7 Tools and Utilities
This chapter explains the tools and utilities available in Advanced Control Services (ACS).
acsAddCallPlan
Purpose
Use the acsAddCallPlan tool to import a control plan, defined in a .cpl text file, into the SMF database either on the same platform or on a different platform. For example, you can export a control plan from one platform by using "acsDumpControlPlan" and then import the control plan into a different platform by using acsAddCallPlan.
The java shell script for acsAddCallPlan is located on SMS nodes. It launches a Java command line class that reuses the CPE code to achieve its requirements.
About Connecting to the Database
acsAddCallPlan and acsDumpCallPlan connect to the database on a local or a remote SMS node based on the values specified for the -u, -j, and -b command line options.
-u username/password (for local connections)
-u username/password -j remote_hostname [-b port:db_SID] (for remote connections)
-u /@wallet_user (for local or remote connections through the Oracle wallet secure external password store)
username and password are user credentials for a screens user or for the SMF database user.
remote_hostname is the host name of the machine running the remote database.
port and db_SID are the port number and database SID of the remote database. If not specified, defaults to 1521:SMF
wallet_user is the alias defined for the username and password credentials in the Oracle wallet secure external password store. For remote connections, this alias can be either a TNS name or a service name from tnsnames.ora.
Configuration
acsAddCallPlan accepts the following parameters.
acsAddCallPlan [–u {usr/pwd|/@wallet_user}] [-j host] [-b port:db_id] [-v] [-D directory [ O directory] C acs_customer]The available parameters are:
Table 7-1 acsAddCallPlan Parameters
| Parameter | Default | Description |
-u usr/pwd -u /@wallet_user |
NA |
Specify one of:
| -j host | localhost | The host name of the machine running the SMF database. |
| -b port:db_id | 1521:SMF | The port number and database ID of the SMF database. |
| -v | off | Verbose (optional) |
| -D directory | ignored | Specify the directory containing the .cpl files to import (optional). |
| -O directory | ignored | Specify the directory to move successfully imported files to (optional, only relevant with -D). Any files that fail to import will not be moved. |
| -C acs_customer | ignored | Specify the ACS customer that will own the imported control plans (required if -D is used). |
-c name -f file [-s name]|[-t name] [-d name] [-m ID] [-p]
Where the record content is:
Table 7-2 Record Contentby stdin Lines
| Field | Description |
| -c name | Customer name. |
| -f file | Exported control plan file name. |
| -s name |
New template name (optional). Tip: This is used when there is no existing template. |
| -t name | Existing template name (optional). |
| -d name | New control plan name (optional). |
| -m ID | MF Identifier for the control plan (optional). |
| -p | Make inserted control plan public (optional). |
-c cust_name -f cpl_file -s cpl_name -d cpl_name
Table 7-3 Record Content for .cpl Files
| -c cust_name | Customer name is taken from the -C option argument. |
| -f cpl_file | Is the filename of each .cpl file in the directory from the -D argument. |
| -s cpl_name | Is the cpl file basename with the .cpl extension removed. |
| -d cpl_name | Is the cpl file basename with the .cpl extension removed. |
The control plan text file format is the same as that used for an exported control plan. Imported control plans will be set private and mf_identifier will be set NULL.
acsAddCustomer
Purpose
Inserts a customer record into the SMF database.
Location
This binary is located on the SMS node.
Configuration
acsAddCustomer accepts the following parameters.
acsAddCallPlan –u usr/pwd [-v]
Table 7-4 acsAddCustomer Parameters
| –u usr/pwd | NA | username/password. Username must be acs_admin. |
| [-v] | off | Verbose |
-c name [-f set] [-y set] [-g set] [-n set] [-m] [-r ref] [-d desc] [-l usr] [-o val=options] [-t policy]
Table 7-5 Record Content for acsAddCustomer
| Field | Default | Description |
| -c name | NA | Customer name (mandatory). |
| -f set | NA | Feature node set name (optional). |
| -y set | NA | Holiday set name (optional). |
| -g set | NA | Geography set name (optional). |
| -n set | NA | Announcement set name (optional). |
| -m | NA | Customer is Telco managed (optional). |
| -r ref | NA | Customer reference (optional). |
| -d desc | NA | Customer description (optional). |
| -l usr | NA | User name to be added for this customer (optional). |
| -o val=options | NA |
Resource limits for customer (optional). Options are:
| -t policy | global |
Termination number range rules (optional). Options are:
acsAddGeography
Purpose
Inserts Geography Set(s) into the SMF database from a text file.
Location
Configuration
acsAddGeography accepts the following parameters.
acsAddGeography -u usr/pwd [-c customer | -p] [-r int] [-g] filenames
| -u usr/pwd | NA | Oracle username/ password. |
| -c name | NA |
Customer to own created geography sets. The -c and -p parameters are mutually exclusive. |
| -p | NA | Public set. |
| -r int | NA | Number of records before a commit (optional). |
| -g | NA | Global number prefix (optional). |
| filenames | NA | Input filename. |
Input file structure
Geography set name area = 1 another area sub area = 21 another sub area = 22 # blank lines or comments (# = comment line) are allowed. Another geography set newlands = 343
acsAddServiceNumber
Purpose
Inserts a service number record into the SMF database.
Location
Configuration
acsAddServiceNumber accepts the following parameters.
acsAddServiceNumber –u usr/pwd [-v]
Table 7-6 Available Parameters for acsAddServiceNumber
| –u usr/pwd | NA | Oracle username/ password. |
-c customer -s sn [-r desc] [-b] [-p pin] [-f number] [-a options] [-t 1|2] [-i 0|1] [-d list]
Table 7-7 Record Content for acsAddServiceNumber
| -c name | Customer Name. |
| -s sn | Service Number. |
| -r desc | Description (optional). |
| -b | Use Toll Free beeps (optional). |
| -p pin | PIN (optional). |
| -f number | Follow me number (optional). |
| -a options | Policy, Min/Max, Account Codes (optional). |
| -t 1|2 |
Barred list type (optional).
| -i 0|1 |
Barred list ignore (optional).
| -d list | List of barred/ allowed numbers (optional). |
acsDecompile
Purpose
Takes a compiled control plan and decodes it into the control plan text file format.
Location
This binary is located on both SLCs and SMSs.
Configuration
acsDecompile accepts the following parameters.
acsDecompile [-u usr/pwd] [-d dataID|-s structureID] [–r|–n]
Table 7-8 Available Parameters for acsDecompile
| Parameter | Description |
| -u usr/pwd | Oracle username/password. |
| -d dataID | Control plan Data ID to decompile. |
| -s structureID | Control plan structure ID to decompile. |
| –r | Dump raw content only. |
| –n | Attempt to decompile node data. |
acsDumpControlPlan
Purpose
Use the acsDumpControlPlan tool to export one or more control plans from the SMF database to text files (one file per control plan). You can import the control plan text files to either the same platform or a different platform, by using "acsAddCallPlan".
The java shell script for acsDumpControlPlan is located on SMS nodes. It launches a Java command line class that reuses the CPE code to achieve its requirements.
Configuration
acsDumpControlPlan -d out_dir [-u {user/password|@wallet_user}][-j host] [-b port:db_id] [ c customer] [ p control_plan] [-i id] | S [ v]The available parameters are:
| -d out_dir | NA | Directory where exported control plan will be written. |
-u user/password -u @wallet_user |
NA |
Specify one of:
| -b port:db_id | 1521:SMF | The port number and database ID for the SMF database. |
| -c customer | ignored | Name of the customer who owns the control plan (optional). |
| -p | ignored | Name of the control plan. May contain % and wildcard characters (optional). |
| -i id | ignored | The control plan ID in the ACS call plan table. If specified, ignores -c and -p. (optional) |
| -v | off | Verbose mode (optional). |
| -S | ignored |
If set, create all files in the same directory as out_dir/customer_name_version.cpl. Otherwise, create files in subdirectories as out_dir/customer/name/version.cpl. (optional) |
The control plan text file format is the same as that used for an exported control plan using the CPE.
acsMonitorCompiler
Purpose
Checks the number of control plans waiting to be compiled. acsMonitorCompiler is designed to be run after a large number of control plans have been entered.
No further control plans should be entered once acsMonitorCompiler has been started.
Location
Configuration
acsMonitorCompiler accepts the following parameters.
acsMonitorCompiler -u usr/pwd -s secs [-w] [-e]
| -u usr/pwd | smf/smf | Oracle username/password. |
| -s secs | NA | Seconds between database checks. |
| -w | NA | Display warnings and above (optional). |
| -e | NA | Display errors and above (optional). |
acsProfile
Purpose
Decodes, displays or changes the value of profile tags.
Location
Configuration
acsProfile -[-u [/@SMF] | [/@SCP]]
-[U]
-[Nn|Ss|Cc|Pp|Gg|Ii|Yy|Zz|Ee|Ff] <IntKey>
-[Nn|Ss|Cc|Pp|Gg|Ii|Yy|Zz|Ee|Ff] <StrKey>
-[j] -
-[j] <filename>
-[D]
-[W] <tag> -[A|H|L|B] <data>
-[R] <tag>
-[K] <tag1>[.<subtag1>],<tag2>[.<subtag2>]
-[V] <tag1>[.<subtag1>],<tag2>[.<subtag2>]
-[T] <tag> -[t] [h|P|d|a|p|m|n|l|v|V|A|B|D|i|H|I|U|W|N|S|O|M]
-[X] <tag>
-[Q] The available parameters are:
Table 7-9 Available Parameters for acsProfile
| [-u [/@SMF] | [/@SCP]] |
Specify the SID of the remote database to connect:
| -U | Specify to enable SMF_SECURITY validation. |
| -targetProfile keyID|’str’ |
Specify the profile block that contains the target profile tags followed by the key as a string or an integer. You can specify one of the following values for targetProfile:
Note: Specify lowercase to force acsProfile to accept a string keyID value. |
| -j -|filename |
Specify to use the stdin/stdout pipeline or a specified file for the target profile. To use:
| -D | Defaults to dump profile |
| -W tag -[A|H|L|B] data | Specify to update, insert, or write a tag with the specified data |
| -R tag | Specify to remove a tag |
| -K tag1[.subtag1],tag2[.subtag2] | Specify to copy the data in tag1 to tag2 |
| -V tag1[.subtag1],tag2[.subtag2] | Specify to move the data in tag1 to tag2 |
| -T tag [-t tagType] |
Decodes one tag, specified in tag, as the chosen type, where type is one of the following: h = ASCII Hex P = embedded profile, all of whose tags are hex d = tree of digit strings a = Announcement Map p = prefix tree of digits and strings m = Miscellaneous n = Number Lists l = Long triples; such as TimeOfWeek v = Variable Announcement Rule Set (VARS) table V = VARS Mapping table A = Array B = Boolean D = Date i = Discount H = HuntingConfig I = Integer U = UnsignedInteger W = UnsignedInteger64 N = NumericString S = String O = OrderedPrefixTree M = NumberMatchingPatterns Example: -T Date_1 –t D Where Date_1 is the profile tag and D is the decoded tag type |
| -X tag |
Cross checks the chosen tag in this profile. For example, for multi-lingual announcements in the global profiles, cross-check announcement language mappings and delete stray ones. Note: Write and remove actions also produce a post-change profile dump. |
| -Q | Indexes the new array type introduced by DAP and OSD. Setting this flag will allow indexing from zero. |
acsScheduleCallPlan
Purpose
Inserts a control plan schedule record into the SMF database.
Location
Configuration
acsScheduleCallPlan accepts the following
acsScheduleCallPlan –u usr/pwd [-v]
Table 7-10 Available Parameters for acsScheduleCallPlan
-c name -s sn -p name -d YYYYMMDD24MMSS [-a]
Table 7-11 Record Content for acsScheduleCallPlan
| -c name | Customer name |
| -s sn | Service number |
| -p name | Control plan name |
| -d list | Schedule time |
| -a | Activate against CLI not SN (optional). |
acsSetupAnnouncement
Purpose
Inserts an announcement record into the SMF database.
Location
Configuration
acsSetupAnnouncement accepts the following parameters.
acsSetupAnnouncement [-u usr/pwd] [-l lang] -s set -e entry -r srf -i id [-c name] [-v] [-n] [-g time] [-d desc]
| -u usr/pwd | Oracle username/password (optional) |
| -l lang | Language name (optional) |
| -s set | Set name |
| -e entry | Entry name |
| -r srf | srf name |
| -i id | Numeric announcement ID |
| -c name | Customer name (optional). If not set, the announcement set will be public. |
| -v | Verbose (optional) |
| -n | No SMS security challenge (optional) |
| -g time | Generate script to run this tool to create same mappings (optional) |
| -d desc | Announcement description (optional) |
numberDataImport
Purpose
The numberDataImport tool enables you to create and update table lookup datasets from a comma separated value (CSV) file.
You can create any number of table lookup datasets. Each table lookup dataset contains a group of related codes and prefix mappings. For example, you can create a table lookup dataset for a specific geographic area or suburb.
A table lookup dataset can be public or private. A private table lookup dataset belongs to a specific customer. It is only available to that customer and the parent customers linked to that customer in the customer hierarchy. A public table lookup dataset is available to all customers.
The numberDataImport tool is located at /IN/service_packages/ACS/bin.
Configure the numberDataImport tool in the eserv.config file. See "Configuring the numberDataImport Tool" .
Create the CSV input file for the numberDataImport tool. See "Creating the Dataset Input File".
If you specify only the user, then numberDataImport prompts you for the user's password at run-time.
If you omit the -u option, then numberDataImport connects to the database by using the default login value '/'.
NUMBER_IMPORT_NO_COMMAND_LINE_PASSWORD=str export NUMBER_IMPORT_NO_COMMAND_LINE_PASSWORD
where str is any string value.
To run numberDataImport, see "Creating and Updating Table Lookup Datasets".
After creating table lookup datasets, you can use them in the Table Lookup feature node configurations. For information about configuring the Table Lookup feature node, see Feature Nodes Reference Guide.
You can search table lookup datasets for a prefix number or a mapping code using the ACS UI. For more information, see the discussion on configuring ACS in ACS User's Guide.
NumberMappingImport = {
closedDirectory = "closed_dir"
errorDirectory = "error_dir"
dbCommitBatchSize = size
progressDotInterval = int
closed_dir is the directory to which numberDataImport copies successful import files. Defaults to /IN/service_packages/ACS/mappingData/closed if not specified.
- error_dir is the directory to which numberDataImport writes import error files. Defaults to /IN/service_packages/ACS/mappingData/error if not specified.
size sets the number of insert or update operations to perform before committing the data to the database. There is a 10 second pause at each interval to help throttle replication. Defaults to 5000 if not specified.
int defines the number of insert or update operations to perform before displaying a progress dot (a dot that is displayed on the console for every x number of updates). Defaults to 100 if not specified.
You import entries into a table lookup dataset from a comma-separated value (CSV) file that you create. You specify this file as input to the numberDataImport tool when you run the tool from a command line.
Open a new file in a text editor.
Add dataset entries to the file by using the following syntax for each entry. Add each entry on a new line:
a|A|d|D,lookup_code,lookup_prefix
Where:-
a or A specifies to add the dataset entry. If the dataset entry already exists, it is updated.
d or D specifies to delete the dataset entry. If the dataset entry does not exist, this file entry is ignored.
lookup_code is the code that maps to the prefix in lookup_prefix.
lookup_prefix is a prefix number or CLI.
A comma (,) preceded by a backslash will be treated as a valid comma character rather than a separator.
A hash (#) preceded by a backslash will be read as a valid hash character rather than beginning of a comment.
Save the file, giving it the file extension .csv. Example CSV file entries:
a,3333,32014733 a,4444,32014744 d,5555,320147355 d,6666,320147366
Open a command shell and log in to the SMS as the acs_oper user.
Navigate to the /IN/service_packages/ACS/bin directory.
Run the numberDataImport tool by using the following syntax:
./numberDataImport [–u user|user/password] [–F|D] [-s dataset] -i filename [-a acs_customer]
Where:-
user and user/password – (Optional) is the user, or the user and password for an ACS user with the required user privilege level. The user must be a Screens user who has the AcsNumberMappingImport permission. For information on setting user privileges, see SMS User's Guide.
F and D – (Optional) indicates whether to create or update the dataset. Specify:
F to create the dataset. If the dataset already exists then you see a warning message asking if you want to continue. If you want to overwrite the existing dataset entries, then answer Y, otherwise answer N.
D to update the specified dataset.
If you do not specify F or D and the dataset does not already exist, then numberDataImport creates a new dataset. If the dataset does exist, then it is updated.
dataset – (Optional) is the name of the dataset that you want to create or update. If you do not specify dataset, then the dataset name defaults to "Default".
filename – (Required) is the name of the CSV file that contains the dataset entries. The CSV file must have the .csv suffix.
acs_customer – (Optional) defines the name of the ACS customer that the dataset belongs to. If you do not specify acs_customer, then the dataset will be public and therefore available to all customers.
Values for the -a, -s, and -i parameters can be quoted or unquoted. However, you must enclose a value in quotes if it contains spaces.
For example, you could create Dataset1 for customer ABC from the entries in Dataset1.csv by running the following command:./numberDataImport -u user/password -F -s Dataset1 -i Dataset1.csv -a ABC
After successfully importing a dataset from a CSV file, the CSV file is moved to /IN/service_packages/ACS/mappingData/closed by default.
If the numberDataImport tool fails to import any entries, then these failed entries are written to the error file /IN/service_packages/ACS/mappingData/error/filename.error by default.
Where filename is the name of the CSV input file.
For information about the location of the numberDataImport output files, see "Configuring the numberDataImport Tool".
