3 Customizing OCNADD
This chapter describes how to customize the Oracle Communications Network Analytics Data Director (OCNADD) deployment, supported deployment models, and provides a list of configuration parameters in the Helm file that are used for customization. The OCNADD deployment is customized by overriding the default values of various configurable parameters.
3.1 OCNADD Deployment Models
- Model 1: All Data Director Services (Default)
- Model 2: Kafka, Common Services, and Aggregation Services
The Data Director supports egress adapters for outbound connections. The egress adapters add value to the message feed by filtering and synthesizing the packets before sending the messages out on the egress connection type 'HTTP/2' or 'Synthetic Feed'. If the customer selects a deployment model that does not include the Egress adapter, additional features such as synthetic packet generation will not be available, although the filtering and correlation features will be available using Kafka feeds only.The following diagram depicts the various Data Director deployment models:
Table 3-1 Resource Saving
| Deployment Model | Model 1 (All Services) | Model 2 (Kafka +Aggregation) |
| Common Services | Available | Available |
| Aggregation Service | Available | Available |
| Adapter Service | Available | Not available |
| Kafka | Available | Available |
| Resource Saving (approx. %) | 0 | 60 |
| Supported Egress Interfaces | HTTP/2
TCP |
Kafka |
The resource saving for the default model will be more if many worker groups are going to be managed with a single management group.Model 1: All Data Director Services (Default: Centralized)
This OCNADD deployment model includes all the services and features. This is the
default model and all the services are selected by default in the ocnadd-custom-values-25.1.100.yaml file.
This profile can stream NFs (SCP, NRF, SEPP) data up to 15K MPS and can be scaled to handle up to 135K MPS for HTTP2 feed when "weighted_lb" is off.
Replication Factor should be 1 and the incoming message size on OCNADD should be less than or equal to 3500 bytes.
- Use the GUI to configure message feeds on OCNADD.
- The Oracle Producer NFs (SCP, SEPP and NRF) copy the messages to their respective source topics.
For this model, the user need not enable or disable any service in the
ocnadd-custom-values-25.1.100.yaml. The default parameters are as below.
global:
ocnaddalarm:
enabled: true
ocnaddconfiguration:
enabled: true
ocnaddhealthmonitoring:
enabled: true
ocnaddaggregation:
enabled: true
ocnaddbackuprestore:
enabled: true
ocnaddkafka:
enabled: true
ocnaddadminsvc:
enabled: true
ocnadduirouter:
enabled: true
ocnaddgui:
enabled: true
ocnaddfilter:
enabled: true
ocnaddexport:
enabled: true
ocnaddnonracleaggregation:
enabled: true
ocnaddredundancyagent:
enabled: true
Use this model when the customer does not wish to receive the message feed using HTTP/2 or TCP connection mode. The third-party monitoring application available to the customer can consume data directly from the Kafka cluster. The Egress adapter is not required in this deployment model; however, the OCNADD deployment requires common services (such as UI, Configuration, Health monitoring, Alarm, and Admin). Features like correlation-id-based load balancing, synthetic feed, and HTTP/2 feeds are unavailable in this deployment model, although the filtering and correlation features will be available using Kafka feeds only. This model saves the egress adapter resource; however, additional resources will be required for Filtering and Correlation services once these features are used in the configurations from UI.
The export feature is also available, however it has to be enabled in the charts by enabling the ocnaddexport service and further export configuration from the UI. For more information, see "Export" section in "OCNADD Features and Feature Specific Limits " chapter and "Export Configuration " section in " Configuring OCNADD" chapter in Oracle Communications Network Analytics Data Director User Guide.
This deployment model supports direct Kafka feed. For more information, see "External Kafka Feeds" section in Oracle Communications Network Analytics Data Director User Guide.
global:
ocnaddalarm:
enabled: true
enabled: true
enabled: true
ocnaddaggregation:
enabled: true
enabled: true
ocnaddkafka:
enabled: true
ocnaddadminsvc:
enabled: true
ocnadduirouter:
enabled: true
ocnaddgui:
enabled: true
ocnaddfilter:
enabled: true
ocnaddexport:
enabled: false
enabled: false
enabled: false- The aggregation service aggregates traffic from the source topics to the Kafka main topic. Choosing any specific combination of NFs for aggregation rules is not possible. The total traffic received is aggregated and available to the consumers.
- The third-party consumer application must create external Kafka feeds to connect with the Kafka cluster, which will allow them to consume messages directly from the designated topic.
- Aggregation: The traffic will be aggregated using the configuration on Oracle Producer NFs to use the Main topic for copying messages on the OCNADD.
- The message feeds must be created from the GUI and aggregation rules determine the source NF combinations for aggregation.
- Metrics related to the feed shall be available on the GUI. The GUI can also be used to view the OCNADD alarms.
The customer can customize the OCNADD deployment based on the identified resources. Plan the resources based on the deployment model and services required for the specific model. For more information of OCNADD resources see Oracle Communications Network Analytics Data Director Benchmarking Guide.
In both models, the two-site redundancy feature can be enabled. For more information, see 'Two Site Redundancy Enable' section in the Oracle Communications Network Analytics Data Director User Guide.
3.2 Customize Configuration Parameters
Perform the following procedure to customize the ocnadd-custom-values-25.1.100.yaml files as per requirements for both parent and sub-charts.
- Ensure that you have the Data Director charts tgz file, which is available in the extracted release package. For information about how to download the release package from MOS, see Downloading OCNADD Package.
- Extract the OCNADD package if not already extracted, and unzip the custom-templates.zip
- Change the directory to custom-templates to access the parent
ocnadd-custom-values-25.1.100.yaml. This file is used to customize the deployment parameters during installation.Change the following parameters in the
ocnadd-custom-values-25.1.100.yamland save the file:- Update the repository path in
global.env.repo.REPO_HOST_PORT: <customer repository path> - Update the CLUSTER-INFO parameters:
cluster.domainName: <customer cluster domain name>cluster.clusterName: <customer cluster name>
- Update the database IP and database name:
db_ip: 10.20.30.40(Update with DB instance IP or with FQDN. For example,mysql-connectivity-service.<cnDBTier namespace>)db_port: 3306(If using a different port for DB, change it. By default, DB port is3306)configuration_db: configuration_schema(Update the DB name as per the section Update Database Name. No change is needed if default DB names are used.)alarm_db: alarm_schema(Update the DB name as per the section Update Database Name. No change is needed if default DB names are used.)health_db: healthdb_schema(Update the DB name as per the section Update Database Name. No change is needed if default DB names are used.)storageadapter_db:storageadapter_schema(Update the DB name as per the section Update Database Name. No change is needed if default DB names are used.)
- Update the cluster and cluster domain name for
UI
ocnadduirouter: ocnadduirouter: name: ocnadduirouter env: PROMETHEUS_API: http://occne-kube-prom-stack-kube-prometheus.occne-infra.ocnadd:80 ## --> update 'ocnadd' with <customer cluster domain name> DD_PROMETHEUS_PATH: /blurr8/prometheus/api/v1/query_range ## --> update 'blurr8' with <customer cluster name> - Change the Prometheus Monitoring Details, bases on the desired MPS
profile, default threshold MPS is
100000:cluster.mps: 100000 - Change the
ocnaddadminsvc.TCP_CONN_INSPECTOR_FIXED_DELAY_MSparameter with "60000" as below. Default is "7200000":TCP_CONN_INSPECTOR_FIXED_DELAY_MS: "60000" - Update the default cluster.prometheus_url based on the cluster
information:
Default prometheus_url:
http://localhost:9000/<cluster-name>/prometheus/api/v1/query_rangeExample URL( For CNE deployment and cluster name as
ocnadd):prometheus_url:
http://occne-kube-prom-stack-kube-prometheus.occne-infra.svc.ocnadd:80/ocnadd/prometheus/api/v1/query_range - (Optional) Updating the OCNADD Backup Cronjob:
Modify the below backup parameters as needed For more information on backup and restore, see "Fault Recovery" section.
BACKUP_STORAGE : Represents Backup storage PVC size BACKUP_CRONEXPRESSION : Represents the time of execution PURGE_DAYS : Represents the backup retention period in days ocnaddbackuprestore: ocnaddbackuprestore: name: ocnaddbackuprestore env: BACKUP_STORAGE: 20Gi BACKUP_CRONEXPRESSION: "0 8 * * *" PURGE_DAYS: 7 - (Optional) Updating the OCNADD Kafka Deployment Mode:
Modify the global parameter below to enable the Kraft-based Kafka deployment. In this case, ZooKeeper will not be deployed, and instead of ZooKeeper, the Kraft controller service will be deployed.
- Kraft mode of deployment is supported only for fresh installations. Upgrading an existing deployment in Kraft mode has not been tested or supported. This mode should be used only if no inter-release upgrade is planned for OCNADD.
- Kraft based deployment with ACL enabled is not supported for OCCM managed
certificates and there is no performance figure benchmarked with Kraft based
deployment.
global.kafka.kraftEnabled: false ## --> update this to 'true'
- Customize the rules file
<chartpath>/templates/ocnadd-alerting-rules.yaml:- If OCNADD is to be installed in OCI setup, then remove the
<chartpath>/templates/ocnadd-alerting-rules.yamland<chartpath>/templates/ocnadd-mgmt-alerting-rules.yamlfiles. - If OCNADD is to be installed in CNE Setup, then all the services will be monitored by Prometheus By default. So there will not be any Modifications in the Helm Chart. All the Prometheus Alert Rules Present in Helm Chart will be Updated in Prometheus Server. (Here the Label Used to Update the Prometheus Server is "role: cnc-alerting-rules", which is added By Default in Helm Charts)
- If OCNADD is to be installed in Tanzu setup, then modify the
metadata.labels" value in<chartpath>/templates/ocnadd-alerting-rules.yamland<chartpath>/templates/ocnadd-mgmt-alerting-rules.yamlfiles as below:For Example "
release: prom-operator" instead of "role: cnc-alerting-rules".To obtain the labels details use the below command:kubectl get prometheus <Prometheus_Configuration_NAME> -n <Prometheus_Namespace> -o=jsonpath='{.spec.ruleSelector.matchLabels}'Example:
$ kubectl get prometheus prom-operator-kube-prometh-prometheus -n occne-infra -o=jsonpath='{.spec.ruleSelector.matchLabels}'{"release: prom-operator"}
Sample Alert File:apiVersion: monitoring.coreos.com/v1 kind: PrometheusRule metadata: labels: release: prom-operator name: ocnadd-alerting-rules namespace: {{ .Values.global.cluster.nameSpace.name }} - If OCNADD is to be installed in OCI setup, then remove the
- <Optional> Creating Registry Credentials:
If the user image repository is protected and has an authentication mechanism, follow the below steps:
- Use the kubectl command to create a secret named "regcred" with the credentials of the image repository.
- Update the
imagePullSecret.enablefield totruein theocnadd-custom-values-25.1.100.yamlfile as follows:imagePullSecret: enable: true ## --> update this to 'true'
- <Optional> Kafka preinstall Configuration changes:
- <Optional> To change the profiles of the brokers, edit the
respective values (CPU, memory, storage, external-access, security, jaas-password,
replicas, internal replication factor, and so on) in kafka-section of
ocnadd-custom-values-25.1.100.yamlfile. Ensure that this is done for all the applicable worker groups.Note:
If the topics are created with Replication Factor (RF) greater than "1" (RF>1) then, ensure to update the corresponding RF values of the following parameters in theocnadd-custom-values-25.1.100.yamlfile under ocnaddkafka:offsetsTopicReplicationFactortransactionStateLogReplicationFactor
For example, if the topics SCP, NRF, SEPP, PCF, BSF, and MAIN are created with RF=3, then the parameters should be set to value "3"
offsetsTopicReplicationFactor: 3 transactionStateLogReplicationFactor: 3 - <Optional> When the security protocol is SASL and the customer
required to add new users, update the
kafka_server_jaas.conf,zookeeper_jaas.conffiles in<chartpath>/charts/ocnaddkafka/config.
- Storage Class:
- If deploying on Tanzu, update the storageClass in the
ocnadd-custom-values-25.1.100.yamlwith the respective storage class name of the TANZU platform. For example,zfs-storage-policy. - If deploying on OCI, update the storageClass in the
ocnadd-custom-values-25.1.100.yamlwith the respective storage class name of the OCI platform, it should be "oci-bv"
This step is specific to the TANZU and OCI platform. Skip this step if you are installing OCNADD on CNE. For CNE, the default storageClass is standard.. - If deploying on Tanzu, update the storageClass in the
- <Optional> To enable Egress Annotation, see the "Enabling Egress Annotation" section in the Oracle Communications Network Analytics Data Director User Guide. The step can be skipped if the Egress Traffic separation via CNLB is planned to be used.
- Loadbalancer on OCI: Update the following in
ocnadd-custom-values-25.1.100.yamlglobal.env.oci: false =====> set it to trueglobal.env.subnetOcid:<subnet_ocid> # Add the OCID of the subnet that user want to use for creating load balancer
3.3 Global Parameters
Table 3-2 Global Parameters
| Parameter Name | Data Type | Range | Default Value | Mandatory(M)/Optional(O)/Conditional(C) | Description |
| ocnaddalarm.enabled | BOOLEAN | true/false | true | M | To enable alarm charts. |
| ocnaddconfiguration.enabled | BOOLEAN | true/false | true | M | To enable configuration charts. |
ocnaddhealthmonitoring.enabled |
BOOLEAN | true/false | true | M | To enable health monitoring charts. |
| ocnaddfilter.enabled | BOOLEAN | true/false | false | M | To disable filter charts ('false' for the current release). |
| ocnaddaggregation.enabled | BOOLEAN | true/false | true | M | To enable aggregation charts. |
| ocnaddbackuprestore.enabled | BOOLEAN | true/false | true | M | To enable backup restore charts. |
| ocnaddkafka.enabled | BOOLEAN | true/false | true | M | To enable Kafka charts. |
| ocnaddadminsvc.enabled | BOOLEAN | true/false | true | M | To enable adminsvc charts. |
| ocnaddgui.enabled | BOOLEAN | true/false | true | M | To enable GUI charts. |
| ocnadduirouter.enabled | BOOLEAN | true/false | true | M | To enable UI router charts. |
| ocnaddredundancyagent.enabled | BOOLEAN | true/false | false | M | To enable two site redundancy |
| ocnaddexport | BOOLEAN | true/false | false | M | To enable export service |
| ocnaddnonoracleaggregation | BOOLEAN | true/false | false | M | To enable non-Oracle aggregation feature through aggregation service instance. |
| ocnaddredundancyagent.egress | BOOLEAN | true/false | false | C | Required if egress annotation is required to allow traffic outside cluster. |
| env.oci | BOOLEAN | true/false | false | M | It should be set to true for OCI platform. |
| env.subnetOcid | STRING | NA | NA | C | It is required for OCI platform. The OCID of the subnet that you want to use for creating load balancers. |
| env.topologyKey | STRING | NA | kubernetes.io/hostname | M | The topology key for setting up the topology constraints on the pod deployment. |
| env.ocwebclient.OCWEBCLIENT_TIMEOUT | INTEGER | NA | 30 | O | Webclient timeout in seconds |
| env.ocwebclient.OCWEBCLIENT_KEEPALIVE_IDLE | INTEGER | NA | 90 | O | Webclient keep alive idle time in seconds |
| env.repo.repo.REPO_HOST_PORT | STRING | NA | docker.io | M | Local container registry to pull the images |
| env.repo.repo.REPO_PATH | STRING | NA | ocdd.repo | M | Additional repo path |
| env.admin.OCNADD_EGW_UPGRADE_ENABLE | BOOLEAN | NA | false | M | Upgrade Egress gateway during Helm upgrade if the flag is set to true. |
| env.admin.OCNADD_ADAPTER_UPGRADE_ENABLE | BOOLEAN | NA | false | M | Upgrade consumer adapter during Helm upgrade if the flag is set to true. |
| scaleDownOnePodAtATime | BOOLEAN | true/false | false | M | Scale down Pods one at a time. |
| stabilizationWindowSeconds | INTEGER | NA | 60 | M | Stabilization period in seconds post which scale down starts. |
| scaleDownPeriodSeconds | INTEGER | NA | 30 | M | Period of each scale down operation in seconds. |
| scaleDownValue | INTEGER | NA | 1 | M | Number of pods which shall go down in every scaleDownPeriodSeconds. |
| initContainers.name | STRING | NA | ocnaddinitcontainer | M | Name of initContainer for SSL support |
| initContainers.image | STRING | NA | jdk21-openssl:1.1.0 | M | InitContainer Image |
| initContainers.REPO_PATH | STRING | NA | utils.repo | M | Repo path where init image is stored |
| initContainers.volumeMounts.ts_ks_volumeName | STRING | NA | truststore-keystore-volume | M | Volume name for truststore |
| initContainers.volumeMounts.ts_ks_volumePath | STRING | NA | /var/securityfiles/keystore | M | Path where keystore files are stored |
| initContainers.volumeMounts.certificateName | STRING | NA | client-server-certificate | M | Volume name for server certificates |
| initContainers.volumeMounts.certificatePath | STRING | NA | /var/securityfiles/certs | M | Path where cert files are stored |
| initContainers.env.cert_file_params.SERVER_CERT_FILE | STRING | NA | servercert.pem | M | Server cert filename |
| initContainers.env.cert_file_params.CLIENT_CERT_FILE | STRING | NA | clientcert.pem | M | Client cert filename |
| initContainers.env.cert_file_params.SERVER_KEY_FILE | STRING | NA | serverprivatekey.pem | M | Server Private Key filename |
| initContainers.env.cert_file_params.CLIENT_KEY_FILE | STRING | NA | clientprivatekey.pem | M | Client Private Key filename |
| initContainers.env.ks_file_params.SERVER_KEY_STORE | STRING | NA | serverKeyStore.p12 | M | Server Keystore file |
| initContainers.env.ks_file_params.CLIENT_KEY_STORE | STRING | NA | clientKeyStore.p12 | M | Client Keystore file |
| initContainers.env.ks_file_params.TRUST_STORE | STRING | NA | trustStore.p12 | M | Truststore file |
| initContainers.cacert.key | STRING | NA | CA_CERT_FILE | M | Cacert key file |
| initContainers.cacert.value | STRING | NA | cacert.pem | M | Cacert file |
| ssl.intraTlsEnabled | BOOLEAN | true/false | false | M | Enable internal service TLS |
| ssl.mTLS | BOOLEAN | true/false | false | M | Enable MTLS support for internal OCNADD services |
| ssl.kafkaCipherSuites | STRING | NA | "TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256,TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384, TLS_AES_256_GCM_SHA384,TLS_AES_128_GCM_SHA256,TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384" | M | Supported Cipher Suites for Kafka Broker service in Data Director |
| ssl.tlsCipherSuites | STRING | NA | "TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256,TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384, TLS_AES_256_GCM_SHA384,TLS_AES_128_GCM_SHA256,TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384" | M | Support Cipher Suites for Internal Services of Data Director |
| ssl.CERT_EXPIRY_CRONEXPRESSION | STRING | NA | 0 0 * * * | M | Schedule for Cron Expression that will check certificate expiry at midnight everyday. |
| ssl.CERT_EXPIRY_CRONJOB | BOOLEAN | true/false | true | M | Enable cronjob schedule to check certificate expiry. |
| acl.genericAclAllowed | BOOLEAN | true/false | false | M | No need to change this flag here, genericAclAllowed=true will be used in upgrade --set command to restrict the generic ACL creation. |
| acl.kafkaClientAuth | STRING | none/required | none | M | This Property is to enable or disable MTLS in Kafka. |
| acl.aclNotAllowed | BOOLEAN | true/false | true | M | This Property is used to turn on or off the Kafka ACL's. |
| image.ocnaddadminsvc.name | STRING | NA | ocnaddadminsvc:25.1.100 | M | Admin Service Image |
| image.ocnaddconsumeradapter.name | STRING | NA | ocnaddconsumeradapter:25.1.100 | M | Consumer Adapter Image |
| image.ocnaddaggregation.name | STRING | NA | ocnaddaggregation:25.1.100 | M | Aggregation Service Image |
| image.ocnaddalarm.name | STRING | NA | ocnaddalarm:25.1.100 | M | Alarm Service Image |
| image.ocnaddconfiguration.name | STRING | NA | ocnaddconfiguration:25.1.100 | M | Configuration Service Image |
| image.ocnaddfilter.name | STRING | NA | ocnaddfilter:25.1.100 | M | Filter Service Image |
| image.ocnaddhealthmonitoring.name | STRING | NA | ocnaddhealthmonitoring:25.1.100 | M | Health Monitoring Image |
| image.ocnadduirouter.name | STRING | NA | ocnadduirouter:25.1.100 | M | UI Router Image |
| image.ocnaddbackuprestore.name | STRING | NA | ocnaddbackuprestore:2.0.10 | M | Backup Restore Image |
| image.ocnadd_kafka_healthclient.name | STRING | NA | ocnaddkafkahealthclient-3.7.0:2.0.34 | M | Kafka Image |
| image.ocnadd_jmx_exporter.name | STRING | NA | jmx-exporter-jdk-21.0.4:0.20.1.2 | M | JMX exporter image |
| image.ocnaddgui.name | STRING | NA | ocnaddgui:25.1.100 | M | OCNADD GUI Image |
| cluster.domainName | STRING | NA | occne-ocdd | M | Domain name of the setup |
| cluster.clusterName | STRING | NA | occne-ocdd | M | Default cluster name of setup |
| cluster.secret.name | STRING | NA | db-secret | M | Database Secret name where DB credentials are stored |
| cluster.mysqlNameSpace.name | STRING | NA | occne-cndbtierone | M | cnDBTier namespace |
| cluster.mysqlPod | STRING | NA | ndbmysqld-0 | M | cnDBTier Pod Name |
| cluster.database.db_ip | STRING | NA | mysql-connectivity-service.occne-cndbtierone | M | Hostname or IP of cnDBTier |
| cluster.database.db_port | INTEGER | NA | 3306 | M | DB Port |
| cluster.database.configuration_db | STRING | NA | configuration_schema | M | Configuration Service Schema Name |
| cluster.database.alarm_db | STRING | NA | alarm_schema | M | Alarm Service Schema Name |
| cluster.database.health_db | STRING | NA | healthdb_schema | M | Health Service Schema Name |
| cluster.storageClass | STRING | NA | standard | M | Storage Class Name |
| cluster.nameSpace.name | STRING | NA | ocnadd-deploy | M | OCNADD Namespace |
| cluster.serviceAccount.create | BOOLEAN | true/false | true | M | To create a ServiceAccount (true/false) |
| cluster.serviceAccount.name | STRING | NA | ocnadd | M | Name of the service Account |
| cluster.clusterRole.create | BOOLEAN | true/false | true | M | To create clusterRole (true/false) |
| cluster.clusterRole.name | STRING | NA | ocnadd | Name of the clusterRole | |
| cluster.clusterRoleBinding.create | BOOLEAN | true/false | true | M | To create clusterRoleBinding (true/false) |
| cluster.clusterRoleBinding.name | STRING | NA | ocnadd | Name of the clusterRoleBinding | |
| cluster.terminationGracePeriodSeconds | INTEGER | NA | 5 | O | Pod grace termination |
| cluster.imagePullSecret.enable | BOOLEAN | true/false | false | M | Image Pull secret creation |
| cluster.imagePullSecret.name | STRING | NA | regcred | O | Set to regcred if cluster.imagePullSecret.enable is true |
| cluster.ALARM_PURGE_DAYS | INTEGER | NA | 7 | M | Alarm Purge in Days |
| cluster.kafka.ocnadd_kafka_bootstrap_servers | STRING | NA | kafka-broker:9092 | M | Bootstrap server for PLAINTEXT |
| cluster.kafka.ocnadd_kafka_bootstrap_servers_ssl | STRING | NA | kafka-broker:9093 | M | Bootstrap server for SSL |
| cluster.kafka.ocnadd_kafka_bootstrap_servers_sasl | STRING | NA | kafka-broker:9094 | M | Bootstrap server for SASL |
| cluster.prometheusScrapePort | INTEGER | NA | 9000 | O | Port to scape metrics required if metrics enabled |
| cluster.prometheusPortName | STRING | NA | cnc-metrics | O | Role required to define in alert rules yaml |
| cluster.max_latency | FLOAT | NA | 0.05 | M | Max latency range of 50ms |
| cluster.memory_threshold | INTEGER | [0-100] | 90 | M | Max Threshold limit for memory |
| cluster.cpu_threshold | INTEGER | [0-100] | 85 | M | CPU max threshold limit |
| cluster.mps | INTEGER | NA | 100000 | M | Default MPS rate |
| cluster.serviceMonitorLabel | STRING | NA | occne-kube-prom-stack | M | service monitor label to scrape metrics |
| cluster.prometheus_url | STRING | NA | http://localhost:9000/cluster-name/prometheus/api/v1/query_range | M | Prometheus URL to scrape metrics |
| network.policy.enable | BOOLEAN | true/false | false | M | Network Policy enable for intercommunication of OCNADD services |
| network.ingress.denyall | BOOLEAN | true/false | false | C | Deny all ingress traffic |
| network.ingress.kafka | BOOLEAN | true/false | true | C | Allow ingress traffic for kafka |
| network.ingress.aggregation | BOOLEAN | true/false | true | C | Allow ingress traffic for aggregation service |
| network.ingress.filter | BOOLEAN | true/false | true | C | Allow ingress traffic for filter service |
| network.ingress.adapter | BOOLEAN | true/false | true | C | Allow ingress traffic for adapter service |
| network.ingress.egw | BOOLEAN | true/false | true | C | Allow ingress traffic for egress service |
| network.ingress.config | BOOLEAN | true/false | true | C | Allow ingress traffic for configuration service |
| network.ingress.alarm | BOOLEAN | true/false | true | C | Allow ingress traffic for alarm service |
| network.ingress.health | BOOLEAN | true/false | true | C | Allow ingress traffic for health monitoring service |
| network.ingress.admin | BOOLEAN | true/false | true | C | Allow ingress traffic for admin service |
| network.ingress.namespaces | STRING | NA |
- occne-infra - occncc |
C | Network communication between allowed namespaces |
| network.ingress.external.enable | BOOLEAN | true/false | false | C | Allow kafka LoadBalancer IP to be created |
| network.ingress.external.cidrs | STRING | NA | - 10.0.0.0/8 | C | Cidr for network communication |
| network.egress.denyall | BOOLEAN | true/false | false | C | Deny egress traffic |
| deployment.centralized | BOOLEAN | true/false | true | M | Whether to use centralized mode of deployment |
| deployment.management | BOOLEAN | true/false | true | M | Whether to deploy management group services when
centralized deployment model is enabled.
Will deploy worker group services if false. |
| deployment.management_namespace | STRING | - | Valid namespace name | M | Specify the managment namespace when deploying the
worker group services.
Centralized Mode: For Management Group Deployment:
For Worker Group Deployment:
This parameter facilitates communication between services in the worker group and the management group of services. Non-Centralized Mode: In this mode:
| deployment.nonCenToCen_upgrade | BOOLEAN | true/false | false | M | True if upgrading from non-centralized to centralized.
Default is False (direct installation) |
| deployment.primary_site | BOOLEAN | true/false | false | C | This parameter is required only in case the redundancy agent service is enabled. It depicts if the configured site is primary or not. |
| deployment.primary_agent_ip | STRING | NA | - | C | This parameter is required only in case the redundancy agent service is enabled. It is configured in the secondary site and denotes the primary site redundancy agent IP address or service FQDN. |
| kakfka.kraftEnabled | BOOLEAN | true/false | false | C | This parameter is required only for the Kraft based
Kafka deployment.
Default value is 'false'. If kraftEnabled is false, then kafka-broker and zookeeper will be deployed. If kraftEnabled is true, then kafka-broker and kraft-controller will be deployed. |
| admin.OCNADD_UPGRADE_WG_NS | STRING | NA | [ocnadd-deploy-wg1,ocnadd-deploy-wg2] | M | This parameter is a comma-separated list of worker group namespaces to update using Helm. |
| kafkaReplicas | INTEGER | - | 4 | M | The parameter to change the replicas for the Kafka broker. |
| cnlb.consumeradapter.enable | BOOLEAN | true/false | false | C | If true, then egress traffic segregation will be enabled
for the consumer feeds.
It will be used for checking if Egress NAD should be attached to consumer adapters or not. The parameter is only recommended to be enabled for the OCCNE with CNLB support. |
| cnlb.ingressadapter.enable | BOOLEAN | true/false | false | C | If true, then ingress traffic segregation will be
enabled for the ingress adapter along with external access.
It will be used for checking if Ingress NAD should be attached to ingress adapters or not. The parameter is only recommended to be enabled for the OCCNE with CNLB support. |
| cnlb.ocnaddredundancyagent.enable | BOOLEAN | true/false | false | C | If true, External Access will be enabled for RedundancyAgent. It will be used for checking if cnlb annotations should be assigned to the redundancy deployments or not. The parameter is only recommended to be enabled for the OCCNE with CNLB support. |
| cnlb.ocnaddredundancyagent.network | STRING | NA | default/nf-oam-int1@nf-oam-int1 | C | This must be the oam network with ingress definition.
The entry means single network will be used by another site's Redundancy
Agent for ingress communication.
Update the network from the generated CNLB annotation, Given value is an example need to be updated as per /var/occne/cluster/$OCCNE_CLUSTER/artifacts/cnlbGenAnnotations.py script. |
| cnlb.ocnaddredundancyagent.externalIP | STRING | NA | 10.1.1.1 | C | For two site RedundancyAgent communication only single External IP required to communicate. Update the IP address in the External IP |
| env.controlPlaneNfList | STRING | NA | BSF,NRF,PCF | M | It enlists all the control plane NFs |
| env.proxyNfList | STRING | NA | SCP,SEPP | M | It enlist all the proxy NFs |
3.4 Helm Hook Parameters
Table 3-3 Helm Hook Parameters
| ocnaddhelmhook.config.name | STRING | - | helmhook-configmap | M | Name of ConfigMap |
| ocnaddhelmhook.config.upgrade_name | STRING | - | helmhook-upgrade-configmap | M | Name of Upgrade ConfigMap |
| ocnaddhelmhook.config.rollback_name | STRING | - | helmhook-rollback-configmap | M | Name of Rollback ConfigMap |
| ocnaddhelmhook.name | STRING | - | ocnaddhelmhook | M | Helm Hook Name |
| ocnaddhelmhook.container.name | STRING | - | ocnaddhelmhook | M | Container Name of Helm Hook Job |
| ocnaddhelmhook.container.image | STRING | - | preinstall-image:2.1.6 | M | Image used for preinstall hooks |
| ocnaddhelmhook.container.imagePullPolicy | STRING | IfNotPresent/Always/Never | IfNotPresent | M | Image Pull Policy |
| ocnaddpostinstallhelmhook.name | STRING | - | ocnaddpostinstallhelmhook | M | Post Install Hook Name |
| ocnaddpostupgradehelmhook.name | STRING | - | ocnaddpostupgradehelmhook | M | Post Upgrade Hook Name |
| ocnaddpostrollbackhelmhook.name | STRING | - | ocnaddpostrollbackhelmhook | M | Post Rollback hook name |
| ocnaddpreupgradehelmhook.name | STRING | - | ocnaddpreupgradehelmhook | M | Pre Upgrade Hook Name |
| ocnaddprerollbackhelmhook.name | STRING | - | ocnaddprerollbackhelmhook | M | Pre Rollback Hook Name |
| ocnaddhelmhook.config.auto_backup_restore_cm | STRING | - | ocnadd-configmap-auto-backup-restore | M | Name of the automatic backup restore ConfigMap |
| ocnaddpreinstallworkergrouphelmhook.name | STRING | - | ocnaddpreinstallworkergrouphelmhook | M | Name of the preinstall hook used during the installation of the worker group |
| ocnaddpreinstallworkergrouphelmhook.retry_max_attempt | INTEGER | - | 5 | M | Maximum number of retries for getting the list of worker group names |
| ocnaddpreinstallworkergrouphelmhook.retry_delay | INTEGER | - | 15 | M | Delay between retries |
| ocnaddpostinstallworkergrouphelmhook.name | STRING | - | ocnaddpostinstallworkergrouphelmhook | M | Name of the postinstall hook used during the installation of the worker group |
| ocnaddpostinstallworkergrouphelmhook.retry_max_attempt | INTEGER | - | 5 | M | Maximum number of retries for invoking the create worker group API |
| ocnaddpostinstallworkergrouphelmhook.retry_delay | INTEGER | - | 15 | M | Delay between retries |
| ocnaddpostdeleteworkergrouphelmhook.name | STRING | - | ocnaddpostdeleteworkergrouphelmhook | M | Name of the postdelete hook used during the uninstallation of the worker group |
| ocnaddpostdeleteworkergrouphelmhook.retry_max_attempt | INTEGER | - | 5 | M | Maximum number of retries for invoking delete API for worker group |
| ocnaddpostdeleteworkergrouphelmhook.retry_delay | INTEGER | - | 15 | M | Delay between retries |
| ocnaddcopybackuppvctemptoorighelmhook.name | STRING | - | ocnaddcopybackuppvctemptoorighelmhook | M | Hook to copy backup from temporary to original PVC |
| ocnaddcopybackuppvcorigtotemphelmhook.name | STRING | - | ocnaddcopybackuppvcorigtotemphelmhook | M | Hook to copy backup from original to temporary PVC. |
| ocnaddcreatetemppvchelmhook.name | STRING | - | ocnaddcreatetemppvchelmhook | M | Hook to create temporary backup PVC during upgrade. |
3.5 Aggregation Service Parameters
Table 3-4 Aggregation Service Parameters
| ocnaddnrfaggregation.name | STRING | - | ocnaddnrfaggregation | M | Name of the application |
| ocnaddscpaggregation.name | STRING | - | ocnaddscpaggregation | M | Name of the application |
| ocnaddseppaggregation.name | STRING | - | ocnaddseppaggregation | M | Name of the application |
| ocnaddbsfaggregation.name | STRING | - | ocnaddbsfaggregation | M | Name of the application |
| ocnaddpcfaggregation.name | STRING | - | ocnaddpcfaggregation | M | Name of the application |
| ocnaddnrfaggregation.resources.limit.cpu | INTEGER | - | 3 | M | Number of maximum CPUs for NRF aggregation |
| ocnaddnrfaggregation.resources.limit.memory | STRING | - | 2Gi | M | Max Memory limit for NRF aggregation |
| ocnaddnrfaggregation.resources.limit.ephemeralstorage | STRING | - | 500Mi | M | Ephemeral Storage for NRF aggregation |
| ocnaddscpaggregation.resources.limit.cpu | INTEGER | - | 3 | M | Number of max CPU for SCP aggregation |
| ocnaddscpaggregation.resources.limit.memory | STRING | - | 2Gi | M | Max Memory limit for SCP aggregation |
| ocnaddscpaggregation.resources.limit.ephemeralstorage | STRING | - | 500Mi | M | Ephemeral Storage for SCP aggregation |
| ocnaddseppaggregation.resources.limit.cpu | INTEGER | - | 3 | M | Number of max CPU for SEPP aggregation |
| ocnaddseppaggregation.resources.limit.memory | STRING | - | 2Gi | M | Max Memory limit for SEPP aggregation |
| ocnaddseppaggregation.resources.limit.ephemeralstorage | STRING | - | 500Mi | M | Ephemeral Storage for SEPP aggregation |
| ocnaddnonoracleaggregation.resources.limit.cpu | INTEGER | - | 3 | M | Number of max CPU for non-Oracle aggregation |
| ocnaddnonoracleaggregation.resources.limit.memory | STRING | - | 2Gi | M | Maximum memory allocation for non-Oracle aggregation |
| ocnaddnonoracleaggregation.resources.limit.ephemeralstorage | STRING | - | 500Mi | M | Ephemeral Storage for non-Oracle aggregation |
| OCNADD_AGGREGATION_LOG_ROOT | STRING | - | INFO | O | Default Log level set for the application. |
| OCNADD_AGGREGATION_LOG_NETTY | STRING | - | INFO | O | Default Netty Log level set for the application. |
| OCNADD_AGGREGATION_SERVICE_TOPIC_RETRIES_THRESHOLD | INTEGER | - | 120000 | O | Retry Threshold for TOPIC reachability |
| OCNADD_METRICS_CPU_THRESHOLD | FLOAT | [ 0, 1 ] | 0.45 | O | Parameter to compute the CPU related metrics of the application. |
| OCNADD_METRICS_MEM_THRESHOLD | FLOAT | [ 0, 1 ] | 0.95 | O | Parameter to compute the Memory related metrics of the application. |
| KAFKA_PRODUCER_SECURITY_PROTOCOL | STRING | - | PLAINTEXT | M | Kafka Producer Secutiry Protocol. |
| KAFKA_PRODUCER_SSL_PROTOCOL | STRING | - | TLSv1.3 | M | SSL Protocol |
| KAFKA_PRODUCER_SASL_MECHANISM | STRING | - | PLAIN | M | Kafka Producer SSAL Mechanism. |
| KAFKA_PRODUCER_SSL_CLIENT_AUTH | BOOLEAN | true, false | false | M | Kafka SSL client authentication. |
| KAFKA_BOOTSTRAP_SERVER | STRING | - | kafka-broker:9092 | M | Kafka Boot strap server address. |
| KAFKA_MAX_AGE_CONFIG | INTEGER | - | 7500 | M | The period of time in milliseconds after which we force a refresh of metadata. |
| ENABLE_AGGREGATION_COUNTER_METRICS | BOOLEAN | true,false | false | M | Enable metrics for Aggregation service |
| OCNADD_TRUST_KEYSTORE | BOOLEAN | true, false | true | M | Enable to secure connection via OCWeb Client. |
| KAFKA_FETCH_MIN_BYTES | STRING | - | 1 | O | The minimum amount of data per-partition the server will return |
| KAFKA_FETCH_MAX_BYTES | INTEGER | - | 576720 | O | The maximum amount of data per-partition the server will return |
| KAFKA_MAX_PARTITIONS_FETCH_BYTES | INTEGER | - | 104858 | O | The maximum amount of data per-partition the server will return. |
| FETCH_MAX_WAIT_MS | INTEGER | - | 100 | O | The maximum amount of time the server will block before answering the fetch request if there isn’t sufficient data to immediately satisfy the requirement given by fetch.min.bytes |
| SESSION_TIME_OUT | INTEGER | - | 15000 | O | The timeout used to detect client failures when using Kafka’s group management facility. |
| HEARTBEAT_INTERVAL_MS | INTEGER | - | 5000 | O | The expected time between heartbeats to the consumer coordinator when using Kafka’s group management facilities |
| MAX_POLL_INTERVAL_MS | INTEGER | - | 30000 | O | The maximum delay between invocations of poll() when using consumer group management |
| MAX_POLL_RECORDS | INTEGER | - | 300 | O | The maximum number of records returned in a single call to poll() |
| CONSUMER_POLL_MS | INTEGER | - | 50 | O | Polling time in ms for consumer |
| BATCH_SIZE | INTEGER | - | 65536 | O | The maximum amount of data to be collected before sending the batch. |
| LINGER_MS | INTEGER | - | 1 | O | The time to wait before sending messages out to Kafka |
| REQUEST_TIMEOUT_MS | INTEGER | - | 1000 | O | The configuration controls the maximum amount of time the client will wait for the response of a request |
| KAFKA_SOCKET_BYTES_BUFFER | INTEGER | - | 104857 | O | Kafka Socket Buffer setting for consumer |
| logging.level.com.oracle.cgbu.cne.ocdd | STRING | [INFO,WARN,DEBUG,ERROR] | INFO | O | To set the log level of the OCDD package level |
| logging.level.com.oracle.cgbu.cne.ocnadd | STRING | [INFO,WARN,DEBUG,ERROR] | INFO | O | To set the log level of the OCNADD package level |
| OCNADD_AGG_REDUNDANCY_DELAY_MS | INTEGER | - | 1000 | C | Delay before starting task to check Kafka ingress rate. This parameter is required when the two-site redundancy feature is enabled. |
| OCNADD_AGG_REDUNDANCY_INTERVAL_MS | INTEGER | - | 250 | C | Interval between tasks to check Kafka ingress rate. This parameter is required when the two-site redundancy feature is enabled. |
| METADATA_HISTORY_LENGTH | INTEGER | - | 20 | C | The number of metadata maintained in the cache. |
| METADATA_CLEAN_DELAY_SEC | INTEGER | - | 86400 | C | Initial delay in cleaning the metadata cache. |
| METADATA_CLEAN_PERIOD_SEC | INTEGER | - | 86400 | C | Interval after the metadata cache is cleaned. |
| MESSAGE_SEQUENCING_TYPE | INTEGER | [NONE,TIME_WINDOW,TRANSACTION,REQUEST_RESPONSE] | NONE | M |
NONE: No message sequencing. TIME_WINDOW: Messages received within a window time for each partition will be sorted separately based on timestamp and streamed to Kafka topic. TRANSACTION: In-order messages received for each transaction within TRANSACTION_MSG_SEQUENCING_EXPIRY_TIMER will be sorted separately and streamed to Kafka topic. REQUEST_RESPONSE: In-order Request (RxRequest and TxRequest) and/or Response pair (RxResponse and TxResponse) messages received for each transaction within REQUEST_RESPONSE will be sorted separately and streamed to Kafka topic. |
| WINDOW_MSG_SEQUENCING_EXPIRY_TIMER | INTEGER | [5-500]ms | 10ms | C | When MESSAGE_SEQUENCING_TYPE = TIME_WINDOW |
| TRANSACTION_MSG_SEQUENCING_EXPIRY_TIMER | INTEGER | [20ms-30s] | 200ms | C | When MESSAGE_SEQUENCING_TYPE = TRANSACTION |
| REQUEST_RESPONSE_MSG_SEQUENCING_EXPIRY_TIMER | INTEGER | [5-500]ms | 10ms | C |
When MESSAGE_SEQUENCING_TYPE = REQUEST_RESPONSE |
3.6 Configuration Service Parameters
Table 3-5 Configuration Service Parameters
| ocnaddconfiguration.name | STRING | - | ocnaddconfiguration | M | Name of configuration service |
| logging.type | STRING | STDOUT/LOGJSON | STDOUT | O | Logging type Standard Output or JSON format |
| logging.level.reactor.netty | STRING | - | INFO | O | Netty logging level |
| OCNADD_TRUST_KEYSTORE | BOOLEAN | - | false | O | Truststore enable for Configuration Service |
| logging.level.com.oracle.cgbu.cne.ocnadd | STRING | - | INFO | O | Logging level for OCNADD services |
| logging.level.com.oracle.cgbu.cne.ocdd | STRING | - | INFO | O | Logging level for Common OCNADD services |
| ADMIN_RETRY_MAXATTEMPT | INTEGER | - | 3 | O | Maximum number of retries attempted while calling admin service |
| ADMIN_RETRY_DELAY | INTEGER | - | 5000 | O | Delay between successive retries while calling admin service |
| ADMIN_FETCH_TIMEOUT | INTEGER | - | 10000 | O | Maximum amount of time to wait for reply while calling admin service |
| FEED_NOTIFICATION_RETRY_MAXATTEMPT | INTEGER | - | 3 | O | Maximum number of feed notification retries to be attempted |
| FEED_NOTIFICATION_RETRY_DELAY | INTEGER | - | 5000 | O | Delay between successive notification retries to be attempted |
| INGRESS_NOTIFICATION_RETRY_MAXATTEMPT | INTEGER | - | 3 | O | Maximum number of notification retries to be attempted |
| INGRESS_NOTIFICATION_RETRY_DELAY | INTEGER | - | 5000 | O | Delay between successive notification retries |
| OCNADD_MAX_EXTERNAL_KAFKA_FEEDS | INTEGER | - | 2 | O | Maximum number of allowed external Kafka Feed |
| MAX_ALLOWED_FILTERS | INTEGER | - | 30 | O | Maximum number of allowed filters |
| MAX_VALUES_IN_FILTER_ATTRIB | INTEGER | - | 20 | O | Maximum number of values allowed in filter attributes |
| MAX_FILTERS_ASSOC_WITH_APP | INTEGER | - | 4 | O | Maximum number of filters associated with a single app |
| MAX_ACTION_TYPE_IN_FILTER | INTEGER | - | 2 | O | Maximum number of action type in a filter with chaining |
| MAX_GLOBALL3L4_ROW_SIZE | INTEGER | - | 500 | O | Maximum size of L3L4 rows |
| OCNADD_REDUNDANCY_NOTIFY_DELAY_SEC | INTEGER | - | 120 | C | Delay before updating mode of worker group from ACTIVE to STANDBY and vice-versa |
| MAX_CORRELATION_CONFIGURATION_SUPPORTED | INTEGER | - | 3 | O | Maximum number of correlation feeds allowed |
| OCNADD_MAX_WORKERGROUP_THRESHOLD_PERCENTAGE | INTEGER | - | 80 | O | The percentage threshold for the maximum worker group supported |
| MAX_EXPORT_CONFIGURATION_SUPPORTED | INTEGER | - | 3 | O | The simultaneous number of export configuration supported on the Data Director |
3.7 Health Monitoring and Alarm Service Parameters
Table 3-6 Health Monitoring Service Parameters
| Parameter Name | Data Type | Default Value | Mandatory(M)/Optional(O)/Conditional(C) | Description |
| ocnaddhealthmonitoring.name | STRING | ocnaddhealthmonitoring | M | Health monitoring service name |
| HEALTH_MONITORING_TIMER | INTEGER | 5000 | O | Timer to check Health of integrated services |
| HEALTH_METRICS_SCHEDULED | BOOLEAN | true | O | Scheduler for metrics |
| HEALTH_METRICS_TIMER | INTEGER | 120000 | O | Timer for health metrics |
| HEALTH_PURGE_TIME_HR | INTEGER | 5 | O | Health profile purging timer in hour |
| HEALTH_MONITORING_CPUTHRESHOLD | INTEGER | 75 | M | CPU threshold to raise alarm |
| HEALTH_MONITORING_MEMORYTHRESHOLD | INTEGER | 95 | M | Memory threshold to raise alarm |
| Logging Properties | ||||
| HEALTH_LOG_HTTPCLIENT | STRING | INFO | O | Set Default Log level for HTTP client |
| HEALTH_LOG_SPRING_WEB | STRING | INFO | O | Set Default Log level for Spring Web |
| logging.level.com.oracle.cgbu.cne.ocnadd | STRING | INFO | O | Logging level for Health Monitoring OCNADD Service |
| logging.level.com.oracle.cgbu.cne.ocdd | STRING | INFO | O | Logging level for Common OCNADD Service |
| HEALTH_APPLICATION_LOG_LEVEL | STRING | INFO | O | Set application logger level |
| HEALTH_LOG_REQUEST_DETAILS | BOOLEAN | true | O | If this parameter is set to true, the health request details will be logged |
| HEALTH_LOG_ROOT | STRING | WARN | O | Root Level Logger |
Table 3-7 Alarm Service Parameters
| ocnaddalarm.name | STRING | - | ocnaddalarm | M | Application name for Alarm Service |
| logging.type | STRING | - | STDOUT | O | Logging Type Standard Outpuut or JSON Format |
| OCNADD_TRUST_KEYSTORE | BOOLEAN | true/false | true | O | Trust Keystore Enable |
| logging.level.com.oracle.cgbu.cne.ocnadd | STRING | - | INFO | O | Logging level for Alarm OCNADD Service |
| logging.level.com.oracle.cgbu.cne.ocdd | STRING | - | INFO | O | Logging level for Common OCNADD Service |
3.8 Admin Service Parameters
Table 3-8 Admin Service Parameters
| ocnadd.admin.name | STRING | - | ocnaddadminservice | M | Application name admin service |
| Environment Variables | |||||
| OCNADD_ADAPTER_LOG_LEVEL_NETTY | STRING | - | INFO | O | Netty log level |
| OCNADD_ADAPTER_LOG_LEVEL | STRING | - | INFO | O | Adapter service log level |
| OCNADD_ADAPTER_MIN_REPLICAS | INTEGER | - | 2 | M | Minimum Replicas for Adapter |
| OCNADD_ADAPTER_MAX_REPLICAS | INTEGER | - | 8 | M | Max Replicas for Adapter |
| MAX_TCP_CONNECTION_PER_DEST | INTEGER | - | 1 | M | Max allowed TCP connection per destination |
| ADAPTER_KAFKA_FETCH_MAX_BYTES | INTEGER | - | 576720 | O | The maximum amount of data the server should return for a fetch request |
| ADAPTER_KAFKA_MAX_PARTITION_FETCH_BYTES | INTEGER | - | 104857 | O | The maximum amount of data per-partition the server will return |
| ADAPTER_KAFKA_FETCH_MAX_WAIT_MS | INTEGER | - | 40 | O | The maximum amount of time the server will block before answering the fetch request |
| ADAPTER_KAFKA_SESSION_TIME_OUT | INTEGER | - | 15000 | O | The timeout used to detect client failures when using Kafka’s group management facility |
| ADAPTER_KAFKA_HEARTBEAT_INTERVAL_MS | INTEGER | - | 5000 | O | The expected time between heartbeats to the consumer coordinator when using Kafka’s group management facilities |
| ADAPTER_KAFKA_MAX_POLL_INTERVAL_MS | INTEGER | - | 30000 | O | The maximum delay between invocations of poll() when using consumer group management |
| ADAPTER_KAFKA_MAX_POLL_RECORDS | INTEGER | - | 1500 | O | The maximum number of records returned in a single call to poll() |
| ADAPTER_KAFKA_COMMIT_INT_CONFIG | INTEGER | - | 30 | O | The frequency in milliseconds that the consumer offsets are committed to Kafka |
| ADAPTER_KAFKA_NUM_THREADS_CONFIG_HTTP2 | INTEGER | - | 9 | O | The number of threads to run stream processing for http2 connections. |
| ADAPTER_KAFKA_NUM_THREADS_CONFIG_TCP | INTEGER | - | 30 | O | The number of threads to run stream processing for tcp connections. |
| ADAPTER_KAFKA_CONSUMER_POLL_MS | INTEGER | - | 30 | O | The amount of time in milliseconds to block waiting for input. |
| ADAPTER_KAFKA_RECEIVE_BUFFER_BYTES | INTEGER | - | 104857 | M | The size of the TCP receive buffer (SO_RCVBUF) to use when reading data. |
| ADAPTER_WEBCLIENT_TYPE | STRING | - | netty | M | Webclient Type for Adapter Service. |
| OCNADD_ADAPTER_USE_TS | BOOLEAN | true/false | true | M | Parameter to enable trustore use for Adapter. |
| OCNADD_ADAPTER_SERVER_SSL | BOOLEAN | true/false | false | M | Enable Server SSL for Adapter. |
| EGRESS_MAX_CONNECTION_POOL_COUNT | INTEGER | - | 100 | O | Max number of connections per connection pool. |
| EGRESS_SSL_HANDSHAKE_TIMEOUT | INTEGER | - | 40 | O | SSL handshake timeout. |
| EGRESS_SSL_CLOSE_NOTIFY_FLUSH_TIMEOUT | INTEGER | - | 20 | O | HttpClient Notify Flush timeout. |
| EGRESS_SSL_CLOSE_NOTIFY_READ_TIMEOUT | INTEGER | - | 20 | O | HttpClient Notify Read timeout. |
| EGRESS_CLIENT_MAX_INMEMORY | INTEGER | - | 12 | O | Webclient Max In Memory in Mb. |
| EGRESS_JETTY_MAX_CONNECTION_PER_DESTINATION | INTEGER | - | 12 | O | Jetty Max Connection per Destination. |
| EGRESS_JETTY_MAX_REQUEST_PER_DESTINATION | INTEGER | - | 1000 | O | Jetty Max Request per Destination. |
| EGRESS_JETTY_CLIENT_IDLE_TIMEOUT | INTEGER | - | 300000 | O | Jetty client IDLE timeout. |
| EGRESS_JETTY_CLIENT_CONNECT_BLOCKING | BOOLEAN | true/false | false | O | Jetty Client Connection Block Enable. |
| EGRESS_JETTY_CLIENT_CONNECT_TIMEOUT | INTEGER | - | 120000 | O | Jetty Client Connection Timeout. |
| EGRESS_JETTY_CLIENT_STREAM_IDLE_TIMEOUT | INTEGER | - | 300000 | O | Jetty Client Stream IDLE timeout. |
| EGRESS_JETTY_CLIENT_MAX_CONCURR_PUSHED_STREAM | INTEGER | - | 12 | O | Jetty HTTP2 client max concurrent pushed stream. |
| ADAPTER_TCP_CLIENT_MSG_RETRY_MAX_ATTEMPTS | INTEGER | - | 10 | O | Max TCP message retry. |
| ADAPTER_TCP_CLIENT_MSG_RETRY_DELAY | INTEGER | - | 50 | O | TCP Message retry delay. |
| ENABLE_ADAPTER_COUNTER_METRICS | BOOLEAN | true/false | true | O | Enable Adapter Counter Metric. |
| ENABLE_ADAPTER_LATENCY_METRICS | BOOLEAN | true/false | true | O | Enable Adapter Latency Metric. |
| ENABLE_L3L4_COUNTER_METRICS | BOOLEAN | true/false | false | O | Enable L3L4 Metric. |
| OCNADD_EGRESS_NETWORK_ENABLE | BOOLEAN | true/false | false | O | Enable this parameter to true if traffic needs to be routed outside the cluster. |
| OCNADD_EGRESS_NETWORK_KEY | STRING | oracle.com.cnc/egress-network | O | Annotation for egress network support. | |
| OCNADD_EGRESS_NETWORK_NAME_VALUE | STRING | oam | O | Name of the egress network configured in the CNE cluster. | |
| OCNADD_EGRESS_NETWORK_TYPE | STRING | oracle.com.cnc | O | Type of Oracle Network. | |
| OCNADD_CNC_ENABLE | STRING | True | O | Enable oracle.com.cnc network. | |
| ADMIN_SVC_LOGGER_KAFKA | STRING | [ON,OFF] | OFF | O | whether to turn ON or OFF the Kafka Logs in Admin Service. |
| ADMIN_SVC_ROOT_LOGGER | STRING | WARN | O | Logger Level for Admin Service. | |
| OCNADD_ADMIN_SVC_LIVENESS_DELAY | INTEGER | 60 | M | Admin Svc Liveness Param: this field tells the kubelet that it should wait for mentioned seconds before performing the first probe. | |
| OCNADD_ADMIN_SVC_LIVENESS_PERIOD_SECONDS | INTEGER | 15 | M | Admin Svc Liveness Param: this field specifies that the kubelet should perform a liveness probe every given no of seconds. | |
| OCNADD_ADMIN_SVC_LIVENESS_FAILURE | INTEGER | 5 | M | Admin Svc Liveness Param: For the case of a liveness probe, triggers a restart for that specific container if the container failed to start for given no of failure retries. | |
| OCNADD_ADMIN_SVC_LIVENESS_TIMEOUT | INTEGER | 20 | M | Admin Svc Liveness Param: Number of seconds after which the probe times out. | |
| ADAPTER_LOG_LEVEL_ROOT | STRING | WARN | O | Logger Level for Adapter Service | |
| ADAPTER_LOG_LEVEL_KAFKA | STRING | [ON,OFF] | OFF | O | Whether to ON or OFF Kafka logs in Adapter Service. |
| OCNADD_ADAPTER_MAX_REPLICAS_TCP | INTEGER | 2 | O | MAX replicas for synthetic Adapter. | |
| OCNADD_ADAPTER_LIVENESS_DELAY | INTEGER | 60 | M | Adapter Svc Liveness Param: this field tells the kubelet that it should wait for mentioned seconds before performing the first probe. | |
| OCNADD_ADAPTER_LIVENESS_PERIOD_SECONDS | INTEGER | 15 | M | Adapter Svc Liveness Param: this field specifies that the kubelet should perform a liveness probe every given number of seconds. | |
| OCNADD_ADAPTER_LIVENESS_FAILURE | INTEGER | 5 | M | Adapter Svc Liveness Param: For the case of a liveness probe, triggers a restart for that specific container if the container failed to start for given number of failure retries. | |
| OCNADD_ADAPTER_LIVENESS_TIMEOUT | INTEGER | 20 | M | Adapter Svc Liveness Param: Number of seconds after which the probe times out. | |
| ADAPTER_PREVIOUS_KAFKA_THREAD_TCP | INTEGER | 1 | M | Kafka Thread for TCP feed in 23.1.0 release. | |
| CONFIG_SVC_DATASTREAM_OFFSET_RETRY | INTEGER | 10 | O | Retries to get data stream offset from config service in case of failure. | |
| CONFIG_SVC_DATASTREAM_OFFSET_DELAY_MS | INTEGER | 3000 | O | Delay in milliseconds between Retries to fetch the data stream offset from config service in case of failure. | |
| ADAPTER_KAFKA_LISTCONSUMER_TIMEOUT_MS | INTEGER | 30000 | O | Timeout in milliseconds to list the Consumer Groups. | |
| ADAPTER_KAFKA_CONSUMERGROUP_RETRY_DELAY_SEC | INTEGER | 25 | O | Delay in milliseconds between Retries to fetch the Consumer Groups from Kafka brokers. | |
| ADAPTER_KAFKA_CONSUMERGROUP_RETRY_COUNT | INTEGER | 10 | O | Retries to get the Consumer Groups from Kafka brokers in case of failure. | |
| KAFKA_TOPIC_NO_OF_PARTITIONS | INTEGER | 10 | O | Default number of partitions that will be created for a topic when a new Kafka feed is created. | |
| KAFKA_TOPIC_REPLICATION_FACTOR | INTEGER | 1 | O | Replication Factor for the Kafka Topic of Kafka Feed. | |
| KAFKA_TOPIC_RETENTION_MS | INTEGER | 300000 | O | Retention Time for Kafka Topic. | |
| EXTERNAL_CONSUMER_SASL_PORT | INTEGER | 9094 | O | Kafka bootstrap server port number for SASL_SSL protocol. | |
| KAFKA_FUTURE_TIMEOUT_MS | INTEGER | 25000 | O | Timeout to fetch the admin client response details. | |
| VERIFY_KAFKA_CONNECTION_TIMEOUT_MS | INTEGER | 10000 | O | Timeout to verify Kafka connection in milliseconds. | |
| KAFKAFEED_METRICS_SCHEDULED | BOOLEAN | true | O | To enable or disable metrics for Kafka Feeds. | |
| KAFKAFEED_METRICS_TIMER | INTEGER | 15000 | O | Metrics timer for Kafka Feeds. | |
| TCP_STREAM_RESET_ENABLED | BOOLEAN | false | O | To enable Kafka feed stream restart. This maybe required only when third-party consumer is not working properly and frequently breaks connections with Synthetic Feed | |
| TCP_STREAM_RESET_ELAPSED_TIME | INTEGER | 60 | O | The time in minutes to check if stream reset is required. | |
| TCP_STREAM_RESET_FIXED_DELAY_MS | INTEGER | 300000 | O | Default scheduler interval time is 30 minutes. | |
| TCP_STREAM_RESET_INI_DELAY_MS | INTEGER | 150000 | O | Default scheduler initial delay to start is 30 minutes. |
3.8.1 Correlation Service Parameters
All the Correlation parameters are available under
ocnaddadminsvc.correlation section in ocnadd-custom-values-25.1.100.yaml file.
Table 3-9 Correlation Service Parameters
| name | STRING | - | ocnaddcorrelation | M | name of the service |
| resources.limits.cpu | INTEGER | - | 3 | M | Number of maximum CPUs for each Correlation instance |
| resources.limits.memory | STRING | - | 64Gi | M | Max Memory limit for each Correlation instance |
| resources.limits.ephemeralstorage | STRING | - | 400Mi | M | Ephemeral Storage for each Correlation instance |
| resources.requests.cpu | INTEGER | - | 3 | M | Minimum number of CPUs required for each Correlation instance |
| resources.requests.memory | STRING | - | 64Gi | M | minimum Memory required for each Correlation instance |
| resources.requests.ephemeralstorage | STRING | - | 400Mi | M | minimum Ephemeral Storage required for each Correlation instance |
Environmental variables for
Correlation service are declared under
"ocnaddadminsvc.correlation.env"
section |
| OCNADD_CORRELATION_SVC_LIVENESS_DELAY | INTEGER | - | 60 | O | This field tells the kubelet that it should wait for mentioned seconds before performing the first probe |
| OCNADD_CORRELATION_SVC_LIVENESS_PERIOD_SECONDS | INTEGER | - | 15 | O | This field specifies that the kubelet should perform a liveness probe every given number of seconds. |
| OCNADD_CORRELATION_SVC_LIVENESS_FAILURE | INTEGER | - | 5 | O | For the case of a liveness probe, triggers a restart for that specific container if the container failed to start for given number of failure retries. |
| OCNADD_CORRELATION_SVC_LIVENESS_TIMEOUT | INTEGER | - | 20 | O | Number of seconds after which the probe times out. |
| OCNADD_CORRELATION_NAME | STRING | - | ocnaddcorrelation | M | correlation service name which will be replaced by the admin service while creating correlation configuration with new name |
| ADMIN_CORRELATION_RESOURCE_FILE | STRING | - | /tmp/ocnadd/deploy/ocnaddcorrelationservice.yaml | M | Template file for deploying correlation service through admin service. |
| OCNADD_CORRELATION_ACTIVE_PROFILE | STRING | [prod,dev] | prod | M | profile with dev or production parameters |
| OCNADD_CORRELATION_SERVER_PORT | INTEGER | - | 9664 | M | port number for correlation service |
| OCNADD_CORRELATION_HTTP2_ENABLED | BOOLEAN | [true/false] | true | M | enable or disable http2 |
| OCNADD_TRUST_CLIENT_KEY_TYPE | STRING | - | PKCS12 | M | trustore client key Type |
| KAFKA_STREAM_STATE | STRING | - | /tmp/ocnadd/kafka/state | O | temporary storage for kafka state store |
| KAFKA_REPLICATION_FACTOR | INTEGER | - | 1 | O | replication factor for state store |
| KAFKA_ENABLE_AUTO_COMMIT | BOOLEAN | [true/false] | false | O | enable or disable kafka auto commit |
| KAFKA_SOCKET_BYTES_BUFFER_PORTION | INTEGER | - | 100 | O | This parameter is used to multiply with KAFKA_SOCKET_BYTES_BUFFER |
| KAFKA_FETCH_MIN_BYTES | INTEGER | - | 1 | O | The minimum amount of data per-partition the server will return |
| KAFKA_FETCH_MAX_BYTES_PORTION | INTEGER | - | 100 | O | This parameter is used to multiply with KAFKA_FETCH_MAX_BYTES |
| KAFKA_MAX_PARTITIONS_FETCH_BYTES_PORTION | INTEGER | - | 10 | O | This parameter is used to multiply with KAFKA_MAX_PARTITIONS_FETCH_BYTES |
| MAX_POLL_RECORDS | INTEGER | - | 500 | O | The maximum number of records returned in a single call to poll() |
| KAFKA_OFFSET_CONFIG | STRING | - | latest | O | default kafka data stream offset config |
| KAFKA_AUTOCOMMIT_INT_CONFIG | INTEGER | - | 50 | O | It specifies how often the consumer commits its current position, which can be useful for ensuring message processing progress. |
| KAFKA_COMMIT_INT_CONFIG | INTEGER | - | 50 | O | this property will configure the interval at which Kafka consumer commits offsets. |
| KAFKA_NUMBER_THREADS_CONFIG | INTEGER | - | 6 | O | this property is used to configure the number of threads or consumers that Kafka Streams or Kafka consumers will use for processing messages |
| KAFKA_MAX_AGE_CONFIG | INTEGER | - | 7500 | O | This property will be used to set a maximum age for Kafka consumer records |
| KAFKA_CONSUMER_STRATEGY | STRING | - | org.apache.kafka.clients.consumer.RoundRobinAssignor | O | This property will be used to the strategy used for partition assignment when consuming messages from Kafka topics |
| PRODUCERS_ACKNOWLEDGMENTS | INTEGER | - | 1 | O | producer acknowledgments |
| INTERNAL_LEAVE_GROUP_ON_CLOSE | BOOLEAN | [true/false] | true | O | this property controls whether the Kafka Streams application should actively leave the consumer group when it is closed or whether it should rely on the group coordinator to remove it when it becomes unresponsive |
| OCNADD_CORRELATION_HEALTH_RETRY_COUNT | INTEGER | - | 3 | O | No of times the correlation service retries for health registration in case of failure |
| OCNADD_CORRELATION_HEALTH_RETRY_DELAY | INTEGER | - | 10 | O | delay between the each retry for health registration |
| OCNADD_CORRELATION_HEALTH_HB_TIMER | INTEGER | - | 120000 | O | heart beat timer for health check |
| OCNADD_KAFKA_SSL_PROTOCOL | STRING | - | TLSv1.3 | O | SSL Protocol version |
| OCNADD_KAFKA_SECURITY_PROTOCOL_SASL | STRING | - | SASL_SSL | O | describes SASL_SSL kafka security Protocol |
| OCNADD_KAFKA_SECURITY_PROTOCOL_SSL | STRING | - | SSL | O | describes SSL kafka security Protocol |
| OCNADD_KAFKA_SASL_MECHANISM | STRING | - | PLAIN | O | describes SASL SCRAM mechanism |
| OCNADD_KAFKA_SASL_JAAS_USERNAME | STRING | - | ocnadd | O | kafka default jaas username present |
| OCNADD_KAFKA_SASL_JAAS_MODULE | STRING | - | org.apache.kafka.common.security.plain.PlainLoginModule | O | kafka Login module |
| OCNADD_KAFKA_JAAS_SECRET_KEY | STRING | - | jaas_password | O | jaas password for kafka authentication taken from the jaas-secret with this key |
| OCNADD_KAFKA_JASS_SECRET_NAME | STRING | - | jaas-secret | O | jaas-secret name |
| CORRELATION_LOG_LEVEL_KAFKA | STRING | [ON,OFF] | OFF | O | Kafka Streams Log Level |
| OCNADD_CORRELATION_LOG_ROOT | STRING | - | WARN | O | root log level |
| OCNADD_CORRELATION_LOG_NETTY | STRING | - | INFO | O | netty log level |
| logging.level.com.oracle.cgbu.cne.ocnadd | STRING | - | INFO | O | ocnadd package log level |
| logging.level.com.oracle.cgbu.cne.ocdd | STRING | - | INFO | O | ocdd package log level |
| OCNADD_TRUST_KEYSTORE | BOOLEAN | - | true | O | Enable to secure connection via OCWeb Client. |
| KAFKASTREAMS_PUNCTUATOR_TIMER | INTEGER | - | 2000 | O | Kafka Stream Scheduler Timer to loop through the Local cache for Timer Expiry Scenario |
3.8.2 Storage Adapter Service Parameters
All the Storage Adapter Service parameters are available under
ocnaddadminsvc.storageadapter section in ocnadd-custom-values-25.1.100.yaml file.
Table 3-10 Storage Adapter Service Parameters
| name | STRING | - | ocnaddstorageadapter | M | Name of the service |
| resources.limits.cpu | INTEGER | - | 3 | M | Number of maximum CPUs for each storage adapter instance. |
| resources.limits.memory | STRING | - | 64Gi | M | Maximum memory limit for each storage adapter instance. |
| resources.limits.ephemeralstorage | STRING | - | 400Mi | M | Ephemeral storage for each storage adapter instance. |
| resources.requests.cpu | INTEGER | - | 3 | M | Minimum number of CPUs required for each storage adapter instance. |
| resources.requests.memory | STRING | - | 64Gi | M | Minimum memory required for each storage adapter instance. |
| resources.requests.ephemeralstorage | STRING | - | 400Mi | M | Minimum ephemeral storage required for each storage adapter instance. |
Environmental variables for Storage
Adapter service are declared under
"ocnaddadminsvc.storageadapter.env"
section |
| OCNADD_STORAGE_ADAPTER_HTTP2_ENABLED | BOOLEAN | [true,false] | true | M | The flag to indicate if HTTP2 should be used or not. Default is true. |
| KAFKA_SOCKET_BYTES_BUFFER | INTEGER | - | 104857 | O | Kafka Socket Buffer setting for consumer. |
| KAFKA_FETCH_MIN_BYTES | INTEGER | - | 1 | O | The minimum amount of data per partition the server will return. |
| KAFKA_MAX_PARTITIONS_FETCH_BYTES | INTEGER | - | 104858 | O | The maximum amount of data per partition the server will return. |
| FETCH_MAX_WAIT_MS | INTEGER | - | 100 | O | The maximum amount of time the server will block before answering the fetch request if there is not sufficient data to immediately satisfy the requirement given by fetch.min.bytes. |
| SESSION_TIME_OUT | INTEGER | - | 90000 | O | The timeout used to detect client failures when using Kafka’s group management facility. |
| HEARTBEAT_INTERVAL_MS | INTEGER | - | 30000 | O | The expected time between heartbeats to the consumer coordinator when using Kafka’s group management facilities. |
| MAX_POLL_INTERVAL_MS | INTEGER | - | 240000 | O | The maximum delay between invocations of poll() when using consumer group management. |
| MAX_POLL_RECORDS | INTEGER | - | 900 | O | The maximum number of records returned in a single call to poll(). |
| KAFKA_OFFSET_CONFIG | STRING | - | latest | O | Default Kafka data stream offset configuration. |
| KAFKA_NUMBER_THREADS_CONFIG | INTEGER | - | 6 | O | This property is used to configure the number of threads or consumers that Kafka streams or Kafka consumers will use for processing messages. |
| PRODUCERS_ACKNOWLEDGMENTS | INTEGER | - | 0 | O |
The parameter determines if the producer needs to wait for acknowledgment from the Kafka cluster or not. After sending data, the producer waits for acknowledgment, and if it is not received, the producer resends the data.
| CONSUMER_POLL_MS | INTEGER | - | 50 | O | Polling time in ms for consumer. |
| BATCH_SIZE | INTEGER | - | 75000 | O | The maximum amount of data to be collected before sending the batch. |
| STORAGE_ADAPTER_LOG_LEVEL_KAFKA | STRING | - | OFF | O | Kafka log level |
| OCNADD_STORAGE_ADAPTER_LOG_ROOT | STRING | - | WARN | O | Root log level |
| OCNADD_STORAGE_ADAPTER_LOG_NETTY | STRING | - | INFO | O | Netty log level |
3.8.3 Ingress Adapter Service Parameters
All the Ingress Adapter Service parameters are available under
ocnaddadminsvc.ingressadapter section in ocnadd-custom-values-25.1.100.yaml file.
Table 3-11 Ingress Adapter Service Parameters
| name | STRING | - | ocnaddingressadapter | M | Name of the service |
| resources.limits.cpu | INTEGER | - | 3 | M | Number of maximum CPUs for each ingress adapter instance. |
| resources.limits.memory | STRING | - | 64Gi | M | Max Memory limit for each ingress adapter instance. |
| resources.limits.ephemeralstorage | STRING | - | 400Mi | M | Ephemeral Storage for each ingress adapter instance. |
| resources.requests.cpu | INTEGER | - | 3 | M | Minimum number of CPUs required for each ingress adapter instance. |
| resources.requests.memory | STRING | - | 64Gi | M | Minimum Memory required for each ingress adapter instance. |
| resources.requests.ephemeralstorage | STRING | - | 400Mi | M | Minimum Ephemeral Storage required for each ingress adapter instance. |
Environmental variables for Ingress
"ocnaddadminsvc.ingressadapter.env"
section |
| INGRESS_ADAPTER_PORT | INTEGER | - | 9188 | M | The port of the ingress adapter service. |
| INGRESS_ADAPTER_SERVICE_NAME | STRING | - | ocnaddingressadapter | M | Name of the service |
| OCNADD_TRUST_KEYSTORE | BOOLEAN | - | true | O | Enable to secure connection using OCWeb Client. |
| OCNADD_TRUST_CLIENT_KEY_TYPE | STRING | - | PKCS12 | M | Trust store client key Type |
| OCWEBCLIENT_TIMEOUT | INTEGER | - | 60 | Webclient timeout | |
| OCWBCLIENT_CHANNEL_TIMEOUT | INTEGER | - | 60 | O | Webclient channel timeout |
| OCWEBCLIENT_SSL_HANDSHAKE_TIMEOUT | INTEGER | - | 30 | O | SSL handshake timeout |
| OCWEBCLIENT_SSL_FLUSH_TIMEOUT | INTEGER | - | 10 | O | SSL flush timeout |
| OCWEBCLIENT_SSL_READ_TIMEOUT | INTEGER | - | 10 | O | SSL read timeout |
| INGRESS_ADAPTER_LOG_LEVEL_ROOT | STRING | - | OFF | O | Kafka log level |
| INGRESS_ADAPTER_NETTY_LOG_LEVEL | STRING | - | WARN | O | Root log level |
| INGRESS_ADAPTER_LOG_LEVEL_KAFKA | STRING | - | INFO | O | netty log level |
| INGRESS_ADAPTER_LOG_FILENAME | STRING | - | ingress-adapter.log | O | The log file name |
| OCNADD_CONSUMER_ADAPTER_HEALTH_RETRY_COUNT | INTEGER | - | 3 | O | The number of retries with the health service. |
| OCNADD_CONSUMER_ADAPTER_HEALTH_RETRY_DELAY | INTEGER | - | 10 | O | The time interval in sec between successive retries with the health service. |
| INGRESS_ADAPTER_HEALTH_HB_TIMER | INTEGER | - | 120000 | O | The heartbeat timer with the health service |
| INGRESS_ADAPTER_HTTP2_ENABLED | BOOLEAN | [true,false] | true | O | The flag to indicate if http2 should be used or not |
| INGRESS_ADAPTER_SSL_ENABLED | BOOLEAN | [true,false] | true | O | The flag to indicate if TLS should be used or not |
| INGRESS_ADAPTER_CLIENT_AUTH_CONFIG | STRING | - | want | O | Parameter to check client authentication |
| INGRESS_ADAPTER_KEYSTORE_TYPE | STRING | - | PKCS12 | M | Trust store client key Type |
| INGRESS_ADAPTER_TRUSTSTORE_TYPE | STRING | - | PKCS12 | M | Trust store key Type |
| INGRESS_HTTPSERVER_ROUTE_PATH | STRING | - | /ocnadd-nonoraclenf/v1/streaming | M | The URL at which the client should stream the data towards ingress adapter. |
| INGRESS_HTTPSERVER_READ_TIMEOUT_MS | INTEGER | - | 30000 | O | The ingress adapter read timeout in milliseconds |
| INGRESS_HTTPSERVER_REQUEST_TIMEOUT_MS | INTEGER | - | 30000 | O | The ingress adapter request timeout in milliseconds |
| INGRESS_HTTPSERVER_CONNECT_TIMEOUT_MS | INTEGER | - | 60000 | O | The ingress adapter connect timeout in milliseconds |
| INGRESS_HTTPSERVER_IDLE_TIMEOUT_MS | INTEGER | - | 120000 | O | The ingress adapter idle timeout in milliseconds |
| INGRESS_HTTPSERVER_SOCKET_RECEIVE_BUF | INTEGER | - | 10485 | O | The socket receive buffer size |
| INGRESS_HTTPSERVER_SOCKET_RECEIVE_BUF_PORTION | INTEGER | - | 100 | O | The socket receive buffer size multiple factor. The actual read buffer bytes will be ( INGRESS_HTTPSERVER_SOCKET_RECEIVE_BUF * INGRESS_HTTPSERVER_SOCKET_RECEIVE_BUF_PORTION) |
| INGRESS_HTTPSERVER_SOCKET_TIMEOUT_MS | INTEGER | - | 60000 | O | The ingress adapter socket timeout in milliseconds |
| INGRESS_HTTPSERVER_SOCKET_KEEPALIVE | BOOLEAN | [true,false] | true | O | The flag to indicate if keepalive should be used in the connection |
| INGRESS_HTTPSERVER_CLOSE_NOTIFY_FLUSH_TIIMEOUT_MS | INTEGER | - | 30000 | O | Notification flush timeout in milliseconds |
| INGRESS_HTTPSERVER_CLOSE_NOTIFY_READ_TIIMEOUT_MS | INTEGER | - | 30000 | O | Notification read timeout in milliseconds |
| INGRESS_HTTPSERVER_SSL_HANDSHAKE_TIMEOUT_MS | INTEGER | - | 30000 | O | SSL handshake timeout in milliseconds |
| KAFKA_SECURITY_PROTOCOL | STRING | - | PLAINTEXT | O | Describes kafka security Protocol |
| INGRESS_ADAPTER_SECURITY_PROTOCOL | STRING | - | SSL | O | Describes ingress adapter security Protocol |
| KAFKA_SSL_PROTOCOL | STRING | - | TLSv1.2 | O | SSL Protocol version |
| KAFKA_SASL_ENABLED | BOOLEAN | [true,false] | false | O | The flag to indicate if SASL is used for the authentication |
| KAFKA_JAAS_CONFIG_MODULE | STRING | - | org.apache.kafka.common.security.plain.PlainLoginModule | O | Kafka Login module |
| KAFKA_JAAS_CONFIG_USER | STRING | - | username | O | Kafka default jaas username |
| KAFKA_JAAS_CONFIG_PASS | STRING | - | secret | O | Kafka default jaas password |
| KAFKA_SASL_MECHANISM | STRING | - | PLAIN | O | Describes SASL SCRAM mechanism |
| externalAccess.enabled | BOOLEAN | [true,false] | false | O | The flag to indicate if external access is enabled for the ingress adapter |
| externalAccess.staticLoadBalancerIp | STRING | - | 10.10.10.1 | O | Default static loadbalancer IP address |
3.9 Kafka Configuration Parameters
Table 3-12 Kafka Configuration Parameters
| Parameter Name | Data Type | Range | Default Value | Mandatory(M)/ Optional(O)/ Conditional(C) | Description |
| kafkaBroker.kafkaProperties.logdirs | String | - | /kafka/logdir/kafka-logs | M | The path to store the kafka logs |
| kafkaBroker.name | String | kafka-broker | Name of the kafka broker | ||
| kafkaBroker.replicas | Int | 4 | The number of replicas that should be available for the pod. | ||
| kafkaBroker.pvcClaimSize | String | 10Gi | M | Size of Block Volume to attach to kafka. | |
| target.averageCpuUtilPercentage | Int | 50 | The target average CPU utilization percentage. | ||
| target.memoryUtilPercentage | Int | 80 | The target average memory utilization percentage. | ||
| kafkaBroker.resource.limits.cpu | Int | 5 | The maximum limit for the number of CPUs used for the container. | ||
| kafkaBroker.resource.limits.memory | String | 24Gi | The maximum limit for the size of the memory used for the container. | ||
| kafkaBroker.kafkaProperties.logRetentionMinutes | Int | 5 | M | Log Retention Time of Topic Data in Minutes. | |
| kafkaBroker.kafkaProperties.kafkaSslProtocol | String | TLSv1.2,TLSv1.3 | M | TLS version supported. | |
| kafkaBroker.kafkaProperties.socketSendBufferBytes | Int | 10485760 | M | TCP socket buffer sizes for the producer. | |
| kafkaBroker.kafkaProperties.socketReceiveBufferBytes | Int | 10485760 | M | TCP socket buffer sizes for the consumer. | |
| kafkaBroker.kafkaProperties.socketRequestMaxBytes | Int | 104857600 | M | The maximum number of bytes in a socket request. | |
| kafkaBroker.kafkaProperties.queuedMaxRequests | Int | 4096 | M | Number of concurrent connections. | |
| kafkaBroker.kafkaProperties.numIoThreads | Int | 820 | M | Number of threads that pick up requests from the request queue to process them. | |
| kafkaBroker.kafkaProperties.numNetworkThreads | Int | 820 | M | Network threads handle requests to the Kafka cluster, such as produce and fetch requests from client applications. | |
| kafkaBroker.kafkaProperties.numReplicaFetchers | Int | 640 | M | Number of fetcher threads used to replicate records from each source broker. | |
| kafkaBroker.kafkaProperties.backgroundThreads | Int | 256 | M | The number of threads to use for various background processing tasks. | |
| kafkaBroker.kafkaProperties.replicaFetchMinBytes | Int | 619200 | M | Minimum bytes expected for each fetch response. | |
| kafkaBroker.kafkaProperties.replicaFetchMaxBytes | Int | 37152000 | M | The maximum number of bytes we will return for a fetch request. | |
| kafkaBroker.kafkaProperties.replicaFetchWaitMaxMs | Int | 50 | M | The maximum wait time for each fetcher request issued by follower replicas. | |
| kafkaBroker.kafkaProperties.replicaSocketReceiveBufferBytes | Int | 10485760 | M | The socket receive buffer for network requests. | |
| kafkaBroker.kafkaProperties.offsetsTopicReplicationFactor | Int | 3 | M | The replication factor for the offsets topic (set higher to ensure availability). Internal topic creation will fail until the cluster size meets this replication factor requirement. | |
| kafkaBroker.kafkaProperties.transactionStateLogReplicationFactor | Int | 3 | M | The replication factor for the transaction topic (set higher to ensure availability). Internal topic creation will fail until the cluster size meets this replication factor requirement. | |
| kafkaBroker.externalAccess.enabled | Boolean | false | M | Flag to enable External access for Kafka. | |
| kafkaBroker.externalAccess.autoDiscovery | Boolean | false | M | Flag to enable auto-discovery of LoadBalancer IPs. | |
| kafkaBroker.externalAccess.type | String | LoadBalancer | M | Service Type of Kafka Broker. | |
| kafkaBroker.externalAccess.setstaticLoadBalancerIps | Boolean | false | M | Setting Static LoadBalancer IPs. | |
| kafkaBroker.externalAccess.LoadBalancerIPList | List | [ ] | C | List if LoadBalancer Static IP available for use. |
3.10 UI Router Parameters
Listed below are the UI Router Parameters:
Table 3-13 UI Router Parameters
| ocnadduirouter.name | String | ocnadduirouter | M | The express application name for ocnadduirouter. | |
| Router_host | String | http://localhost | M | The Router host contains uirouter service endpoint and value of this variable can be service name, node IP, and Load Balancer IP. | |
| Router_port | String | 8080 | M | The ocnadduirouter service has exposed this specified port and this port can be used to access specific router service. | |
| DD_UIAPI | String | http://ocnaddgui:80 | M | The target endpoint of ocnaddgui service and use to configure the GUI. | |
| DD_CONFIG_API | String | http://ocnaddconfiguration:12590 | M | Target endpoint of the configuration service used to route the GUI request and forward the response. | |
| DD_ALARM_API | String | http://ocnaddalarm:9099 | M | Target endpoint of the Alarm service used to route the GUI request and forward the response. | |
| DD_HEALTH_API | String | http://ocnaddhealthmonitoring:12591 | M | Target endpoint of the Health Monitoring service used to route the GUI request and forward the response. | |
| PROMETHEUS_API | String | http://occne-kube-prom-stack-kube-prometheus.occne-infra.svc.ocnadd:80 | M | Target endpoint of the Prometheus service used to route the GUI request and forward the response.
Note: Update this parameter based on the setup. |
| DD_PROMETHEUS_PATH | String | /blurr8/prometheus/api/v1/query_range | M | The Prometheus endpoint API URL path.
3.11 Filter Service Parameters
Filter Service Parameters are present under ocnaddfilter section in ocnadd-custom-values-25.1.100.yaml file.
Table 3-14 Filter Service Parameters
| Parameter Name | Data Type | Range | Default Value | Mandatory(M)/Optional(O)/Conditional(C) | Description |
| name | String | - | ocnaddfilter | M | Name of the Service. |
| maxReplicas | INTEGER | - | 3 | M | number of Replicas of Filter Service |
| resources.limits.cpu | INTEGER | - | 2 | M | Number of maximum CPUs for each Filter service instance |
| resources.limits.memory | String | - | 3Gi | M | Max Memory limit for each Filter service instance |
| resources.limits.ephemeralstorage | String | - | 500Mi | M | Ephemeral Storage for each Filter service instance |
| resources.requests.cpu | INTEGER | - | 2 | M | Minimum number of CPUs required for each Filter service instance |
| resources.requests.memory | String | - | 3Gi | M | minimum Memory required for each Filter service instance |
| resources.requests.ephemeralstorage | String | - | 500Mi | M | minimum Ephemeral Storage required for each Filter service instance |
| Environmental variables are present under section "ocnaddfilter.env" | |||||
| OCNADD_TRUST_KEYSTORE | BOOLEAN | [true/false] | true | O | Enable to secure connection via OCWeb Client. |
| ENABLE_FILTER_METRICS | BOOLEAN | [true/false] | true | O | To enable/disable filter metrics |
| KAFKA_PRODUCER_SSL_PROTOCOL | STRING | - | TLSv1.3 | O | kafka SSL protocol version |
| KAFKA_PRODUCER_SSL_CLIENT_AUTH | BOOLEAN | [true/false] | false | O | whether kafka producer client auth is required or not |
| KAFKA_PRODUCER_SASL_MECHANISM | STRING | [PLAIN,SCRAM-SHA-256,SCRAM-SHA-512] | PLAIN | O | kafka SASL scram mechanism |
| KAFKA_PRODUCER_SECURITY_PROTOCOL | STRING | - | PLAINTEXT | O | kafka authentication method |
| KAFKA_MAX_AGE_CONFIG | INTEGER | - | 7500 | O | The period of time in milliseconds after which we force a refresh of metadata. |
| MAX_POLL_RECORDS | INTEGER | - | 900 | O | The maximum number of records returned in a single call to poll() |
| TRANSACTION_FILTER | BOOLEAN | [true/false] | true | O | To enable or disable transaction filtering |
| KAFKA_SOCKET_BYTES_BUFFER_PORTION | INTEGER | - | 100 | O | This parameter is used for multiplying with KAFKA_SOCKET_BYTES_BUFFER |
| FILTER_KAFKA_PARTITIONER_STRATEGY | STRING | [key/custom/roundrobin] | key | O | Kafka record partitioner strategy |
3.12 Redundancy Agent Service Parameters
Table 3-15 Redundancy Agent Service Parameter
| name | STRING | - | ocnaddredundancyagent | M | Name of service. |
| autoScaling.enabled | BOOLEAN | true/false | false | M | Allow HorizontalAutoScalar of
ocnaddredundancy pods.
| minReplicas | INTEGER | - | 1 | C | Number of minimum replicas for HPA. |
| maxReplicas | INTEGER | - | 1 | C | Number of maximum replicas for HPA. |
| resources.limit.cpu | INTEGER | - | 2 | M | Maximum number of CPU for each pod. |
| resources.limits.memory | STRING | 1Gi | M | Maximum memory limit for each service instance. | |
| resources.limits.ephemeralstorage | STRING | 500Mi | M | Ephemeral storage for each service instance. | |
| resources.requests.cpu | INTEGER | 2 | M | Minimum number of CPUs required for each service instance. | |
| resources.requests.memory | STRING | 1Gi | M | Minimum memory required for each service instance. | |
| resources.requests.ephemeralstorage | STRING | 500Mi | M | Minimum ephemeral storage required for each service instance. | |
| resources.target.averageCpuUtilsPercentage | INTEGER | - | 85 | C | Threshold set for Pod AutoScalar. |
| Environmental variables are present under section ocnaddredundancyagent.env | |||||
| OCNADD_REDUNDANCY_HB_INTERVAL | INTEGER | - | 10 | O | Interval of heartbeat requests sent to primary agent by secondary agent. |
| OCNADD_REDUNDANCY_HB_MISSING | INTEGER | 3 | O | Max unsuccessful heartbeat in case of secondary agent or max missing heartbeat in case of primary agent. | |
| OCNADD_REDUNDANCY_KAFKA_DELAY_MS | INTEGER | 2000 | O | Delay before starting periodic Kafka ingress traffic rate. | |
| OCNADD_REDUNDANCY_KAFKA_INTERVAL_MS | INTEGER | 500 | O | Interval of periodic Kafka ingress traffic check, will switch mode of secondary agent if change is required during the check. | |
| OCNADD_REDUNDANCY_HEALTH_RETRY_COUNT | INTEGER | 10 | O | Number of retries for Health registration. | |
| OCNADD_REDUNDANCY_HEALTH_RETRY_DELAY | INTEGER | 15 | O | Delay between each retries for Health Registration. | |
| OCNADD_REDUNDANCY_HEALTH_HB_TIMER | INTEGER | 120000 | O | Heart Beat Timer interval to health monitoring service. | |
| OCNADD_REDUNDANCY_HEALTH_SVC_TYPE | STRING | REDUNDANCY | O | Health Registration name for REDUNDANCY agent. | |
3.13 Export Service Parameters
Table 3-16 Export Service Parameters
| name | STRING | - | ocnaddexport | M | Name of service |
| autoScaling.enabled | BOOLEAN | true/false | false | M | Allow HorizontalAutoScalar of ocnaddexport service pods. |
| maxReplicas | INTEGER | - | 2 | C | Number of maximum replicas for HPA. |
| resources.limit.cpu | INTEGER | - | 4 | M | Max number of cpu for each pod. |
| resources.limits.memory | STRING | - | 64Gi | M | Max memory limit for each service instance. |
| resources.limits.ephemeralstorage | STRING | - | 2Gi | M | Ephemeral storage for each service instance. |
| resources.requests.cpu | INTEGER | - | 2 | M | Minimum number of CPUs required for each service instance. |
| resources.requests.memory | STRING | - | 4Gi | M | Minimum memory required for each service instance. |
| resources.requests.ephemeralstorage | STRING | - | 100Mi | M | Minimum ephemeral storage required for each service instance. |
| Environmental variables are present under section ocnaddexport.env | |||||
| EXPORT_WEB_LOG_LEVEL | STRING | - | INFO | O | Export service application log level |
| EXPORT_BLOCKINGQUEUE_SIZE | INTEGER | - | 10 | O | The queue size to store the result set from the database for the export. |
| EXPORT_SEQUENCING | BOOLEAN | true,false | true | O | The parameter to decide if the result set needs to be in sequence based on the record timestamp or not. |
3.14 Helm Parameter Configuration for OCCM
Table 3-17 Helm Parameter Configuration for OCCM
| global.certificates.occm.enabled | BOOLEAN | true/false | false | M | Whether to use OCCM for creating services. |
| global.certificates.occm.issuer | STRING | - | CA1 | M | Name of the Issuer configured in OCCM to use to create certificate |
| global.certificates.occm.renewBefore | INTEGER | - | 14 | M | Number of days before expiry, before which OCCM will automatically update the certificates |
| global.certificates.occm.days | INTEGER | - | 90 | M | Number of days for which certificates will be valid |
| global.certificates.occm.cncc.cncc_iam_ingress_gateway.external_ip | STRING | - | - | M | Load balancer IP address of CNCC IAM Ingress Gateway Service |
| global.certificates.occm.cncc.cncc_iam_ingress_gateway.port | INTEGER | - | 80 | M | Port of CNCC IAM Ingress Gateway Service |
| global.certificates.occm.cncc.cncc_mcore_ingress_gateway.external_ip | STRING | - | - | M | Load balancer IP address of CNCC MCORE Ingress Gateway Service |
| global.certificates.occm.cncc.cncc_mcore_ingress_gateway.port | INTEGER | - | 80 | M | Port of CNCC MCORE Ingress Gateway Service |
| global.certificates.occm.cncc.cnccId | STRING | - | Cluster1 | M | ID of CNCC owner of OCCM instance |
| global.certificates.occm.cncc.occm_cncc_instance_id | STRING | - | Cluster1-occm-instance1 | M | OCCM instance ID |
| global.certificates.occm.subject.country | STRING | - | - | M | Specify the country field (C) in DN for each certificate |
| global.certificates.occm.subject.state | STRING | - | - | M | Specify the state field (S) in DN for each certificate |
| global.certificates.occm.subject.location | STRING | - | - | M | Specify the location field (L) in DN for each certificate |
| global.certificates.occm.subject.organization | STRING | - | - | M | Specify the organization field (O) in DN for each certificate |
| global.certificates.occm.subject.country.organizationUnit | STRING | - | - | M | Specify the organization unit field (OU) in DN for each certificate |
| global.certificates.occm.occm_cacert | STRING | - | occm-ca-secret | O | Name of the Secret storing CA certificate/certificate chain. |
| global.certificates.occm.truststore_keystore_secret | STRING | - | occm-truststore-keystore-secret | O | Name of the Secret storing truststore and keystore key |
| global.certificates.occm.occm_secret | STRING | - | occm-secret | O | Name of the Secret storing CNCC user credentials |
| global.certificates.occm.occm_namespace | STRING | - | - | O | OCCM Namespace |
| global.certificates.occm.occm_service_name | STRING | - | occm | O | OCCM Kubernetes Service Name |
| global.certificates.occm.occm_port | INTEGER | - | 8989 | O | OCCM Service Port |
| global.certificates.occm.volumes.json | STRING | - | /occm-request | O | Mount path of the JSONs used when sending request to OCCM |
| global.certificates.occm.volumes.script | STRING | - | /occm-script | O | Mount path of the script used to send request to OCCM |
| global.certificates.occm.san.kafka.update_required | BOOLEAN | true/false | false | C | If update of SAN field for Kafka certificates is required. Should be enabled post-installation when external access of Kafka is required. |
| global.certificates.occm.san.kafka.ips | LIST[STRING] | - | ["10.10.10.10", "10.10.10.11", "10.10.10.12"] | C | IPs to add in SAN for Kafka certificate. Provide the Load balancer IPs during installation if static IPs for load balancer are chosen |
| global.certificates.occm.san.kafka.uuid.client | STRING | - | - | C | UUID of existing Kafka broker certificate with names prefixed by KAFKABROKER-SECRET-CLIENT |
| global.certificates.occm.san.kafka.uuid.server | STRING | - | - | C | UUID of existing Kafka broker certificate with names prefixed by KAFKABROKER-SECRET-SERVER |
| global.certificates.occm.san.redundancy_agent.update_required | BOOLEAN | true/false | false | C | If update of SAN field for Redundancy Agent certificates is required. Should be enabled post-installation when two site redundancy is enabled. |
| global.certificates.occm.san.redundancy_agent.ips | LIST[STRING] | - | ["10.10.10.10"] | C | IPs to add in SAN for Redundancy Agent certificate. Provide the Load balancer IP during installation if static IP for load balancer is chosen |
| global.certificates.occm.san.redundancy_agent.uuid.client | STRING | - | - | C | UUID of existing Redundancy Agent certificate with names prefixed by KAFKABROKER-SECRET-CLIENT |
| global.certificates.occm.san.redundancy_agent.uuid.server | STRING | - | - | C | UUID of existing Redundancy Agent certificate with names prefixed by KAFKABROKER-SECRET-SERVER |
| global.certificates.occm.san.ingress_adapter.update_required | BOOLEAN | true/false | false | C | If update of SAN field for Ingress Adapter certificates is required. Should be enabled post-installation when external access to Ingress Adapter/s is needed. |
| global.certificates.occm.san.ingress_adapter.ips | LIST[STRING] | - | ["10.10.10.10"] | C | IPs to add in SAN for Ingress Adapter certificate |
| global.certificates.occm.san.ingress_adapter.uuid.client | STRING | - | - | C | UUID of existing Ingress Adapter certificate with names prefixed by KAFKABROKER-SECRET-CLIENT |
| global.certificates.occm.san.ingress_adapter.uuid.server | STRING | - | - | C | UUID of existing Ingress Adapter certificate with names prefixed by KAFKABROKER-SECRET-SERVER |
| global.certificates.occm.keyAlgorithm | STRING | RSA/EC | RSA | C | Select OCCM key algorithm, RSA for RSA based key generation and EC for ECDSA based key generation |
| global.certificates.occm.keySize | STRING | KEYSIZE_2048/KEYSIZE_4096 | KEYSIZE_2048 | C | Defines the keySize of RSA based key generation. |
| global.certificates.occm.ecCurve | STRING | SECP384r1/SECP256r1 | SECP384r1 | C | Define the curve parameter when keyAlgorithm select is EC. |
3.15 cnDBTier Customization Parameters
The Data Director uses cnDBTier as an independent database for georedundant
sites. By default, the ocnadd_dbtier_custom_values.yaml file provided
with the OCNADD installation is for a single-site deployment of cnDBTier.
Single-site cnDBTier deployment mode: Georeplication is unavailable. Users must continue taking databse backups periodically, preferably on a daily basis, so that the same can be used when fault recovery scenarios arise. See the section "Fault Recovery" for backup options in the OCNADD.
For information about the values of the following parameters, see theocnadd_dbtier_custom_values.yaml file:
- Any change in the cnDBTier
custom_valuesfile introduced by the cnDBTier patch must be updated in thecustom_valuesfile provided by OCNADD before deployment. - For detailed information on the cnDBTier resources, see the section
"DB Profile" in the Oracle Communications Network Analytics Data Director
Benchmarking Guide. The resources in the
ocnadd_dbtier_custom_values.yamlshould match with this guide; if not, update them according to this guide.
Table 3-18 cnDBTier Customization Parameters
| Parameter | Description | Version |
global.repository |
The value should be updated to point to the actual path of your
Docker registry, for example
occne-repo-host:5000/occne |
24.3.0 |
global.sitename |
This parameter must be set to the name of the current cluster | 24.3.0 |
global.domain |
Set it to the name of the Kubernetes cluster on which cnDBTier is
installed, for example, occne1-cgbu-cne-dbtier |
24.3.0 |
global.namespace |
The Kubernetes namespace in which the cnDBTier is deployed | 24.3.0 |
global.storageClassName |
Storage class to be used. By default, |
24.3.0 |
global.mgmReplicaCount |
Default value to be used as in the file | 24.3.0 |
global.ndbReplicaCount |
The default value in the
o - Should be updated to 4 when cnDBTier is planned to be used as extended storage for xDRs - Default value (2) to be used in the file when cnDBTier is not used as extended storage |
24.3.0 |
global.ndbappReplicaCount |
Default value (2) to be used as in the file | 24.3.0 |
global.ndbappReplicaMaxCount |
Default value (4) to be used as in the file
24.3.0 |
global.apiReplicaCount |
- In the case of no replication, the minimum number of SQL nodes required is 0. |
24.3.0 |
global.ndb.datamemory |
- Should be updated to 96G when cnDBTier is planned to be used as extended storage for xDRs - Default value (1G) to be used in the file when cnDBTier is not used as extended storage |
24.3.0 |
global.mgm.ndbdisksize |
Default value (30Gi) to be used as in the file | 24.3.0 |
global.ndb.ndbdisksize |
- Should be updated to ndb.resources.limits.memory + 30Gi when cnDBTier is planned to be used as extended storage for xDRs - Default value (30Gi) to be used in the file when cnDBTier is not used as extended storage |
24.3.0 |
global.ndb.ndbbackupdisksize |
global.api.ndbdisksize |
global.ndbapp.ndbdisksize |
Default value (20Gi) to be used as in the file | 24.3.0 |
mgm.resources.limits.cpu |
Default value (1) to be used as in the file | 24.3.0 |
mgm.resources.limits.memory |
Default value (1Gi) to be used as in the file | 24.3.0 |
mgm.resources.requests.cpu |
mgm.resources.requests.memory |
ndb.resources.limits.cpu |
- Should be updated to 8 when cnDBTier is planned to be used as extended storage for xDRs - Default value (1) to be used in the file when cnDBTier is not used as extended storage |
24.3.0 |
ndb.resources.limits.memory |
- Should be updated to 128Gi when cnDBTier is planned to be used as extended storage for xDRs - Default value (4Gi) to be used in the file when cnDBTier is not used as extended storage |
24.3.0 |
ndb.resources.requests.cpu |
24.3.0 |
ndb.resources.requests.memory |
24.3.0 |
api.resources.limits.cpu |
api.resources.limits.memory |
api.resources.requests.cpu |
api.resources.requests.memory |
api.ndbapp.resources.limits.cpu |
api.ndbapp.resources.limits.memory |
api.ndbapp.resources.requests.cpu |
api.ndbapp.resources.requests.memory |
db-replicationsvc.dbreplsvcdeployments.enabled |
Default value (false) to be used as in the file | 24.3.0 |
db-replicationsvc.resources.limits.cpu |
db-replicationsvc.resources.limits.memory |
Default value (2048Mi) to be used as in the file | 24.3.0 |
db-replicationsvc.resources.requests.cpu |
Default value (0.6) to be used as in the file | 24.3.0 |
db-replicationsvc.resources.requests.memory |
Default value (1024Mi) to be used as in the file | 24.3.0 |
db-monitor-svc.resources.limits.cpu |
Default value (200m) to be used as in the file | 24.3.0 |
db-monitor-svc.resources.limits.memory |
Default value (500Mi) to be used as in the file | 24.3.0 |
db-monitor-svc.resources.requests.cpu |
db-monitorsvc.resources.requests.memory |
For more information about these parameters, see Oracle Communications Cloud Native Core cnDBTier Installation, Upgrade, and Fault Recovery Guide.
