1 Introduction
This document provides Oracle Communications Network Analytics Data Director (OCNADD) troubleshooting information.
1.1 Overview
Oracle Communications Network Analytics Data Director (OCNADD) is a specialized Network Data Broker (NDB) that receives network data from various data sources (such as 5G NFs and Non-5G NFs) and sends the data securely to the subscribed consumers (such as third-party tools) after applying mechanisms such as data filtering, data replication, and data aggregation. All these mechanisms are configurable by the consumers.
OCNADD provides curated data (either filtered or replicated) for network analytics and monitoring. OCNADD supports robust, configurable filtering and aggregation options which enables the operator to sort data, create comprehensive dashboards, and generate Key Performance Indicators (KPIs) for all departments within the service provider framework. OCNADD also provides a GUI that enables users to create, edit, and delete data feed.
For more information about OCNADD architecture and features, see Oracle Communications Network Analytics Data Director User Guide.
1.2 References
For more information about OCNADD, refer to the following documents:
- Oracle Communications Network Analytics Data Director User Guide
- Oracle Communications Network Analytics Data Director Installation, Upgrade, and Fault Recovery Guide
- Oracle Communications Network Analytics Data Director Benchmarking Guide
- Oracle Communications Cloud Native Environment Installation, Upgrade, and Fault Recovery Guide
- Oracle Communications Cloud Native Core cnDBTier Installation, Upgrade, and Fault Recovery Guide
- Oracle Communications Cloud Native Configuration Console Installation, Upgrade, and Fault Recovery Guide
- Oracle Communications Cloud Native Configuration Console Troubleshooting Guide
