6 Supported Request Type
- BalanceTransfer
- ApplyLoan
- GenericRequest
If the location fetch fails during BalanceTransfer or ApplyLoan APIs, Convergent Charging Controller does not send any location attributes to BRM. In such cases, taxes are applied based on how it is configured in the BRM system.BalanceTransfer
BalanceTransfer request is triggered when the following parameter is present in the input xml request:
<operation>BalanceTransfer</operation>
- Configure BalanceTransfer under restendpoint in config.json file.
- The output request will be always POST.
Input Request
Table 6-1 describes the parameters accepted in the XML <requestDetails>
tag.
Table 6-1 Input Request Parameters
| Notification Type | Mandatory/Optional | Description |
| sourceMSISDN | Mandatory | Source MSISDN for BalanceTransfer. |
| destinationMSISDN | Mandatory | Destination MSISDN for BalanceTransfer. |
| transferAmount | Mandatory | Amount to be transferred from source to destination. |
| transferAmountType | Optional |
ResourceId of the amount passed. If not present in the input request, default value of resourceid from the config file is used. |
| chargeSource | Optional |
Boolean flag to indicate whether the source account will be charged. If not present in the input request, default value of chargesource from the config file is used. |
| chargeDestination | Optional |
Boolean flag to indicate whether the target or destination account will be charged. If not present in the input request, default value of chargedestination from the config file is used. |
| sourceZoneMapTarget | Optional |
Cellid for source MSISDN. If not present in the input request, location will not be sent to the REST server. |
| targetZoneMapTarget | Optional |
Cellid for destination MSISDN. If not present in the input request, location will not be sent to the REST server. |
Sample XML Input Request
Following is a sample XML input request sent out from DAP module.
<requestDetails>
<sourceMSISDN>90989098</sourceMSISDN>
<destinationMSISDN>89878987</destinationMSISDN>
<transferAmount>10</transferAmount>
<transferAmountType>840</transferAmountType>
<chargeSource>true</chargeSource>
<chargeDestination>false</chargeDestination>
<sourceZoneMapTarget>52021005DC03EA</sourceZoneMapTarget>
<targetZoneMapTarget>52121005DC03EA</targetZoneMapTarget>
</requestDetails>
REST Request Parameters
Table 6-2 lists the parameters sent to the REST server.
Table 6-2 REST Request Parameters
| Notification Type | Mapping From Input Request |
| sourceRef.id | From sourceMSISDN. |
| sourceRef.type | Always set as service. |
| targetRef.id | From destinationMSISDN. |
| targetRef.type | Always set as service. |
| transferAmount | From transferAmount. |
| transferAmountType | From transferAmountType.
If not present in the input request, restendpoint.BalanceTransfer.resourceid from the config file is used. |
| chargeSource | From chargeSource.
If not present in the input request, restendpoint.BalanceTransfer.chargesource from the config file is used. |
| chargeDestination | From chargeDestination.
If not present in the input request, restendpoint.BalanceTransfer.chargedestination from the config file is used. |
| description | Same as operation name. |
| sourceLocation. zoneMapTarget | From sourceZoneMapTarget. |
| targetLocation. zoneMapTarget | From targetZoneMapTarget. |
Sample REST API Request
Following is a sample REST API request sent out from RESTClient towards REST endpoint.
"description" : "BalanceTransfer",
"sourceRef" : {
"id" : "90989098",
"type" : "service"
"targetRef" : {
"id" : "89878987",
"type" : "service"
"transferAmount" : 10,
"transferAmountType" : 840,
"chargeSource" : true,
"chargeDestination" : false,
"sourceLocation" : {
"zoneMapTarget" : "52021005DC03EA"
"targetLocation" : {
"zoneMapTarget" : "52121005DC03EA"
REST API Response
Tags present in the response will not be validated. JSON message will be directly converted to XML.
Sample REST API Response
Following is the snippet of response received from the REST endpoint.
"extension": null,
"id": "0.0.0.1+-event-audit-transfer_balance+335711686285720131",
"uri": "http://hostname:port/bcws/webresources/v1.0/billunits/balancegroups/transferbalance/0.0.0.1+-event-audit-transfer_balance+335711686285720131",
"transferAmount": 10,
"transferAmountType": 840,
"sourceRef": {
"id": "90989098",
"type": "service"
"targetRef": {
"id": "89878987",
"type": "service"
"sourceBucket": [
"validFrom": 1647993600000,
"validTo": 0,
"currentBalance": 2147485311.57
"targetBucket": [
"validTo": 0,
"currentBalance": -2147483808.93
"validFrom": 1632230093000,
"validTo": 1703164493000,
"currentBalance": 0
"sourceTransferFee": {
"amount": 3.00,
"feeTax": 0.30,
"resourceId": 840
"targetTransferFee": {
"amount": 3.00,
"feeTax": 0.60,
"resourceId": 840
where, hostname and port is the hostname and port of the machine where REST server is running.
XML Response
XML response will have extra tag <rest_result_code> containing the status code from REST response header. The status code from RESTClient to DAP will always be 200. <rest_status_code> can be used for checking the status code from REST server.
Sample XML Response
Following is the XML response received by DAP for a particular request.
<targetRef>
<id>89878987</id>
<type>service</type>
</targetRef>
<extension>null</extension>
<targetBucket>
<currentBalance>-2.14748380893E9</currentBalance>
<validFrom>1647993600000</validFrom>
<validTo>0</validTo>
</targetBucket>
<targetBucket>
<currentBalance>0</currentBalance>
<validFrom>1632230093000</validFrom>
<validTo>1703164493000</validTo>
</targetBucket>
<targetTransferFee>
<amount>3.0</amount>
<resourceId>840</resourceId>
<feeTax>0.6</feeTax>
</targetTransferFee>
<sourceTransferFee>
<feeTax>0.3</feeTax>
</sourceTransferFee>
<id>0.0.0.1+-event-audit-transfer_balance+335711686285720131</id>
<sourceRef>
<id>90989098</id>
</sourceRef>
<sourceBucket>
<currentBalance>2.14748531157E9</currentBalance>
</sourceBucket>
<uri>http://hostname:port/bcws/webresources/v1.0/billunits/balancegroups/transferbalance/0.0.0.1+-event-audit-transfer_balance+335711686285720131</uri>
<rest_status_code>201</rest_status_code>
ApplyLoan
ApplyLoan request is triggered when the following parameter is present in the input request.
<operation>ApplyLoan</operation>
- Configure ApplyLoan under restendpoint in config.json file.
Input Request
Table 6-3 describes the parameters accepted in the XML <requestDetails>
tag.
Table 6-3 Input Request Parameters
| Notification Type | Mandatory | Description |
| sourceMSISDN | Mandatory | Source MSISDN for ApplyLoan. |
| loanAmount | Mandatory | Amount for loan. |
| loanResourceId | Optional |
<requestDetails>
<sourceMSISDN>635495522</sourceMSISDN>
<loanAmount>5</loanAmount>
<loanResourceId>840</loanResourceId>
<serviceType>/service</serviceType>
</requestDetails>
Table 6-4 lists the parameters sent to the REST server.
Table 6-4 REST Request Parameters
| accountRef.id | Always set as "0.0.0.1+-account+1". |
| service.id | From sourceMSISDN. |
| service.type |
From serviceType. If not present in the input request, restendpoint.ApplyLoan. serviceType from the config file is used. |
| amount | From loanAmount. |
resourceId |
From loanResourceId. If not present in the input request, restendpoint.ApplyLoan.resourceid from the config file is used. |
| zoneMapTarget |
From userLocation. If not present in the input request, this parameter will not be sent. |
"accountRef": {
"id": "0.0.0.1+-account+1"
"service": {
"id" : "635495522",
"type" : "/service"
"amount": 5,
"resourceId": 840,
"zoneMapTarget": "52021005DC03EA"
REST API Response
"extension": null,
"availableLoanBalance": 172,
"currentBalance": 800,
"amount": 122,
"loanFee": 10,
"tax": 8.54,
"balances": [],
"availableLoanLimit": 9510.91,
"creditLimit": 10000,
"loanObj": {
"id": "0.0.0.1+-event-billing-loan_debit+335782055029906029",
"uri": null
"loanFeeObj": {
"id": "0.0.0.1+-event-billing-loan_fee+335782055029904493",
"uri": null
XML Response
response header. The status code from RESTClient to DAP will always will be 200.
Sample XML Response
<amount>122</amount>
<loanFee>10</loanFee>
<loanObj>
<id>0.0.0.1+-event-billing-loan_debit+335782055029906029</id>
<uri>null</uri>
</loanObj>
<currentBalance>800</currentBalance>
<creditLimit>10000</creditLimit>
<loanFeeObj>
<id>0.0.0.1+-event-billing-loan_fee+335782055029904493</id>
<uri>null</uri>
</loanFeeObj>
<tax>8.54</tax>
<availableLoanLimit>9510.91</availableLoanLimit>
<availableLoanBalance>172</availableLoanBalance>
GenericRequest
For sending any request (other than BalanceTransfer and ApplyLoan) to a third party REST endpoint, generic request option can be used. You can configure the required operation with the corresponding endpoint in the config.json file and then use the same operation name in the input xml triggered from DAP to REST client.
Configure the new operation in the config.json file as follows:
"restendpoint": {
"OperationName" : {
"endpoint" : "restendpoint",
"type" : "POST",
"servergroupid" : "BRM"
- Generic request Handler supports POST, PUT, and GET requests.
- servergroupid and endpoint can be custom configurations.
Sample Configuration
"restendpoint": {
"GenericBalanceTransferDetails" : {
"servergroupid" : "BillingCare"
Input Request
Table 6-5 describes the parameters accepted in the XML input request.
Table 6-5 Input Request Parameters
| operation | Mandatory | Operation name for the request which is configured. |
| type | Optional | If present, it will override the type present in the config for the operation. |
| endPoint | Optional | If present, it will override the endpoint present in the config for the operation. |
| requestDetails | Mandatory for POST/PUT |
For GET, requestDetails will not be sent to the REST server. For POST/PUT, XML request will be converted to JSON and sent as body in the OUTPUT request. |
| arrayXmlTags | Optional |
Tags that need to be converted to array type in JSON request. Multiple tags can be used with comma separator. Example: <arrayXmlTags>bundles,package</arrayXmlTags> |
Sample XML Request
<operation>GenericRequest</operation><requestDetails>
<msisdn>923450010213</msisdn> <package> <packageType>Addon</packageType>
<bundles> <bundleName>500001</bundleName> </bundles>
</package></requestDetails> <arrayXmlTags>bundles,package</arrayXmlTags>
Sample JSON Converted Request
JSON Request{
"arrayXmlTags": "bundles,package",
"requestDetails": {
"package": [{
"bundles": [{"bundleName": 500001}],
"packageType": "Addon"
"msisdn": 923450010213
"operation": "GenericRequest"
This example shows a GET request for balance transfer audit object using Generic request Handler.
<operation>GenericBalanceTransferDetails</operation>
<endPoint>http://hostname:port/bcws/webresources/v1.0/billunits/balancegroups/transferbalance/0.0.0.1+-event-audit-transfer_balance+335887608146194890</endPoint>
<type>GET</type>
"endPoint": "http://hostname:port/bcws/webresources/v1.0/billunits/balancegroups/transferbalance/0.0.0.1+-event-audit-transfer_balance+335887608146194890",
"type": "GET",
"operation": "GenericBalanceTransferDetails"
REST API Response
"extension":null,
"id":"0.0.0.1+-event-audit-transfer_balance+335887608146194890",
"sourceAccountRef":{
"id":"0.0.0.1+-account+37201",
"uri":"http://hostname:port/bcws/webresources/v1.0/accounts/0.0.0.1+-account+37201"
"targetAccountRef":{
"id":"0.0.0.1+-account+34057",
"uri":"http://hostname:port/bcws/webresources/v1.0/accounts/0.0.0.1+-account+34057"
"transferDate":1649681472000,
"sourceRef":{
"id":"0.0.0.1+-balance_group+40785",
"type":"balanceGroup"
"targetRef":{
"id":"0.0.0.1+-balance_group+34953",
"transferAmount":11,
"transferAmountType":840,
"chargeSource":false,
"chargeDestination":true,
"sourceImpactedBucket":[{"validFrom":1647993600000,"validTo":0,"amount":11}],
"targetImpactedBucket":[{"validFrom":1647993600000,"validTo":0,"amount":-11}],
"sourceTransferFee":null,
"targetTransferFee":{
"amount":3,
"feeTax":0.6,
"resourceId":840
XML Response
Sample XML Response
<targetRef>
<id>0.0.0.1+-balance_group+34953</id>
<type>balanceGroup</type>
</targetRef>
<targetImpactedBucket>
<amount>-11</amount>
</targetImpactedBucket>
<chargeSource>false</chargeSource>
<targetTransferFee>
<amount>3</amount>
<transferAmount>11</transferAmount>
<sourceTransferFee>null</sourceTransferFee>
<targetAccountRef>
<id>0.0.0.1+-account+34057</id>
<uri>http://hostname:port/bcws/webresources/v1.0/accounts/0.0.0.1+-account+34057</uri>
</targetAccountRef>
<transferDate>1649681472000</transferDate>
<chargeDestination>true</chargeDestination>
<id>0.0.0.1+-event-audit-transfer_balance+335887608146194890</id>
<sourceAccountRef>
<id>0.0.0.1+-account+37201</id>
<uri>http://hostname:port/bcws/webresources/v1.0/accounts/0.0.0.1+-account+37201</uri>
</sourceAccountRef>
<sourceRef>
<id>0.0.0.1+-balance_group+40785</id>
</sourceRef>
<sourceImpactedBucket>
<amount>11</amount>
</sourceImpactedBucket>
<rest_status_code>200</rest_status_code>
