7 Voice Calls
Successful National Call (EDR 1)
Mandatory EDR 1 fields
This list identifies the mandatory EDR record fields for a successful national call (CDR type 1):
- ACCOUNT_TYPE (Product Type ID)
- ACS_CUST_ID (ACS Customer ID)
- BALANCE_TYPES - use one of:
- BALANCE_TYPES (account changed or created)
- BALANCE_TYPES (account changed or created) - mid call rate changes
- BALANCES - use one of:
- BALANCES (pre-call or account creation)
- BALANCES (pre-call or account creation) - mid call rate changes
- CASCADE_ID - use one of:
- CASCADE_ID (balance type cascade IDs)
- CASCADE_ID (balance type cascade IDs) - mid call rate change
- CLI - use one of:
- CLI (initiating call number)
- CLI (initiating call number) - mid call rate changes
- COSTS - use one of:
- COSTS (rated calls)
- COSTS (rated calls) - mid call rate changes
- DISCOUNTS - use one of
- DISCOUNTS (rated calls)
- DISCOUNTS (rated calls) - mid call rate changes
- DURATION (call length)
- DURATION_CHARGED
- DURATION_DELTA
- END_CALL_REASON (reasons for call termination)
- FCA (final call address)
- LAST_RECORD_DATE
- LENGTHS - use one of:
- LENGTHS (rate durations)
- LENGTHS (rate durations) -1end duration
- LENGTHS (rate durations) - mid call rate changes
- MAX_CHARGE - use one of:
- MAX_CHARGE (for this call)
- MAX_CHARGE (for this call) - mid call rate changes
- OGEO_ID (originating geo node id)
- RATES - use one of:
- RATES (rated calls)
- RATES (rated calls) - mid call rate changes
- SVC_ID (single tariff rated calls)
- TCE (ccs time call ended)
- TCS (ccs time call started)
- TGEO_ID (terminating geo node id)
- TN (ccs called number)
- WALLET_TYPE (ID of wallet changed)
Optional EDR 1 fields
This list identifies the optional EDR record fields for a successful national call (CDR type 1):
- CUG_NAME (closed user group)
- OVERRIDDEN_TARIFF_PLAN (ID)
- RELC (inap release cause)
- TARIFF_CODE (name)
Partial EDR additional fields
Enabling of Mid-Session EDRs production creates Partial EDRs. Either the Commit Volume Threshold or Mid-Session EDRs parameters are enabled (Rating Management > Reservation Config > New Reservation Config screen).
These additional tags are on all the partial EDRs, but not on the final, complete EDR:
- MID_SESSION (partial EDR)
- SESSION_SEQUENCE (partial EDR)
Timed-out reservation confirmation additional fields
If a confirmed reservation times out, these tags will be added to the EDR.
- RNCF (Reservation Not Charged For)
- TIMED_OUT (reservation confirmation)
Account Activated additional fields
If the account is activated, the following fields are generated:
- NEW_ACCT_STATE (always active - A)
- OLD_ACCT_STATE (P or D before update)
Cross balance type discount additional fields
If the cross balance type discounting has been applied during the call, the following fields will be present:
- CBTD_BALANCE_TYPES (list to apply to discounts)
- CBTD_BALANCE_TYPES (list to apply to discounts) - mid call rate changes
- CBTD_BALANCES (value for each cross balance type)
- CBTD_BALANCES (value for each cross balance type) - mid call rate change
- CBTD_CASCADE_ID (used for this call)
- CBTD_CASCADE_ID (used for this call) - mid call rate change
- CBTD_COSTS (costs applied to each cross balance type)
- CBTD_COSTS (costs applied to each cross balance type) - mid call rate changes
- CBTD_DISCOUNTS (discounts applied to balance types)
- CBTD_DISCOUNTS (discounts applied to balance types) - mid call rate changes
MSISDN additional fields
If the MSISDN ccsCDRLoader plug-in is installed on the SMS, the following field will be present:
- MSISDN (account calling number)
Mobile number portability additional fields
If the Mobile Number Portability (MNP) software is installed, the following fields will be present:
- PORTED (name of porting carrier)
Bucket level costs additional field
If addBucketLevelCostsInEdr configuration is enabled, the following field will be present:
- BUCKET_LEVEL_COSTS
Example EDR 1 for single tariff rated call
BILLING_ENGINE_ID=21|SCP_ID=366273322|SEQUENCE_NUMBER=487291|CDR_TYPE=1|RECORD_DATE=20070423190107|ACCT_ID=83| ACCT_REF_ID=83|CLI=01206233252|ACS_CUST_ID=1|BALANCE_TYPES=1|BALANCES=49880|COSTS=120|ACCOUNT_TYPE=22|CASCADE_ID=44|RATES=60|LENGTHS=2810.00|DISCOUNTS=0| MAX_CHARGE=500|DURATION=120.00|DURATION_CHARGED=120.00|TN=01473|TCS=20070423181310| TCE=20070423181510|CS=S|DISCOUNT_TYPE=S*W*R|WALLET_TYPE=1|FCA=01473254338|END_CALL_REASON=14
Example EDR 1 for multi tariff rated call
BILLING_ENGINE_ID=42|SCP_ID=789955221|SEQUENCE_NUMBER=11775353|CDR_TYPE= 1|RECORD_DATE=20070430180652| ACCT_ID=261|ACCT_REF_ID=255|CLI=6610|ACS_CUST_ID=1|BALANCE_TYPES=1,2|BALANCES=1 80,100|COSTS=60,45|ACCOUNT_TYPE=1| CASCADE_ID=1,49|RATES=aa:10,10,10,20,20,30,30,30,bb:5,10,20,20,15,15,20,20| LENGTHS=aa:30.00,15.00,15.00,30.00,30.00,30.00,60.00,0.00,bb:30.00,15.00,15.00, 30.00,30.00,30.00,60.00,0.00| DISCOUNTS=aa:0,0,0,0,0,0,0,0,bb:0,0,0,0,0,0,0,0| MAX_CHARGE=-1|DURATION=180.00|DURATION_CHARGED=180.00|TN=6610|TCS=20070430180659| TCE=20070430180959|CS=S|DISCOUNT_TYPE=BASIC|WALLET_TYPE=1|FCA=6610|END_CALL_REASON=16
Example Account Activated
BILLING_ENGINE_ID=21|SCP_ID=366273322|SEQUENCE_NUMBER=487291|CDR_TYPE=1|RECORD_DATE=20040803142342|ACCT_ID=83|ACCT_REF_ID=83|CLI=01206233252|ACS_CUST_ID=1|BALANCE_TYPES=1|BALANCES=1000|COSTS=1|ACCOUNT_TYPE=1|CASCADE_ID=1|RATES=50,25|LENGTHS=120.00,40.00|DISCOUNTS=0,0|MAX_CHARGE=1|DURATION=160|DURATION_CHARGED=160|TN=01473289900|TCS=20040803141934|TCE=20040803142034|CS=S|OLD_ACCT_STATE=P|NEW_ACCT_STATE=A|DISCOUNT_TYPE=S*W*R|WALLET_TYPE=1|END_CALL_REASON=14
Example Account Activated - MSISDN
BILLING_ENGINE_ID=21|SCP_ID=366273322|SEQUENCE_NUMBER=487291|CDR_TYPE=1|RECORD_DATE=20040803142342|ACCT_ID=83| ACCT_REF_ID=83|CLI=01206233252|ACS_CUST_ID=1|BALANCE_TYPES=1|BALANCES=1000|COSTS=28|ACCOUNT_TYPE=1|CASCADE_ID=1| RATES=50,25|LENGTHS=120.00,40.00|DISCOUNTS=450000,560000| MAX_CHARGE=500|DURATION=160|DURATION_CHARGED=160|TN=01473289900|TCS=20040803141934| TCE=20040803142034|CS=S|DISCOUNT_TYPE=S*W*R|WALLET_TYPE=1|MSISDN=01206233252|END_CALL_REASON=14
Commit Reservation (EDR 1)
This list identifies the mandatory EDR record fields when a Commit Reservation has been performed (CDR type 1):
- CLI - use one of:
- CS (call status, S or D) (call status, S or D)
- DISCOUNT_TYPE (applied to this call) - R*W
- DURATION_CHARGED
- MFILE (for rating data)
- OPERATOR_RELEASED (commit/revoke reservation)
- TERMINAL (Network ID)
- USER (operator logon name)
Example EDR 1 for reservation commit
BILLING_ENGINE_ID=21|SCP_ID=366273322|SEQUENCE_NUMBER=487291|CDR_TYPE=1|RECORD_DATE=20070423190107|ACCT_ID=83| ACCT_REF_ID=83|CLI=49393520|BALANCE_TYPES=1|BALANCES=89140|COSTS=540|RATES=60|LENGTHS=-1|DISCOUNTS=0|MAX_CHARGE=2000|CASCADE_ID=1|ACS_CUST_ID=1|ACCOUNT_TYPE=21|DURATION=540.00|DURATION_CHARGED=540.00|TN=47777777|TCS=20100602225949|TCE=20100602230025|CS=S|DISCOUNT_TYPE=R*W|MFILE=20100602203530|USER=SU|TERMINAL=192.168.2.68|OPERATOR_RELEASED=1|END_CALL_REASON=15
Revoke Reservation (EDR 1)
This list identifies the mandatory EDR record fields when a Revoke Reservation has been performed (CDR type 1):
- CLI - use one of:
- DURATION_CHARGED
BILLING_ENGINE_ID=21|SCP_ID=366273322|SEQUENCE_NUMBER=487291|CDR_TYPE=1|RECORD_DATE=20070423190107|ACCT_ID=83| ACCT_REF_ID=83|ACS_CUST_ID=1|ACCOUNT_TYPE=21|DURATION=0.00|DURATION_CHARGED=60|TN=47777777|TCS=20100602034410|TCE=20100602034432|CS=S|DISCOUNT_TYPE=R*W|MFILE=20100602032245|OPERATOR_RELEASED=1|USER=SU|TERMINAL=192.168.2.68|CLI=49393520
Declined National Call
This list identifies the mandatory EDR record fields for a declined national call (EDR type 1):
- NACK (long list of codes)
This list identifies the optional EDR record fields for a declined national call (EDR type 1):
Example EDR 1 for declined national call
BILLING_ENGINE_ID=21|SCP_ID=230612530|SEQUENCE_NUMBER=487291|CDR_TYPE=1|RECORD_DATE=20070703121758|ACCT_ID=83|ACCT_REF_ID=83|CLI=01206233252|TN=01473289900|TCS=20070725124332|CS=D|ACCOUNT_TYPE=15| NACK=INSF|WALLET_TYPE=1|ACS_CUST_ID=1END_CALL_REASON=13
BILLING_ENGINE_ID=21|SCP_ID=230612530|SEQUENCE_NUMBER=487291|CDR_TYPE=1|RECORD_DATE=20040803121758|ACCT_ID=83|ACCT_REF_ID=83|CLI=01206233252|TN=01473289900|TCS=20040625124332|CS=D|ACCOUNT_TYPE=15|NACK=INSF|WALLET_TYPE=1|ACS_CUST_ID=1|OLD_ACCT_STATE=P|NEW_ACCT_STATE=A|END_CALL_REASON=14
Example MSISDN
BILLING_ENGINE_ID=21|SCP_ID=230612530|SEQUENCE_NUMBER=487291|CDR_TYPE=1|RECORD_DATE=20040803121758|ACCT_ID=83|ACCT_REF_ID=83|CLI=01206233252|TN=01473289900|TCS=20040625124332|CS=D|ACCOUNT_TYPE=15| NACK=INSF|WALLET_TYPE=1|ACS_CUST_ID=1|OLD_ACCT_STATE=P|NEW_ACCT_STATE=A|MSISDN=01206233252|END_CALL_REASON=14
Direct Amount Charge (EDR 6)
Mandatory EDR 23 fields
This list identifies the mandatory EDR record fields for a direct amount charge (EDR type 6):
- APPLICATION_DESC (application freeform)
- NEW_ACCT_EXPIRY (date after update)
- NEW_ACCT_STATE (after update)
- NEW_BALANCE_EXPIRIES (date after balance update)
- OLD_ACCT_STATE (before update)
- OLD_ACCT_EXPIRY (dates before update)
- OLD_BALANCE_EXPIRIES (dates before voucher recharge)
- REFERENCE (OSA bonus)
- WALLET_TYPE (ID of wallet recharged)
Note: See EDR header fields for a list of fields common to every EDR.
