6 Deploying Network Bridge
You can deploy Oracle Communications Network Bridge on a cloud native environment by running the Helm install command.
Topics in this document:
Deploying Network Bridge Cloud Native
To deploy Network Bridge on your cloud native environment:
Create a namespace for the Network Bridge Helm chart:
kubectl create namespace NBNameSpace
where NBNameSpace is the namespace in which to create Kubernetes objects for the Network Bridge Helm chart.
Validate the content of your Helm chart by running the Helm lint command:
helm lint --strict oc-ccs-helm-chart-version --values oc-ccs-helm-chart-version/values.yaml --values OverrideValuesFile
You'll see this if the command completes successfully:
1 chart(s) linted, no failures
Validate the values in your override-values.yaml file by using the helm template command:
helm template NBReleaseName oc-ccs-helm-chart-versionwhere NBReleaseName is the release name for oc-ccs-helm-chart-version and is used to track this installation instance.
Deploy Network Bridge by running this command:
helm install NBReleaseName oc-ccs-helm-chart-version --namespace NBNameSpace --values override-values.yaml -
Verify that the pods were deployed successfully by running this command:
kubectl -n NbNameSpace get podsYou should see something similar to this:
NAME READY STATUS RESTARTS AGE diameter-adapter-d2h-6f79d95887-lp7qs 1/1 Running 0 6d17h diameter-adapter-h2d-5496bf8d94-vjgn7 1/1 Running 0 6d17h diameter-proxy-d5ccf6dbd-l968b 1/1 Running 0 6d17h diameter-proxy-db-job-22bsg 0/1 Completed 0 7d5h egress-7b974f4488-wx9qz 1/1 Running 0 7d4h mediation-75f9dcd99d-vrrwg 1/1 Running 0 7d4h oc-ccs-ndb-mgmd-0 1/1 Running 0 7d5h oc-ccs-ndb-mgmd-1 1/1 Running 0 7d5h oc-ccs-ndb-mysqld-0 1/1 Running 0 7d5h oc-ccs-ndb-mysqld-1 1/1 Running 0 7d5h oc-ccs-ndb-ndbmtd-0 1/1 Running 0 7d5h oc-ccs-ndb-ndbmtd-1 1/1 Running 0 7d5h
