28 Incoming Number Restrictions
Allowed and barred numbers in the ACS Resources screen are provisioned on a per customer basis.
Each customer has one incoming and one outgoing list. Each of these lists must be classed as either “Allowed” or “Barred”.
Allowed numbers are allowed only if they occur in the list. If the list is empty then no numbers are allowed – everything is barred.
Barred numbers are barred only if they occur in the list. If the list is empty then no numbers are barred – everything is allowed.
Use with Call Filtering Node
While the primary use of the lists is to allow or bar, based on service number (incoming, or CLI (outgoing) they may in fact be used to compare against any type of number available in the Call Filtering feature node in the ACS Control Plan Editor.
The lists can be applied in control plans by selecting the service number profile or CLI profile in the Call Filtering node in the CPE. As mentioned earlier, these lists may be used to match against any type of number but are labeled “Incoming” and “Outgoing” for convenience.
Examples:
You have an INCOMING ALLOWED list containing the numbers 555-1234, 555-1235, and 555-1236. Calls to the service numbers 555-1234, 555-1235, and 555-1236 are allowed but calls to all other numbers are not allowed, so a call to 444-5555 would not be allowed.
You have an INCOMING BARRED list containing the same numbers. Calls to the service numbers listed will not be allowed; calls to all other service numbers are allowed.
You have an OUTGOING ALLOWED list containing the same numbers. An outgoing call to CLI 555-1234 would be allowed (as would 555-1235 and 555-1236). Outgoing calls to any other CLI would be be barred.
You have an OUTGOING BARRED list containing the same numbers. An outgoing call to CLI 555-1234 would be barred (as would 555-1234 and 555-1236). Outgoing calls to any other CLI would be allowed.
Use with Prefix Tree Branching Node
The Prefix Tree Branching node allows you to select incoming or outgoing list data and branch on whether the number is in that list or not. Used in conjunction with other nodes, such as Profile Branching, you can determine whether it is the barred or allowed list and branch accordingly.
Number Restrictions Tab Fields
Here is a description of the fields used when setting incoming and outgoing number restrictions.
| Field | Description |
| Restriction List |
Displays the list of restricted numbers in the number profile. You can:
| List Type |
Each ACS customer has one incoming and one outgoing restriction list. The list must be classed as either "Allowed" or "Barred". If list type is:
| Ignore | Select this check box if you want to ignore the restricted numbers list displayed. |
| New Number |
Use this field to add a new number to the restricted numbers list. Enter the new number then click Add to send it to the list. |
Editing Incoming No. Restrictions
Follow these steps to edit numbers in an incoming number restrictions list.
Tip: You can set number restrictions at the SN or CLI level in the Numbers screen.
On the Incoming No. Restrictions tab, select the type of list from the List Type drop down list. If you select
Allowed, only listed numbers will be allowed. If you selectBarred, all numbers are allowed, except for the listed numbers. -
If you want the incoming number restrictions to be ignored for this customer, select the Ignore check box.
In the New Number field, enter a number to add to the list and click Add.
Result: The number will be added to the restriction list.
From the Restriction List, select a number to remove and click Remove.
Result: The number will be removed from the restriction list.
Click Save.
Result: The changes will be saved to the database.
