Details Tab
Use the Details tab to edit the data element display name and define specific constraint values. When you select a data element in the Parameters area, the details for the selected data element appear in the Parameter Details area.
Field Use
Select
(Optional) Select a data element that exists in the Data Dictionary, in case you want the selected parameter, in the Parameters area, to behave like a data element in the data schema. Click the Type label to open the data element.
Primitive Type
Displays the data type for simple data elements as in the data schema.
Name
Displays the name of the data element as in the data schema.
Display Name
Edit the data element display name. The Atomic Action editor supports multiple languages for this field. The field adjacent to Display Name displays your language. You can define a Display Name field value for any language you select from the list.
If your preferences are set up to work in one language only, the system displays only the [default] option. See "Defining Language Preferences" for more information.
Path
Displays to which atomic action the parameter belongs.This field is read only.
Namespace
Not applicable in Activation.
Multiplicity
Select any one of the following:
  • Required: If the required parameters are not available, ASAP will not validate the work orders. The minimum and maximum values are both 1.
  • Optional: If the optional parameters are not available, ASAP will proceed validating the work orders. The minimum value is 0 and maximum value is 1.
  • Range: You can change Minimum, Maximum, and Unbounded only when you select Range. Depending on the minimum value, multiplicity will be either required or optional for an ASAP server. If minimum is 0, multiplicity is an optional parameter for ASAP. If minimum is greater than 0, multiplicity is a required ASAP parameter. Multiplicity can be seen in the build artifact file of the atomic actions in the generated SAR file.
Abstract and Internal
Deprecated
Select to discourage use to the data element.
Length
Specify the minimum and maximum length for String data type. This field is read only for data elements that inherit from a parent element.
You must define the minimum and maximum lengths with a non-negative integer between 0 and 999999999. Select Unbounded to define the maximum length as 999999999.
Default
Specify a default value. If there is no value in the work order for the parameter the default value is used.
