4 Change Password Module
The Change Password module enables ordinary users to change the password for their SMS user account.
Accessing the Change Password screen
Follow these steps to access the Change Password screen.
1 Select the Operator Functions menu from the SMS Main screen.
2 Select Change Password.
Result: You see the Change Password screen.
Note: The Change Password option on the Operator Functions menu appears only if a template associated with the user has been allocated the Execute ChangePassword permission.
Change Password
The Change Password screen enables ordinary users to change the password for their SMS user account.
Field descriptions
The table below describes the function of each field.
Field | Description |
Old Password | Current user password. |
New Password |
New password. For security reasons, a password must be at least 8 characters long. |
Confirmation | Confirmed password. |
Changing a password
Follow these steps to change your password.
Note: Password rules must be adhered to.
Enter your current password in the Old Password field.
Enter your new password in the New Password field.
Note: An explicit error message is displayed when an invalid password is entered.
Re-enter your new password in the Confirmation field.
Click OK to save the changed password.
