5 Rolling Back OCNADD
This chapter describes the OCNADD rollback procedure from a target release to a previously supported version. In the current release, centralized deployment is supported, and OCNADD microservices will follow the centralized deployment mode with the management group and the worker group separation concerning microservices functions.
The rollback will be supported for the following cases:
- Upgrade was done from source releases to the target release in the Centralized deployment mode.
Table 5-1 Supported Rollback Paths
| Source Release | Target Release |
| 25.2.100 | 25.1.200 |
Rollback Steps
- (Optional) A timeout interval of 15 minutes can be set while performing an upgrade, as only one pod of the OCNADD services is upgraded at a time.
- Ensure that the status of the target version in the Helm history is not in a failed or error state. If Data Director has been integrated with a Druid cluster after upgrading to the current release and a rollback is required, it is recommended to remove all correlation and export configurations before performing the rollback.
Rollback Usecase 2: Upgrade Was Done from Source Releases (Centralized) to Target Release in the Centralized Deployment Mode
This scenario is applicable for rollback from 25.2.100 Centralized Deployment Mode to 25.1.200 Centralized Deployment Mode.To roll back to a previous working version in the target rollback release, follow these steps:
- Add back the HNC annotations
Use the following command:
kubectl hns set <child-namespace> --parent <parent-namespace>Example:kubectl hns tree ocnadd-mgmtSample Output:ocnadd-mgmt ocnadd-wg1Then run:kubectl hns set ocnadd-wg1 --parent ocnadd-mgmtVerify the changes:kubectl hns tree ocnadd-mgmtSample Output:ocnadd-mgmt +-- [s] ocnadd-wg1 - Special case – if the management namespace was also a child of another
namespace
Run the following command:
kubectl annotate namespace <child-namespace> hnc.x-k8s.io/subnamespace-of=<parent-namespace> --overwriteExample:kubectl hns tree ocnadd-siteSample Output:ocnadd-site +-- [s] ocnadd-mgmt +-- [s] ocnadd-wg1 (1)Then run:kubectl annotate namespace ocnadd-wg1 hnc.x-k8s.io/subnamespace-of=ocnadd-mgmt --overwriteVerify the changes:kubectl hns tree ocnadd-siteSample Output:ocnadd-site └── [s] ocnadd-mgmt └── [s] ocnadd-wg1 - Repeat the above steps for each worker group namespace.
Rollback of Management Group:
- In case of default worker group, first disable the Admin service in default
worker group custom_value file as
below:
global.ocnaddadmin.enabled: falseUpgrade the default worker group in the current releasehelm upgrade <ocandd-default-workergroup-release-name> <helm_chart_current_release> -n <ocndd-mgmt-namespace> -f ocnadd-custom-values-<current_release>.yaml - Check Revision of the Management Group Release to
Rollback:
helm history <ocandd-release-name> --namespace <ocndd-mgmt-namespace>Where,
<ocandd-release-name>is the release name used for management group deployment.For example:helm history ocnadd --namespace ocnadd-deploy-mgmtSample Helm history output:REVISION UPDATED STATUS CHART APP VERSION DESCRIPTION 1 Fri Jul 08 04:57:43 2025 superseded ocnadd-25.1.200 25.1.200.0.0 Install complete (revision required for rollback) 2 Fri Jul 08 05:07:43 2025 deployed ocnadd-25.2.100 25.2.100.0.0 Upgrade complete - Rollback to Required Revision of the management
release:
helm rollback <ocandd-mgmt-release-name> <REVISION> --namespace <ocndd-mgmt-namespace>Where,
<REVISION> is the revision number obtained in the previous step to which the services need to be rolled back.
For example:helm rollback ocnadd 2 --namespace ocnadd-deploy - After the successful completion of the management rollback (i.e., no service is
in the Init stage), execute the following
command:
kubectl rollout restart deployment -n <ocndd-mgmt-namespace> ocnaddconfigurationExample:kubectl rollout restart deployment -n ocnadd-deploy-mgmt ocnaddconfiguration - After restarting the configuration service, verify that all required configurations have been initialized.
Rollback of Worker Groups
- Check Revision for
Rollback:
helm history <ocandd-release-name> --namespace <ocnadd-workergroup-namespace>Where,
<ocandd-release-name>is the release name used for default worker group deployment.For example:helm history ocnadd --namespace ocnadd-deploySample Helm history output:REVISION UPDATED STATUS CHART APP VERSION DESCRIPTION 1 Fri Jul 08 04:57:43 2025 superseded ocnadd-25.1.200 25.1.200.0.0 Install complete (revision required for rollback) 2 Fri Jul 08 05:07:43 2025 superseded ocnadd-25.2.100 25.2.100.0.0 Upgrade complete 3 Fri Jul 08 05:15:43 2025 superseded ocnadd-25.2.100 25.2.100.0.0 Upgrade complete 4 Fri Jul 08 07:07:43 2025 deployed ocnadd-25.2.100 25.2.100.0.0 Upgrade complete - Rollback to Required Revision or the worker group
release:
helm rollback <ocandd-release-name> <REVISION> --namespace <ocndd-workergroup-namespace>Where,
For example:helm rollback ocnadd 2 --namespace ocnadd-deploy - Rollback Adapter Services and other services to the previous
version. Follow the below steps:
- Perform helm upgrade using the management group charts
folder:
- If no correlation configurations are
present:
helm upgrade <management-release-name> -f ocnadd-custom-values-<mgmt-group>.yaml --namespace <ocnadd-namespace> <mgmt_helm_chart> --set global.env.admin.OCNADD_ADAPTER_UPGRADE_ENABLE=trueFor example:helm upgrade ocnadd-mgmt -f ocnadd-custom-values-mgmt-group.yaml --namespace ocnadd-deploy ocnadd_mgmt --set global.env.admin.OCNADD_ADAPTER_UPGRADE_ENABLE=true - If correlation configurations are also
present:
helm upgrade <management-release-name> -f ocnadd-custom-values-<mgmt-group>.yaml --namespace <ocnadd-namespace> <mgmt_helm_chart> --set global.env.admin.OCNADD_ADAPTER_UPGRADE_ENABLE=true,global.env.admin.OCNADD_CORR_UPGRADE_ENABLE=trueNote:
If the correlation configuration was enabled for extended storage (from 24.2.0 onwards) then also use the flag "global.env.admin.OCNADD_STORAGE_ADAPTER_UPGRADE_ENABLE=true" in the above command.For example:helm upgrade ocnadd-mgmt -f ocnadd-custom-values-mgmt-group.yaml --namespace ocnadd-deploy ocnadd_mgmt --set global.env.admin.OCNADD_ADAPTER_UPGRADE_ENABLE=true,global.env.admin.OCNADD_CORR_UPGRADE_ENABLE=trueNote:
If the correlation configuration was enabled for extended storage (from 24.2.0 onwards), then also use the flagglobal.env.admin.OCNADD_STORAGE_ADAPTER_UPGRADE_ENABLE=truein the above command.helm upgrade ocnadd-mgmt -f ocnadd-custom-values-mgmt-group.yaml --namespace ocnadd-deploy ocnadd_mgmt --set global.env.admin.OCNADD_ADAPTER_UPGRADE_ENABLE=true,global.env.admin.OCNADD_CORR_UPGRADE_ENABLE=true,global.env.admin.OCNADD_STORAGE_ADAPTER_UPGRADE_ENABLE=true - If ingress adapter configurations are also
present:
helm upgrade <management-release-name> -f ocnadd-custom-values-<mgmt-group>.yaml --namespace <ocnadd-namespace> <mgmt_helm_chart> --set global.env.admin.OCNADD_ADAPTER_UPGRADE_ENABLE=true,global.env.admin.OCNADD_CORR_UPGRADE_ENABLE=true,global.env.admin.OCNADD_INGRESS_ADAPTER_UPGRADE_ENABLE=trueFor example:helm upgrade ocnadd-mgmt -f ocnadd-custom-values-mgmt-group.yaml --namespace ocnadd-deploy ocnadd_mgmt --set global.env.admin.OCNADD_ADAPTER_UPGRADE_ENABLE=true,global.env.admin.OCNADD_CORR_UPGRADE_ENABLE=true,global.env.admin.OCNADD_INGRESS_ADAPTER_UPGRADE_ENABLE=true
present:
folder:
- Check the status of the upgrade, and monitor the pods to come back to the RUNNING state.
- If the rollback is unsuccessful, see troubleshooting steps outlined in the Oracle Communications Network Analytics Data Director Troubleshooting Guide.
- On rollback completion, if the export, correlation, aggregation, ingress-adapter and/or consumer adapter services may not receive the configuration notification in timely manner and start processing data, then see the section "Invalid Subscription entry in the subscription table" in the Oracle Communication Network Analytics Troubleshooting Guide.
- If the rollback is successful and intraTLS is disabled, then create the certificates of all the OCNADD services. For required certificates, see rollbacked release Oracle Communication Network Analytics Security Guide.
