9 Configuration Scenarios
Overview
Introduction
This chapter explains how Messaging Manager configuration is completed through the use of several scenarios.
Mobile to SMSC Messaging
Description
The Mobile to SMSC messaging (MO SMS) service allows subscribers to send short messages from their mobile phone to the SMSC, for delivery to another mobile phone.
This example covers creating a routing scheme to route messages to an SMSC through IP. Each set of steps for this example follow in the order presented.
MO SMS diagram
Using only the Messaging Manager base module, MM can be configured to provide an MO SMS service. In this example we will receive mobile originating MAP messages and deliver to the SMSC over TCP/IP using the SMPP protocol. The following diagram shows the modules required.
This is alt image text.
Process overview
This table lists the procedures that you need to follow to complete this scenario.
Step Action
1 Create MAP adapter
2 Create routing scheme
3 Create message center
4 Create SMPP adapter
5 Create SMSC path
6 Create SMSC connection
7 Create domain
8 Create submit routing rule (using MAP domain out to SMSC path)
Create MAP adapter
The adapter name in the GUI must match exactly the adapterName parameter in the eserv.config for the MAP protocol.
For this example we assume the eserv.config has the following:
# Adapter definitionsadapters = [# First adapter (MAP){#
adapter identifier.#adapterName = "MAP1"..}
Follow these steps to configure a MAP adapter, which will be used for receiving inbound SMSs.
Step Action
1 Configure the MAP adapter in the MM eserv.config file. For more information, see MM Technical Guide.
2
On the Configuration screen, Adapters tab, click New.
Result: The New Adapter screen opens.
3 In the Name field, enter MAP1.
4
In the Protocol field, select MAP.
Result: The screen should look like this:
5 Click Save to save the new adapter record in the configuration database.
Create Routing Scheme
Follow these steps to create a new routing scheme.
Step Action
1
On the Configuration screen, Schemes tab, click New.
Result: The New Scheme screen opens.
2
In the Name field, enter Mobile2SMSC
Result: The Save button becomes available.
3 Ensure the Default network field is set to Default.
4
In the Description field, enter a description for this scheme.
Example:
Scheme for Mobile to SMSC
messaging.
5
Ensure the Also create default domain check box is selected.
Result: The screen should now look like this:
6
Click Save to save the new scheme record in the configuration database.
Result: Messaging Manager automatically generates an MC (to/from an SMSC) and an SME (to from an MSC/HLR) path for the MAP1 adapter created in step 1.
Create Message Center
Follow these steps to create a Message Center.
Step Action
1
On the Configuration screen, Message Centres tab, click New.
Result: The New Message Centre screen opens.
2 In the Message Centre Name field, enter Message Centre 1
3
In the Service centre address field you would normally enter the global title of the service center to be used. For IP service centers, this is not used, but something has to be entered.
Result: The Save button will appear.
4 Click Save to save the new record to the database.
Create SMPP adapter
The adapter name in the GUI must match exactly the adapterName parameter in the eserv.config for the SMPP protocol.
# Adapter definitionsadapters = [# Third adapter (SMPP){#
adapter identifier.#adapterName = "SMPP1"..}
Follow these steps to configure an SMPP adapter, which will be used for submitting SMSs to the SMSC.
Step Action
1
2 In the Name field, enter SMPP1
3
In the Protocol field, select SMPP.
Result: The screen should look like this.
4 Click Save to save the new adapter in the configuration database.
Create SMSC path
Configure one or more outbound paths to the SMSC over the SMPP protocol.
Follow these steps to add the required paths.
Step Action
1
In the grid on the Configuration screen, Schemes tab, click on the Mobile2SMSC scheme to add the outbound paths to and click Open.
Result: The Messaging Manager Scheme 'Mobile2SMSC' screen opens.
2
Select the Paths tab and click New.
Result: The New Path screen opens.
3 In the Name field, type
Mobile2SMSC SMPP
SMSC
4
From the Adapter drop down list, select SMPP1.
5
From the Endpoint type drop down list, select MC.
Note: Where the message is being sent using SMPP to an SMSC, we select MC as the endpoint. Where the message is being sent to an ASP, we select SME as the endpoint.
6 Click Save to save the new Path to the configuration database.
7 Repeat steps 3 to 8, adding the
Mobile2SMSC SMPP
ASP
path with and Endpoint of SME.
Follow these steps to add a connection to the outbound path.
Step Action
1 In the table on the Paths tab, select the Mobile2SMSC SMPP SMSC path.
2
Click Add Connection.
Result: The New SMPP Connection panel opens.
Mobile2SMSC SMSC
Connection 1
4 In the Weighting field, enter 10
5 Select the Preopen, RX and TX check boxes to allow the receiving and sending of transmissions.
6 In the Remote username field, enter msgout
7 In the Remote password field, enter msgout
8 In the Remote listen field, enter 205.100.97.53
9
In the Remote Listen Port field, enter 5000.
Result: The screen should now look like this.
10 Click Save to save the new connection to the configuration database.
11 In the table on the Paths tab, select Mobile2SMSC SMPP ASP path and click New Connection.
12 In the Name field, enter
Mobile2SMSC ASP
Connection 1
13 In the Weighting field, enter 10.
14 Select the RX and TX check boxes.
15 In the Local Username and Local Password fields, enter lclout.
16 In the Remote Username and Remote Password fields, enter msgout.
17 In the Remote Listen field, enter 205.100.97.53.
18
In the Port field, enter 5000.
19 Click Save to save the new connection to the configuration database.
Create domain
Identify the domains that are wanted to route to the SMSC through IP.
Follow these steps to add routing address prefixes:
Step Action
1
In the table on the Configuration screen, Schemes tab, click on the Mobile2SMSC routing scheme and click Open.
2 Select the Domains tab and click New.
3
MAP
Inbound
4
Click Save.
Result: The Domain will be saved and be selected in the table.
5 Select the Screening tab and select the Originating Address Screening rule.
6 Click Add.
7 In the Incoming path name prefix field, enter MAP Inbound.
8 In the Originating address prefix field, enter 033.
9
Select MAP Inbound from the Allocate domain drop-down list.
10 Click Save.
11 Steps 7 to 11can be repeated to build up a list of routing address prefixes for this routing scheme.
Create Submit routing rule
The Routing rules enable Messaging Manager to have a list of paths to attempt routing over. Messaging Manager will attempt routing using the first path, second and so on down the list.
Follow these steps to establish a list of paths.
Step Action
1
In the table on the Configuration screen, Schemes tab, click on the Mobile2SMSC scheme and click Open.
2 Select the Routing tab and click New.
3 In the Routing Class drop down list, select Submit.
4 In the Message centre drop down list, select Message Centre 1.
5 In the Originating domain drop down list, select MAP Inbound.
6 From the Paths sequencing drop down list, select Mobile2SMSC SMPP SMSC.
7
Click Add.
8 Click Save.
Application to Mobile Messaging
Description
Application to mobile is a simple service that provides basic delivery of SMSs to a mobile phone.
Application to Mobile diagram
Using only the Messaging Manager Base module, MM can be configured to provide an application to mobile service. In this example we will receive EMI protocol messages from ASPs and deliver them to an SMSC over SS7 using the IS-41 protocol.
The following diagram shows the modules required:
This is image alt text.
Process overview
Step Action
1 Create EMI adapter
3 Create EMI SMSC path
4 Create EMI SMSC connection
5 Create EMI ASP path
6 Create EMI ASP connection
7 Create address range
8 Create throttling rule
9 Configure trigger rule
10 Configure routing rule
11 Configure Messaging Manager node
Create EMI Adapter
The adapter name in the GUI must match exactly the adapterName parameter in the eserv.config for the EMI protocol.
# Adapter definitionsadapters = [# Second Adapter (EMI){#
adapter identifier.#adapterName = "EMI1"..}
Follow these steps to configure an EMI adapter, which will be used for receiving inbound SMSs:
Step Action
1 Configure the EMI Adapter in the Messaging Manager eserv.config file. For more information, see the MM Technical Guide.
2
On the Configuration screen, Adapters tab, click New....
3 In the Name field, type EMI1.
4
In the Protocol field, select EMI.
5 Click Save to save the new Adapter record in the configuration database.
Step Action
1
2
In the Name field, type App2Mobile
3 In the Description field, type a description for this scheme.
4
Ensure the Also create default domain check box is ticked.
Result: The screen should now look similar to this:
5 Click Save to save the new Scheme record in the configuration database.
Follow these steps to create a default routing path to an SMSC via EMI:
Step Action
1 In the grid on the Schemes tab, click on the App2Mobile scheme.
2 Click Open.
3
4
EMI
SMSC
Note: The Name can be generic since this path can also be used by other paths as their default routing path.
5
From the Adapter drop down list, select EMI Adapter.
Result: the Save button becomes available.
6
From the Endpoint type field, select MC.
7 Click Save to save the new Path to the configuration database.
Follow these steps to create and configure an EMI SMSC connection:
Step Action
1 In the grid on the Paths tab, click on the EMI SMSC path.
2
Result: The New EMI Connection screen displays.
3
EMI SMSC
Connection
4 In the Weighting field, type 10.
5 Tick the Preopen, RX and TX check boxes to allow the receiving and sending of transmissions.
6 In the Local username and Local password fields, type local.
7 In the Port fields, type 5000.
8
The EMI Options will have default values assigned.
These can be changed as required. For instance, select Allow Alternative Source Address and force a Session Timeout of 60 seconds.
Result: The screen should now look similar this:
9 Click Save to save the new Connection to the configuration database.
Create EMI ASP path
Follow these steps to create and configure the inbound ASP path:
Step Action
2 Click Open.
3
Click the Paths tab and click New.
Result: The New Path panel opens.
4 In the Name field, type
Stock
Quotes
5
From the Adapter drop down list, select EMI1
6 From the Endpoint type drop down list, select SME.
7
From the Default routing path drop down list, select EMI SMSC.
8 Click Save to save the new Path to the configuration database.
Follow these steps to create and configure an EMI connection to the ASP:
Step Action
1 In the grid on the Paths tab, click on the Stock Quotes path.
2
Click Add Connection to add a Connection to the selected path.
3
Stock Quote
1
5 Select the RX and TX check boxes to allow the receiving and sending of transmissions.
6 In the Local username and Local password fields, type stock.
7
In the Local listen port field, type 5000.
In the Local source port field, type 1512
8
These can be changed as required. For instance, select Allow alt. source address and force a Session timeout of 60 seconds.
Identify the domains that will be used to route from the ASP (short code 123) to a mobile phone.
Follow these steps to add new domains:
Step Action
1 On the Schemes tab, select the App2Mobile routing scheme.
2 Click Open.
3 Select the Domains tab and click New....
4
In the Name field, type Stock_Quotes.
5
Click Save.
The Domain will be saved and be selected in the grid.
6 Click New....
7
In the Name field, type Telco_Local_Subscribers.
8
Click Save.
9 Select the Screening tab and select the Originating Address Screening rule.
10 Click Add....
11 In the Incoming path name prefix field, type Stock Quotes
12 In the Originating address prefix field, type 123.
13
Select Stock_Quotes from the Allocate domain drop-down list.
14 Click Save.
15 Select the Destination Address Screening rule.
16 Click Add....
17 In the Incoming path name prefix field, type Stock Quotes.
18 In the Destination address prefix field, type 056.
19
Select Telco_Local_Subscribers from the Allocate domain drop-down list.
20 Click Save.
21 Steps 16 to 20 can be repeated to build up a list of address prefixes for the domain.
Create Throttling Rule
Follow these steps to set the throttling values for the path. Traffic from the ASP will only be accepted if the system is running below 50% capacity:
Step Action
1 Select the Throttling tab and click New.
2 In the Detection point field, select Submit.
3 In the Originating domain field select Stock_Quotes.
4
In the Throttle field, type 50
5 Click Save.
Configure Trigger Rule
Follow these steps to configure a trigger rule:
Step Action
1 On the Triggering tab, click New.
2 From the Detection point drop down list, select Submit
3 From the Originating Domain drop down list, select Stock_Quotes.
4 Select the Route action from the Perform action: drop down list.
5
Select the Set routing class check box and from drop down list, select Deliver
6 Click Save.
Follow these steps to establish a list of paths:
Step Action
1 Create CDMA Adapter as in the Mobile to Application Messaging scenario if it doesn't already exist.
2 On the Routing tab, from the Routing class drop down list, select Deliver.
3
Click New....
Result: The New Routing Rule screen will open. The Routing class field will be populated with Deliver.
4 From the Destination domain drop down list, select Telco_Local_Subscribers.
5 From the Originating domain drop down list, select Stock_Quotes.
6 From the Paths sequencing drop down list, select IS41_CDMA_SME_CDMA Adapter.
7
Click Add.
Results:
  • The path will be added to the Paths sequencing list.
  • The screen should now like similar to this:
8 Click Save.
To enable loading of a routing scheme by Messaging Manager, the scheme is associated with the node listed in the eserv.config file.
Follow these steps to associate the scheme just configured with the SCP01 node:
Step Action
1 From the table on the Nodes tab, select the node, in this example, SCP01.
2
Click Edit.
Result: The Edit Node screen opens.
3
From the Scheme list, select APP2Mobile.
Result: The screen will look similar to this:
4 Click Save.
5
Click Close.
Result: This example configuration is now complete.
Description
The mobile to application to service provides delivery of SMSs that originated on a mobile phone to an ASP.
Messaging Manager will attempt to deliver the SMS directly to the ASP, falling back to an SMSC if the direct delivery (FDA) fails.
Setting the scene
This example covers the configuration required for the following flows:
FDA deliver attempt success
FDA submit attempt success
Default routing path attempt success
Mobile to Application diagram
Using the Messaging Manager Multigate and the Messaging Manager Director modules, MM can be configured to provide a Mobile to Application service. In this example we will receive mobile originating IS-41 messages and deliver them to ASPs over EMI using FDA. This diagram shows the modules required.
Process overview
Step Action
1 Create a CDMA adapter
3 Create SMSC path
4 Configure SS7 SMSC path connection
5 Assign default routing path to inbound CDMA path
6 Create outbound path
7 Configure outbound path EMI connection
8 Create EMI SMSC path
9 Configure inbound path EMI connection
10 Create originating domain
11 Configure originating domain rule
12 Create destination domain
13 Configure destination domain rule
14 Create throttling rule
15 Configure trigger rule
16 Configure deliver routing rule
17 Configure submit routing rule
18 Configure Messaging Manager node Messaging Manager
Create CDMA Adapter
The adapter name in the GUI must match exactly the adapterName parameter in the eserv.config for the IS41 CDMA protocol.
# Adapter definitionsadapters = [# IS-41 CDMA Adapter{#
adapter identifier.#adapterName = "CDMA1"..}
Follow these steps to configure a CDMA adapter, which will be used for receiving inbound SMSs:
Step Action
1 Configure the CDMA adapter in the Messaging Manager eserv.config file. For more information, see MM Technical Guide.
2
3 In the Name field, enter CDMA1
4
From Protocol list, select IS41_CDMA.
Step Action
1
2
In the Name field, type Mobile2App.
3 In the Description field, enter a description.
4
5 Click Save to save the new scheme record in the configuration database.
Create SMSC path
Follow these steps to create a CDMA SMSC path.
Step Action
1 In the table on the Schemes tab, select the Mobile2App scheme to add the default routing path to.
2 Click Open.
3
Select the Paths tab and click New....
4
CDMA
SMSC
Note: The Name can be generic since this path can be used many times by other schemes/ paths as their relay path.
5 From the Adapter drop down list, select CDMA1.
6 From the Endpoint type drop down list, select MC.
7
Select the This is a trusted path check box.
8 Click Save to save the new path to the configuration database.
Follow these steps to add a SS7 connection to the SMSC path.
Step Action
1 In the table on the Paths tab, select the CDMA SMSC path.
2
Result: The New SS7 Connection screen opens.
SMSC
Connection1
4 Select the Outbound check box.
5 In the SS7 field, enter 021
6
In the GT field, enter 071234567
Note: When adding a new connection the Save button becomes available after entering either PC or GT and SS7 fields.
7
In the Weight field, type 1 (may need to deselect the Failover check box first).
Note: With a single connection, any non-zero value equates to a maximum loading.
8 Click Save to save the new connection to the database.
Follow these steps to assign a default routing path to the predefined CDMA SME path. This will be used for all inbound MO traffic that has no specific routing rule defined.
Step Action
1 In the table on the Paths tab, select the inbound path IS41_CDMA_SME_CDMA1_Adapter.
2
Click Edit.
Result: The Edit Path 'path_name' screen appears.
3
From the Default routing path drop down list, select CDMA SMSC.
4 Click Save.
Follow these steps to create an outbound path to the EMI ASP.
Step Action
1
Pop
Idol
3 From the Adapter drop down list, select EMI1
4
Note: Where the message is being sent using EMI to an SMSC, we select MC as the endpoint. Where the message is being sent to an ASP, we select SME as the endpoint.
5 Click Save to save the new path to the configuration database.
Follow these steps to create and configure an EMI ASP connection.
Step Action
1 In the table on the Paths tab, select the path Pop Idol.
2
Result: The New EMI Connection screen opens.
3
Pop Idol
connection
Note: When adding a new connection the Save button becomes available on entering the Name field.
4 In the Weighting field, enter 10.
5 Select the Preopen check box to allow the connection to open on Messaging Manager startup/ reload.
6 Select the RX and TX check boxes to allow the receiving and sending of transmissions.
7 In the Local username and Local Password fields, enter popidol
8
In the Local listen Port field, enter 5000
In the Local source Port field, enter 1512
9
The EMI options will have default values assigned. These can be changed as required.
10 Click Save to save the new connection to the database.
Follow these steps to add an outbound path to the SMSC via EMI.
Step Action
1
SMSC via
EMI
3 From the Adapter drop down list, select EMI1.
4
Follow these steps to create and configure an EMI connection.
Step Action
1 In the table on the Paths tab, select the path SMSC via EMI.
2
3
SMSC via
EMI
connection
7 In the Remote username and Remote password fields, enter smsc
8 In the Remote listen field, enter 200.10.20.1
9 In the Remote listen Port field, enter 5000
10
Result: The screen should look similar this:
11 Click Save to save the new connection to the database.
Create originating Domain
Follow these steps to add an originating message domain.
Step Action
1 In the table on the Schemes tab, select the Mobile2App routing scheme.
2 Click Open.
3
Result: The New Domain screen opens.
4
In the Name field, enter Originating.
5 Click Save.
Configure originating Domain Rule
Follow these steps to add a rule to the selected address domain.
Step Action
1
On the Screening tab, select the Originating Address Screening rule and click Add....
Result: The Add Originating Screening Rule screen opens.
2
In the Incoming path name prefix field, enter IS41_CDMA_SME_CDMA Adapter
This applies the address rule to a single path - the default inbound CDMA path from a handset.
3 In the Originating address prefix field, type 023
4
From the Allocate domain drop-down list select Originating.
5 Click Save to save the new domain rule to the configuration database.
Create destination Domain
Follow these steps to add a destination message domain.
Step Action
1
Select the Domains tab of the Mobile2App Scheme screen, and click New.
2
In the Name field, enter PopIdol
3 Click Save.
Configure destination Domain Rule
Follow these steps to add a rule to the selected domain.
Step Action
1
In the table on the Screening tab, select the Destination Address Screening rule and click Add....
Result: The Add Destination Screening Rule screen opens.
2
In the Incoming path name prefix field, enter IS41_CDMA_MO_IN_CDMA Adapter
3 In the Destination Address Prefix field, enter 777
4
Select PopIdol from the Allocate domain drop-down list.
Step Action
2 In the Detection Point field, select Submit.
3 In the Originating domain field, select Originating.
4
In the Throttle field, enter 60.
5 Click Save.
Follow these steps to configure a trigger rule.
Step Action
1 On the Triggering tab, from the Detection point drop down list, select Submit.
2
Click New....
Result: The New Trigger Rule screen will open. The Detection point field will be populated with Submit.
3 From the Originating Domain drop down list, select Originating.
5
Select the Set routing class check box and from drop down list, select FDA.
6 Click Save.
Configure deliver Routing Rule
The Routing rules enable Messaging Manager to have a list of paths to attempt routing over. Messaging Manager will attempt delivery using the first path, second and so on down the list.
Because the FDA routing class was specified in the trigger rule above. Messaging Manager will firstly attempt routing using a Deliver routing rule, then using a Submit routing rule.
Follow these steps to establish a Deliver routing rule with a list of SME paths.
Step Action
1 On the Routing tab, from the Routing class drop down list, select Deliver.
2
Click New....
Note: This represents the first delivery attempt for the FDA.
3 From the Destination domain drop down list, select PopIdol.
4 From the Originating domain drop down list, select Originating.
5
From the Paths sequencing drop down list, select Pop Idol and click Add.
6 Click Save.
Configure submit Routing Rule
The routing rules enable Messaging Manager to have a list of paths to attempt routing over. Messaging Manager will use the paths in a Submit routing rule after the Deliver leg of FDA routing has failed.
Follow these steps to establish a Submit rule with a list of SMSC paths.
Step Action
1 On the Routing tab, from the Routing class drop down list, select Submit.
2
Click New....
Result: The New Routing Rule screen will open. The Routing class field will be populated with Submit.
Note: This represents the second delivery attempt for the FDA.
3 From the Message centre drop down list, select Default.
5
From the Paths sequencing drop down list, select SMSC via EMI.
Note: This represents the Submit attempt part of a failed FDA delivery.
6 Click Add.
7
From the Paths sequencing drop down list, select CDMA SMSC.
Note: This represents the Default routing path attempt after a failed FDA.
8 Click Add.
9 In the Retries field, enter 3.
10
In the Interval field, enter 3.
11 Click Save.
Step Action
2
Click Edit.
3
From the Scheme list, select Mobile2App.
4 Click Save.
5
Click Close.
Mobile to Mobile triggering to ACS
Description
The Mobile to Mobile messaging (MO SMS) service allows customers to send short messages from one mobile phone to another.
In this example messages will be triggered to an ACS control plan to route large messages to a specific SMSC.
Diagram
Using the Messaging Manager Multigate and the Messaging Manager Director modules, MM can be configured to provide a Mobile to Mobile service, triggering to ACS. In this example we will receive mobile originating MAP messages and deliver them to SMSCs over MAP having triggered them to ACS to offload all large messages to a separate SMSC. The following diagram shows the modules required:
Process overview
Step Action
3 Create new message center
4 Create MC path
5 Create MC path SS7 connection
6 Create large MC path
7 Create large MC path connection
8 Create address range
9 Create control plan
10 Create trigger rule
11 Configure standard routing rule
12 Configure large message routing rule
13 Configure Messaging Manager node
Create MAP adapter
Step Action
2
4
Follow these steps to create a new routing scheme:
Step Action
1
On the Configuration screen, Schemes tab, click New....
2
In the Name field, enter Mobile2ACS.
3
Example:
Scheme for Mobile to ACS
messaging
4
5
Result: All the required Messaging Manager inbound paths for the MAP protocol are automatically generated by Messaging Manager.
Create new Message Center
Follow these steps to create a separate message center for large messages.
Step Action
1
On the Message Centres tab, click New....
2 In the Message centre name field, enter Large Message Centre.
3
In the Service centre address field, enter 122.
Result: The Save button will appear, and the screen should look like this:
4 Click Save to save the new message center record to the database.
Create MC path
Follow these steps to create a MAP path to the standard SMSC.
Step Action
1 In the table on the Schemes tab, select the Mobile2ACS scheme to add the inbound path to.
2 Click Open.
3
4 In the Name field, enter
MAP
SMSC
5
6
7 Click Save to save the new path to the configuration database.
Follow these steps to add an SS7 connection to the standard SMSC path.
Step Action
1 In the table on the Paths tab, select the MAP SMSC path.
2
3
MAP SMSC
connection
5 In the PC field, enter 50
6 In the SSN field, enter 8
7 In the GT field, enter 6449393367
8
In the Weight field, enter 1 (may need to clear the Failover check box first).
9 Click Save to save the new connection to the database.
Follow these steps to create a MAP path to the SMSC for large messages.
Step Action
2 Click Open.
3
MAP Large
SMSC
5
From the Adapter drop down list, select CDMA Adapter.
6
Follow these steps to add an SS7 connection to the large SMSC path.
Step Action
1 In the table on the Paths tab, select the MAP Large SMSC path.
2
3
MAP Large SMSC
connection
5 In the PC field, enter 51.
6 In the SSN field, enter 8.
7 In the GT field, enter 6449393368.
8
In the Weight field, enter 1 (may need to deselect the Failover check box first).
Create Domain
Create a domain to identify traffic that will trigger to Messaging Manager Director.
Follow these steps to add a new domain for all MAP inbound MO traffic:
Step Action
1 On the Schemes tab, select the Mobile2ACS routing scheme.
2 Click Open.
4
In the Name field, enter MAP_MO.
5 Click Save.
Create Control Plan
Follow these steps to create a Messaging Manager Director control plan.
Step Action
1 Open the ACS Control Plan Editor. See CPE User's Guide for details.
2 Select the required customer.
3
Create a control plan using the following nodes:
  • Start
  • End
  • Content Size Branching
  • Set Message Routing - to set the message center to "Large Message Centre"
  • Attempt Delivery Pending
Result: The control plan will look similar to this:
4 Save the control plan.
Create trigger rule
Step Action
2
Click New....
3 From the Originating Domain drop down list, select SMSC Offload.
4 Select the Trigger a call plan in ACS option.
5 Deselect the Use scheduled call plan if present check box.
6 Select the Use this named call plan check box.
7
Select the ACS customer and control plan named, as created and saved in Create Control Plan .
8 Click Save.
Follow these steps to establish a routing rule and list of paths.
Step Action
2
Click New....
4 From the Originating domain drop down list, select MAP_MO.
5 From the Paths sequencing drop down list, select MAP SMSC and click Add.
6 In the Retries field, enter 3.
7
8 Click Save.
If the Control Plan determined that the message was a large one, it will have set a different message center, allowing a routing rule to select a special SMSC.
Step Action
2
Click New....
3 In the Message centre drop down list, select Large Message Centre.
4 In the Originating domain drop down list, select MAP_MO.
5 From the Paths sequencing drop down list, select MAP Large SMSC and click Add.
7
8 Click Save.
Step Action
1 From the table on the Nodes tab, select the node, in this example, SCP01. See Configure Messaging Manager node ).
2
Click Edit....
3
From the drop down list, select Mobile2ACS.
4 Click Save.
5
Click Close.
Instant Messaging
Process overview
The process required is similar to the Mobile to Mobile triggering to ACS process, but the details are yet to be finalized. However, two procedures which are required for this scenario are listed in this table.
Step Action
1 Create SCA Adapter
2 Create Control Plan for SIP
SMS forwarded to SIP
In this scenario, Tom sends a short message to Dick, who has enabled instant message forwarding using some mechanism not relevant to this design. This will forward a copy of the short messages to Dick’s SIP user agent.
This is accomplished by processing a control plan that contains the Send Short Message Notification node (SSMN), which allows sending instant messages. The node specifies the destination address in URI format (for example, Dick@imdomain.com). The content and other information about the message is contained in a GenericSM event. This event is sent through the SLEE to the SCA Adapter. The SCA Adapter converts the GenericSM event to a SipSleeEvent and forwards this event to the SCA.
SMS to SIP
In this scenario, Tom sends a short message to a special short code (64121) that will forward the short message to Dick’s instant message user agent. This scenario is similar to the scenario described above, and the path is the same as shown in that diagram, except that the destination address is specified as part of the message content (for example, "Dick@imdomain.com Watson, come here." The SSMN (or other) node extracts the destination address from the content. The short message is swallowed by MM.
SIP to SMS
In this scenario Tom sends an instant message to Dick, addressed to a handset (the E.164 telephone number - for example, 64123402). The SCA converts this message to a SipSleeEvent and passes this to the SCA Adapter. The SCA Adapter creates a GenericSM event and MM routes this to the MAP adapter. The MAP adapter sends a MAP MO-ForwardSM to the SMSC.
In this scenario, Tom uses his E.164 alias (for example, 64123570) as the originating address. This allows a reply through SMS.
Create SCA Adapter
The adapter name in the GUI must match exactly the adapterName parameter in the eserv.config for the SCA protocol.
# Adapter definitionsadapters = [# SCA (SIP) adapter{#
adapter identifier.#adapterName = "SCA1"..}
Follow these steps to configure an SCA adapter, which will be used for receiving inbound SMSs.
Step Action
1 Configure the SCA adapter in the MM eserv.config file. For more information, see MM Technical Guide.
2
3 In the Name field, enter SCA1.
4
In the Protocol field, select SIP.
Follow these steps to create a Messaging Manager Director control plan for SIP.
Step Action
3
  • Start
  • End
  • Extract Content
  • Configure Keyword Search and Replace
  • Modify
  • Set
  • Copy
  • Accept
  • Set Message Routing - to set the originating and destination domains.
  • Send Short Message Notification
  • Reject
Result: The control plan will look similar to the Example Control Plan for SIP
Here is an example control plan for SIP.
Email
Process overview
Refer to PME Control Plan Scenarios for an explanation of how this is set up.
