2 Find Results Mode
This chapter explains how to use the find results.
This chapter contains the following topics.
Find Flag Results
This table describes the content of each column.
Column | Description |
Flag | The unique flag name. |
Description | Flag description. |
Last User | Name of last user to amend (or add) this record |
Last Date | Date when this record was added or amended |
ID | Record number within the database table |
Selecting record for update
To amend any of the records in the results list, click on the row to change, then click Select.
Result: The record detail is displayed in Update Mode.
Find Services Results
Service | The unique name of the service. |
Description | A brief description of the service. |
Find Subscriber or Operator Results
Name | The operator or subscriber name, depending on the option selected. |
Number Start | The start of number in a range for this operator or subscriber. |
Number End | The last number in a range for this operator or subscriber. |
Entry Type | Indicator of type of list, either O(perator), or S(ubscriber). |
Find NAPTR Records Results
Subscriber/Operator | The subscriber or operator name |
Description | Description of the record. |
Order | A 16-bit unsigned integer that specifies the processing order of the NAPTR records, with lower-numbered records processed before higher-numbered records. |
Preference |
A 16-bit unsigned integer that specifies a processing preference within NAPTR records that have equal order values. The distinction between the order and preference values is that a client can process records having the same order number but different preference numbers, but cannot process records with a different order number after a match is found. |
Flag |
A character that governs the interpretation and rewriting of the record's fields. Letters can be either uppercase or lowercase. Only values S, A, U, and P are defined. The S, A and U flags indicate that the current NAPTR record is the last one and they determine what the next action will be.
The letter P specifies that the rest of the application algorithm is executed in a manner that is consistent with a specified protocol. The rules are identified by the protocol specified in the Services field. See the standards documentation for the naming authority pointing dns resource record for more information on these values. |
Service | The service name. |
Regular Expression |
A string that holds a regular expression to apply to the client's original string to create the next domain name to look up. See the standards documentation for the Naming Authority Pointer DNS Resource Record for information on the substitution rules The regular expression must be applied only to the client's original string and not to a domain name that was produced by a previous NAPTR rewrite. |
Replacement | The next name to query for NAPTR, SRV, or address records depending on the value of the Flag field. This must be a fully qualified domain-name |
