3 Customizing OCNADD
This chapter describes how to customize the Oracle Communications Network Analytics Data Director (OCNADD) deployment, supported deployment models, and provides a list of configuration parameters in the Helm file that are used for customization. The OCNADD deployment is customized by overriding the default values of various configurable parameters.
3.1 OCNADD Deployment Models
- Model 1: All Data Director Services (Default)
- Model 2: Kafka, Common Services, and Aggregation Services
The Data Director supports egress adapters for outbound connections. The egress adapters add value to the message feed by filtering and synthesizing the packets before sending the messages out on the egress connection type 'HTTP/2' or 'Synthetic Feed'. If the customer selects a deployment model that does not include the Egress adapter, additional features such as synthetic packet generation will not be available, although the filtering and correlation features will be available using Kafka feeds only.The following diagram depicts the various Data Director deployment models:
Table 3-1 Resource Saving
| Deployment Model | Model 1 (All Services) | Model 2 (Kafka +Aggregation) |
| Common Services | Available | Available |
| Aggregation Service | Available | Available |
| Adapter Service | Available | Not available |
| Kafka | Available | Available |
| Resource Saving (approx. %) | 0 | 60 |
| Supported Egress Interfaces | HTTP/2
TCP |
Kafka |
The resource saving for the default model will be more if many worker groups are going to be managed with a single management group.Model 1: All Data Director Services (Default: Centralized)
This OCNADD deployment model includes all the services and features. This is the
default model and all the services are selected by default in the ocnadd-custom-values-25.1.200.yaml file.
This profile can stream NFs (SCP, NRF, SEPP) data up to 15K MPS and can be scaled to handle up to 135K MPS for HTTP2 feed when "weighted_lb" is off.
Replication Factor should be 1 and the incoming message size on OCNADD should be less than or equal to 3500 bytes.
- Use the GUI to configure message feeds on OCNADD.
- The Oracle Producer NFs (SCP, SEPP and NRF) copy the messages to their respective source topics.
For this model, the user need not enable or disable any service in the
ocnadd-custom-values-25.1.200.yaml. The default parameters are as below.
global:
ocnaddalarm:
enabled: true
ocnaddconfiguration:
enabled: true
ocnaddhealthmonitoring:
enabled: true
ocnaddscpaggregation:
enabled: true
ocnaddnrfaggregation:
enabled: true
ocnaddseppaggregation:
enabled: true
ocnaddbsfaggregation:
enabled: false
ocnaddpcfaggregation:
enabled: false
ocnaddbackuprestore:
enabled: true
ocnaddkafka:
enabled: true
ocnaddadmin:
enabled: true
ocnadduirouter:
enabled: true
ocnaddgui:
enabled: true
ocnaddfilter:
enabled: true
ocnaddexport:
enabled: true
ocnaddnonracleaggregation:
enabled: true
ocnaddredundancyagent:
enabled: true
Use this model when the customer does not wish to receive the message feed using HTTP/2 or TCP connection mode. The third-party monitoring application available to the customer can consume data directly from the Kafka cluster. The Egress adapter is not required in this deployment model; however, the OCNADD deployment requires common services (such as UI, Configuration, Health monitoring, Alarm, and Admin). Features like correlation-id-based load balancing, synthetic feed, and HTTP/2 feeds are unavailable in this deployment model, although the filtering and correlation features will be available using Kafka feeds only. This model saves the egress adapter resource; however, additional resources will be required for Filtering and Correlation services once these features are used in the configurations from UI.
The export feature is also available, however it has to be enabled in the charts by enabling the ocnaddexport service and further export configuration from the UI. For more information, see "Export" section in "OCNADD Features and Feature Specific Limits " chapter and "Export Configuration " section in " Configuring OCNADD" chapter in Oracle Communications Network Analytics Data Director User Guide.
This deployment model supports direct Kafka feed. For more information, see "External Kafka Feeds" section in Oracle Communications Network Analytics Data Director User Guide.
global:
ocnaddalarm:
enabled: true
enabled: true
enabled: true
enabled: true
enabled: true
enabled: true
enabled: false
enabled: false
enabled: true
ocnaddkafka:
enabled: true
ocnaddadmin:
enabled: true
ocnadduirouter:
enabled: true
ocnaddgui:
enabled: true
ocnaddfilter:
enabled: true
ocnaddexport:
enabled: false
enabled: false
enabled: false- The aggregation service aggregates traffic from the source topics to the Kafka main topic. Choosing any specific combination of NFs for aggregation rules is not possible. The total traffic received is aggregated and available to the consumers.
- The third-party consumer application must create external Kafka feeds to connect with the Kafka cluster, which will allow them to consume messages directly from the designated topic.
- Aggregation: The traffic will be aggregated using the configuration on Oracle Producer NFs to use the Main topic for copying messages on the OCNADD.
- The message feeds must be created from the GUI and aggregation rules determine the source NF combinations for aggregation.
- Metrics related to the feed shall be available on the GUI. The GUI can also be used to view the OCNADD alarms.
The customer can customize the OCNADD deployment based on the identified resources. Plan the resources based on the deployment model and services required for the specific model. For more information of OCNADD resources see Oracle Communications Network Analytics Data Director Benchmarking Guide.
In both models, the two-site redundancy feature can be enabled. For more information, see 'Two Site Redundancy Enable' section in the Oracle Communications Network Analytics Data Director User Guide.
3.2 Customize Configuration Parameters
Perform the following procedure to customize the ocnadd-custom-values-25.1.200.yaml files as per requirements for both parent and sub-charts.
- Ensure that you have the Data Director charts tgz file, which is available in the extracted release package. For information about how to download the release package from MOS, see Downloading OCNADD Package.
- Extract the OCNADD package if not already extracted, and unzip the custom-templates.zip
- Change the directory to custom-templates to access the parent
ocnadd-custom-values-25.1.200.yaml. This file is used to customize the deployment parameters during installation.Change the following parameters in the
ocnadd-custom-values-25.1.200.yamland save the file:- Update the repository path in
global.env.repo.REPO_HOST_PORT: <customer repository path> - Update the CLUSTER-INFO parameters:
cluster.domainName: <customer cluster domain name>cluster.clusterName: <customer cluster name>
- Update the database IP and database name:
db_ip: 10.20.30.40(Update with DB instance IP or with FQDN. For example,mysql-connectivity-service.<cnDBTier namespace>)db_port: 3306(If using a different port for DB, change it. By default, DB port is3306)configuration_db: configuration_schema(Update the DB name as per the section Update Database Name. No change is needed if default DB names are used.)alarm_db: alarm_schema(Update the DB name as per the section Update Database Name. No change is needed if default DB names are used.)health_db: healthdb_schema(Update the DB name as per the section Update Database Name. No change is needed if default DB names are used.)storageadapter_db:storageadapter_schema(Update the DB name as per the section Update Database Name. No change is needed if default DB names are used.)
- Update the cluster and cluster domain name for
UI
ocnadduirouter: ocnadduirouter: name: ocnadduirouter env: PROMETHEUS_API: http://occne-kube-prom-stack-kube-prometheus.occne-infra.ocnadd:80 ## --> update 'ocnadd' with <customer cluster domain name> DD_PROMETHEUS_PATH: /blurr8/prometheus/api/v1/query_range ## --> update 'blurr8' with <customer cluster name> - Change the Prometheus Monitoring Details, bases on the desired MPS
profile, default threshold MPS is
100000:cluster.mps: 100000 - Update the default cluster.prometheus_url based on the cluster
information:
Default prometheus_url:
http://localhost:9000/<cluster-name>/prometheus/api/v1/query_rangeExample URL( For CNE deployment and cluster name as
ocnadd):prometheus_url:
http://occne-kube-prom-stack-kube-prometheus.occne-infra.svc.ocnadd:80/ocnadd/prometheus/api/v1/query_range - (Optional) Updating the OCNADD Backup Cronjob:
Modify the below backup parameters as needed For more information on backup and restore, see "Fault Recovery" section.
BACKUP_STORAGE : Represents Backup storage PVC size BACKUP_CRONEXPRESSION : Represents the time of execution PURGE_DAYS : Represents the backup retention period in days ocnaddbackuprestore: ocnaddbackuprestore: name: ocnaddbackuprestore env: BACKUP_STORAGE: 20Gi BACKUP_CRONEXPRESSION: "0 8 * * *" PURGE_DAYS: 7 - Updating the OCNADD Kafka Deployment Mode:
In the current release deployment by Kraft mode is the only supported mode for the Kafka Cluster, the Zookeeper mode has been obsoleted and removed.
Modify the below global parameter for enabling the Kraft based Kafka deployment. In this case, zookeeper will not be deployed and instead of zookeeper, Kraft controller service will be deployed.
# Set this parameter to 'true' **only** when KRaft mode is selected during a fresh installation. # This parameter **must remain 'false'** during a Data Director upgrade (Zookeeper mode) or migration from Zookeeper to KRaft. # During an upgrade, if the source release was already in KRaft mode, this parameter should remain 'true'. global.kafka.kraftEnabled: false ## --> update this to 'true' - Enable the specific aggregation service as needed. The default values are listed
below. To enable a specific aggregation service, set its corresponding value to
true.global: ocnaddscpaggregation: enabled: true ocnaddnrfaggregation: enabled: true ocnaddseppaggregation: enabled: true ocnaddbsfaggregation: enabled: false ocnaddpcfaggregation: enabled: false
- Customize the rules file
<chartpath>/templates/ocnadd-alerting-rules.yaml:- If OCNADD is to be installed in OCI setup, then remove the
<chartpath>/templates/ocnadd-alerting-rules.yamland<chartpath>/templates/ocnadd-mgmt-alerting-rules.yamlfiles. - If OCNADD is to be installed in CNE Setup, then all the services will be monitored by Prometheus By default. So there will not be any Modifications in the Helm Chart. All the Prometheus Alert Rules Present in Helm Chart will be Updated in Prometheus Server. (Here the Label Used to Update the Prometheus Server is "role: cnc-alerting-rules", which is added By Default in Helm Charts)
- If OCNADD is to be installed in Tanzu setup, then modify the
metadata.labels" value in<chartpath>/templates/ocnadd-alerting-rules.yamland<chartpath>/templates/ocnadd-mgmt-alerting-rules.yamlfiles as below:For Example "
release: prom-operator" instead of "role: cnc-alerting-rules".To obtain the labels details use the below command:kubectl get prometheus <Prometheus_Configuration_NAME> -n <Prometheus_Namespace> -o=jsonpath='{.spec.ruleSelector.matchLabels}'Example:
$ kubectl get prometheus prom-operator-kube-prometh-prometheus -n occne-infra -o=jsonpath='{.spec.ruleSelector.matchLabels}'{"release: prom-operator"}
Sample Alert File:apiVersion: monitoring.coreos.com/v1 kind: PrometheusRule metadata: labels: release: prom-operator name: ocnadd-alerting-rules namespace: {{ .Values.global.cluster.nameSpace.name }} - If OCNADD is to be installed in OCI setup, then remove the
- <Optional> Creating Registry Credentials:
If the user image repository is protected and has an authentication mechanism, follow the below steps:
- Use the kubectl command to create a secret named "regcred" with the credentials of the image repository.
- Update the
imagePullSecret.enablefield totruein theocnadd-custom-values-25.1.200.yamlfile as follows:imagePullSecret: enable: true ## --> update this to 'true'
- <Optional> Kafka preinstall Configuration changes:
- <Optional> To change the profiles of the brokers, edit the
respective values (CPU, memory, storage, external-access, security, jaas-password,
replicas, internal replication factor, and so on) in kafka-section of
ocnadd-custom-values-25.1.200.yamlfile. Ensure that this is done for all the applicable worker groups.Note:
If the topics are created with Replication Factor (RF) greater than "1" (RF>1) then, ensure to update the corresponding RF values of the following parameters in theocnadd-custom-values-25.1.200.yamlfile under ocnaddkafka:offsetsTopicReplicationFactortransactionStateLogReplicationFactor
For example, if the topics SCP, NRF, SEPP, PCF, BSF, and MAIN are created with RF=3, then the parameters should be set to value "3"
offsetsTopicReplicationFactor: 3 transactionStateLogReplicationFactor: 3 - <Optional> When the security protocol is SASL and the customer
required to add new users, update the
kafka_server_jaas.conf,zookeeper_jaas.conffiles in<chartpath>/charts/ocnaddkafka/config.
- Storage Class:
- If deploying on Tanzu, update the storageClass in the
ocnadd-custom-values-25.1.200.yamlwith the respective storage class name of the TANZU platform. For example,zfs-storage-policy. - If deploying on OCI, update the storageClass in the
ocnadd-custom-values-25.1.200.yamlwith the respective storage class name of the OCI platform, it should be "oci-bv"
This step is specific to the TANZU and OCI platform. Skip this step if you are installing OCNADD on CNE. For CNE, the default storageClass is standard.. - If deploying on Tanzu, update the storageClass in the
- <Optional> To enable Egress Annotation, see the "Enabling Egress Annotation" section in the Oracle Communications Network Analytics Data Director User Guide. The step can be skipped if the Egress Traffic separation via CNLB is planned to be used.
- Loadbalancer on OCI: Update the following in
ocnadd-custom-values-25.1.200.yamlglobal.env.oci: false =====> set it to trueglobal.env.subnetOcid:<subnet_ocid> # Add the OCID of the subnet that user want to use for creating load balancer
3.3 Global Parameters
Table 3-2 Global Parameters
| Parameter Name | Data Type | Range | Default Value | Mandatory(M)/Optional(O)/Conditional(C) | Description |
| ocnaddalarm.enabled | BOOLEAN | true/false | true | M | To enable alarm charts. |
| env.admin.OCNADD_CORR_UPGRADE_ENABLE | BOOLEAN | true/false | false | M | Upgrade correlation service during Helm upgrade if the flag is set to true |
| env.admin.OCNADD_INGRESS_ADAPTER_UPGRADE_ENABLE | BOOLEAN | true/false | false | M | Upgrade ingress adapter during Helm upgrade if the flag is set to true |
| env.admin.OCNADD_STORAGE_ADAPTER_UPGRADE_ENABLE | BOOLEAN | true/false | false | M | Upgrade storage adapter during Helm upgrade if the flag is set to true |
| ocnaddconfiguration.enabled | BOOLEAN | true/false | true | M | To enable configuration charts. |
ocnaddhealthmonitoring.enabled |
BOOLEAN | true/false | true | M | To enable health monitoring charts. |
| ocnaddfilter.enabled | BOOLEAN | true/false | false | M | To disable filter charts ('false' for the current release). |
| ocnaddscpaggregation.enabled | BOOLEAN | true/false | true | M | To enable SCP aggregation charts |
| ocnaddnrfaggregation.enabled | BOOLEAN | true/false | true | M | To enable NRF aggregation charts |
| ocnaddseppaggregation.enabled | BOOLEAN | true/false | true | M | To enable SEPP aggregation charts |
| ocnaddbsfaggregation.enabled | BOOLEAN | true/false | false | M | To enable BSF aggregation charts |
| ocnaddpcfaggregation.enabled | BOOLEAN | true/false | false | M | To enable PCF aggregation charts |
| ocnaddbackuprestore.enabled | BOOLEAN | true/false | true | M | To enable backup restore charts. |
| ocnaddkafka.enabled | BOOLEAN | true/false | true | M | To enable Kafka charts. |
| ocnaddadminsvc.enabled | BOOLEAN | true/false | true | M | To enable adminsvc charts. |
| ocnaddgui.enabled | BOOLEAN | true/false | true | M | To enable GUI charts. |
| ocnadduirouter.enabled | BOOLEAN | true/false | true | M | To enable UI router charts. |
| ocnaddredundancyagent.enabled | BOOLEAN | true/false | false | M | To enable two site redundancy |
| ocnaddexport | BOOLEAN | true/false | false | M | To enable export service |
| ocnaddnonoracleaggregation | BOOLEAN | true/false | false | M | To enable non-Oracle aggregation feature through aggregation service instance. |
| ocnaddredundancyagent.egress | BOOLEAN | true/false | false | C | Required if egress annotation is required to allow traffic outside cluster. |
| env.oci | BOOLEAN | true/false | false | M | It should be set to true for OCI platform. |
| env.subnetOcid | STRING | NA | NA | C | It is required for OCI platform. The OCID of the subnet that you want to use for creating load balancers. |
| env.topologyKey | STRING | NA | kubernetes.io/hostname | M | The topology key for setting up the topology constraints on the pod deployment. |
| env.ocwebclient.OCWEBCLIENT_TIMEOUT | INTEGER | NA | 30 | O | Webclient timeout in seconds |
| env.ocwebclient.OCWEBCLIENT_KEEPALIVE_IDLE | INTEGER | NA | 90 | O | Webclient keep alive idle time in seconds |
| env.repo.repo.REPO_HOST_PORT | STRING | NA | docker.io | M | Local container registry to pull the images |
| env.repo.repo.REPO_PATH | STRING | NA | ocdd.repo | M | Additional repo path |
| env.admin.OCNADD_ADAPTER_UPGRADE_ENABLE | BOOLEAN | NA | false | M | Upgrade consumer adapter during Helm upgrade if the flag is set to true. |
| scaleDownOnePodAtATime | BOOLEAN | true/false | false | M | Scale down Pods one at a time. |
| stabilizationWindowSeconds | INTEGER | NA | 60 | M | Stabilization period in seconds post which scale down starts. |
| scaleDownPeriodSeconds | INTEGER | NA | 30 | M | Period of each scale down operation in seconds. |
| scaleDownValue | INTEGER | NA | 1 | M | Number of pods which shall go down in every scaleDownPeriodSeconds. |
| initContainers.name | STRING | NA | ocnaddinitcontainer | M | Name of initContainer for SSL support |
| initContainers.REPO_PATH | STRING | NA | utils.repo | M | Repo path where init image is stored |
| initContainers.volumeMounts.ts_ks_volumeName | STRING | NA | truststore-keystore-volume | M | Volume name for truststore |
| initContainers.volumeMounts.ts_ks_volumePath | STRING | NA | /var/securityfiles/keystore | M | Path where keystore files are stored |
| initContainers.volumeMounts.certificateName | STRING | NA | client-server-certificate | M | Volume name for server certificates |
| initContainers.volumeMounts.certificatePath | STRING | NA | /var/securityfiles/certs | M | Path where cert files are stored |
| initContainers.env.cert_file_params.SERVER_CERT_FILE | STRING | NA | servercert.pem | M | Server cert filename |
| initContainers.env.cert_file_params.CLIENT_CERT_FILE | STRING | NA | clientcert.pem | M | Client cert filename |
| initContainers.env.cert_file_params.SERVER_KEY_FILE | STRING | NA | serverprivatekey.pem | M | Server Private Key filename |
| initContainers.env.cert_file_params.CLIENT_KEY_FILE | STRING | NA | clientprivatekey.pem | M | Client Private Key filename |
| initContainers.env.ks_file_params.SERVER_KEY_STORE | STRING | NA | serverKeyStore.p12 | M | Server Keystore file |
| initContainers.env.ks_file_params.CLIENT_KEY_STORE | STRING | NA | clientKeyStore.p12 | M | Client Keystore file |
| initContainers.env.ks_file_params.TRUST_STORE | STRING | NA | trustStore.p12 | M | Truststore file |
| initContainers.cacert.key | STRING | NA | CA_CERT_FILE | M | Cacert key file |
| initContainers.cacert.value | STRING | NA | cacert.pem | M | Cacert file |
| ssl.intraTlsEnabled | BOOLEAN | true/false | false | M | Enable internal service TLS |
| ssl.mTLS | BOOLEAN | true/false | false | M | Enable MTLS support for internal OCNADD services |
| ssl.kafkaCipherSuites | STRING | NA | "TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256,TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384, TLS_AES_256_GCM_SHA384,TLS_AES_128_GCM_SHA256,TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384" | M | Supported Cipher Suites for Kafka Broker service in Data Director |
| ssl.tlsCipherSuites | STRING | NA | "TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256,TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384, TLS_AES_256_GCM_SHA384,TLS_AES_128_GCM_SHA256,TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256, TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384" | M | Support Cipher Suites for Internal Services of Data Director |
| ssl.CERT_EXPIRY_CRONEXPRESSION | STRING | NA | 0 0 * * * | M | Schedule for Cron Expression that will check certificate expiry at midnight everyday. |
| ssl.CERT_EXPIRY_CRONJOB | BOOLEAN | true/false | true | M | Enable cronjob schedule to check certificate expiry. |
| acl.genericAclAllowed | BOOLEAN | true/false | false | M | No need to change this flag here, genericAclAllowed=true will be used in upgrade --set command to restrict the generic ACL creation. |
| acl.kafkaClientAuth | STRING | none/required | none | M | This Property is to enable or disable MTLS in Kafka. |
| acl.aclNotAllowed | BOOLEAN | true/false | true | M | This Property is used to turn on or off the Kafka ACL's. |
| cluster.domainName | STRING | NA | occne-ocdd | M | Domain name of the setup |
| cluster.clusterName | STRING | NA | occne-ocdd | M | Default cluster name of setup |
| cluster.secret.name | STRING | NA | db-secret | M | Database Secret name where DB credentials are stored |
| cluster.mysqlNameSpace.name | STRING | NA | occne-cndbtierone | M | cnDBTier namespace |
| cluster.mysqlPod | STRING | NA | ndbmysqld-0 | M | cnDBTier Pod Name |
| cluster.database.db_ip | STRING | NA | mysql-connectivity-service.occne-cndbtierone | M | Hostname or IP of cnDBTier |
| cluster.database.db_port | INTEGER | NA | 3306 | M | DB Port |
| cluster.database.configuration_db | STRING | NA | configuration_schema | M | Configuration Service Schema Name |
| cluster.database.alarm_db | STRING | NA | alarm_schema | M | Alarm Service Schema Name |
| cluster.database.health_db | STRING | NA | healthdb_schema | M | Health Service Schema Name |
| cluster.storageClass | STRING | NA | standard | M | Storage Class Name |
| cluster.nameSpace.name | STRING | NA | ocnadd-deploy | M | OCNADD Namespace |
| cluster.serviceAccount.create | BOOLEAN | true/false | true | M | To create a ServiceAccount (true/false) |
| cluster.serviceAccount.name | STRING | NA | ocnadd | M | Name of the service Account |
| cluster.clusterRole.create | BOOLEAN | true/false | true | M | To create clusterRole (true/false) |
| cluster.clusterRole.name | STRING | NA | ocnadd | Name of the clusterRole | |
| cluster.clusterRoleBinding.create | BOOLEAN | true/false | true | M | To create clusterRoleBinding (true/false) |
| cluster.clusterRoleBinding.name | STRING | NA | ocnadd | Name of the clusterRoleBinding | |
| cluster.terminationGracePeriodSeconds | INTEGER | NA | 5 | O | Pod grace termination |
| cluster.imagePullSecret.enable | BOOLEAN | true/false | false | M | Image Pull secret creation |
| cluster.imagePullSecret.name | STRING | NA | regcred | O | Set to regcred if cluster.imagePullSecret.enable is true |
| cluster.ALARM_PURGE_DAYS | INTEGER | NA | 7 | M | Alarm Purge in Days |
| cluster.kafka.ocnadd_kafka_bootstrap_servers | STRING | NA | kafka-broker:9092 | M | Bootstrap server for PLAINTEXT |
| cluster.kafka.ocnadd_kafka_bootstrap_servers_ssl | STRING | NA | kafka-broker:9093 | M | Bootstrap server for SSL |
| cluster.kafka.ocnadd_kafka_bootstrap_servers_sasl | STRING | NA | kafka-broker:9094 | M | Bootstrap server for SASL |
| cluster.prometheusScrapePort | INTEGER | NA | 9000 | O | Port to scape metrics required if metrics enabled |
| cluster.prometheusPortName | STRING | NA | cnc-metrics | O | Role required to define in alert rules yaml |
| cluster.max_latency | FLOAT | NA | 0.05 | M | Max latency range of 50ms |
| cluster.memory_threshold | INTEGER | [0-100] | 90 | M | Max Threshold limit for memory |
| cluster.cpu_threshold | INTEGER | [0-100] | 85 | M | CPU max threshold limit |
| cluster.mps | INTEGER | NA | 100000 | M | Default MPS rate |
| cluster.serviceMonitorLabel | STRING | NA | occne-kube-prom-stack | M | service monitor label to scrape metrics |
| cluster.prometheus_url | STRING | NA | http://localhost:9000/cluster-name/prometheus/api/v1/query_range | M | Prometheus URL to scrape metrics |
| network.policy.enable | BOOLEAN | true/false | false | M | Network Policy enable for intercommunication of OCNADD services |
| network.ingress.denyall | BOOLEAN | true/false | false | C | Deny all ingress traffic |
| network.ingress.kafka | BOOLEAN | true/false | true | C | Allow ingress traffic for kafka |
| network.ingress.aggregation | BOOLEAN | true/false | true | C | Allow ingress traffic for aggregation service |
| network.ingress.filter | BOOLEAN | true/false | true | C | Allow ingress traffic for filter service |
| network.ingress.adapter | BOOLEAN | true/false | true | C | Allow ingress traffic for adapter service |
| network.ingress.egw | BOOLEAN | true/false | true | C | Allow ingress traffic for egress service |
| network.ingress.config | BOOLEAN | true/false | true | C | Allow ingress traffic for configuration service |
| network.ingress.alarm | BOOLEAN | true/false | true | C | Allow ingress traffic for alarm service |
| network.ingress.health | BOOLEAN | true/false | true | C | Allow ingress traffic for health monitoring service |
| network.ingress.admin | BOOLEAN | true/false | true | C | Allow ingress traffic for admin service |
| network.ingress.namespaces | STRING | NA |
- occne-infra - occncc |
C | Network communication between allowed namespaces |
| network.ingress.external.enable | BOOLEAN | true/false | false | C | Allow kafka LoadBalancer IP to be created |
| network.ingress.external.cidrs | STRING | NA | - 10.0.0.0/8 | C | Cidr for network communication |
| network.egress.denyall | BOOLEAN | true/false | false | C | Deny egress traffic |
| deployment.centralized | BOOLEAN | true/false | true | M | Whether to use centralized mode of deployment |
| deployment.management | BOOLEAN | true/false | true | M | Whether to deploy management group services when
centralized deployment model is enabled.
Will deploy worker group services if false. |
| deployment.management_namespace | STRING | - | Valid namespace name | M | Specify the managment namespace when deploying the
worker group services.
Centralized Mode: For Management Group Deployment:
For Worker Group Deployment:
This parameter facilitates communication between services in the worker group and the management group of services. Non-Centralized Mode: In this mode:
| deployment.nonCenToCen_upgrade | BOOLEAN | true/false | false | M | True if upgrading from non-centralized to centralized.
Default is False (direct installation) |
| deployment.primary_site | BOOLEAN | true/false | false | C | This parameter is required only in case the redundancy agent service is enabled. It depicts if the configured site is primary or not. |
| deployment.primary_agent_ip | STRING | NA | - | C | This parameter is required only in case the redundancy agent service is enabled. It is configured in the secondary site and denotes the primary site redundancy agent IP address or service FQDN. |
| kafka.kraftEnabled | BOOLEAN | true/false | true | C |
This parameter is required only when Kafka is deployed in KRaft mode. The default value is 'false'. Set this parameter to 'true' only during a fresh install when KRaft mode is selected. It must remain 'false' during a Data Director upgrade (Zookeeper mode) or during migration from Zookeeper to KRaft. If the source release was already using KRaft mode during an upgrade, this parameter must remain 'true'. |
| kafka.spawnKraftController | BOOLEAN | true/false | false | C |
This parameter indicates whether the KRaft controller should be spawned during the migration process. It should only be enabled when running the migration procedure as defined in the Oracle Communications Network Analytics Data Director User Guide. |
| kafka.migrationBroker | BOOLEAN | true/false | false | C | Parameter to indicate that the migration of Kafka brokers to Kraft controllers. This should only be enabled while running the migration procedure defined in the User guide |
| kafka.kraftBroker | BOOLEAN | true/false | false | C | Parameter to indicate that the migration of Kafka brokers to Kraft. This should only be enabled while running the migration procedure defined in the Oracle Communications Network Analytics Data Director User Guide. |
| kafka.finalizeMigration | BOOLEAN | true/false | false | C | Parameter to indicate that the migration to Kraft can now be finalized. This should only be enabled while running the migration procedure defined in the Oracle Communications Network Analytics Data Director User Guide. |
| kafka.removeZookeeper | BOOLEAN | true/false | false | C | Parameter to indicate that zookeeper can now be deprovisioned after the migration to Kraft is finalized. This should only be enabled while running the migration procedure defined in the Oracle Communications Network Analytics Data Director User Guide. |
| kafka.occmZookeeperClientUUID | STRING | - | false | C | UUID value of Zookeeper client certificate in OCCM. If OCCM is enabled during migration from Zookeeper mode to KRaft Mode then this value is used to delete the CLIENT Certificate of Zookeeper in OCCM |
| kafka.occmZookeeperServerUUID | STRING | - | false | C | UUID value of Zookeeper server certificate in OCCM. If OCCM is enabled during migration from Zookeeper mode to KRaft Mode then this value is used to delete the SERVER Certificate of Zookeeper in OCCM |
| admin.OCNADD_UPGRADE_WG_NS | STRING | NA | [ocnadd-deploy-wg1,ocnadd-deploy-wg2] | M | This parameter is a comma-separated list of worker group namespaces to update using Helm. |
| kafkaReplicas | INTEGER | - | 4 | M | The parameter to change the replicas for the Kafka broker. |
| cnlb.consumeradapter.enable | BOOLEAN | true/false | false | C | If set to true, egress traffic
segregation will be enabled for consumer feeds. This determines whether
an Egress NAD should be attached to consumer adapters. Recommended only
for OCCNE with CNLB support.
| cnlb.ingressadapter.enable | BOOLEAN | true/false | false | C | If set to true, ingress traffic
segregation and external access will be enabled for the ingress adapter.
This determines whether an Ingress NAD should be attached. Recommended
only for OCCNE with CNLB support.
| cnlb.ocnaddredundancyagent.enable | BOOLEAN | true/false | false | C | If set to true, external access will be
enabled for the Redundancy Agent. This determines whether CNLB
annotations should be applied to redundancy deployments. Recommended
| cnlb.ocnaddredundancyagent.network | STRING | NA | default/nf-oam-int1@nf-oam-int1 | C | This must be the oam network with ingress definition.
The entry means single network will be used by another site's Redundancy
Agent for ingress communication.
Update the network from the generated CNLB annotation, Given value is an example need to be updated as per /var/occne/cluster/$OCCNE_CLUSTER/artifacts/cnlbGenAnnotations.py script. |
| cnlb.ocnaddredundancyagent.externalIP | STRING | NA | 10.1.1.1 | C | Specifies the single external IP required for communication between Redundancy Agents in a two-site setup. Replace with the actual external IP. |
| cnlb.kafkabroker.enable | BOOLEAN | true / false | false | C | If set to true, external access for
Kafka brokers will be enabled in a CNLB-enabled cluster.
| cnlb.kafkabroker.networks | STRING | NA |
"default/nf-sig2-int1@nf-sig2-int1, default/nf-sig2-int2@nf-sig2-int2, default/nf-sig2-int3@nf-sig2-int3, default/nf-sig2-int4@nf-sig2-int4" |
C | Used to populate the
k8s.v1.cni.cncf.io/networks annotation. Update this
based on the "Enable CNLB for Kafka Broker" section of the Oracle Communications Network Analytics Data Director
User Guide.
| cnlb.kafkabroker.networks_extip | STRING | NA | C | Used to populate the
oracle.com.cnc/cnlb annotation. Ensure the IP
addresses are also included in the SAN entries for SSL
communication.
| env.controlPlaneNfList | STRING | NA | BSF,NRF,PCF | M | It enlists all the control plane NFs |
| env.proxyNfList | STRING | NA | SCP,SEPP | M | It enlist all the proxy NFs |
3.4 Helm Hook Parameters
Table 3-3 Helm Hook Parameters
| ocnaddhelmhook.config.name | STRING | - | helmhook-configmap | M | Name of ConfigMap |
| ocnaddhelmhook.config.upgrade_name | STRING | - | helmhook-upgrade-configmap | M | Name of Upgrade ConfigMap |
| ocnaddhelmhook.config.rollback_name | STRING | - | helmhook-rollback-configmap | M | Name of Rollback ConfigMap |
| ocnaddhelmhook.name | STRING | - | ocnaddhelmhook | M | Helm Hook Name |
| ocnaddhelmhook.container.name | STRING | - | ocnaddhelmhook | M | Container Name of Helm Hook Job |
| ocnaddhelmhook.container.image | STRING | - | preinstall-image:2.1.6 | M | Image used for preinstall hooks |
| ocnaddhelmhook.container.imagePullPolicy | STRING | IfNotPresent/Always/Never | IfNotPresent | M | Image Pull Policy |
| ocnaddpostinstallhelmhook.name | STRING | - | ocnaddpostinstallhelmhook | M | Post Install Hook Name |
| ocnaddpostupgradehelmhook.name | STRING | - | ocnaddpostupgradehelmhook | M | Post Upgrade Hook Name |
| ocnaddpostrollbackhelmhook.name | STRING | - | ocnaddpostrollbackhelmhook | M | Post Rollback hook name |
| ocnaddpreupgradehelmhook.name | STRING | - | ocnaddpreupgradehelmhook | M | Pre Upgrade Hook Name |
| ocnaddprerollbackhelmhook.name | STRING | - | ocnaddprerollbackhelmhook | M | Pre Rollback Hook Name |
| ocnaddhelmhook.config.auto_backup_restore_cm | STRING | - | ocnadd-configmap-auto-backup-restore | M | Name of the automatic backup restore ConfigMap |
| ocnaddpreinstallworkergrouphelmhook.name | STRING | - | ocnaddpreinstallworkergrouphelmhook | M | Name of the preinstall hook used during the installation of the worker group |
| ocnaddpreinstallworkergrouphelmhook.retry_max_attempt | INTEGER | - | 5 | M | Maximum number of retries for getting the list of worker group names |
| ocnaddpreinstallworkergrouphelmhook.retry_delay | INTEGER | - | 15 | M | Delay between retries |
| ocnaddpostinstallworkergrouphelmhook.name | STRING | - | ocnaddpostinstallworkergrouphelmhook | M | Name of the postinstall hook used during the installation of the worker group |
| ocnaddpostinstallworkergrouphelmhook.retry_max_attempt | INTEGER | - | 5 | M | Maximum number of retries for invoking the create worker group API |
| ocnaddpostinstallworkergrouphelmhook.retry_delay | INTEGER | - | 15 | M | Delay between retries |
| ocnaddpostdeleteworkergrouphelmhook.name | STRING | - | ocnaddpostdeleteworkergrouphelmhook | M | Name of the postdelete hook used during the uninstallation of the worker group |
| ocnaddpostdeleteworkergrouphelmhook.retry_max_attempt | INTEGER | - | 5 | M | Maximum number of retries for invoking delete API for worker group |
| ocnaddpostdeleteworkergrouphelmhook.retry_delay | INTEGER | - | 15 | M | Delay between retries |
| ocnaddcopybackuppvctemptoorighelmhook.name | STRING | - | ocnaddcopybackuppvctemptoorighelmhook | M | Hook to copy backup from temporary to original PVC |
| ocnaddcopybackuppvcorigtotemphelmhook.name | STRING | - | ocnaddcopybackuppvcorigtotemphelmhook | M | Hook to copy backup from original to temporary PVC. |
| ocnaddcreatetemppvchelmhook.name | STRING | - | ocnaddcreatetemppvchelmhook | M | Hook to create temporary backup PVC during upgrade. |
3.5 Aggregation Service Parameters
Table 3-4 Aggregation Service Parameters
| BATCH_SIZE | INTEGER | - | 65536 | O | The maximum amount of data to be collected before sending the batch. |
| CONSUMER_POLL_MS | INTEGER | - | 50 | O | Polling time in ms for consumer |
| DD_METADATA_MAP_CACHE_EXPIRY_TIME_MS | INTEGER | 30ms-30s | 30 | O | DD metadata cache expiry timer, default is 30ms |
| DD_METADATA_MAP_CACHE_SCHEDULER_TIME_MS | INTEGER | 5ms-2s | 5 | O | This timer value depends on the attribute METADATA_MAP_CACHE_EXPIRY_TIME_MS. The timer value should be adjusted up or down corresponding to increase or decrease in METADATA_MAP_CACHE_EXPIRY_TIME_MS, default is 5ms. |
| ENABLE_AGGREGATION_COUNTER_METRICS | BOOLEAN | true,false | false | M | Enable metrics for Aggregation service |
| FETCH_MAX_WAIT_MS | INTEGER | - | 100 | O | The maximum amount of time the server will block before answering the fetch request if there isn’t sufficient data to immediately satisfy the requirement given by fetch.min.bytes |
| HEARTBEAT_INTERVAL_MS | INTEGER | - | 5000 | O | The expected time between heartbeats to the consumer coordinator when using Kafka’s group management facilities |
| KAFKA_FETCH_MAX_BYTES | INTEGER | - | 576720 | O | The maximum amount of data per-partition the server will return |
| KAFKA_FETCH_MIN_BYTES | STRING | - | 1 | O | The minimum amount of data per-partition the server will return |
| KAFKA_MAX_AGE_CONFIG | INTEGER | - | 7500 | M | The period of time in milliseconds after which we force a refresh of metadata. |
| KAFKA_MAX_PARTITIONS_FETCH_BYTES | INTEGER | - | 104858 | O | The maximum amount of data per-partition the server will return. |
| KAFKA_PRODUCER_SSL_CLIENT_AUTH | BOOLEAN | true, false | false | M | Kafka SSL client authentication. |
| KAFKA_SOCKET_BYTES_BUFFER | INTEGER | - | 104857 | O | Kafka Socket Buffer setting for consumer |
| LINGER_MS | INTEGER | - | 1 | O | The time to wait before sending messages out to Kafka |
| logging.level.com.oracle.cgbu.cne.ocdd | STRING | [INFO,WARN,DEBUG,ERROR] | INFO | O | To set the log level of the OCDD package level |
| logging.level.com.oracle.cgbu.cne.ocnadd | STRING | [INFO,WARN,DEBUG,ERROR] | INFO | O | To set the log level of the OCNADD package level |
| MAX_POLL_INTERVAL_MS | INTEGER | - | 30000 | O | The maximum delay between invocations of poll() when using consumer group management |
| MAX_POLL_RECORDS | INTEGER | - | 300 | O | The maximum number of records returned in a single call to poll() |
| MESSAGE_REORDERING_INCOMPLETE_TRANSACTION_METRICS_ENABLE | BOOLEAN | true/false | false | O | The parameter enables the Metric to check/count missing/inordered messages of transactions for MESSAGE_SEQUENCING_TYPE=TRANSACTION/REQUEST_RESPONSE |
| MESSAGE_SEQUENCING_TYPE | INTEGER | [NONE,TIME_WINDOW,TRANSACTION,REQUEST_RESPONSE] | NONE | M |
NONE: No message sequencing. TIME_WINDOW: Messages received within a window time for each partition will be sorted separately based on timestamp and streamed to Kafka topic. TRANSACTION: In-order messages received for each transaction within TRANSACTION_MSG_SEQUENCING_EXPIRY_TIMER will be sorted separately and streamed to Kafka topic. REQUEST_RESPONSE: In-order Request (RxRequest and TxRequest) and/or Response pair (RxResponse and TxResponse) messages received for each transaction within REQUEST_RESPONSE will be sorted separately and streamed to Kafka topic. |
| OCNADD_AGG_REDUNDANCY_DELAY_MS | INTEGER | - | 1000 | C | Delay before starting task to check Kafka ingress rate. This parameter is required when the two-site redundancy feature is enabled. |
| OCNADD_AGG_REDUNDANCY_INTERVAL_MS | INTEGER | - | 250 | C | Interval between tasks to check Kafka ingress rate. This parameter is required when the two-site redundancy feature is enabled. |
| OCNADD_AGGREGATION_LOG_NETTY | STRING | - | INFO | O | Default Netty Log level set for the application. |
| OCNADD_AGGREGATION_LOG_ROOT | STRING | - | INFO | O | Default Log level set for the application. |
| OCNADD_AGGREGATION_SERVICE_TOPIC_RETRIES_THRESHOLD | INTEGER | - | 120000 | O | Retry Threshold for TOPIC reachability |
| OCNADD_KAFKA_BOOTSTRAP_SERVER_SSL | STRING | - | kafka-broker:9093 | M | Kafka Boot strap server address for SSL |
| OCNADD_KAFKA_SASL_MECHANISM | STRING | - | PLAIN | M | Kafka SASL Mechanism. |
| OCNADD_KAFKA_SECURITY_PROTOCOL_SASL | STRING | - | SASL_SSL | M | Kafka security protocol |
| OCNADD_KAFKA_SECURITY_PROTOCOL_SSL | STRING | - | SSL | M | Kafka SSL Mechanism. |
| OCNADD_TRUST_KEYSTORE | BOOLEAN | true, false | true | M | Enable to secure connection via OCWeb Client. |
| ocnaddbsfaggregation.maxReplicas | INTEGER | - | 1 | M | The maximum number of replicas required for BSF aggregation service instance |
| ocnaddbsfaggregation.minReplicas | INTEGER | - | 1 | M | The minimum number of replicas required for BSF aggregation service instance |
| ocnaddbsfaggregation.name | STRING | - | ocnaddbsfaggregation | M | Name of the application |
| ocnaddnonoracleaggregation.resources.limit.cpu | INTEGER | - | 3 | M | Number of max CPU for non-Oracle aggregation |
| ocnaddnonoracleaggregation.resources.limit.ephemeralstorage | STRING | - | 500Mi | M | Ephemeral Storage for non-Oracle aggregation |
| ocnaddnonoracleaggregation.resources.limit.memory | STRING | - | 2Gi | M | Maximum memory allocation for non-Oracle aggregation |
| ocnaddnonoracleaggregation.maxReplicas | INTEGER | - | 1 | M | The maximum number of replicas required for ocnaddnonoracleaggregation aggregation service instance |
| ocnaddnonoracleaggregation.minReplicas | INTEGER | - | 1 | M | The minimum number of replicas required for ocnaddnonoracleaggregation aggregation service instance |
| ocnaddnrfaggregation.name | STRING | - | ocnaddnrfaggregation | M | Name of the application |
| ocnaddnrfaggregation.resources.limit.cpu | INTEGER | - | 3 | M | Number of maximum CPUs for NRF aggregation |
| ocnaddnrfaggregation.resources.limit.ephemeralstorage | STRING | - | 500Mi | M | Ephemeral Storage for NRF aggregation |
| ocnaddnrfaggregation.resources.limit.memory | STRING | - | 2Gi | M | Max Memory limit for NRF aggregation |
| ocnaddnrfaggregation.maxReplicas | INTEGER | - | 1 | M | The maximum number of replicas required for NRF aggregation service instance |
| ocnaddnrfaggregation.minReplicas | INTEGER | - | 1 | M | The minimum number of replicas required for NRF aggregation service instance |
| ocnaddpcfaggregation.name | STRING | - | ocnaddpcfaggregation | M | Name of the application |
| ocnaddpcfaggregation.resources.limit.cpu | INTEGER | - | 2 | M | Number of max CPU for PCF Aggregation |
| ocnaddpcfaggregation.resources.limit.ephemeralstorage | STRING | - | 500Mi | M | Ephemeral Storage for PCF Aggregation |
| ocnaddpcfaggregation.resources.limit.memory | STRING | - | 2Gi | M | Max Memory limit for PCF Aggregation |
| ocnaddscpaggregation.minReplicas | INTEGER | - | 1 | M | The minimum number of replicas required for SCP aggregation service instance |
| ocnaddscpaggregation.name | STRING | - | ocnaddscpaggregation | M | Name of the application |
| ocnaddscpaggregation.resources.limit.cpu | INTEGER | - | 3 | M | Number of max CPU for SCP aggregation |
| ocnaddscpaggregation.resources.limit.ephemeralstorage | STRING | - | 500Mi | M | Ephemeral Storage for SCP aggregation |
| ocnaddscpaggregation.resources.limit.memory | STRING | - | 2Gi | M | Max Memory limit for SCP aggregation |
| ocnaddseppaggregation.maxReplicas | INTEGER | - | 2 | M | The maximum number of replicas required for SEPP aggregation service instance |
| ocnaddseppaggregation.minReplicas | INTEGER | - | 1 | M | The minimum number of replicas required for SEPP aggregation service instance |
| ocnaddseppaggregation.name | STRING | - | ocnaddseppaggregation | M | Name of the application |
| ocnaddseppaggregation.resources.limit.cpu | INTEGER | - | 3 | M | Number of max CPU for SEPP aggregation |
| ocnaddseppaggregation.resources.limit.ephemeralstorage | STRING | - | 500Mi | M | Ephemeral Storage for SEPP aggregation |
| ocnaddseppaggregation.resources.limit.memory | STRING | - | 2Gi | M | Max Memory limit for SEPP aggregation |
| REQUEST_RESPONSE_MSG_SEQUENCING_EXPIRY_TIMER | INTEGER | [5-500]ms | 10ms | C |
When MESSAGE_SEQUENCING_TYPE = REQUEST_RESPONSE |
| REQUEST_TIMEOUT_MS | INTEGER | - | 1000 | O | The configuration controls the maximum amount of time the client will wait for the response of a request |
| SESSION_TIME_OUT | INTEGER | - | 15000 | O | The timeout used to detect client failures when using Kafka’s group management facility. |
| SRC_FEED_METADATA_CLEAN_DELAY_SEC | INTEGER | - | 86400 | C | Initial delay in cleaning the metadata cache |
| SRC_FEED_METADATA_CLEAN_PERIOD_SEC | INTEGER | - | 86400 | C | Interval after the metadata cache is cleaned |
| SRC_FEED_METADATA_HISTORY_LENGTH | INTEGER | - | 20 | C | The number of the metadata maintained in the cache |
| TOTAL_FORWARDED_MESSAGE_METRICS_ENABLE | BOOLEAN | true/false | false | O | The parameter enables the Metric to get total count of forwarded messages by aggregation service |
| TRANSACTION_MSG_SEQUENCING_EXPIRY_TIMER | INTEGER | [20ms-30s] | 200ms | C | When MESSAGE_SEQUENCING_TYPE = TRANSACTION |
| WINDOW_MSG_SEQUENCING_EXPIRY_TIMER | INTEGER | [5-500]ms | 10ms | C | When MESSAGE_SEQUENCING_TYPE = TIME_WINDOW |
3.6 Configuration Service Parameters
Table 3-5 Configuration Service Parameters
| ADAPTER_DEFAULT_INGRESS_ACKS | STRING | - | all | O | The non oracle producer acknowledgement value |
| ADAPTER_DEFAULT_INGRESS_LIMIT | INTEGER | - | 101874 | O | The buffer in bytes in the non oracle ingress adapter feed for the http connection |
| ADAPTER_DEFAULT_INGRESS_PARTITIONS | INTEGER | - | 30 | O | The number of partitions for the non oracle ingress feed adapter |
| ADAPTER_DEFAULT_INGRESS_REPLICATION_FACTOR | INTEGER | - | 1 | O | The non oracle topic replication factor |
| ADAPTER_DEFAULT_INGRESS_RETENTION_MS | INTEGER | - | 600000 | O | The non oracle topic retention time in milisec |
| ADAPTER_DEFAULT_INGRESS_RETRY | INTEGER | - | 3 | O | The number of retries for the non oracle ingress adapter feed |
| ADAPTER_DEFAULT_INGRESS_TOPIC | STRING | - | NON_ORACLE | O | The topic name for the non oracle ingress feed adapter |
| ADMIN_RESPONSE_TIMEOUT_MS | INTEGER | - | 60000 | O | The timeout in receiving response from the admin service |
| ADMIN_RETRY_DELAY_MS | INTEGER | - | 5000 | O | Delay between successive retries while calling admin service |
| ADMIN_RETRY_MAXATTEMPT | INTEGER | - | 3 | O | Maximum number of retries attempted while calling admin service |
| CONFIG_NOTIFICATION_RETRY_DELAY | INTEGER | - | 50000 | O | Delay between successive notification retries to be attempted |
| CONFIG_NOTIFICATION_RETRY_MAXATTEMPT | INTEGER | - | 3 | O | The number of retries for the notification to the subscribed service instance |
| CONFIG_NOTIFICATION_SCHEDULER_INITIAL_DELAY_MS | STRING | - | 200ms | O | The initial delay for the Notification sender thread in the configuration service |
| CONFIG_NOTIFICATION_SCHEDULER_PERIOD_MS | STRING | - | 200ms | O | The notification sender thread fixed delay upon which it will check for the pending notiifications |
| CONFIGURATION_FILTER_METHODS | STRING | [GET,POST,PUT,DELETE,PATCH,CONNECT,OPTIONS,TRACE] | GET,POST,PUT,DELETE,PATCH,CONNECT,OPTIONS,TRACE | O | The configuration of methods on which the filter is possible |
| EXPORT_CONFIG_PURGE_TIMER_HR | INTEGER | [ 1-48] | 24 | O | The purge timer for the export configuration |
| EXPORT_PURGE_SCHEDULER_DELAY_MS | INTEGER | - | 30000 | O | The delay in milisec after which the purging of the export configuration will be checked. |
| logging.level.com.oracle.cgbu.cne.ocdd | STRING | - | INFO | O | Logging level for Common OCNADD services |
| logging.level.com.oracle.cgbu.cne.ocnadd | STRING | - | INFO | O | Logging level for OCNADD services |
| logging.level.reactor.netty | STRING | - | INFO | O | Netty logging level |
| logging.type | STRING | STDOUT/LOGJSON | STDOUT | O | Logging type Standard Output or JSON format |
| MAX_ACTION_TYPE_IN_FILTER | INTEGER | - | 2 | O | Maximum number of action type in a filter with chaining |
| MAX_ALLOWED_FILTERS | INTEGER | - | 30 | O | Maximum number of allowed filters |
| MAX_CORRELATION_CONFIGURATION_SUPPORTED | INTEGER | - | 3 | O | Maximum number of correlation feeds allowed |
| MAX_EXPORT_CONFIGURATION_SUPPORTED | INTEGER | - | 3 | O | The simultaneous number of export configuration supported on the Data Director |
| MAX_FILTERS_ASSOC_WITH_APP | INTEGER | - | 4 | O | Maximum number of filters associated with a single app |
| MAX_GLOBALL3L4_ROW_SIZE | INTEGER | - | 500 | O | Maximum size of L3L4 rows |
| MAX_VALUES_IN_FILTER_ATTRIB | INTEGER | - | 20 | O | Maximum number of values allowed in filter attributes |
| OCNADD_CONFIG_FILTER_NOTIF_DELAY_SEC | INTEGER | - | 3 | O | The delay between the notification to be sent to the filter service instance |
| OCNADD_CONFIG_TIMEOUT_CONNECT | STRING | - | 30s | O | The timeout for receiving no response from the server on a http connection |
| OCNADD_CONFIG_TIMEOUT_READ_IDLE | STRING | - | 30s | O | The setting (which defaults to 30 sec) dictates when to close a connection after it becomes idle |
| OCNADD_CONFIG_TIMEOUT_SSL_HANDSHAKE | STRING | - | 30s | O | The SSL connection handshake timeout in configuration service |
| OCNADD_CONFIGURATION_LIVENESS_DELAY | INTEGER | - | 600 | M | Configuration Svc Liveness Param: this field tells the kubelet that it should wait for mentioned seconds before performing the first probe. |
| OCNADD_CONFIGURATION_LIVENESS_FAILURE | INTEGER | - | 50 | M | Configuration Svc Liveness Param: For the case of a liveness probe, triggers a restart for that specific container if the container failed to start for given no of failure retries. |
| OCNADD_CONFIGURATION_LIVENESS_PERIOD_SECONDS | INTEGER | - | 15 | M | Configuration Svc Liveness Param: this field specifies that the kubelet should perform a liveness probe every given no of seconds. |
| OCNADD_CONFIGURATION_LIVENESS_TIMEOUT | INTEGER | - | 20 | M | Configuration Svc Liveness Param: Number of seconds after which the probe times out. |
| OCNADD_MAX_EXTERNAL_KAFKA_FEEDS | INTEGER | - | 2 | O | Maximum number of allowed external Kafka Feed |
| OCNADD_MAX_WORKERGROUP_THRESHOLD_PERCENTAGE | INTEGER | - | 80 | O | The percentage threshold for the maximum worker group supported |
| OCNADD_REDUNDANCY_NOTIFY_DELAY_SEC | INTEGER | - | 120 | C | Delay before updating mode of worker group from ACTIVE to STANDBY and vice-versa |
| OCNADD_TRUST_KEYSTORE | BOOLEAN | - | false | O | Truststore enable for Configuration Service |
| ocnaddconfiguration.name | STRING | - | ocnaddconfiguration | M | Name of configuration service |
| resources.limits.cpu | INTEGER | - | 1 | M | Number of maximum CPUs for each configuration service instance |
| resources.limits.ephemeralstorage | STRING | - | 500Mi | M | Ephemeral Storage for each configuration service |
| resources.limits.memory | STRING | - | 1Gi | M | Max Memory limit for each configuration service instance |
| resources.requests.cpu | INTEGER | - | 1 | M | Minimum number of CPUs required for each configuration service instance |
| resources.requests.ephemeralstorage | STRING | - | 100Mi | M | minimum Ephemeral Storage required for each configuration instance |
| resources.requests.memory | STRING | - | 1Gi | M | minimum Memory required for each configuration instance |
| SITE_REDUNDANCY_RESPONSE_TIMEOUT | INTEGER | - | 30000 | O | The timeout to get a response from the redundancy agent for the request sent from the configuration service |
| SITE_REDUNDANCY_RETRY | INTEGER | - | 3 | O | The number of retries towards the redundancy agent service |
| SITE_REDUNDANCY_RETRY_DELAY | INTEGER | - | 100 | O | Delay between successive retries to be attempted |
3.7 Health Monitoring and Alarm Service Parameters
Table 3-6 Health Monitoring Service Parameters
| Parameter Name | Data Type | Default Value | Mandatory(M)/Optional(O)/Conditional(C) | Description |
| ocnaddhealthmonitoring.name | STRING | ocnaddhealthmonitoring | M | Health monitoring service name |
| HEALTH_MONITORING_TIMER | INTEGER | 5000 | O | Timer to check Health of integrated services |
| HEALTH_METRICS_SCHEDULED | BOOLEAN | true | O | Scheduler for metrics |
| HEALTH_METRICS_TIMER | INTEGER | 120000 | O | Timer for health metrics |
| HEALTH_PURGE_TIME_HR | INTEGER | 5 | O | Health profile purging timer in hour |
| HEALTH_MONITORING_CPUTHRESHOLD | INTEGER | 75 | M | CPU threshold to raise alarm |
| HEALTH_MONITORING_MEMORYTHRESHOLD | INTEGER | 95 | M | Memory threshold to raise alarm |
| Logging Properties | ||||
| HEALTH_LOG_HTTPCLIENT | STRING | INFO | O | Set Default Log level for HTTP client |
| HEALTH_LOG_SPRING_WEB | STRING | INFO | O | Set Default Log level for Spring Web |
| logging.level.com.oracle.cgbu.cne.ocnadd | STRING | INFO | O | Logging level for Health Monitoring OCNADD Service |
| logging.level.com.oracle.cgbu.cne.ocdd | STRING | INFO | O | Logging level for Common OCNADD Service |
| HEALTH_APPLICATION_LOG_LEVEL | STRING | INFO | O | Set application logger level |
| HEALTH_LOG_REQUEST_DETAILS | BOOLEAN | true | O | If this parameter is set to true, the health request details will be logged |
| HEALTH_LOG_ROOT | STRING | WARN | O | Root Level Logger |
| resources.limits.cpu | INTEGER | 1 | M | Number of maximum CPUs for each health monitoring service instance |
| resources.limits.memory | STRING | 1Gi | M | Max Memory limit for each health monitoring service instance |
| resources.limits.ephemeralstorage | STRING | 500Mi | M | Ephemeral Storage for each health monitoring service |
| resources.requests.cpu | INTEGER | 1 | M | Minimum number of CPUs required for each health monitoring service instance |
| resources.requests.memory | STRING | 1Gi | M | minimum Memory required for each health monitoring instance |
| resources.requests.ephemeralstorage | STRING | 200Mi | M | minimum Ephemeral Storage required for each health monitoring instance |
Table 3-7 Alarm Service Parameters
| ocnaddalarm.name | STRING | - | ocnaddalarm | M | Application name for Alarm Service |
| logging.type | STRING | - | STDOUT | O | Logging Type Standard Outpuut or JSON Format |
| OCNADD_TRUST_KEYSTORE | BOOLEAN | true/false | true | O | Trust Keystore Enable |
| logging.level.com.oracle.cgbu.cne.ocnadd | STRING | - | INFO | O | Logging level for Alarm OCNADD Service |
| logging.level.com.oracle.cgbu.cne.ocdd | STRING | - | INFO | O | Logging level for Common OCNADD Service |
| resources.limits.cpu | INTEGER | - | 1 | M | Number of maximum CPUs for each alarm service instance |
| resources.limits.memory | STRING | - | 1Gi | M | Max Memory limit for each alam service instance |
| resources.limits.ephemeralstorage | STRING | - | 200Mi | M | Ephemeral Storage for each alarm service |
| resources.requests.cpu | INTEGER | - | 1 | M | Minimum number of CPUs required for each alarm service instance |
| resources.requests.memory | STRING | - | 1Gi | M | minimum Memory required for each alarm instance |
| resources.requests.ephemeralstorage | STRING | - | 200Mi | M | minimum Ephemeral Storage required for each alarm instance |
| MAX_ALARM_RETRIEVE_COUNT | INTEGER | - | 1000 | O | Parameter to fetch maximum of 1000 latest alarm for each severity type |
| OCNADD_ALARM_LIVENESS_DELAY | INTEGER | - | 60 | M | Alarm Svc Liveness Parameter: this field tells the kubelet that it should wait for mentioned seconds before performing the first probe. |
| OCNADD_ALARM_LIVENESS_PERIOD_SECONDS | INTEGER | - | 15 | M | Alarm Svc Liveness Parameter: this field specifies that the kubelet should perform a liveness probe every given no of seconds. |
| OCNADD_ALARM_LIVENESS_FAILURE | INTEGER | - | 5 | M | Alarm Svc Liveness Parameter: For the case of a liveness probe, triggers a restart for that specific container if the container failed to start for given no of failure retries. |
| OCNADD_ALARM_LIVENESS_TIMEOUT | INTEGER | - | 20 | M | Alarm Svc Liveness Parameter: Number of seconds after which the probe times out. |
3.8 Admin Service Parameters
Table 3-8 Admin Service Parameters
| Parameter Name | Data Type | Range | Default Value | M/O/C | Description |
| ocnadd.admin.name | STRING | - | ocnaddadminservice | M | Application name for the Admin Service |
| OCNADD_ADMIN_PORT | INTEGER | - | 9181 | M | Application port for the Admin Service |
| resources.limits.cpu | INTEGER | - | 1 | M | Maximum number of CPUs for each Admin Service instance |
| resources.limits.memory | STRING | - | 1Gi | M | Maximum memory limit for each Admin Service instance |
| resources.limits.ephemeralstorage | STRING | - | 200Mi | M | Ephemeral storage limit for each Admin Service instance |
| resources.requests.cpu | INTEGER | - | 1 | M | Minimum number of CPUs required for each Admin Service instance |
| resources.requests.memory | STRING | - | 1Gi | M | Minimum memory required for each Admin Service instance |
| resources.requests.ephemeralstorage | STRING | - | 200Mi | M | Minimum ephemeral storage required for each Admin Service instance |
| logging.level.com.oracle.cgbu.cne.ocdd | STRING | - | INFO | O | Logging level for common OCNADD services |
| ADMIN_SVC_LOGGER_KAFKA | STRING | [ON, OFF] | OFF | O | Whether to enable Kafka logging in the Admin Service |
| ADMIN_SVC_ROOT_LOGGER | STRING | - | WARN | O | Root logger level for the Admin Service |
| OCNADD_ADMIN_SVC_LIVENESS_DELAY | INTEGER | - | 60 | M | Time (in seconds) for the kubelet to wait before performing the first liveness probe |
| OCNADD_ADMIN_SVC_LIVENESS_PERIOD_SECONDS | INTEGER | - | 15 | M | Time interval (in seconds) between liveness probes by the kubelet |
| OCNADD_ADMIN_SVC_LIVENESS_FAILURE | INTEGER | - | 5 | M | Number of failed liveness probes before restarting the container |
| OCNADD_ADMIN_SVC_LIVENESS_TIMEOUT | INTEGER | - | 20 | M | Timeout (in seconds) for the liveness probe |
| OCNADD_ADMINSVC_HEALTH_RETRY_DELAY | INTEGER | - | 2 | M | Retry delay (in seconds) for the Admin Service connection to the health monitoring service |
| OCNADD_ADMINSVC_HEALTH_HB_TIMER | INTEGER | - | 10000 | M | Heartbeat interval (in milliseconds) for the Admin Service to the health monitoring service |
| OCNADD_ADMINSVC_HEALTH_RETRY_COUNT | INTEGER | - | 1 | M | Number of retry attempts for the Admin Service connection to the health monitoring service |
3.8.1 Consumer Aapter Parameters
Table 3-9 Consumer Aapter Parameters
| consumeradapter.resources.limits.cpu | INTEGER | - | 3 | M | Number of maximum CPUs for each admin service |
| consumeradapter.resources.limits.memory | STRING | - | 6Gi | M | Max Memory limit for each admin service instance |
| consumeradapter.resources.limits.ephemeralstorage | STRING | - | 1Gi | M | Ephemeral Storage for each admin service |
| consumeradapter.resources.requests.cpu | INTEGER | - | 3 | M | Minimum number of CPUs required for each admin service instance |
| consumeradapter.resources.requests.memory | STRING | - | 6Gi | M | minimum Memory required for each Correlation instance |
| consumeradapter.resources.requests.ephemeralstorage | STRING | - | 1Gi | M | minimum Ephemeral Storage required for each Correlation instance |
| OCNADD_CONSUMER_ADAPTER_PORT | INTEGER | - | 9182 | M | Application port for the consumer adapter |
| OCNADD_ADAPTER_HEALTH_RETRY_DELAY | INTEGER | - | 2 | M | Retry delay for the adapter service connection towards healt monitoring service |
| OCNADD_ADAPTER_HEALTH_HB_TIMER | INTEGER | - | 10000 | M | Heart beat timer in consumer adapter towards the health monitoring service |
| OCNADD_ADAPTER_HEALTH_RETRY_COUNT | INTEGER | - | 1 | M | Retry count for the adapter service connection towards health monitoring service |
| ALARM_CLIENT_RETRY_COUNT | INTEGER | - | 3 | M | Retry count for the adapter service connection towards alarm service |
| EGRESS_SSL_HANDSHAKE_TIMEOUT | INTEGER | - | 5 | O | SSL handshake timeout. |
| ENABLE_ADAPTER_COUNTER_METRICS | BOOLEAN | true/false | true | O | Enable Adapter Counter Metric. |
| OCNADD_EGRESS_NETWORK_ENABLE | BOOLEAN | true/false | false | O | Enable this parameter to true if traffic needs to be routed outside the cluster. |
| OCNADD_EGRESS_NETWORK_NAME_VALUE | STRING | - | oam | O | Name of the egress network configured in the CNE cluster. |
| OCNADD_CNC_ENABLE | STRING | - | True | O | Enable oracle.com.cnc network. |
| OCNADD_ADAPTER_MIN_REPLICAS_HTTP2 | INTEGER | - | 2 | M | Minimum Replicas for HTTP2 Adapter |
| OCNADD_ADAPTER_MAX_REPLICAS_HTTP2 | INTEGER | - | 13 | M | Max Replicas for HTTP2 Adapter |
| OCNADD_ADAPTER_MIN_REPLICAS_TCP | INTEGER | - | 1 | M | Minimum Replicas for TCP Adapter |
| OCNADD_ADAPTER_MAX_REPLICAS_TCP | INTEGER | - | 9 | M | Max Replicas for TCP Adapter |
| MAX_TCP_CONNECTION_PER_DEST | INTEGER | - | 6 | M | Max allowed TCP connection per destination |
| ADAPTER_KAFKA_FETCH_MIN_BYTES | INTEGER | - | 0 | O | The minimum amount of data the server should return for a fetch request |
| ADAPTER_KAFKA_FETCH_MAX_BYTES | STRING | - | 57672000 | O | The maximum amount of data the server should return for a fetch request |
| ADAPTER_KAFKA_MAX_PARTITION_FETCH_BYTES | STRING | - | 10485700 | O | The maximum amount of data per-partition the server will return |
| ADAPTER_KAFKA_FETCH_MAX_WAIT_MS | INTEGER | - | 40 | O | The maximum amount of time the server will block before answering the fetch request |
| ADAPTER_KAFKA_SESSION_TIME_OUT | INTEGER | - | 15000 | O | The timeout used to detect client failures when using Kafka’s group management facility |
| ADAPTER_KAFKA_HEARTBEAT_INTERVAL_MS | INTEGER | - | 5000 | O | The expected time between heartbeats to the consumer coordinator when using Kafka’s group management facilities |
| ADAPTER_KAFKA_MAX_POLL_INTERVAL_MS | INTEGER | - | 30000 | O | The maximum delay between invocations of poll() when using consumer group management |
| ADAPTER_KAFKA_MAX_POLL_RECORDS | INTEGER | - | 1500 | O | The maximum number of records returned in a single call to poll() |
| ADAPTER_KAFKA_COMMIT_INT_CONFIG | INTEGER | - | 30 | O | The frequency in milliseconds that the consumer offsets are committed to Kafka |
| ADAPTER_KAFKA_NUM_THREADS_CONFIG_HTTP2 | INTEGER | - | 9 | O | The number of threads to run stream processing for http2 connections. |
| ADAPTER_KAFKA_NUM_THREADS_CONFIG_TCP | INTEGER | - | 6 | O | The number of threads to run stream processing for tcp connections. |
| ADAPTER_KAFKA_CONSUMER_POLL_MS | INTEGER | - | 30 | O | The amount of time in milliseconds to block waiting for input. |
| ADAPTER_KAFKA_RECEIVE_BUFFER_BYTES | STRING | - | 10485700 | M | The size of the TCP receive buffer (SO_RCVBUF) to use when reading data. |
| ADAPTER_LOG_LEVEL_KAFKA | STRING | [ON,OFF] | OFF | O | Whether to ON or OFF Kafka logs in Adapter Service. |
| OCNADD_ADAPTER_MAX_REPLICAS_TCP | INTEGER | - | 2 | O | MAX replicas for synthetic Adapter. |
| OCNADD_ADAPTER_LIVENESS_DELAY | INTEGER | - | 60 | M | AdapterService Liveness Param: this field tells the kubelet that it should wait for mentioned seconds before performing the first probe. |
| OCNADD_ADAPTER_LIVENESS_PERIOD_SECONDS | INTEGER | - | 15 | M | AdapterService Liveness Param: this field specifies that the kubelet should perform a liveness probe every given number of seconds. |
| OCNADD_ADAPTER_LIVENESS_FAILURE | INTEGER | - | 5 | M | AdapterService Liveness Param: For the case of a liveness probe, triggers a restart for that specific container if the container failed to start for given number of failure retries. |
| OCNADD_ADAPTER_LIVENESS_TIMEOUT | INTEGER | - | 20 | M | AdapterService Liveness Param: Number of seconds after which the probe times out. |
| CONFIG_SVC_DATASTREAM_OFFSET_DELAY_MS | INTEGER | - | 3000 | O | Delay in milliseconds between Retries to fetch the data stream offset from config service in case of failure. |
| ADAPTER_KAFKA_LISTCONSUMER_TIMEOUT_MS | INTEGER | - | 30000 | O | Timeout in milliseconds to list the Consumer Groups. |
| KAFKA_TOPIC_NO_OF_PARTITIONS | INTEGER | - | 42 | O | Default number of partitions that will be created for a topic when a new Kafka feed is created. |
| KAFKA_TOPIC_REPLICATION_FACTOR | INTEGER | - | 1 | O | Replication Factor for the Kafka Topic of Kafka Feed. |
| KAFKA_TOPIC_RETENTION_MS | INTEGER | - | 300000 | O | Retention Time for Kafka Topic. |
| KAFKA_TOPIC_SEGMENT_MS | INTEGER | - | 300000 | O | Retention Time for the Kafka topic segment |
| EXTERNAL_CONSUMER_SASL_PORT | INTEGER | - | 9094 | O | Kafka bootstrap server port number for SASL_SSL protocol. |
| KAFKA_FUTURE_TIMEOUT_MS | INTEGER | - | 25000 | O | Timeout to fetch the admin client response details. |
| VERIFY_KAFKA_CONNECTION_TIMEOUT_MS | INTEGER | - | 10000 | O | Timeout to verify Kafka connection in milliseconds. |
| KAFKAFEED_METRICS_SCHEDULED | BOOLEAN | - | true | O | To enable or disable metrics for Kafka Feeds. |
| KAFKAFEED_METRICS_TIMER | STRING | - | 15s | O | Metrics timer for Kafka Feeds. |
| TCP_STREAM_RESET_ENABLED | BOOLEAN | - | false | O | To enable Kafka feed stream restart. This maybe required only when 3rd Party consumer is not working properly and frequently breaks connections with Synthetic Feed |
| TCP_STREAM_RESET_ELAPSED_TIME | INTEGER | - | 60 | O | The time in minutes to check if stream reset is required. |
| TCP_STREAM_RESET_FIXED_DELAY_MS | INTEGER | - | 300000 | O | Default 300 sec, Schedular Interval Time |
| TCP_STREAM_RESET_INI_DELAY_MS | INTEGER | - | 150000 | O | Default 150 sec, Schedular Initial Delay to Start |
| TCP_STREAM_RESTART_INTERVAL_MS | INTEGER | - | 300000 | O | Default 300 sec, interval to check for the TCP stream restart |
| TCP_CONN_INSPECTOR_ENABLED | BOOLEAN | true/false | true | O | The parameter to enable the watcher for the TCP connection in consumer adapter |
| OCNADD_INTERNAL_CLIENT_SSL_PROTOCOL | STRING | - | TLS | O | The SSL protocol used between the adapter and internal DD services communication |
| OCNADD_INTERNAL_CLIENT_SSL_PROTOCOLS | STRING | - | TLSv1.2,TLSv1.3 | O | The version of TLS supported between adapter and internal DD services communication |
| OCNADD_INTERNAL_CLIENT_SSL_HANDSHAKE_TIMEOUT | STRING | - | 30s | O | SSL handshake timeout between adapter and internal DD services communication |
| OCNADD_SSL_CIPHERS | STRING | - | TLS_AES_256_GCM_SHA384,TLS_AES_128_GCM_SHA256,TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256,TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 | O | Oracle Ciphers supported for the TLS communication |
| OCNADD_ADAPTER_CONFIG_RETRY_DELAY | STRING | - | 5s | M | The retry interval between adapter and configuration service communication for subscription |
| OCNADD_ADAPTER_CONFIG_RETRY_DELETE_SUBS_REQ_ATTEMPT | STRING | - | 3 | M | The number of retries supported for sending the delete subscription request to configuration service by consumer adapter service |
| OCNADD_ADAPTER_CONFIG_RETRY_DELETE_SUBS_REQ_DELAY | STRING | - | 3s | M | The retry interval supported for sending the delete subscription request to configuration service by consumer adapter service |
| EGRESS_TRUSTSTORE_ENABLED | BOOLEAN | true/false | true | M | The parameter to enable/disable the truststore between consumer adapter and 3rd party application |
| EGRESS_SSL_CLIENT_AUTH | STRING | need/want | want | M | SSL Authentication mode to be supported between consumer adapter and 3rd party communication |
| EGRESS_SSL_HANDSHAKE_TIMEOUT | STRING | - | 5s | M | SSL handshake timeout between adapter and 3rd party application communication |
| HTTP_ENABLE_SUBSCRIBE_API_ASYNC_PROCESSING | BOOLEAN | true/false | true | M | The parameter to enable the asynchronous processing of subscription request towards the configuration service |
| EGRESS_RESPONSE_IDLE_TIMEOUT_SEC | INTEGER | - | 120 | O | The setting (which defaults to 2 minutes) dictates when to close a connection after it becomes idle |
| EGRESS_RESPONSE_TIMEOUT_SEC | INTEGER | - | 8 | O | The amount of time it takes to actually receive the response back from the server, default is 8 sec |
| EGRESS_CHANNEL_TIMEOUT_SEC | INTEGER | - | 6 | O | Specifies the amount of time, in seconds, that the HTTP transport channel waits for a read request to complete on a socket after the first read occurs. Default is 6 sec |
| EGRESS_HTTP_FOLLOW_REDIRECTS | STRING | - | false | O | The parameter to indicate that consumer adapter does not want any redirections from the 3rd party applications |
| SO_SEND_BUF_BYTES_HTTP | STRING | 16777216 | O | The send socket buffer size for the HTTP connection towards 3rd party application | |
| EGRESS_KEEPALIVE_IDLE | INTEGER | - | 60 | O | The keepalive will be sent after the connection is idle for the configured seconds |
| EGRESS_KEEPALIVE_INT | INTEGER | - | 60 | O | interval between two keepalive messages |
| EGRESS_KEEPALIVE_COUNT | INTEGER | - | 10 | O | The maximum number of keepalive packets that will be sent before assuming the connection is dead |
| EGRESS_HTTP_CLIENT_MAX_CONCURRENT_HTTP_CONN | INTEGER | - | 100 | O | The maximum number of concurrent HTTP connection that can be made by http client |
| EGRESS_HTTP_MAX_CONCURR_REQ_PER_HTTP_CONN | INTEGER | - | 5 | O | The maximum number of concurrent HTTP Requests that can be sent by http client on the single http connection |
| EGRESS_MAX_CONNECTION_POOL_IDLE | INTEGER | - | 30 | O | In the http client connection pool, the connections that are not currently in use but are maintained by the pool for reuse |
| EGRESS_HTTP_CLIENT_SHUTDOWN_QUIET_PERIOD_SEC | INTEGER | - | 25 | O | Sets the amount of quiet period for shutdown of client thread pools |
| EGRESS_HTTP_CLIENT_SHUTDOWN_TIMEOUT_SEC | INTEGER | - | 30 | O | Sets the amount of time to wait for shutdown of client thread pools |
| ADAPTER_TCP_CLIENT_POOL_MAX | INTEGER | - | 1000 | O | the maximum number of concurrent TCP connections a client can establish with a server |
| ADAPTER_TCP_CLIENT_CHANNEL_TIMEOUT | INTEGER | - | 60 | O | A TCP client channel timeout occurs when a TCP client doesn't receive a response from a server within a specific timeframe, leading to the connection being terminated |
| ADAPTER_TCP_CLIENT_KEEPALIVE_IDLE | INTEGER | - | 120 | O | The keepalive will be sent after the connection is idle for the configured seconds |
| ADAPTER_TCP_CLIENT_KEEPALIVE_INT | INTEGER | - | 20 | O | interval between two keepalive messages |
| ADAPTER_TCP_CLIENT_KEEPALIVE_COUNT | INTEGER | - | 5 | O | The maximum number of keepalive packets that will be sent before assuming the connection is dead |
| ADAPTER_TCP_CLIENT_SSL_HANDSHAKE | INTEGER | - | 60 | O | The timeout for the SSL handshake to complete for the TCP connection |
| TCP_CONN_INSPECTOR_FIXED_DELAY | STRING | - | 30s | O | The delay interval after which the TCP connection watcher will keep on watching the connection |
| TCP_CONN_INSPECTOR_INI_DELAY | STRING | - | 20s | O | The initial delay after which the TCP connection watcher will start watching the connection |
| ADAPTER_TCP_CONNECT_TIMEOUT | INTEGER | - | 60 | O | The TCP connection timeout after which there is no response received from the server |
| ADAPTER_TCP_CONNECT_RETRY_MS | INTEGER | - | 1000 | O | The TCP connection retry interval |
| ADAPTER_TCP_CONNECT_MAX_RETRY_DELAY_MS | STRING | - | 120000 | O | The maximum wait for the TCP connection retry |
| TCP_SEQ_ACK_CONNECTION_MGMT_TIMER_MILLI | STRING | - | 7200000 | O | The connection management timer for the sequence acknowledgement feature in consumer adapter. It is configured in milisec |
| SYNTHETIC_SEQ_ACK_CACHE_CLEAN_DELAY_SEC | INTEGER | - | 5 | O | The timeout after which the cache cleaning will happen for the sequence ack cache |
| SYNTHETIC_SEQ_ACK_CACHE_CLEAN_PERIOD_SEC | INTEGER | - | 5 | O | The time period an entry will remain in sequence ack cache |
| SYNTHETIC_STREAM_ID_TRANSACTION_MGMT_TIMER_MILLI | INTEGER | - | 100000 | O | The connection management timer for the stream-id feature in consumer adapter. It is configured in milisec |
| SYNTHETIC_STREAM_ID_CACHE_CLEAN_DELAY_SEC | INTEGER | - | 2 | O | The timeout after which the cache cleaning will happen for the stream-id cache |
| SYNTHETIC_STREAM_ID_CACHE_CLEAN_PERIOD_SEC | INTEGER | - | 2 | O | The time period an entry will remain in stream-id cache |
| ADAPTER_KAFKA_SOURCE_TOPIC | STRING | - | MAIN | M | The topic name that consumer adapter will start reading from |
| ADAPTER_KAFKA_TOPIC_CHECK_INITIAL_DELAY | STRING | - | 120s | M | The interval after which the consumer adapter will check if the topic to consume has been created. |
| OCNADD_KAFKA_SSL_PROTOCOL | STRING | - | TLSv1.3 | M | SSL protocol configured in consumer adapter with Kafka cluster |
| ADAPTER_KAFKA_MAX_METADATA_AGE | STRING | - | 300000 | O | The time after which the consumer adapter will refresh the metadata information from the Kafka cluster |
| ENABLE_KAFKA_RECORD_TIMESTAMP_PROCESSING | BOOLEAN | true/false | true | O | The parameter to denote that Kafka record timestamp should be used in the latency calculation |
| ADAPTER_KAFKA_ENABLE_AUTO_COMMIT | BOOLEAN | true/false | false | O | The parameter to enable the autocommit of Kafka consumer offsets by the consumer adapter |
| ADAPTER_KAFKA_AUTOCOMMIT_INT_CONFIG | INTEGER | - | 0 | O | The value of autocommit interval if autocommit is enabled in the consumer adapter |
| STREAM_THREAD_DELAY_MS | INTEGER | - | 10000 | O | The initial delay in the stream processing after which the asynchronous retries will be tried. |
| ADAPTER_ASYNC_ENDPOINT_RETRY_SCH_FXD_DELAY | STRING | - | 30s | O | The delay after which the retry is done in an asynchronous communication with the 3rd party application |
| MAX_CONSECUTIVE_ERRORS_ALLOWED | INTEGER | - | 10 | O | The number of consecutive failure after which the circuit is broken |
| MAX_CONSECUTIVE_SUCCESS_REQ_ALLOWED | STRING | - | 270000 | O | The consecutive successful messages count before the circuit is deemed to be closed again |
3.8.2 Correlation Service Parameters
All the Correlation parameters are available under
ocnaddadminsvc.correlation section in ocnadd-custom-values-25.1.200.yaml file.
Table 3-10 Correlation Service Parameters
| name | STRING | - | ocnaddcorrelation | M | name of the service |
| resources.limits.cpu | INTEGER | - | 3 | M | Number of maximum CPUs for each Correlation instance |
| resources.limits.memory | STRING | - | 64Gi | M | Max Memory limit for each Correlation instance |
| resources.limits.ephemeralstorage | STRING | - | 400Mi | M | Ephemeral Storage for each Correlation instance |
| resources.requests.cpu | INTEGER | - | 3 | M | Minimum number of CPUs required for each Correlation instance |
| resources.requests.memory | STRING | - | 64Gi | M | minimum Memory required for each Correlation instance |
| resources.requests.ephemeralstorage | STRING | - | 400Mi | M | minimum Ephemeral Storage required for each Correlation instance |
| Environmental variables for Correlation service are declared under "ocnaddadminsvc.correlation.env" section | |||||
| OCNADD_CORRELATION_SVC_LIVENESS_DELAY | INTEGER | - | 60 | O | This field tells the kubelet that it should wait for mentioned seconds before performing the first probe |
| OCNADD_CORRELATION_SVC_LIVENESS_PERIOD_SECONDS | INTEGER | - | 15 | O | This field specifies that the kubelet should perform a liveness probe every given number of seconds. |
| OCNADD_CORRELATION_SVC_LIVENESS_FAILURE | INTEGER | - | 5 | O | For the case of a liveness probe, triggers a restart for that specific container if the container failed to start for given number of failure retries. |
| OCNADD_CORRELATION_SVC_LIVENESS_TIMEOUT | INTEGER | - | 20 | O | Number of seconds after which the probe times out. |
| OCNADD_CORRELATION_NAME | STRING | - | ocnaddcorrelation | M | correlation service name which will be replaced by the admin service while creating correlation configuration with new name |
| ADMIN_CORRELATION_RESOURCE_FILE | STRING | - | /tmp/ocnadd/deploy/ocnaddcorrelationservice.yaml | M | Template file for deploying correlation service through admin service. |
| OCNADD_CORRELATION_ACTIVE_PROFILE | STRING | [prod,dev] | prod | M | profile with dev or production parameters |
| OCNADD_CORRELATION_SERVER_PORT | INTEGER | - | 9664 | M | port number for correlation service |
| OCNADD_CORRELATION_HTTP2_ENABLED | BOOLEAN | [true/false] | TRUE | M | enable or disable http2 |
| OCNADD_TRUST_CLIENT_KEY_TYPE | STRING | - | PKCS12 | M | trustore client key Type |
| KAFKA_STREAM_STATE | STRING | - | /tmp/ocnadd/kafka/state | O | temporary storage for kafka state store |
| KAFKA_REPLICATION_FACTOR | INTEGER | - | 1 | O | replication factor for state store |
| KAFKA_ENABLE_AUTO_COMMIT | BOOLEAN | [true/false] | FALSE | O | enable or disable kafka auto commit |
| KAFKA_SOCKET_BYTES_BUFFER_PORTION | INTEGER | - | 100 | O | This parameter is used to multiply with KAFKA_SOCKET_BYTES_BUFFER |
| KAFKA_FETCH_MIN_BYTES | INTEGER | - | 1 | O | The minimum amount of data per-partition the server will return |
| KAFKA_FETCH_MAX_BYTES_PORTION | INTEGER | - | 100 | O | This parameter is used to multiply with KAFKA_FETCH_MAX_BYTES |
| KAFKA_MAX_PARTITIONS_FETCH_BYTES_PORTION | INTEGER | - | 10 | O | This parameter is used to multiply with KAFKA_MAX_PARTITIONS_FETCH_BYTES |
| MAX_POLL_RECORDS | INTEGER | - | 500 | O | The maximum number of records returned in a single call to poll() |
| KAFKA_OFFSET_CONFIG | STRING | - | latest | O | default kafka data stream offset config |
| KAFKA_AUTOCOMMIT_INT_CONFIG | INTEGER | - | 50 | O | It specifies how often the consumer commits its current position, which can be useful for ensuring message processing progress. |
| KAFKA_COMMIT_INT_CONFIG | INTEGER | - | 50 | O | this property will configure the interval at which Kafka consumer commits offsets. |
| KAFKA_NUMBER_THREADS_CONFIG | INTEGER | - | 6 | O | this property is used to configure the number of threads or consumers that Kafka Streams or Kafka consumers will use for processing messages |
| KAFKA_MAX_AGE_CONFIG | INTEGER | - | 7500 | O | This property will be used to set a maximum age for Kafka consumer records |
| KAFKA_CONSUMER_STRATEGY | STRING | - | org.apache.kafka.clients.consumer.RoundRobinAssignor | O | This property will be used to the strategy used for partition assignment when consuming messages from Kafka topics |
| PRODUCERS_ACKNOWLEDGMENTS | INTEGER | - | 0 | O | producer acknowledgments |
| INTERNAL_LEAVE_GROUP_ON_CLOSE | BOOLEAN | [true/false] | TRUE | O | this property controls whether the Kafka Streams application should actively leave the consumer group when it is closed or whether it should rely on the group coordinator to remove it when it becomes unresponsive |
| OCNADD_CORRELATION_HEALTH_RETRY_COUNT | INTEGER | - | 3 | O | No of times the correlation service retries for health registration in case of failure |
| OCNADD_CORRELATION_HEALTH_RETRY_DELAY | INTEGER | - | 10 | O | delay between the each retry for health registration |
| OCNADD_CORRELATION_HEALTH_HB_TIMER | INTEGER | - | 120000 | O | heart beat timer for health check |
| OCNADD_KAFKA_SSL_PROTOCOL | STRING | - | TLSv1.3 | O | SSL Protocol version |
| OCNADD_KAFKA_SECURITY_PROTOCOL_SASL | STRING | - | SASL_SSL | O | describes SASL_SSL kafka security Protocol |
| OCNADD_KAFKA_SECURITY_PROTOCOL_SSL | STRING | - | SSL | O | describes SSL kafka security Protocol |
| OCNADD_KAFKA_SASL_MECHANISM | STRING | - | PLAIN | O | describes SASL SCRAM mechanism |
| OCNADD_KAFKA_SASL_JAAS_USERNAME | STRING | - | ocnadd | O | kafka default jaas username present |
| OCNADD_KAFKA_SASL_JAAS_MODULE | STRING | - | org.apache.kafka.common.security.plain.PlainLoginModule | O | kafka Login module |
| OCNADD_KAFKA_JAAS_SECRET_KEY | STRING | - | jaas_password | O | jaas password for kafka authentication taken from the jaas-secret with this key |
| OCNADD_KAFKA_JASS_SECRET_NAME | STRING | - | jaas-secret | O | jaas-secret name |
| CORRELATION_LOG_LEVEL_KAFKA | STRING | [ON,OFF] | OFF | O | Kafka Streams Log Level |
| OCNADD_CORRELATION_LOG_ROOT | STRING | - | WARN | O | root log level |
| OCNADD_CORRELATION_LOG_NETTY | STRING | - | INFO | O | netty log level |
| logging.level.com.oracle.cgbu.cne.ocnadd | STRING | - | INFO | O | ocnadd package log level |
| logging.level.com.oracle.cgbu.cne.ocdd | STRING | - | INFO | O | ocdd package log level |
| OCNADD_TRUST_KEYSTORE | BOOLEAN | - | TRUE | O | Enable to secure connection via OCWeb Client. |
| KAFKASTREAMS_PUNCTUATOR_TIMER | INTEGER | - | 2000 | O | Kafka Stream Scheduler Timer to loop through the Local cache for Timer Expiry Scenario |
3.8.3 Storage Adapter Service Parameters
All the Storage Adapter Service parameters are available under
ocnaddadminsvc.storageadapter section in ocnadd-custom-values-25.1.200.yaml file.
Table 3-11 Storage Adapter Service Parameters
| Parameter Name | Data Type | Range | Default Value | Mandatory(M)/Optional(O)/Conditional(C) | Description |
| name | STRING | - | ocnaddstorageadapter | M | Name of the service |
| resources.limits.cpu | INTEGER | - | 3 | M | Number of maximum CPUs for each storage adapter instance. |
| resources.limits.memory | STRING | - | 64Gi | M | Maximum memory limit for each storage adapter instance. |
| resources.limits.ephemeralstorage | STRING | - | 400Mi | M | Ephemeral storage for each storage adapter instance. |
| resources.requests.cpu | INTEGER | - | 3 | M | Minimum number of CPUs required for each storage adapter instance. |
| resources.requests.memory | STRING | - | 64Gi | M | Minimum memory required for each storage adapter instance. |
| resources.requests.ephemeralstorage | STRING | - | 400Mi | M | Minimum ephemeral storage required for each storage adapter instance. |
Environmental variables for Storage Adapter service are declared under "ocnaddadminsvc.storageadapter.env" section
Table 3-12 Environmental variables for Storage Adapter service are declared under "ocnaddadminsvc.storageadapter.env" section
| OCNADD_STORAGE_ADAPTER_HTTP2_ENABLED | BOOLEAN | [true,false] | true | M | The flag to indicate if HTTP2 should be used or not. Default is true |
| STORAGE_ADAPTER_KAFKA_FETCH_MIN_BYTES | INTEGER | - | 1 | O | The minimum amount of data per-partition the server will return |
| STORAGE_ADAPTER_KAFKA_MAX_PARTITION_FETCH_BYTES | INTEGER | - | 104858 | O | The maximum amount of data per-partition the server will return. |
| STORAGE_ADAPTER_KAFKA_FETCH_MAX_WAIT_MS | INTEGER | - | 100 | O | The maximum amount of time the server will block before answering the fetch request if there isn’t sufficient data to immediately satisfy the requirement given by fetch.min.bytes |
| STORAGE_ADAPTER_KAFKA_SESSION_TIME_OUT | INTEGER | - | 90000 | O | The timeout used to detect client failures when using Kafka’s group management facility. |
| STORAGE_ADAPTER_KAFKA_HEARTBEAT_INTERVAL_MS | INTEGER | - | 30000 | O | The expected time between heartbeats to the consumer coordinator when using Kafka’s group management facilities |
| STORAGE_ADAPTER_KAFKA_MAX_POLL_INTERVAL_MS | INTEGER | - | 240000 | O | The maximum delay between invocations of poll() when using consumer group management |
| STORAGE_ADAPTER_KAFKA_MAX_POLL_RECORDS | INTEGER | - | 900 | O | The maximum number of records returned in a single call to poll() |
| STORAGE_ADAPTER_KAFKA_OFFSET_CONFIG | STRING | - | latest | O | Default Kafka data stream offset config |
| STORAGE_ADAPTER_KAFKA_NUM_THREADS_CONFIG | INTEGER | - | 6 | O | This property is used to configure the number of threads or consumers that Kafka Streams or Kafka consumers will use for processing messages |
| PRODUCERS_ACKNOWLEDGMENTS | INTEGER | - | 0 | O | Producer acknowledgments |
| STORAGE_ADAPTER_KAFKA_CONSUMER_POLL_MS | INTEGER | - | 50 | O | Polling time in ms for consumer |
| KAFKA_BATCH_SIZE | INTEGER | - | 75000 | O | The maximum amount of data to be collected before sending the batch. |
| STORAGE_ADAPTER_LOG_LEVEL_KAFKA | STRING | - | OFF | O | Kafka log level |
| OCNADD_STORAGE_ADAPTER_LOG_ROOT | STRING | - | WARN | O | root log level |
| OCNADD_STORAGE_ADAPTER_LOG_NETTY | STRING | - | INFO | O | Netty log level |
| logging.level.com.oracle.cgbu.cne.ocnadd | STRING | - | INFO | O | OCNADD package log level |
| logging.level.com.oracle.cgbu.cne.ocdd | STRING | - | INFO | O | OCNADD package log level |
| OCNADD_INTERNAL_CLIENT_SSL_PROTOCOL | STRING | - | TLS | O | The secure protocol used between Storage adapter and internal DD services for the HTTP communication |
| OCNADD_INTERNAL_CLIENT_SSL_PROTOCOLS | STRING | - | TLSv1.2,TLSv1.3 | O | The TLS version supported by HTTP client in the storage adapter service |
| OCNADD_INTERNAL_CLIENT_SSL_HANDSHAKE_TIMEOUT | STRING | - | 30s | O | The SSL handshake timeout value in the HTTP client used in the storage adapter service |
| STORAGE_ADAPTER_METRICS_ENABLED | BOOLEAN | true/false | false | O | Parameter to enable the metrics pegging for the storage adapter, defaule is false |
| STORAGE_ADAPTER_EVENT_ENABLED | BOOLEAN | true/false | true | O | Parameter to enable the events on the storage adapter, default is true |
| EVENT_DELETE_BATCH_SIZE | INTEGER | - | 5000 | O | The size of the event list that can be deleted by storage adapter, default is 5000 |
3.8.4 Ingress Adapter Service Parameters
All the Ingress Adapter Service parameters are available under
ocnaddadminsvc.ingressadapter section in ocnadd-custom-values-25.1.200.yaml file.
Table 3-13 Ingress Adapter Service Parameters
| name | STRING | - | ocnaddingressadapter | M | Name of the service |
| resources.limits.cpu | INTEGER | - | 3 | M | Number of maximum CPUs for each ingress adapter instance. |
| resources.limits.memory | STRING | - | 64Gi | M | Max Memory limit for each ingress adapter instance. |
| resources.limits.ephemeralstorage | STRING | - | 400Mi | M | Ephemeral Storage for each ingress adapter instance. |
| resources.requests.cpu | INTEGER | - | 3 | M | Minimum number of CPUs required for each ingress adapter instance. |
| resources.requests.memory | STRING | - | 64Gi | M | Minimum Memory required for each ingress adapter instance. |
| resources.requests.ephemeralstorage | STRING | - | 400Mi | M | Minimum Ephemeral Storage required for each ingress adapter instance. |
Environmental variables for Ingress
"ocnaddadminsvc.ingressadapter.env"
section |
| INGRESS_ADAPTER_PORT | INTEGER | - | 9188 | M | The port of the ingress adapter service. |
| INGRESS_ADAPTER_SERVICE_NAME | STRING | - | ocnaddingressadapter | M | Name of the service |
| OCNADD_TRUST_KEYSTORE | BOOLEAN | - | true | O | Enable to secure connection using OCWeb Client. |
| OCNADD_TRUST_CLIENT_KEY_TYPE | STRING | - | PKCS12 | M | Trust store client key Type |
| OCWEBCLIENT_TIMEOUT | INTEGER | - | 60 | Webclient timeout | |
| OCWBCLIENT_CHANNEL_TIMEOUT | INTEGER | - | 60 | O | Webclient channel timeout |
| OCWEBCLIENT_SSL_HANDSHAKE_TIMEOUT | INTEGER | - | 30 | O | SSL handshake timeout |
| OCWEBCLIENT_SSL_FLUSH_TIMEOUT | INTEGER | - | 10 | O | SSL flush timeout |
| OCWEBCLIENT_SSL_READ_TIMEOUT | INTEGER | - | 10 | O | SSL read timeout |
| INGRESS_ADAPTER_LOG_LEVEL_ROOT | STRING | - | OFF | O | Kafka log level |
| INGRESS_ADAPTER_NETTY_LOG_LEVEL | STRING | - | WARN | O | Root log level |
| INGRESS_ADAPTER_LOG_LEVEL_KAFKA | STRING | - | INFO | O | netty log level |
| INGRESS_ADAPTER_LOG_FILENAME | STRING | - | ingress-adapter.log | O | The log file name |
| OCNADD_CONSUMER_ADAPTER_HEALTH_RETRY_COUNT | INTEGER | - | 3 | O | The number of retries with the health service. |
| OCNADD_CONSUMER_ADAPTER_HEALTH_RETRY_DELAY | INTEGER | - | 10 | O | The time interval in sec between successive retries with the health service. |
| INGRESS_ADAPTER_HEALTH_HB_TIMER | INTEGER | - | 120000 | O | The heartbeat timer with the health service |
| INGRESS_ADAPTER_HTTP2_ENABLED | BOOLEAN | [true,false] | true | O | The flag to indicate if http2 should be used or not |
| INGRESS_ADAPTER_SSL_ENABLED | BOOLEAN | [true,false] | true | O | The flag to indicate if TLS should be used or not |
| INGRESS_ADAPTER_CLIENT_AUTH_CONFIG | STRING | - | want | O | Parameter to check client authentication |
| INGRESS_ADAPTER_KEYSTORE_TYPE | STRING | - | PKCS12 | M | Trust store client key Type |
| INGRESS_ADAPTER_TRUSTSTORE_TYPE | STRING | - | PKCS12 | M | Trust store key Type |
| INGRESS_HTTPSERVER_ROUTE_PATH | STRING | - | /ocnadd-nonoraclenf/v1/streaming | M | The URL at which the client should stream the data towards ingress adapter. |
| INGRESS_HTTPSERVER_READ_TIMEOUT_MS | INTEGER | - | 30000 | O | The ingress adapter read timeout in milliseconds |
| INGRESS_HTTPSERVER_REQUEST_TIMEOUT_MS | INTEGER | - | 30000 | O | The ingress adapter request timeout in milliseconds |
| INGRESS_HTTPSERVER_CONNECT_TIMEOUT_MS | INTEGER | - | 60000 | O | The ingress adapter connect timeout in milliseconds |
| INGRESS_HTTPSERVER_IDLE_TIMEOUT_MS | INTEGER | - | 120000 | O | The ingress adapter idle timeout in milliseconds |
| INGRESS_HTTPSERVER_SOCKET_RECEIVE_BUF | INTEGER | - | 10485 | O | The socket receive buffer size |
| INGRESS_HTTPSERVER_SOCKET_RECEIVE_BUF_PORTION | INTEGER | - | 100 | O | The socket receive buffer size multiple factor. The actual read buffer bytes will be ( INGRESS_HTTPSERVER_SOCKET_RECEIVE_BUF * INGRESS_HTTPSERVER_SOCKET_RECEIVE_BUF_PORTION) |
| INGRESS_HTTPSERVER_SOCKET_TIMEOUT_MS | INTEGER | - | 60000 | O | The ingress adapter socket timeout in milliseconds |
| INGRESS_HTTPSERVER_SOCKET_KEEPALIVE | BOOLEAN | [true,false] | true | O | The flag to indicate if keepalive should be used in the connection |
| INGRESS_HTTPSERVER_CLOSE_NOTIFY_FLUSH_TIIMEOUT_MS | INTEGER | - | 30000 | O | Notification flush timeout in milliseconds |
| INGRESS_HTTPSERVER_CLOSE_NOTIFY_READ_TIIMEOUT_MS | INTEGER | - | 30000 | O | Notification read timeout in milliseconds |
| INGRESS_HTTPSERVER_SSL_HANDSHAKE_TIMEOUT_MS | INTEGER | - | 30000 | O | SSL handshake timeout in milliseconds |
| KAFKA_SECURITY_PROTOCOL | STRING | - | PLAINTEXT | O | Describes kafka security Protocol |
| INGRESS_ADAPTER_SECURITY_PROTOCOL | STRING | - | SSL | O | Describes ingress adapter security Protocol |
| KAFKA_SSL_PROTOCOL | STRING | - | TLSv1.2 | O | SSL Protocol version |
| KAFKA_SASL_ENABLED | BOOLEAN | [true,false] | false | O | The flag to indicate if SASL is used for the authentication |
| KAFKA_JAAS_CONFIG_MODULE | STRING | - | org.apache.kafka.common.security.plain.PlainLoginModule | O | Kafka Login module |
| KAFKA_JAAS_CONFIG_USER | STRING | - | username | O | Kafka default jaas username |
| KAFKA_JAAS_CONFIG_PASS | STRING | - | secret | O | Kafka default jaas password |
| KAFKA_SASL_MECHANISM | STRING | - | PLAIN | O | Describes SASL SCRAM mechanism |
| externalAccess.enabled | BOOLEAN | [true,false] | false | O | The flag to indicate if external access is enabled for the ingress adapter |
| externalAccess.staticLoadBalancerIp | STRING | - | 10.10.10.1 | O | Default static loadbalancer IP address |
3.9 Kafka Configuration Parameters
Table 3-14 Kafka Configuration Parameters
| Parameter Name | Data Type | Range | Default Value | Mandatory(M)/ Optional(O)/ Conditional(C) | Description |
| kafkaBroker.kafkaProperties.logdirs | String | - | /kafka/logdir/kafka-logs | M | The path to store the Kafka logs |
| kafkaBroker.name | String | - | kafka-broker | - | Name of the Kafka broker |
| kafkaBroker.replicas | Int | - | 4 | - | The number of replicas that should be available for the pod. |
| kafkaBroker.pvcClaimSize | String | - | 10Gi | M | Size of Block Volume to attach to Kafka. |
| target.averageCpuUtilPercentage | Int | - | 50 | - | The target average CPU utilization percentage. |
| target.memoryUtilPercentage | Int | - | 80 | - | The target average memory utilization percentage. |
| kafkaBroker.resource.limits.cpu | Int | - | 5 | - | The maximum limit for the number of CPUs used for the container. |
| kafkaBroker.resource.limits.memory | String | - | 24Gi | - | The maximum limit for the size of the memory used for the container. |
| kafkaBroker.kafkaProperties.logRetentionMinutes | Int | - | 5 | M | Log Retention Time of Topic Data in Minutes. |
| kafkaBroker.kafkaProperties.kafkaSslProtocol | String | - | TLSv1.2,TLSv1.3 | M | TLS version supported. |
| kafkaBroker.kafkaProperties.socketSendBufferBytes | Int | - | 10485760 | M | TCP socket buffer sizes for the producer. |
| kafkaBroker.kafkaProperties.socketReceiveBufferBytes | Int | - | 10485760 | M | TCP socket buffer sizes for the consumer. |
| kafkaBroker.kafkaProperties.socketRequestMaxBytes | Int | - | 104857600 | M | The maximum number of bytes in a socket request. |
| kafkaBroker.kafkaProperties.queuedMaxRequests | Int | - | 4096 | M | Number of concurrent connections. |
| kafkaBroker.kafkaProperties.numIoThreads | Int | - | 820 | M | Number of threads that pick up requests from the request queue to process them. |
| kafkaBroker.kafkaProperties.numNetworkThreads | Int | - | 820 | M | Network threads handle requests to the Kafka cluster, such as produce and fetch requests from client applications. |
| kafkaBroker.kafkaProperties.numReplicaFetchers | Int | - | 640 | M | Number of fetcher threads used to replicate records from each source broker. |
| kafkaBroker.kafkaProperties.backgroundThreads | Int | - | 256 | M | The number of threads to use for various background processing tasks. |
| kafkaBroker.kafkaProperties.replicaFetchMinBytes | Int | - | 619200 | M | Minimum bytes expected for each fetch response. |
| kafkaBroker.kafkaProperties.replicaFetchMaxBytes | Int | - | 37152000 | M | The maximum number of bytes we will return for a fetch request. |
| kafkaBroker.kafkaProperties.replicaFetchWaitMaxMs | Int | - | 500 | M | The maximum wait time for each fetcher request issued by follower replicas. |
| kafkaBroker.kafkaProperties.replicaSocketReceiveBufferBytes | Int | - | 10485760 | M | The socket receive buffer for network requests. |
| kafkaBroker.kafkaProperties.offsetsTopicReplicationFactor | Int | - | 3 | M | The replication factor for the offsets' topic (set higher to ensure availability). Internal topic creation will fail until the cluster size meets this replication factor requirement. |
| kafkaBroker.kafkaProperties.transactionStateLogReplicationFactor | Int | - | 3 | M | The replication factor for the transaction topic (set higher to ensure availability). Internal topic creation will fail until the cluster size meets this replication factor requirement. |
| kafkaBroker.externalAccess.enabled | Boolean | - | false | M | Flag to enable External access for Kafka. |
| kafkaBroker.externalAccess.autoDiscovery | Boolean | - | false | M | Flag to enable auto-discovery of LoadBalancer IPs. |
| kafkaBroker.externalAccess.type | String | - | LoadBalancer | M | Service Type of Kafka Broker. |
| kafkaBroker.externalAccess.setstaticLoadBalancerIps | Boolean | - | false | M | Setting Static LoadBalancer IPs. |
| kafkaBroker.externalAccess.LoadBalancerIPList | List | - | [ ] | C | List of LoadBalancer Static IP available for use. |
3.10 UI Router Parameters
Listed below are the UI Router Parameters:
Table 3-15 UI Router Parameters
| ocnadduirouter.name | String | ocnadduirouter | M | The express application name for ocnadduirouter. | |
| Router_host | String | http://localhost | M | The Router host contains uirouter service endpoint and value of this variable can be service name, node IP, and Load Balancer IP. | |
| Router_port | String | 8080 | M | The ocnadduirouter service has exposed this specified port and this port can be used to access specific router service. | |
| DD_UIAPI | String | http://ocnaddgui:80 | M | The target endpoint of ocnaddgui service and use to configure the GUI. | |
| DD_CONFIG_API | String | http://ocnaddconfiguration:12590 | M | Target endpoint of the configuration service used to route the GUI request and forward the response. | |
| DD_ALARM_API | String | http://ocnaddalarm:9099 | M | Target endpoint of the Alarm service used to route the GUI request and forward the response. | |
| DD_HEALTH_API | String | http://ocnaddhealthmonitoring:12591 | M | Target endpoint of the Health Monitoring service used to route the GUI request and forward the response. | |
| PROMETHEUS_API | String | http://occne-kube-prom-stack-kube-prometheus.occne-infra.svc.ocnadd:80 | M | Target endpoint of the Prometheus service used to route the GUI request and forward the response.
Note: Update this parameter based on the setup. |
| DD_PROMETHEUS_PATH | String | /blurr8/prometheus/api/v1/query_range | M | The Prometheus endpoint API URL path.
3.11 Filter Service Parameters
Filter Service Parameters are present under ocnaddfilter section in ocnadd-custom-values-25.1.200.yaml file.
| name | STRING | - | ocnaddfilter | M | Name of the Service. |
| minReplicas | INTEGER | - | 1 | M | Minimum number of Replicas of Filter Service |
| maxReplicas | INTEGER | - | 3 | M | Maximum number of Replicas of Filter Service |
| resources.limits.cpu | INTEGER | - | 2 | M | Number of maximum CPUs for each Filter service instance |
| resources.limits.memory | STRING | - | 3Gi | M | Max Memory limit for each Filter service instance |
| resources.limits.ephemeralstorage | STRING | - | 800Mi | M | Ephemeral Storage for each Filter service instance |
| resources.requests.cpu | INTEGER | - | 2 | M | Minimum number of CPUs required for each Filter service instance |
| resources.requests.memory | STRING | - | 3Gi | M | Minimum Memory required for each Filter service instance |
| resources.requests.ephemeralstorage | STRING | - | 500Mi | M | Minimum Ephemeral Storage required for each Filter service instance |
| Environmental variables are present under section "ocnaddfilter.env" | |||||
| OCNADD_TRUST_KEYSTORE | BOOLEAN | [true/false] | true | O | Enable to secure connection via OCWeb Client. |
| ENABLE_FILTER_METRICS | BOOLEAN | [true/false] | true | O | To enable/disable filter metrics, default is true |
| KAFKA_PRODUCER_SSL_PROTOCOL | STRING | - | TLSv1.3 | O | Kafka SSL protocol version |
| KAFKA_PRODUCER_SSL_CLIENT_AUTH | BOOLEAN | [true/false] | false | O | Whether Kafka producer client auth is required or not |
| KAFKA_MAX_AGE_CONFIG | INTEGER | - | 7500 | O | The period of time in milliseconds after which we force a refresh of metadata. |
| KAFKA_FETCH_MAX_BYTES | STRING | - | 57672000 | O | The maximum amount of data per-partition the server will return |
| KAFKA_MAX_PARTITIONS_FETCH_BYTES | STRING | - | 1048580 | O | The maximum amount of data per-partition the server will return. |
| BATCH_SIZE | INTEGER | - | 130000 | O | The maximum amount of data to be collected before sending the batch. |
| LINGER_MS | INTEGER | - | 2 | O | The time to wait before sending messages out to Kafka |
| TRANSACTION_FILTER | BOOLEAN | [true/false] | true | O | To enable or disable transaction filtering |
| KAFKA_SOCKET_BYTES_BUFFER | STRING | - | 1048570 | O | Kafka Socket Buffer setting for consumer |
| FILTER_KAFKA_PARTITIONER_STRATEGY | STRING | [key/custom/roundrobin] | key | O | Kafka record partitioned strategy |
| OCNADD_FILTER_KAFKA_TOPIC_INITIAL_DELAY | STRING | - | 10s | O | The parameter denotes the initial delay in checking for the Kafka topic existence, default is 10sec |
| OCNADD_FILTER_KAFKA_TOPIC_RETRY_THRESHOLD | STRING | - | 20s | O | The parameter denotes the retry interval for checking the Kafka topic existence, default is 20sec |
| OCNADD_CONFIG_RETRY_COUNT | INTEGER | - | 3 | O | The number of retries for the communication towards the configuration service in case of failure, default is 3 |
| OCNADD_CONFIG_RETRY_DELAY_MS | INTEGER | - | 5000 | O | The retry interval for the communication towards the configuration service in case of failure, default is 5ms |
| KAFKA_DESCRIBE_TOPIC_TIMEOUT_MS | INTEGER | - | 10000 | O | The timeout for the request to get the Kafka describe topic output from Kafka cluster, default is 10ms |
| OCNADD_FILTER_HEALTH_SVC_TYPE | STRING | - | FILTER_SERVICE | M | The type with which filter service registers with the health monitoring service |
| OCNADD_FILTER_HEALTH_HB_TIMER | INTEGER | - | 10000 | M | The heartbeat timer on the filter service to exchange the heartbeat with the health monitoring service, default is 10sec |
| OCNADD_FILTER_HEALTH_RETRY_COUNT | INTEGER | - | 1 | M | The number of retries with the health monitoring service for the registration of filter service health profile, default is 1 |
| OCNADD_FILTER_HEALTH_RETRY_DELAY | INTEGER | - | 2 | M | The retry delay between two consecutive retries for the health profile registration of filter service, default is 2sec |
| OCNADD_FILTER_MAX_REPLICA | INTEGER | - | 1 | M | The number of maximum replicas, the health service instance reports to the health service during health profile registration. |
| OCNADD_FILTER_LIVENESS_FAILURE | INTEGER | 60 | M | Filter service Liveness Parameter : this field tells the kubelet that it should wait for mentioned seconds before performing the first probe. | |
| OCNADD_FILTER_LIVENESS_DELAY | INTEGER | 15 | M | Filter service Liveness Parameter : this field specifies that the kubelet should perform a liveness probe every given no of seconds. | |
| OCNADD_FILTER_LIVENESS_PERIOD_SECONDS | INTEGER | 5 | M | Filter service Liveness Parameter : For the case of a liveness probe, triggers a restart for that specific container if the container failed to start for given no of failure retries. | |
| OCNADD_FILTER_LIVENESS_TIMEOUT | INTEGER | 20 | M | Filter service Liveness Parameter : Number of seconds after which the probe times out. | |
| OCNADD_KAFKA_SECURITY_PROTOCOL_SASL | STRING | - | SASL_SSL | O | The Kafka security protocol for the filter service for SASL connection with Kafka |
| OCNADD_KAFKA_SECURITY_PROTOCOL_SSL | STRING | - | SSL | O | The Kafka security protocol for the filter service for SSL connection with Kafka |
| OCNADD_KAFKA_SASL_JAAS_MODULE | STRING | - | org.apache.kafka.common.security.plain.PlainLoginModule | O | Kafka Login module |
| OCNADD_KAFKA_JASS_SECRET_NAME | STRING | - | username | O | Kafka default JAAS username present |
| OCNADD_KAFKA_JAAS_SECRET_KEY | STRING | - | secret | O | Kafka default JASS password present |
| OCNADD_KAFKA_SASL_MECHANISM | STRING | - | PLAIN | O | Describes SASL SCRAM mechanism |
3.12 Redundancy Agent Service Parameters
Table 3-16 Redundancy Agent Service Parameter
| name | STRING | - | ocnaddredundancyagent | M | Name of service. |
| autoScaling.enabled | BOOLEAN | true/false | false | M | Allow HorizontalAutoScalar of
ocnaddredundancy pods.
| minReplicas | INTEGER | - | 1 | C | Number of minimum replicas for HPA. |
| maxReplicas | INTEGER | - | 1 | C | Number of maximum replicas for HPA. |
| resources.limit.cpu | INTEGER | - | 2 | M | Maximum number of CPU for each pod. |
| resources.limits.memory | STRING | 1Gi | M | Maximum memory limit for each service instance. | |
| resources.limits.ephemeralstorage | STRING | 500Mi | M | Ephemeral storage for each service instance. | |
| resources.requests.cpu | INTEGER | 2 | M | Minimum number of CPUs required for each service instance. | |
| resources.requests.memory | STRING | 1Gi | M | Minimum memory required for each service instance. | |
| resources.requests.ephemeralstorage | STRING | 500Mi | M | Minimum ephemeral storage required for each service instance. | |
| resources.target.averageCpuUtilsPercentage | INTEGER | - | 85 | C | Threshold set for Pod AutoScalar. |
| Environmental variables are present under section ocnaddredundancyagent.env | |||||
| OCNADD_REDUNDANCY_HB_INTERVAL | INTEGER | - | 10 | O | Interval of heartbeat requests sent to primary agent by secondary agent. |
| OCNADD_REDUNDANCY_HB_MISSING | INTEGER | 3 | O | Max unsuccessful heartbeat in case of secondary agent or max missing heartbeat in case of primary agent. | |
| OCNADD_REDUNDANCY_KAFKA_DELAY_MS | INTEGER | 2000 | O | Delay before starting periodic Kafka ingress traffic rate. | |
| OCNADD_REDUNDANCY_KAFKA_INTERVAL_MS | INTEGER | 500 | O | Interval of periodic Kafka ingress traffic check, will switch mode of secondary agent if change is required during the check. | |
| OCNADD_REDUNDANCY_HEALTH_RETRY_COUNT | INTEGER | 10 | O | Number of retries for Health registration. | |
| OCNADD_REDUNDANCY_HEALTH_RETRY_DELAY | INTEGER | 15 | O | Delay between each retries for Health Registration. | |
| OCNADD_REDUNDANCY_HEALTH_HB_TIMER | INTEGER | 120000 | O | Heart Beat Timer interval to health monitoring service. | |
| OCNADD_REDUNDANCY_HEALTH_SVC_TYPE | STRING | REDUNDANCY | O | Health Registration name for REDUNDANCY agent. | |
3.13 Export Service Parameters
Table 3-17 Export Service Parameters
| name | STRING | - | ocnaddexport | M | Name of service |
| autoScaling.enabled | BOOLEAN | true/false | true | M | Allow HorizontalAutoScalar of ocnaddexport service pods. |
| maxReplicas | INTEGER | - | 2 | C | Number of maximum replicas for HPA. |
| resources.limit.cpu | INTEGER | - | 6 | M | Max number of cpu for each pod. |
| resources.limits.memory | STRING | - | 24Gi | M | Max memory limit for each service instance. |
| resources.limits.ephemeralstorage | STRING | - | 2Gi | M | Ephemeral storage for each service instance. |
| resources.requests.cpu | INTEGER | - | 4 | M | Minimum number of CPUs required for each service instance. |
| resources.requests.memory | STRING | - | 4Gi | M | Minimum memory required for each service instance. |
| resources.requests.ephemeralstorage | STRING | - | 100Mi | M | Minimum ephemeral storage required for each service instance. |
| Environmental variables are present under section ocnaddexport.env | |||||
| EXPORT_WEB_LOG_LEVEL | STRING | - | INFO | O | Export service application log level |
| EXPORT_BLOCKINGQUEUE_SIZE | INTEGER | - | 10 | O | The queue size to store the result set from the database for the export. |
| EXPORT_SEQUENCING | BOOLEAN | true,false | true | O | The parameter to decide if the result set needs to be in sequence based on the record timestamp or not. |
3.14 Helm Parameter Configuration for OCCM
Table 3-18 Helm Parameter Configuration for OCCM
| global.certificates.occm.enabled | BOOLEAN | true/false | false | M | Whether to use OCCM for creating services. |
| global.certificates.occm.issuer | STRING | - | CA1 | M | Name of the Issuer configured in OCCM to use to create certificate |
| global.certificates.occm.renewBefore | INTEGER | - | 14 | M | Number of days before expiry, before which OCCM will automatically update the certificates |
| global.certificates.occm.days | INTEGER | - | 90 | M | Number of days for which certificates will be valid |
| global.certificates.occm.cncc.cncc_iam_ingress_gateway.external_ip | STRING | - | - | M | Load balancer IP address of CNCC IAM Ingress Gateway Service |
| global.certificates.occm.cncc.cncc_iam_ingress_gateway.port | INTEGER | - | 80 | M | Port of CNCC IAM Ingress Gateway Service |
| global.certificates.occm.cncc.cncc_mcore_ingress_gateway.external_ip | STRING | - | - | M | Load balancer IP address of CNCC MCORE Ingress Gateway Service |
| global.certificates.occm.cncc.cncc_mcore_ingress_gateway.port | INTEGER | - | 80 | M | Port of CNCC MCORE Ingress Gateway Service |
| global.certificates.occm.cncc.cnccId | STRING | - | Cluster1 | M | ID of CNCC owner of OCCM instance |
| global.certificates.occm.cncc.occm_cncc_instance_id | STRING | - | Cluster1-occm-instance1 | M | OCCM instance ID |
| global.certificates.occm.subject.country | STRING | - | - | M | Specify the country field (C) in DN for each certificate |
| global.certificates.occm.subject.state | STRING | - | - | M | Specify the state field (S) in DN for each certificate |
| global.certificates.occm.subject.location | STRING | - | - | M | Specify the location field (L) in DN for each certificate |
| global.certificates.occm.subject.organization | STRING | - | - | M | Specify the organization field (O) in DN for each certificate |
| global.certificates.occm.subject.country.organizationUnit | STRING | - | - | M | Specify the organization unit field (OU) in DN for each certificate |
| global.certificates.occm.occm_cacert | STRING | - | occm-ca-secret | O | Name of the Secret storing CA certificate/certificate chain. |
| global.certificates.occm.truststore_keystore_secret | STRING | - | occm-truststore-keystore-secret | O | Name of the Secret storing truststore and keystore key |
| global.certificates.occm.occm_secret | STRING | - | occm-secret | O | Name of the Secret storing CNCC user credentials |
| global.certificates.occm.occm_namespace | STRING | - | - | O | OCCM Namespace |
| global.certificates.occm.occm_service_name | STRING | - | occm | O | OCCM Kubernetes Service Name |
| global.certificates.occm.occm_port | INTEGER | - | 8989 | O | OCCM Service Port |
| global.certificates.occm.volumes.json | STRING | - | /occm-request | O | Mount path of the JSONs used when sending request to OCCM |
| global.certificates.occm.volumes.script | STRING | - | /occm-script | O | Mount path of the script used to send request to OCCM |
| global.certificates.occm.san.kafka.update_required | BOOLEAN | true/false | false | C | If update of SAN field for Kafka certificates is required. Should be enabled post-installation when external access of Kafka is required. |
| global.certificates.occm.san.kafka.ips | LIST[STRING] | - | ["10.10.10.10", "10.10.10.11", "10.10.10.12"] | C | IPs to add in SAN for Kafka certificate. Provide the Load balancer IPs during installation if static IPs for load balancer are chosen |
| global.certificates.occm.san.kafka.uuid.client | STRING | - | - | C | UUID of existing Kafka broker certificate with names prefixed by KAFKABROKER-SECRET-CLIENT |
| global.certificates.occm.san.kafka.uuid.server | STRING | - | - | C | UUID of existing Kafka broker certificate with names prefixed by KAFKABROKER-SECRET-SERVER |
| global.certificates.occm.san.redundancy_agent.update_required | BOOLEAN | true/false | false | C | If update of SAN field for Redundancy Agent certificates is required. Should be enabled post-installation when two site redundancy is enabled. |
| global.certificates.occm.san.redundancy_agent.ips | LIST[STRING] | - | ["10.10.10.10"] | C | IPs to add in SAN for Redundancy Agent certificate. Provide the Load balancer IP during installation if static IP for load balancer is chosen |
| global.certificates.occm.san.redundancy_agent.uuid.client | STRING | - | - | C | UUID of existing Redundancy Agent certificate with names prefixed by KAFKABROKER-SECRET-CLIENT |
| global.certificates.occm.san.redundancy_agent.uuid.server | STRING | - | - | C | UUID of existing Redundancy Agent certificate with names prefixed by KAFKABROKER-SECRET-SERVER |
| global.certificates.occm.san.ingress_adapter.update_required | BOOLEAN | true/false | false | C | If update of SAN field for Ingress Adapter certificates is required. Should be enabled post-installation when external access to Ingress Adapter/s is needed. |
| global.certificates.occm.san.ingress_adapter.ips | LIST[STRING] | - | ["10.10.10.10"] | C | IPs to add in SAN for Ingress Adapter certificate |
| global.certificates.occm.san.ingress_adapter.uuid.client | STRING | - | - | C | UUID of existing Ingress Adapter certificate with names prefixed by KAFKABROKER-SECRET-CLIENT |
| global.certificates.occm.san.ingress_adapter.uuid.server | STRING | - | - | C | UUID of existing Ingress Adapter certificate with names prefixed by KAFKABROKER-SECRET-SERVER |
| global.certificates.occm.keyAlgorithm | STRING | RSA/EC | RSA | C | Select OCCM key algorithm, RSA for RSA based key generation and EC for ECDSA based key generation |
| global.certificates.occm.keySize | STRING | KEYSIZE_2048/KEYSIZE_4096 | KEYSIZE_2048 | C | Defines the keySize of RSA based key generation. |
| global.certificates.occm.ecCurve | STRING | SECP384r1/SECP256r1 | SECP384r1 | C | Define the curve parameter when keyAlgorithm select is EC. |
3.15 cnDBTier Customization Parameters
The Data Director uses cnDBTier as an independent database for georedundant
sites. By default, the ocnadd_dbtier_custom_values.yaml file provided
with the OCNADD installation is for a single-site deployment of cnDBTier.
Single-site cnDBTier deployment mode: Georeplication is unavailable. Users must continue taking databse backups periodically, preferably on a daily basis, so that the same can be used when fault recovery scenarios arise. See the section "Fault Recovery" for backup options in the OCNADD.
For information about the values of the following parameters, see theocnadd_dbtier_custom_values.yaml file:
- Any change in the cnDBTier
custom_valuesfile introduced by the cnDBTier patch must be updated in thecustom_valuesfile provided by OCNADD before deployment. - For detailed information on the cnDBTier resources, see the section
"DB Profile" in the Oracle Communications Network Analytics Data Director
Benchmarking Guide. The resources in the
ocnadd_dbtier_custom_values.yamlshould match with this guide; if not, update them according to this guide.
Table 3-19 cnDBTier Customization Parameters
| Parameter | Description | Version |
global.repository |
The value should be updated to point to the actual path of your
Docker registry, for example
occne-repo-host:5000/occne |
24.3.0 |
global.sitename |
This parameter must be set to the name of the current cluster | 24.3.0 |
global.domain |
Set it to the name of the Kubernetes cluster on which cnDBTier is
installed, for example, occne1-cgbu-cne-dbtier |
24.3.0 |
global.namespace |
The Kubernetes namespace in which the cnDBTier is deployed | 24.3.0 |
global.storageClassName |
Storage class to be used. By default, |
24.3.0 |
global.mgmReplicaCount |
Default value to be used as in the file | 24.3.0 |
global.ndbReplicaCount |
The default value in the
o - Should be updated to 4 when cnDBTier is planned to be used as extended storage for xDRs - Default value (2) to be used in the file when cnDBTier is not used as extended storage |
24.3.0 |
global.ndbappReplicaCount |
Default value (2) to be used as in the file | 24.3.0 |
global.ndbappReplicaMaxCount |
Default value (4) to be used as in the file
24.3.0 |
global.apiReplicaCount |
- In the case of no replication, the minimum number of SQL nodes required is 0. |
24.3.0 |
global.ndb.datamemory |
- Should be updated to 96G when cnDBTier is planned to be used as extended storage for xDRs - Default value (1G) to be used in the file when cnDBTier is not used as extended storage |
24.3.0 |
global.mgm.ndbdisksize |
Default value (30Gi) to be used as in the file | 24.3.0 |
global.ndb.ndbdisksize |
- Should be updated to ndb.resources.limits.memory + 30Gi when cnDBTier is planned to be used as extended storage for xDRs - Default value (30Gi) to be used in the file when cnDBTier is not used as extended storage |
24.3.0 |
global.ndb.ndbbackupdisksize |
global.api.ndbdisksize |
global.ndbapp.ndbdisksize |
Default value (20Gi) to be used as in the file | 24.3.0 |
mgm.resources.limits.cpu |
Default value (1) to be used as in the file | 24.3.0 |
mgm.resources.limits.memory |
Default value (1Gi) to be used as in the file | 24.3.0 |
mgm.resources.requests.cpu |
mgm.resources.requests.memory |
ndb.resources.limits.cpu |
- Should be updated to 8 when cnDBTier is planned to be used as extended storage for xDRs - Default value (1) to be used in the file when cnDBTier is not used as extended storage |
24.3.0 |
ndb.resources.limits.memory |
- Should be updated to 128Gi when cnDBTier is planned to be used as extended storage for xDRs - Default value (4Gi) to be used in the file when cnDBTier is not used as extended storage |
24.3.0 |
ndb.resources.requests.cpu |
24.3.0 |
ndb.resources.requests.memory |
24.3.0 |
api.resources.limits.cpu |
api.resources.limits.memory |
api.resources.requests.cpu |
api.resources.requests.memory |
api.ndbapp.resources.limits.cpu |
api.ndbapp.resources.limits.memory |
api.ndbapp.resources.requests.cpu |
api.ndbapp.resources.requests.memory |
db-replicationsvc.dbreplsvcdeployments.enabled |
Default value (false) to be used as in the file | 24.3.0 |
db-replicationsvc.resources.limits.cpu |
db-replicationsvc.resources.limits.memory |
Default value (2048Mi) to be used as in the file | 24.3.0 |
db-replicationsvc.resources.requests.cpu |
Default value (0.6) to be used as in the file | 24.3.0 |
db-replicationsvc.resources.requests.memory |
Default value (1024Mi) to be used as in the file | 24.3.0 |
db-monitor-svc.resources.limits.cpu |
Default value (200m) to be used as in the file | 24.3.0 |
db-monitor-svc.resources.limits.memory |
Default value (500Mi) to be used as in the file | 24.3.0 |
db-monitor-svc.resources.requests.cpu |
db-monitorsvc.resources.requests.memory |
For more information about these parameters, see Oracle Communications Cloud Native Core cnDBTier Installation, Upgrade, and Fault Recovery Guide.
