5 Rolling Back OCNADD
This chapter describes the OCNADD rollback procedure from a target release to a previously supported version. In the current release, centralized deployment is supported, and OCNADD microservices will follow the centralized deployment mode with the management group and the worker group separation concerning microservices functions.
The rollback will be supported for the following cases:
- Upgrade was done from source releases to the target release in the Centralized deployment mode.
- Upgrade was done from source releases to the target release in the Non-Centralized deployment mode.
Changing mode from Centralized deployment mode to Non-Centralized deployment is not supported within the target release (24.1.0). See Supported Upgrade Paths section of this document.Table 5-1 Supported Rollback Paths
| Source Release | Target Release |
| 24.1.0 | 23.4.0.0.x |
| 24.1.0 | 23.3.0.0.x |
23.3.0.0.x/23.4.0.0.x is the supported patch release. For example, 23.3.0.0.1- Rollback Usecase 1: Upgrade Was Done from Source Releases(Non-Centralized) to Target Release in the Centralized Deployment Mode
- Rollback Usecase 2: Upgrade Was Done from Source Releases (Centralized) to Target Release in the Centralized Deployment Mode
- Rollback Usecase 3: Upgrade Was Done from Source Releases (Non-Centralized Mode) to Target Release in the Non-Centralized Mode
- Rollback Usecase 4: Upgrade Was Done to Move to the Centralized Deployment Mode and Got Failed
Rollback Steps
- (Optional) A timeout interval of 15 minutes can be set while performing an upgrade as only one POD of the OCNADD services is upgraded at a time.
- Ensure the status for the target version in the helm history is not in failed or error state.
- Ensure to delete the Kafka feed if enabled on 24.1.0, before attempting the rollback, follow the section 'Disable Kafka Feed Configuration Support' of the Oracle Communications Network Analytics Data Director User Guide.
This scenario is applicable for rollback from 24.1.0 Centralized Deployment Mode to 23.3.x or 23.4.x Non-Centralized Deployment Mode.To roll back to a previous working version in the target rollback release, follow these steps:
- Uninstall the Management
Group
helm uninstall <management-release-name> --namespace <ocndd-namespace>Where,
<management-release-name>is the name used to identify the management group deployment.<ocndd-namespace>is the namespace of the OCNADD deployment.
For example:helm uninstall ocnadd-mgmt --namespace ocnadd-deploy - Check Revision for
Rollback:
helm history <ocandd-release-name> --namespace <ocndd-namespace>Where,
<ocandd-release-name>is the release name used for default worker group deployment.For example:helm history ocnadd --namespace ocnadd-deploySample Helm history output:REVISION UPDATED STATUS CHART APP VERSION DESCRIPTION 1 Fri Feb 08 04:57:43 2024 superseded ocnadd-0.0.0-23.4.0 23.4.0.0.0 Install complete 2 Fri Feb 08 05:07:43 2024 superseded ocnadd-0.0.0-23.4.0 23.4.0.0.0 Upgrade complete (revision required for rollback) 3 Fri Feb 08 05:21:52 2024 superseded ocnadd-23.4.0 23.4.0.0.0 Upgrade complete 4 Fri Feb 08 05:35:15 2024 deployed ocnadd-24.1.0 24.1.0.0.0 Upgrade complete - Rollback to Required
Revision:
helm rollback <ocandd-release-name> <REVISION> --namespace <ocndd-namespace>Where,
<REVISION> is the required revision at which the first successful upgrade was performed in the "Preupgrade procedure" step "d". Perform Helm upgrade on source release to update the backup-pvc changes.
For example:helm rollback ocnadd 2 --namespace ocnadd-deploy - Restore the Backup-PVC:
- Run the command from the source release folder
corresponding to 24.1.0:
bash custom-templates/copy_backup_pvc.bash <source-release-namespace> <storageClass-name> <service-account>Where
source-release-namespaceis the OCNADD namespace of the source releasestorageClass-nameis the Storage Class of OCNADD deployment (default used is standard)service-accountis the Service Account name set inglobal.cluster.serviceAccount.nameinocnadd-custom-values-24.1.0.yaml
For example:bash custom-templates/copy_backup_pvc.bash ocnadd-deploy standard ocnaddSample output with namespace as the argument:PVC backup-mysql-pvc-temp exists in namespace ocnadd-deploy. PVC backup-mysql-pvc exists in namespace ocnadd-deploy. Running job to Copy backup contents from backup-mysql-pvc-temp to backup-mysql-pvc job.batch/ocnaddcopybackuppvc-temp-to-orig created Copied successfully persistentvolumeclaim "backup-mysql-pvc-temp" deleted - Update File References in the Target Release Folder:
Change the directory to the target release folder.
For example: For 23.4.0 release the folder is ocnadd-package-23.4.0sed -i 's/backup-mysql-pvc-temp/backup-mysql-pvc/g' ocnadd/templates/ocnadd-postrollback-version-db.yml sed -i 's/backup-mysql-pvc-temp/backup-mysql-pvc/g' ocnadd/templates/ocnadd-preupgrade-db.yaml sed -i 's/backup-mysql-pvc-temp/backup-mysql-pvc/g' ocnadd/templates/ocnadd-prerollback-db.yaml - Verify and Update Management Group Services.
Ensure all Management group services are set to 'true' in the ocnadd-custom-values.yaml of the target release. Update settings if necessary:
global: ocnaddalarm: enabled: false ##---> to true ocnaddconfiguration: enabled: false ##---> to true ocnaddhealthmonitoring: enabled: false ##---> to true ocnaddbackuprestore: enabled: false ##---> to true ocnaddadminsvc: enabled: false ##---> to true ocnadduirouter: enabled: false ##---> to true ocnaddgui: enabled: false ##---> to true - Rollback Adapter Services to Previous Version.
Run the command to upgrade all Adapter services to the previous version:
helm upgrade <ocandd-release-name> -f ocnadd-custom-values-<previous_release>.yaml --namespace <ocnadd-namespace> <helm_chart_previous_release> --set global.env.admin.OCNADD_ADAPTER_UPGRADE_ENABLE=trueFor example:helm upgrade ocnadd -f ocnadd-custom-values-23.4.0.yaml --namespace ocnadd-deploy ocnadd --set global.env.admin.OCNADD_ADAPTER_UPGRADE_ENABLE=true
- Verify if the rollback is successful.
- Ensure pods respawned after the upgrade have the latest age (in seconds).
- Check Adapter pods and data feed status via the GUI.
- The Kafka broker pods may be in crashloopback state after the rollback due to a service account issue. For any such Kafka broker issues after rollback, refer to the "Kafka brokers in crashloop state after rollback" section in the Oracle Communications Network Analytics Data Director Troubleshooting Guide.
If the rollback remains unsuccessful, refer to the troubleshooting steps outlined in the Oracle Communications Network Analytics Data Director Troubleshooting Guide.
This scenario is applicable for rollback from 24.1.0 Centralized Deployment Mode to 23.4.x or 24.1.0 Centralized Deployment Mode.To roll back to a previous working version in the target rollback release, follow these steps:
Rollback of Management Group:
Rollback:
helm history <ocandd-release-name> --namespace <ocndd-mgmt-namespace>Where,
Revision:
helm rollback <ocandd-release-name> <REVISION> --namespace <ocndd-mgmt-namespace>Where,
<REVISION> is the revision number obtained in the previous step to which the services need to be rolled back.
Rollback of Worker Groups
Rollback:
helm history <ocandd-release-name> --namespace <ocnadd-workergroup-namespace>Where,
Revision:
helm rollback <ocandd-release-name> <REVISION> --namespace <ocndd-workergroup-namespace>Where,
For example:helm rollback ocnadd 2 --namespace ocnadd-deploy - Rollback Adapter Services to the Previous Version. Run the below commands to
rollback all Adapter/Correlation services to the previous version:
- Perform helm upgrade using the management group charts folder:
- If no correlation configurations are
present:
helm upgrade <management-release-name> -f ocnadd-custom-values-<mgmt-group>.yaml --namespace <ocnadd-namespace> <mgmt_helm_chart> --set global.env.admin.OCNADD_ADAPTER_UPGRADE_ENABLE=trueFor example:helm upgrade ocnadd-mgmt -f ocnadd-custom-values-mgmt-group.yaml --namespace ocnadd-deploy ocnadd_mgmt --set global.env.admin.OCNADD_ADAPTER_UPGRADE_ENABLE=true - If correlation configurations are also
present:
helm upgrade <management-release-name> -f ocnadd-custom-values-<mgmt-group>.yaml --namespace <ocnadd-namespace> <mgmt_helm_chart> --set global.env.admin.OCNADD_ADAPTER_UPGRADE_ENABLE=true,global.env.admin.OCNADD_CORR_UPGRADE_ENABLE=trueFor example:helm upgrade ocnadd-mgmt -f ocnadd-custom-values-mgmt-group.yaml --namespace ocnadd-deploy ocnadd_mgmt --set global.env.admin.OCNADD_ADAPTER_UPGRADE_ENABLE=true,global.env.admin.OCNADD_CORR_UPGRADE_ENABLE=true
present:
- Check the status of the upgrade, and monitor the pods to come back to the RUNNING state.
- If the rollback remains unsuccessful, see troubleshooting steps outlined in the Oracle Communications Network Analytics Data Director Troubleshooting Guide.
- Run the following command to check the revision to rollback:
Where the required revision is the revision at which the helm upgrade was performed to disable the '
ocnadduirouter' and 'ocnaddgui' before upgrading to the target release.$ helm history <ocandd-release-name> -n <ocnadd-namespace>Where,
<ocandd-release-name>is the release name of the OCNADD deployment.<ocndd-namespace>is the name the namespace of OCNADD deployment.For example:
helm history ocnadd --namespace ocnadd-deploySample Helm history output with patch 23.3.0 example:
REVISION UPDATED STATUS CHART APP VERSION DESCRIPTION 1 Fri Feb 08 04:57:43 2024 superseded ocnadd-0.0.0-23.3.0 23.3.0.0.0 Install complete 2 Fri Feb 08 05:07:43 2024 superseded ocnadd-0.0.0-23.3.0 23.3.0.0.0 Upgrade complete =======> revision required for rollback 3 Fri Feb 08 05:35:15 2024 deployed ocnadd-24.1.0 24.1.0.0.0 Upgrade complete - Run the command to rollback to the required
revision:
helm rollback <ocandd-release-name> <REVISION> --namespace <ocnadd-namespace>Where, <REVISION> is the revision number obtained in the previous step to which the services needs to be rolled backed.
For example:
helm rollback ocnadd 2 --namespace ocnadd-deploy - Run the following command to roll back the Adapter service to
the previous version along with the '
ocnadduirouter' and 'ocnaddgui':- Go to the release folder.
For example: For 23.3.0 release the folder is
ocnadd-package-23.3.0. - Update the
ocnadd-custom-values.yamlfile:global.ocnadduirouter.enabled: false ##---> update it to 'true' global.ocnaddgui.enabled: false ##---> update it to 'true' - Perform helm upgrade using helm charts
folder:
helm upgrade <ocandd-release-name> -f ocnadd-custom-values-<previous_release>.yaml --namespace <ocnadd-namespace> <helm_chart_previous_release> --set global.env.admin.OCNADD_ADAPTER_UPGRADE_ENABLE=trueFor example: For release 23.3.0helm upgrade ocnadd -f ocnadd-custom-values-23.3.0.yaml --namespace ocnadd-deploy ocnadd --set global.env.admin.OCNADD_ADAPTER_UPGRADE_ENABLE=true
- All the pods that has been respawned after upgrade, have the latest age (in secs)
- The Adapter pods also gets respawned for any upgrade. The status can also be verified from GUI for respective data feeds.
In this case, the upgrade was done in the target release itself to move to the Centralized deployment mode from the Non-Centralized mode. In such a case, there will be only one default worker group running in the same namespace along with the management group services. The procedure is similar to "Rollback Usecase1", except that the target and source release will remain the same. The steps in the "Rollback Usecase1" should be followed, and care must be taken while using the same release charts of the source release (24.1.0) for rollback.
The procedure is applicable for the following scenarios:
The upgrade was successfully done from source releases 23.3.0.0.x/23.4.0.0.x to 24.1.0.0.0 release in Non-Centralized mode. Later on, the upgrade was performed to enable the Centralized deployment mode and it failed.
The above procedure is not applicable to switch between Non-Centralized and Centralized modes.
