2 LCP Feature Nodes
This chapter describes the Oracle Communications Convergent Charging Controller Location Capabilities Pack (LCP) feature nodes. These feature nodes enable you to use Advanced Control Services applications to look up location information for subscribers' mobile devices.
This chapter contains the following topics.
Available Feature Nodes
This table lists the feature nodes available from the LCP palette group in the ACS Control Plan Editor and the fast key for each feature node in the list. You can use fast keys to search for feature nodes in the palette or the canvas.
Node Name | Node Description |
In The Zone |
The In The Zone node allows a location-based service to be provided to the end-users to allow differential service depending on the location or MSISDN. Fast key: ITZ |
Set My Zone |
The Set My Zone node allows a “self-care” service to be provided to the end-users to set a zone of a selected type. Fast key: SMZ |
Store My Location |
The Store My Location feature node provides an alternative location-based service, by allowing the end-user’s current location or MSISDN to be stored in a context field for later comparison. Fast key: STML |
Store My Network ID |
The Store My Network Identity node stores the retrieved IMSI or MSRN in a profile tag. Fast key: STMN |
Exits
All of the LCP feature nodes contain the following two exits:
No Location Info
Error
The exit taken by a LCP feature node depends on the communication plug-in used by LCP to communicate with the location servers on the customer's network.
Using MAP ATI Plug-in
If the plug-in selected is MAP ATI Plugin
and the location
application returns one of the results listed below, then the No Location
Info
exit will be followed:
Unknown subscriber
Absent subscriber
System failure
Unauthorized network
Unauthorized application
Position method failure
These conditions are outside the scope of the Location Application (the errors are generated by external entities rather than the Location Application itself).
Using POSREQ Plug-in
If the plug-in selected is IS41 POSREQ Plugin
and the
location application returns one of the results listed below, then:
Error
exit is taken:-
Operation Sequence Problem = 132
Parameter Error = 136
Invalid Parameter Value = 138
Feature Inactive = 139
Missing Parameter = 140
No Location Info
exit is taken:-
OSA Unknown Subscriber
Unrecognized MIN = 129
Unrecognized ESN = 130
Unrecognized MDN = 143
OSA Absent Subscriber
MIN/HLR Mismatch = 131
OSA Unauthorized Network
Operation Not Supported = 134
OSA System Failure
System Failure = 137
Resource Shortage = 133
Trunk Unavailable = 135
Using SRI-MSRN Plug-in
If the plug-in selected is the SRI-MSRN Plugin
, or SRI-IMSI
Plugin
and the location application returns one of the results listed
below, then the No Location Info
System failure
Unauthorized network, caused by:
Facility not supported
OR not allowed
Bearer service not provided
Tele service not provided
CUG reject
Call barred
Forwarding Violation
Unknown subscriber, caused by:
Unknown subscriber
Number changed
Absent subscriber
Busy subscriber
No subscriber reply
In The Zone
This node denormalizes the number currently held in the MSISDN buffer, using the standard rules defined in acs.conf or the default rule configured.
Node exits
This node has one entry and five exits. The number of exits cannot be changed.
Exit | Cause | Description |
1 | In Zone | The current location is in the zone specified. |
2 | Not In Zone | The current location is outside the zone specified. |
3 | No Location Info | Unable to obtain the location information. |
4 | No Zones | There are no zones configured for the current service provider |
5 | Error | An internal error has occurred. |
Note: Refer to Exits for a description of errors that will cause the No
Location Info
and Error
exits to be taken.
Configuring the node
Follow these steps to edit the In The Zone node.
In the MSISDN source to query section, select the MSISDN that will be used to query the HLR:
MSISDN Source Data Type: Select the source data type.
MSISDN Source Location: Select the profile block containing the MSISDN.
MSISDN Source Field: Select the profile field containing the MSISDN.
In Profile Block, select where the zone will be read from.
Specify the Call Leg to be used for the location query. Select one of the following:
Originating (Calling Party)
Terminating (Called Party)
In Plugin Name, select which location plug-in to use. The default setting is the locApp configured plug-in.
Specify the Location Info Age. This is how old location information is allowed to be (if in cache). Select one of the following:
Default: Use the locApp specified time.
None: Never use the cache.
Manual entry text field: Here you need to type a value (in seconds) in the text box beside the option. Minimum value 1, maximum 864000 (10 days).
Specify a Response Deadline. This is how long the locApp is allowed (in number of seconds) before a reply is returned (note that if a timeout occurs a timeout result will be returned). Select one of the following:
Default: Use the locApp specified default.
Manual entry: Here you need to type a value (in seconds) in the text box beside the option, how long the timeout should be. Minimum value 1, maximum 600 (10 minutes).
In Zone Name, select which zone type this node is comparing against, or
<All>
for all zones.This field is populated by the Zone type entries in the ACS Configuration, Profile Tag Details tab. For more information about this tab, see ACS User's Guide.
Note: The location information returned by the HLR is always compared against the zones configured for the A-Party.
Note: The list of data types is fixed at installation time for each feature node or screen.
Further reference:
For information about profile blocks (data type, location, and field) and how to use them, see Profile Blocks and Tags.
The primary tag lists are configured in the SMS > Services > ACS Service > Configuration >Profile Tag Details and Profile Tag Mapping tabs (see ACS User's Guide, Profile Tag Details for more information).
Set My Zone
Node exits
This node has one entry and four exits. The number of exits cannot be changed.
1 | Success | The action to set a zone completed successfully. |
2 | Too Many Zone Shapes | The number of zone shapes for the zone type has exceeded the maximum number (the maximum zone types is set to 5). |
4 | Error | An internal error has occurred. |
Location Info
and Error
exit branches to be taken.
Follow these steps to edit the Set My Zone node.
In Profile Block, select where the zone will be written to.
In Zone Name, select which zone to set for this node.
This field is populated by the Zone type entries on the ACS Configuration, Profile Tag Details tab. For more information about this tab, see ACS User's Guide.
In Plugin Name, select which location plug-in to use. Default setting is to use the locApp configured plug-in.
Specify a Modification Type. Select one of the following:
Add: This will add a new zone (the current location) into the selected zone type.
Reset: This will cause the node to delete all the existing zones in the selected zone type and add the current location as the only zone.
In Min Radius, specify the minimum radius of a zone. If the locApp returns an uncertainty radius smaller than the minimum radius specified, the min radius (in km) is used.
Further reference:
Store My Location
This feature node can also be used to find the location details or MSISDN of a subscriber; for example, to include in billing for callback when the subscriber is roaming.
The MSISDN used to query the HLR will be denormalized as per the standard denormalization rules specified in the acs.conf or the default rule configured.
Node exits
This feature node has one entry and three exits. The number of exits cannot be changed.
1 | Success | The current location has been stored in the context specified. |
2 | No Location Info | Unable to obtain the location information. |
3 | Error | An internal error has occurred. |
Note: See Exits for a description of the errors that cause the No
Location Info
and Error
Follow these steps to configure the Store My Location node.
Using the drop down lists in the MSISDN source to query area, select the field containing the MSISDN that will be used to query the HLR.
In Store to Buffer, select where the location information will be stored. The following buffers are available in the drop down list:
Pending Termination Number
Calling Logical Number
Calling Private Network Address
Calling Network Address
Calling Party ID
Dialed Service Number
Additional Calling Party Number
Leg Cell Id or LAI
Routing Number
Choose which Call Leg to use for the location query. Select one of the following:
From the Plugin Name drop down list, select which location plug-in to use. Select
<Default>
to use the locApp configured plug-in. -
Further reference:
Store My Network ID
Node exits
This node has one entry and three exits. The number of exits cannot be changed.
1 | Success | The IMSI location information has been successfully retrieved. |
2 | NoLocationInfo | Unable to retrieve location information. |
Configuration fields
This table describes the function of each field in the Configure Store My Network Id node screen.
Field | Description |
Node name | The name of the node. |
MSISDN Data Type | The MSISDN profile block data type. |
MSISDN Location | The profile block containing the MSISDN location. |
MSISDN Field | The profile field containing the MSISDN. |
IMSI Data Type | The IMSI profile block data type. |
IMSI Location | The profile block location for the retrieved IMSI. |
IMSI Field | The profile field where the retrieved IMSI will be stored. |
Call Leg | Whether to retrieve the IMSI from the originating (caller) or terminating (called) party. |
Plugin Name | The name of the plug-in to use to retrieve the IMSI. By default the MAP SRI-MSRN plug-in will be used. |
Location Info Age (s) |
Maximum age allowed for location information (if in cache). One of the following:
Response Deadline (s) |
Maximum length of time allowed (in seconds) before receiving a response (if a timeout occurs a timeout result will be returned). One of the following:
Follow these steps to configure the node.
Note: For more information on the configuration fields, see Configuration fields.
From the MSISDN Location area, using the drop down boxes, select the profile containing the MSISDN.
From the IMSI Location area, using the drop down boxes, select the profile where the IMSI will be stored.
Click Save.
Further reference:
