41 Global Configuration
The Global Configuration tab enables you to:
                     Set the announcement set and entry to be used for the Beep announcement. Important: These announcements must be on a CS2 INMAP capable SSP in order to work correctly. See ACS Technical Guide for more information.
                     Choose to display the time, date and version numbers or just the time and date on the Control Plans table on the ACS Numbers Screen.
                     Set the default access code policy that is referenced from the Access Code List on the Service Numbers tab and CLI Numbers tab on the ACS Numbers screen.
                     Increase or decrease the maximum number of ACS self management sessions allowed.
Global Configuration Fields
The following tables describe the function of each field on the Global Configuration tab.
Beep Announcement Fields
| Field | Description |
| Announcement Set | The announcement set to be used for the Beep announcement. |
| Announcement Entry | The announcement entry to be used for the Beep announcement. Note: See Announcements for more information about announcement entries. |
Control Plan Display Fields
| Version Numbers, Time and Date | Select to display the version numbers on the control plan tables on the ACS Numbers screen. |
| Time and Date Only | The time and date is always displayed. Select this option to ensure that the versions numbers are not displayed on the Control Plan tables on the ACS Numbers screen. Note: See ACS Numbers for more information about managing control plans on the ACS Numbers screen. |
Default Access Code Policy Fields
This function applies to the Access Code Entry node.
| Not Required | The user is not required to enter an access code. |
| Required and Verified | The user is required to enter an access code and the code will be verified against the list in the Access Code Management frame on the Service Number screen or CLI screen. |
| Required and Not Verified | The user is required to enter an access code but the code will not be verified. Note: See Service Numbers and CLI Numbers for more information. |
| Max ACS Database Sessions | Increase or decrease the maximum number of ACS self management sessions allowed. Warning: Ensure that this number does not exceed the total maximum number of system sessions allowed. Contact your system administrator for more information. |
Editing the Global Configuration Settings
Follow these steps to edit the Global Configuration settings.
Note: There is only one set of Global Configuration settings within the system.
                        On the Global Configuration tab click Edit. Result: The Edit Global Configuration screen appears. See the Global Configuration Fields for this screen for more information.
                        In the Beep Announcement frame, for the Beep announcement, from the drop down lists, select the appropriate: -
                              Announcement set
                              Announcement entry
                        In the Control Plan Display frame, select the option you wish to have displayed on the control plan. The options are: -
                              Time and Date Only
                        In the Default Access Code Policy frame, select the option for the appropriate default access code policy. The options are: -
                              Not Required
                        In the Max ACS Database Sessions field, enter or select the required maximum number of database sessions that can exist at the same time.
                        Click Save to save the new settings. Result: The screen will return to the Global Configuration tab; note that this will now display the most recent setting update information above the buttons at the bottom of the screen.
Related topic
