistence Database Details
Password
JDBC URL
where:
For example:
If you do not select SSL Enabled, the remaining SSL-related fields are disabled.
SSL Type
SSL Server Cert DN
Wallet Location
Wallet Type
Wallet Password
In the Config Data Details window, enter the path or browse to the directory where ECE retrieves the XML files that contain configuration data (mediation specifications). Click Next.
After installation, when you load data into ECE, the loading utility loads configuration data from this directory.
In the Pricing Data Details window, enter the path or browse to the directory where ECE retrieves the XML files that contain pricing data. Click Next.
After installation, when you load data into ECE, the loading utility loads pricing data from this directory.
In the Customer Data Details window, enter the path or browse to the directory where ECE retrieves the XML files that contain customer data. Click Next.
After installation, when you load data into ECE, the loading utility loads customer data from this directory.
In the PayLoad Config File Details window, enter the path or browse to the directory where ECE retrieves the XML files that contain payloadconfig data. Click Next.
After installation, when you load data into ECE, the loading utility loads payloadconfig data from this directory.
CDR to generate only CDRs.
DIRECT to load data directly into BRM when BRM integration is configured.
CDR_DIRECT to load data directly into BRM and generate CDRs for audit purposes.
In the Cross-Reference Data Details window, enter the path or browse to the directory where ECE retrieves the XML files that contain cross-reference data. Click Next.
After installation, when you load data into ECE, the loading utility loads cross-reference data from this directory.
In the Persistence Data Details window, enter the path or browse to the directory into which the ECE BrmCdrPluginDirect Plug-in writes call detail record (CDR) files for rated events. Click Next.
The plug-in stores completed CDR files in this directory for BRM processing.
In the ECE Cluster Details window, enter the information in Table 5-28 and then click Next.
Table 5-28 ECE Cluster Details
Java Heap Settings
This setting applies to every node on the driver and server machines.
Cluster Name
Select this checkbox if you do not plan to set up an active-active disaster recovery system.
Note: If you select this option, skip to step 25.
Select this checkbox if you plan to set up an active-active disaster recovery system. This is selected by default.
In the ECE Active Active Clusters window, click Next.
In the Coherence Grid Security window, specify the machines allowed to be part of the Coherence cluster and the credentials required to access the cluster. Then click Next.
If you selected the Security disabled option, this window does not appear. Proceed to step 26.
In the Host Details in Comma Separated Format field, list the host names or IP addresses of all machines on which ECE nodes will reside. Separate each value with a comma.
In the Alias Name for Coherence Grid Security field, enter the account alias that defines the administrator for securing the Coherence cluster.
In the Password for the Alias field, enter the password used to access the cluster security key in the Coherence keystore (the ECE_home/oceceserver/config/server.jks file).
You use this password when enabling SSL.
In the KeyStore Credentials window, specify the information in Table 5-29 and then click Next.
Table 5-29 KeyStore Credentials
DName
The distinguished name used for Coherence cluster authentication.
Examples:
Or:
CN=Developer,OU=ECE
where:
The DName value is used as a command-line parameter for creating the server.jks keystore.
In the Oracle Wallet Details window, specify the ECE wallet details in Table 5-30 and then click Next.
Table 5-30 Oracle Wallet Details
The full path to the directory in which you want to store the Oracle wallet for ECE.
Wallet Password
Reenter the ECE wallet password for confirmation.
In the ECE Notification Queue Details window, enter the Java Message Service (JMS) credentials in Table 5-31 and then click Next.
ECE publishes notification events into this JMS queue (JMS topic), which external systems can use to obtain data for their own processing.
After you install ECE, you run a postinstallation script that creates the JMS queue (JMS topic) on the server.
Table 5-31 ECE Notification Queue Details
Port Number
User Name
Password
The password for logging in to the server. on which the JMS queue (JMS topic) resides.
Topic Name
Suspense Queue Name
The name of the suspense queue to which ECE sends failed notifications.
In the ECE Notification Queue SSL Details window, enter the information in Table 5-32, which is required to connect to the JMS destination that receives ECE notification events. Click Next.
Table 5-32 ECE Notification Queue SSL Details
Keystore password
Keystore location
In the Diameter Gateway Details window, enter the information in Table 5-33 and then click Next.
Table 5-33 Diameter Gateway Details
Origin Host
This is a unique identifier that you assign to your Diameter Gateway server on its host. It can be any string value.
Origin Realm
This is the signaling realm (domain) that you assign to your Diameter Gateway server.
The Diameter Gateway details you enter in this window apply to one Diameter Gateway node instance that listens to all network interfaces for Diameter messages. This configuration is suitable for basic testing immediately after installation.
For a distributed environment, you must add Diameter Gateway node instances to your topology and configure a unique network interface for each instance after installation. See the discussion about adding Diameter Gateway nodes for online charging in "ECE Postinstallation Tasks".
In the RADIUS Gateway Details window, enter the information in Table 5-34 and then click Next.
Table 5-34 RADIUS Gateway Details
Name
Port
Shared Secret
Disconnect Port
The port used to send RADIUS Disconnect-Request messages to the NAS to end active subscriber sessions.
The RADIUS Gateway details you enter in this window apply to a single RADIUS Gateway instance (node) that listens to all network interfaces for RADIUS messages. This configuration is suitable for basic testing immediately after installation.
For a distributed environment, you must add RADIUS Gateway instances (nodes) to your topology and configure a unique network interface for each instance after installation. See the discussion about adding RADIUS Gateway nodes in "ECE Postinstallation Tasks".
In the Third-Party Library Details window, enter the path or browse to the directory that contains the JAR files required by ECE and then click Next.
In the Installation Progress window, wait until the installation completes and then click Next.
The installer checks for all required software and displays errors if it detects any missing or unavailable components or if any connectivity issues occur.
Installing ECE by Using the Silent Installation
The silent installation procedure enables you to perform a non-interactive installation of ECE. You can use the silent installation to install ECE quickly on multiple systems.
Silent install mode does not use the GUI and runs in the background. In this mode, you use a response file template that contains a predefined set of values to install ECE. You can generate a response file that contains the parameters and values during the ECE GUI installation.
Creating a Response File
To create a response file:
Create a copy of the response file that was generated during the GUI installation. See "Installing ECE by Using the GUI Installation" for more information.
The GUI installer does not store passwords provided during installation in the response file. You must manually add the passwords after creating a copy of the response file.
You can create as many response files as needed.
Open the file in a text editor.
Modify the response file you copied by specifying the key-value information for the parameters you want in your installation.
The response file template contains guidelines and examples on how to enter the values in the parameters.
The installer treats incorrect context, format, and type values in a response file as if no value were specified.
Save and close the response file.
Performing a Silent Installation
To perform a silent installation:
Create a response file. See "Creating a Response File".
Copy the response file you created to the machine on which you are running the silent installation.
On the machine on which you are running the silent installation, go to the temp_dir directory to which you have downloaded the PDC server software pack, and run the following command:
Java_home/bin/java -jar jarfile -debug -invPtrLoc Inventory_home/oraInventory/oraInst.loc [parameter=value] -responseFile path -silent
where:
jarfile is the ECE installer file, for example ocece-16.26.0.0.0.0_generic.jar.
parameter is the name of an installation parameter.
value is the value of the installation parameter.
path is the absolute path to the response file.
For example:
Java_home/bin/java -jar ocece-16.26.0.0.0.0_generic.jar -debug -invPtrLoc Inventory_home/oraInventory/oraInst.loc INSTALL_TYPE=Complete -responseFile /tmp/oracle.communications.ocece.ece.rsp -silent
The installation runs silently in the background.
The ECE installer checks for all required software and writes errors to a log file if it detects any missing or unavailable components or if any connectivity issues occur.
