Atomic Action Editor Parameters Tab
Use the Parameters tab to add data elements from the Data Dictionary and configure values to the ASAP run-time type parameters.
In Activation, the Enumeration, Tags, and Usage tabs are not applicable.
When working with the Parameters tab, see the following topics:
