2 Using SES Feature Nodes
This chapter explains how SES uses ACS. This includes details on the SES specific feature nodes that are used in the ACS Control Plan Editor (CPE). These check subscribers on entering or leaving a network using SES and determine whether to send them messages and if so, determine the number of messages to be sent.
For an overview of ACS and the ACS Control Plan Editor, see the relevant ACS or CPE user's guides.
This chapter contains the following topics.
In-Roamer Contact Check
When a roaming subscriber enters your network, this node checks the duration since any previous inbound roaming contact with the subscriber, by looking up the contact history, and compares the duration with the period of days configured in the node.
Node exits - In-Roamer Contact Check
This node has one entry and two exits. The number of exits cannot be changed.
| Exit | Cause | Description |
| 1 | Contacted | The subscriber has been contacted within the configured number of days. |
| 2 | Not Contacted | The subscriber has not been contacted within the configured number of days (includes never been contacted and any system failures). |
In-Roamer Messages Selection
This node selects the messages for sending to the subscriber, based on the message priority, the number of messages to be sent, and the message selection option used. For more information, see SES User's and Technical Guide, System Overview chapter.
Node exits - In-Roamer Messages Selection
| 1 | No Messages Selected | No messages were selected (includes system failures). |
| 2 | Messages Selected | At least one message was selected. |
Using the node - In-Roamer Messages Selection
For descriptions of how this node is used, refer to the following topics in SES User's and Technical Guide:
Example Control Plan - In-Roamer
Example scenarios
Editing the node - In-Roamer Messages Selection
Follow these steps to edit the In-Roamer Messages Selection node.
Type the maximum number of messages to send to the subscriber in the Number field.
Note: Currently the maximum is about 2 billion.
Select either the Random or Latest message Selection Method.
Note: Messages are configured to be priority, or non priority (see SES User's and Technical Guide, SES Configuration - Messages Tab). For either option, the priority messages are used to fulfill the Number parameter before the non priority messages. See SES User's and Technical Guide, SES Example scenarios.
Note: Latest is the message with the most recent availability date.
Click Save.
Out-Roamer Contact Check
When a roaming subscriber leaves your network, this node checks the duration since any previous out-roaming contact with the subscriber, by looking up the contact history, and compares the duration with the period of days configured in the node.
Node exits - Out-Roamer Contact Check
This node has one entry and three exits. The number of exits cannot be changed.
| 1 | Opted Out |
The subscriber has opted out of being contacted on leaving the network. Note: This flag is configurable. Refer to SES
User's and Technical Guide, |
| 2 | Contacted | The subscriber has been contacted within the configured number of days. |
| 3 | Not Contacted | The subscriber has not been contacted within the configured number of days (includes never been contacted and any system failures). |
Out-Roamer Messages Selection
This node selects the messages for sending to the subscriber, based on the message priority, the number of messages to be sent, and the message selection option used. For more information, see the discussion of system overview in Subscriber Event Service User's and Technical Guide.
Node exits - Out-Roamer Messages Selection
Using the node - Out-Roamer Messages Selection
For descriptions of how this feature node is used, see the following topics in Subscriber Event Service User's and Technical Guide:
Example Control Plan - Out-Roamer
Example scenarios
Configuring the node - Out-Roamer Messages Selection
Follow these steps to edit the Out-Roamer Messages Selection node.
Note: Currently this is about 2 billion.
Note: Messages are configured to be priority or no priority (see Messages). For either option, the priority messages are used to fulfill the Number parameter before the no priority messages. See SES Example scenarios.
Click Save.
