Service Action Editor Realization Tab
Use the Service Action editor Realization tab to associate ASAP service actions with a conceptual model technical action.
Field | Use |
Realizes |
Click to open the selected technical action in the Action editor. |
Select |
Associates the ASAP service action with a conceptual model technical action. To select from the available conceptual model technical actions, there must be a dependency defined between your ASAP cartridge project and the Model project in which your conceptual model is saved. See "Managing Project Dependencies" for more information. |
