7 Control Plan Change
The Control Plan Change tab allows you:
To replace the termination number in the termination node of a control plan
For each service number on the ACS Numbers screen, to override the scheduled control plan, with the predefined alternative control plan
Note: To override a scheduled control plan, the alternative control plan name must follow this syntax:
<ServiceNumber><alternativeCallPlanNamePostfix>For example, if service number 0800123456 uses control plan "ABC", the alternative control plan for this service number must be named 0800123456_alternativeCallPlanNamePostfix.
Where alternativeCallPlanNamePostfix is the value specified in the
alternativeCallPlanNamePostfixparameter of the acs.conf file. For more information, see ACS Technical Guide.
Tab Areas
This table describes the function of each area of the tab.
| Field | Description |
| Alternative control plans | Allows you to activate or deactivate the alternative control plans. |
| State |
Text displays the current state of control plan activation:
| Termination number substitution |
Allows you to activate or deactivate the termination number substitution. You can add, edit, and delete the termination number/replacement number pair. |
| State |
Text displays the current state of number substitution:
Activating Alternative Control Plan Changes
Follow these steps to activate the alternative control plan changes.
On the Control Plan Change tab, in the Alternative control plans area, if currently deactivated, you can click Activate.
Result: The Activation Confirmation dialog appears.
Click Activate.
Result: Activates the control plans. The text (see Tab Areas) at the top of the following tabs changes to display the new state of activation and substitution:
Service Numbers tab of the Numbers screen (if any are activated)
Deactivating Alternative Control Plan Changes
Follow these steps to deactivate the alternative control plan changes.
On the Control Plan Change tab, in the Alternative control plans area, if currently activated, you can click Deactivate.
Result: The Deactivation Confirmation dialog appears.
Click Deactivate.
Result: Deactivates the control plans. The text (see Tab Areas) at the top of the following tabs changes to display the new state of activation and substitution:
Activating Termination Number Substitution
Follow these steps to activate the termination number substitution.
On the Control Plan Change tab, in the termination number substitution area, if currently deactivated, you can click Activate.
Click Activate.
Result:
The termination number substitution is activated
The text (see Tab Areas) changes to display the new state of activation and substitution at the top of the Control Plan Change tab and the Service Numbers tab of the Numbers screen (if any are activated)
Deactivating Termination Number Substitution
Follow these steps to deactivate the termination number substitution.
On the Control Plan Change tab, in the Termination number substitution area, if currently activated, you can click Deactivate.
Click Deactivate.
Result: The:
Termination number substitution is deactivated
The text (see Tab Areas) changes to display the new state of activation and substitution at the top of the:
Adding a Termination Number Substitution
Follow these steps to add a termination number substitution.
On the Control Plan Change tab, click New...
Result: The New Termination Number substitution screen is displayed.
Enter the termination number and the replacement number.
Click Save.
Related topic
Editing a Termination Number Substitution
Follow these steps to edit a termination number substitution.
On the Control Plan Change tab, select a termination number/replacement number pair from the table and click Edit...
Result: The Edit Termination Number substitution screen is displayed.
Make changes to the termination number and the replacement number.
Click Save.
Related topic
Deleting a Termination Number Substitution
Follow these steps to delete a termination number substitution.
On the Control Plan Change tab,select a termination number/replacement number from the table and click Delete.
Result: The Deletion Confirmation dialog is displayed, with a confirmation of the termination and replacement number pair.
Click Delete to delete the substitution.
Related topic
