7 Tools and Utilities
dapReadyCertificates.sh
Purpose
dapReadyCertificates.sh prepares the
certificates located in the directory specified in the
certificatePath parameter into the form
required by openssl
(by
concatenating them into human-readable form and running
c_rehash
on them).
dapReadyCertificates.sh concatenates the files
into the file specified by the certificatesName parameter.
See Certificate Management for an overview of how certificates are handled.
Warning: The concatenated file is overwritten
each time dapReadyCertificates.sh is run. To keep
the existing file, move it to a directory other than the one
specified by certificatePath, or rename it with a
suffix other than .pem (otherwise it will be
concatenated into the new file along with the other
*.pem files in certificatePath).
dapSchemaTool
Purpose
This tool is used to export existing ASPs and operations from one server (that is, a testing server) and import them to another server (that is, a production server).
Usage
Format
dapSchemaTool -E data|-I data -n name [-s operation_set_name]
[-f filename] -u db_user -p db_password [-c
TNS_connect_string]Export example
/dapSchemaTool -E asponly -n abc -u SMF -p SMF -c
server_SMFImport example
/dapSchemaTool -I operation -n xyz -f testOutput.txt -u SMF
-p SMF -c server_SMFArguments
This table describes the function of each command argument.
| Argument | Description | |
| -E | Export from database | |
| -I | Import to database | |
| -n | ASP, operation, or operation set name to export or import | |
| -s | Operation set name (optional, only required if the given operation name is not unique) | |
| -f | Filename for exported data (optional, required for importing, uses the standard output for exporting if not specified) | |
| -u | Oracle username of database to use | |
| -p | Oracle password of database to use | |
| -c | Oracle TNS connect string (optional, uses $ORACLE_SID to connect to the local database if not specified) | |
| Data arguments for-E and -I options - one of these must be used | ||
| asponly | Only the given ASP | |
| asp | The given ASP and all attached operations, as well as the operation set each operation belongs to, and all parameters each operation contains | |
| operation | The given operation, its parameters, and the associated ASP and the operation set (the associated operation set will be exported but will not be imported using this argument) | |
| operationset | The given operation set and its all operations, as well as the associated ASP and parameters of each operation | |
