8 About Installation and Removal
Overview
Introduction
This chapter provides information about the installed components for the Oracle Communications Convergent Charging Controller application described in this guide. It also lists the files installed by the application that you can check for, to ensure that the application installed successfully.
Checking the Installation
Checking the DAP SMS Installation
On successful installation, the package will have created the following directories:
- /IN/service_packages/DAP/db
- /IN/service_packages/DAP/lib
- /IN/service_packages/DAP/tmp
The following feature nodes will have been installed and added to the ACS database:
- Send Request
- DAP Send Request
- DAP VXML
Checking the DAP SLC Installation
- /IN/service_packages/DAP/bin
- /IN/service_packages/DAP/etc
The following binaries and interfaces will have been installed:
- /IN/service_packages/DAP/bin/dapIF
The following configuration files will have been installed:
- /IN/service_packages/DAP/etc/example.eserv.config
The following shared libraries will have been installed:
- /IN/service_packages/DAP/lib/dapMacroNodes.so
- /IN/service_packages/DAP/lib/libdapChassisActions.so
