6 Uninstalling OCNADD
This chapter provides information on how to uninstall Oracle Communications Network Analytics Data Director (OCNADD).
When you uninstall a helm chart from the OCNADD deployment, it removes only the Kubernetes objects created during the installation.
kubectl commands might vary based on the platform deployment. Replace
kubectl with Kubernetes environment-specific
command line tool to configure kubernetes resources through kube-api server. The
instructions provided in this document are as per the Oracle Communications Cloud
Native Core, Cloud Native Environment (CNE) version of kube-api server.
Caution:
- While deleting any OCNADD resources make sure to provide the corresponding namespace used in the deployment.
- Based on requirement, make sure to retain the OCNADD backup before the uninstallation procedure. For more information, see Performing OCNADD Backup Procedures.
- Ensure any configured datafeeds are deleted using the OCNADD GUI prior to performing the OCNADD uninstallation steps. For deletion of the datafeeds, refer to Oracle Communications Network Analytics Data Director User Guide.
Uninstalling OCNADD in Centralized Deployment Mode
- Uninstall the worker groups one after another using the following command:
helm uninstall <worker-group-release-name> --namespace <worker-group-namespace>For example:helm uninstall ocnadd-wg1 -namespace dd-worker-group1 - Clean up Kafka Configuration for all the worker groups.
To clean up the Kafka configuration, perform the following steps for all the worker groups:
- To list the secrets in the namespace, run the following
command:
kubectl get secrets -n <worker-group-namespace> - To delete all the secrets related to Kafka, run the following
command:
kubectl delete secret --all -n <worker-group-namespace> - To delete configmap used for Kafka, run the following
command:
kubectl delete configmap --all -n <worker-group-namespace> - To delete PVCs used for Kafka,
- run the following command, and list the PVCs used in the
namespace:
kubectl get pvc -n <worker-group-namespace> - run the following command, and delete the PVCs used by the
brokers and zookeepers:
kubectl delete pvc --all -n <worker-group-namespace>
namespace:
command:
- Run the following command to delete all the objects:
- To delete all the Kubernetes
objects:
kubectl delete all --all -n <wg-group-namespace>Caution:
The command deletes all the Kubernetes objects of the specified namespace. In case, you have created the RBAC resources and service accounts before the helm installation in the same namespace, and these resources are required, then do not delete them. - Run the following command to delete the specific
resources:
kubectl delete <resource-type> <resource-name> -n <wg-group-namespace>
objects:
- Delete all the worker group's namespaces using the below
command (This step is only needed if there are more than one worker
group):
kubectl delete namesapce <worker-group-namespace>Caution:
The command removes all the resources or objects created in the namespace. Therefore, ensure that you run the command only when you want to delete the namespace completely. - Uninstall the management group using the following
command:
helm uninstall <management-release-name> --namespace <management-group-namespace>For example:helm uninstall ocnadd-mgmt --namespace dd-mgmt-group - Clean up the Database.
To clean up the database, perform the following steps:
- Log in to the MySQL client on SQL Node with the OCNADD user and
password:
mysql -h <IP_address of SQL Node> -u <ocnadduser> -p - To clean up the configuration, alarm, and health database, run the
following command: pass the database names in
mysql> drop database <dbname>; - To remove MySQL users while uninstalling OCNADD, run the following
commands:
SELECT user FROM mysql.user; DROP USER 'ocnaddappuser@'%';
password:
Verifying Uninstallation
- Check if any worker group namespaces exists
kubectl get namespaces- If the output list have any worker group
namespaces then perform the
following:
kubectl delete namespace <worker-group-namespace>Caution:
following:
- Check the management namespace
kubectl get all -n <management-group-namespace>In case of successful uninstallation, no OCNADD resource is displayed in the command output.
If the command output displays the OCNADD resources or objects, then perform the following procedure:- Run the following command to delete all the
objects:
objects:
kubectl delete all --all -n <mgmt-group-namespace>Caution:
specific
resources:
kubectl delete <resource-type> <resource-name> -n <management-group-namespace> - Run the following command to delete the
management group
namespace:
kubectl delete namespace <management-group-namespace>For example:kubectl delete namespace ocnadd-deployCaution:
objects:
objects:
