8 XMS Parameters Feature Nodes
This chapter describes the Oracle Communications Convergent Charging Controller Messaging Manager XMS Parameters feature nodes.
This chapter contains the following topics.
Alphabet Branching
The Alphabet Branching node determines if the message text is using the alphabet specified in this node and branches accordingly.
Content Size Branching
The Content Size Branching node branches depending on the size of the short message (in bytes). It takes the threshold entered into the node and chooses either the small or large branch.
Message Attribute Branching
Branches on the value of a message attribute. Branching is based on the result of a logical comparison between a value and the value in the corresponding message attribute.
Node exits
This node has one entry and four exits. The number of exits cannot be changed.
Exit | Cause | Description |
1 | Less Than | The value in the message is lower than the value configured in the node. |
2 | Equals | The value in the message is the same as the value configured in the node. |
3 | Greater Than | The value in the message is greater than the value configured in the node. |
4 | Not Found | An error occurred during the comparison. |
Note: Strings are evaluated against ASCII order, on a character-by-character basis starting with the left-hand character.
Configuring the node
Follow these steps to configure the node.
Configure this record by entering data in the fields on the Configure Set Message Attribute screen.
For more information about the fields on this screen, see Configuration fields.
Click Save.
This table describes the function of each field.
Field | Description |
Attribute | The message attribute to compare. |
Value Type | The type of value the attribute will be compared with. |
Fixed |
The value the message attribute will be compared with. Note: This field is only available if the Value
Type field is set to |
Enumerated |
The value the message attribute will be compared with. Notes:
Source Location |
The profile block which stores the value the message attribute will be compared with. Notes:
Source Field |
The profile field which stores the value the message attribute will be compared with. Notes:
Enumerated fields
This table describes the list of enumerated values which are available to the Message Attribute nodes.
Group Name | Value | Description |
ATTRIBUTE | SRR | Status report (delivery receipt) request |
ATTRIBUTE | RRR | Read-reply report request |
ATTRIBUTE | SMS_CLASS | SMS Message class |
ATTRIBUTE | MW_TYPE | Message waiting type |
ATTRIBUTE | MW_SENSE | Message waiting sense |
ATTRIBUTE | MW_GROUP | Message waiting group |
ATTRIBUTE | PRIORITY | NA |
ATTRIBUTE | SINGLE_SHOT | Single-shot |
ATTRIBUTE | RECIPIENTS | Number of recipients |
ATTRIBUTE | RECIPIENT | Current recipient |
ATTRIBUTE | SIZE | Message size |
ATTRIBUTE | MMS_CLASS | MMS message class |
ATTRIBUTE | ADAPTATION | Content adaptation |
ATTRIBUTE | TIME_ZONE | NA |
ATTRIBUTE | SERVICE_CODE | NA |
ATTRIBUTE | BILLING_INFO | Billing Identifier |
ATTRIBUTE | VP_TYPE | Validity Period Type |
ATTRIBUTE | VALIDITY | Validity Period |
ATTRIBUTE | MESSAGE_TYPE | NA |
ATTRIBUTE | CHARGED_PARTY | NA |
ATTRIBUTE | VAS_ID | NA |
ATTRIBUTE | VASP_ID | NA |
SRR | 0 | None requested |
SRR | 1 | SME requested |
SRR | 2 | MMX requested |
SRR | 3 | Both requested |
RRR | 0 | Not requested |
RRR | 1 | Requested |
SMS_CLASS | 0 | None |
SMS_CLASS | 1 | Display (GSM 0) |
SMS_CLASS | 2 | Mobile Equipment (GSM 1) |
SMS_CLASS | 3 | SIM (GSM 2) |
SMS_CLASS | 4 | External (GSM 3) |
MW_TYPE | 0 | None |
MW_TYPE | 1 | Voicemail |
MW_TYPE | 2 | Fax |
MW_TYPE | 3 | |
MW_TYPE | 4 | Other |
MW_SENSE | 0 | Inactive |
MW_SENSE | 1 | Active |
MW_GROUP | 0 | None |
MW_GROUP | 1 | Discard |
MW_GROUP | 2 | Store |
PRIORITY | 0 | Normal |
PRIORITY | 1 | Interactive |
PRIORITY | 2 | Urgent |
PRIORITY | 3 | Emergency |
SINGLE_SHOT | 0 | False |
SINGLE_SHOT | 1 | True |
MMS_CLASS | 0 | None |
MMS_CLASS | 1 | Personal |
MMS_CLASS | 2 | Advert |
MMS_CLASS | 3 | Info |
MMS_CLASS | 4 | Auto |
ADAPTATION | 0 | False |
ADAPTATION | 1 | True |
VP_TYPE | 0 | Relative |
VP_TYPE | 1 | Absolute |
MESSAGE_TYPE | 0 | Submit |
CHARGED_PARTY | 0 | Neither |
CHARGED_PARTY | 1 | Sender |
CHARGED_PARTY | 2 | Recipient |
CHARGED_PARTY | 3 | Both |
CHARGED_PARTY | 0 |
CHARGED_PARTY | 1 |
text/*
CHARGED_PARTY | ... | NA |
Segment Number Branching
The Segment Number Branching node branches, depending on if the current message is the last (or only) component in a concatenated, multi-part, message. It compares the current segment number with the total number of segments and takes the appropriate exit.
Node exits
1 | Only Segment | The message contains only one segment. |
2 | First Segment | There is more than one segment in the message and the segment number is one. |
3 | Middle Segment | There is more than one segment in the message and the segment number does not match the number of segments. |
4 | Last Segment | There is more than one segment in the message and the segment number matches the number of segments. |
Set Data Coding
The Set Data Coding node sets the character set of the message to be used when the ACS Control Plan passes the message on to Messaging Manager for delivery.
Node exits
This node has one entry and two exits. The number of exits cannot be changed.
1 | Success |
The configured alphabet has been successfully selected. Note: The Set Data Coding node does not change the data coding in ACS, but it does define the data coding used when the message is returned to Messaging Manager. This occurs when the message is actually ready to be sent. Consequently, the TP-DCS known to ACS in the Control Plan is still the original TP-DCS, and its value does not change when leaving this node through the Success branch. |
2 | Failure | General error occurred. |
Allows the modification various attributes of the message data by overriding the options requested by a caller.
To set a message's time zone to the time zone of the user, see Set Time Zone Message Attribute.
Node exits
1 | Success | The specified attribute was set successfully. |
2 | Failure | The node failed to change the specified attribute. |
Click Save.
Fixed |
Enumerated |
Source Location |
Source Field |
Sets the message time zone attribute to the user's time zone.
To set other message attributes, see Set Message Attribute.
To branch on message attributes (including time zone), see Message Attribute Branching.
Node exits
1 | Success | The time zone was set successfully. |
2 | Failure | An error occurred and the time zone was not set. |
Configure this record by entering data in the fields on the Configure Set Time Zone Message Attribute screen.
Click Save.
Test Data Coding
The Test Data Coding node checks the message for compatibility with the specified (in this node) destination alphabet.
This node is used to determine if the message can be converted to the specified alphabet. If not then the control plan can be set to compare against another alphabet in another instance of this mode.
Node exits
1 | Pass | The message will be convertible to the destination alphabet with less than or equal to the allowed character conversion failures. |
2 | Fail | The message will not be converted to the destination alphabet without incurring more than the allowed character conversion failures. |
Follow these steps to edit the node configuration.
Select the destination alphabet for the message to be converted to from the Alphabet drop down list.
Enter the maximum number of characters that cannot be converted to the destination alphabet before failing the conversion test in the Misses Allowed field.
Click Save.
