6 CNC Console Alerts
This section provides information about CNC Console Alerts.
Alert file is present in the Scripts directory.occncc_csar_<version>.zip can be
downloaded from MOS. Unzip the file to get occncc_alertrules_<version>.yaml
file.
- Review the occncc_alerting_rules_promha_<version>.yaml file and edit the value of the parameters in the occncc_alerting_rules_promha_<version>.yaml file (if needed to be changed from default values) before configuring the alerts.
- kubernetes_namespace is configured as kubernetes namespace in which CNCC is deployed. Default value is cncc. Update the occncc_alertrules_<version>.yaml file to reflect the correct CNCC kubernetes namespace.
Two sample Alert files are provided, one for supporting CNE 1.8 or lower and second one supporting CNE Prometheus HA.
- CNC Console Alert Rules file: occncc_alertrules_<version>.yaml file.
- CNC Console Alert Rules file supporting CNE Prometheus HA: occncc_alerting_rules_promha_<version>.yaml file.
6.1 CNC Console IAM Alerts
This section provides information about CNC Console IAM Alerts.
6.1.1 CnccIamTotalIngressTrafficRateAboveMinorThreshold
Table 6-1 CnccIamTotalIngressTrafficRateAboveMinorThreshold
| Field | Details |
| Trigger Condition | The total CNCC IAM Ingress Message rate has crossed
the configured minor threshold of 700 TPS.
Default value of this alert trigger point in occncc_alertrules_<version>.yamlis when CNCC IAM Ingress Rate crosses 70 % of 1000 (Maximum ingress request rate) |
| Severity | Minor |
| Alert details provided |
Description: CNCC IAM Ingress traffic Rate is above the configured minor threshold i.e. 700 requests per second (current value is: {{ $value }}) For CNE with Prometheus HA Operator: summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Traffic Rate is above 70 Percent of Max requests per second(1000)' For CNE without Prometheus Operator : summary: 'namespace: {{$labels.kubernetes_namespace}}, podname: {{$labels.kubernetes_pod_name}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Traffic Rate is above 70 Percent of Max requests per second(1000)' |
| OID used for SNMP Traps | 1.3.6.1.4.1.323.5.3.51.1.2.7001 |
| Metric Used | oc_ingressgateway_http_requests_total |
| Resolution |
The alert is cleared either when the total Ingress Traffic rate falls below the Minor threshold or when the total traffic rate crosses the Major threshold, in which case the CnccIamTotalIngressTrafficRateAboveMajorThreshold alert is raised. Note: The threshold is configurable in the occncc_alertrules_<version>.yaml file. Steps:
6.1.2 CnccIamTotalIngressTrafficRateAboveMajorThreshold
Table 6-2 CnccIamTotalIngressTrafficRateAboveMajorThreshold
| Field | Details |
| Trigger Condition |
The total CNCC IAM Ingress Message rate has crossed the configured major threshold of 800 TPS. Default value of this alert trigger point ino ccncc_alertrules_<version>.yaml is when CNCC IAM Ingress Rate crosses 80 % of 1000 (Maximum ingress request rate) |
| Severity | Major |
Description: 'CNCC IAM Ingress traffic Rate is above the configured major threshold i.e. 800 requests per second (current value is: {{ $value }})' For CNE with Prometheus HA Operator: summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Traffic Rate is above 80 Percent of Max requests per second(1000)' For CNE without Prometheus Operator : summary: 'namespace: {{$labels.kubernetes_namespace}}, podname: {{$labels.kubernetes_pod_name}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Traffic Rate is above 80 Percent of Max requests per second(1000)' |
| Resolution |
The alert is cleared when the total Ingress Traffic rate falls below the Major threshold or when the total traffic rate crosses the Critical threshold, in which case the CnccIamTotalIngressTrafficRateAboveCriticalThreshold alert is raised. Note: The threshold is configurable in the occncc_alertrules_<version>.yaml file. Steps:
6.1.3 CnccIamTotalIngressTrafficRateAboveCriticalThreshold
Table 6-3 CnccIamTotalIngressTrafficRateAboveCriticalThreshold
| Field | Details |
| Trigger Condition |
The total CNCC IAM Ingress Message rate has crossed the configured critical threshold of 900TPS. Default value of this alert trigger point in occncc_alertrules_<version>.yaml is when CNCC IAM Ingress Rate crosses 90 % of 1000 (Maximum ingress request rate) |
| Severity | Critical |
Description:CNCC IAM Ingress traffic Rate is above the configured critical threshold, that is, 900 requests per second (current value is: {{ $value }}) For CNE with Prometheus HA Operator: summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Traffic Rate is above 90 Percent of Max requests per second(1000)' For CNE without Prometheus Operator: summary: 'namespace: {{$labels.kubernetes_namespace}}, podname: {{$labels.kubernetes_pod_name}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Traffic Rate is above 90 Percent of Max requests per second(1000)' |
| Resolution |
The alert is cleared when the Ingress Traffic rate falls below the Critical threshold. Note: The threshold is configurable in the occncc_alertrules_<version>.yaml file. Steps:
6.1.4 CnccIamMemoryUsageCrossedMinorThreshold
Table 6-4 CnccIamMemoryUsageCrossedMinorThreshold
| Field | Details |
| Trigger Condition | A pod has reached the configured minor threshold( 70%) of its memory resource limits. |
| Severity | Minor |
Description: 'CNCC IAM Memory Usage for pod {{ $labels.pod }} has crossed the configured minor threshold (70%) (value={{ $value }}) of its limit.' Summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }} : Memory Usage of pod exceeded 70% of its limit.' |
| OID used for SNMP Traps | 1.3.6.1.4.1.323.5.3.51.1.2.7002 |
| Metric Used |
container_memory_usage_bytes, kube_pod_container_resource_limits Note:This is a Kubernetes metric used for instance availability monitoring. If the metric is not available, use a similar metric as exposed by the monitoring system. |
| Resolution |
The alert gets cleared when the memory utilization falls below the Minor Threshold or crosses the major threshold, in which case CnccIamMemoryUsageCrossedMajorThreshold alert is raised. Note: The threshold is configurable in the occncc_alertrules_<version>.yaml file. If guidance is required, contact My Oracle Support. |
6.1.5 CnccIamMemoryUsageCrossedMajorThreshold
Table 6-5 CnccIamMemoryUsageCrossedMajorThreshold
| Field | Details |
| Trigger Condition | A pod has reached the configured major threshold( 80%) of its memory resource limits. |
| Severity | Major |
Description: 'CNCC IAM Memory Usage for pod {{ $labels.pod }} has crossed the configured major threshold (80%) (value = {{ $value }}) of its limit.' Summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }} : Memory Usage of pod exceeded 80% of its limit.' |
| Metric Used |
container_memory_usage_bytes, kube_pod_container_resource_limits Note: This is a Kubernetes metric used for instance availability monitoring.If the metric is not available, use a similar metric as exposed by the monitoring system. |
| Resolution | The alert gets cleared when the memory utilization falls below the
Major Threshold or crosses the critical threshold, in which case
CnccIamMemoryUsageCrossedCriticalThreshold alert shall be raised.
6.1.6 CnccIamMemoryUsageCrossedCriticalThreshold
Table 6-6 CnccIamMemoryUsageCrossedCriticalThreshold
| Field | Details |
| Trigger Condition | A pod has reached the configured critical threshold ( 90% ) of its memory resource limits |
Description: 'CNCC IAM Memory Usage for pod {{ $labels.pod }} has crossed the configured critical threshold (90%) (value = {{ $value }}) of its limit.' Summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }} : Memory Usage of pod exceeded 90% of its limit.' |
| Metric Used |
container_memory_usage_bytes, kube_pod_container_resource_limits Note: This is a Kubernetes metric used for instance availability monitoring. If the metric is not available, use a similar metric as exposed by the monitoring system. |
Critical Threshold.
Note : The threshold is configurable in the
6.1.7 CnccIamTransactionErrorRateAbove0.1Percent
Table 6-7 CnccIamTransactionErrorRateAbove0.1Percent
| Field | Details |
| Trigger Condition | The number of failed transactions is above 0.1 percent of the total transactions. |
| Severity | Warning |
| Alert details provided | Description: 'CNCC IAM transaction Error rate is above 0.1 Percent of Total Transactions (current value is {{ $value }})' Summary: 'CNCC IAM transaction Error Rate detected above 0.1 Percent of Total Transactions' |
| OID used for SNMP Traps | 1.3.6.1.4.1.323.5.3.51.1.2.7003 |
| Metric Used | oc_ingressgateway_http_responses_total |
| Resolution | The alert is cleared when the number of failed transactions is below
0.1% of the total transactions or when the number of failed transactions crosses the
1% threshold in which case the CnccIamTransactionErrorRateAbove1Percent is
raised.
Steps:
6.1.8 CnccIamTransactionErrorRateAbove1Percent
Table 6-8 CnccIamTransactionErrorRateAbove1Percent
| Field | Details |
| Trigger Condition | The number of failed transactions is above 1 percent of the total transactions. |
| Alert details provided | Description: 'CNCC IAM transaction Error rate is above 1 Percent of Total Transactions (current value is {{ $value }})' Summary: 'CNCC IAM transaction Error Rate detected above 1 Percent of Total Transactions' |
1% of the total transactions or when the number of failed transactions crosses the 10%
threshold in which case the CnccIamTransactionErrorRateAbove10Percent is raised.
Steps:
6.1.9 CnccIamTransactionErrorRateAbove10Percent
Table 6-9 CnccIamTransactionErrorRateAbove10Percent
| Field | Details |
| Trigger Condition | The number of failed transactions is above 10 percent of the total transactions. |
| Severity | Minor |
Description: CNCC IAM transaction Error rate is above 10 Percent of Total Transactions (current value is {{ $value }})' Summary: 'CNCC IAM transaction Error rate is above 10 Percent of Total Transactions (current value is {{ $value }})' |
10% of the total transactions or when the number of failed transactions crosses the
25% threshold in which case the CnccIamTransactionErrorRateAbove25Percent is
raised.
Steps:
6.1.10 CnccIamTransactionErrorRateAbove25Percent
Table 6-10 CnccIamTransactionErrorRateAbove25Percent
| Field | Details |
| Trigger Condition | The number of failed transactions is above 25 percent of the total transactions. |
| Severity | Major |
Description: 'CNCC IAM transaction Error Rate detected above 25 Percent of Total Transactions (current value is {{ $value }})' Summary: 'CNCC IAM transaction Error Rate detected above 25 Percent of Total Transactions' |
| Resolution |
TThe alert is cleared when the number of failed transactions are below 25% of the total transactions or when the number of failed transactions cross the 50% threshold in which case the CnccIamTransactionErrorRateAbove50Percent is raised. Steps:
6.1.11 CnccIamTransactionErrorRateAbove50Percent
Table 6-11 CnccIamTransactionErrorRateAbove50Percent
| Field | Details |
| Trigger Condition | The number of failed transactions is above 50 percent of the total transactions. |
Description: The number of failed transactions is above 50 percent of the total transactions. Summary: 'CNCC IAM transaction Error Rate detected above 50 Percent of Total Transactions'. |
| Resolution |
The alert is cleared when the number of failed transactions is below 50 percent of the total transactions. The threshold is configurable in the occncc_alertrules_<version>.yaml file. Steps:
6.1.12 CnccIamIngressGatewayServiceDown
Table 6-12 CnccIamIngressGatewayServiceDown
| Field | Details |
| Trigger Condition |
The pods of the CNCC IAM Ingress Gateway microservice is available. |
Description:'CNCC IAM Ingress-Gateway service InstanceIdentifier=~".*cncc-iam_ingressgateway" is down' For CNE with Prometheus HA Operator: summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }} : Ingress-gateway service down' For CNE without Prometheus Operator: summary: 'namespace: {{$labels.kubernetes_namespace}}, podname: {{$labels.kubernetes_pod_name}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }} : Ingress-gateway service down' |
| OID used for SNMP Traps | 1.3.6.1.4.1.323.5.3.51.1.2.7004 |
| Metric Used |
'up' Note: This is a Prometheus metric used for instance availability monitoring. If this metric is not available, use a similar metric as exposed by the monitoring system. |
| Resolution |
The alert is cleared when the cncc-iam_ingressgateway service is available. Steps:
6.1.13 CnccIamFailedLogin
Table 6-13 CnccIamFailedLogin
| Field | Details |
| Trigger Condition |
The count of failed login attempts in CNCC-IAM by a user goes above '3' |
Description:'{{ $value }} failed Login attempts have been detected in CNCC IAM for user {{$labels.UserName}}, the configured threshold value is 3 failed login attempts for every 5 min' For CNE with Prometheus HA Operator: summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: failed login attempts are more than the configured threshold value' For CNE without Prometheus Operator: summary: 'namespace: {{$labels.kubernetes_namespace}}, podname: {{$labels.kubernetes_pod_name}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: failed login attempts are more than the configured threshold value' |
| OID used for SNMP Traps | 1.3.6.1.4.1.323.5.3.51.1.2.7005 |
| Resolution |
The alert gets cleared when the total failed login attempts for a particular user goes below the threshold value (default value is '3') in the last 5 min (default value is 5 m). Note: The threshold and time is configurable in the alerts.yaml file. If guidance is required, contact My Oracle Support. |
6.1.14 AdminUserCreation
Table 6-14 AdminUserCreation
| Field | Details |
| Trigger Condition |
If a new admin account is created in the last 5 min |
For CNE with Prometheus HA Operator: Description: '{{ $value }} admin users have been created by {{$labels.UserName}} ' summary: 'namespace: {{$labels.namespace}} summary: {{$labels.pod}}, user: {{$labels.UserName}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Admin users have been created ' For CNE without Prometheus Operator: Description: '{{ $value }} admin users have been created by {{$labels.UserName}} ' summary: 'namespace: {{$labels.kubernetes_namespace}} summary: {{$labels.kubernetes_pod_name}}, user: {{$labels.UserName}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Admin users have been created ' |
| OID used for SNMP Traps | 1.3.6.1.4.1.323.5.3.51.1.2.7006 |
| Resolution |
The alert gets cleared when no new user is created in the last 5 min (default value is 5m) Note: The time is configurable in the alerts yaml file Login to admin GUI and review the newly created admin user, take necessary action to retain or delete the new admin user. If guidance required, contact My Oracle Support. |
6.1.15 CnccIamAccessTokenFailure
Table 6-15 CnccIamAccessTokenFailure
| Field | Details |
| Trigger Condition |
If the count of failed token for CNCC-IAM goes above configured value of '3' |
Description: 'CNCC Iam Access Token Failure count is above the configured value i.e. 3 for every 5 min. Failed access token request count per second is (current value is: {{ $value }})' For CNE with Prometheus HA Operator: summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Access Token Failure count is above the configured threshold value' For CNE without Prometheus Operator: summary: 'namespace: {{$labels.kubernetes_namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Access Token Failure count is above the configured threshold value' |
| OID used for SNMP Traps | 1.3.6.1.4.1.323.5.3.51.1.2.7007 |
| Resolution |
The alert gets cleared when the total failed tokens for a particular user go below the threshold value (default value is '3') in the last 5 min (default value is 5 m) Note: The threshold and time is configurable in the occncc_alertrules_<version>.yaml file. If guidance is required, contact My Oracle Support. |
6.2 CNC Console Core Alerts
This section provides the information about CNC Console Core Alerts.
6.2.1 CnccCoreTotalIngressTrafficRateAboveMinorThreshold
Table 6-16 CnccCoreTotalIngressTrafficRateAboveMinorThreshold
| Field | Details |
| Trigger Condition |
The total CNCC Core Ingress Message rate has crossed the configured minor threshold of 700 TPS. Default value of this alert trigger point in cncc_alert_rules.yaml is when CNCC Core Ingress Rate crosses 70 % of 1000 (Maximum ingress request rate) |
| Severity | Minor |
Description: 'CNCC Core Ingress traffic Rate is above the configured minor threshold i.e. 700 requests per second (current value is: {{ $value }})' For CNE with Prometheus HA Operator: summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Traffic Rate is above 70 Percent of Max requests per second(1000)' For CNE without Prometheus Operator: summary: 'namespace: {{$labels.kubernetes_namespace}}, podname: {{$labels.kubernetes_pod_name}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Traffic Rate is above 70 Percent of Max requests per second(1000)' |
| OID used for SNMP Traps | 1.3.6.1.4.1.323.5.3.51.1.2.8001 |
| Resolution |
The alert is cleared either when the total Ingress traffic rate falls below the minor threshold or when the total traffic rate crosses the major threshold, in which case the CnccCoreTotalIngressTrafficRateAboveMajorThreshold alert is raised. Note: The threshold is configurable in the occncc_alertrules_<version>.yaml file. Steps:
6.2.2 CnccCoreTotalIngressTrafficRateAboveMajorThreshold
Table 6-17 CnccCoreTotalIngressTrafficRateAboveMajorThreshold
| Field | Details |
| Trigger Condition | The total CNCC Core Ingress Message rate has crossed the configured
Default value of this alert trigger point in cncc_alert_rules.yaml is when CNCC Core Ingress Rate crosses 80 % of 1000 (Maximum ingress request rate) |
| Severity | Major |
Description: 'CNCC Core Ingress traffic Rate is above the configured major threshold i.e. 800 requests per second (current value is: {{ $value }})' For CNE with Prometheus HA Operator: summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Traffic Rate is above 80 Percent of Max requests per second(1000)' For CNE without Prometheus Operator : summary: 'namespace: {{$labels.kubernetes_namespace}}, podname: {{$labels.kubernetes_pod_name}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Traffic Rate is above 80 Percent of Max requests per second(1000)' |
| Resolution | The alert is cleared when the total Ingress Traffic ratefalls below
the Major threshold or when the total traffic rate cross the Critical threshold, in
which case the CnccCoreTotalIngressTrafficRate Above CriticalThreshold.
Note: The threshold is configurable in the alerts.yaml file. Steps:
6.2.3 CnccCoreTotalIngressTrafficRateAboveCriticalThreshold
Table 6-18 CnccCoreTotalIngressTrafficRateAboveCriticalThreshold
| Field | Details |
| Trigger Condition |
The total CNCC Core Ingress Message rate has crossed the configured critical threshold of 900TPS. Default value of this alert trigger point in cncc_alert_rules.yaml is when CNCC Core Ingress Rate crosses 90 % of 1000 (Maximum ingress request rate) |
Description: 'CNCC Core Ingress traffic Rate is above the configured critical threshold i.e. 900 requests per second (current value is: {{ $value }})' For CNE with Prometheus HA Operator: summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Traffic Rate is above 90 Percent of Max requests per second(1000)' For CNE without Prometheus Operator : summary: 'namespace: {{$labels.kubernetes_namespace}}, podname: {{$labels.kubernetes_pod_name}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Traffic Rate is above 90 Percent of Max requests per second(1000)' |
| Resolution |
6.2.4 CnccCoreMemoryUsageCrossedMinorThreshold
Table 6-19 CnccCoreMemoryUsageCrossedMinorThreshold
| Field | Details |
| Trigger Condition |
| Severity | Minor |
Description: 'CNCC Core Memory Usage for pod {{ $labels.pod }} has crossed the configured minor threshold (70%) (value={{ $value }}) of its limit.' Summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }} : Memory Usage of pod exceeded 70% of its limit.' |
| OID used for SNMP Traps | 1.3.6.1.4.1.323.5.3.51.1.2.8002 |
| Metric Used |
container_memory_usage_bytes kube_pod_container_resource_limits Note : This is a kubernetes metric used for instance availability monitoring. If the metric is not available, use the similar metric as exposed by the monitoring system. |
| Resolution |
The alert gets cleared when the memory utilization falls below the Minor Threshold or crosses the major threshold, in which case CnccCoreMemoryUsageCrossedMajorThreshold alert is raised. Note: The threshold is configurable in the occncc_alertrules_<version>.yaml file. If guidance is required, contact My Oracle Support. |
6.2.5 CnccCoreMemoryUsageCrossedMajorThreshold
Table 6-20 CnccCoreMemoryUsageCrossedMajorThreshold
| Field | Details |
| Trigger Condition |
| Severity | Major |
Description: 'CNCC Core Memory Usage for pod {{ $labels.pod }} has crossed the configured major threshold (80%) (value = {{ $value }}) of its limit.' Summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }} : Memory Usage of pod exceeded 80% of its limit.' |
| Metric Used |
| Resolution |
The alert gets cleared when the memory utilization falls below the Major Threshold or crosses the critical threshold, in which case CnccCoreMemoryUsageCrossedCriticalThreshold alert is raised Note: The threshold is configurable in the occncc_alertrules_<version>.yaml file. If guidance is required, contact My Oracle Support. |
6.2.6 CnccCoreMemoryUsageCrossedCriticalThreshold
Table 6-21 CnccCoreMemoryUsageCrossedCriticalThreshold
| Field | Details |
| Trigger Condition |
Description: 'CNCC Core Memory Usage for pod {{ $labels.pod }} has crossed the configured critical threshold (90%) (value = {{ $value }}) of its limit.' Summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }} : Memory Usage of pod exceeded 90% of its limit.' |
| Metric Used |
container_memory_usage_bytes kube_pod_container_resource_limits Note : This is a Kubernetes metric used for instance availability monitoring. If the metric is not available, use the similar metric as exposed by the monitoring system. |
| Resolution |
The alert gets cleared when the memory utilization falls below the Critical Threshold. Note: The threshold is configurable in the occncc_alertrules_<version>.yaml file. If guidance is required, contact My Oracle Support. |
6.2.7 CnccCoreTransactionErrorRateAbove0.1Percent
Table 6-22 CnccCoreTransactionErrorRateAbove0.1Percent
| Field | Details |
| Trigger Condition | The number of failed transactions is above 0.1 percent of the total transactions.. |
Description:'CNCC Core transaction Error rate is above 0.1 Percent of Total Transactions (current value is {{ $value }})' Summary:'CNCC Core transaction Error rate is above 0.1 Percent of Total Transactions (current value is {{ $value }})' |
| OID used for SNMP Traps | 1.3.6.1.4.1.323.5.3.51.1.2.8003 |
| Resolution |
The alert is cleared when the number of failed transactions are below 0.1% of the total transactions or when the number of failed transactions cross the 1% threshold in which case the CnccCoreTransactionErrorRateAbove1Percent is raised. The threshold is configurable in the alerts.yaml file. Steps:
6.2.8 CnccCoreTransactionErrorRateAbove1Percent
Table 6-23 CnccCoreTransactionErrorRateAbove1Percent
| Field | Details |
Description: 'CNCC Core transaction Error rate is above 1 Percent of Total Transactions (current value is {{ $value }})' Summary:'CNCC Core transaction Error Rate detected above 1 Percent of Total Transactions' |
| Resolution |
The alert is cleared when the number of failed transactions are below 1% of the total transactions or when the number of failed transactions crosses the 10% threshold in which case the CnccCoreTransactionErrorRateAbove10Percent is raised. Steps:
6.2.9 CnccCoreTransactionErrorRateAbove10Percent
Table 6-24 CnccCoreTransactionErrorRateAbove10Percent
| Field | Details |
| Severity | Minor |
Description: 'CNCC Core transaction Error rate is above 10 Percent of Total Transactions (current value is {{ $value }})' summary: 'CNCC Core ransaction Error Rate detected above 10 Percent of Total Transactions' |
| Resolution |
The alert is cleared when the number of failed transactions are below 10% of the total transactions or when the number of failed transactions crosses the 25% threshold in which case the CnccCoreTransactionErrorRateAbove25Percent is raised. Steps:
6.2.10 CnccCoreTransactionErrorRateAbove25Percent
Table 6-25 CnccCoreTransactionErrorRateAbove25Percent
| Field | Details |
| Severity | Major |
Description: 'CNCC Core transaction Error Rate detected above 25 Percent of Total Transactions (current value is {{ $value }})' Summary: 'CNCC Core transaction Error Rate detected above 25 Percent of Total Transactions' |
| Resolution |
The alert is cleared when the number of failed transactions are below 25% of the total transactions or when the number of failed transactions crosses the 50% threshold in which case the CnccCoreTransactionErrorRateAbove50Percent is raised. Steps:
6.2.11 CnccCoreTransactionErrorRateAbove50Percent
Table 6-26 CnccCoreTransactionErrorRateAbove50Percent
| Field | Details |
Description: 'CNCC Core transaction Error Rate detected above 50 Percent of Total Transactions (current value is {{ $value }})' Summary: 'CNCC Core transaction Error Rate detected above 50 Percent of Total Transactions' |
| Resolution |
The alert is cleared when the number of failed transactions are below 50 percent of the total transactions Steps:
6.2.12 CnccCoreIngressGatewayServiceDown
Table 6-27 CnccCoreIngressGatewayServiceDown
| Field | Details |
| Trigger Condition | Cncc Core Ingress Gateway service is down |
Description: 'CNCC Core Ingress-Gateway service InstanceIdentifier=~".*core_ingressgateway" is down' For CNE with Prometheus HA Operator: summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }} : Ingress-gateway service down' For CNE without Prometheus Operator: summary: 'namespace: {{$labels.kubernetes_namespace}}, podname: {{$labels.kubernetes_pod_name}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }} : Ingress-gateway service down' |
| OID used for SNMP Traps | 1.3.6.1.4.1.323.5.3.51.1.2.8004 |
| Metric Used |
| Resolution |
The alert is cleared when the cncc-core_ingressgateway service is available. Steps:
6.2.13 CnccCoreFailedLogin
Table 6-28 CnccCoreFailedLogin
| Field | Details |
| Trigger Condition |
The count of failed login attempts in CNCC-Core by a user goes above '3' |
Description:'{{ $value }} failed Login attempts have been detected in CNCC Core for user {{$labels.UserName}}, the configured threshold value is 3 failed login attempts for every 5 min' For CNE with Prometheus HA Operator: summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: failed login attempts are more than the configured threshold value' For CNE without Prometheus Operator : summary: 'namespace: {{$labels.kubernetes_namespace}}, podname: {{$labels.kubernetes_pod_name}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: failed login attempts are more than the configured threshold value' |
| OID used for SNMP Traps | 1.3.6.1.4.1.323.5.3.51.1.2.8005 |
| Resolution |
The alert gets cleared when the total failed login attempts for a particular user go below the threshold value (default value is '3') in the last 5 min (default value is 5 m) Note: The threshold and time is configurable in the alerts.yaml file. If guidance is required, contact My Oracle Support. |
6.2.14 CnccCoreUnauthorizedAccess
Table 6-29 CnccCoreUnauthorizedAccess
| Field | Details |
| Trigger Condition |
Description:'{{ $value }} Unauthorized Accesses have been detected in CNCC-Core for {{$labels.ResourceType}} for {{$labels.Method}} request. The configured threshold value is 3 for every 5 min' For CNE with Prometheus HA Operator: summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Unauthorized Access for CNCC-Core are more than threshold value' For CNE without Prometheus Operator : summary: 'namespace: {{$labels.kubernetes_namespace}}, podname: {{$labels.kubernetes_pod_name}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Unauthorized Access for CNCC-Core are more than threshold value' |
| OID used for SNMP Traps | 1.3.6.1.4.1.323.5.3.51.1.2.8006 |
| Resolution |
The alert gets cleared when the total failed login attempts for a particular user go below the threshold value (default value is '3') in the last 5 min (default value is 5 m) Note: The threshold and time is configurable in the alerts.yaml If guidance is required, contact My Oracle Support. |
6.2.15 CnccCoreAccessTokenFailure
Table 6-30 CnccCoreAccessTokenFailure
| Field | Details |
| Trigger Condition |
If the count of failed token for CNCC-Core goes above configured value of '3' |
Description: 'CNCC Core Access Token Failure count is above the configured value i.e. 3 for every 5 min. Failed access token request count per second is (current value is: {{ $value }})' For CNE with Prometheus HA Operator: summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.kubernetes_pod_name}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Access Token Failure count is above the configured threshold value' For CNE without Prometheus Operator : summary: 'namespace: {{$labels.kubernetes_namespace}}, podname: {{$labels.kubernetes_pod_name}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Access Token Failure count is above the configured threshold value' |
| OID used for SNMP Traps | 1.3.6.1.4.1.323.5.3.51.1.2.8007 |
| Resolution |
The alert gets cleared when the total failed tokens for a particular user go below the threshold value (default value is '3') in the last 5 min (default value is 5 m) Note: The threshold and time is configurable in the alerts.yaml file. If guidance is required, Contact My Oracle Support. |
6.3 CNC Console Alerts on OCI
This section provides information about CNC Console Alerts on OCI:
6.3.1 CnccCoreTotalIngressTrafficRateAboveMinorThreshold
Table 6-31 CnccCoreTotalIngressTrafficRateAboveMinorThreshold
| Field | Details |
| Trigger Condition |
| Severity | minor |
| Alert details provided | CNCC Core Ingress traffic Rate is above the configured minor threshold i.e. 700 requests per second |
| Resolution | The alert is cleared either when the total Ingress Traffic rate falls below the Minor threshold or when the total traffic rate cross the Major threshold, inwhich case the CnccCoreTotalIngressTrafficRateAboveMajorThresholdalert shall be raised.Note: The threshold is configurable in the alerts.yamlSteps:Reassess why the CNCC Core is receiving additionaltraffic.If this is unexpected, contact My Oracle Support. |
6.3.2 CnccCoreTotalIngressTrafficRateAboveMajorThreshold
Table 6-32 CnccCoreTotalIngressTrafficRateAboveMajorThreshold
| Field | Details |
| Trigger Condition |
The total CNCC Core Ingress Message rate has crossed the configured major threshold of 800 TPS. Default value of this alert trigger point in cncc_alert_rules.yaml is when CNCC Core Ingress Rate crosses 80 % of 1000 (Maximum ingress request rate) |
| Severity | major |
| Alert details provided | CNCC Core Ingress traffic Rate is above the configured major threshold i.e. 800 requests per second |
| Resolution | The alert is cleared when the total Ingress Traffic ratefalls below the Major threshold or when the total traffic rate cross the Critical threshold, in which casethe CnccCoreTotalIngressTrafficRateAboveCriticalThresholdNote: The threshold is configurable in the alerts.yaml alert shall be raised.Steps:Reassess why the CNCC Core is receiving additionaltraffic.If this is unexpected, contact My Oracle Support. |
6.3.3 CnccCoreTotalIngressTrafficRateAboveCriticalThreshold
Table 6-33 CnccCoreTotalIngressTrafficRateAboveCriticalThreshold
| Field | Details |
| Trigger Condition |
| Severity | critical |
| Alert details provided | CNCC Core Ingress traffic Rate is above the configured critical threshold i.e. 900 requests per second |
| Resolution | The alert is cleared when the Ingress Traffic rate falls below the Critical threshold.Note: The threshold is configurable in the alerts.yamlSteps:Reassess why the CNCC Core is receiving additional traffic.If this is unexpected, contact My Oracle Support. |
6.3.4 CnccCoreMemoryUsageCrossedMinorThreshold
Table 6-34 CnccCoreMemoryUsageCrossedMinorThreshold
| Field | Details |
| Severity | minor |
| Alert details provided | CNCC Core Memory Usage for pod has crossed the configured minor threshold (70%) of its limit. |
| Metric Used |
container_memory_usage_bytes Note : This is a kubernetes metric used for instance availability monitoring. If the metric is not available, use the similar metric as exposed by the monitoring system. |
| Resolution |
The alert gets cleared when the memory utilization falls below the Minor Threshold or crosses the major threshold, in which case CnccCoreMemoryUsageCrossedMajorThreshold alert shall be raised Note : The threshold is configurable in the alerts.yaml If guidance required, Contact My Oracle Support. |
6.3.5 CnccCoreMemoryUsageCrossedMajorThreshold
Table 6-35 CnccCoreMemoryUsageCrossedMajorThreshold
| Field | Details |
| Severity | major |
| Alert details provided | CNCC Core Memory Usage for pod has crossed the configured major threshold (80%) of its limit. |
| Metric Used |
| Resolution |
The alert gets cleared when the memory utilization falls below the Major Threshold or crosses the critical threshold, in which case CnccCoreMemoryUsageCrossedCriticalThreshold alert shall be raised Note : The threshold is configurable in the alerts.yaml If guidance required, Contact My Oracle Support. |
6.3.6 CnccCoreMemoryUsageCrossedCriticalThreshold
Table 6-36 CnccCoreMemoryUsageCrossedCriticalThreshold
| Field | Details |
| Alert details provided | CNCC Core Memory Usage for pod has crossed the configured critical threshold (90%) of its limit. |
| Metric Used |
| Resolution |
The alert gets cleared when the memory utilization falls below the Critical Threshold. Note : The threshold is configurable in the alerts.yaml If guidance required, Contact My Oracle Support. |
6.3.7 CnccCoreTransactionErrorRateAbovePointOnePercent
Table 6-37 CnccCoreTransactionErrorRateAbovePointOnePercent
| Field | Details |
| Severity | warning |
| Alert details provided | CNCC Core transaction Error rate is above 0.1 Percent of Total Transactions |
| Resolution | The alert is cleared when the number of failure transactions are below 0.1% of the total transactions or when the number of failure transactions cross the 1% threshold in which case the CnccCoreTransactionErrorRateAbove1Percent shall beraised.Steps:1. Check the Service specific metrics to understand the specific service request errors.2. If guidance required, contact My Oracle Support. |
6.3.8 CnccCoreTransactionErrorRateAboveOnePercent
Table 6-38 CnccCoreTransactionErrorRateAboveOnePercent
| Field | Details |
| Alert details provided | CNCC Core transaction Error rate is above 1 Percent of Total Transactions |
| Resolution | The alert is cleared when the number of failure transactions are below 1% of the total transactions or when the number of failure transactions cross the 10% threshold in which case the CnccCoreTransactionErrorRateAbove10Percent shall beraised.Steps:1. Check the Service specific metrics to understand the specific service request errors.2. If guidance required, contact My Oracle Support. |
6.3.9 CnccCoreTransactionErrorRateAboveTenPercent
Table 6-39 CnccCoreTransactionErrorRateAboveTenPercent
| Field | Details |
| Severity | minor |
| Alert details provided | CNCC Core transaction Error rate is above 10 Percent of Total Transactions |
| Resolution | The alert is cleared when the number of failure transactions are below 10% of the total transactions or when the number of failure transactions cross the 25% threshold in which case the CnccCoreTransactionErrorRateAbove25Percent shall beraised.Steps:1. Check the Service specific metrics to understand the specific service request errors.2. If guidance required, contact My Oracle Support. |
6.3.10 CnccCoreTransactionErrorRateAboveTwentyFivePercent
Table 6-40 CnccCoreTransactionErrorRateAboveTwentyFivePercent
| Field | Details |
| Severity | major |
| Alert details provided | CNCC Core transaction Error Rate detected above 25 Percent of Total Transactions |
| Resolution | The alert is cleared when the number of failure transactions are below 25% of the total transactions or when the number of failure transactions cross the 50% threshold in which case the CnccCoreTransactionErrorRateAbove50Percent shall beraised.Steps:1. Check the Service specific metrics to understand the specific service request errors.2. If guidance required, contact My Oracle Support. |
6.3.11 CnccCoreTransactionErrorRateAboveFiftyPercent
Table 6-41 CnccCoreTransactionErrorRateAboveFiftyPercent
| Field | Details |
| Alert details provided | CNCC Core transaction Error Rate detected above 50 Percent of Total Transactions |
| Resolution | The alert is cleared when the number of failure transactions are below 50 percent of the total transactions.Steps:1. Check the Service specific metrics to understand the specific service request errors.2. If guidance required, contact My Oracle Support. |
6.3.12 CnccCoreUnauthorizedAccess
Table 6-42 CnccCoreUnauthorizedAccess
| Field | Details |
| Trigger Condition | If the count of unauthorized access goes above the configured value of '3' |
| Alert details provided | Unauthorized Accesses have been detected in CNCC-Core for request. The configured threshold value is 3 for every 5 min |
| Resolution |
The alert gets cleared when the total unauthorized accesses for a particular user go below the threshold value (default value is '3') in the last 5 min (default value is 5 m) Note : The threshold and time is configurable in the alerts.yaml If guidance required, Contact My Oracle Support. |
