40 Default Termination Range
The Default Termination Range tab enables you to add, edit and delete the default termination number ranges that apply to the following feature nodes:
Unconditional Termination
Attempt Termination
No Lookup and Translation
Follow Me Number
These default ranges are assigned to the customer on the New Customer dialog box of the ACS Customer screen. See Adding Customers.
Note: For more information about setting up individual customer termination number ranges see the Termination Rangestab of the ACS Resources screen procedure.
Default Termination Range fields
Here is a description of the fields used when managing default termination ranges.
| Field | Description |
| Termination Number Range | The default termination number ranges that are currently configured for ACS. |
| Prefix | The prefix of the termination number. |
| Minimum Digits | The minimum number of digits permitted for the termination number. |
| Maximum Digits | The maximum number of digits permitted for the termination number. |
Adding a Default Termination Range
Follow these steps to add a new default termination range.
On the Default Termination Range tab, click New.
Result: The New Termination Range screen is displayed.
See Default Termination Range fields for details.
In the Prefix field, enter the prefix for the termination number.
In the Minimum Digits field, enter the minimum number of digits.
In the Maximum Digits field, enter the maximum number of digits.
Result: As you type, the Range Model field displays the termination range, with the minimum digits after the prefix displayed as Xs and the maximum digits displayed as Ys, for example
0800XXYYYY. -
Click Save.
Related topic
Editing a Default Termination Range
Follow these steps to edit an existing default termination range.
On the Default Termination Range tab, select the default termination range to edit.
Click Edit.
Result: The Edit Termination Range screen is displayed.
Change the value as required. See Default Termination Range fields for details.
Click Save.
Related topic
