About the Atomic Action Editor Context Menu
The Atomic Action editor context menu contains actions specific to simple and structured data elements. To access these actions, you right-click in the Parameters area in the Parameters tab. The context menu options that are available depend on the selection in the area. For example, the list of context menu options that appear when you have a data element actively selected is different from the list that appears when no data element in the area is selected.
Field | Use |
Select Simple Element |
Add a simple data element to the atomic action entity. See "Adding Existing Simple and Structured Data Elements to Entities" for more information. |
Select Structured Element |
Add a structured data element to the atomic action entity. See "Adding Existing Simple and Structured Data Elements to Entities" for more information. |
Delete |
Deletes data elements from the entity. |
Move Up and Move Down |
Repositions a data element in the Parameters area by moving it up or down in the list. |
Refactoring |
Select to access a menu of options for improving names and locations of the data elements. See "Refactoring Entities and Data Elements" for more information. |
Expand |
Expands a structured data element to display all child elements of the structure. |
Collapse |
Collapses a structured data element to hide all child elements of the structure. |
Refresh |
Refreshes the view. |
Related Topics
