8 Freeform Recharges
Freeform Recharge Succeeds using the GUI (EDR 8)
Mandatory EDR 8 fields
The recharge succeeds where the account is credited.
This list identifies the mandatory EDR record fields for a successful freeform recharge using the GUI (EDR type 8):
- ACCOUNT_TYPE (Product Type ID)
- ACS_CUST_ID (ACS Customer ID)
- BALANCE_TYPES (existing account)
- BALANCES (pre-transaction account balances)
- BONUS_TYPE (name)
- COSTS (rated calls)
- CS (call status, S or D) (call status, S or D)
- NEW_BALANCE_EXPIRIES (dates after voucher recharge)
- OLD_BALANCE_EXPIRIES (dates before voucher recharge)
- REFERENCE (operator freeform)
- RELOAD_BONUS (promotion name)
- RELOAD_BONUS_AMOUNT (amount applied)
- RELOAD_BONUS_EXPIRY (date remaining bonus expires)
- RELOAD_BONUS_LEFT (bonus amount remaining)
- RESULT (voucher redemption, always Success)
- TERMINAL (Network ID)
- USER (operator logon name)
- WALLET_TYPE (ID of wallet changed)
Optional EDR 8 fields
This list identifies the optional EDR record fields for a freeform recharge succeeds using the GUI (EDR type 8):
- ADJUSTMENT (generated by an adjustment)
- BEARER_TYPE (bearer type for promotions) (bearer type for rewards)
- CHANNEL (for rewards) (for rewards)
- REVERSE_CHARGE (generated by a reverse charge)
- NEW_ACCT_STATE (after update)
- OLD_ACCT_STATE (before update)
Note: The NEW_ACCT_STATE and OLD_ACCT_STATE tags will always be present when the freeform recharge causes a change to the wallet state.
MSISDN additional fields
If the MSISDN ccsCDRLoader plug-in is installed on the SMS, the following field will be present:
- MSISDN (account calling number)
Example EDR 8 for freeform succeeds
BILLING_ENGINE_ID=21|SCP_ID=110537566|SEQUENCE_NUMBER=139450184|CDR_TYPE=8|RECORD_DATE=20040804132135|ACCT_ID=61|ACCT_REF_ID=61|USER=SU|TERMINAL=192.168.25.108|RESULT=Success|BONUS_TYPE=CUSTOM|CS=S|REFERENCE=FreeForm Recharge|ACCOUNT_TYPE=1|BALANCE_TYPES=1|BALANCES=1000|COSTS=-100|OLD_BALANCE_EXPIRIES=0|NEW_BALANCE_EXPIRIES=0|ACS_CUST_ID=1|WALLET_TYPE=1
Example MSISDN
BILLING_ENGINE_ID=21|SCP_ID=110537566|SEQUENCE_NUMBER=13950184|CDR_TYPE=8|RECORD_DATE=20040804132135|ACCT_ID=61|ACCT_REF_ID=61|USER=SU|RESULT=Success|CLI=1234|REFERENCE=FreeForm Recharge|ACCOUNT_TYPE=1|OLD_ACCT_EXPIRY=0|NEW_ACCT_EXPIRY=0|MAX_CONCURRENT=10|NEW_LAST_USE=20040804132122|BALANCE_TYPES=1|BALANCES=1000|COSTS=-100|OLD_BALANCE_EXPIRIES=0|NEW_BALANCE_EXPIRIES=0|ACS_CUST_ID=1|MSISDN=1234
Freeform Recharge Succeeds using PI (EDR 8)
This list identifies the mandatory EDR record fields for a successful freeform recharge using PI (EDR type 8):
- BUCKET_IDS (within balance type recharged)
- NEW_ACCT_EXPIRY (date after update)
- OLD_ACCT_EXPIRY (dates before update)
- PI (logon name and IP address)
This list identifies the optional EDR record fields for a freeform recharge succeeds using PI (EDR type 8):
- REFERENCE (from pi reference)
Platform dependant additional fields
Depending on the installed platform, the following field will be present:
- COMPONENT (from pi command reference)
BILLING_ENGINE_ID=21|SCP_ID=161986004|SEQUENCE_NUMBER=12|CDR_TYPE=8|RECORD_DATE=20070704141927|ACCT_ID=61|ACCT_REF_ID=61|ACS_CUST_ID=1|BALANCES=1000|BALANCE_TYPES=1|BUCKET_IDS=45844|COSTS=-100|NEW_BALANCE_EXPIRIES=|OLD_BALANCE_EXPIRIES=|PI=adminAT192.168.25.106|OLD_ACCT_EXPIRY=0|NEW_ACCT_EXPIRY=0|WALLET_TYPE=1|ACCOUNT_TYPE=1
Example MSISDN
BILLING_ENGINE_ID=21|SCP_ID=161986004|SEQUENCE_NUMBER=12|CDR_TYPE=8|RECORD_DATE=20040804141927|ACCT_ID=61|ACCT_REF_ID=61|ACS_CUST_ID=1|BALANCES=1000|BALANCE_TYPES=1|BUCKET_IDS=45844|COSTS=-100|CS=S|NEW_BALANCE_EXPIRIES=|OLD_BALANCE_EXPIRIES=|PI=adminAT192.168.25.106|REFERENCE=PIFreeForm|WALLET_TYPE=1|ACCOUNT_TYPE=1| LAST_USED=200401011234|MSISDN=1394111111
Freeform Recharge Succeeds using PI (EDR 2)
Mandatory EDR 2 fields
The recharge succeeds where the account is debited.
This list identifies the mandatory EDR record fields for a successful freeform recharge using PI (EDR type 2):
- BONUS_TYPE (name)
Example EDR 2 for freeform succeeds
BILLING_ENGINE_ID=21|SCP_ID=161986004|SEQUENCE_NUMBER=13|CDR_TYPE=2|RECORD_DATE=20040804141927|ACCT_ID=61|ACCT_REF_ID=61|ACS_CUST_ID=1|BALANCES=1100|BALANCE_TYPES=1|RESULT=Success|COSTS=100|CS=S|NEW_BALANCE_EXPIRIES=|OLD_BALANCE_EXPIRIES=|PI=adminAT192.168.25.106|REFERENCE=PI FreeForm|WALLET_TYPE=1|BONUS_TYPE=CUSTOM|ACCOUNT_TYPE=1|OLD_ACCT_EXPIRY=0|NEW_ACCT_EXPIRY=0
Example MSISDN
BILLING_ENGINE_ID=21|SCP_ID=161986004|SEQUENCE_NUMBER=13|CDR_TYPE=2|RECORD_DATE=20040804141927|ACCT_ID=61|ACCT_REF_ID=61|ACS_CUST_ID=1|BALANCES=1100|BALANCE_TYPES=1|BUCKET_IDS=45844|COSTS=100|CS=S|NEW_BALANCE_EXPIRIES=|OLD_BALANCE_EXPIRIES=|PI=adminAT192.168.25.106|REFERENCE=PI FreeForm|WALLET_TYPE=1|ACCOUNT_TYPE=1|OLD_ACCT_EXPIRY=0|NEW_ACCT_EXPIRY=0|MSISDN=1394111111
Freeform Recharge Fails using PI (EDR 2, 8)
A EDR type 2 will be produced for a charge attempt, and a EDR type 8 will be produced for a refund attempt.
This list identifies the mandatory EDR record fields for an unsuccessful PI promotional recharge using PI:
- BONUS_TYPE (name)
- CS (call status, always D)
- NACK (freeform recharge list)
- RESULT (pi failure)
Example EDR 8 for freeform fails
BILLING_ENGINE_ID=21|SCP_ID=161986004|SEQUENCE_NUMBER=12|CDR_TYPE=8|RECORD_DATE=20070704141927|ACCT_ID=61|ACCT_REF_ID=61|ACS_CUST_ID=1|BONUS_TYPE=CUSTOM|CS=D|PI=adminAT192.168.25.106|REFERENCE=PI FreeForm|WALLET_TYPE=1|NACK=WDISP|ACCOUNT_TYPE=1|RESULT=Frozen Wallet
