23 SES Feature Nodes
Overview
Introduction
This chapter describes the Oracle Communications Convergent Charging Controller Subscriber Event Service (SES) feature nodes.
You use SES feature nodes to check which subscribers are entering or leaving a network using SES, and to configure which messages should be sent to these subscribers.
Available Feature Nodes
SES Feature Nodes List
Use SES feature nodes in your control plans to determine if a subscriber qualifies for messages, and to configure the selection of the messages to send.
This table lists the feature nodes available from the SES palette group and the fast key for each feature node in the list. You can use fast keys to search for feature nodes in the palette or the canvas.
Node name Node description
In-Roamer Contact Check
This feature node checks for the last time the subscriber was contacted on entering the network.
Fast key: IRCC
In-Roamer Messages Selection
This feature node configures which messages to send to an inbound subscriber.
Fast key: IRMS
Out-Roamer Contact Check
This feature node checks for the last time the subscriber was contacted on leaving the network.
Fast key: ORCC
Out-Roamer Messages Selection
This feature node configures which messages to send to an outbound subscriber.
Fast key: ORMS
Node description
When a roaming subscriber enters your network, this node checks the duration since any previous inbound roaming contact with the subscriber, by looking up the contact history, and compares the duration with the period of days configured in the node.
Node icon
This is image alt text.
If the CPE has been configured to use the static panel CPE palette style, the CPE displays the icon shown below to represent the feature node.
Restrictions
A control plan may contain as many In-Roamer Contact Check nodes as required.
Node exits
This node has one entry and two exits. The number of exits cannot be changed.
Exit Cause Description
1 Contacted The subscriber has been contacted within the configured number of days.
2 Not Contacted The subscriber has not been contacted within the configured number of days (includes never been contacted and any system failures).
Configuration screen
Here is an example Configure In-Roamer Contact Check screen.
Using the node
For descriptions of how this node is used, refer to the following topics in SES User's and Technical Guide:
  • Example Control Plan - In-Roamer
  • Example scenarios
Configuring the node
Follow these steps to edit the node.
Step Action
1
Type a value in days in the Period field.
Note: Blank or zero means the subscriber will be contacted every time they enter the network.
2 Click Save.
Node description
This node selects the messages for sending to the subscriber, based on the message priority, the number of messages to be sent, and the message selection option used. For more information, see SES User's and Technical Guide, System Overview chapter.
Node icon
Restrictions
A control plan may contain as many In-Roamer Messages Selection nodes as required, however they should be placed after an In-Roamer Contact Check node to ensure they do not get messages every time.
Node exits
1 No Messages Selected No messages were selected (includes system failures).
2 Messages Selected At least one message was selected.
Here is an example Configure In-Roamer Messages Selection screen.
Using the node
  • Example scenarios
Editing the node
Follow these steps to edit the In-Roamer Messages Selection node.
Step Action
1
Type the maximum number of messages to send to the subscriber in the Number field.
Note: Currently the maximum is about 2 billion.
2
Select either the Random or Latest message Selection Method.
Note: Messages are configured to be priority, or non priority (see SES User's and Technical Guide, SES Configuration - Messages Tab). For either option, the priority messages are used to fulfill the Number parameter before the non priority messages. See SES User's and Technical Guide, SES Example scenarios.
Note: Latest is the message with the most recent availability date.
3 Click Save.
Node description
When a roaming subscriber leaves your network, this node checks the duration since any previous out-roaming contact with the subscriber, by looking up the contact history, and compares the duration with the period of days configured in the node.
Node icon
Restrictions
A control plan may contain as many Out-Roamer Contact Check nodes as required.
Node exits
This node has one entry and three exits. The number of exits cannot be changed.
1 Opted Out
The subscriber has opted out of being contacted on leaving the network.
Note: This flag is configurable. Refer to SES User's and Technical Guide, macroNodes configuration, for the value of the tag used.
2 Contacted The subscriber has been contacted within the configured number of days.
3 Not Contacted The subscriber has not been contacted within the configured number of days (includes never been contacted and any system failures).
Using the node
For descriptions of how this feature node is used, see the following topics in Subscriber Event Service User's and Technical Guide:
  • Example Control Plan - Out-Roamer
  • Example scenarios
Here is an example Configure Out-Roamer Contact Check screen.
Step Action
1
Note: Blank or zero means the subscriber will be contacted every time they exit the network.
2 Click Save.
Node description
This node selects the messages for sending to the subscriber, based on the message priority, the number of messages to be sent, and the message selection option used. For more information, see the discussion of system overview in Subscriber Event Service User's and Technical Guide.
Node icon
Restrictions
A control plan may contain as many Out-Roamer Messages Selection nodes as required, however they should be placed after an Out-Roamer Contact Check node to ensure they do not get messages every time.
Node exits
Here is an example Configure Out-Roamer Messages Selection screen.
Using the node
  • Example scenarios
Follow these steps to edit the Out-Roamer Messages Selection node.
Step Action
1
Note: Currently this is about 2 billion.
2
Note: Messages are configured to be priority or no priority (see SES Configuration - Messages Tab). For either option, the priority messages are used to fulfill the Number parameter before the no priority messages. See SES Example scenarios.
3 Click Save.
