12 Using Keyboard Shortcuts
You can use keyboard shortcuts for many actions in SMS GUI.
Action | Shortcut |
To open File menu on the Service Management System screen. | Alt + F |
In a drop-down menu, move to the next item in the list. | Down Arrow |
In a drop-down menu, move to the previous item in the list. | Up Arrow |
In a drop-down menu, to expand the sub-listed items (mentioned with >). | Right Arrow |
To enter the selected item from the drop-down list. | Enter |
To traverse to menus other than the File menu on the Service Management System screen. | Right or Left Arrow |
To traverse through the tabs of a screen. | Ctrl + Tab |
To traverse forward to the forms or fields of a selected tab of the screen. | Tab |
To traverse backward to the forms or fields of a selected tab of the screen. | Shift + Tab |
To toggle between the radio buttons in the same row. | Right or Left Arrow |
To click the button on focus. | Enter |
To enable or disable the selected check box or radio button. | Spacebar |
To select value from the drop-down list of values for a field. | Up or Down Arrow |
