Configuring Directory Number Routing
To configure DN routing:
In the Studio Projects view, double-click a DN routing map entity.
The DN Routing Map editor appears.
In the Description field, specify the description for the editor.
In the DN Routing Details area, click Add.
A new row with default values appears.
Click the row to edit the DN routing details.
This enables the fields in the Routing Map Details area for this specific row.
In the Routing Map Details area, for the specific row, specify the values for the NPA, NXX, Min Line, and Max Line fields.
The range for NPA and NXX is from 100 to 999 and for Min Line and Max Line is from 1000 to 9999.
(Optional) Click the … button and select an atomic action that you want to route using DN.
Click the … button and select a network element to which you want to route the atomic action.
Select File, then select Save.
