1 PI Commands
The Commands tab of the PI Administration screen enables you to set the security level for PI commands.
Note: Commands cannot be added to or removed from the list of available commands.
Commands fields
This table describes the function of each field.
Field | Description |
Name | The PI command name. |
Security Level | The security level required to execute the command. |
Subscriber Domain | Indicates the command applies to an account that belongs to the subscriber domain, that is, the account exists on the SMS, the account wallet may be on a VWS or on a third party billing engine. |
Wallet Domain | Indicates the command applies to an account that belongs to the wallet domain, that is, both the account and wallet exists on the SMS and VWS. |
Voucher Domain | Indicates the command applies to a voucher that belongs to the voucher domain, that is, a voucher that exists on the VWS. |
Editing PI commands
Follow these steps to edit a PI command.
From the list of PI commands on the Commands tab, select the command you want to edit.
Click Edit.
Result: The edit dialog box for the selected command appears. See Commands fieldsCommands fields for a description of each field.
Change the Security Level as required.
Note: Range is 1 to 99 (highest) inclusive.
Click Save.
Result: The details are saved to the database.
Soft restart the PI. For details, see Soft PI Restart in PI User's and Technical Guide.
Result: The updated configuration details will be loaded by the PImanager.
Related topic
