Atomic Action Editor
Use the Atomic Action editor to define activation run-time type parameters, define a routing type, and map the atomic action to one or more action processors.
For atomic actions generated by Design Studio from CTM Templates for IP Service Activator, see "IP Service Activator Atomic Action Editor".
You can create the Atomic Action editor using the Atomic Action Wizard. In the Studio Projects view, double-click an atomic action entity to open the editor.
See the following topics:
