62 pin.conf Reference
Learn how to use pin.conf settings to configure Oracle Communications Billing and Revenue Management (BRM).
Use pin.conf files to configure connections between system components, and to configure business logic operations, such as how billing works.
The pin.conf files are text files, and can be edited by using any text editor. Each entry in a pin.conf file includes instructions on how to configure it.
Note the following points when editing pin.conf files:
pin.conf files are usually stored in the same directory as the utility or component that uses them. For example, the pin.conf file that you edit to configure a CM is stored in BRM_home/sys/cm. This file is frequently referred to as "the CM pin.conf file."
In some cases, a pin.conf file might be stored in a directory that is not the same as the directory that contains the utility. In that case, you need to run the utility from the directory that contains the pin.conf file.
You can remove or comment out entries in a pin.conf file. In that case, the default value is used. If an entry is not in the file, you can add it.
Topics in this document:
See also "Business Parameter Reference".
Account Creation pin.conf Entries
Table 62-1 lists the account creation pin.conf entries.
Table 62-1 Account Creation pin.conf Entries
| Name | Program | Description | pin.conf File | Implementation |
allow_active_service_with_inactive_account |
fm_cust |
Specifies whether services can be activated (during a SET_STATUS operation) if the account or bill unit is inactive. |
CM |
Cached by the Connection Manager (CM). Restart the CM after changing this entry. |
config_dir |
fm_cust_pol |
Specifies the location of the ISP configuration data, which is stored in the default.config file. Used by the PCM_OP_CUST_POL_GET_CONFIG policy opcode. |
CM |
The new value becomes effective immediately and applies to the next account created. The CM does not need to be restarted. |
country |
fm_cust_pol |
Specifies the default country for new accounts (default is USA). |
CM |
currency |
fm_cust_pol |
Specifies the default currency for new accounts. |
CM |
domain |
fm_cust_pol |
Specifies the email domain assigned to customers during account creation. |
CM |
new_account_welcome_msg |
fm_cust_pol |
Specifies whether the system should send the default welcome message on account creation. |
CM |
welcome_dir |
fm_cust_pol |
Specifies the location of the welcome message sent to customers after account creation. |
CM |
Accounts Receivable pin.conf Entries
Table 62-2 lists the Accounts Receivable pin.conf entries.
Table 62-2 Accounts Receivable pin.conf Entries
calc_cycle_from_cycle_start_t |
fm_bill |
Specifies whether to calculate charge offer fees based on the charge offer's purchase date (PIN_FLD_CYCLE_START_T). See "Calculating Cycle Fees for Backdating" in BRM Configuring and Running Billing. |
CM |
This value is read by the utility when it runs. You do not need to restart the CM. |
item_search_batch |
fm_bill |
Specifies the number of items returned by a step search. |
CM |
overdue_tolerance |
fm_bill |
Specifies how BRM treats amounts applied to the item when they are less than the amount due as a result of euro and Economic and Monetary Union (EMU) conversions. See "Rounding Errors for Overpayments and Underpayments" in BRM Managing Customers. |
CM |
underdue_tolerance |
fm_bill |
Specifies how BRM treats amounts applied to the item when they are more than the amount due as a result of euro and EMU conversions. See "Rounding Errors for Overpayments and Underpayments" in BRM Managing Customers. |
CM |
Cached by the CM. Restart the CM after changing this entry. |
Billing pin.conf Entries
Table 62-3 lists the Billing pin.conf entries.
Table 62-3 Billing pin.conf Entries
advance_bill_cycle |
fm_bill |
Sets the first billing date to be the day after account creation. See "Setting the First Billing Cycle to the Day after Account Creation" in BRM Configuring and Running Billing. |
CM |
attach_item_to_event |
fm_act |
Specifies how BRM assigns event and service combinations to bill items. See "About Using Event and Service Combinations to Assign Bill Items" in BRM Configuring and Running Billing. |
CM |
billing_segment_config_refresh_delay |
fm_cust |
Specifies how often data in the cached /config/billing_segment object is automatically refreshed from the database. See "Updating Billing Segments" in BRM Configuring and Running Billing. |
CM |
custom_bill_no |
fm_bill |
Specifies the accounting cycle (first or last) in which to assign a bill number to a bill in a multi-month billing cycle. See "Specifying When to Apply Custom Bill Numbers" in BRM Configuring and Running Billing. |
CM Billing utilities |
cycle_delay_use_special_days |
fm_bill |
Sets the delayed cycle start date to the 1st of the following month for all bundles purchased on the 29th, 30th, or 31st. See "Setting Delayed Cycle Start Dates to the 29th, 30th, or 31st" in BRM Configuring and Running Billing. |
deadlock_retry_count |
fm_bill_accts |
Specifies the number of retries to attempt when a deadlock occurs during a billing run. See "Specifying the Number of Retries in Case of a Deadlock". |
pin_billd |
This entry is read by the utility when it runs. You do not need to restart the CM. |
delay_cycle_fees |
fm_bill |
In systems set up for delayed billing, specifies when to apply cycle forward fees and cycle rollovers (during partial billing or final billing). See "Specifying When to Apply Cycle Forward Fees and Cycle Rollovers" in BRM Configuring and Running Billing. |
CM |
delta_step |
pin_billd |
Reduces contention at the database level during billing. |
pin_billd |
enable_30_day_proration |
fm_bill |
Allows you to base monthly proration on 30-day months rather than the actual number of days in a billing cycle. This is often needed when working in parallel with older legacy billing systems. See "About 30-Day-Based Proration" in BRM Configuring and Running Billing. |
CM |
enforce_billing |
pin_bill_accts |
Enforces partial billing from the billing application inside the billing delay interval. See "Enforcing Partial Billing in the Billing Delay Interval" in BRM Configuring and Running Billing. |
pin_billd |
group_by_account |
pin_deferred_act |
Specifies to use one thread to process scheduled actions for one account. |
pin_billd |
open_item_actg_include_prev_total |
fm_bill |
Includes previous bill totals in the pending receivable value calculated during billing for accounts that use open item accounting. See "Including Previous Balances in the Current Amount Due in Open Item Accounting" in BRM Configuring and Running Billing. |
CM |
Cached by the CM. Restart the CM after changing this entry |
purchase_fees_backcharge |
fm_bill |
Specifies which cycle (current or next) to apply the deferred purchase fees to during billing when the deferred time coincides with the billing time. See "Specifying Which Billing Cycle to Assign to Deferred Purchase Fees" in BRM Configuring and Running Billing. |
CM |
rating_longcycle_roundup_flag |
fm_rate |
Enables rounding up for the long cycle. |
CM |
unset_error_status |
pin_bill_accts |
Sets billing status in a bill unit when billing errors occur. See "Setting the Bill Unit Status When Billing Errors Occur" in BRM Configuring and Running Billing. |
pin_billd |
use_number_of_days_in_month |
fm_bill |
Specifies how to calculate proration when a cycle charge offer is purchased or canceled. See "Calculating Prorated Cycle Fees" in BRM Configuring and Running Billing. |
CM |
Collections pin.conf Entries
Table 62-4 lists the Collections pin.conf entries.
Table 62-4 Collections pin.conf Entries
account_search_batch |
fm_collections |
Specifies the number of bill units to retrieve in collections step searches. See "Setting the Number of Bill Units Retrieved during Step Searches" in BRM Collections Manager. |
CM |
collections_action_dependency |
fm_collect |
Creates dependencies between collections actions in a collections scenario. See "Creating Dependencies between Collections Actions in a Scenario" in BRM Collections Manager. |
CM |
email_body |
pin_collections_send_dunning pin_inv_send |
Specifies the path to a text file containing a customized message. See "Specifying a File for the Email Body" in BRM Collections Manager. |
pin_collections pin_inv |
The new value is effective immediately. You do not need to restart the CM. |
execute_all_actions |
fm_collections |
Specifies whether to run all actions, including actions due before the date on which pin_collections_process is run for the first time, or only to run actions due after the date on which pin_collections_process is run for the first time. See "Performing Scheduled Collections Actions after Reinstalling Collections Manager" in BRM Collections Manager. |
CM |
minimum_due |
pin_collections_process |
Specifies the minimum overdue balance that a bill unit must have to qualify for collections. See "Setting the Minimum Overdue Balance to Process" in BRM Collections Manager. |
pin_collections |
Customer Management pin.conf Entries
Table 62-5 lists the Customer Management pin.conf entries.
Table 62-5 Customer Management pin.conf Entries
cycle_arrear_proration |
fm_rate |
Specifies when to prorate cycle arrears fees, at purchase or at cancellation. See "Proration for Special Cases" in BRM Configuring and Running Billing. |
CM |
em_db |
fm_delivery |
Specifies the Email Data Manager database number. See "Configuring the Email Data Manager" in BRM Managing Customers. |
CM |
intro_dir |
fm_cust_pol |
Specifies the location of the introductory message that allows a customer to confirm account creation. |
CM |
Discounting pin.conf Entries
Table 62-6 lists the Discounting pin.conf entries.
Table 62-6 Discounting pin.conf Entries
rollover_zeroout_discounts |
fm_rate |
Zeroes-out the positive bucket. See "Configuring the Start and End Times for Discount Sharing" in BRM Managing Customers. |
CM |
General Ledger pin.conf Entries
Table 62-7 lists the General Ledger pin.conf entries.
Table 62-7 General Ledger pin.conf Entries
gl_segment |
fm_cust_pol |
Specifies the default G/L segment for an account during account creation. See "Changing the Default G/L Segment" in BRM Collecting General Ledger Data. |
CM |
transaction_grouping |
pin_ledger_report |
Specifies how many A/R accounts to group in a single transaction for ledger_report to run. See "Setting the Number of Paying Accounts per G/L Report" in BRM Collecting General Ledger Data. |
pin_billd |
Invoicing pin.conf Entries
Table 62-8 lists the Invoicing pin.conf entries.
Table 62-8 Invoicing pin.conf Entries
database |
pin_inv_accts pin_inv_export pin_inv_send pin_inv_upgrade |
Specifies the database schema to which the following utilities should connect:
See "Configuring the Invoice pin.conf for Multiple Database Schemas" in BRM Designing and Generating Invoices. |
pin_inv |
export_dir |
pin_inv_export |
Specifies the path to the invoice directory. See "Exporting Invoices" in BRM Designing and Generating Invoices. |
pin_inv |
from |
pin_inv_send |
Specifies the e-mail address of the sender. See "pin_inv_send" in BRM Designing and Generating Invoices. |
pin_inv |
html_template |
pin_inv_pol |
Specifies the HTML template file to use to generate invoices. |
CM |
invoice_db |
pin_inv_export pin_inv_send |
Specifies the database number for the schema. See "Configuring BRM to Use a Separate Invoice Database Schema" in BRM Designing and Generating Invoices. |
pin_inv |
invoice_dir |
fm_bill |
Specifies the directory where invoices are stored. See "Exporting Invoices" in BRM Designing and Generating Invoices. |
CM |
invoice_fmt |
Specifies the invoice format. See "Exporting Invoices" in BRM Designing and Generating Invoices. |
pin_inv |
inv_perf_features |
fm_inv |
Improves performance by removing unnecessary details from your invoices. |
CM |
sender |
fm_cust_pol pin_inv_send |
Specifies the name of the e-mail sender. See "pin_inv_send" in BRM Designing and Generating Invoices. |
CM pin_inv |
service_centric_invoice |
fm_inv_pol |
Enables service-centric invoicing. |
CM |
show_rerate_details |
fm_inv_pol |
Specifies whether to display shadow adjustment details on invoices. See "Including Shadow Event Adjustment Details in Invoices" in BRM Designing and Generating Invoices. |
CM |
subject |
pin_inv_send |
Specifies the subject of the e-mail. See "pin_inv_send" in BRM Designing and Generating Invoices. |
pin_inv |
Payments pin.conf Entries
Table 62-9 lists the Payments pin.conf entries.
Table 62-9 Payments pin.conf Entries
cc_validate |
fm_pymt_pol |
Specifies whether to validate a customer's credit card information during account creation. See "Validating Credit Cards at Account Creation" in BRM Managing Customers. |
CM |
config_payment |
fm_pymt |
Specifies the database and POID of the /config/payment object. Change this value if you create a custom /config/payment object. |
CM |
dd_validate |
fm_pymt_pol |
Specifies whether to validate a customer's direct debit (debit card) information during account creation. |
CM |
merchant |
fm_cust_pol |
Specifies the merchant to receive money collected during credit-card processing. See "Specifying Merchant IDs and Merchant Numbers" in BRM Configuring and Collecting Payments. |
CM |
minimum |
pin_billd |
Specifies the minimum balance for retrieving accounts for credit card collection. Use this entry to set a minimum threshold for the amount due on an account when searching for accounts for collection. See "Specifying the Minimum Payment to Collect" in BRM Configuring and Running Billing. |
pin_billd |
The new value becomes effective immediately. You do not need to restart the CM. |
validate_acct |
fm_pymt_pol |
Allows use of the customer's credit card on an account different from the root account. See "Specifying the Account That Records Credit Card Validations" in BRM Managing Customers. |
CM |
Pricing and Rating pin.conf Entries
Table 62-10 lists the Pricing and Rating pin.conf entries.
Table 62-10 Pricing and Rating pin.conf Entries
delay |
pin_rerate |
Specifies the delay for rerating jobs. |
pin_rerate |
fm_offer_profile_cache |
cm_cache |
Specifies the attributes of the CM cache for offer profiles. Note: This entry is mandatory for policy-driven charging. See "Improving Performance for Loading Large Product Offerings". |
CM |
fm_price_cache_beid |
cm_cache |
Specifies attributes of the CM cache for the size of balance element IDs (BEID). See "Improving Performance for Loading Large Product Offerings". |
CM |
fm_price_prod_provisioning_cache |
cm_cache |
Specifies the attributes of the CM cache for the size of charge offer provisioning tags. See "Improving Performance for Loading Large Product Offerings". |
CM |
log_refresh_product |
fm_rate |
Specifies whether to log product offering changes. You can use the log entries to generate notifications about such changes. See "Logging Changes to Product Offerings" in PDC Creating Product Offerings. |
CM |
rating_max_scale |
fm_rate |
Specifies the precision level of decimal values. See "Changing the Precision of Rounded and Calculated Values". |
CM |
rating_quantity_rounding_scale |
fm_rate |
Specifies the precision of rounded values. See "Changing the Precision of Rounded and Calculated Values". |
CM |
rating_timezone |
fm_rate |
Specifies the server time zone. |
CM |
refresh_product_interval |
fm_rate |
Specifies the interval in which product offerings are refreshed in cache memory. See "Setting the Interval for Checking for Product Offering Changes". |
CM |
timezone_file |
fm_rate |
Specifies the location of the timezones.txt file. |
CM |
update_interval |
fm_zonemap_pol |
Specifies an interval for revising the value map. See "Setting the Interval for Checking for Product Offering Changes". |
CM |
validate_deal_dependencies |
fm_utils |
Specifies whether to validate the bundle prerequisites and mutually exclusive relations. See "Configuring Bundle Dependencies" in BRM Managing Customers. |
CM |
Revenue Assurance pin.conf Entries
Table 62-11 lists the Revenue Assurance pin.conf entries.
Table 62-11 Revenue Assurance pin.conf Entries
writeoff_control_point_id |
fm_process_audit |
Changes the control point ID. See "Renaming the Control Point for Collecting Data from Usage Write-Offs" in BRM Collecting Revenue Assurance Data. |
CM |
Service Lifecycle Management pin.conf Entries
Table 62-12 lists the Service Lifecycle Management pin.conf entries.
Table 62-12 Service Lifecycle Management pin.conf Entries
fm_cust_lifecycle_config_cache |
cm_cache |
Specifies attributes of the lifecycle cache. This cache is used by the Service Lifecycle Management feature. See "Managing Custom Service Life Cycles" in BRM Managing Customers. |
CM |
fm_cust_statemap_config_cache |
cm_cache |
Specifies attributes of the statemap cache. This cache is used by the Service Lifecycle Management feature. See "Managing Custom Service Life Cycles" in BRM Managing Customers. |
CM |
Services Framework pin.conf Entries
Table 62-13 lists the Services Framework pin.conf entries.
Table 62-13 Service Framework pin.conf Entries.
agent_return |
fm_tcf |
Specifies the provisioning status when provisioning is simulated. |
CM |
commit_at_prep |
dm_provision |
Specifies whether to send the payload to the agent at PREP_COMMIT time and not to send anything at COMMIT time. |
dm_prov_telco |
connect_retries |
dm_provision |
Specifies the number of times dm_provision attempts to connect to the Infranet agent on connection failure. See "Configuring the Provisioning Data Manager" in BRM Telco Integration. |
dm_prov_telco |
connect_retry_interval |
dm_provision |
Specifies how many seconds to wait before retrying to connect to the Infranet agent on connection failure. See "Configuring the Provisioning Data Manager" in BRM Telco Integration. |
dm_prov_telco |
prov_db |
fm_tcf |
Specifies the number of the database to which provisioning connects to send the service order. See "Connecting the Connection Manager to the Provisioning Data Manager" in BRM Telco Integration. |
CM |
prov_ptr |
dm_provision |
Specifies where to find the Provisioning Data Manager. See "Configuring the Provisioning Data Manager" in BRM Telco Integration. |
dm_prov_telco |
prov_timeout |
dm_provision |
Specifies the length of time to wait to receive a complete response from the provisioning agent. See the instructions in the pin.conf file. |
dm_prov_telco |
provisioning_enabled |
fm_tcf |
Enables charge offer provisioning. |
CM |
simulate_agent |
fm_tcf |
Creates a response and updates the service order. |
CM |
Tax Calculation pin.conf Entries
Table 62-14 lists the Tax Calculation pin.conf entries.
Table 62-14 Tax Calculation pin.conf Entries
include_zero_tax |
fm_rate |
Specifies whether to include zero tax amounts in the tax jurisdictions for the event's balance impacts. See "Reporting Zero Tax Amounts" in BRM Calculating Taxes. |
CM |
provider_loc |
fm_rate_pol |
Specifies the city, state, ZIP code, and country where services are provided for taxation. See "Defining a Default Ship-From Locale" in BRM Calculating Taxes. |
CM |
The new value becomes effective immediately and all subsequent tax calculations use the new address. You do not need to restart the CM. |
tax_now |
fm_ar |
Specifies when tax is calculated for account-level adjustments (at the end of billing or at the time of adjustment). See "Configuring the Default Tax Method for Account Adjustments" in BRM Calculating Taxes. |
CM |
tax_return_juris |
fm_rate |
Specifies whether to summarize taxes by jurisdiction or to itemize taxes. See "Itemizing or Summarizing Taxes for Each Jurisdiction Level" in BRM Calculating Taxes. |
CM |
tax_return_loglevel |
fm_rate |
Specifies how to log messages returned from the taxation DM. |
CM |
tax_reversal_with_tax |
fm_ar |
Specifies whether to apply a tax reversal for an adjustment, dispute, or settlement |
CM |
tax_supplier_map |
fm_rate |
Specifies the location of the tax_supplier_map file. See "Allowing Your Sales and Use Tax Software to Determine Tax Supplier Data" in BRM Calculating Taxes. |
tax_valid |
fm_cust_pol |
Specifies how to validate the state and zip code of the billing address during account creation. See "Validating Customer Addresses" in BRM Calculating Taxes. |
CM |
taxation_switch |
fm_bill |
Enables taxation. See "Enabling and Disabling Taxation Globally" in BRM Calculating Taxes. |
CM |
taxcodes_map |
fm_rate |
Specifies the location of the taxcodes_map file. |
em_group |
TBA |
Specifies the external manager group (tax_gateway) used by CM to route taxation-related requests to the Taxation Gateway |
CM |
TBA |
| em_pointer |
TBA |
Specifies the network location (host and port) of the tax_gateway external manager used by CM to reach the Taxation Gateway |
CM |
TBA |
CM System Administration pin.conf Entries
Table 62-15 lists the CM system administration pin.conf entries.
Table 62-15 CM pin.conf Entries
cm_cache_space |
cm |
(Optional) Reserves the cache memory for all the Facilities Modules. The default is 6291456. The value is always in multiples of 1024. |
cm_data_dictionary_cache |
cm_cache |
Increases the size of the CM cache for the data dictionary. See "Increasing the Size of the CM Cache for the Data Dictionary" in BRM Developer's Guide. |
cm_data_file |
cm |
Specifies the name and location of the shared memory file that caches global information for the CM. See the instructions in the CM pin.conf file. |
cm_cache |
Loads all offer_profile objects at initialization of fm_offer_profile library. |
cm_logfile |
cm |
Specifies the full path to the log file used by the CM. |
cm_logformat |
cm |
Specifies which PINLOG format to use. |
cm_max_connects |
cm |
Specifies the maximum number of client connections to the CM. |
cm_name |
cm |
Specifies the name of the computer where the CM runs. |
cm_opcode_stats |
cm |
Specifies whether to collect statistics about CM opcode performance. |
cm_ports |
cm |
Specifies the port number of the computer where the CM runs. |
cm_timeout |
cm |
Specifies the time-out value for receiving the next opcode request from an application. |
creation_logging |
fm_cust |
Determines whether to log nondollar events. See "Logging Noncurrency Events" and "Improving Connection Manager Performance". |
dm_attributes |
cm |
Specifies attributes associated with a particular database. |
dm_pointer |
cm |
Specifies where to find one or more DMs for the BRM database. |
enable_pcm_op_call_stack |
dm |
Specifies whether PCM_OP_CALL_STACK is printed in the cm.pinlog file after each opcode from a nap (Network Application Program) is completed. |
enable_preferences_enrichment |
fm_publish |
Specifies whether to enrich business events with your customers' preferences before they are sent to an external notification application. See "Enabling Notification Enrichment" in BRM Managing Customers. |
fetch_size |
pin_billd pin_mta |
Specifies the number of records to retrieve from the database in a batch and cache in system memory for processing by the utility. See "Tuning the Account Cache Size for Billing Utilities (fetch_size)" and "Tuning the Account Cache Size for Invoice Utilities (fetch_size)". |
group_children_fetch |
fm_bill |
Used to perform a step search for child accounts in groups when the parent group contains many members. See "Filtering Search Results". |
group_members_fetch |
fm_bill |
Used to perform a step search for members of the group sharing object when the parent group contains many members. See "Filtering Search Results". |
ip |
N/A |
Specifies the IP address of the devices managed by IP Address Manager. |
item_fetch_size |
fm_bill |
Used to perform a step search for items. See "Filtering Search Results". |
login_audit |
cm |
Creates the session event's object for each client application. |
max_pcm_op_call_stack_entries |
dm |
Specifies the number of entries allocated for PCM_OP_CALL_STACK. |
monitor |
pin_mta |
Specifies the path and name of a shared memory map file used by the pin_mta_monitor utility. |
passwd_age |
cm |
Specifies the number of days after which the password expires. |
pcp_validate_string_fields_as_utf8 |
cm |
Disables the UTF8 validation process in BRM. |
prefs_enabled_publisher_list |
fm_publish |
Specifies whether to enrich business events with your customers' preferences before they are sent to specific publishers. See "Enabling Notification Enrichment" in BRM Managing Customers. |
prefs_phone_no_location |
fm_publish |
Specifies where BRM can find a customer's MSIDN number. See "Enabling Notification Enrichment" in BRM Managing Customers. |
primary_database |
N/A |
Specifies the primary database schema. See the instructions in the pin.conf file. |
primary_db |
cm |
Specifies the primary database schema. See "Completing Configuration of the Primary Installation System" in BRM Installation Guide. |
rps_no_reorder |
fm_price |
Specifies whether to reorder rate plan selectors before committing them to the database.
See "Maintaining the Order of Rate Plan Selectors" in BRM Setting Up Pipeline Pricing. |
sample_handler_logfile |
N/A |
Specifies the full path to the log file for the Batch Controller. See "Configuring the Batch Controller" and "Customizing SampleHandler". |
support_multiple_so |
fm_tcf |
Specifies whether Services Framework provisioning can make in-flight changes to service orders. |
DM System Administration pin.conf Entries
Table 62-16 lists the DM system administration pin.conf entries.
Table 62-16 DM pin.conf Entries
config_dir |
fm_cust_pol |
Specifies the location of the ISP configuration data. Used by the PCM_OP_CUST_POL_GET_CONFIG policy opcode. See "Sending Account Information to Your Application When an Account Is Created" in BRM Managing Customers. |
crypt |
NA |
Associates a four-byte tag with an encryption algorithm and secret key combination. See "Configuring the Data Manager for Oracle ZT PKI Encryption" in BRM Developer's Guide. |
dd_write_enable_fields |
dm |
Specifies whether this DM can create fields in the data dictionary. See "Modifying the pin.conf file to Enable Changes" in BRM Developer's Guide. |
dd_write_enable_objects |
dm |
Specifies whether this DM can edit, create, and delete custom storable classes in the data dictionary. See "Modifying the pin.conf file to Enable Changes" in BRM Developer's Guide. |
dd_write_enable_portal_objects |
dm |
Specifies whether this DM can delete predefined BRM storable classes and add and delete fields in one of those classes. See "Modifying the pin.conf file to Enable Changes" in BRM Developer's Guide. |
dd_write_enable_types |
dm |
Specifies whether this DM can edit, create, and delete custom object type names in the data dictionary. |
dm_bigsize |
dm |
Specifies the size of the DM shared memory. |
dm_debug |
dm |
Specifies the debugging information to send to the log file. See the instructions in the pin.conf file. |
dm_in_batch_size |
dm |
Specifies the number of objects to retrieve from subtables (arrays or substructs) in a search query. See the instructions in the pin.conf file. |
dm_init_be_timeout |
dm |
Specifies the amount of time, in seconds, for the first DM backend to start before the DM times out. See "Setting How Long the DM Waits for the Background Startup Process to Complete". |
dm_logfile |
dm |
dm_max_per_fe |
dm |
Specifies the maximum number of connections for each front end. See the instructions in the pin.conf file. |
dm_n_be |
dm |
Specifies the number of back ends the program creates and uses. |
dm_n_fe |
dm |
Specifies the number of front ends the program creates and uses. |
dm_port |
dm |
Specifies the port number for this DM. |
dm_process_name |
dm |
Specifies a name for the dm_oracle process. When this entry is set, the process name has to be prefixed to the sm_id entry in this file and the sm_pw key in the Oracle client wallet. This is done to configure unique database credentials for multiple dm_oracle processes. If this entry is not set, dm_oracle uses the default sm_id and sm_pw keys. See "Using Oracle Wallet". |
dm_restart_children |
dm |
Specifies whether to replace child processes. |
dm_restart_delay |
dm |
Specifies the interval delay when DM back ends are spawned and respawned. See "Customizing BRM Multithreaded Client Applications" and "Configuring Your Multithreaded Application" in BRM Developer's Guide. |
dm_sequence_cache_size |
dm |
(Optional) Specifies the number of Portal object IDs (POIDs) to be cached when each instance of a DM is started. The default is 1000. The POIDs are cached in the memory when the DM is started. Whenever a database object is created, the DM uses the POIDs instead of accessing the database each time. |
dm_shmsize |
dm |
Specifies the size of the shared-memory segment shared between the front and back ends for this BRM process. |
dm_sql_retry |
dm |
Specifies the number of times an SQL statement is retried if the ORA-01502: index 'PINPAP.I_EVENT_ITEM_OBJ__ID' or partition of such index is in unusable state error occurs. Note: This is not a mandatory parameter in the pin.conf file. The default behavior is not to try running the SQL statement if the error occurs. |
dm_trans_be_max |
dm |
Specifies the maximum number of back ends that can be used for processing transactions. |
dm_trans_timeout |
dm |
dm_xa_trans_timeout_in_secs |
dm |
Specifies how long, in seconds, an extended architecture (XA) transaction remains in an active state. By default, successfully prepared XA transactions expire in BRM if a commit request is not received within one hour after the transaction opens. This timeout is used only if the application server XA transaction timeout is not specified. The minimum value is 10, and the maximum value is 5184000 (60 days). The default is 3600 (1 hour). See "Changing the XA Transaction Timeout Period" in BRM JCA Resource Adapter. |
extra_search |
dm |
Specifies whether to perform an extra search count (*) on subtables for optimal memory allocation. See "Optimizing Memory Allocation during Database Searches". |
dm |
sm_database |
dm |
Specifies the database alias name. |
sm_id |
dm |
Specifies the database user name that the DM uses to log in to the BRM database. This entry is set when you install BRM, but it can be changed. |
sm_oracle_ddl |
dm |
Specifies whether to use Data Definition Language (DDL) when object types are updated in the data dictionary tables. See "Using DDL When Updating the Data Dictionary Tables" in BRM Developer's Guide. |
sm_pw |
dm |
Specifies the password for the user specified in the sm_id entry. See "Configuring the Data Manager for Oracle ZT PKI Encryption" in BRM Developer's Guide. |
stmt_cache_entries |
dm |
Specifies the maximum number of Oracle statement handles to cache to improve performance. |
Enterprise Application Integration (EAI) Manager pin.conf Entries
Table 62-17 lists the EAI Manager pin.conf entries.
Table 62-17 EAI Manager pin.conf Entries
dm_http_100_continue |
dm |
Specifies whether the DM waits for and reads a 100 Continue response. See "Configuring EAI Manager to Publish to an HTTP Port" in BRM Developer's Guide. |
dm_http_agent_ip |
dm |
Specifies a pointer to the HTTP agent. See "Configuring EAI Manager to Publish to an HTTP Port" in BRM Developer's Guide. |
dm_http_delim_crlf |
dm |
Specifies the HTTP server dependent delimiter used in the header. See "Configuring EAI Manager to Publish to an HTTP Port" in BRM Developer's Guide. |
dm_http_header_send_host_name |
dm |
Specifies that DM will send the host name as part of the header. See "Configuring EAI Manager to Publish to an HTTP Port" in BRM Developer's Guide. |
dm_http_read_success |
dm |
Specifies whether the DM waits for and reads a 20x success response. See "Configuring EAI Manager to Publish to an HTTP Port" in BRM Developer's Guide. |
dm_http_url |
dm |
(Optional) Specifies complete URL of the HTTP server. See "Configuring EAI Manager to Publish to an HTTP Port" in BRM Developer's Guide. |
eai_pointer |
cm |
Specifies where to find the EM that provides the opcode for the EAI Manager. See "Configuring the EAI DM" in BRM Developer's Guide. |
em_eai_group |
cm |
Specifies the member opcode in a group provided by the EAI Manager. |
em_group |
cm |
Specifies a member opcode in a group of opcodes provided by an EM. See "Configuring the Connection Manager for EAI" in BRM Developer's Guide. |
enable_publish |
fm_publish |
Enables publishing of business events by using the EAI Manager. See "Configuring the Connection Manager for EAI" in BRM Developer's Guide. |
plugin_name |
dm |
Specifies a pointer to a shared library that contains the code that implements the required interfaces of dm_eai as defined in dm_eai_plugin.h. See "Configuring the EAI DM" in BRM Developer's Guide. |
Multithreaded Application (MTA) Framework pin.conf Entries
Table 62-18 lists the MTA Framework pin.conf entries.
Table 62-18 MTA Framework pin.conf Entries
children |
pin_inv_accts pin_inv_export pin_inv_send pin_inv_upgrade pin_mta |
Specifies the number of worker threads spawned to perform the specified work. See "Tuning the Number of Children for Billing Utilities" and "Setting the Number of Children for Invoice Utilities". |
cm_login_module |
cm |
Specifies the protocol for verifying applications that try to log in to the CM. |
fetch_size |
pin_mta |
Specifies the number of records to retrieve from the database in a batch and cache in system memory for processing by the utility. See "Tuning the Account Cache Size for Billing Utilities (fetch_size)". |
hotlist |
pin_mta |
Specifies the path and file name of the hotlist file. |
log_rotate_by_size_megabytes |
See "C-Based Applications and Utilities that Support Log Rotation" for more information on the program list. |
Specifies the size-based log rotation in megabytes. The value is an integer. See "Rotating Log Files for C/C++Based Applications" for more information. |
log_rotate_by_days_at_time |
See "C-Based Applications and Utilities that Support Log Rotation" for the list of applications. |
Specifies the number of days and time for time-based rotation, in the format frequency HH:MM, where frequency is an integer indicating the number of days, HH is an integer between 0 and 23 indicating the hour at which the rotation should take place, and MM is an integer between 0 and 59 indicating the minute at which the rotation should take place. See "Rotating Log Files for C/C++Based Applications" for more information. |
log_rotate_backup_dir |
Specifies the location in which the backup files will be stored during the log rotation cycle. You need to enter the full directory path. See "Rotating Log Files for C/C++Based Applications" for more information. |
log_rotate_file_name_format |
Specifies the time format for the log rotation in the format format append, where format is a format specifier compatible with strftime() and append is either 1 indicating that the system should append the end time to the file name, or 0 indicating the system should not append it. Note: The append parameter is considered only when day-based rotation is enabled. See "Rotating Log Files for C/C++Based Applications" for more information. |
logfile |
pin_mta |
Specifies the name and location of the log file to record debug, warning, and error messages of running MTA-based applications. See "About the BRM MTA Framework" in BRM Developer's Guide. |
login_name |
nap |
Specifies the user login name. |
login_pw |
nap |
Specifies the login password. |
login_type |
nap |
Specifies whether a login name and password are required. |
loglevel |
pin_mta |
Specifies how much information is recorded in the log specified by the logfile parameter in the pin.conf file. |
max_errs |
pin_mta |
Specifies the maximum number of errors allowed in the application. |
max_time |
pin_mta |
Specifies the maximum time, measured from application start time, for job processing before the application exits. |
multi_db |
pin_mta |
Specifies whether the application works with a BRM multischema system. See "Using Multithreaded Applications with Multiple Database Schemas" in BRM Developer's Guide. |
per_batch |
pin_mta |
Specifies the number of account objects processed by each worker thread in batch mode. |
per_step |
pin_mta |
Specifies how much data to store in dm_oracle when the utility is performing a step search. See "Setting the Batch Size for Invoice Utilities (per_step)". |
respawn_threads |
pin_mta |
Specifies whether to respawn worker threads if they exit because of an error. |
retry_mta_srch |
pin_mta |
Retries MTA searches when an insufficient memory error occurred. |
return_worker_error |
pin_mta |
Specifies whether to return an error code when there is an error in any of the threads. |
userid |
N/A |
Specifies the CM for logging into the Data Manager. |
Utility pin.conf Entries
Table 62-19 lists the utility pin.conf entries.
Table 62-19 Utility pin.conf Entries
testnap |
