6 CNC Console Alerts
This section provides information about CNC Console Alerts.
For OCI:
The only section applicable for OCI is CNC Console Alerts on OCI.
Alert file is present in the Scripts directory. occncc_csar_<version>.zip can be downloaded from MOS. Unzip the file to get occncc_alertrules_<version>.yaml file.
  • Review the occncc_alerting_rules_promha_<version>.yaml file and edit the value of the parameters in the occncc_alerting_rules_promha_<version>.yaml file (if needed to be changed from default values) before configuring the alerts.
  • kubernetes_namespace is configured as kubernetes namespace in which CNCC is deployed. Default value is cncc. Update the occncc_alertrules_<version>.yaml file to reflect the correct CNCC kubernetes namespace.
Two sample Alert files are provided, one for supporting CNE 1.8 or lower and second one supporting CNE Prometheus HA.
  • CNC Console Alert Rules file: occncc_alertrules_<version>.yaml file.
  • CNC Console Alert Rules file supporting CNE Prometheus HA: occncc_alerting_rules_promha_<version>.yaml file.
6.1 CNC Console IAM Alerts
This section provides information about CNC Console IAM Alerts.
6.1.1 CnccIamTotalIngressTrafficRateAboveMinorThreshold
Table 6-1 CnccIamTotalIngressTrafficRateAboveMinorThreshold
Field Details
Trigger Condition The total CNCC IAM Ingress Message rate has crossed the configured minor threshold of 700 TPS.
Default value of this alert trigger point in occncc_alertrules_<version>.yamlis when CNCC IAM Ingress Rate crosses 70 % of 1000 (Maximum ingress request rate)
Severity Minor
Alert details provided
Description: CNCC IAM Ingress traffic Rate is above the configured minor threshold i.e. 700 requests per second (current value is: {{ $value }})
For CNE with Prometheus HA Operator:
summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Traffic Rate is above 70 Percent of Max requests per second(1000)'
For CNE without Prometheus Operator :
summary: 'namespace: {{$labels.kubernetes_namespace}}, podname: {{$labels.kubernetes_pod_name}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Traffic Rate is above 70 Percent of Max requests per second(1000)'
OID used for SNMP Traps 1.3.6.1.4.1.323.5.3.51.1.2.7001
Metric Used oc_ingressgateway_http_requests_total
Resolution
The alert is cleared either when the total Ingress Traffic rate falls below the Minor threshold or when the total traffic rate crosses the Major threshold, in which case the CnccIamTotalIngressTrafficRateAboveMajorThreshold alert is raised.
Note: The threshold is configurable in the occncc_alertrules_<version>.yaml file.
Steps:
  1. Reassess why the CNCC IAM is receiving additional traffic.
  2. If this is unexpected, contact My Oracle Support.
6.1.2 CnccIamTotalIngressTrafficRateAboveMajorThreshold
Table 6-2 CnccIamTotalIngressTrafficRateAboveMajorThreshold
Field Details
Trigger Condition
The total CNCC IAM Ingress Message rate has crossed the configured major threshold of 800 TPS.
Default value of this alert trigger point ino ccncc_alertrules_<version>.yaml is when CNCC IAM Ingress Rate crosses 80 % of 1000 (Maximum ingress request rate)
Severity Major
Description: 'CNCC IAM Ingress traffic Rate is above the configured major threshold i.e. 800 requests per second (current value is: {{ $value }})'
summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Traffic Rate is above 80 Percent of Max requests per second(1000)'
summary: 'namespace: {{$labels.kubernetes_namespace}}, podname: {{$labels.kubernetes_pod_name}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Traffic Rate is above 80 Percent of Max requests per second(1000)'
Resolution
The alert is cleared when the total Ingress Traffic rate falls below the Major threshold or when the total traffic rate crosses the Critical threshold, in which case the CnccIamTotalIngressTrafficRateAboveCriticalThreshold alert is raised.
Steps:
6.1.3 CnccIamTotalIngressTrafficRateAboveCriticalThreshold
Table 6-3 CnccIamTotalIngressTrafficRateAboveCriticalThreshold
Field Details
Trigger Condition
The total CNCC IAM Ingress Message rate has crossed the configured critical threshold of 900TPS. Default value of this alert trigger point in occncc_alertrules_<version>.yaml is when CNCC IAM Ingress Rate crosses 90 % of 1000 (Maximum ingress request rate)
Severity Critical
Description:CNCC IAM Ingress traffic Rate is above the configured critical threshold, that is, 900 requests per second (current value is: {{ $value }})
summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Traffic Rate is above 90 Percent of Max requests per second(1000)'
For CNE without Prometheus Operator:
summary: 'namespace: {{$labels.kubernetes_namespace}}, podname: {{$labels.kubernetes_pod_name}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Traffic Rate is above 90 Percent of Max requests per second(1000)'
Resolution
The alert is cleared when the Ingress Traffic rate falls below the Critical threshold.
Steps:
6.1.4 CnccIamMemoryUsageCrossedMinorThreshold
Table 6-4 CnccIamMemoryUsageCrossedMinorThreshold
Field Details
Trigger Condition A pod has reached the configured minor threshold( 70%) of its memory resource limits.
Severity Minor
Description: 'CNCC IAM Memory Usage for pod {{ $labels.pod }} has crossed the configured minor threshold (70%) (value={{ $value }}) of its limit.'
Summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }} : Memory Usage of pod exceeded 70% of its limit.'
OID used for SNMP Traps 1.3.6.1.4.1.323.5.3.51.1.2.7002
Metric Used
container_memory_usage_bytes,
kube_pod_container_resource_limits
Note:This is a Kubernetes metric used for instance availability monitoring. If the metric is not available, use a similar metric as exposed by the monitoring system.
Resolution
The alert gets cleared when the memory utilization falls below the Minor Threshold or crosses the major threshold, in which case CnccIamMemoryUsageCrossedMajorThreshold alert is raised.
If guidance is required, contact My Oracle Support.
6.1.5 CnccIamMemoryUsageCrossedMajorThreshold
Table 6-5 CnccIamMemoryUsageCrossedMajorThreshold
Field Details
Trigger Condition A pod has reached the configured major threshold( 80%) of its memory resource limits.
Severity Major
Description: 'CNCC IAM Memory Usage for pod {{ $labels.pod }} has crossed the configured major threshold (80%) (value = {{ $value }}) of its limit.'
Summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }} : Memory Usage of pod exceeded 80% of its limit.'
Metric Used
Note: This is a Kubernetes metric used for instance availability monitoring.If the metric is not available, use a similar metric as exposed by the monitoring system.
Resolution The alert gets cleared when the memory utilization falls below the Major Threshold or crosses the critical threshold, in which case CnccIamMemoryUsageCrossedCriticalThreshold alert shall be raised.
6.1.6 CnccIamMemoryUsageCrossedCriticalThreshold
Table 6-6 CnccIamMemoryUsageCrossedCriticalThreshold
Field Details
Trigger Condition A pod has reached the configured critical threshold ( 90% ) of its memory resource limits
Severity Critical
Description: 'CNCC IAM Memory Usage for pod {{ $labels.pod }} has crossed the configured critical threshold (90%) (value = {{ $value }}) of its limit.'
Summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }} : Memory Usage of pod exceeded 90% of its limit.'
Metric Used
Note: This is a Kubernetes metric used for instance availability monitoring. If the metric is not available, use a similar metric as exposed by the monitoring system.
Resolution The alert gets cleared when the memory utilization falls below the Critical Threshold.
Note : The threshold is configurable in the occncc_alertrules_<version>.yaml file.
6.1.7 CnccIamTransactionErrorRateAbove0.1Percent
Table 6-7 CnccIamTransactionErrorRateAbove0.1Percent
Field Details
Trigger Condition The number of failed transactions is above 0.1 percent of the total transactions.
Severity Warning
Alert details provided Description: 'CNCC IAM transaction Error rate is above 0.1 Percent of Total Transactions (current value is {{ $value }})'
Summary: 'CNCC IAM transaction Error Rate detected above 0.1 Percent of Total Transactions'
OID used for SNMP Traps 1.3.6.1.4.1.323.5.3.51.1.2.7003
Metric Used oc_ingressgateway_http_responses_total
Resolution The alert is cleared when the number of failed transactions is below 0.1% of the total transactions or when the number of failed transactions crosses the 1% threshold in which case the CnccIamTransactionErrorRateAbove1Percent is raised.
Steps:
  1. Check the Service specific metrics to understand the specific service request errors.
  2. If guidance is required, contact My Oracle Support.
6.1.8 CnccIamTransactionErrorRateAbove1Percent
Table 6-8 CnccIamTransactionErrorRateAbove1Percent
Field Details
Trigger Condition The number of failed transactions is above 1 percent of the total transactions.
Severity Warning
Alert details provided Description: 'CNCC IAM transaction Error rate is above 1 Percent of Total Transactions (current value is {{ $value }})'
Summary: 'CNCC IAM transaction Error Rate detected above 1 Percent of Total Transactions'
Resolution The alert is cleared when the number of failed transactions is below 1% of the total transactions or when the number of failed transactions crosses the 10% threshold in which case the CnccIamTransactionErrorRateAbove10Percent is raised.
Steps:
6.1.9 CnccIamTransactionErrorRateAbove10Percent
Table 6-9 CnccIamTransactionErrorRateAbove10Percent
Field Details
Trigger Condition The number of failed transactions is above 10 percent of the total transactions.
Severity Minor
Description: CNCC IAM transaction Error rate is above 10 Percent of Total Transactions (current value is {{ $value }})'
Summary: 'CNCC IAM transaction Error rate is above 10 Percent of Total Transactions (current value is {{ $value }})'
Resolution The alert is cleared when the number of failed transactions is below 10% of the total transactions or when the number of failed transactions crosses the 25% threshold in which case the CnccIamTransactionErrorRateAbove25Percent is raised.
Steps:
6.1.10 CnccIamTransactionErrorRateAbove25Percent
Table 6-10 CnccIamTransactionErrorRateAbove25Percent
Field Details
Trigger Condition The number of failed transactions is above 25 percent of the total transactions.
Severity Major
Description: 'CNCC IAM transaction Error Rate detected above 25 Percent of Total Transactions (current value is {{ $value }})'
Summary: 'CNCC IAM transaction Error Rate detected above 25 Percent of Total Transactions'
Resolution
TThe alert is cleared when the number of failed transactions are below 25% of the total transactions or when the number of failed transactions cross the 50% threshold in which case the CnccIamTransactionErrorRateAbove50Percent is raised.
Steps:
6.1.11 CnccIamTransactionErrorRateAbove50Percent
Table 6-11 CnccIamTransactionErrorRateAbove50Percent
Field Details
Trigger Condition The number of failed transactions is above 50 percent of the total transactions.
Severity Critical
Description: The number of failed transactions is above 50 percent of the total transactions.
Summary: 'CNCC IAM transaction Error Rate detected above 50 Percent of Total Transactions'.
Resolution
The alert is cleared when the number of failed transactions is below 50 percent of the total transactions.
Steps:
6.1.12 CnccIamIngressGatewayServiceDown
Table 6-12 CnccIamIngressGatewayServiceDown
Field Details
Trigger Condition
The pods of the CNCC IAM Ingress Gateway microservice is available.
Severity Critical
Description:'CNCC IAM Ingress-Gateway service InstanceIdentifier=~".*cncc-iam_ingressgateway" is down'
summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }} : Ingress-gateway service down'
summary: 'namespace: {{$labels.kubernetes_namespace}}, podname: {{$labels.kubernetes_pod_name}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }} : Ingress-gateway service down'
OID used for SNMP Traps 1.3.6.1.4.1.323.5.3.51.1.2.7004
Metric Used
'up'
Note: This is a Prometheus metric used for instance availability monitoring. If this metric is not available, use a similar metric as exposed by the monitoring system.
Resolution
The alert is cleared when the cncc-iam_ingressgateway service is available.
Steps:
  1. Check the orchestration logs of cncc-iam_ingressgateway service and check for liveness or readiness probe failures.
  2. Refer to the application logs on Kibana and filter based on cncc-iam_ingressgateway service names. Check for ERROR WARNING logs related to thread exceptions.
  3. Depending on the failure reason, take the resolution steps.
  4. In case the issue persists, contact My Oracle Support.
6.1.13 CnccIamFailedLogin
Table 6-13 CnccIamFailedLogin
Field Details
Trigger Condition
The count of failed login attempts in CNCC-IAM by a user goes above '3'
Severity Warning
Description:'{{ $value }} failed Login attempts have been detected in CNCC IAM for user {{$labels.UserName}}, the configured threshold value is 3 failed login attempts for every 5 min'
summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: failed login attempts are more than the configured threshold value'
summary: 'namespace: {{$labels.kubernetes_namespace}}, podname: {{$labels.kubernetes_pod_name}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: failed login attempts are more than the configured threshold value'
OID used for SNMP Traps 1.3.6.1.4.1.323.5.3.51.1.2.7005
Resolution
The alert gets cleared when the total failed login attempts for a particular user goes below the threshold value (default value is '3') in the last 5 min (default value is 5 m).
Note: The threshold and time is configurable in the alerts.yaml file.
6.1.14 AdminUserCreation
Table 6-14 AdminUserCreation
Field Details
Trigger Condition
If a new admin account is created in the last 5 min
Severity Warning
Description: '{{ $value }} admin users have been created by {{$labels.UserName}} '
summary: {{$labels.pod}}, user: {{$labels.UserName}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Admin users have been created '
summary: {{$labels.kubernetes_pod_name}}, user: {{$labels.UserName}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Admin users have been created '
OID used for SNMP Traps 1.3.6.1.4.1.323.5.3.51.1.2.7006
Resolution
The alert gets cleared when the total failed login attempts for a particular user go below the threshold value (default value is '3') in the last 5 min (default value is 5 m)
Note: The threshold and time is configurable in the occncc_alertrules_<version>.yaml file.
Login to admin GUI and review the user created.
6.1.15 CnccIamAccessTokenFailure
Table 6-15 CnccIamAccessTokenFailure
Field Details
Trigger Condition
If the count of failed token for CNCC-IAM goes above configured value of '3'
Severity Warning
Description: 'CNCC Iam Access Token Failure count is above the configured value i.e. 3 for every 5 min. Failed access token request count per second is (current value is: {{ $value }})'
summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Access Token Failure count is above the configured threshold value'
summary: 'namespace: {{$labels.kubernetes_namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Access Token Failure count is above the configured threshold value'
OID used for SNMP Traps 1.3.6.1.4.1.323.5.3.51.1.2.7007
Resolution
The alert gets cleared when the total failed tokens for a particular user go below the threshold value (default value is '3') in the last 5 min (default value is 5 m)
6.2 CNC Console Core Alerts
This section provides the information about CNC Console Core Alerts.
6.2.1 CnccCoreTotalIngressTrafficRateAboveMinorThreshold
Table 6-16 CnccCoreTotalIngressTrafficRateAboveMinorThreshold
Field Details
Trigger Condition
The total CNCC Core Ingress Message rate has crossed the configured minor threshold of 700 TPS.
Default value of this alert trigger point in cncc_alert_rules.yaml is when CNCC Core Ingress Rate crosses 70 % of 1000 (Maximum ingress request rate)
Severity Minor
Description: 'CNCC Core Ingress traffic Rate is above the configured minor threshold i.e. 700 requests per second (current value is: {{ $value }})'
OID used for SNMP Traps 1.3.6.1.4.1.323.5.3.51.1.2.8001
Resolution
The alert is cleared either when the total Ingress traffic rate falls below the minor threshold or when the total traffic rate crosses the major threshold, in which case the CnccCoreTotalIngressTrafficRateAboveMajorThreshold alert is raised.
Steps:
  1. Reassess why the CNCC Core is receiving additional traffic.
6.2.2 CnccCoreTotalIngressTrafficRateAboveMajorThreshold
Table 6-17 CnccCoreTotalIngressTrafficRateAboveMajorThreshold
Field Details
Trigger Condition The total CNCC Core Ingress Message rate has crossed the configured major threshold of 800 TPS.
Default value of this alert trigger point in cncc_alert_rules.yaml is when CNCC Core Ingress Rate crosses 80 % of 1000 (Maximum ingress request rate)
Severity Major
Description: 'CNCC Core Ingress traffic Rate is above the configured major threshold i.e. 800 requests per second (current value is: {{ $value }})'
Resolution The alert is cleared when the total Ingress Traffic ratefalls below the Major threshold or when the total traffic rate cross the Critical threshold, in which case the CnccCoreTotalIngressTrafficRate Above CriticalThreshold.
Note: The threshold is configurable in the alerts.yaml file.
Steps:
6.2.3 CnccCoreTotalIngressTrafficRateAboveCriticalThreshold
Table 6-18 CnccCoreTotalIngressTrafficRateAboveCriticalThreshold
Field Details
Trigger Condition
The total CNCC Core Ingress Message rate has crossed the configured critical threshold of 900TPS.
Default value of this alert trigger point in cncc_alert_rules.yaml is when CNCC Core Ingress Rate crosses 90 % of 1000 (Maximum ingress request rate)
Severity Critical
Description: 'CNCC Core Ingress traffic Rate is above the configured critical threshold i.e. 900 requests per second (current value is: {{ $value }})'
Resolution
Steps:
6.2.4 CnccCoreMemoryUsageCrossedMinorThreshold
Table 6-19 CnccCoreMemoryUsageCrossedMinorThreshold
Field Details
Trigger Condition
Severity Minor
Description: 'CNCC Core Memory Usage for pod {{ $labels.pod }} has crossed the configured minor threshold (70%) (value={{ $value }}) of its limit.'
OID used for SNMP Traps 1.3.6.1.4.1.323.5.3.51.1.2.8002
Metric Used
Note : This is a kubernetes metric used for instance availability monitoring. If the metric is not available, use the similar metric as exposed by the monitoring system.
Resolution
The alert gets cleared when the memory utilization falls below the Minor Threshold or crosses the major threshold, in which case CnccCoreMemoryUsageCrossedMajorThreshold alert is raised.
6.2.5 CnccCoreMemoryUsageCrossedMajorThreshold
Table 6-20 CnccCoreMemoryUsageCrossedMajorThreshold
Field Details
Trigger Condition
Severity Major
Description: 'CNCC Core Memory Usage for pod {{ $labels.pod }} has crossed the configured major threshold (80%) (value = {{ $value }}) of its limit.'
Metric Used
Resolution
The alert gets cleared when the memory utilization falls below the Major Threshold or crosses the critical threshold, in which case CnccCoreMemoryUsageCrossedCriticalThreshold alert is raised
6.2.6 CnccCoreMemoryUsageCrossedCriticalThreshold
Table 6-21 CnccCoreMemoryUsageCrossedCriticalThreshold
Field Details
Trigger Condition
Severity Critical
Description: 'CNCC Core Memory Usage for pod {{ $labels.pod }} has crossed the configured critical threshold (90%) (value = {{ $value }}) of its limit.'
Metric Used
Note : This is a Kubernetes metric used for instance availability monitoring. If the metric is not available, use the similar metric as exposed by the monitoring system.
Resolution
6.2.7 CnccCoreTransactionErrorRateAbove0.1Percent
Table 6-22 CnccCoreTransactionErrorRateAbove0.1Percent
Field Details
Trigger Condition The number of failed transactions is above 0.1 percent of the total transactions..
Severity Warning
Description:'CNCC Core transaction Error rate is above 0.1 Percent of Total Transactions (current value is {{ $value }})'
Summary:'CNCC Core transaction Error rate is above 0.1 Percent of Total Transactions (current value is {{ $value }})'
OID used for SNMP Traps 1.3.6.1.4.1.323.5.3.51.1.2.8003
Resolution
The alert is cleared when the number of failed transactions are below 0.1% of the total transactions or when the number of failed transactions cross the 1% threshold in which case the CnccCoreTransactionErrorRateAbove1Percent is raised.
Steps:
6.2.8 CnccCoreTransactionErrorRateAbove1Percent
Table 6-23 CnccCoreTransactionErrorRateAbove1Percent
Field Details
Severity Warning
Description: 'CNCC Core transaction Error rate is above 1 Percent of Total Transactions (current value is {{ $value }})'
Summary:'CNCC Core transaction Error Rate detected above 1 Percent of Total Transactions'
Resolution
The alert is cleared when the number of failed transactions are below 1% of the total transactions or when the number of failed transactions crosses the 10% threshold in which case the CnccCoreTransactionErrorRateAbove10Percent is raised.
Steps:
  2. If guidance is required,contact My Oracle Support.
6.2.9 CnccCoreTransactionErrorRateAbove10Percent
Table 6-24 CnccCoreTransactionErrorRateAbove10Percent
Field Details
Severity Minor
Description: 'CNCC Core transaction Error rate is above 10 Percent of Total Transactions (current value is {{ $value }})'
summary: 'CNCC Core ransaction Error Rate detected above 10 Percent of Total Transactions'
Resolution
The alert is cleared when the number of failed transactions are below 10% of the total transactions or when the number of failed transactions crosses the 25% threshold in which case the CnccCoreTransactionErrorRateAbove25Percent is raised.
Steps:
6.2.10 CnccCoreTransactionErrorRateAbove25Percent
Table 6-25 CnccCoreTransactionErrorRateAbove25Percent
Field Details
Severity Major
Description: 'CNCC Core transaction Error Rate detected above 25 Percent of Total Transactions (current value is {{ $value }})'
Summary: 'CNCC Core transaction Error Rate detected above 25 Percent of Total Transactions'
Resolution
The alert is cleared when the number of failed transactions are below 25% of the total transactions or when the number of failed transactions crosses the 50% threshold in which case the CnccCoreTransactionErrorRateAbove50Percent is raised.
Steps:
6.2.11 CnccCoreTransactionErrorRateAbove50Percent
Table 6-26 CnccCoreTransactionErrorRateAbove50Percent
Field Details
Severity Critical
Description: 'CNCC Core transaction Error Rate detected above 50 Percent of Total Transactions (current value is {{ $value }})'
Summary: 'CNCC Core transaction Error Rate detected above 50 Percent of Total Transactions'
Resolution
The alert is cleared when the number of failed transactions are below 50 percent of the total transactions
Steps:
6.2.12 CnccCoreIngressGatewayServiceDown
Table 6-27 CnccCoreIngressGatewayServiceDown
Field Details
Trigger Condition Cncc Core Ingress Gateway service is down
Severity Critical
Description: 'CNCC Core Ingress-Gateway service InstanceIdentifier=~".*core_ingressgateway" is down'
OID used for SNMP Traps 1.3.6.1.4.1.323.5.3.51.1.2.8004
Metric Used
'up'
Resolution
The alert is cleared when the cncc-core_ingressgateway service is available.
Steps:
  1. Check the orchestration logs of cncc-core_ingressgateway service and check for liveness or readiness probe failures.
  2. Refer the application logs on Kibana and filter based on cncc-core_ingressgateway service names. Check for ERROR WARNING logs related to thread exceptions.
6.2.13 CnccCoreFailedLogin
Table 6-28 CnccCoreFailedLogin
Field Details
Trigger Condition
The count of failed login attempts in CNCC-Core by a user goes above '3'
Severity Warning
Description:'{{ $value }} failed Login attempts have been detected in CNCC Core for user {{$labels.UserName}}, the configured threshold value is 3 failed login attempts for every 5 min'
OID used for SNMP Traps 1.3.6.1.4.1.323.5.3.51.1.2.8005
Resolution
6.2.14 CnccCoreUnauthorizedAccess
Table 6-29 CnccCoreUnauthorizedAccess
Field Details
Trigger Condition
Severity Warning
Description:'{{ $value }} Unauthorized Accesses have been detected in CNCC-Core for {{$labels.ResourceType}} for {{$labels.Method}} request. The configured threshold value is 3 for every 5 min'
summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.pod}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Unauthorized Access for CNCC-Core are more than threshold value'
summary: 'namespace: {{$labels.kubernetes_namespace}}, podname: {{$labels.kubernetes_pod_name}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Unauthorized Access for CNCC-Core are more than threshold value'
OID used for SNMP Traps 1.3.6.1.4.1.323.5.3.51.1.2.8006
Resolution
6.2.15 CnccCoreAccessTokenFailure
Table 6-30 CnccCoreAccessTokenFailure
Field Details
Trigger Condition
If the count of failed token for CNCC-Core goes above configured value of '3'
Severity Warning
Description: 'CNCC Core Access Token Failure count is above the configured value i.e. 3 for every 5 min. Failed access token request count per second is (current value is: {{ $value }})'
summary: 'namespace: {{$labels.namespace}}, podname: {{$labels.kubernetes_pod_name}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Access Token Failure count is above the configured threshold value'
summary: 'namespace: {{$labels.kubernetes_namespace}}, podname: {{$labels.kubernetes_pod_name}}, timestamp: {{ with query "time()" }}{{ . | first | value | humanizeTimestamp }}{{ end }}: Access Token Failure count is above the configured threshold value'
OID used for SNMP Traps 1.3.6.1.4.1.323.5.3.51.1.2.8007
Resolution
If guidance is required, Contact My Oracle Support.
6.3 CNC Console Alerts on OCI
This section provides information about CNC Console Alerts on OCI:
6.3.1 CnccCoreTotalIngressTrafficRateAboveMinorThreshold
Table 6-31 CnccCoreTotalIngressTrafficRateAboveMinorThreshold
Field Details
Trigger Condition
Severity minor
Alert details provided CNCC Core Ingress traffic Rate is above the configured minor threshold i.e. 700 requests per second
Resolution The alert is cleared either when the total Ingress Traffic rate falls below the Minor threshold or when the total traffic rate cross the Major threshold, inwhich case the CnccCoreTotalIngressTrafficRateAboveMajorThresholdalert shall be raised.Note: The threshold is configurable in the alerts.yamlSteps:Reassess why the CNCC Core is receiving additionaltraffic.If this is unexpected, contact My Oracle Support.
6.3.2 CnccCoreTotalIngressTrafficRateAboveMajorThreshold
Table 6-32 CnccCoreTotalIngressTrafficRateAboveMajorThreshold
Field Details
Trigger Condition
Severity major
Alert details provided CNCC Core Ingress traffic Rate is above the configured major threshold i.e. 800 requests per second
Resolution The alert is cleared when the total Ingress Traffic ratefalls below the Major threshold or when the total traffic rate cross the Critical threshold, in which casethe CnccCoreTotalIngressTrafficRateAboveCriticalThresholdNote: The threshold is configurable in the alerts.yaml alert shall be raised.Steps:Reassess why the CNCC Core is receiving additionaltraffic.If this is unexpected, contact My Oracle Support.
6.3.3 CnccCoreTotalIngressTrafficRateAboveCriticalThreshold
Table 6-33 CnccCoreTotalIngressTrafficRateAboveCriticalThreshold
Field Details
Trigger Condition
Severity critical
Alert details provided CNCC Core Ingress traffic Rate is above the configured critical threshold i.e. 900 requests per second
Resolution The alert is cleared when the Ingress Traffic rate falls below the Critical threshold.Note: The threshold is configurable in the alerts.yamlSteps:Reassess why the CNCC Core is receiving additional traffic.If this is unexpected, contact My Oracle Support.
6.3.4 CnccCoreMemoryUsageCrossedMinorThreshold
Table 6-34 CnccCoreMemoryUsageCrossedMinorThreshold
Field Details
Severity minor
Alert details provided CNCC Core Memory Usage for pod has crossed the configured minor threshold (70%) of its limit.
Metric Used
Resolution
The alert gets cleared when the memory utilization falls below the Minor Threshold or crosses the major threshold, in which case CnccCoreMemoryUsageCrossedMajorThreshold alert shall be raised
Note : The threshold is configurable in the alerts.yaml
If guidance required, Contact My Oracle Support.
6.3.5 CnccCoreMemoryUsageCrossedMajorThreshold
Table 6-35 CnccCoreMemoryUsageCrossedMajorThreshold
Field Details
Severity major
Alert details provided CNCC Core Memory Usage for pod has crossed the configured major threshold (80%) of its limit.
Metric Used
Resolution
The alert gets cleared when the memory utilization falls below the Major Threshold or crosses the critical threshold, in which case CnccCoreMemoryUsageCrossedCriticalThreshold alert shall be raised
6.3.6 CnccCoreMemoryUsageCrossedCriticalThreshold
Table 6-36 CnccCoreMemoryUsageCrossedCriticalThreshold
Field Details
Severity critical
Alert details provided CNCC Core Memory Usage for pod has crossed the configured critical threshold (90%) of its limit.
Metric Used
Resolution
6.3.7 CnccCoreTransactionErrorRateAbovePointOnePercent
Table 6-37 CnccCoreTransactionErrorRateAbovePointOnePercent
Field Details
Severity warning
Alert details provided CNCC Core transaction Error rate is above 0.1 Percent of Total Transactions
Resolution The alert is cleared when the number of failure transactions are below 0.1% of the total transactions or when the number of failure transactions cross the 1% threshold in which case the CnccCoreTransactionErrorRateAbove1Percent shall beraised.Steps:1. Check the Service specific metrics to understand the specific service request errors.2. If guidance required, contact My Oracle Support.
6.3.8 CnccCoreTransactionErrorRateAboveOnePercent
Table 6-38 CnccCoreTransactionErrorRateAboveOnePercent
Field Details
Severity warning
Alert details provided CNCC Core transaction Error rate is above 1 Percent of Total Transactions
Resolution The alert is cleared when the number of failure transactions are below 1% of the total transactions or when the number of failure transactions cross the 10% threshold in which case the CnccCoreTransactionErrorRateAbove10Percent shall beraised.Steps:1. Check the Service specific metrics to understand the specific service request errors.2. If guidance required, contact My Oracle Support.
6.3.9 CnccCoreTransactionErrorRateAboveTenPercent
Table 6-39 CnccCoreTransactionErrorRateAboveTenPercent
Field Details
Severity minor
Alert details provided CNCC Core transaction Error rate is above 10 Percent of Total Transactions
Resolution The alert is cleared when the number of failure transactions are below 10% of the total transactions or when the number of failure transactions cross the 25% threshold in which case the CnccCoreTransactionErrorRateAbove25Percent shall beraised.Steps:1. Check the Service specific metrics to understand the specific service request errors.2. If guidance required, contact My Oracle Support.
6.3.10 CnccCoreTransactionErrorRateAboveTwentyFivePercent
Table 6-40 CnccCoreTransactionErrorRateAboveTwentyFivePercent
Field Details
Severity major
Alert details provided CNCC Core transaction Error Rate detected above 25 Percent of Total Transactions
Resolution The alert is cleared when the number of failure transactions are below 25% of the total transactions or when the number of failure transactions cross the 50% threshold in which case the CnccCoreTransactionErrorRateAbove50Percent shall beraised.Steps:1. Check the Service specific metrics to understand the specific service request errors.2. If guidance required, contact My Oracle Support.
6.3.11 CnccCoreTransactionErrorRateAboveFiftyPercent
Table 6-41 CnccCoreTransactionErrorRateAboveFiftyPercent
Field Details
Severity critical
Alert details provided CNCC Core transaction Error Rate detected above 50 Percent of Total Transactions
Resolution The alert is cleared when the number of failure transactions are below 50 percent of the total transactions.Steps:1. Check the Service specific metrics to understand the specific service request errors.2. If guidance required, contact My Oracle Support.
6.3.12 CnccCoreUnauthorizedAccess
Table 6-42 CnccCoreUnauthorizedAccess
Field Details
Trigger Condition If the count of unauthorized access goes above the configured value of '3'
Severity warning
Alert details provided Unauthorized Accesses have been detected in CNCC-Core for request. The configured threshold value is 3 for every 5 min
Resolution
The alert gets cleared when the total unauthorized accesses for a particular user go below the threshold value (default value is '3') in the last 5 min (default value is 5 m)
Note : The threshold and time is configurable in the alerts.yaml
