1 EDR Overview
EDR Generation
Introduction
EDRs are generated by:
- CCS - on the:
- SLC (refer to SLC Generated EDRs.
- Billing engine and the SMS (refer to Billing Engine and SMS EDR Definitions).
- ACS - slee_acs on the SLC. Refer to ACS EDRs.
- Messaging Manager - xmsTrigger on the SLC. Refer to Messaging Manager EDRs.
- Diameter Charging Driver - slee_acs on the SLC. Refer to DCD EDRs.
EDR Tag List
EDR tag versions
Where a tag is redefined, for a new version of software, both the new and old definition is included. Where the new version is used in a CCS EDR, the tag list will also have both the old and new tags listed.
EDR tags - A
This list covers all application EDRs defined within this guide, starting with the letter A.
- ACCOUNT_TYPE (Product Type ID)
- ACCT_ID (changed wallet ID)
- ACCT_REF_ID (changed account ID)
- ACS_CUST_ID (ACS Customer ID)
- ACTION (voucher activity)
- ACTION_DETAIL (voucher activity)
- ACTIVATION_DATE (account activation date)
- ADJUSTMENT (generated by an adjustment)
- AIDL (played announcement ID list)
- ALPH (alphabet name)
- ANS_TM (answer time)
- APPLICATION_DESC (application freeform)
- ASAD (ip of originating asp)
- ASPDF (asp definition)
- ASPID (inbound and outbound path)
- AXAD (ip connections from asp)
EDR tags - B
This list covers all application EDRs defined within this guide, starting with the letter B.
- BAD_PINS (number of attempts)
- BALANCE_EXPIRIES (period hours)
- BALANCE_TYPES (account changed or created)
- BALANCE_TYPES (account changed or created) - mid call rate changes
- BALANCE_TYPES (existing account)
- BALANCES (pre-call or account creation)
- BALANCES (pre-call or account creation) - mid call rate changes
- BALANCES (pre-transaction account balances)
- BARRED_LIST_TYPE (description)
- BATCH_DESCRIPTION (for voucher batch)
- BARCODE (voucher details)
- BCOR (balance cascade override)
- BEARER_TYPE (bearer type id)
- BFT (billing failure treatment
- BILLING_ENGINE_ID (BE where account resides)
- BONUS_TYPE (name)
- BUCKET_IDS (within balance type recharged)
- BUCKET_LEVEL_COSTS
EDR tags - C
This list covers all application EDRs defined within this guide, starting with the letter C.
- CA (called address)
- CAET (call attempt elapsed time)
- CALLINGNUM (lcr set calling number)
- CALLINGNOA (noa of callingnum)
- CARD_DESIGN (voucher details)
- CARRIERNAME (carrier name)
- CARRIERPOS (position of carrier name in hunt list)
- CASCADE (always empty for pi)
- CASCADE_ID (balance type cascade IDs)
- CASCADE_ID (balance type cascade IDs) - mid call rate change
- CBAT (connected by attempt termination)
- CBTD_BALANCE_TYPES (list to apply to discounts)
- CBTD_BALANCE_TYPES (list to apply to discounts) - mid call rate changes
- CBTD_BALANCES (value for each cross balance type)
- CBTD_BALANCES (value for each cross balance type) - mid call rate change
- CBTD_CASCADE_ID (used for this call)
- CBTD_CASCADE_ID (used for this call) - mid call rate change
- CBTD_COSTS (costs applied to each cross balance type)
- CBTD_COSTS (costs applied to each cross balance type) - mid call rate changes
- CBTD_COSTS_RND_REM (rounding remainder of cross balance CBTD_COSTS)
- CBTD_DISCOUNTS (discounts applied to balance types)
- CBTD_DISCOUNTS (discounts applied to balance types) - mid call rate changes
- CC (carrier code)
- CCET (call connect elapsed time)
- CCTS (call connect timestamp)
- CDR_TYPE (reason for record generation)
- CDR_TYPE (sca reason for record generation)
- CELLID (cell id in the idp)
- CGN (calling network number)
- CGNA (global calling network address)
- CGNN (calling party nature of number)
- CHARGE_EXPIRY (new periodic charge expiry) (new periodic charge expiry)
- CHARGE_NAME (of periodic charge)
- CID (slee call ID)
- CLI (calling logical number)
- CLI (for the account that will be changed)
- CLI (initiating call number)
- CLI (initiating call number) - mid call rate changes
- CLI (roaming initiating call number)
- COMPONENT (from pi command reference)
- COSTS (rated calls)
- COSTS (rated calls) - mid call rate changes
- COSTS_RND_REM (rounding remainder of balance COSTS)
- CPC (calling party category)
- CPN (control plan name)
- CPNI (calling private network ID)
- CPNN (called party nature of number)
- CPPI (calling party presentation restriced indicator)
- CS (call status, always D)
- CS (call status, S or D) (call status, S or D)
- CS (acs connect status)
- CT_NAME (credit transfer)
- CT_TYPE (credit transfer)
- CUG_NAME (closed user group)
- CUST (customer database ID)
EDR tags - D
This list covers all application EDRs defined within this guide, starting with the letter D.
- DADR (destination address)
- DATE (timestamp sms sent to mmx)
- DELTS (timestamp of delivery attempt)
- DIA_RC (result code)
- DIA_REQ (current session message number)
- DIA_SID (session id)
- DIA_TIME (time ccr sent)
- DICWR (Disable Incoming Calls When Roaming)
- DIMSI (destination imsi)
- DISC (discount override)
- DISCOUNT (always zero for pi)
- DISCOUNT_TYPE (applied to this call)
- DISCOUNT_TYPE (applied to this call) - R*W
- DISCOUNT_TYPE (applied to this call) - service discount
- DISCOUNTS (for each named event)
- DISCOUNTS (rated calls)
- DISCOUNTS (rated calls) - mid call rate changes
- DISPLAY_SPEND_RATIO (Balance Type Display to Spend Ratio)
- DISTRIBUTOR_CHANNEL (voucher details)
- DISTS (timestamp of discard)
- DLOC (terminating party location information)
- DLVR (message delivered flag)
- DPATH (delivery path)
- DSCA (destination service center address)
- DSCGT (destination gt)
- DSTL (destination gt of fda msc)
- DURATION (call length)
- DURATION (session duration)
- DURATION_DELTA
EDR tags - E
This list covers all application EDRs defined within this guide, starting with the letter E.
- END_CALL_REASON (reasons for call termination)
- ESN (electronic serial number)
- EVENT_CLASS (list of classes used)
- EVENT_COST (for each named event)
- EVENT_COUNT (for each named event)
- EVENT_NAME (list used for this call)
- EVENT_TIME_COST (for a named event)
- EXPIRED_WALLET (ID of expired wallet)
- EXT(0-9) (extension buffer contents)
EDR tags - F
This list covers all application EDRs defined within this guide, starting with the letter F.
- FATS (first announcement timestamp)
- FCA (final call address)
- FREE_TEXT_FIELD_1 (voucher details)
- FREE_TEXT_FIELD_2 (voucher details)
- FREE_TEXT_FIELD_3 (voucher details)
- FROM (sip message from header)
EDR tags - G
This list covers all application EDRs defined within this guide, starting with the letter G.
- GPRS (general packet radio service)
EDR tags - H
This list covers all application EDRs defined within this guide, starting with the letter H.
- HOST (initiating credit transfer)
- HTS (hunting timestamp)
EDR tags - I
This list covers all application EDRs defined within this guide, starting with the letter I.
- IGNORE_BARRED (ignore numbers in call barring list)
- IPRI (incoming protocol value)
- IPRN (incoming protocol name)
- ITS (incoming tele service)
EDR tags - L
This list covers all application EDRs defined within this guide, starting with the letter L.
- LAC (last account code used)
- LAST_RECORD_DATE
- LENGTHS (rate durations)
- LENGTHS (rate durations) - mid call rate changes
- LGID (language ID)
- LI_LOC_NUM (location information for loc_num)
- LOC_NUM (location number in idp)
- LOCADD (additional configuration prefixes)
- LPN (most recent pin entered)
EDR tags - M
This list covers all application EDRs defined within this guide, starting with the letter M.
- MAX_CHARGE (for this call)
- MAX_CHARGE (for this call) - mid call rate changes
- MAX_CONCURRENT (maximum concurrent accesses allowed)
- MCOR (maximum charge override)
- METHOD (sip method of request)
- MFILE (for rating data)
- MID_SESSION (partial EDR)
- MSCA (smsc address)
- MSGD (message destination)
- MSGR (message reference number)
- MSISDN (account calling number)
- MTYP (message type)
EDR tags - N
This list covers all application EDRs defined within this guide, starting with the letter N.
- NACK (freeform recharge list)
- NACK (long list of codes)
- NACK (short list of codes)
- NEW_ACCOUNT (ID of account type)
- NEW_ACCT_EXPIRY (date after account deleted)
If the expiry date is updated then this tag will be present.
- NEW_ACCT_EXPIRY (date after recharge)
- NEW_ACCT_EXPIRY (date after update)
- NEW_ACCT_STATE (after update)
- NEW_ACCT_STATE (always active - A)
- NEW_ACCT_STATE (always frozen - F)
- NEW_ACCT_STATE (always preuse - P)
- NEW_ACCT_STATE (always terminated - T)
- NEW_ACCT_TYPE (ID of account after recharge)
- NEW_ACCT_TYPE (prod type swap)
- NEW_ACTIVE_SVC (account type)
- NEW_BALANCE_EXPIRIES (date after balance update)
- NEW_BALANCE_EXPIRIES (dates after voucher recharge)
- NEW_BARRED_LIST (of call barring numbers)
- NEW_CHARGE_STATE (periodic charge subscription state)
- NEW_FD (friends destination number)
- NEW_FF (list of friends and family numbers)
- NEW_LAST_USE (date last used)
- NEW_WLC_PERIOD (after update)
- NEW_WLC_PLAN (Id)
- NOAT (number of attempt terminations)
- NRQ (status report requested for message)
- NRQD (emi with defined nrq)
- NT (network type)
- NUMBER (voucher number)
EDR tags - O
This list covers all application EDRs defined within this guide, starting with the letter O.
- OA (sccp originating address)
- OADR (originating address)
- OAID (originating adapter id)
- OCAU (acs cause value)
- OCPI (original called party)
- OGEO_ID (originating geo node id)
- OIMSI (originating imsi)
- OIPA (originating ip address)
- OLD_ACCOUNT (ID of account type)
- OLD_ACCT_EXPIRY (date before recharge)
- OLD_ACCT_EXPIRY (dates before update)
- OLD_ACCT_STATE (always active - A)
- OLD_ACCT_STATE (before update)
- OLD_ACCT_STATE (P or D before update)
- OLD_ACCT_STATE (pre-call)
- OLD_ACCT_TYPE (ID of account before recharge)
- OLD_ACCT_TYPE (prod type swap)
- OLD_ACTIVE_SVC (account type)
- OLD_BALANCE_EXPIRIES (dates before balance update)
- OLD_BALANCE_EXPIRIES (dates before voucher recharge)
- OLD_BARRED_LIST (of call barring numbers)
- OLD_CHARGE_EXPIRY (periodic charge expiry date changes)
- OLD_CHARGE_STATE (periodic charge subscription state)
- OLD_FD (friends destination number)
- OLD_FF (list of friends and family numbers)
- OLD_WLC_PERIOD (before update)
- OLD_WLC_PLAN (Id)
- OLOC (originating party location information)
- OPERATOR_RELEASED (commit/revoke reservation)
- OPRI (outgoing priority)
- OPPN (output protocol name)
- OPRT (originating port number)
- ORIGTRUNK (idp location number content)
- OVERDRAWN_AMOUNT (take Balance Negative)
- OTI (originating transaction ID)
- OTS (outgoing tele service)
- OVERRIDDEN_TARIFF_PLAN (ID)
EDR tags - P
This list covers all application EDRs defined within this guide, starting with the letter P.
- PCNA (calling private network address)
- PC_TYPE (periodic charge type)
- PERR (protocol specific error)
- PI (logon name and IP address)
- PID (unix process id)
- PORTED (name of porting carrier)
- PTI (product type id)
- PTNA (private terminating network address)
- PRES (terminating adapter response)
- PRID (protocol identifier)
- PROVISIONING_DATE (voucher details)
- PRO_RATE (periodic charge subscription)
- PURCHASING_ACCT_ID (purchasing wallet ID)
- PURCHASING_MSISDN (purchasing CLI)
EDR tags - R
This list covers all application EDRs defined within this guide, starting with the letter R.
- RATES (rated calls)
- RATES (rated calls) - mid call rate changes
- RDPN (redirecting party id)
- RDPNN (normalised redirecting party id)
- RDRES (redirection reason)
- RECIPIENT_ACCT_ID (receiving wallet ID)
- RECIPIENT_MSISDN (receiving CLI)
- RECORD_DATE (date edr created)
- REDEEMING_ACCT_REF (ID of account)
- REDEEMING_ACCT_TYPE (name of account type)
- REFERENCE (credit card reference, always cc)
- REFERENCE (from pi reference)
- REFERENCE (operator freeform)
- REFERENCE (voucher freeform)
- REFERENCE (web site reference - ws)
- RELC (acs release cause)
- RELC (inap release cause)
- RELOAD_BONUS (promotion name)
- RELOAD_BONUS_AMOUNT (amount applied)
- RELOAD_BONUS_EXPIRY (date remaining bonus expires)
- RELOAD_BONUS_LEFT (bonus amount remaining)
- REMAINING_CHARGE (partial Charge)
- REQUEST_URI (uri request content)
- RESL (submit result)
- RESULT (frozen or suspended)
- RESULT (general cause)
- RESULT (pi failure)
- RESULT (voucher redemption, always Success)
- RESULT (web - success)
- RETAIL_CHANNEL (voucher details)
- REVERSE_CHARGE (generated by a reverse charge)
- REWARD (ID)
- REWARD_AMOUNTS (value of reward)
- REWARD_TYPES (balance types getting reward)
- RNCF (Reservation Not Charged For)
- ROAMING_COUNTRY (name)
- ROAMING_TYPE (of call)
- ROUTEDEST (routing destination for call)
EDR tags - S
This list covers all application EDRs defined within this guide, starting with the letter S.
- SC (service category)
- SCA (service center address)
- SCENARIO (voucher scenario number)
- SCP_ID (where call originated)
- SCRID (screening rule ID of the message)
- SEGN (message segment number)
- SEGR (concatenated message reference)
- SEGT (total message segments)
- SEQUENCE_NUMBER (call identifier)
- SESSION_SEQUENCE (partial EDR)
- SK (service key)
- SN (service number)
- SRCL (source location)
- SSAD (ip of originating smsc)
- SSRID (screening sub-rule id) (screening sub-rule ID of the message)
- SSTN (smpp service type)
- STATE (of recharge)
- STRR (status report request)
- SUB_STATUS (subscriber status)
- SVC_ID (single tariff rated calls)
EDR tags - T
This list covers all application EDRs defined within this guide, starting with the letter T.
- TAID (terminating adapter id)
- TARIFF_CODE (name)
- TCAU (acs terminate cause value)
- TCE (acs time call ended)
- TCE (ccs time call ended)
- TCS (acs time call started)
- TCS (ccs time call started)
- TERMINAL (Network ID)
- TEXT (voucher details)
- TFN (tracked feature node list)
- TGEO_ID (terminating geo node id)
- TGNA (global terminating network address)
- THRD (throttled flag)
- TIME (creation timestamp of lcr edr)
- TIMED_OUT (reservation confirmation)
- TIMESTAMP (creation timestamp of scr edr)
- TLEN (length of user data in characters)
- TN (acs termination number)
- TN (ccs called number)
- TN (roaming called number)
- TNNUM (lcr terminating number)
- TNNOA (noa of terminating number)
- TO (sip to header content)
- TPNI (terminating private network ID)
- TPO (tariff plan override)
- TYPE (type of edr)
- TYPE_DESCRIPTION (voucher type)
EDR tags - U
This list covers all application EDRs defined within this guide, starting with the letter U.
- ULEN (length of user data)
- USER (operator logon name)
- USRD (user data)
